    4. Iobroker Oberfläche öffnet nicht
    SOLVED Iobroker Oberfläche öffnet nicht
      sigi234 Forum Testing Most Active @Rocket85 last edited by
      @Rocket85
      https://www.iobroker.net/#de/documentation/trouble/RunsNoMore.md
      • dslraser
        dslraser Forum Testing Most Active @Rocket85 last edited by
        @Rocket85
        hast Du mal den Fixer laufen lassen ?
        Das hier sieht nach einem Rechte Problem aus...
        EACCES: permission denie
        Fixer
        curl -sL https://iobroker.net/fix.sh | bash -
          Hab alles schritt für schritt gemacht, ohne erfolg.
            pi@raspberrypi:~ $ cd /opt/iobroker
            pi@raspberrypi:/opt/iobroker $ iobroker start
            Starting iobroker controller daemon...
            iobroker controller daemon failed to start:  Failed to write pidfile (EACCES)
            Error: Failed to write pidfile (EACCES)
            pi@raspberrypi:/opt/iobroker $ node node_modules/iobroker.js-controller/controll        er.js --logs
            2019-11-22 14:18:17.200  - info: host.raspberrypi iobroker.js-controller version        1.5.14 js-controller starting
            2019-11-22 14:18:17.207  - info: host.raspberrypi Copyright (c) 2014-2018 bluefo        x, 2014 hobbyquaker
            2019-11-22 14:18:17.208  - info: host.raspberrypi hostname: raspberrypi, node: v        10.17.0
            2019-11-22 14:18:17.212  - info: host.raspberrypi ip addresses: 192.168.178.87 2        a02:810c:ccc0:45a0:6733:40f8:70dd:257f fe80::3b7f:ed1c:96e6:b13b
            2019-11-22 14:18:17.359  - info: host.raspberrypi  inMem-states listening on por        t 9000
            2019-11-22 14:18:18.061  - info: host.raspberrypi  inMem-objects listening on po        rt 9001
            2019-11-22 14:18:18.100  - info: host.raspberrypi InMemoryDB connected
            2019-11-22 14:18:18.144  - info: host.raspberrypi 19 instances found
            host.raspberrypi check instance "system.adapter.admin.0" for host "raspberrypi"
            host.raspberrypi check instance "system.adapter.discovery.0" for host "raspberrypi"
            host.raspberrypi check instance "system.adapter.cloud.0" for host "raspberrypi"
            host.raspberrypi check instance "system.adapter.web.0" for host "raspberrypi"
            host.raspberrypi check instance "system.adapter.rpi2.0" for host "raspberrypi"
            host.raspberrypi check instance "system.adapter.vis.0" for host "raspberrypi"
            host.raspberrypi check instance "system.adapter.terminal.0" for host "raspberrypi"
            host.raspberrypi check instance "system.adapter.alexa2.0" for host "raspberrypi"
            host.raspberrypi check instance "system.adapter.vis-players.0" for host "raspberrypi"
            host.raspberrypi check instance "system.adapter.scenes.0" for host "raspberrypi"
            host.raspberrypi check instance "system.adapter.mihome.0" for host "raspberrypi"
            host.raspberrypi check instance "system.adapter.javascript.0" for host "raspberrypi"
            host.raspberrypi check instance "system.adapter.telegram.0" for host "raspberrypi"
            host.raspberrypi check instance "system.adapter.text2command.0" for host "raspberrypi"
            host.raspberrypi check instance "system.adapter.shelly.0" for host "raspberrypi"
            host.raspberrypi check instance "system.adapter.pushover.0" for host "raspberrypi"
            host.raspberrypi check instance "system.adapter.info.0" for host "raspberrypi"
            host.raspberrypi check instance "system.adapter.shelly.1" for host "raspberrypi"
            host.raspberrypi check instance "system.adapter.backitup.0" for host "raspberrypi"
            2019-11-22 14:18:18.190  - info: host.raspberrypi starting 14 instances
            2019-11-22 14:18:18.304  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 18290
            2019-11-22 14:18:19.309  - error: uncaught exception: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/pids.txt'
            2019-11-22 14:18:19.313  - error: Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/pids.txt'
                at Object.openSync (fs.js:443:3)
                at Object.writeFileSync (fs.js:1194:35)
                at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:2024:16)
                at ontimeout (timers.js:436:11)
                at tryOnTimeout (timers.js:300:5)
                at listOnTimeout (timers.js:263:5)
                at Timer.processTimers (timers.js:223:10)
            2019-11-22 14:18:19.319  - info: iobroker _restart
            2019-11-22 14:18:20.059  - info: iobroker Starting node restart.js
            2019-11-22 14:18:20.087  - info: iobroker exit 0
            2019-11-22 14:18:29.331  - info: host.raspberrypi force terminating
            2019-11-22 14:18:29.332  - info: Adapter admin still running
            2019-11-22 14:18:30.234  - info: host.raspberrypi instance system.adapter.alexa2.0 started with pid 18323
            • Negalein
              Negalein Global Moderator @Rocket85 last edited by
              @Rocket85 sagte in Iobroker Oberfläche öffnet nicht:
              folgender Fehler:
              Mod-Edit: Thema ins passende Forum verschoben!
                Rocket85 @Rocket85 last edited by
                 iobroker list instances
                  system.adapter.admin.0                 : admin       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  system.adapter.alexa2.0                : alexa2      -  enabled
                  system.adapter.backitup.0              : backitup    -  enabled
                  system.adapter.cloud.0                 : cloud       -  enabled
                  system.adapter.discovery.0             : discovery   - disabled
                  system.adapter.info.0                  : info        -  enabled
                  system.adapter.javascript.0            : javascript  -  enabled
                  system.adapter.mihome.0                : mihome      -  enabled, port: 9898, bind: 0.0.0.0
                  system.adapter.pushover.0              : pushover    -  enabled
                  system.adapter.rpi2.0                  : rpi2        - disabled
                  system.adapter.scenes.0                : scenes      - disabled
                  system.adapter.shelly.0                : shelly      -  enabled, port: 1882, bind: 0.0.0.0
                  system.adapter.shelly.1                : shelly      -  enabled, port: 1882, bind: 0.0.0.0
                  system.adapter.telegram.0              : telegram    -  enabled, port: 8443, bind: 0.0.0.0
                  system.adapter.terminal.0              : terminal    -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                  system.adapter.text2command.0          : text2command -  enabled
                  system.adapter.vis-players.0           : vis-players -  enabled
                  system.adapter.vis.0                   : vis         - disabled
                  system.adapter.web.0                   : web         - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                • dslraser
                  @Rocket85
                  Fixer
                    @dslraser sagte in Iobroker Oberfläche öffnet nicht:
                    moment läuft
                      Rocket85 @dslraser last edited by
                      @dslraser
                      geht wieder.
                      Ich danke dir vielmals bzw. euch allen.
                      jetzt will er ein update des admin. kann man das ohne probleme machen?
                      • dslraser
                        @dslraser
                        geht wieder.
                        Ich denke schon. Immer wenn Du nicht sicher bist was Du machst, vorher Backup machen.
                          Jetzt versteh ich nix mehr. Es läuft wieder alles.
                          Allerdings hatte ich den js-controller vor Tagen schon auf die neuste verseion upgedatet. Und jetzt steht er wieder verfügbar auf 2.1.0 und installiert 1.5.14??
                          • dslraser
                            dslraser Forum Testing Most Active @Rocket85 last edited by dslraser
                            wahrscheinlich hattest Du den Verwahrungsort auf default und hast dann nach der verlinkten Anleitung alles wieder hergestellt ?
                            PS:
                            Es gibt heute Abend dann 2.1.1 in latest.
                              Na dann warte ich bis morgen 🙂
                              • dslraser
                                Ich habe 2.1.1 schon installiert und es läuft bisher alles ohne Auffälligkeiten.
                                iobroker
                                2207
