    4. Adapter: DasWetter
    Adapter: DasWetter
    • hg6806
      hg6806 Most Active last edited by
      OK, wo finde ich das Verzeichnis "docs"
      • Rene_HM
        Rene_HM Developer @hg6806 last edited by
        @hg6806 siehe hier:
        oder auch bei DasWetter unter
        https://www.daswetter.com/api/#/board/hilfe
          Alexxx2005 @Rene_HM last edited by
          @Rene_HM said in Adapter: DasWetter:
          Die vis habe ich mit einem zusätzlichen javascript erstellt.
          ! createState('WeatherSymbol0', '');
          ! createState('WindSymbol0', '');
          ! createState('WeatherSymbol1', '');
          ! createState('WindSymbol1', '');
          ! createState('WeatherSymbol2', '');
          ! createState('WindSymbol2', '');
          ! createState('WeatherSymbol3', '');
          ! createState('WindSymbol3', '');
          ! createState('WeatherSymbol4', '');
          ! createState('WindSymbol4', '');
          ! on("daswetter.0.NextDaysDetailed.0d.SymbolID", function(obj) {
          ! var symbol = parseInt(obj.newState.val, 10);
          ! var temp = 'http://192.168.DeineIP:8082/daswetter/i … /galeria3/' + symbol + '.png';
          ! log (temp);
          ! setState('WeatherSymbol0', temp );
          ! on("daswetter.0.NextDaysDetailed.0d.WindSymbolB", function(obj) {
          ! var windsymbol = parseInt(obj.newState.val, 10);
          ! var temp = 'http://192.168.DeineIP:8082/daswetter/i ... nd/galeria 2 - Beaufort/' + windsymbol + '.png';
          ! log (temp);
          ! setState('WindSymbol0', temp);
          ! on("daswetter.0.NextDaysDetailed.1d.SymbolID", function(obj) {
          ! var temp = 'http://192.168.DeineIP:8082/daswetter/i ... /galeria3/' + symbol + '.png';
          ! log (temp);
          ! setState('WeatherSymbol1', temp );
          ! on("daswetter.0.NextDaysDetailed.1d.WindSymbolB", function(obj) {
          ! log (temp);
          ! setState('WindSymbol1', temp);
          ! on("daswetter.0.NextDaysDetailed.2d.SymbolID", function(obj) {
          ! log (temp);
          ! setState('WeatherSymbol2', temp );
          ! on("daswetter.0.NextDaysDetailed.2d.WindSymbolB", function(obj) {
          ! log (temp);
          ! setState('WindSymbol2', temp);
          ! on("daswetter.0.NextDaysDetailed.3d.SymbolID", function(obj) {
          ! log (temp);
          ! setState('WeatherSymbol3', temp );
          ! on("daswetter.0.NextDaysDetailed.3d.WindSymbolB", function(obj) {
          ! log (temp);
          ! setState('WindSymbol3', temp);
          ! on("daswetter.0.NextDaysDetailed.4d.SymbolID", function(obj) {
          ! log (temp);
          ! setState('WeatherSymbol4', temp );
          ! on("daswetter.0.NextDaysDetailed.4d.WindSymbolB", function(obj) {
          ! log (temp);
          ! setState('WindSymbol4', temp);
          In dem script lege ich für jeden Tage eine Variable für WetterSymbol und WindSymbol an. Bei Änderung des Wertes im Adapter wird der link auf das entsprechende Icon auf die Variable geschrieben. Ich habe die komplette IP (muss oben im script entsprechend angepasst werden) mit drin, damit das ganze nicht nur im explorer sondern auch in der Android-App funktioniert.
          In der vis nehme ich dann ein einfaches "String Image Src"und als Quelle nehme ich die Variable aus dem javascript (siehe Bild)
          Hallo Zusammen bekomme es einfach nicht geschafft, kann es sein das es so aktuell nicht mehr möglich ist ?
          Danke, Grüße Alex
            Coffeelover @Alexxx2005 last edited by
            @Alexxx2005 Nein, kann eigentlich nicht sein - bei mir läuft das in VIS.
            • ListenpunktHast du Einträge im Log?
            • Läuft das Script?
            • Werden die Datenpunkte selbst richtig angelegt / befüllt?
            • Ändern sich die Icon, wenn du die Datenpunkte selbst veränderst? Da kann ja nichts passieren, weil das Script deine Änderung im nächsten Update eh wieder aktualisiert.
            VG
            B A 2 Replies Last reply Reply Quote 0
              Bastel2001 @Coffeelover last edited by
              ich habe den Adapter, den Script und das Widget installiert und alles läuft. Schonmal vorab vielen Dank dafür.
              Die Beschriftung auf der X-Achse ist nach durchprobieren %a..%z augenscheinlich englisch, ich hätte hier gern die deutsche kurze Variante also Mo,Di,Mi...
              Gibt es hierfür eine Lösung?
              Danke sehr
                Alexxx2005 @Coffeelover last edited by
                @Coffeelover Danke nun läuft das Script.
                habe in der zwischenzeit noch den Sonnenstand installiert, Problem ist hier noch mit den icons wo finde ich die Sonnen Icon's habe alles durchblättert und finde nur die Wetter Hd oder Mond Icon's würde mich freuen wenn mir hier jemand weiter helfen kann. Grüße Alex
                  die icoc's habe ich mittlerweile gefunden .
                  Problem ist nur das mein Adapter sich nicht aktualisiert, habe beim vierten Pfad die API eingetragen , jetzt die große Frage müssen oben beide Haken gesetzt sein oder nicht da bin ich mir nicht sicher.
                  Grüße Alex
                    sigi234 Forum Testing Most Active @Alexxx2005 last edited by
                    @Alexxx2005 sagte in Adapter: DasWetter:
                    Cron auf aktuelle Zeit setzen und warten
                      Alexxx2005 @sigi234 last edited by
                      @sigi234 ok aber was ist mit den Haken in der Adapterkonfiguration ?
                      • Rene_HM
                        Rene_HM Developer @Alexxx2005 last edited by
                        @Alexxx2005 Es muss nur ein Haken "neue Struktur" gesetzt sein...
                        Bzgl. Aktualisierung: schau mal im log nach, ob da etwas steht...
                          Snapergy last edited by
                          Gibt es denn eine Möglichkeit, dass die Schnittstelle auch die Regenwahrscheinlichkeit und den UV-Index mit ausgibt?
                            sigi234 Forum Testing Most Active @Snapergy last edited by
                            @Snapergy sagte in Adapter: DasWetter:
                            Nein, aber Regen geht mit WU und UV mit dem Adapter
                            https://github.com/x3l4c0d3/ioBroker.openuv
                            • SMS
                              SMS last edited by SMS
                              irgendwie funktioniert das bei mir nicht:
                              Das Obere ist das weather Widget
                              Im Unteren sollten eigentlich die Daten wie hier beschrieben wird dargestellt werden.
                              Werte kommen an
                              Müsste hier nicht auch was drin stehen?
                              Steht im LOG
                              Danke!
                              Negalein FredF 2 Replies Last reply Reply Quote 0
                              • Negalein
                                Negalein Global Moderator @SMS last edited by
                                @SMS sagte in Adapter: DasWetter:
                                Steht im LOG
                                Stell den Adapter mal auf "Debug". Dann sieht man mehr im Log.
                                • SMS
                                  SMS last edited by
                                  Hab cron mal kurz auf eine Minute gestellt:
                                  • Rene_HM
                                    Rene_HM Developer @SMS last edited by Rene_HM
                                    @SMS Der Adapter aktualisiert Daten. Das sieht man ja auch oben im screen shot unter daswetter.0.
                                    Der Adapter schreibt aber nicht auf Datenpunkte unter javascript.vis. Das müsste im script erfolgen...
                                    • FredF
                                      FredF Most Active Forum Testing @SMS last edited by
                                      @SMS
                                      Wenn Daten ankommen, ist die Frage was das Skript macht und wo die Daten hinwandern. Zeig doch bitte mal dein Skript
                                      • SMS
                                        var temp = 'http://192.168.178.75:8082/daswetter/i … /galeria3/' + symbol + '.png';
                                        log (temp);
                                        var temp = 'http://192.168.178.75:8082/daswetter/i ... nd/galeria 2 - Beaufort/' + windsymbol + '.png';
                                        log (temp);
                                        var temp = 'http://192.168.178.75:8082/daswetter/i ... /galeria3/' + symbol + '.png';
                                        log (temp);
                                        log (temp);
                                        log (temp);
                                        log (temp);
                                        log (temp);
                                        log (temp);
                                        log (temp);
                                        log (temp);
                                        Ist der von hier, habe lediglich die IP Adresse angepasst
                                        Das obere weather Widget hatte ich mir auch anders vorgestellt ... Zumindest wenn ich mal so vergleiche was man so sieht ...
                                        Rene_HM 2 Replies Last reply Reply Quote 0
                                        • Rene_HM
                                          @SMS und warum nimmst du die Pfade zu den Symbolen nicht direkt aus dem Adapter?
                                          Da könntest du dir das script sparen...
                                          • Rene_HM
                                            Da kannst du doch fast alles selbst einstellen. Was fehlt dir?
                                            1208
                                            411586
