    4. Iobroker Oberfläche öffnet nicht
    SOLVED Iobroker Oberfläche öffnet nicht
      sigi234 Forum Testing Most Active @Rocket85 last edited by
      @Rocket85
      Was kommt bei:
      cd /opt/iobroker
      iobroker list instances
      node -v
      nodejs -v
      npm -v
      • dslraser
        dslraser Forum Testing Most Active @Rocket85 last edited by
        @Rocket85
        hast Du mal den Fixer laufen lassen ?
        Das hier sieht nach einem Rechte Problem aus...
        EACCES: permission denie
        Fixer
        curl -sL https://iobroker.net/fix.sh | bash -
          pi@raspberrypi:~ $ cd /opt/iobroker
          pi@raspberrypi:/opt/iobroker $ iobroker list instances
          internal/modules/cjs/loader.js:638
              throw err;
          Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iob                                   roker.js'
              at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
              at Function.Module._load (internal/modules/cjs/loader.js:562:25)
              at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
              at startup (internal/bootstrap/node.js:283:19)
              at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
          pi@raspberrypi:/opt/iobroker $ node -v
          v10.17.0
          pi@raspberrypi:/opt/iobroker $ nodejs -v
          v10.17.0
          pi@raspberrypi:/opt/iobroker $ npm -v
          6.11.3
            @Rocket85
            https://www.iobroker.net/#de/documentation/trouble/RunsNoMore.md
              Hab alles schritt für schritt gemacht, ohne erfolg.
                pi@raspberrypi:/opt/iobroker $ iobroker start
                Starting iobroker controller daemon...
                iobroker controller daemon failed to start:  Failed to write pidfile (EACCES)
                Error: Failed to write pidfile (EACCES)
                pi@raspberrypi:/opt/iobroker $ node node_modules/iobroker.js-controller/controll        er.js --logs
                2019-11-22 14:18:17.200  - info: host.raspberrypi iobroker.js-controller version        1.5.14 js-controller starting
                2019-11-22 14:18:17.207  - info: host.raspberrypi Copyright (c) 2014-2018 bluefo        x, 2014 hobbyquaker
                2019-11-22 14:18:17.208  - info: host.raspberrypi hostname: raspberrypi, node: v        10.17.0
                2019-11-22 14:18:17.212  - info: host.raspberrypi ip addresses: 192.168.178.87 2        a02:810c:ccc0:45a0:6733:40f8:70dd:257f fe80::3b7f:ed1c:96e6:b13b
                2019-11-22 14:18:17.359  - info: host.raspberrypi  inMem-states listening on por        t 9000
                2019-11-22 14:18:18.061  - info: host.raspberrypi  inMem-objects listening on po        rt 9001
                2019-11-22 14:18:18.100  - info: host.raspberrypi InMemoryDB connected
                2019-11-22 14:18:18.144  - info: host.raspberrypi 19 instances found
                host.raspberrypi check instance "system.adapter.admin.0" for host "raspberrypi"
                host.raspberrypi check instance "system.adapter.discovery.0" for host "raspberrypi"
                host.raspberrypi check instance "system.adapter.cloud.0" for host "raspberrypi"
                host.raspberrypi check instance "system.adapter.web.0" for host "raspberrypi"
                host.raspberrypi check instance "system.adapter.rpi2.0" for host "raspberrypi"
                host.raspberrypi check instance "system.adapter.vis.0" for host "raspberrypi"
                host.raspberrypi check instance "system.adapter.terminal.0" for host "raspberrypi"
                host.raspberrypi check instance "system.adapter.alexa2.0" for host "raspberrypi"
                host.raspberrypi check instance "system.adapter.vis-players.0" for host "raspberrypi"
                host.raspberrypi check instance "system.adapter.scenes.0" for host "raspberrypi"
                host.raspberrypi check instance "system.adapter.mihome.0" for host "raspberrypi"
                host.raspberrypi check instance "system.adapter.javascript.0" for host "raspberrypi"
                host.raspberrypi check instance "system.adapter.telegram.0" for host "raspberrypi"
                host.raspberrypi check instance "system.adapter.text2command.0" for host "raspberrypi"
                host.raspberrypi check instance "system.adapter.shelly.0" for host "raspberrypi"
                host.raspberrypi check instance "system.adapter.pushover.0" for host "raspberrypi"
                host.raspberrypi check instance "system.adapter.info.0" for host "raspberrypi"
                host.raspberrypi check instance "system.adapter.shelly.1" for host "raspberrypi"
                host.raspberrypi check instance "system.adapter.backitup.0" for host "raspberrypi"
                2019-11-22 14:18:18.190  - info: host.raspberrypi starting 14 instances
                2019-11-22 14:18:18.304  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 18290
                2019-11-22 14:18:19.309  - error: uncaught exception: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/pids.txt'
                2019-11-22 14:18:19.313  - error: Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/pids.txt'
                    at Object.openSync (fs.js:443:3)
                    at Object.writeFileSync (fs.js:1194:35)
                    at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:2024:16)
                    at ontimeout (timers.js:436:11)
                    at tryOnTimeout (timers.js:300:5)
                    at listOnTimeout (timers.js:263:5)
                    at Timer.processTimers (timers.js:223:10)
                2019-11-22 14:18:19.319  - info: iobroker _restart
                2019-11-22 14:18:20.059  - info: iobroker Starting node restart.js
                2019-11-22 14:18:20.087  - info: iobroker exit 0
                2019-11-22 14:18:29.331  - info: host.raspberrypi force terminating
                2019-11-22 14:18:29.332  - info: Adapter admin still running
                2019-11-22 14:18:30.234  - info: host.raspberrypi instance system.adapter.alexa2.0 started with pid 18323
                • Negalein
                  Negalein Global Moderator @Rocket85 last edited by
                  @Rocket85 sagte in Iobroker Oberfläche öffnet nicht:
                  folgender Fehler:
                  Mod-Edit: Thema ins passende Forum verschoben!
                    Rocket85 @Rocket85 last edited by
                      system.adapter.admin.0                 : admin       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      system.adapter.alexa2.0                : alexa2      -  enabled
                      system.adapter.backitup.0              : backitup    -  enabled
                      system.adapter.cloud.0                 : cloud       -  enabled
                      system.adapter.discovery.0             : discovery   - disabled
                      system.adapter.info.0                  : info        -  enabled
                      system.adapter.javascript.0            : javascript  -  enabled
                      system.adapter.mihome.0                : mihome      -  enabled, port: 9898, bind: 0.0.0.0
                      system.adapter.pushover.0              : pushover    -  enabled
                      system.adapter.rpi2.0                  : rpi2        - disabled
                      system.adapter.scenes.0                : scenes      - disabled
                      system.adapter.shelly.0                : shelly      -  enabled, port: 1882, bind: 0.0.0.0
                      system.adapter.shelly.1                : shelly      -  enabled, port: 1882, bind: 0.0.0.0
                      system.adapter.telegram.0              : telegram    -  enabled, port: 8443, bind: 0.0.0.0
                      system.adapter.terminal.0              : terminal    -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                      system.adapter.text2command.0          : text2command -  enabled
                      system.adapter.vis-players.0           : vis-players -  enabled
                      system.adapter.vis.0                   : vis         - disabled
                      system.adapter.web.0                   : web         - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                    • dslraser
                      @Rocket85
                      Fixer
                        @dslraser sagte in Iobroker Oberfläche öffnet nicht:
                        moment läuft
                          Rocket85 @dslraser last edited by
                          @dslraser
                          geht wieder.
                          Ich danke dir vielmals bzw. euch allen.
                          jetzt will er ein update des admin. kann man das ohne probleme machen?
                          • dslraser
                            @dslraser
                            geht wieder.
                            Ich denke schon. Immer wenn Du nicht sicher bist was Du machst, vorher Backup machen.
                              Jetzt versteh ich nix mehr. Es läuft wieder alles.
                              Allerdings hatte ich den js-controller vor Tagen schon auf die neuste verseion upgedatet. Und jetzt steht er wieder verfügbar auf 2.1.0 und installiert 1.5.14??
                              • dslraser
                                dslraser Forum Testing Most Active @Rocket85 last edited by dslraser
                                wahrscheinlich hattest Du den Verwahrungsort auf default und hast dann nach der verlinkten Anleitung alles wieder hergestellt ?
                                PS:
                                Es gibt heute Abend dann 2.1.1 in latest.
                                  Na dann warte ich bis morgen 🙂
                                  • dslraser
                                    Ich habe 2.1.1 schon installiert und es läuft bisher alles ohne Auffälligkeiten.
                                    iobroker
                                    2207
