    4. Conbee USB Stick auf Synology Diskstation im Docker Container
    • StM47
      StM47 last edited by StM47
      Hilft leider auch nicht.
      Hier das Log
      visibility
      build
      Host iobroker
      ioBroker.admin 3.7.1
      refresh pausedelete delete_forever
      Log herunterladen
      Log-Größe: 0.03 MB
      Zeit
      host.iobroker 2019-11-24 21:15:15.295 info instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
      openweathermap.0 2019-11-24 21:15:14.643 info (15845) Terminated (NO_ERROR): Without reason
      host.iobroker 2019-11-24 21:15:14.529 info instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      daswetter.0 2019-11-24 21:15:14.005 info (15830) Terminated (NO_ERROR): Without reason
      openweathermap.0 2019-11-24 21:15:11.417 info (15845) starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v10.17.0
      host.iobroker 2019-11-24 21:15:08.063 info instance system.adapter.openweathermap.0 started with pid 15845
      daswetter.0 2019-11-24 21:15:06.108 info (15830) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.17.0
      host.iobroker 2019-11-24 21:15:04.280 info instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
      host.iobroker 2019-11-24 21:15:04.044 info instance system.adapter.daswetter.0 started with pid 15830
      dwd.0 2019-11-24 21:15:03.763 info (15815) Terminated (NO_ERROR): Without reason
      dwd.0 2019-11-24 21:15:02.238 info (15815) starting. Version 2.4.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v10.17.0
      host.iobroker 2019-11-24 21:15:00.031 info instance system.adapter.dwd.0 started with pid 15815
      deconz.1 2019-11-24 21:13:36.042 warn (15795) No API Key found
      deconz.1 2019-11-24 21:13:36.010 info (15795) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.deconz, node: v10.17.0
      host.iobroker 2019-11-24 21:13:34.137 info instance system.adapter.deconz.1 started with pid 15795
      host.iobroker 2019-11-24 21:13:18.625 info Restart adapter system.adapter.deconz.1 because enabled
      host.iobroker 2019-11-24 21:13:18.625 error instance system.adapter.deconz.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
      host.iobroker 2019-11-24 21:13:18.625 error Caught by controller[0]: at emitErrorAndCloseNT (internal/streams/destroy.js:59:3)
      host.iobroker 2019-11-24 21:13:18.625 error Caught by controller[0]: at emitErrorNT (internal/streams/destroy.js:91:8)
      host.iobroker 2019-11-24 21:13:18.624 error Caught by controller[0]: at Socket.emit (events.js:198:13)
      host.iobroker 2019-11-24 21:13:18.624 error Caught by controller[0]: at Socket.socketErrorListener (_http_client.js:392:9)
      host.iobroker 2019-11-24 21:13:18.624 error Caught by controller[0]: at ClientRequest.emit (events.js:198:13)
      host.iobroker 2019-11-24 21:13:18.624 error Caught by controller[0]: at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:881:8)
      host.iobroker 2019-11-24 21:13:18.624 error Caught by controller[0]: at Request.emit (events.js:198:13)
      host.iobroker 2019-11-24 21:13:18.623 error Caught by controller[0]: at self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
      host.iobroker 2019-11-24 21:13:18.623 error Caught by controller[0]: at Request._callback (/opt/iobroker/node_modules/iobroker.deconz/main.js:692:28)
      host.iobroker 2019-11-24 21:13:18.623 error Caught by controller[0]: at JSON.parse (<anonymous>)
      host.iobroker 2019-11-24 21:13:18.622 error Caught by controller[0]: SyntaxError: Unexpected token u in JSON at position 0
      deconz.1 2019-11-24 21:13:18.095 info (15779) terminating
      deconz.1 2019-11-24 21:13:18.093 warn (15779) Terminated (UNCAUGHT_EXCEPTION): Without reason
      deconz.1 2019-11-24 21:13:17.090 error at emitErrorAndCloseNT (internal/streams/destroy.js:59:3)
      deconz.1 2019-11-24 21:13:17.090 error at emitErrorNT (internal/streams/destroy.js:91:8)
      deconz.1 2019-11-24 21:13:17.090 error at Socket.emit (events.js:198:13)
      deconz.1 2019-11-24 21:13:17.090 error at Socket.socketErrorListener (_http_client.js:392:9)
      deconz.1 2019-11-24 21:13:17.090 error at ClientRequest.emit (events.js:198:13)
      deconz.1 2019-11-24 21:13:17.090 error at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:881:8)
      deconz.1 2019-11-24 21:13:17.090 error at Request.emit (events.js:198:13)
      deconz.1 2019-11-24 21:13:17.090 error at self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
      deconz.1 2019-11-24 21:13:17.090 error at Request._callback (/opt/iobroker/node_modules/iobroker.deconz/main.js:692:28)
      deconz.1 2019-11-24 21:13:17.090 error at JSON.parse (<anonymous>)
      deconz.1 2019-11-24 21:13:17.090 error (15779) SyntaxError: Unexpected token u in JSON at position 0
      deconz.1 2019-11-24 21:13:17.090 error (15779) uncaught exception: Unexpected token u in JSON at position 0
      deconz.1 2019-11-24 21:13:17.001 info (15779) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.deconz, node: v10.17.0
      host.iobroker 2019-11-24 21:13:14.941 info instance system.adapter.deconz.1 started with pid 15779
      host.iobroker 2019-11-24 21:13:13.458 info instance system.adapter.deconz.1 terminated with code 156 (156)
      host.iobroker 2019-11-24 21:13:13.420 info stopInstance system.adapter.deconz.1 killing pid 15763
      deconz.1 2019-11-24 21:13:12.926 info (15763) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      deconz.1 2019-11-24 21:13:12.924 info (15763) terminating
      deconz.1 2019-11-24 21:13:12.423 info (15763) Got terminate signal TERMINATE_YOURSELF
      host.iobroker 2019-11-24 21:13:12.420 info stopInstance system.adapter.deconz.1 send kill signal
      host.iobroker 2019-11-24 21:13:12.418 info stopInstance system.adapter.deconz.1 (force=false, process=true)
      deconz.1 2019-11-24 21:12:45.478 warn (15763) No API Key found
      deconz.1 2019-11-24 21:12:45.448 info (15763) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.deconz, node: v10.17.0
      host.iobroker 2019-11-24 21:12:43.414 info instance system.adapter.deconz.1 started with pid 15763
      deconz.0 2019-11-24 21:12:28.855 debug (15504) system.adapter.admin.0: logging true
      deconz.0 2019-11-24 21:12:16.653 debug (15504) system.adapter.admin.0: logging false
      host.iobroker 2019-11-24 21:12:13.394 info Restart adapter system.adapter.deconz.1 because enabled
      host.iobroker 2019-11-24 21:12:13.394 info instance system.adapter.deconz.1 terminated with code 0 (NO_ERROR)
      host.iobroker 2019-11-24 21:12:13.394 error Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:63:19)
      host.iobroker 2019-11-24 21:12:13.394 error Caught by controller[0]: at emitErrorAndCloseNT (internal/streams/destroy.js:59:3)
      host.iobroker 2019-11-24 21:12:13.394 error Caught by controller[0]: at emitErrorNT (internal/streams/destroy.js:91:8)
      host.iobroker 2019-11-24 21:12:13.393 error Caught by controller[0]: at Socket.emit (events.js:198:13)
      host.iobroker 2019-11-24 21:12:13.393 error Caught by controller[0]: at Socket.socketErrorListener (_http_client.js:392:9)
      host.iobroker 2019-11-24 21:12:13.393 error Caught by controller[0]: at ClientRequest.emit (events.js:198:13)
      host.iobroker 2019-11-24 21:12:13.393 error Caught by controller[0]: at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:881:8)
      host.iobroker 2019-11-24 21:12:13.393 error Caught by controller[0]: at Request.emit (events.js:198:13)
      host.iobroker 2019-11-24 21:12:13.393 error Caught by controller[0]: at self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
      host.iobroker 2019-11-24 21:12:13.392 error Caught by controller[0]: at Request._callback (/opt/iobroker/node_modules/iobroker.deconz/main.js:415:47)
      host.iobroker 2019-11-24 21:12:13.391 error Caught by controller[0]: TypeError: Cannot read property 'statusCode' of undefined
      deconz.1 2019-11-24 21:12:12.858 info (15745) Terminated (NO_ERROR): Without reason
      deconz.1 2019-11-24 21:12:12.857 info (15745) terminating
      deconz.1 2019-11-24 21:12:12.352 error at process._tickCallback (internal/process/next_tick.js:63:19)
      deconz.1 2019-11-24 21:12:12.352 error at emitErrorAndCloseNT (internal/streams/destroy.js:59:3)
      deconz.1 2019-11-24 21:12:12.352 error at emitErrorNT (internal/streams/destroy.js:91:8)
      deconz.1 2019-11-24 21:12:12.352 error at Socket.emit (events.js:198:13)
      deconz.1 2019-11-24 21:12:12.352 error at Socket.socketErrorListener (_http_client.js:392:9)
      deconz.1 2019-11-24 21:12:12.352 error at ClientRequest.emit (events.js:198:13)
      deconz.1 2019-11-24 21:12:12.352 error at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:881:8)
      deconz.1 2019-11-24 21:12:12.352 error at Request.emit (events.js:198:13)
      deconz.1 2019-11-24 21:12:12.352 error at self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
      deconz.1 2019-11-24 21:12:12.352 error at Request._callback (/opt/iobroker/node_modules/iobroker.deconz/main.js:415:47)
      deconz.1 2019-11-24 21:12:12.352 error (15745) TypeError: Cannot read property 'statusCode' of undefined
      deconz.1 2019-11-24 21:12:12.351 error (15745) uncaught exception: Cannot read property 'statusCode' of undefined
      deconz.1 2019-11-24 21:12:12.308 info (15745) 192.168.178:8077auth: ZGVsaWdodDpkZWxpZ2h0
      deconz.1 2019-11-24 21:11:58.818 warn (15745) No API Key found
      deconz.1 2019-11-24 21:11:58.784 info (15745) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.deconz, node: v10.17.0
      host.iobroker 2019-11-24 21:11:56.693 info instance system.adapter.deconz.1 started with pid 15745
      deconz.0 2019-11-24 21:11:55.592 debug (15504) system.adapter.admin.0: logging true
      host.iobroker 2019-11-24 21:11:55.204 info instance system.adapter.deconz.1 terminated with code 156 (156)
      host.iobroker 2019-11-24 21:11:55.171 info stopInstance system.adapter.deconz.1 killing pid 15730
      deconz.1 2019-11-24 21:11:54.678 info (15730) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      deconz.1 2019-11-24 21:11:54.676 info (15730) terminating
      deconz.1 2019-11-24 21:11:54.173 info (15730) Got terminate signal TERMINATE_YOURSELF
      host.iobroker 2019-11-24 21:11:54.170 info stopInstance system.adapter.deconz.1 send kill signal
      host.iobroker 2019-11-24 21:11:54.167 info stopInstance system.adapter.deconz.1 (force=false, process=true)
      deconz.1 2019-11-24 21:11:53.936 warn (15730) No API Key found
      deconz.1 2019-11-24 21:11:53.904 info (15730) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.deconz, node: v10.17.0
      host.iobroker 2019-11-24 21:11:51.869 info instance system.adapter.deconz.1 started with pid 15730
      host.iobroker 2019-11-24 21:11:50.379 info instance system.adapter.deconz.1 terminated with code 156 (156)
      host.iobroker 2019-11-24 21:11:50.346 info stopInstance system.adapter.deconz.1 killing pid 15714
      deconz.1 2019-11-24 21:11:49.852 info (15714) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      deconz.1 2019-11-24 21:11:49.851 info (15714) terminating
      deconz.1 2019-11-24 21:11:49.348 info (15714) Got terminate signal TERMINATE_YOURSELF
      host.iobroker 2019-11-24 21:11:49.345 info stopInstance system.adapter.deconz.1 send kill signal
      host.iobroker 2019-11-24 21:11:49.343 info stopInstance system.adapter.deconz.1 (force=false, process=true)
      deconz.1 2019-11-24 21:11:40.281 warn (15714) No API Key found
      deconz.1 2019-11-24 21:11:40.249 info (15714) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.deconz, node: v10.17.0
      host.iobroker 2019-11-24 21:11:37.503 info instance system.adapter.deconz.1 started with pid 15714
      Bei denem Log wird ganz klar deine IP Adresse angezeigt 192.168.178.11
      und dann der Port 8077.
      Meine IP wird ganz anders aufgelöst.
      Das hängt bestimmt mit dem MACVLAN zusammen.
      Dort wird der Fehler liegen.
      • Glasfaser
        Glasfaser @StM47 last edited by
        @StM47 sagte in Conbee USB Stick auf Synology Diskstation im Docker Container:
        Siehe dein Screenshot
        Nee kann nicht … bei dir ist doch 192.168.178.50:8077
        • Glasfaser
          Glasfaser @StM47 last edited by Glasfaser
          @StM47
          Da ist mir was in deinem neuen Log aufgefallen :
          Die IP ist nicht richtig !!!
          • StM47
            Ja, habe ich schon gefixt.
            Schau mal, das steht in der rechten oberen Ecke in der Phoscon App
            • StM47
              Wenn ich die Phoscon App öffne, kommt für ein paar Sekunden folgendes Bild
              welches sich dann folgendermaßen ändert.
              • Glasfaser
                @StM47
                Sorry , komm leider nicht weiter .😧
                @Asgothian oder @Jey-Cee könnt Ihr vielleicht weiterhelfen !??
                StM47 1 Reply Last reply Reply Quote 1
                • StM47
                  StM47 @Glasfaser last edited by
                  @Glasfaser
                  Trotz dem danke für deine Hilfe! 👍
                  • StM47
                    StM47 @StM47 last edited by
                    @haselchen
                    Auch dir besten Dank!
                      duffbeer2000 last edited by duffbeer2000
                      So, ich hab leider keine Benachrichtigung per Mail erhalten das hier was passiert daher erst jetzt.
                      Mal ein paar Basisdaten damit ich weiß wie was angebunden ist:
                      • ioBroker Container, in welchem Netzwerkmodus läuft der? Host? Bridge? MacVLAN
                      • Deconz Container, in welchem Netzwerkmodus läuft der? Host? Bridge? MacVLAN
                      • Welche IP hat deine Synology?
                      Hinweise:
                      • Die Ports der Container nicht auf automatisch stellen sondern fest vergeben sonst hat man nach jedem Neustart der Diskstation Chaos.
                      • Die IP mit der 172.17.0.4 ist die interne IP des Dockereigenen Netzwerks, diese IP-Adresse ist von außen nie erreichbar. Wenn die in der Phoscon App am Anfang angezeigt wird einfach ignorieren
                      • Den Container wenn möglich nicht mit der Einstellung "Container mit höchster Priorität ausführen" betreiben! Du gewährst damit dem Container sehr weitreichende Rechte, inkl. z.B. dem Recht alle deine Daten zu löschen, nein nicht nur die im Container, sondern auch auf deiner Diskstation! Also don't do it!
                      Vermutung:
                      Dein ioBroker-Container läuft im Netzwerkmodus MacVLAN und dein Deconz-Container als Bridge oder Host. Damit ist dann (hab keine Synology, kann daher nur vom Docker Standard sprechen der bestimmt auch von der Diskstation eingehalten wird) die Kommunikation zwischen den beiden Containern geblockt. Es handelt sich hierbei um ein Sicherheitsfeature von Docker, das ein Container nicht seinen eigenen Host erreichen darf (MacVLAN -> Brige, Host geht nicht), das man auch nur über komplizierte Umwege umgehen kann. Sollte es also so sein dann ändere den Netzwerkmode vom Deconz-Container auch auf MacVLAN. (Einschränkung hierbei ist das Deconz dann nicht mehr von Alexa als Philips-Hue erkannt wird da UPNP nicht mehr funktioniert.)
                      StM47 1 Reply Last reply Reply Quote 0
                      • StM47
                        StM47 @duffbeer2000 last edited by
                        @duffbeer2000
                        Danke für deine Antwort!
                        Ich habe schon sowas vermutet.
                        Ich werde als Nächstes das ioBroker Netzwerk ändern.
                        NACVLAN bringt für mich eigentlich keinen Vorteil.
                        Wenn dann alles über Host oder Bridge läuft, sollte es mit dem Conbee Stick funktionieren.
                          rowoy last edited by
                          Hallo, hänge mich hier einfach mal dran. Bin gerade dabei den Container einzubinden. Komme aber nicht mal auf die Deconz Oberfläche. Habe soweit alle Einstellungen wie Haselchen gesetzt. Nix passiert bei Port 5900. Ich habe den Verdacht das mein Stick gar nicht von der Syno (DS218+) erkannt wird. Muss ich da noch was extra installieren oder bei DECONZ_DEVICE einen Pfad wie /dev/ttyACM1 eintragen? Nutze im Moment auf dem gleichen System in einem anderen Docker den IObroker mit einem Zigbee CC25.. Stick am USB Port ttyACM0... den wollte ich eigentlich mit den ConBee ersetzen. Hat wer eine Idee wo ich noch ansetzen könnte?
                          • Glasfaser
                            Glasfaser @rowoy last edited by
                            @rowoy
                            Port 5900 ist nur mit VNC Viewer sichtbar .
                            zu /dev/ttyACM1
                            • StM47
                              So Leute, ich habe meine ioBroker Instanz auf den Bridge Mode umgebaut.
                              Jetzt laufen der Conbee Stick und die Syno im selben Netzwerk.
                              Und siehe da, die Verbindung steht beim ersten Versuch.
                              Der API Key wurde sofort erzeugt.
                              Vielen Dank noch einmal an alle, die sich für mich bemüht haben!
                                p3pp0 @StM47 last edited by
                                @StM47 mit welchen Einstellungen hast du das hinbekommen? Ich hatte immer Fehler im Log + Adapter-Dauer-Neustart im Bridge Mode... nur wenn iobroker + Deconz im Host laufen geht es bei mir
                                • StM47
                                  So sehen meine Einstellungen aus.
                                  Bei mir musste bei DECONZ_DEVICE noch der Pfad für den Stick rein - /dev/ttyACM0
                                  Konnte ohne diese Einstellung keine Sensoren anlernen und ich muss den Container mit hoher Priorität ausführen, sonst wird Conbee Stick nicht erkannt .
                                  In einem anderen Bord habe ich gelesen, dass einige User noch folgende Befehle in der Konsole ausführen mussten. War bei m ir aber nicht nötig.
                                  sudo insmod /lib/modules/usbserial.ko
                                  sudo insmod /lib/modules/ftdi_sio.ko
                                  Bei mir läuft soweit alles ganz gut.
                                  Ich kann nur keine Zeitzone einstellen. Keine Ahnung, warum?!
                                    duffbeer2000 @StM47 last edited by
                                    @StM47
                                    Kannst du mal auf deiner Diskstation folgende Befehle ausführen und den Output posten?
                                    grep dialout /etc/group
                                    ls -l /dev/ttyACM0
                                    ls /etc/localtime
                                    Die Einstellung "Container mit hoher Priorität ausführen" sollte unbedingt vermieden werden. Beim Conbee Container geht das über die dialout Gruppe, wenn die die richtigen Rechte hat, dann läuft der Contianer ohne die hohe Priorität, deshalb die ersten beiden Befehle um zu schauen was fehlt:
                                    https://github.com/marthoc/docker-deconz/#pre-requisite
                                    Und der letzte Befehl bezüglich der Zeitzone.
                                    • StM47
                                      @duffbeer2000 sagte in Conbee USB Stick auf Synology Diskstation im Docker Container:
                                      root@iobroker:/opt/iobroker# grep dialout /etc/group
                                      dialout❌20:iobroker
                                      ls -l /dev/ttyACM0
                                      root@iobroker:/opt/iobroker# ls -l /dev/ttyACM0
                                      ls: Zugriff auf '/dev/ttyACM0' nicht möglich: Datei oder Verzeichnis nicht gefunden
                                      ls /etc/localtime
                                      root@iobroker:/opt/iobroker# ls /etc/localtime
                                      /etc/localtime
                                        @StM47 Nicht im ioBroker Container sondern direkt auf deiner Diskstation 😉
                                        StM47 2 Replies Last reply Reply Quote 0
                                        • StM47
                                          @duffbeer2000
                                          😊 Moment
                                          • StM47
                                            ls /etc/localtime
                                            root@DiskStation:~# grep dialout /etc/group
                                            root@DiskStation:~# ls -l /dev/ttyACM0
                                            crw------- 1 root root 166, 0 Nov 26 00:29 /dev/ttyACM0
                                            root@DiskStation:~# ls /etc/localtime
                                            /etc/localtime
                                            root@DiskStation:~#
                                            301
                                            61443
