    4. Skript LOWBAT
    Skript LOWBAT
      deifel last edited by
      10:30:00.016	warn	javascript.0 (28564) at script.js.common.Lowbat:20:10
      10:30:00.016	warn	javascript.0 (28564) at countLowbat (script.js.common.Lowbat:18:24)
      10:30:00.016	warn	javascript.0 (28564) at Object.<anonymous> (script.js.common.Lowbat:46:4)
      10:30:00.017	warn	javascript.0 (28564) at script.js.common.Lowbat:21:19
      10:30:00.017	warn	javascript.0 (28564) at countLowbat (script.js.common.Lowbat:18:24)
      10:30:00.017	warn	javascript.0 (28564) at Object.<anonymous> (script.js.common.Lowbat:46:4)
      10:30:00.018	info	javascript.0 (28564) script.js.common.Lowbat: Geräte Nr. 101: undefined: null
      10:30:00.018	warn	javascript.0 (28564) at script.js.common.Lowbat:20:10
      10:30:00.018	warn	javascript.0 (28564) at countLowbat (script.js.common.Lowbat:18:24)
      10:30:00.018	warn	javascript.0 (28564) at Object.<anonymous> (script.js.common.Lowbat:46:4)
      10:30:00.019	warn	javascript.0 (28564) at script.js.common.Lowbat:21:19
      10:30:00.019	warn	javascript.0 (28564) at countLowbat (script.js.common.Lowbat:18:24)
      10:30:00.019	warn	javascript.0 (28564) at Object.<anonymous> (script.js.common.Lowbat:46:4)
      10:30:00.020	info	javascript.0 (28564) script.js.common.Lowbat: Geräte Nr. 102: undefined: null
      10:30:00.021	warn	javascript.0 (28564) at script.js.common.Lowbat:20:10
      10:30:00.021	warn	javascript.0 (28564) at countLowbat (script.js.common.Lowbat:18:24)
      10:30:00.021	warn	javascript.0 (28564) at Object.<anonymous> (script.js.common.Lowbat:46:4)
      10:30:00.022	warn	javascript.0 (28564) at script.js.common.Lowbat:21:19
      10:30:00.022	warn	javascript.0 (28564) at countLowbat (script.js.common.Lowbat:18:24)
      10:30:00.022	warn	javascript.0 (28564) at Object.<anonymous> (script.js.common.Lowbat:46:4)
      10:30:00.023	info	javascript.0 (28564) script.js.common.Lowbat: Geräte Nr. 103: undefined: null
      10:30:00.023	warn	javascript.0 (28564) at script.js.common.Lowbat:20:10
      10:30:00.023	warn	javascript.0 (28564) at countLowbat (script.js.common.Lowbat:18:24)
      10:30:00.023	warn	javascript.0 (28564) at Object.<anonymous> (script.js.common.Lowbat:46:4)
      10:30:00.024	warn	javascript.0 (28564) at script.js.common.Lowbat:21:19
      10:30:00.024	warn	javascript.0 (28564) at countLowbat (script.js.common.Lowbat:18:24)
      10:30:00.024	warn	javascript.0 (28564) at Object.<anonymous> (script.js.common.Lowbat:46:4)
      10:30:00.024	info	javascript.0 (28564) script.js.common.Lowbat: Geräte Nr. 104: undefined: null
      10:30:00.025	warn	javascript.0 (28564) at script.js.common.Lowbat:20:10
      10:30:00.025	warn	javascript.0 (28564) at countLowbat (script.js.common.Lowbat:18:24)
      10:30:00.025	warn	javascript.0 (28564) at Object.<anonymous> (script.js.common.Lowbat:46:4)
      10:30:00.026	warn	javascript.0 (28564) at script.js.common.Lowbat:21:19
      10:30:00.026	warn	javascript.0 (28564) at countLowbat (script.js.common.Lowbat:18:24)
      10:30:00.026	warn	javascript.0 (28564) at Object.<anonymous> (script.js.common.Lowbat:46:4)
      10:30:00.026	info	javascript.0 (28564) script.js.common.Lowbat: Geräte Nr. 105: undefined: null
      10:30:00.026	info	javascript.0 (28564) script.js.common.Lowbat: Text:
      10:30:00.026	info	javascript.0 (28564) script.js.common.Lowbat: Anzahl Geräte: 106 # davon LOWBAT erkannt: 0
        paul53 @deifel last edited by
        @deifel Welche IDs gibt das Test-Skript mit den Nummern 101 bis 105 aus ?
          @paul53 said in Skript LOWBAT:
          $('channel[state.id=*0.LOWBAT]').each(function(id, i) { if(i > 82) log(i + ': ' + id); });
          10:35:50.771	info	javascript.0 (28564) script.js.common.TEST: 100: hm-rpc.0.QEQ0087728.0.LOWBAT
          10:35:50.771	info	javascript.0 (28564) script.js.common.TEST: 101: hm-rpc.1.CUX2801001.0.LOWBAT
          10:35:50.771	info	javascript.0 (28564) script.js.common.TEST: 102: hm-rpc.1.CUX4000001.0.LOWBAT
          10:35:50.771	info	javascript.0 (28564) script.js.common.TEST: 103: hm-rpc.1.CUX9000002.0.LOWBAT
          10:35:50.771	info	javascript.0 (28564) script.js.common.TEST: 104: hm-rpc.1.CUX9000003.0.LOWBAT
          10:35:50.771	info	javascript.0 (28564) script.js.common.TEST: 105: hm-rpc.1.CUX9000004.0.LOWBAT
            Hab die Datenpunkte gefunden. Indicator.lowbat heißen die.
            Soll / muss ich die entfernen?
              @deifel Erweitere mal den $Selector:
              $('channel[state.id=hm-rpc.0*0.LOWBAT]').each(function(id, i) {
                Damit bekomme ich die CUXD-Geräte nicht mehr angezeigt, nur die "korrekten" Geräte.
                  @deifel Dann übernehme die Erweiterung in das Lowbat-Skript.
                    Ich danke Dir! Wenn ich das so übernehme, dann fehlen mir leider die Geräte aus der HM-IP-Instanz 😕
                      Kannst Du mir sagen, wie ich die Geräte aus meiner HM-IP-Instanz (rpc.2) noch dazu bekomme?
                      Diese werden nicht gefunden. Die Datenpunkte LOWBAT sind aber vorhanden.
                      Vielen DANK!
                        @deifel sagte:
                        CUXD-Geräte, obwohl diese nicht im Gewerk "Batteriebetrieb" sind.
                        Dann erweitere den $Selector anstelle von "hm-rpc.0" um das Gewerk (Schreibweise groß/klein in der enum-ID beachten)
                        $('channel[state.id=*0.LOWBAT](functions=Batteriebetrieb)').each(function(id, i) {
                           log(i + ': ' + id);
                        Werden dann alle "richtigen" IDs geloggt ?
                        • dslraser
                          dslraser Forum Testing Most Active @deifel last edited by dslraser
                          @deifel sagte in Skript LOWBAT:
                          Bei mir heißen die HM-IP LOW_BAT und nicht LOWBAT.
                            Danke - das hab ich versucht. Eigenartigerweise wird damit nichts gefunden 😞
                            Ich verzweifle noch.
                            "Batteriebetrieb" ist korrekt geschrieben.
                            Die Datenpunkte unter den IP-Geräten heißen allerdings "LOW_BAT".
                            Mit dem Selektor :
                               log(i + ': ' + id);
                            bekomme ich kein Ergebnis (0 Geräte).
                            Mit dem Selektor:
                            bekomme ich nur die von der normalen HM-Instanz.
                            und mit dem Selektor:
                            bekomme ich die normalen und die CuxD - aber auch keine HM-IP-Geräte
                              $('channel[state.id=hm-rpc.*0.LOW*](functions=Batteriebetrieb)').each(function(id, i) {
                                 if(i > 1) log(i + ': ' + id);
                              Gibt mir alle aus, also inkl. HMIP und auch den CUX-D-Geräten. Wenn ich jetzt noch die CUXD weg bekomme, dann wärs perfekt.
                                @deifel sagte:
                                   if(id.indexOf('CUX') == -1) log(i + ': ' + id);
                                  Leider nein, damit findet er nichts 😞
                                  dslraser paul53 2 Replies Last reply Reply Quote 0
                                  • dslraser
                                    @deifel
                                    Ich bin unterwegs und am Handy, deshalb bekomme ich das Script nicht kopiert, aber hier ein Screenshot vom Selektor, wie es bei mir funktioniert.
                                      @deifel sagte:
                                      Ohne functions ?
                                      $('channel[state.id=hm-rpc.*0.LOW*]').each(function(id, i) {
                                        Danke Euch Beiden! Es klappt jetzt mit beiden Varianten. Wobei evtl. das von dslraser sicherer ist, da es nicht nur noch low* abfragt - keine Ahnung, was in Zukunft sonst noch "low" wird 😉
                                        Vielen Dank für die tatkräftige Unterstützung!!!
                                          Kleine Ergänzung: Bei der Lösung von dslraser werden die cux-Geräte gefunden und eine Warnung angezeigt...
                                          Ich lass es jetzt trotzdem so drin
                                            @deifel sagte:
                                            Es hätte mich auch sehr gewundert, wenn nicht.
                                            201
                                            40758
