    4. Test Adapter fb-checkpresence v0.1.x
      ple last edited by ple
      2019-11-18 15:57:04.968 - info: fb-checkpresence.0 (18758) Got terminate signal TERMINATE_YOURSELF
      2019-11-18 15:57:04.970 - info: fb-checkpresence.0 (18758) cleaned everything up...
      2019-11-18 15:57:04.970 - info: fb-checkpresence.0 (18758) terminating
      2019-11-18 15:57:04.970 - info: fb-checkpresence.0 (18758) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2019-11-18 15:57:05.567 - info: host.iobroker instance system.adapter.fb-checkpresence.0 terminated with code 156 (156)
      2019-11-18 15:57:07.482 - info: host.iobroker instance system.adapter.fb-checkpresence.0 started with pid 25639
      2019-11-18 15:57:08.218 - debug: fb-checkpresence.0 (25639) Redis Objects: Use Redis connection: 127.0.0.1:6379
      2019-11-18 15:57:08.237 - debug: fb-checkpresence.0 (25639) Objects client ready ... initialize now
      2019-11-18 15:57:08.239 - debug: fb-checkpresence.0 (25639) Objects create PubSub Client
      2019-11-18 15:57:08.239 - debug: fb-checkpresence.0 (25639) Objects client initialize lua scripts
      2019-11-18 15:57:08.247 - debug: fb-checkpresence.0 (25639) objectDB connected
      2019-11-18 15:57:08.248 - debug: fb-checkpresence.0 (25639) Redis States: Use Redis connection: 127.0.0.1:6379
      2019-11-18 15:57:08.250 - debug: fb-checkpresence.0 (25639) Objects connected to redis: 127.0.0.1:6379
      2019-11-18 15:57:08.252 - debug: fb-checkpresence.0 (25639) States create PubSub Client
      2019-11-18 15:57:08.253 - debug: fb-checkpresence.0 (25639) statesDB connected
      2019-11-18 15:57:08.264 - debug: fb-checkpresence.0 (25639) States connected to redis: 127.0.0.1:6379
      2019-11-18 15:57:08.333 - info: fb-checkpresence.0 (25639) starting. Version 0.0.7 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v10.16.3
      2019-11-18 15:57:08.364 - info: fb-checkpresence.0 (25639) start fb-checkpresence: ip-address: xxxxxxx polling interval: 1 (*/1 * * * *)
      2019-11-18 15:57:08.367 - debug: fb-checkpresence.0 (25639) createGlobalObjects
      2019-11-18 15:57:08.698 - debug: fb-checkpresence.0 (25639) body response: {"statusCode":200,"body":"\n\n\n\n16\n\n\n","headers":{"date":"Mon, 18 Nov 2019 14:57:08 GMT","server":"FRITZ!Box Fon WLAN 7270 v3 UPnP/1.0 AVM FRITZ!Box Fon WLAN 7270 v3 74.06.06","connection":"close","content-length":"345","content-type":"text/xml; charset=\"utf-8\"","ext":""},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"xxxxxxxxxxxxxxxx:49000/upnp/control/hosts"},"method":"POST","headers":{"SoapAction":"urn:dslforum-org:service:Hosts:1#GetHostNumberOfEntries","Content-Type":"text/xml","charset":"utf-8","content-length":448}}}
      16
      2019-11-18 15:57:08.705 - debug: fb-checkpresence.0 (25639) getHostNo: 16
      2019-11-18 15:57:08.714 - debug: fb-checkpresence.0 (25639) state fb-checkpresence.0.devices changed: 16 (ack = true)
      2019-11-18 15:57:08.714 - debug: fb-checkpresence.0 (25639) state fb-checkpresence.0.info.connection changed: true (ack = true)
      2019-11-18 15:57:08.715 - debug: fb-checkpresence.0 (25639) state fb-checkpresence.0.info.lastUpdate changed: 2019-11-18T14:57:08.368Z (ack = true)
      2019-11-18 15:57:08.716 - debug: fb-checkpresence.0 (25639) body response: {"statusCode":500,"body":"\n\n\n\ns:Client\nUPnPError\n\n\n401\nInvalid Action\n\n\n\n\n","headers":{"date":"Mon, 18 Nov 2019 14:57:08 GMT","server":"FRITZ!Box Fon WLAN 7270 v3 UPnP/1.0 AVM FRITZ!Box Fon WLAN 7270 v3 74.06.06","connection":"close","content-length":"433","content-type":"text/xml; charset=\"utf-8\""},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"xxxxxxxxxxxx:49000","port":"49000","hostname":"xxxxxxxxxxxxxx","hash":null,"search":null,"query":null,"pathname":"/upnp/control/hosts","path":"/upnp/control/hosts","href":"http://xxxxxxxxxxxxxxxxx:49000/upnp/control/hosts"},"method":"POST","headers":{"SoapAction":"urn:dslforum-org:service:Hosts:1#X_AVM-DE_GetHostListPath","Content-Type":"text/xml","charset":"utf-8","content-length":452}}}
      s:Client
      UPnPError
      401
      Invalid Action
      2019-11-18 15:57:08.717 - error: fb-checkpresence.0 (25639) soapAction error undefined
      2019-11-18 15:57:08.718 - error: fb-checkpresence.0 (25639) Error checkPresence: TypeError: Cannot read property 'message' of undefined
      2019-11-18 15:57:08.718 - debug: fb-checkpresence.0 (25639) checkPresence first run
      2019-11-18 15:57:08.729 - debug: fb-checkpresence.0 (25639) state fb-checkpresence.0.info.connection changed: false (ack = true)
      2019-11-18 15:57:09.532 - debug: fb-checkpresence.0 (25639) system.adapter.admin.0: logging true
      afuerhoff 1 Reply Last reply Reply Quote 0
      • afuerhoff
        afuerhoff Developer @ple last edited by afuerhoff
        @ple
        Gib mal bitte diese URL ein: http://fritz.box:49000/hostsSCPD.xml
        In der angezeigten XML Datei müsste folgender Abschnitt zu finden sein:
        <action>
        <name>X_AVM-DE_GetHostListPath</name>
        <argumentList>
        <argument>
        <name>NewX_AVM-DE_HostListPath</name>
        <direction>out</direction>
        <relatedStateVariable>X_AVM-DE_HostListPath</relatedStateVariable>
        </argument>
        </argumentList>
        </action>
        Das ist die Funktion, die laut Log unbekannt sein soll.
        Ist sie in der XML Datei vorhanden?
        Welche Version hat deine Fritzbox? Die Funktion gibt es erst seit dem 18.07.2016 laut AVM in der TR064 Spezifikation.
          ple last edited by
          ja dann ist die 7270 V3 raus, firmware von 20-Oct-2015. Hatte ich mir schon fast gedacht. Solltest vielleicht auf Github das eben erwähnen.,nicht das noch einer auf die Idee kommt wie ich mit einer uralten Fritte das zu realisieren 🙂
          dann mach ich mich mal auf der Suche nach einer anderen Fritte. Melde mich dann wieder.
          Gruß und besten Dank.
          • afuerhoff
            @ple
            Ich hab schon überlegt, ob ich eine Abfrage der in der Fritzbox hinterlegten Dienste mit einbaue und nach Verfügbarkeit dann Funktionen hinzu nehme + Hinweis im Log.
              ple last edited by
              Joar, wäre hilfreich. Hoffe ich komme morgen dazu die andere Box Inbetrieb zu nehmen.
                Bias last edited by
                Hi @afuerhoff , existiert dieser Adapter noch oder ist gerade möglicherweise etwas kaputt?
                Sowohl mein Ubuntu-Terminal(npm install ioBroker.fb-checkpresence) als auch meine Browser sagen, es existiert nichts unter:
                https://www.npmjs.com/package/iobroker.fb-checkpresence
                Da ich blutiger ioBroker- und Ubuntu-Anfänger bin, schließe ich ein Layer 8-Problem nicht aus 😉
                • Negalein
                  Negalein Global Moderator @Bias last edited by
                  @Bias sagte in [Neuer Adapter] iobroker.fb-checkpresence:
                  nichts kaputt.
                  Musst ihn nur richtig installieren.
                  Siehe 1. Beitrag!
                    Bias @Negalein last edited by Bias
                    @Negalein übersehe ich was? Ich folge dem Link im ersten Beitrag auf GitHub und führe das darin genannte Command aus. : "npm install ioBroker.fb-checkpresence". Das Terminal schmeißt dann Fehler, da der o.g. Link nicht erreichtbar ist . Eine Installation über die "Katze" ist nicht möglich, da nichts gefunden wird, das mit "fb" beginnt.
                    • Negalein
                      Du musst "Beliebig" nehmen!
                        @Negalein Danke – das kannte ich noch nicht! 🤦 Funktioniert!
                        Kannst Du mir erklären, warum man den eindeutig auf GitHub liegenden Adapter nicht "Von GitHub" installieren kann?
                        SBorg apollon77 2 Replies Last reply Reply Quote 0
                        • SBorg
                          SBorg Forum Testing Most Active @Bias last edited by
                          @Bias Bin zwar nicht @Negalein , aber "Von GitHub" ist nur für die offiziell releasten Versionen, nicht für Betas, in Entwicklung befindliche usw. Adapter.
                            apollon77 @Bias last edited by
                            @Bias Weil der Adater noch nicht im Repository ist was Du gewählt hast, damit ist es nicht in der Liste drin und daher geht es nur per "Beliebig"
                            • afuerhoff
                              afuerhoff Developer last edited by
                              ich habe die Version 0.1.0 veröffentlicht.
                              Änderungen:
                              • InfluxDB implementiert (konnte ich allerdings nicht testen)
                              • Debug Informationen optimiert
                              Viel Spaß beim Testen
                                e-s @afuerhoff last edited by
                                @afuerhoff
                                Habe die neue Version noch nicht getestet. Vorhin habe ich eine aktuelle Beta auf meine 7490 gespielt, danach ist mir aufgefallen, wie stark das log mit Fehlermeldungen von deinem Apapter zugebombt wurde. Durch das Update ist lange kein Internet vorhanden und dann auch der Router selbst nicht erreichbar, das sollte dann irgendwie abgefangen werden.
                                • afuerhoff
                                  afuerhoff Developer @e-s last edited by
                                  @e-s
                                  Auf welcher Logstufe steht die Instanz?
                                    @afuerhoff
                                    auf info, aber die logeinträge waren alles errors, z.B.:
                                    fb-checkpresence.0	2019-11-25 09:05:18.616	error	(6207) soapAction error: Error: connect ECONNREFUSED 192.168.2.1:49000
                                    fb-checkpresence.0	2019-11-25 09:05:18.606	error	(6207) Error getActive: undefined
                                    fb-checkpresence.0	2019-11-25 09:05:18.606	error	(6207) soapAction error: Error: connect ECONNREFUSED 192.168.2.1:49000
                                    fb-checkpresence.0	2019-11-25 09:05:18.597	error	(6207) Error getActive: undefined
                                    fb-checkpresence.0	2019-11-25 09:05:18.596	error	(6207) soapAction error: Error: connect ECONNREFUSED 192.168.2.1:49000
                                    fb-checkpresence.0	2019-11-25 09:05:18.587	error	(6207) Error getActive: undefined
                                    fb-checkpresence.0	2019-11-25 09:05:18.587	error	(6207) soapAction error: Error: connect ECONNREFUSED 192.168.2.1:49000
                                    fb-checkpresence.0	2019-11-25 09:05:18.577	error	(6207) Error getActive: undefined
                                    fb-checkpresence.0	2019-11-25 09:05:18.576	error	(6207) soapAction error: Error: connect ECONNREFUSED 192.168.2.1:49000
                                    fb-checkpresence.0	2019-11-25 09:05:18.564	error	(6207) Error getActive: undefined
                                    fb-checkpresence.0	2019-11-25 09:05:18.564	error	(6207) soapAction error: Error: connect ECONNREFUSED 192.168.2.1:49000
                                    fb-checkpresence.0	2019-11-25 09:05:18.544	error	(6207) Error getActive: undefined
                                    fb-checkpresence.0	2019-11-25 09:05:18.544	error	(6207) soapAction error: Error: connect ECONNREFUSED 192.168.2.1:49000
                                    fb-checkpresence.0	2019-11-25 09:05:18.536	error	(6207) Error getActive: undefined
                                    fb-checkpresence.0	2019-11-25 09:05:18.534	error	(6207) soapAction error: Error: connect ECONNREFUSED 192.168.2.1:49000
                                    fb-checkpresence.0	2019-11-25 09:05:18.517	error	(6207) Error getActive: undefined
                                    fb-checkpresence.0	2019-11-25 09:05:18.511	error	(6207) soapAction error: Error: connect ECONNREFUSED 192.168.2.1:49000
                                    fb-checkpresence.0	2019-11-25 09:05:18.499	error	(6207) Error getActive: undefined
                                    fb-checkpresence.0	2019-11-25 09:05:18.498	error	(6207) soapAction error: Error: connect ECONNREFUSED 192.168.2.1:49000
                                    und das dauerhaft bis wieder die fritz da war.
                                    • afuerhoff
                                      @e-s
                                      Ich überlege mir mal was.
                                      • afuerhoff
                                        Hallo, hat schon jemand InfluxDB getestet?
                                        • Z
                                          zahnheinrich @afuerhoff last edited by zahnheinrich
                                          @afuerhoff
                                          Jupp:
                                          Bekomme für beide devices: No history before this day is available (lastVal = null)
                                          obwohl der Adapter schon einige Tage rennt ohne Fehlermeldungen.
                                          Das debug-log:
                                          fb-checkpresence.0	2019-12-09 15:19:00.883	debug	state fb-checkpresence.0.TerrysSamsungS7.historyHtml changed: <table class="mdui-table"><thead><tr><th>Status</th><th>Date</th></tr></thead><tbody><tr><td><div class="mdui-green-bg mdui-state mdui-car
                                          fb-checkpresence.0	2019-12-09 15:19:00.883	debug	state fb-checkpresence.0.TerrysSamsungS7.history changed: [{"Active":"true","Date":"2019.12.09 03:18:17"},{"Active":"true","Date":"2019.12.09 02:39:00"},{"Active":"false","Date":"2019.12.09 02:37:00"}
                                          fb-checkpresence.0	2019-12-09 15:19:00.883	debug	state fb-checkpresence.0.TerrysSamsungS7.absent.sum_day changed: 179 (ack = true)
                                          fb-checkpresence.0	2019-12-09 15:19:00.882	debug	state fb-checkpresence.0.TerrysSamsungS7.present.sum_day changed: 740 (ack = true)
                                          fb-checkpresence.0	2019-12-09 15:19:00.882	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.historyHtml {"val":"<table class=\"mdui-table\"><thead><tr><th>Status</th><th>Date</th></tr></thead><tbody><tr><td><div cl
                                          fb-checkpresence.0	2019-12-09 15:19:00.881	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.history {"val":"[{\"Active\":\"true\",\"Date\":\"2019.12.09 03:18:17\"},{\"Active\":\"true\",\"Date\":\"2019.12.09 02:39:0
                                          fb-checkpresence.0	2019-12-09 15:19:00.881	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.absent.sum_day {"val":179,"ack":true,"ts":1575901140874,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.us
                                          fb-checkpresence.0	2019-12-09 15:19:00.881	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.present.sum_day {"val":740,"ack":true,"ts":1575901140873,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.u
                                          fb-checkpresence.0	2019-12-09 15:19:00.875	info	TerrysSamsungS7: No history before this day is available (lastVal = null)
                                          fb-checkpresence.0	2019-12-09 15:19:00.875	debug	redis pmessage messagebox.system.adapter.fb-checkpresence.0 messagebox.system.adapter.fb-checkpresence.0 {"command":"getHistory","message":{"result":[{"ack":true,"from":"system.adapter.influxdb.0","q
                                          fb-checkpresence.0	2019-12-09 15:19:00.860	debug	sendTo "getHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
                                          fb-checkpresence.0	2019-12-09 15:19:00.860	debug	redis pmessage messagebox.system.adapter.fb-checkpresence.0 messagebox.system.adapter.fb-checkpresence.0 {"command":"getHistory","message":{"result":[{"val":true,"ts":1575824521227},{"ack":true,"from
                                          fb-checkpresence.0	2019-12-09 15:19:00.860	debug	state fb-checkpresence.0.presence changed: true (ack = true)
                                          fb-checkpresence.0	2019-12-09 15:19:00.859	debug	state fb-checkpresence.0.presenceAll changed: true (ack = true)
                                          fb-checkpresence.0	2019-12-09 15:19:00.858	debug	state fb-checkpresence.0.html changed: <table class="mdui-table"><thead><tr><th>Name</th><th>Status</th><th>Kommt</th><th>Geht</th></tr></thead><tbody><tr><td>UlisSamsungS7</td><td><div class="mdui-gr
                                          fb-checkpresence.0	2019-12-09 15:19:00.858	debug	state fb-checkpresence.0.json changed: [{"Name":"UlisSamsungS7","Active":"true","Kommt":"2019.12.09 01:48:00","Geht":"2019.12.09 01:46:00"},{"Name":"TerrysSamsungS7","Active":"true","Kommt":"2019.12.0
                                          fb-checkpresence.0	2019-12-09 15:19:00.858	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.presence {"val":true,"ack":true,"ts":1575901140843,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.admin","lc":157589
                                          fb-checkpresence.0	2019-12-09 15:19:00.858	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.presenceAll {"val":true,"ack":true,"ts":1575901140843,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.admin","lc":157
                                          fb-checkpresence.0	2019-12-09 15:19:00.857	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.html {"val":"<table class=\"mdui-table\"><thead><tr><th>Name</th><th>Status</th><th>Kommt</th><th>Geht</th></tr></thead><tbody><tr><td>Uli
                                          fb-checkpresence.0	2019-12-09 15:19:00.857	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.json {"val":"[{\"Name\":\"UlisSamsungS7\",\"Active\":\"true\",\"Kommt\":\"2019.12.09 01:48:00\",\"Geht\":\"2019.12.09 01:46:00\"},{\"Name\
                                          fb-checkpresence.0	2019-12-09 15:19:00.849	debug	checkPresence scheduled
                                          fb-checkpresence.0	2019-12-09 15:19:00.848	debug	sendTo "getHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
                                          fb-checkpresence.0	2019-12-09 15:19:00.847	debug	history start
                                          fb-checkpresence.0	2019-12-09 15:19:00.846	debug	state fb-checkpresence.0.TerrysSamsungS7.absent.since changed: 0 (ack = true)
                                          fb-checkpresence.0	2019-12-09 15:19:00.845	debug	state fb-checkpresence.0.TerrysSamsungS7.present.since changed: 40 (ack = true)
                                          fb-checkpresence.0	2019-12-09 15:19:00.844	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.absent.since {"val":0,"ack":true,"ts":1575901140834,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.a
                                          fb-checkpresence.0	2019-12-09 15:19:00.844	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.present.since {"val":40,"ack":true,"ts":1575901140834,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user
                                          fb-checkpresence.0	2019-12-09 15:19:00.843	debug	getActive [{"Name":"UlisSamsungS7","Active":"true","Kommt":"2019.12.09 01:48:00","Geht":"2019.12.09 01:46:00"},{"Name":"TerrysSamsungS7","Active":"true","Kommt":"2019.12.09 02:39:00","Geht":"2019.12.0
                                          fb-checkpresence.0	2019-12-09 15:19:00.834	debug	getActive TerrysSamsungS7 1
                                          fb-checkpresence.0	2019-12-09 15:19:00.833	debug	body response: {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n <s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:
                                          fb-checkpresence.0	2019-12-09 15:19:00.801	debug	state fb-checkpresence.0.UlisSamsungS7.historyHtml changed: <table class="mdui-table"><thead><tr><th>Status</th><th>Date</th></tr></thead><tbody><tr><td><div class="mdui-green-bg mdui-state mdui-card"
                                          fb-checkpresence.0	2019-12-09 15:19:00.801	debug	state fb-checkpresence.0.UlisSamsungS7.history changed: [{"Active":"true","Date":"2019.12.09 03:18:17"},{"Active":"true","Date":"2019.12.09 01:48:00"},{"Active":"false","Date":"2019.12.09 01:46:00"},{
                                          fb-checkpresence.0	2019-12-09 15:19:00.801	debug	state fb-checkpresence.0.UlisSamsungS7.absent.sum_day changed: 644 (ack = true)
                                          fb-checkpresence.0	2019-12-09 15:19:00.801	debug	state fb-checkpresence.0.UlisSamsungS7.present.sum_day changed: 275 (ack = true)
                                          fb-checkpresence.0	2019-12-09 15:19:00.800	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.historyHtml {"val":"<table class=\"mdui-table\"><thead><tr><th>Status</th><th>Date</th></tr></thead><tbody><tr><td><div clas
                                          fb-checkpresence.0	2019-12-09 15:19:00.800	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.history {"val":"[{\"Active\":\"true\",\"Date\":\"2019.12.09 03:18:17\"},{\"Active\":\"true\",\"Date\":\"2019.12.09 01:48:00\
                                          fb-checkpresence.0	2019-12-09 15:19:00.800	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.absent.sum_day {"val":644,"ack":true,"ts":1575901140793,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user
                                          fb-checkpresence.0	2019-12-09 15:19:00.800	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.present.sum_day {"val":275,"ack":true,"ts":1575901140793,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.use
                                          fb-checkpresence.0	2019-12-09 15:19:00.794	info	UlisSamsungS7: No history before this day is available (lastVal = null)
                                          fb-checkpresence.0	2019-12-09 15:19:00.794	debug	redis pmessage messagebox.system.adapter.fb-checkpresence.0 messagebox.system.adapter.fb-checkpresence.0 {"command":"getHistory","message":{"result":[{"ack":true,"from":"system.adapter.influxdb.0","q
                                          fb-checkpresence.0	2019-12-09 15:19:00.779	debug	sendTo "getHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
                                          fb-checkpresence.0	2019-12-09 15:19:00.779	debug	redis pmessage messagebox.system.adapter.fb-checkpresence.0 messagebox.system.adapter.fb-checkpresence.0 {"command":"getHistory","message":{"result":[{"val":true,"ts":1575793020415},{"ack":true,"from
                                          fb-checkpresence.0	2019-12-09 15:19:00.773	debug	sendTo "getHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
                                          fb-checkpresence.0	2019-12-09 15:19:00.773	debug	history start
                                          fb-checkpresence.0	2019-12-09 15:19:00.766	debug	getActive [{"Name":"UlisSamsungS7","Active":"true","Kommt":"2019.12.09 01:48:00","Geht":"2019.12.09 01:46:00"},
                                          fb-checkpresence.0	2019-12-09 15:19:00.766	debug	state fb-checkpresence.0.UlisSamsungS7.absent.since changed: 0 (ack = true)
                                          fb-checkpresence.0	2019-12-09 15:19:00.766	debug	state fb-checkpresence.0.UlisSamsungS7.present.since changed: 91 (ack = true)
                                          fb-checkpresence.0	2019-12-09 15:19:00.766	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.absent.since {"val":0,"ack":true,"ts":1575901140761,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.adm
                                          fb-checkpresence.0	2019-12-09 15:19:00.766	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.present.since {"val":91,"ack":true,"ts":1575901140761,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.a
                                          fb-checkpresence.0	2019-12-09 15:19:00.760	debug	getActive UlisSamsungS7 1
                                          fb-checkpresence.0	2019-12-09 15:19:00.760	debug	body response: {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n <s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:
                                          fb-checkpresence.0	2019-12-09 15:19:00.721	debug	state fb-checkpresence.0.guest changed: false (ack = true)
                                          fb-checkpresence.0	2019-12-09 15:19:00.719	debug	state fb-checkpresence.0.activeDevices changed: 67 (ack = true)
                                          fb-checkpresence.0	2019-12-09 15:19:00.719	debug	state fb-checkpresence.0.guest.count changed: 0 (ack = true)
                                          fb-checkpresence.0	2019-12-09 15:19:00.719	debug	state fb-checkpresence.0.guest.listJson changed: [] (ack = true)
                                          fb-checkpresence.0	2019-12-09 15:19:00.718	debug	state fb-checkpresence.0.guest.listHtml changed: <table class="mdui-table"><thead><tr><th>Hostname</th><th>IPAddress</th><th>MACAddress</th></tr></thead><tbody></body></table> (ack = true)
                                          fb-checkpresence.0	2019-12-09 15:19:00.718	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.guest {"val":false,"ack":true,"ts":1575901140709,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.admin","lc":15757421
                                          fb-checkpresence.0	2019-12-09 15:19:00.717	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.activeDevices {"val":67,"ack":true,"ts":1575901140708,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.admin","lc":157
                                          fb-checkpresence.0	2019-12-09 15:19:00.717	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.guest.count {"val":0,"ack":true,"ts":1575901140708,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.admin","lc":157574
                                          fb-checkpresence.0	2019-12-09 15:19:00.717	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.guest.listJson {"val":"[]","ack":true,"ts":1575901140707,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.admin","lc":
                                          fb-checkpresence.0	2019-12-09 15:19:00.717	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.guest.listHtml {"val":"<table class=\"mdui-table\"><thead><tr><th>Hostname</th><th>IPAddress</th><th>MACAddress</th></tr></thead><tbody></
                                          fb-checkpresence.0	2019-12-09 15:19:00.712	debug	getGuests: 67
                                          fb-checkpresence.0	2019-12-09 15:19:00.709	debug	getDeviceList: [{"Index":"1","IPAddress":"192.168.3.96","MACAddress":"34:EA:34:C7:C6:C6","Active":"0","HostName":"Broadlink","InterfaceType":"","X_AVM-DE_Port":"0","X_AVM-DE_Speed":"0","X_AVM-DE_Updat
                                          fb-checkpresence.0	2019-12-09 15:19:00.104	debug	body response: {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n <s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:
                                          fb-checkpresence.0	2019-12-09 15:19:00.080	debug	body response: {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n <s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:
                                          fb-checkpresence.0	2019-12-09 15:19:00.080	debug	state fb-checkpresence.0.info.lastUpdate changed: 2019-12-09T14:19:00.025Z (ack = true)
                                          fb-checkpresence.0	2019-12-09 15:19:00.080	debug	state fb-checkpresence.0.info.connection changed: true (ack = true)
                                          fb-checkpresence.0	2019-12-09 15:19:00.079	debug	state fb-checkpresence.0.devices changed: 108 (ack = true)
                                          fb-checkpresence.0	2019-12-09 15:19:00.079	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.info.lastUpdate {"val":"2019-12-09T14:19:00.025Z","ack":true,"ts":1575901140061,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"s
                                          fb-checkpresence.0	2019-12-09 15:19:00.079	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.info.connection {"val":true,"ack":true,"ts":1575901140061,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.admin","lc"
                                          fb-checkpresence.0	2019-12-09 15:19:00.079	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.devices {"val":"108","ack":true,"ts":1575901140060,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.admin","lc":157589
                                          fb-checkpresence.0	2019-12-09 15:19:00.063	debug	getHostNo: 108
                                          fb-checkpresence.0	2019-12-09 15:19:00.062	debug	body response: {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n <s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:
                                          fb-checkpresence.0	2019-12-09 15:18:18.770	debug	state fb-checkpresence.0.TerrysSamsungS7.historyHtml changed: <table class="mdui-table"><thead><tr><th>Status</th><th>Date</th></tr></thead><tbody><tr><td><div class="mdui-green-bg mdui-state mdui-ca
                                          fb-checkpresence.0	2019-12-09 15:18:18.770	debug	state fb-checkpresence.0.TerrysSamsungS7.history changed: [{"Active":"true","Date":"2019.12.09 03:18:17"},{"Active":"true","Date":"2019.12.09 02:39:00"},{"Active":"false","Date":"2019.12.09 02:37:00"
                                          fb-checkpresence.0	2019-12-09 15:18:18.770	debug	state fb-checkpresence.0.TerrysSamsungS7.absent.sum_day changed: 178 (ack = true)
                                          fb-checkpresence.0	2019-12-09 15:18:18.770	debug	state fb-checkpresence.0.TerrysSamsungS7.present.sum_day changed: 740 (ack = true)
                                          fb-checkpresence.0	2019-12-09 15:18:18.770	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.historyHtml {"val":"<table class=\"mdui-table\"><thead><tr><th>Status</th><th>Date</th></tr></thead><tbody><tr><td><div c
                                          fb-checkpresence.0	2019-12-09 15:18:18.769	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.history {"val":"[{\"Active\":\"true\",\"Date\":\"2019.12.09 03:18:17\"},{\"Active\":\"true\",\"Date\":\"2019.12.09 02:39:
                                          fb-checkpresence.0	2019-12-09 15:18:18.769	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.absent.sum_day {"val":178,"ack":true,"ts":1575901098764,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.u
                                          fb-checkpresence.0	2019-12-09 15:18:18.768	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.present.sum_day {"val":740,"ack":true,"ts":1575901098763,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.
                                          fb-checkpresence.0	2019-12-09 15:18:18.758	info	TerrysSamsungS7: No history before this day is available (lastVal = null)
                                          fb-checkpresence.0	2019-12-09 15:18:18.757	debug	redis pmessage messagebox.system.adapter.fb-checkpresence.0 messagebox.system.adapter.fb-checkpresence.0 {"command":"getHistory","message":{"result":[{"ack":true,"from":"system.adapter.influxdb.0","
                                          fb-checkpresence.0	2019-12-09 15:18:18.744	debug	state fb-checkpresence.0.presence changed: true (ack = true)
                                          fb-checkpresence.0	2019-12-09 15:18:18.743	debug	state fb-checkpresence.0.presenceAll changed: true (ack = true)
                                          fb-checkpresence.0	2019-12-09 15:18:18.743	debug	state fb-checkpresence.0.html changed: <table class="mdui-table"><thead><tr><th>Name</th><th>Status</th><th>Kommt</th><th>Geht</th></tr></thead><tbody><tr><td>UlisSamsungS7</td><td><div class="mdui-g
                                          fb-checkpresence.0	2019-12-09 15:18:18.743	debug	state fb-checkpresence.0.json changed: [{"Name":"UlisSamsungS7","Active":"true","Kommt":"2019.12.09 01:48:00","Geht":"2019.12.09 01:46:00"},{"Name":"TerrysSamsungS7","Active":"true","Kommt":"2019.12.
                                          fb-checkpresence.0	2019-12-09 15:18:18.742	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.presence {"val":true,"ack":true,"ts":1575901098738,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.admin","lc":15758
                                          fb-checkpresence.0	2019-12-09 15:18:18.742	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.presenceAll {"val":true,"ack":true,"ts":1575901098737,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.admin","lc":15
                                          fb-checkpresence.0	2019-12-09 15:18:18.741	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.html {"val":"<table class=\"mdui-table\"><thead><tr><th>Name</th><th>Status</th><th>Kommt</th><th>Geht</th></tr></thead><tbody><tr><td>Ul
                                          fb-checkpresence.0	2019-12-09 15:18:18.741	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.json {"val":"[{\"Name\":\"UlisSamsungS7\",\"Active\":\"true\",\"Kommt\":\"2019.12.09 01:48:00\",\"Geht\":\"2019.12.09 01:46:00\"},{\"Name
                                          fb-checkpresence.0	2019-12-09 15:18:18.740	debug	sendTo "getHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
                                          fb-checkpresence.0	2019-12-09 15:18:18.739	debug	redis pmessage messagebox.system.adapter.fb-checkpresence.0 messagebox.system.adapter.fb-checkpresence.0 {"command":"getHistory","message":{"result":[{"val":true,"ts":1575824521227},{"ack":true,"fro
                                          fb-checkpresence.0	2019-12-09 15:18:18.700	debug	checkPresence first run
                                          fb-checkpresence.0	2019-12-09 15:18:18.700	debug	sendTo "getHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
                                          fb-checkpresence.0	2019-12-09 15:18:18.699	debug	history start
                                          fb-checkpresence.0	2019-12-09 15:18:18.698	debug	state fb-checkpresence.0.TerrysSamsungS7.absent.since changed: 0 (ack = true)
                                          fb-checkpresence.0	2019-12-09 15:18:18.697	debug	state fb-checkpresence.0.TerrysSamsungS7.present.since changed: 39 (ack = true)
                                          fb-checkpresence.0	2019-12-09 15:18:18.696	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.absent.since {"val":0,"ack":true,"ts":1575901098687,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.
                                          fb-checkpresence.0	2019-12-09 15:18:18.695	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.present.since {"val":39,"ack":true,"ts":1575901098686,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.use
                                          fb-checkpresence.0	2019-12-09 15:18:18.693	debug	getActive [{"Name":"UlisSamsungS7","Active":"true","Kommt":"2019.12.09 01:48:00","Geht":"2019.12.09 01:46:00"},{"Name":"TerrysSamsungS7","Active":"true","Kommt":"2019.12.09 02:39:00","Geht":"2019.12.
                                          fb-checkpresence.0	2019-12-09 15:18:18.684	debug	getActive TerrysSamsungS7 1
                                          fb-checkpresence.0	2019-12-09 15:18:18.682	debug	</s:Envelope>
                                          fb-checkpresence.0	2019-12-09 15:18:18.682	debug	</s:Body>
                                          fb-checkpresence.0	2019-12-09 15:18:18.682	debug	</u:GetSpecificHostEntryResponse>
                                          fb-checkpresence.0	2019-12-09 15:18:18.682	debug	<NewHostName>TerrysSamsungS7</NewHostName>
                                          fb-checkpresence.0	2019-12-09 15:18:18.682	debug	<NewActive>1</NewActive>
                                          fb-checkpresence.0	2019-12-09 15:18:18.682	debug	<NewInterfaceType>802.11</NewInterfaceType>
                                          fb-checkpresence.0	2019-12-09 15:18:18.682	debug	<NewLeaseTimeRemaining>864000</NewLeaseTimeRemaining>
                                          fb-checkpresence.0	2019-12-09 15:18:18.682	debug	<NewAddressSource>DHCP</NewAddressSource>
                                          fb-checkpresence.0	2019-12-09 15:18:18.682	debug	<NewIPAddress>192.168.3.131</NewIPAddress>
                                          fb-checkpresence.0	2019-12-09 15:18:18.682	debug	<u:GetSpecificHostEntryResponse xmlns:u="urn:dslforum-org:service:Hosts:1">
                                          fb-checkpresence.0	2019-12-09 15:18:18.682	debug	<s:Body>
                                          fb-checkpresence.0	2019-12-09 15:18:18.682	debug	<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
                                          fb-checkpresence.0	2019-12-09 15:18:18.682	debug	body response: {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n <s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s
                                          fb-checkpresence.0	2019-12-09 15:18:18.590	debug	state fb-checkpresence.0.UlisSamsungS7.historyHtml changed: <table class="mdui-table"><thead><tr><th>Status</th><th>Date</th></tr></thead><tbody><tr><td><div class="mdui-green-bg mdui-state mdui-card
                                          fb-checkpresence.0	2019-12-09 15:18:18.590	debug	state fb-checkpresence.0.UlisSamsungS7.history changed: [{"Active":"true","Date":"2019.12.09 03:18:17"},{"Active":"true","Date":"2019.12.09 01:48:00"},{"Active":"false","Date":"2019.12.09 01:46:00"},
                                          fb-checkpresence.0	2019-12-09 15:18:18.590	debug	state fb-checkpresence.0.UlisSamsungS7.absent.sum_day changed: 643 (ack = true)
                                          fb-checkpresence.0	2019-12-09 15:18:18.589	debug	state fb-checkpresence.0.UlisSamsungS7.present.sum_day changed: 275 (ack = true)
                                          fb-checkpresence.0	2019-12-09 15:18:18.589	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.historyHtml {"val":"<table class=\"mdui-table\"><thead><tr><th>Status</th><th>Date</th></tr></thead><tbody><tr><td><div cla
                                          fb-checkpresence.0	2019-12-09 15:18:18.588	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.history {"val":"[{\"Active\":\"true\",\"Date\":\"2019.12.09 03:18:17\"},{\"Active\":\"true\",\"Date\":\"2019.12.09 01:48:00
                                          fb-checkpresence.0	2019-12-09 15:18:18.587	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.absent.sum_day {"val":643,"ack":true,"ts":1575901098579,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.use
                                          fb-checkpresence.0	2019-12-09 15:18:18.584	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.present.sum_day {"val":275,"ack":true,"ts":1575901098578,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.us
                                          fb-checkpresence.0	2019-12-09 15:18:18.574	info	UlisSamsungS7: No history before this day is available (lastVal = null)
                                          fb-checkpresence.0	2019-12-09 15:18:18.569	debug	redis pmessage messagebox.system.adapter.fb-checkpresence.0 messagebox.system.adapter.fb-checkpresence.0 {"command":"getHistory","message":{"result":[{"ack":true,"from":"system.adapter.influxdb.0","
                                          fb-checkpresence.0	2019-12-09 15:18:18.558	debug	sendTo "getHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
                                          fb-checkpresence.0	2019-12-09 15:18:18.555	debug	redis pmessage messagebox.system.adapter.fb-checkpresence.0 messagebox.system.adapter.fb-checkpresence.0 {"command":"getHistory","message":{"result":[{"val":true,"ts":1575793020415},{"ack":true,"fro
                                          fb-checkpresence.0	2019-12-09 15:18:18.542	debug	sendTo "getHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
                                          fb-checkpresence.0	2019-12-09 15:18:18.541	debug	history start
                                          fb-checkpresence.0	2019-12-09 15:18:18.317	debug	state fb-checkpresence.0.UlisSamsungS7.absent.since changed: 0 (ack = true)
                                          fb-checkpresence.0	2019-12-09 15:18:18.316	debug	state fb-checkpresence.0.UlisSamsungS7.present.since changed: 90 (ack = true)
                                          fb-checkpresence.0	2019-12-09 15:18:18.316	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.absent.since {"val":0,"ack":true,"ts":1575901098303,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.ad
                                          fb-checkpresence.0	2019-12-09 15:18:18.315	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.present.since {"val":90,"ack":true,"ts":1575901098299,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.
                                          fb-checkpresence.0	2019-12-09 15:18:18.313	debug	getActive [{"Name":"UlisSamsungS7","Active":"true","Kommt":"2019.12.09 01:48:00","Geht":"2019.12.09 01:46:00"},
                                          fb-checkpresence.0	2019-12-09 15:18:18.296	debug	getActive UlisSamsungS7 1
                                          fb-checkpresence.0	2019-12-09 15:18:18.293	debug	</s:Envelope>
                                          fb-checkpresence.0	2019-12-09 15:18:18.293	debug	</s:Body>
                                          fb-checkpresence.0	2019-12-09 15:18:18.293	debug	</u:GetSpecificHostEntryResponse>
                                          fb-checkpresence.0	2019-12-09 15:18:18.293	debug	<NewHostName>UlisSamsungS7</NewHostName>
                                          fb-checkpresence.0	2019-12-09 15:18:18.293	debug	<NewActive>1</NewActive>
                                          fb-checkpresence.0	2019-12-09 15:18:18.293	debug	<NewInterfaceType>802.11</NewInterfaceType>
                                          fb-checkpresence.0	2019-12-09 15:18:18.293	debug	<NewLeaseTimeRemaining>0</NewLeaseTimeRemaining>
                                          fb-checkpresence.0	2019-12-09 15:18:18.293	debug	<NewAddressSource>DHCP</NewAddressSource>
                                          fb-checkpresence.0	2019-12-09 15:18:18.293	debug	<NewIPAddress>192.168.3.136</NewIPAddress>
                                          fb-checkpresence.0	2019-12-09 15:18:18.293	debug	<u:GetSpecificHostEntryResponse xmlns:u="urn:dslforum-org:service:Hosts:1">
                                          fb-checkpresence.0	2019-12-09 15:18:18.293	debug	<s:Body>
                                          fb-checkpresence.0	2019-12-09 15:18:18.293	debug	<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
                                          fb-checkpresence.0	2019-12-09 15:18:18.293	debug	body response: {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n <s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s
                                          fb-checkpresence.0	2019-12-09 15:18:18.251	debug	state fb-checkpresence.0.guest changed: false (ack = true)
                                          fb-checkpresence.0	2019-12-09 15:18:18.251	debug	state fb-checkpresence.0.activeDevices changed: 68 (ack = true)
                                          fb-checkpresence.0	2019-12-09 15:18:18.250	debug	state fb-checkpresence.0.guest.count changed: 0 (ack = true)
                                          fb-checkpresence.0	2019-12-09 15:18:18.250	debug	state fb-checkpresence.0.guest.listJson changed: [] (ack = true)
                                          fb-checkpresence.0	2019-12-09 15:18:18.250	debug	state fb-checkpresence.0.guest.listHtml changed: <table class="mdui-table"><thead><tr><th>Hostname</th><th>IPAddress</th><th>MACAddress</th></tr></thead><tbody></body></table> (ack = true)
                                          fb-checkpresence.0	2019-12-09 15:18:18.249	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.guest {"val":false,"ack":true,"ts":1575901098240,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.admin","lc":1575742
                                          afuerhoff 2 Replies Last reply Reply Quote 0
                                          • afuerhoff
                                            afuerhoff Developer @zahnheinrich last edited by
                                            @zahnheinrich
                                            Hallo, was wird denn in der Historie zu einem der Datenpunkte angezeigt? Kannst Du mal den aktuellen und den Tag davor posten. Falls vorhanden.
                                            Nach Meldung dürften keine Historien Einträge vor dem aktuellen Tag vorhanden sein.
                                            31.7k
                                            79.8k
                                            fb-checkpresence adapter
                                            30
                                            346
                                            44104
