    4. Test Adapter enigma2 v1.2.x
    • Scrounger
      Scrounger Developer @Matten Matten last edited by Scrounger
      @Matten-Matten sagte in Test Adapter enigma2 v1.2.x:
      1.2.5 (2019-11-17)
      • (Scrounger) add: .enigma2.Timer_list
      Damit kann man mit meiner Table des Material Design Wigdets Adapter ein ganz schickes Widget realisieren:
      Skript um Daten aufzubereiten:
      // import
      const moment = require("moment");
      const momentDurationFormatSetup = require("moment-duration-format");
      moment.locale("de");
      let enigma2AdapterTimerListId = 'enigma2.0.enigma2.Timer_list';
      on({ id: enigma2AdapterTimerListId }, formatList);
      function formatList() {
          try {
              let list = JSON.parse(getState(enigma2AdapterTimerListId).val);
              let myList = [];
              if (list && list !== null && list !== undefined && list !== '') {
                  for (var i = 0; i <= list.length - 1; i++) {
                      let listItem = list[i]
                      let startTime = moment(listItem.starTime * 1000);
                      let endTime = moment(listItem.endTime * 1000);
                      let recordDateFormatted = `${startTime.format('ddd')} ${startTime.format('DD.MM')}`
                      let starTimeFormatted = `${startTime.format('LT')}`
                      let endTimeFormatted = `${endTime.format('LT')}`
                      if (moment().isSame(startTime, 'day')) {
                          recordDateFormatted = `Heute ${startTime.format('DD.MM')}`;
                      } else if (moment().add(1, 'day').isSame(startTime, 'day')) {
                          recordDateFormatted = `Morgen ${startTime.format('DD.MM')}`;
                      let rawtitle = listItem.title;
                      let title = rawtitle;
                      let subtitle = listItem.subtitle;
                      if (title.includes(' - ')) {
                          title = rawtitle.substring(0, rawtitle.indexOf(' - ')).trim();
                          if (subtitle === '') {
                              subtitle = rawtitle.substring(rawtitle.indexOf(' - ') + 2, rawtitle.length).trim();
                      myList.push(
                              channelImage: `/vis.0/myImages/picons/${listItem.serviceRefName}.png`,
                              title: title,
                              recordDateFormatted: recordDateFormatted,
                              subtitle: subtitle,
                              starTimeFormatted: starTimeFormatted,
                              startTime: listItem.starTime,
                              endTimeFormatted: endTimeFormatted,
                              channel: listItem.channel,
                  myList.sort(function (a, b) {
                      // Liste sortieren nach Startzeit
                      return a.starTime == b.starTime ? 0 : +(a.starTime > b.starTime) || -1;
              myDevices.Netzwerk.Devices.VuPlus.TimerList.setState(JSON.stringify(myList), true);
          } catch (err) {
              console.error(`[createList] error: ${err.message}`);
              console.error(`[createList] stack: ${err.stack}`);
      formatList();
      Widget:
      [{"tpl":"tplVis-materialdesign-Table","data":{"oid":"linkeddevices.0.Netzwerk.Devices.VuPlus.TimerList","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","countCols":"2","tableLayout":"standard","showHeader":"true","headerTextSize":"11","showColumn0":"true","colType0":"image","textAlign0":"center","showColumn1":"true","colType1":"text","textAlign1":"left","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"showColumn2":"true","colType2":"text","textAlign2":"right","showColumn3":"true","colType3":"text","textAlign3":"center","imageSize0":"50","sortKey1":"channel","showColumn4":"true","colType4":"text","textAlign4":"center","showColumn5":"true","colType5":"text","textAlign5":"center","showColumn6":"true","colType6":"text","textAlign6":"center","showColumn7":"true","colType7":"text","textAlign7":"center","showColumn8":"true","colType8":"text","textAlign8":"center","label0":"Kanal","label1":"Aufnahme","label2":"Zeit","padding_left0":"6","colorHeaderRowText":"#ffffff","colorRowBackground":"","colorHeaderRowBackground":"#44739e","headerFontFamily":"RobotoCondensed-Regular","rowHeight":"","suffix1":"<br>\n<span style=\"display: inline-block; white-space: nowrap; overflow: hidden !important; text-overflow: ellipsis; max-width: 170px; font-size: 12px; font-family: RobotoCondensed-LightItalic; color: #8a8a8a\">#[obj.subtitle]</span>\n","textSize1":"14","fontFamily1":"RobotoCondensed-Regular","textColor1":"#44739e","padding_right0":"6","padding_left1":"0","sortKey0":"channel","sortKey2":"startTime","fontFamily2":"RobotoCondensed-LightItalic","textSize2":"11px","suffix2":"<br>\n<span style=\"display: inline-block; white-space: nowrap; overflow: hidden !important; max-width: 150px; font-size: 12px; font-family: RobotoCondensed-LightItalic; color: #8a8a8a\">#[obj.starTimeFormatted] - #[obj.endTimeFormatted]</span>\n","padding_left2":"0","padding_right1":"0","textColor2":"#44739e"},"style":{"left":"667px","top":"16px","width":"340px","height":"372px","overflow-y":"auto"},"widgetSet":"materialdesign"}]
      Zur Info ich hab die Channel picons lokal abgelegt, da meine Box nicht immer läuft.
      Ihr könnt aber im Skript natürlich auch das verwenden:
      http://192.168.0.1:80/picon/1_0_19_2B5C_41B_1_FFFF014A_0_0_0.png
      Glasfaser K 2 Replies Last reply Reply Quote 1
      • Glasfaser
        Glasfaser @Scrounger last edited by Glasfaser
        @Scrounger sagte in Test Adapter enigma2 v1.2.x:
        } catch (err) {
        Hast du da ein Fehler drin !?
        ist das nicht so :
        setState("myDevices.Netzwerk.Devices.VuPlus.TimerList",JSON.stringify(myList), true);
        • Scrounger
          Scrounger Developer @Glasfaser last edited by Scrounger
          @Glasfaser
          Ne alles richtig. Sowas geht mit dem meinem linkedDevices Adapter. Damit kann man sich automatisch Variablen erzeugen lassen.
          Wenn du z.B. mit ner IDE deine Skripte schreibst, dann werden diese erzeugten Variablen entsprechend vorgeschlagen. Vorteil man muss nicht immer die Id's sich einzeln raus suchen.
            eve11 last edited by Negalein
            Hallo zusammen, ich habe schon seit über einen Jahr den Enigma Adapter nicht mit einem Update versehen. (Never change a running system 🙂 ) Jetzt habe ich von der alten version 1.1.0 auf die aktuellste Version upgedatet. Nun habe ich natürlich ein Problem.
            Log:
            enigma2.0	2019-11-24 14:02:44.335	info	(594) enigma2: 192.168.178.33:80 ist nicht erreichbar
            enigma2.0	2019-11-24 14:02:47.098	info	(594) enigma2 Verbunden
            Wie ihr sehen könnt, verliert der Adapter kurz die Verbindung zur VU Box.
            Da ich an das Ein-und Ausschalten gewisse Aktionen gebunden habe, werden diese natürlich jetzt ausgelöst.
            Wie kann ich dieses Problem angehen ? Kann ich irgendwo die alten Versionen downloaden ?
            Die Node.js und der js-controller sind jeweils auf dem aktuellen Stand.
            Vielen Dank für eure Hilfe.
            eve11
            Matten Matten 1 Reply Last reply Reply Quote 0
              ChrisXY last edited by ChrisXY
              Selbst schon verstanden 😉
                Jan1 @ChrisXY last edited by
                @ChrisXY
                Da hast recht, ist ne dumme Frage.
                Erstens weil der Adapter Enigma2 heißt und das nicht die Version des Adapter ist sondern das OS des Sat Receiver und zweitens steht gleich im ersten Post das Changelog des Adapter 😊
                • Negalein
                  Negalein Global Moderator @Jan1 last edited by Negalein
                  @Jan1 sagte in Test Adapter enigma2 v1.2.x:
                  Ähhhh sorry, aber es gibt KEINE dummen Fragen !!
                    Jan1 @Negalein last edited by
                    @Negalein
                    Doch, hatte er ja schon selber bemerkt und wo er recht hat, hat er recht 😉
                      BlueEssi last edited by
                      Ich habe in einem anderen Thread gelesen, dass es parallel zum Enigma2-Adapter noch einen VU+-Adapter gibt. Dieser scheint nicht mehr weiter entwickelt zu werden, hat aber eine Erweiterung zur Steuerung von Enigmalight integriert. Wäre es möglich, diese Erweiterung für den Enigma2-Adapter zu übernehmen?
                      E Matten Matten 2 Replies Last reply Reply Quote 0
                        el_malto @BlueEssi last edited by
                        @BlueEssi
                        Ich denke das wird schwierig. Der Adapter hier soll ja "universal" sein, also für jedes Image. Soweit ich weiß, läuft Enigmalight nur mit dem VTi Image.
                          Jan1 @el_malto last edited by
                          Enigma Light läuft auf der Box als Plugin, warum sollte man das im Adapter noch steuern können? Da erschließt sich mir der Sinn nicht, da das an oder aus ist.
                          Das läuft übrigens bei mir auf der DM900 mit der original FW OS2.5, ist halt ne Dream und keine VU😎
                          • Matten Matten
                            Matten Matten @eve11 last edited by
                            @eve11 sagte in Test Adapter enigma2 v1.2.x:
                            Log:
                            eve11
                            Am besten den Adapter komplett löschen und von GitHub neu laden und Instanzen neu erzeugen.
                            • Matten Matten
                              Matten Matten @BlueEssi last edited by Matten Matten
                              @BlueEssi sagte in Test Adapter enigma2 v1.2.x:
                              Das habe ich bewusst wieder heraus genommen, da dieser Adapter nur für den enigma2 Receiver ist in Verbindung mit dem Webinterface ist.
                              Wenn du da Interesse hast ein anderes Plugin zu steuern dann ist es vielleicht interessanter einen extra Adapter dafür zu bauen.
                              Denn für das auch bekannte Hyperion ambilight gibt's auch einen extra Adapter.
                              • coyote
                                coyote Most Active last edited by
                                @Matten-Matten ich habe gerade die 1.2.5 über Git installiert, jetzt bekomme ich folgenden Fehler:
                                host.debian	2019-11-26 13:55:49.837	info	Restart adapter system.adapter.enigma2.0 because enabled
                                host.debian	2019-11-26 13:55:49.836	info	instance system.adapter.enigma2.0 terminated with code 0 (NO_ERROR)
                                host.debian	2019-11-26 13:55:49.836	error	Caught by controller[2]: at Parser.exports.Parser.Parser.parseString (/opt/iobroker/node_modules/xml2js/lib/parser.js:322:31)
                                host.debian	2019-11-26 13:55:49.836	error	Caught by controller[2]: at SAXParser.write (/opt/iobroker/node_modules/sax/lib/sax.js:1436:13)
                                host.debian	2019-11-26 13:55:49.836	error	Caught by controller[2]: at closeTag (/opt/iobroker/node_modules/sax/lib/sax.js:889:7)
                                host.debian	2019-11-26 13:55:49.836	error	Caught by controller[2]: at emitNode (/opt/iobroker/node_modules/sax/lib/sax.js:629:5)
                                host.debian	2019-11-26 13:55:49.836	error	Caught by controller[2]: at emit (/opt/iobroker/node_modules/sax/lib/sax.js:624:35)
                                host.debian	2019-11-26 13:55:49.836	error	Caught by controller[2]: at SAXParser.onclosetag (/opt/iobroker/node_modules/xml2js/lib/parser.js:261:26)
                                host.debian	2019-11-26 13:55:49.835	error	Caught by controller[2]: at Parser.emit (events.js:198:13)
                                host.debian	2019-11-26 13:55:49.835	error	Caught by controller[2]: at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:303:18)
                                host.debian	2019-11-26 13:55:49.835	error	Caught by controller[2]: at /opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:323:7
                                host.debian	2019-11-26 13:55:49.835	error	Caught by controller[2]: at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:385:64)
                                host.debian	2019-11-26 13:55:49.835	error	Caught by controller[2]: TypeError: Cannot read property 'e2statetext' of undefined
                                host.debian	2019-11-26 13:55:49.835	error	Caught by controller[1]: at Parser.exports.Parser.Parser.parseString (/opt/iobroker/node_modules/xml2js/lib/parser.js:322:31)
                                host.debian	2019-11-26 13:55:49.835	error	Caught by controller[1]: at SAXParser.write (/opt/iobroker/node_modules/sax/lib/sax.js:1436:13)
                                host.debian	2019-11-26 13:55:49.834	error	Caught by controller[1]: at closeTag (/opt/iobroker/node_modules/sax/lib/sax.js:889:7)
                                host.debian	2019-11-26 13:55:49.834	error	Caught by controller[1]: at emitNode (/opt/iobroker/node_modules/sax/lib/sax.js:629:5)
                                host.debian	2019-11-26 13:55:49.834	error	Caught by controller[1]: at emit (/opt/iobroker/node_modules/sax/lib/sax.js:624:35)
                                host.debian	2019-11-26 13:55:49.829	error	Caught by controller[1]: at SAXParser.onclosetag (/opt/iobroker/node_modules/xml2js/lib/parser.js:261:26)
                                host.debian	2019-11-26 13:55:49.829	error	Caught by controller[1]: at Parser.emit (events.js:198:13)
                                host.debian	2019-11-26 13:55:49.829	error	Caught by controller[1]: at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:303:18)
                                host.debian	2019-11-26 13:55:49.829	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:323:7
                                host.debian	2019-11-26 13:55:49.829	error	Caught by controller[1]: at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:550:60)
                                host.debian	2019-11-26 13:55:49.829	error	Caught by controller[1]: TypeError: Cannot read property 'e2about' of undefined
                                host.debian	2019-11-26 13:55:49.829	error	Caught by controller[0]: at Parser.exports.Parser.Parser.parseString (/opt/iobroker/node_modules/xml2js/lib/parser.js:322:31)
                                host.debian	2019-11-26 13:55:49.829	error	Caught by controller[0]: at SAXParser.write (/opt/iobroker/node_modules/sax/lib/sax.js:1436:13)
                                host.debian	2019-11-26 13:55:49.828	error	Caught by controller[0]: at closeTag (/opt/iobroker/node_modules/sax/lib/sax.js:889:7)
                                host.debian	2019-11-26 13:55:49.828	error	Caught by controller[0]: at emitNode (/opt/iobroker/node_modules/sax/lib/sax.js:629:5)
                                host.debian	2019-11-26 13:55:49.828	error	Caught by controller[0]: at emit (/opt/iobroker/node_modules/sax/lib/sax.js:624:35)
                                host.debian	2019-11-26 13:55:49.828	error	Caught by controller[0]: at SAXParser.onclosetag (/opt/iobroker/node_modules/xml2js/lib/parser.js:261:26)
                                host.debian	2019-11-26 13:55:49.828	error	Caught by controller[0]: at Parser.emit (events.js:198:13)
                                host.debian	2019-11-26 13:55:49.828	error	Caught by controller[0]: at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:303:18)
                                host.debian	2019-11-26 13:55:49.828	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:323:7
                                host.debian	2019-11-26 13:55:49.828	error	Caught by controller[0]: at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:406:76)
                                host.debian	2019-11-26 13:55:49.828	error	Caught by controller[0]: TypeError: Cannot read property 'e2instandby' of undefined
                                enigma2.0	2019-11-26 13:55:49.152	info	(3184) Terminated (NO_ERROR): Without reason
                                enigma2.0	2019-11-26 13:55:49.150	info	(3184) terminating
                                enigma2.0	2019-11-26 13:55:48.907	info	(3184) enigma2 Verbunden!
                                enigma2.0	2019-11-26 13:55:48.687	error	(3184) TypeError: Cannot read property 'e2statetext' of undefined at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:385:64) at /opt/iobroker/node_modules/iobro
                                enigma2.0	2019-11-26 13:55:48.687	error	(3184) uncaught exception: Cannot read property 'e2statetext' of undefined
                                enigma2.0	2019-11-26 13:55:48.674	error	(3184) No e2volume found
                                enigma2.0	2019-11-26 13:55:48.667	error	(3184) TypeError: Cannot read property 'e2about' of undefined at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:550:60) at /opt/iobroker/node_modules/iobroker.
                                enigma2.0	2019-11-26 13:55:48.667	error	(3184) uncaught exception: Cannot read property 'e2about' of undefined
                                enigma2.0	2019-11-26 13:55:48.648	error	(3184) TypeError: Cannot read property 'e2instandby' of undefined at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:406:76) at /opt/iobroker/node_modules/iobro
                                enigma2.0	2019-11-26 13:55:48.648	error	(3184) uncaught exception: Cannot read property 'e2instandby' of undefined
                                enigma2.0	2019-11-26 13:55:42.709	info	(3184) starting Polling every 5000 ms
                                Die Instanz hab ich schon gelöscht, nochmal installiert und einen Upload gemacht, gleicher Fehler.
                                Den Adapter komplett deinstallieren ging nicht "marked as non deletable"
                                Könnte die Instanz jetzt nochmal löschen und den Adapter aus node-modules von Hand löschen
                                • Matten Matten
                                  Matten Matten @coyote last edited by
                                  @coyote
                                  Bist du dir sicher das die IP Adresse und der Port sowie der eventuelle Login richtig eingetragen ist?
                                  • coyote
                                    coyote Most Active @Matten Matten last edited by
                                    @Matten-Matten hm, anscheinend hat sich meine Box gerade verabschiedet, IP ist nicht mehr erreichbar. Werde später nochmal testen.
                                    Habe aber jetzt von Hand alles gelöscht und neu installiert, dann bekomm ich keinen Erro wie oben, sonder es steht nur, dass sie nicht erreichbar ist
                                    • coyote
                                      @Matten-Matten hat sich erledigt, funktioniert. War wirklich nur die Box abgeschmiert.
                                      • dslraser
                                        @Matten-Matten
                                        da ja über den Adapter auch Nachrichten an die Box gesendet werden können, würde vielleicht so etwas Sinn machen ?
                                        Im Moment mache ich das so
                                        oder so
                                        • Matten Matten
                                          @dslraser
                                          klar warum nicht, aber keine ahnung wer das in blockly programiert...
                                          • dslraser
                                            dslraser Forum Testing Most Active @Matten Matten last edited by
                                            @dslraser
                                            das geht über die jeweiligen Adapter. Aber da ich keine Ahnung von Adapterprogrammierung habe, frage ich das ja Dich.
                                            adapter enigma2
                                            71
                                            640
                                            140914
