    4. Test Adapter HeatingControl v2.12.x
    • Rene_HM
      Rene_HM Developer @Wolf-unterwegs last edited by
      @Wolf-unterwegs evtl. hilft ein "Upload":
      Admin sollte in 0.3.5 so aussehen:
      P W 2 Replies Last reply Reply Quote 0
        jake @Rene_HM last edited by
        @Rene_HM
        ich hoffe ich hab alles erwischt
        "Path2PresentDP": {"en": "Path2PresentDP", "de": "Path2PresentDP", "ru": "Path2PresentDP", "pt": "Path2PresentDP", "nl": "Path2PresentDP", "fr": "Path2PresentDP", "es": "Path2PresentDP", "pl": "Path2PresentDP", "it": "Path2PresentDP", "zh-cn": "Path2PresentDP"}, translate.js:24:17
        "UseFixHeatingPeriod": {"en": "UseFixHeatingPeriod", "de": "UseFixHeatingPeriod", "ru": "UseFixHeatingPeriod", "pt": "UseFixHeatingPeriod", "nl": "UseFixHeatingPeriod", "fr": "UseFixHeatingPeriod", "es": "UseFixHeatingPeriod", "pl": "UseFixHeatingPeriod", "it": "UseFixHeatingPeriod", "zh-cn": "UseFixHeatingPeriod"}, translate.js:24:17
        "FixHeatingPeriodStart": {"en": "FixHeatingPeriodStart", "de": "FixHeatingPeriodStart", "ru": "FixHeatingPeriodStart", "pt": "FixHeatingPeriodStart", "nl": "FixHeatingPeriodStart", "fr": "FixHeatingPeriodStart", "es": "FixHeatingPeriodStart", "pl": "FixHeatingPeriodStart", "it": "FixHeatingPeriodStart", "zh-cn": "FixHeatingPeriodStart"}, translate.js:24:17
        "FixHeatingPeriodEnd": {"en": "FixHeatingPeriodEnd", "de": "FixHeatingPeriodEnd", "ru": "FixHeatingPeriodEnd", "pt": "FixHeatingPeriodEnd", "nl": "FixHeatingPeriodEnd", "fr": "FixHeatingPeriodEnd", "es": "FixHeatingPeriodEnd", "pl": "FixHeatingPeriodEnd", "it": "FixHeatingPeriodEnd", "zh-cn": "FixHeatingPeriodEnd"}, translate.js:24:17
        "WindowIsOpen": {"en": "WindowIsOpen", "de": "WindowIsOpen", "ru": "WindowIsOpen", "pt": "WindowIsOpen", "nl": "WindowIsOpen", "fr": "WindowIsOpen", "es": "WindowIsOpen", "pl": "WindowIsOpen", "it": "WindowIsOpen", "zh-cn": "WindowIsOpen"}, translate.js:24:17
        "Select": {"en": "Select", "de": "Select", "ru": "Select", "pt": "Select", "nl": "Select", "fr": "Select", "es": "Select", "pl": "Select", "it": "Select", "zh-cn": "Select"}, translate.js:24:17
        "Edit Room:": {"en": "Edit Room:", "de": "Edit Room:", "ru": "Edit Room:", "pt": "Edit Room:", "nl": "Edit Room:", "fr": "Edit Room:", "es": "Edit Room:", "pl": "Edit Room:", "it": "Edit Room:", "zh-cn": "Edit Room:"}, translate.js:24:17
        "id": {"en": "id", "de": "id", "ru": "id", "pt": "id", "nl": "id", "fr": "id", "es": "id", "pl": "id", "it": "id", "zh-cn": "id"}, 3 translate.js:24:17
        "Ok": {"en": "Ok", "de": "Ok", "ru": "Ok", "pt": "Ok", "nl": "Ok", "fr": "Ok", "es": "Ok", "pl": "Ok", "it": "Ok", "zh-cn": "Ok"}, translate.js:24:17
        ##on change index_m.html:262:21
        show actor settings index_m.html:91:25
        hide sensors settings index_m.html:104:25
        got instance heatingcontrol.0 index_m.html:294:29
        got rooms {"list":[{"name":"Wohnzimmer","isActive":false,"WindowIsOpen":false,"TempOverride":false,"TempOverrideDue":""},{"name":"Arbeitszimmer","isActive":false,"WindowIsOpen":false,"TempOverride":false,"TempOverrideDue":""},{"name":"Flur","isActive":false,"WindowIsOpen":false,"TempOverride":false,"TempOverrideDue":""}],"newRooms":0} index_m.html:179:25
        tableRoomsOnReady index_m.html:335:21
        got functions [{"name":"Licht"},{"name":"Heizung"},{"name":"Verschluss"},{"name":"Zentrale"}]
        • Rene_HM
          Rene_HM Developer @jake last edited by
          @jake mit dem Log sollte eigentlich mindestens die Zimmer-Liste angezeigt werden. Wie sieht bei dir diese Seite aus?
            @Rene_HM
              @Rene_HM
              Problem gelöst: ich habe den kompletten iobroker.heatingcontrol Ordner unter Nodes_modules von Hand gelöscht und nochmal neu installiert. Jetzt kommen die Räume sofort.
              Evtl. ist da mal eine Installation nicht komplett durchgelaufen?
              Danke für Deine Hilfe!
              • V
                vogtländer @Rene_HM last edited by
                @Rene_HM
                Super!
                Aber ich finde die Vor-Einstellung nicht.
                • Rene_HM
                  Rene_HM Developer @vogtländer last edited by
                  @vogtländer gleiches Problem wie hier?
                  https://forum.iobroker.net/topic/22579/test-adapter-heatingcontrol-v0-3-x/380
                  • V
                    @Rene_HM
                    Danke ich hab's
                      Pittini Developer @Rene_HM last edited by
                      @Rene_HM Im Admin ist alles soweit deutsch, warum heißt die neue Einstellung jetzt "TemperatureDecrease" und nicht z.B. "Temperatur Absenkung"?
                      • V
                        @Rene_HM
                        Hallo ich hab die Änderung "absolute Temperatur" getestet. Ich denke da stimmt etwas noch nicht oder ich mache was falsch. Wenn ich in den Party-Modus schalte werden die Temperaturen geändert aber es wird nicht die Party-Temperatur sondern die ReducedTemperature verwendet. Im Gästet-Modus ändert sich keine der Temperaturen. Alle mit der Einstellung absolut im Admin.
                        • Rene_HM
                          @vogtländer Party-Modus ist genau so implementiert: wenn Party dann reduzierte Temperatur. Ich habe derzeit nur eine reduzierte Temperatur, die in allen Fällen (Party, Abwesenheit, Fenster offen, ..) verwendet wird. Gäste-Modus im "absolut"-Betrieb fehlt. Soll ich hier wieder relativ anheben, oder besser auch eine feste Temperatur vorgeben?
                            loi83 last edited by
                            Servus, ich bin echt begeistert von dem Adapter.Vielen dank erstmal dafür.
                            Nun habe ich aber gleich mal an Anliegen. Ich habe ein Homematic Wandthermostat mit dem ein Aktor geschalten wird. Dieser Aktor schaltet die Umwälzpumpe für die Fußbodenheizung An/Aus. Bis jetzt hab ich das eher mäßig zufriedenstellend über ein Script gelöst, wäre das auch mit dem Adapter möglich? Dann hätte ich noch gerne gewusst wie ich den ical adapter einbinden kann, so das der Urlaub auch berücksichtigt wird.
                            Gruß Michi
                            • Rene_HM
                              Rene_HM Developer @loi83 last edited by
                              @loi83 ical - Einbindung fehlt noch, das habe ich aber noch vor...
                              Bzgl. der Fußbodenheizung bin ich nicht sicher, ob ich richtig verstanden habe... Wenn die Pumpe laufen soll, wenn geheizt werden muss, kannst du einfach die Option "Use Actors" verwenden. Dann steuert der Adapter die Pumpe basierend auf Soll und Ist vom Thermostat. Der Aktor muss dann einfach für den jeweiligen Raum konfiguriert werden und die o.g. Option muss im Admin eingeschaltet werden. Derzeit ist die Regelung aber sehr einfach gehalten (ein wenn Soll größer als Ist und aus wenn Ist größer als Soll).
                                loi83 @Rene_HM last edited by
                                @Rene_HM ich glaub du hast mich richtig verstanden.
                                Zeigt das Thermostat 23° soll die Fußbodenheizung aus gehen, also Aktor auf Aus und wenn die Temperatur 22° hat, wieder einschalten.
                                • Rene_HM
                                  @loi83 genau das macht der Adapter...
                                  • Z
                                    zahnheinrich @Rene_HM last edited by zahnheinrich
                                    @Rene_HM sagte in Test Adapter HeatingControl v0.3.x:
                                    ... Gäste-Modus im "absolut"-Betrieb fehlt. Soll ich hier wieder relativ anheben, oder besser auch eine feste Temperatur vorgeben?
                                    Bitte absolut anheben!
                                    Geht der Gästemodus dann auch für einzelne Räume? (Gästezimmer)
                                    Bisher wirkt der Datenpunkt "GuestsPresent" wohl global oder?
                                    • V
                                      vogtländer @zahnheinrich last edited by
                                      @Rene_HM
                                      Hallo ich weiß wir stellen hohe Ansprüche ich würde es so machen:
                                      absolute Vorgabetemperatur für Party (PartyDecrease)
                                      absolute Vorgabetemperatur für Gäste (GuestIncrease)
                                      absolute Vorgabetemperatur für Fenster (WindowOpenDecrease)
                                      Diese Temperaturen sind pro Zimmer einstellbar und werden bis zu Aufhebung
                                      der jeweiligen Option für beibehalten. Ich weiß das ist viel Arbeit aber dann
                                      wäre es richtig rund.
                                        Wolf-unterwegs @Rene_HM last edited by
                                        @Rene_HM
                                        Super, der Tip hat das Problem gelöst.
                                        Wie von vogtländer vorgeschlagen, finde ich z.B. eine Gastkennung pro Zimmer auch sehr hilfreich.
                                        Wir haben ein Zimmer und ein Bad für Gäste. Das sollte bei Besuch anders beheizt werden, als z.B. das Wohnzimmer.
                                        Dein Adapter und die bisherige Funktionalität gefällt mir aber sehr gut.
                                        Wolfgang
                                          Pittini Developer last edited by
                                          Ich hab mich heute auch mal an die neue Version gemacht, hat mich bisher anhand der Datenpunktänderung etwas abgeschreckt (muß immer Vis für 9 Räume anpassen und das je einmal für Übersicht und Detailanzeige). Leider komm ich gar nicht klar mit der absoluten Absenkung. Aber vielleicht versteh ich auch nur was nicht. Ich ging davon aus, dass der Datenpunkt "ReducedTemperature" eine Temp beinhaltet welche bei Fensteröffnung gesetzt wird, unabhängig von der eingestellten Normaltemp. Also hab ich dort mal 15° eingestellt. Diese Temp wird auch gesetzt - und zwar sofort, ohne Fensteröffnung und zack - wurde es ganz schön frisch in der Bude. Ist das jetzt ein Bug oder versteh ich die Funktion falsch oder verwende ich nen falschen Datenpunkt?
                                          • Rene_HM
                                            @Wolf-unterwegs , @vogtländer dann werde ich das ganze mal so umbauen...
                                            @zahnheinrich
                                            Bisher wirkt der Datenpunkt "GuestsPresent" wohl global oder? >
                                            Die Einstellung der Temperatur gilt pro Raum, "GuestPresent" ist global. Bei relativer Absenkung / Anhebung kann man einfach 0K eingeben, für Räume die nicht verändert werden sollen. Das kann ih auch bei absoluter Absenkung/Erhöhung machen, d.h. nur verändern, wenn die ReducedTemperature nicht null ist...
                                            heating
                                            236
                                            3158
                                            1959191
