    4. [gelöst] regex
    [gelöst] regex
      mike1976 last edited by
      Geht leider nicht.
      Das ist der Quelltext der seite:
      <!DOCTYPE html>
      <html lang="en">
        <head>
          <meta charset="utf-8" />
          <meta name="viewport" content="width=device-width, initial-scale=1.0" />
          <title>AQI</title>
          <script src="aqi.js"></script>
          <link rel='stylesheet' href='style.css'>
        </head>
        <body>
          <div class="container">
            <h1>AQI</h1>
            <p class='time' id="time"></p>
            <div class='aqi-container' id="containerPm25">
                <div class='aqi-label'>AQI (PM2.5)</div>
                <div class='aqi' id="aqiPm25"></div>
                <div class='pm-label' id="pm25"></div>
            </div>
            <div class='aqi-container' id="containerPm10">
                <div class='aqi-label'>AQI (PM10)</div>
                <div class='aqi' id="aqiPm10"></div>
                <div class='pm-label' id="pm10"></div>
            </div>
          </div>
        </body>
        <script type="text/javascript">
          getData();
          setInterval(getData, 60000);
        </script>
      </html>
      H crycode 2 Replies Last reply Reply Quote 0
        hans_999 @mike1976 last edited by
        @mike1976 said in regex:
        Geht leider nicht.
        Das schaut aber auch nicht so aus wie im Screenshot oben!
        Wo ist denn jetzt der Wert
        id="aqiPm10" class="aqi">9</div>
        geblieben?
          mike1976 last edited by mike1976
          der wird zwischen >< hinterlegt von diesem code:
          #!/usr/bin/python
          # coding=utf-8
          # "DATASHEET": http://cl.ly/ekot
          # https://gist.github.com/kadamski/92653913a53baf9dd1a8
          from __future__ import print_function
          import serial, struct, sys, time, json
          DEBUG = 0
          CMD_MODE = 2
          CMD_QUERY_DATA = 4
          CMD_DEVICE_ID = 5
          CMD_SLEEP = 6
          CMD_FIRMWARE = 7
          CMD_WORKING_PERIOD = 8
          MODE_ACTIVE = 0
          MODE_QUERY = 1
          ser = serial.Serial()
          ser.port = "/dev/ttyUSB0"
          ser.baudrate = 9600
          ser.open()
          ser.flushInput()
          byte, data = 0, ""
          def dump(d, prefix=''):
              print(prefix + ' '.join(x.encode('hex') for x in d))
          def construct_command(cmd, data=[]):
              assert len(data) <= 12
              data += [0,]*(12-len(data))
              checksum = (sum(data)+cmd-2)%256
              ret = "\xaa\xb4" + chr(cmd)
              ret += ''.join(chr(x) for x in data)
              ret += "\xff\xff" + chr(checksum) + "\xab"
              if DEBUG:
                  dump(ret, '> ')
              return ret
          def process_data(d):
              r = struct.unpack('<HHxxBB', d[2:])
              pm25 = r[0]/10.0
              pm10 = r[1]/10.0
              checksum = sum(ord(v) for v in d[2:8])%256
              return [pm25, pm10]
              #print("PM 2.5: {} μg/m^3  PM 10: {} μg/m^3 CRC={}".format(pm25, pm10, "OK" if (checksum==r[2] and r[3]==0xab) else "NOK"))
          def process_version(d):
              r = struct.unpack('<BBBHBB', d[3:])
              print("Y: {}, M: {}, D: {}, ID: {}, CRC={}".format(r[0], r[1], r[2], hex(r[3]), "OK" if (checksum==r[4] and r[5]==0xab) else "NOK"))
          def read_response():
              byte = 0
              while byte != "\xaa":
                  byte = ser.read(size=1)
              d = ser.read(size=9)
              if DEBUG:
                  dump(d, '< ')
              return byte + d
          def cmd_set_mode(mode=MODE_QUERY):
              ser.write(construct_command(CMD_MODE, [0x1, mode]))
              read_response()
          def cmd_query_data():
              ser.write(construct_command(CMD_QUERY_DATA))
              d = read_response()
              values = []
              if d[1] == "\xc0":
                  values = process_data(d)
              return values
          def cmd_set_sleep(sleep=1):
              mode = 0 if sleep else 1
              ser.write(construct_command(CMD_SLEEP, [0x1, mode]))
              read_response()
          def cmd_set_working_period(period):
              ser.write(construct_command(CMD_WORKING_PERIOD, [0x1, period]))
              read_response()
          def cmd_firmware_ver():
              ser.write(construct_command(CMD_FIRMWARE))
              d = read_response()
              process_version(d)
          def cmd_set_id(id):
              id_h = (id>>8) % 256
              id_l = id % 256
              ser.write(construct_command(CMD_DEVICE_ID, [0]*10+[id_l, id_h]))
              read_response()
          if __name__ == "__main__":
              while True:
                  cmd_set_sleep(0)
                  cmd_set_mode(1);
                  for t in range(15):
                      values = cmd_query_data();
                      if values is not None:
                          print("PM2.5: ", values[0], ", PM10: ", values[1])
                          time.sleep(2)
                  # open stored data
                  with open('/var/www/html/aqi.json') as json_data:
                      data = json.load(json_data)
                  # check if length is more than 100 and delete first element
                  if len(data) > 100:
                      data.pop(0)
                  # append new values
                  data.append({'pm25': values[0], 'pm10': values[1], 'time': time.strftime("%d.%m.%Y %H:%M:%S")})
                  # save it
                  with open('/var/www/html/aqi.json', 'w') as outfile:
                      json.dump(data, outfile)
                  print("Going to sleep for 5min...")
                  cmd_set_mode(0);
                  cmd_set_sleep()
                  time.sleep(300)
          es geht um einen sds011 sensor, habe das script direkt am pi hinterlegt.
          sicherlich würde es leichter gehen wenn ich den wert bei node-red einlesen würde.
          Einlesen klappt ja eigentlich auch,
          Bin aber leider zu blöd das ich den Sensor in sleep modus bekomme.
          Deswegen eigentlich der umweg über die web seite.
          Ausser du kannst mir veraten wie ich den sleep modus aktiviere und deaktiviere über node red.
          Hier die Node-red variate, wie gesagt der sensor ist verbunden und liefert auch die benötigeten werte, doch leider
          bekomme ich den befehl nicht hin das er für eine zeit in sleep modus geht 😞
          oder hast du eine idee wie der befehl aussehen müsste?
          • crycode
            crycode Developer @mike1976 last edited by
            @mike1976
            Wie @hans_999 schon geschrieben hat sieht der HTML Code jetzt anders aus, als in deinem ersten Post.
            Wenn die Zahl dann an der entsprechenden Stelle steht solle dazu dann dieser RegEx passen:
            /<[^>]*id=['"]aqiPm10['"][^>]*>(\d+)<\/\w+>/
            Siehe auch https://regex101.com/r/a41Fp3/2
            Der findet eine Zahl innerhalb eines beliebigen Tags (in deinem Code das div) mit der ID aqiPm10, unabhängig davon, ob der Tag noch andere Attribute hat oder ob " oder ' für die Attribute verwendet wird.
            Dein Screenshot sieht nach dem den Parser-Adapter aus. Ich bin mir nicht sicher, aber kann sein, dass du da den RegEx ohne die / am Anfang und Ende eingeben musst.
            Bezüglich Node-red kann ich dir leider nicht weiterhelfen.
              mike1976 @crycode last edited by
              @crycode
              Okay auf https://regex101.com/r/a41Fp3/2 geht es,
              doch leider will der Adapter nicht.
              habe es mit
              und ohne
              getestet, immer das gleiche. noch eine idee?
                Homoran Global Moderator Administrators @mike1976 last edited by Homoran
                @mike1976 sagte in regex:
                Dann brauchen wir den "echten" quellcode.
                mit dem geposteten kann ich das nicht nachvollziehen
                Beim Parser gibt es den ein oder anderen feinen Unterschied im Vergleich zu regex101
                Wahrscheinlich liegt es nur am Format.
                Ich habe mal den folgenden Wert (10.50) genommen:
                <!DOCTYPE html>
                <html lang="en">
                  <head>
                    <title>AQI</title>
                  </head>
                  <body>
                      <h1>AQI</h1>
                      </div>
                          <div class='aqi' id="aqiPm10">10.50</div>
                      </div>
                    </div>
                  </body>
                    getData();
                  </script>
                </html>
                Und mit dem regex <[^>]*id="aqiPm10">(\d+\.\d+)<\/div> ausgelesen
                Auch die genauen Einstellungen im Adapter wären interessant
                  @Homoran
                  testpi.dyndns-at-home.com:56000
                  habe ich mal freigeschalten. kannst direkt auf die webseite
                  Quellcode:
                  aqi.py
                  einstellungen von adapter habe ich oben einen screen gemacht. gibt ja nicht viele punkte
                  crycode 1 Reply Last reply Reply Quote 0
                    und das ist die export file des adapters:
                    system.adapter.parser.0.json
                    • crycode
                      @mike1976
                      Das Problem an der Stelle ist, dass der eigentliche Wert gar nichtdirekt im HTML Code steht, sondern per JavaScript aus der Datei api.json geladen wird. Versuch mal als URL http://192.168.1.241/api.json und als RegEx den: {"pm10":\s+(\d+(\.\d+)?)[^}]*}]
                      Das sollte dann jeweils den letzten (aktuellsten) Wert auslesen, egal ob es nun z.B. 9 oder 9.5 ist.
                      Beispiel: https://regex101.com/r/a41Fp3/3
                      Alternativ könnte man sicherlich auch über den JavaScript Adapter direkt die JSON-Datei laden und daraus dann den gewünschten Wert extrahieren.
                        @crycode said in regex:
                        Leider nein der aufruf geht auch nicht 😞
                        wenn ich im den link so teste bzw. öffne bekomme ich nur 404 not found
                        okay muss einsehen das es für mich leider nicht möglich sein wird den wert in iobroker zu bekommen.
                        Danke an euch allen für euer rasches bemühen.
                        lg mike
                        • crycode
                          @mike1976 ups, mein Fehler... das sollte aqi.json heißen. Dann müsste er die Datei auch finden 😉
                            @crycode
                            okay damit liest der adapter jetzt die seite ein, aber er will mir einfach keinen wert geben.
                            Hast recht auf https://regex101.com/r/a41Fp3/3 geht es einwandfrei.
                            Habe jetzt alle varianten gesteset im adapter:
                            boolean
                            number(.)
                            number(,)
                            string
                            JSON
                            eigentlich müsste der type ja nummer(.) sein, aber nicht um die bohne das er mir einen wert gibt
                              update bekomme jetzt einen wert 🙂
                              habe bei den einstellungen noch Num 4 drinnen stehen
                              geändert auf 0 und siehe da es kommt was rein.
                              ich weis das kling jetzt sicherlich frech aber wie könnte ich jetzt immer die letzten werte von
                              pm25 und seperat pm10 haben.
                              im moment ist es ja immer der von pm10.
                              Man Tausend dank erstmal 🙂
                                Denke habe es hinbekommen
                                geändert auf
                                "pm25":\s+(\d+(\.\d+)?)[^}]*}]
                                  Danke das auslesen der "µg/m³" geht nun einwandfrei.
                                  Ist es eigentlich möglich den "AQI (PM2.5)" und den "AQI (PM15)" auch auszulesen?
                                  in http://192.168.1.241/aqi.json wird der ja nicht augelistet.
                                  Das sind die Webseiten auf den das script aufbaut:
                                  $ wget -O /var/www/html/index.html https://raw.githubusercontent.com/zefanja/aqi/master/html/index.html
                                  $ wget -O /var/www/html/aqi.js https://raw.githubusercontent.com/zefanja/aqi/master/html/aqi.js
                                  $ wget -O /var/www/html/style.css https://raw.githubusercontent.com/zefanja/aqi/master/html/style.css
                                  • crycode
                                    crycode Developer @mike1976 last edited by crycode
                                    @mike1976 Das sieht doch schon mal gut aus 🙂
                                    Direkt auslesen kannst du die beiden Werte nicht, da die ja nicht so in den Daten enthalten sind.
                                    Du kannst die Berechnung aber in ioBroker über ein Script nachbilden und die Ergebnisse dann eigene Datenpunkte schreiben.
                                    Dann wäre aber wieder der oben schon mal erwähnte Weg direkt die JSON-Datei zu laden die schönere und zuverlässigere Variante.
                                    Das Script dazu sieht dann so aussehen:
                                    // URL von der die JSON-Daten geladen werden
                                    const url = 'http://192.168.1.241/aqi.json';
                                    // Datenpunkte (javascript.0.XX)
                                    const objPm10 = 'aqi.pm10';
                                    const objPm25 = 'aqi.pm25';
                                    const objAqiPm10 = 'aqi.aqiPm10';
                                    const objAqiPm25 = 'aqi.aqiPm25';
                                    // Objekete anlegen, falls nicht vorhanden
                                    createState(objPm10, { name: 'PM10', unit: 'µg/m³', type: 'number', role: 'value' });
                                    createState(objPm25, { name: 'PM2.5', unit: 'µg/m³', type: 'number', role: 'value' });
                                    createState(objAqiPm10, { name: 'AQI (PM10)', type: 'number', role: 'value' });
                                    createState(objAqiPm25, { name: 'AQI (PM2.5)', type: 'number', role: 'value' });
                                    // alle 5 Sekunden die Daten laden
                                    schedule('*/5 * * * * *', loadData);
                                     * Funktion zum Laden der Daten.
                                    function loadData () {
                                      request(url, (err, res, body) => {
                                        if (err) {
                                          log(err.toString(), 'error');
                                          return;
                                        const data = JSON.parse(body);
                                        const pm10 = data[data.length -1].pm10;
                                        const pm25 = data[data.length -1].pm25;
                                        const aqiPm10 = calcAQIpm10(pm10);
                                        const aqiPm25 = calcAQIpm25(pm25);
                                        // Log-Ausgabe zum Testen
                                        // log(`pm10: ${pm10}, pm25: ${pm25}, aqiPm10: ${aqiPm10}, aqiPm25: ${aqiPm25}`);
                                        setState(objPm10, pm10, true);
                                        setState(objPm25, pm25, true);
                                        setState(objAqiPm10, aqiPm10, true);
                                        setState(objAqiPm25, aqiPm25, true);
                                     * Berechnung von AQI PM 2.5.
                                     * Quelle: https://github.com/zefanja/aqi/blob/master/html/aqi.js#L55
                                    function calcAQIpm25(pm25) {
                                      let pm1 = 0;
                                      let pm2 = 12;
                                      let pm3 = 35.4;
                                      let pm4 = 55.4;
                                      let pm5 = 150.4;
                                      let pm6 = 250.4;
                                      let pm7 = 350.4;
                                      let pm8 = 500.4;
                                      let aqi1 = 0;
                                      let aqi2 = 50;
                                      let aqi3 = 100;
                                      let aqi4 = 150;
                                      let aqi5 = 200;
                                      let aqi6 = 300;
                                      let aqi7 = 400;
                                      let aqi8 = 500;
                                      let aqipm25 = 0;
                                      if (pm25 >= pm1 && pm25 <= pm2) {
                                        aqipm25 = ((aqi2 - aqi1) / (pm2 - pm1)) * (pm25 - pm1) + aqi1;
                                      } else if (pm25 >= pm2 && pm25 <= pm3) {
                                        aqipm25 = ((aqi3 - aqi2) / (pm3 - pm2)) * (pm25 - pm2) + aqi2;
                                      } else if (pm25 >= pm3 && pm25 <= pm4) {
                                        aqipm25 = ((aqi4 - aqi3) / (pm4 - pm3)) * (pm25 - pm3) + aqi3;
                                      } else if (pm25 >= pm4 && pm25 <= pm5) {
                                        aqipm25 = ((aqi5 - aqi4) / (pm5 - pm4)) * (pm25 - pm4) + aqi4;
                                      } else if (pm25 >= pm5 && pm25 <= pm6) {
                                        aqipm25 = ((aqi6 - aqi5) / (pm6 - pm5)) * (pm25 - pm5) + aqi5;
                                      } else if (pm25 >= pm6 && pm25 <= pm7) {
                                        aqipm25 = ((aqi7 - aqi6) / (pm7 - pm6)) * (pm25 - pm6) + aqi6;
                                      } else if (pm25 >= pm7 && pm25 <= pm8) {
                                        aqipm25 = ((aqi8 - aqi7) / (pm8 - pm7)) * (pm25 - pm7) + aqi7;
                                      return Math.round(aqipm25);
                                     * Berechnung von AQI PM 10.
                                     * Quelle: https://github.com/zefanja/aqi/blob/master/html/aqi.js#L94
                                    function calcAQIpm10(pm10) {
                                      let pm1 = 0;
                                      let pm2 = 54;
                                      let pm3 = 154;
                                      let pm4 = 254;
                                      let pm5 = 354;
                                      let pm6 = 424;
                                      let pm7 = 504;
                                      let pm8 = 604;
                                      let aqi1 = 0;
                                      let aqi2 = 50;
                                      let aqi3 = 100;
                                      let aqi4 = 150;
                                      let aqi5 = 200;
                                      let aqi6 = 300;
                                      let aqi7 = 400;
                                      let aqi8 = 500;
                                      let aqipm10 = 0;
                                      if (pm10 >= pm1 && pm10 <= pm2) {
                                        aqipm10 = ((aqi2 - aqi1) / (pm2 - pm1)) * (pm10 - pm1) + aqi1;
                                      } else if (pm10 >= pm2 && pm10 <= pm3) {
                                        aqipm10 = ((aqi3 - aqi2) / (pm3 - pm2)) * (pm10 - pm2) + aqi2;
                                      } else if (pm10 >= pm3 && pm10 <= pm4) {
                                        aqipm10 = ((aqi4 - aqi3) / (pm4 - pm3)) * (pm10 - pm3) + aqi3;
                                      } else if (pm10 >= pm4 && pm10 <= pm5) {
                                        aqipm10 = ((aqi5 - aqi4) / (pm5 - pm4)) * (pm10 - pm4) + aqi4;
                                      } else if (pm10 >= pm5 && pm10 <= pm6) {
                                        aqipm10 = ((aqi6 - aqi5) / (pm6 - pm5)) * (pm10 - pm5) + aqi5;
                                      } else if (pm10 >= pm6 && pm10 <= pm7) {
                                        aqipm10 = ((aqi7 - aqi6) / (pm7 - pm6)) * (pm10 - pm6) + aqi6;
                                      } else if (pm10 >= pm7 && pm10 <= pm8) {
                                        aqipm10 = ((aqi8 - aqi7) / (pm8 - pm7)) * (pm10 - pm7) + aqi7;
                                      return Math.round(aqipm10);
                                    Die beiden Funktionen calcAQIpm25 und calcAQIpm10 sind direkt aus der aqi.js übernommen. Ich habe dabei lediglich den Rückgabewert angepasst, sodass immer eine Zahl ohne Nachkommastellen zurückgegeben wird.
                                    Die Daten sind dann unter javascript.0.aqi.* verfügbar. 🙂
                                      @crycode
                                      Ähhh... Was soll ich sagen ausser 1000 mal Danke.
                                      Das funktioniert einwandfrei 😄 😄
                                      Hatte die hoffnung schon aufgegeben.
                                      Kommer leider aus der SPS welt und script mässig ein kompleter noob.
                                      Danke nochmal hast mir einen riesen schritt weitergeholfen, jetzt muss ich nur noch eine vernünftige Wochenzeitschaltuhr für die Vis finden.
                                      GLG Mike
                                      PS: Danke für deine Zeit und Hilfe
                                      79.9k
                                      communication
                                      1034
