    4. [Vorstellung] Meine zweite Visualisierung
      Kuddel @Uli977 last edited by
      @Uli977 hier das Powershell Skript.
      Geht sicherlich auch per Blockly und Exec, aber das habe ich noch nicht umgesetzt.
      Import-Module VMware.PowerCLI
      cls
      Connect-VIServer 192.168.4.45 -user root -Password ******************
      cls
      #ESX-NUC Infos Abfragen
      $esx_nuc_infos = get-vmhost
      #Freier RAM ESX-NUC
      $esx_nuc_ram = $esx_nuc_infos.MemoryUsageMB
      Invoke-WebRequest -Uri http://192.168.4.30:8087/set/javascript.0.ressourcen.esx.esx-nuc_mem_usage?value=$esx_nuc_ram | Out-Null
      $esx_nuc_ram_usage_percent = $esx_nuc_infos.MemoryUsageMB / $esx_nuc_infos.MemoryTotalMB
      $esx_nuc_ram_usage_percent = $esx_nuc_ram_usage_percent * 100
      $esx_nuc_ram_usage_percent = [math]::Round($esx_nuc_ram_usage_percent,0)
      Invoke-WebRequest -Uri http://192.168.4.30:8087/set/javascript.0.ressourcen.esx.esx-nuc_mem_usage_percent?value=$esx_nuc_ram_usage_percent | Out-Null
      #CPU Auslastung
      $esx_nuc_cpu_usage = [INT]$esx_nuc_infos.CpuUsageMhz
      Invoke-WebRequest -Uri http://192.168.4.30:8087/set/javascript.0.ressourcen.esx.esx-nuc_cpu_usage?value=$esx_nuc_cpu_usage | Out-Null
      $esx_nuc_cpu_usage_percent = $esx_nuc_infos.CpuUsageMhz / $esx_nuc_infos.CpuTotalMhz
      $esx_nuc_cpu_usage_percent = $esx_nuc_cpu_usage_percent * 100
      $esx_nuc_cpu_usage_percent = [math]::Round($esx_nuc_cpu_usage_percent,0)
      Invoke-WebRequest -Uri http://192.168.4.30:8087/set/javascript.0.ressourcen.esx.esx-nuc_cpu_usage_percent?value=$esx_nuc_cpu_usage_percent | Out-Null
      #Speicherauslastung SSD
      $datastore = Get-Datastore SSD
      $datastore_usage_percent = $datastore.CapacityGB - $datastore.FreeSpaceGB
      $datastore_usage_percent = $datastore_usage_percent / $datastore.CapacityGB
      $datastore_usage_percent = $datastore_usage_percent * 100
      $datastore_usage_percent = [math]::Round($datastore_usage_percent,2)
      Invoke-WebRequest -Uri http://192.168.4.30:8087/set/javascript.0.ressourcen.esx.esx-nuc_datastore_usage_percent?value=$datastore_usage_percent | Out-Null
      #Freier Speicher in GB
      Invoke-WebRequest -Uri http://192.168.4.30:8087/set/javascript.0.ressourcen.esx.esx-nuc_datastore_freespace?value=$($datastore.FreeSpaceGB) | Out-Null
      Uli977 K 4 Replies Last reply Reply Quote 0
      • Uli977
        Uli977 @Kuddel last edited by
        @Kuddel Was ist das? ein normales Javaskript?
        • Uli977
          @Kuddel Ach ne, über console
          • Uli977
            @Kuddel Ääää, wo muss ich das verwenden?
              Kuddel @Kuddel last edited by
              @Kuddel sagte in [Vorstellung] Meine zweite Visualisierung:
              Das ist ein Powershell Skript und muss auf Windows laufen
              Uli977 1 Reply Last reply Reply Quote 0
              • Uli977
                @Kuddel Ah, danke!
                  crunchip Forum Testing Most Active @Uli977 last edited by
                  @Uli977 liefert die Werte nicht der info Adapter
                    Kuddel @crunchip last edited by
                    @crunchip nein, der liefert nur die Werte für den ioBroker, aber nicht für den Virtualisierungshost
                      crunchip Forum Testing Most Active @Kuddel last edited by
                      @Kuddel ah ok, dann gibt es noch den ioBroker.moma und Systeminfo Adapter, jedoch eher sehr Ressourcen intensiv
                        DennisMenger @Kuddel last edited by Negalein
                        Nachdem ich mit der ersten Version meiner VIS nicht mehr zufreiden war, hab ich mich daran gemacht, alles einmal komplett neu zu machem.
                        Die Seiten sind alle fpr mein Galaxy Tab A erstellt worden.
                        Vielen Dank an @Annuit20 , der ebenfalls seine komplette VIS zur Verfügung gestellt hat. An dieser konnte ich mich orientieren und mir einige Ideen abgucken.
                        Ich denke so richtig fertig ist man ja nie, aber ein Bisschen habe ich schon geschafft….
                        Hallo.
                        Danke für die klasse Vis.
                        Leider bekomme ich die Vis nicht zusammen mit den Icons zusammen importiert. Die Icons werden in den Views nicht angezeigt. Habe beide Archive runtergeladen, jeweils entpackt und dann in einem neuen Archiv zusammengeführt. Aber nur die Vis ist da.
                        Was mache ich verkehrt?
                        Mod-Edit: Vollzitat gekürzt! Bitte vermeidet Vollzitate! Siehe Forum Regeln, Punkt 2
                        Glasfaser 1 Reply Last reply Reply Quote 1
                        • Glasfaser
                          Glasfaser @DennisMenger last edited by Glasfaser
                          @DennisMenger
                          Zeige mal den zip ( Archiv ) Inhalt , wie du es zusammen gefügt hast !
                          So muss dann der Inhalt aussehen !
                          Test Projekt installiert ……. , so sieht es dann aus :
                          @Negalein Danke für den Edit 👍
                            Super danke. Das Archiv war verkehrt gepackt. Jetzt hat es funktioniert.
                            Muss ich noch was aktualisieren damit die Bilder auch in den Views gleich angezeigt werden?
                            • Glasfaser
                              @DennisMenger
                              Was bekommst du nicht angezeigt bzw. fehlt noch !?
                              • Uli977
                                @Kuddel
                                Hallo Kuddel,
                                ich bräuchte nochmal deine Hilfe.
                                Ich will diese Anzeige aktivieren
                                Ich habe also die Objekte dazu angelegt
                                Jetzt muss das Objekt ja auch noch beschrieben werden. Das machst du mit einen Skript aus Windows heraus, oder?
                                Wenn ja kannst du mir dies nochmal bereitstellen, damit ich ein bisschen rumprobieren kann.
                                Zur Umsetzung..
                                Ich benötige also eine Windows Installation (auf dem NUC) welche ebenfalls ständig läuft, oder?
                                Heißt, unter Proxmox Win10 installieren?
                                Danke für dein Feedback!
                                Gruß,
                                Uli
                                  Kuddel @Uli977 last edited by Kuddel
                                  @Uli977 da du Proxmox verwendest, brauchst du glaube ich gar kein Script um die CPU Auslastung auszulesen.
                                  Für Proxmox gibt es einen Dapter, der das kann.
                                  [Neuer Adapter] Proxmox VM
                                  Uli977 2 Replies Last reply Reply Quote 0
                                  • Uli977
                                    @Kuddel ok, danke!
                                    Mal eine generelle Frage.
                                    Wie stelle ich fest, wer oder was den Wert befüllt?
                                    Gruß!
                                    • Uli977
                                      @Kuddel Habs gefunden.....
                                        DennisMenger @Glasfaser last edited by
                                        @Glasfaser teilweise die Bilder in der Vis, manche sind da manche nicht. Muss mal sehen, ob es vielleicht auch Bilder von noch fehlenden Adaptern sind
                                          Kuddel @DennisMenger last edited by
                                          @DennisMenger hast du den Adapter "icons-mfd-png" installiert?
                                            Jup, der ist installiert. So nach und nach sind auch fast alle Icons da.
                                            Jetzt habe ich noch eine Frage zum Adapter daswetter.
                                            Mir werden die Icons des Wetters nicht in der Vis angezeigt. Siehe Anhang.
                                            Wo ist der Denkfehler?
                                            template vis
                                            148
                                            1324
                                            490949
