    4. Test Adaper Tado v0.1.x
    • Dutchman
      Dutchman Developer Most Active Administrators @rehmosch last edited by
      @rehmosch sagte in Test Adaper Tado v0.1.x:
      Habe über githhub upgedated und bekomme gar keine Fehlermeldung mehr.
      super, habe Version 0.1.3 nach 4 positieven signalen auf NPM released wird morgen ueber den admin. installierbar sein.
      So dan fuer die 0.2. ... mal. bitte ne liste mit. nötigen Verbesserungen auf GitHub hab ich. noch 1 issue sind wir fast fertig ? 😊
      CKMartens 1 Reply Last reply Reply Quote 0
      • CKMartens
        CKMartens @Dutchman last edited by
        @Dutchman
        Habe heute vormittag per Admin-Oberfläche updaten wollen: Es wurde folgender Fehler geworfen:
        Fertig mit Fehler: /opt/iobroker/node_modules/standard-as-callback/built/index.js:6 throw e; ^TypeError: Cannot read property '0' of undefined at _scripts.forEach (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInRedis.js:2862:70) at Array.forEach () at client.script (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInRedis.js:2862:26) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:30:51) at process._tickCallback (internal/process/next_tick.js:68:7)
        $ ./iobroker upgrade tado
        Update tado from @0.1.2 to @0.1.3
        NPM version: 6.11.3npm install iobroker.tado@0.1.3 --loglevel error --prefix "/opt/iobroker" (System call)Update tado from @0.1.2 to @0.1.3
        ERROR: /opt/iobroker/node_modules/standard-as-callback/built/index.js:6        throw e;        ^TypeError: Cannot read property '0' of undefined    at _scripts.forEach (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInRedis.js:2862:70)    at Array.forEach (<anonymous>)    at client.script (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInRedis.js:2862:26)    at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)    at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:30:51)    at process._tickCallback (internal/process/next_tick.js:68:7)
        ERROR: process exited with code 1
        Die Installation von der Konsole mit
        iobroker upload tado
        Hat aber fehlerfrei funktioniert.
        • Dutchman
          Dutchman Developer Most Active Administrators @CKMartens last edited by
          @CKMartens sagte in Test Adaper Tado v0.1.x:
          @Dutchman
          hmm der ist interessant werde ich mal intern nachfragen sieht nach nem Fehler aus dem JS-controller aus aber was. da genau passiert...
          Sollte die Funktionalität aber nicht beeinträchtigen.
          • Dutchman
            @CKMartens
            welche JS-Controller hast du installiert, 2.0.x oder 2.1 ?
            • CKMartens
              @Dutchman js-controler 2.1.x aus stable
              Der tado-Adapter funktioniert einwandfrei nachdem ich mit npm instaliert habe. War nur zur Info für Dich/Euch gepostet
              • Dutchman
                Danke und genau dem probieren ich nach zu gehen @apollon77 scheint beim JS-controller 2.1 passiert zu sein
                  stockics6 last edited by
                  ersteinmal vielen Dank für den Adapter, die Implementierung lief perfekt!
                  Leider kriege ich es nicht hin, dass ich über die VIS die Temperatur ändern kann.
                  Komfortmodus VIS AN = Blockly Steuerung = Mehrere Hezizkörper an
                  Der Wert 24 wird nicht übernommen, wenn ich den Wert unter Objekte manuell eingebe funktioniert es komischerweise.
                  Weiß jemand woran das liegt?
                  Danke!
                  • CKMartens
                    CKMartens @stockics6 last edited by CKMartens
                    @stockics6 du setzt da die 24 sls einen String (Text) ein. Es muss aber eine Zahl sein.
                    Das steht unter Mathematik
                      stockics6 last edited by stockics6
                      ich habe beides getestet, aber er nimmt auch die Zahl nicht.
                      CKMartens Dutchman 2 Replies Last reply Reply Quote 0
                      • CKMartens
                        @stockics6 könnte was damit zu tun haben das Du etwas unter ScriptEnabled abgreifst. Soweit ich weiß sollten diese States nur für ioBroker intern verwendet werden. Leg besser eigene Datenpunkte an und nutz diese.
                        • Dutchman
                          Dutchman Developer Most Active Administrators @stockics6 last edited by Dutchman
                          @stockics6 sagte in Test Adaper Tado v0.1.x:
                          was du da machst funktioniert aus 2 gründen nicht vernünftig :
                          1 ) Du schaltest mit deinem vis das script ein und aus, ich kappieren immer noch. nicht warum aus einem video vor 1,5 Jahren mit Alexa immer noch hunderte user diesen Fehler machen. Was du machen solltest
                          • ein object erstellen (z.b. unter eigene Objekte. wie seit JS-controller 2.1 vorhanden)
                          • script erstellen
                          • in dem script loest du Aktionen aus durch aenderung des objectes
                          • das script bliebt immer an, das. schlafen der variable löst. aus !
                          2 ) true ist nicht true
                          mit andere Worten, ein text Baustein true ist etwas anderes als ein boolean wert true (0/1)
                          Deine if abfrage wird so also niemals gehen wen der datenpunkt ein boolean ist
                          Dutch
                          CKMartens 1 Reply Last reply Reply Quote 1
                          • CKMartens
                            @Dutchman sagte in Test Adaper Tado v0.1.x:
                            Dutch
                            Das ist mir gar nicht aufgefallen.... Für manche Sachen ist man wohl beim schnellen draufsehen betriebsblind
                              Stormbringer last edited by
                              Muss euch jetzt leider nochmal nerven g Spiel grad ein bisschen rum mit dem Umstellen von HAM auf tado.... Habe mir eingebildet, dass On/Off immer Rückkehr zum letzen Modus (und bei Manuell letzte eingestellte Temperatur) ist. Aber bei mir geht er, wenn vorher Auto war dann auf Manuell. Das spuckt mir irgendwie gewaltig in die Suppe 😨
                              • CKMartens
                                CKMartens @Stormbringer last edited by
                                @Stormbringer das hatte ich auch. Kannst du bis @Dutchman das einbaut mit dem State clearZoneOverlay zurück setzen
                                S Dutchman 2 Replies Last reply Reply Quote 0
                                  Stormbringer @CKMartens last edited by
                                  @CKMartens Danke. Ne bringt nix, weil er ja dann in der Übergangsphase auf Auto umstellen würde (das hat mich vorm HAM Adapter tierisch genervt) und ich jetzt alle möglichen Skripte verbiegen müsste. Dann warte ich halt noch ab. Hoffe es kommt nur wieder wie früher. Danke für die Info.
                                  Schlecht wärs auch nicht, wenn er bei Power off nicht manuell anzeigt sondern aus. Falls man den Wunsch noch integrieren kann 😉
                                  • Dutchman
                                    was muss ich genau einbauen ?
                                    • CKMartens
                                      CKMartens @Dutchman last edited by CKMartens
                                      Wäre schön nach poweroff den letzten Zustand wieder zu bekommen. Also wenn manuell eingestellt wurde, dann poweroff, dann wieder manuell bzw. wenn Auto, dann powerOff und danach wieder Auto.
                                      Und was geil wäre, wenn die Timer Funktion noch kommen würde
                                      • Dutchman
                                        ich glaube das ist du oder rolli mir mal genauer erklaehren was ihr genau meint 🤗
                                          Coffeelover last edited by
                                          Hi zusammen,
                                          hat einer von euch schon einmal real getestet, wieviel die Intelligenz der Tado ausmacht?
                                          Es geht mir um die Frage, ob ich die Steuerung von Tado außer Kraft setze oder nicht. Konkret: Lohnt es sich, Tado die Steuerung bzgl. Wettervorschau, Vorheizen, etc. zu überlassen? Oder doch besser Pläne außerhalb Tado z.B. über den Adapter?
                                          VG
                                          CKMartens S 2 Replies Last reply Reply Quote 0
                                          • CKMartens
                                            CKMartens @Coffeelover last edited by
                                            @Coffeelover sagte in Test Adaper Tado v0.1.x:
                                            Hi zusammen,
                                            VG
                                            Kann da nur für mich sprechen, aber gerade das ich mich nicht mehr um die Regelung kümmern muss macht das System für mich wertvoll. Ich habe die Einstellung vorgenommen wann Komforttemperatur laufen soll, wie welche Heizung reagiert wenn wir weg sind und wieder zurück sind.
                                            Ich habe die letzten Jahre gute Einsparungen mit tado gemacht und genieße das es komfortabel und für mich einfach zu bedienen ist.
                                            Sicherlich gibt es Potential immer besser Lösungen, ich habe mich selbst schon an ein eigenes Script gewagt. Aber da muss eben doch öfter kontrolliert und justiert werden und das kann ich mir sparen. Den Adapter von Dutchman nehme ich zum einen für die Visualisierung, zum anderen die Heizkörper bei offenen Fenster besser zu steuern. Ansonsten läuft alles auf Automatik.
                                            31.7k
                                            79.9k
                                            adapter tado testing team
                                            62
                                            868
                                            198331
