    4. Adapter: iobroker.backitup (stable Release)
    • simatec
      simatec Developer Most Active @stoffel67 last edited by
      @stoffel67
      ja mach ein node Update.
      Node 10 ist aktuell die sinnvollste Version.
      https://forum.iobroker.net/post/266625
        stoffel67 @simatec last edited by stoffel67
        @simatec
        OHje... habe ein
        curl -sL https://deb.nodesource.com/setup_10.x |sudo -E bash
        dann
        sudo apt-get install -y nodejs
        dannach iobroker gestartet...
        jetzt hagelt es nur noch Fehler im LOG!
        host.raspiP
        2019-11-26 10:51:08.446
        error
        instance system.adapter.yahka.0 terminated with code 1 ()
        host.raspiP
        error
        Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
        host.raspiP
        error
        Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
        host.raspiP
        error
        Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/ed25519-hap/index.js:1:37)
        host.raspiP
        error
        Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:76:44)
        host.raspiP
        error
        Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
        host.raspiP
        2019-11-26 10:51:08.445
        error
        Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
        host.raspiP
        error
        Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
        host.raspiP
        error
        Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
        host.raspiP
        error
        Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
        host.raspiP
        error
        Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)
        host.raspiP
        error
        Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
        host.raspiP
        error
        Caught by controller[0]: NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
        host.raspiP
        error
        Caught by controller[0]: NODE_MODULE_VERSION 48. This version of Node.js requires
        host.raspiP
        error
        Caught by controller[0]: was compiled against a different Node.js version using
        host.raspiP
        error
        Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/ed25519-hap/build/Release/ed25519.node'
        host.raspiP
        error
        Caught by controller[0]: ^
        host.raspiP
        error
        Caught by controller[0]: throw e
        host.raspiP
        2019-11-26 10:51:08.442
        error
        Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:83
        kann ich/ muß ich hier auf eine ältere Version????
          Einstein67 last edited by Einstein67
          Erstmal Vielen Dank für die Version 1.30! Das History Backup/Restore funktioniert total SUPER!
          Ich hab ein kleines Problem mit den Passwörtern von Wiederhergestellten Adaptern/Instanzen.
          Zum Beispiel beim Adapter Sonoff wird das MQTT-Passwort zwar wiederhergestellt, allerdings falsch. Auch bei BackitUp passiert das selbe mit dem Passwort für den SMB-Mount.
          Mach ich da irgendwas falsch, oder ist dieses Verhalten (aus Sicherheitsgründen) sogar gewünscht?
            stoffel67 @Einstein67 last edited by stoffel67
            so hab jetzt auch beim YAHKA Adapter ein rebuild gemacht, scheint jetzt auch wieder zu laufen...
            allerdings macht der Backit-up Adapter nur noch ein "Standrad"(Minimal-backup)
            das ist bei mir ca. 2MB groß, vorher war ein full-backup 160MB groß
            wie bekomm ich wieder ein Full-Backup?
            Ich hätte schon gern alles gesichert?
            simatec M 2 Replies Last reply Reply Quote 0
            • simatec
              @stoffel67
              Full Backups werden nicht mehr unterstützt und werden auch nicht benötigt.
              Das Standard Backup beinhaltet alles, was man braucht
              S 1 Reply Last reply Reply Quote -1
                @simatec
                OK, dh. da ist alles drin was ich für die Widerherstellung meiner ioBroker-Inst. brauche?😮
                wieso die Größenunterschiede?
                • simatec
                  @stoffel67
                  Genau und falls du redis, Zigbee oder mysql nutzt, kannst du in backitup dafür die Extra Backups aktivieren
                    @simatec
                    nee die nutz ich aktuell nicht, aber ganz wichtig Javascript-Scripte und vor allem YAHKA ( sonst "tillt" meine bessere Hälfte)😀
                    • MathiasJ
                      MathiasJ @Henny112 last edited by
                      @Henny112
                      Ja kann man, ist aber so gewollt.
                        Henny112 @MathiasJ last edited by
                        @MathiasJ danke ich teste das mal.
                          Alexxx2005 last edited by
                          wie erkenne ich wie weit ein wiederherstellen ist.
                          hab mich mal per sftp aufgeschalten , Logo's
                          unter vis.0. sind hergestellt in der Konsole dreht
                          sich der runde kreis mal rot mal grün.
                          Grüße Alex
                          • simatec
                            simatec Developer Most Active @Alexxx2005 last edited by
                            @Alexxx2005
                            Welche Version von Backitup ist installiert und wie lange läuft die Wiederherstellung schon?
                              das neuste was es derzeit in der adapter umgebung im iobroker gibt (kann grad nicht schauen) es läuft seit heute ca.: 16 Uhr , waren 15 Vis Seiten und um die 30 Instanzen (Adapter mit Logo und weiteres VIS Zubehör.
                              Grüße Aex
                              • simatec
                                @Alexxx2005
                                Hast du Installer Fix vorher laufen lassen?
                                Falls nein starte mal auf Konsole
                                Sollte inzwischen fertig sein
                                  für ein Backup Newbie was is ein Installer Fix , wie kann ich es laufen lassen ?
                                  Nein habe es Zuvor nicht laufen lassen , ist das irgendwo dokumentiert wie man da vorgehen muss (richtige Reihenfolge) konnte da nichts finden, sorry
                                  Grüße Alex
                                    Homoran Global Moderator Administrators @Alexxx2005 last edited by Homoran
                                    @Alexxx2005 sagte in Adapter: iobroker.backitup (stable Release):
                                    Link steht bei @simatec im Footer
                                    der steht bei mir im Footer
                                    • opossum
                                      opossum last edited by
                                      Hallo @simatec ,
                                      habe das jetzt getestet. Leider keinen Erfolg. Hier meine Daten. Ich habe BackitUp so eingestellt, dass zu einer bestimmten Uhrzeit das Backup geschrieben wird. Über NAS/COPY habe ich eingestellt, dass das Backup noch nach /media/backup kopiert wird. Das klappt auch, nur wird die Backupdatei für das mysql-Backup noch nicht korrekt geschrieben.
                                      Hier der Screen für /opt/iobroker/backups:
                                      Hier ist der Zeitstempel für die Dateien einmal 27.11.2019 07:13:14 für das Minimalbackup, der Zeitstempel für das mysql-Backup ist der 27.11.2019 07:13:36
                                      Hier der Screen von /media/backup:
                                      Man sieht, dass die Dateien in /media/backup/ einen Zeitstempel vom 27.11.2019 07:13:24 besitzen.
                                      Aus meiner Sicht wird das mysql-Backup zu früh kopiert und damit dann in /media/backup unbrauchbar. Schaust Du Dir das bei Gelegenheit mal an. Hat keine Eile, da ich zur Zeit die Datenbank mit einem Script sichere.
                                      Läuft da bei mir vielleicht etwas auf dem NUC verkehrt? Rechte von /media/backup stehen auf 777.
                                      • simatec
                                        simatec Developer Most Active @opossum last edited by simatec
                                        @opossum
                                        Zeige mal bitte deine Einstellungen von NAS/Copy.
                                        Haste du den Installer Fix mal drüberlaufen lassen?
                                        Stelle die Instanz auch mal bitte auf debug und poste mal den log der Backuperstellung bitte hier.
                                        Ich schaue mir das auch gleich noch einmal an ...
                                        • opossum
                                          Hallo, @simatec ,
                                          sorry, hatte gerade ein wenig Stress (Homeoffice). Hier die Einstellungen:
                                          … und hier das Log:
                                          2019-11-27 13:55:11.529 - debug: backitup.0 (13617) [minimal/minimal] host.iobrokerprod 10144 states saved
                                          2019-11-27 13:55:11.551 - debug: backitup.0 (13617) [minimal/minimal] host.iobrokerprod 13101 objects saved
                                          2019-11-27 13:55:12.942 - info: daswetter.0 (16531) Terminated (NO_ERROR): Without reason
                                          2019-11-27 13:55:13.506 - info: host.iobrokerprod instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                                          2019-11-27 13:55:15.153 - debug: backitup.0 (13617) [minimal/minimal] Backup created: /opt/iobroker/backups/minimal_2019_11_27-13_55_10_standard_backupiobroker.tar.gz
                                          2019-11-27 13:55:16.161 - debug: backitup.0 (13617) [minimal/minimal] done
                                          2019-11-27 13:55:25.390 - debug: backitup.0 (13617) [minimal/mysql] done
                                          2019-11-27 13:55:25.398 - debug: backitup.0 (13617) [minimal/cifs] Copy minimal_2019_11_27-13_55_10_standard_backupiobroker.tar.gz...
                                          2019-11-27 13:55:25.571 - debug: backitup.0 (13617) [minimal/cifs] Copy mysql_2019_11_27-13_55_16_backupiobroker.tar.gz...
                                          2019-11-27 13:55:25.587 - debug: backitup.0 (13617) [minimal/cifs] done
                                          2019-11-27 13:55:25.589 - debug: backitup.0 (13617) [minimal/clean] delete /opt/iobroker/backups/minimal_2019_11_25-23_41_17_standard_backupiobroker.tar.gz
                                          2019-11-27 13:55:25.591 - debug: backitup.0 (13617) [minimal/clean] done
                                          2019-11-27 13:55:25.641 - debug: backitup.0 (13617) [minimal/history] backitup.0.history.html
                                          2019-11-27 13:55:25.642 - debug: backitup.0 (13617) [minimal] exec: done
                                          2019-11-27 13:55:35.391 - debug: backitup.0 (13617) [minimal/mysql] Packed 51MB so far...
                                          2019-11-27 13:55:36.489 - debug: backitup.0 (13617) [minimal/mysql] done
                                          2019-11-27 13:55:36.491 - debug: backitup.0 (13617) [minimal] exec: done
                                          2019-11-27 13:55:36.524 - debug: backitup.0 (13617) [minimal/mysql] MySql File deleted!
                                          … und die Screens aus /iobroker/backups:
                                          … und aus media/backup:
                                          • Diginix
                                            Diginix last edited by Diginix
                                            @simatec
                                            Könnte man das History Backup seltener als das tägliche Minimal einplanen?
                                            Mein minimal ist nur 4 MB groß, der gepackte history Ordner hat 80 MB. Das würde ich aber ungern täglich in die Dropbox schaufeln wollen.
                                            adapter backitup backup iobroker backup iobroker.backitup
                                            185
                                            2335
                                            1111292
