    3. Entwicklung
    4. [Adapter] Doorbird - Ideensammlung
      hegse last edited by hegse
      Nabend. Bekomme den Adapter über den Admin Bereich nicht installiert.
      Mir fehlen scheinbar die Schreibrechte auf meinem Pi. Kann mir da jemand auf die Sprünge helfen? Besten Dank im voraus!
      $ ./iobroker url "https://github.com/BuZZy1337/ioBroker.doorbird.git"
      install https://github.com/BuZZy1337/ioBroker.doorbird/tarball/master
      npm install https://github.com/BuZZy1337/ioBroker.doorbird/tarball/master --production --save --prefix "/opt/iobroker" (System call)
      npm
       WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.doorbird
      npm
       WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
      npm
       ERR! path /opt/iobroker/node_modules/iobroker.doorbirdnpm ERR! code EACCES
      npm ERR! errno -13npm ERR! syscall access
      npm
       ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.doorbird'npm ERR!  { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.doorbird']
      npm ERR!   stack:
      npm ERR!    'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/iobroker.doorbird\'',
      npm ERR!
         errno: -13,npm ERR!   code: 'EACCES',
      npm ERR!   syscall: 'access',
      npm ERR!   path: '/opt/iobroker/node_modules/iobroker.doorbird' }
      npm ERR! npm ERR! The operation was rejected by your operating system.
      npm ERR! It is likely you do not have the permissions to access this file as the current user
      npm
      ERR! npm ERR! If you believe this might be a permissions issue, please double-check the
      npm ERR! permissions of the file and its containing directories, or try running
      npm ERR! the command again as root/Administrator (though this is not recommended).
      npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-11-21T19_36_21_545Z-debug.log
      ERROR: host.raspberrypi Cannot install https://github.com/BuZZy1337/ioBroker.doorbird/tarball/master: 243
      ERROR: process exited with code 25
      Edit: hat sich erledigt!
      • Z
        zahnheinrich @sourex last edited by zahnheinrich
        @sourex
        den lifechat bekommst du nicht in Vis direkt eingebunden.
        Ich habe den fully Browser installiert.
        Ein blockly schaltet mit fully commands die Anzeige nach dem Klingeln von Vis um auf die DoorBird App und wieder zurück.
        Findest du alles im Forum.
        • Negalein
          Negalein Global Moderator @zahnheinrich last edited by
          @zahnheinrich sagte in [Adapter] Doorbird - Ideensammlung:
          Würdest du das Blockly zur Verfügung stellen?
          Ich finde nur eine Lösung mit Tasker. Dazu muss das Tablett aber leider gerootet sein.
          • Z
            zahnheinrich @Negalein last edited by
            @Negalein
            Bitteschön:
              <variables>
                <variable type="undefined" id="timeout3">timeout3</variable>
                <variable type="undefined" id="timeout">timeout</variable>
              </variables>
              <block type="create" id="}pLCv[ASDixk]bWPW$j)" collapsed="true" disabled="true" x="88" y="-737">
                <field name="NAME">javascript.0.Variablen.DoorBird.doorbird</field>
                  <block type="logic_boolean" id="2OEtlFZMXvkO(%~rGi9N">
                  <block type="comment" id="``,yrzV@53[XfjaMXpqE">
                    <field name="COMMENT">button de auf die doorbird app wechselt</field>
                      <block type="comment" id="G-S$}/CW]ps(^=EX;tM0">
                        <field name="COMMENT">oder wenn jemand klingelt</field>
                          <block type="on_ext" id="~InNTIlI;tkEFM`2B.B5">
                            <value name="OID0">
                              <shadow type="field_oid" id="Px`^x@jK]Hqs2WMO,-a#">
                                <field name="oid">javascript.0.Variablen.DoorBird.doorbird</field>
                            <value name="OID1">
                              <shadow type="field_oid" id="?@5#x8KkT={%l4tFH/O@">
                                <field name="oid">doorbird.0.Doorbell.1.trigger</field>
                              <block type="debug" id="[NfvqhwbpQDIZK26Q#zN">
                                <value name="TEXT">
                                  <shadow type="text" id="YWkLl4i1PB5Xfk8M2zdi">
                                    <field name="TEXT">--- starte DoorBird App</field>
                                  <block type="procedures_callnoreturn" id="8E|!|GDRe@nu++8Q@N;T">
                                    <mutation name="doorbird"></mutation>
                              <block type="comment" id="g.E}ZOW:r$NV:E?i+%%j">
                                <field name="COMMENT">wenn sich was bewegt</field>
                                  <block type="on_ext" id="GyUJR:1lFaz0WXO]s|)N">
                                    <value name="OID0">
                                      <shadow type="field_oid" id="/zB.k5@)Q^oA2qDlRUgP">
                                        <field name="oid">doorbird.0.Motion.trigger</field>
                                      <block type="controls_if" id="~Awn^=wwX9}9BzX[x_Jw">
                                          <block type="logic_compare" id="bw-tsB`7p]mSBv75aB_-">
                                            <field name="OP">EQ</field>
                                              <block type="get_value" id="gJ;}tEG%hNR3_0a!T9Cw">
                                                <field name="OID">doorbird.0.Motion.trigger</field>
                                              <block type="logic_boolean" id="b_JL6;?fTuB,1hg=*xQU">
                                          <block type="procedures_callnoreturn" id="9cQ}sI2ZXib!bC!QV3aP">
                                      <block type="comment" id="GVv5P.W$@Gj+h$j|iYU!">
                                        <field name="COMMENT">bildschirm ein wenn jemand nach hause kommt, bzw aus wenn alle das hausverlassen</field>
                                          <block type="on_ext" id="^pRvz(J`83-LLKv;3m|i">
                                            <value name="OID0">
                                              <shadow type="field_oid" id="^@9+`,`E@m(LI86?f!kk">
                                                <field name="oid">hm-rega.0.50493</field>
                                              <block type="timeouts_settimeout" id="b57HF3OP7d#MuWSIGpe7">
                                                <field name="DELAY">2000</field>
                                                <field name="UNIT">ms</field>
                                                  <block type="controls_if" id="7_xJm`dMS4GX]mGv^V?|">
                                                      <block type="logic_operation" id="IMTf?8wLlWrVwt5*3apR" inline="false">
                                                        <field name="OP">AND</field>
                                                          <block type="time_compare" id="kvVCD!+)^|GkG`QvYUFj">
                                                            <mutation end_time="true"></mutation>
                                                            <field name="START_TIME">05:59</field>
                                                            <field name="END_TIME">22:21</field>
                                                          <block type="on_source" id=".?(+mq?](hxSFC=s:OWk">
                                                      <block type="procedures_callnoreturn" id="isG=_?2Pb51=IZQP2|+M">
                                                        <mutation name="display_on"></mutation>
                                                    <statement name="ELSE">
                                                      <block type="procedures_callnoreturn" id="N.}yeNQN_6O]oL:~bO{p">
                                                        <mutation name="display_off"></mutation>
              <block type="procedures_defnoreturn" id="53TwS?4NX*0d+)HU;m8U" x="987" y="-688">
                <field name="NAME">display_off</field>
                <statement name="STACK">
                  <block type="comment" id="j4LA3Dj|;#aHamjBX2YU">
                    <field name="COMMENT">befehle display aus</field>
                      <block type="control" id="x`Mjs-BBLS-IO8QfVYTN">
                        <field name="OID">fullybrowser.0.192_168_3_25.Commands.screenOff</field>
                          <block type="logic_boolean" id="BZ.Q,wNc$WU3pKMN0h8t">
                          <block type="control" id="6vDz7T69xfkbNcJ5%BN=">
                            <field name="OID">fullybrowser.0.192_168_3_26.Commands.screenOff</field>
                              <block type="logic_boolean" id="K3rY3#|Q^%Fl2rUY3LhS">
              <block type="procedures_defnoreturn" id="ug{F{JHlC$QPsy[4i[(R" x="987" y="-412">
                <field name="NAME">display_on</field>
                  <block type="comment" id="y:%!nG}zIBk*Q;PfLmWS">
                    <field name="COMMENT">befehle display an</field>
                      <block type="control" id="w0~cmx8PYYmPD.p9gFzr">
                        <field name="OID">fullybrowser.0.192_168_3_25.Commands.screenOn</field>
                          <block type="logic_boolean" id="h:__*3gtl99;{jO4hP]v">
                          <block type="control" id="iVK@;mS}M:?gGWJg8j}n">
                            <field name="OID">fullybrowser.0.192_168_3_26.Commands.screenOn</field>
                              <block type="logic_boolean" id="+CJ=U#C1Ne#lB-G2hvUF">
              <block type="procedures_defnoreturn" id="2z6oiB]zf#Cscz}h}6TO" x="988" y="-212">
                <field name="NAME">doorbird</field>
                  <block type="controls_if" id="V5vFcpL*;2,ek2*h[n/=">
                      <block type="logic_compare" id="z*ZSpV@L-}#m[#.+LNLm">
                          <block type="get_value" id="oe@7]K{cC3#h*XS-#szm">
                            <field name="OID">hm-rega.0.20907</field>
                          <block type="math_number" id="tz?3+.rm5mWnSc+Mdc_A">
                            <field name="NUM">1</field>
                      <block type="comment" id="^I?~uXiTJc$HM#8$jbVj">
                        <field name="COMMENT">befehle bei doorbird</field>
                          <block type="procedures_callnoreturn" id="6ffN~gBjuJBW5{Ij5z)a">
                              <block type="control" id="th#JRU]VY3BT|NP[:+_z">
                                <field name="OID">fullybrowser.0.192_168_3_25.Commands.startApplication</field>
                                  <block type="text" id="A*CS6?hf,{f{!moE1!.(">
                                    <field name="TEXT">com.doorbird.doorbird</field>
                                  <block type="control" id="|y#HD18FmV;,W2da4bXH">
                                    <field name="OID">fullybrowser.0.192_168_3_26.Commands.startApplication</field>
                                      <block type="text" id="F!pz#P}CseVsPo5BRV^[">
                                      <block type="timeouts_settimeout" id="ONkd*5UreD(R.SB1DW^#">
                                        <field name="NAME">timeout3</field>
                                        <field name="DELAY">60</field>
                                          <block type="control" id="S#){dd3:lDra9FSEO9Q@">
                                              <block type="text" id="i~nP.#BCP1pTeLY}o[`p">
                                                <field name="TEXT">de.ozerov.fully</field>
                                              <block type="control" id="67~2[6+FcbF8yT;.rH|j">
                                                  <block type="text" id="3,cI$!{iRye3=.Rzl}-/">
            Nicht wundern, daß die fully commands scheinbar doppelt vorhanden sind. Ich steuere zwei tablets damit (mit entsprechend unterschiedlichen commands).
            Und: Das script stammt nicht von mir, sondern ist aus diesem super hervorragenden Forum, nur auf meine Bedürfnisse angepasst.
            • Jan Geurts
              Jan Geurts last edited by
              Hello,
              I'm from Belgium, my German isn't good (at all) so excuse me for replying in English. I have the same issue as someone above...
              Doorbird-instance is created, user settings and the app are correct, everything shows up except for the RING folder
              What am I doing wrong? 🙂
              Thanks in advance!
              Kind regards,
              Jan
              • Z
                zahnheinrich @Jan Geurts last edited by
                @Jan-Geurts
                I think it's not a problem of iobroker but a problem of a missing http command for ring inside your doorbird settings.
                Jan Geurts 2 Replies Last reply Reply Quote 0
                • Jan Geurts
                  Jan Geurts @zahnheinrich last edited by
                  @zahnheinrich
                  I've tried lots of things. Reinstalling the Doorbird-adapter, recreating the instance, reloading the instance, restarting ioBroker. Even when the instance is recreated, it creates the doorbird.0 with the same objects as before: Motion, Relays and info.
                  I've tried - as suggested by someone else in this thread - to delete the HTTP(S) calls in the DoorBird administration section and then re-adding the doorbird, nothing changes. So it keeps showing everything except the ring folder (with trigger and snapshot).
                  I've tried manually creating a HTTP-call for the ring that points to the object in ioBroker, but that doesn't magically make it show up there...
                  I'm quite stuck 😲
                  • Jan Geurts
                    @zahnheinrich
                    I have tried the same on a Windows-install of ioBroker and now I noticed what happens in the logs when adding a Doorbird-instance:
                    host.WKS80SERVER(WKS80)	2019-11-26 13:09:16.621	info	iobroker exit 0
                    host.WKS80SERVER(WKS80)	2019-11-26 13:09:15.617	info	iobroker host.WKS80SERVER(WKS80) object system.adapter.doorbird.0 created
                    host.WKS80SERVER(WKS80)	2019-11-26 13:09:15.587	info	iobroker host.WKS80SERVER(WKS80) object system.adapter.doorbird.0.alive created
                    host.WKS80SERVER(WKS80)	2019-11-26 13:09:15.562	info	iobroker host.WKS80SERVER(WKS80) object system.adapter.doorbird.0.connected created
                    host.WKS80SERVER(WKS80)	2019-11-26 13:09:15.535	info	iobroker host.WKS80SERVER(WKS80) object system.adapter.doorbird.0.compactMode created
                    host.WKS80SERVER(WKS80)	2019-11-26 13:09:15.508	info	iobroker host.WKS80SERVER(WKS80) object system.adapter.doorbird.0.cpu created
                    host.WKS80SERVER(WKS80)	2019-11-26 13:09:15.481	info	iobroker host.WKS80SERVER(WKS80) object system.adapter.doorbird.0.cputime created
                    host.WKS80SERVER(WKS80)	2019-11-26 13:09:15.454	info	iobroker host.WKS80SERVER(WKS80) object system.adapter.doorbird.0.memHeapUsed created
                    host.WKS80SERVER(WKS80)	2019-11-26 13:09:15.428	info	iobroker host.WKS80SERVER(WKS80) object system.adapter.doorbird.0.memHeapTotal created
                    host.WKS80SERVER(WKS80)	2019-11-26 13:09:15.401	info	iobroker host.WKS80SERVER(WKS80) object system.adapter.doorbird.0.memRss created
                    host.WKS80SERVER(WKS80)	2019-11-26 13:09:15.375	info	iobroker host.WKS80SERVER(WKS80) object system.adapter.doorbird.0.uptime created
                    host.WKS80SERVER(WKS80)	2019-11-26 13:09:15.347	info	iobroker host.WKS80SERVER(WKS80) object system.adapter.doorbird.0.inputCount created
                    host.WKS80SERVER(WKS80)	2019-11-26 13:09:15.322	info	iobroker host.WKS80SERVER(WKS80) object system.adapter.doorbird.0.outputCount created
                    host.WKS80SERVER(WKS80)	2019-11-26 13:09:15.295	info	iobroker host.WKS80SERVER(WKS80) object system.adapter.doorbird.0.eventLoopLag created
                    host.WKS80SERVER(WKS80)	2019-11-26 13:09:15.268	info	iobroker host.WKS80SERVER(WKS80) object system.adapter.doorbird.0.sigKill created
                    host.WKS80SERVER(WKS80)	2019-11-26 13:09:15.242	info	iobroker host.WKS80SERVER(WKS80) object doorbird.0.Restart created
                    host.WKS80SERVER(WKS80)	2019-11-26 13:09:15.215	info	iobroker host.WKS80SERVER(WKS80) object doorbird.0.Motion.trigger created
                    host.WKS80SERVER(WKS80)	2019-11-26 13:09:15.190	info	iobroker host.WKS80SERVER(WKS80) object doorbird.0.Motion.snapshot created
                    host.WKS80SERVER(WKS80)	2019-11-26 13:09:15.163	info	iobroker host.WKS80SERVER(WKS80) object doorbird.0.info created
                    host.WKS80SERVER(WKS80)	2019-11-26 13:09:15.135	info	iobroker host.WKS80SERVER(WKS80) object doorbird.0.info.connection created
                    host.WKS80SERVER(WKS80)	2019-11-26 13:09:15.109	info	iobroker host.WKS80SERVER(WKS80) object doorbird.0.info.firmware created
                    host.WKS80SERVER(WKS80)	2019-11-26 13:09:15.083	info	iobroker host.WKS80SERVER(WKS80) object doorbird.0.info.build created
                    host.WKS80SERVER(WKS80)	2019-11-26 13:09:15.055	info	iobroker host.WKS80SERVER(WKS80) object doorbird.0.info.type created
                    host.WKS80SERVER(WKS80)	2019-11-26 13:09:15.053	info	iobroker host.WKS80SERVER(WKS80) create instance doorbird
                    host.WKS80SERVER(WKS80)	2019-11-26 13:09:14.059	info	iobroker add doorbird --host WKS80SERVER(WKS80)
                    There is no ring object created when creating the instance, however, the app has the 'doorbell' function enabled. HTTP(S) calls are empty right now... Can I add the HTTP(S)-calls manually?
                    Thanks in advance!
                    Kind regards,
                    Jan
                    • Jan Geurts
                      Solved! Manually logging in over http (using the API-commands provided in the Doorbird API manual) created the necessary HTTP(S) calls for the iobroker.doorbird-adapter to pick up. Thanks for pointing me partly in the right direction! 😉
                      • Z
                        @Jan-Geurts
                        You are welcome any time 😊
                        • Jey Cee
                          Da der Adapter schon lange im Stable ist schließe ich dieses Thema.
                          Für Fragen zum Adapter und dessen Benutzung eröffnet bitte ein Thema in der Unterkategorie ioBroker Allgemein. Wenn ihr Fehler im Adapter findet eröffnet bitte in der Unterkategorie Error/Bug ein Thema.
                          • Negalein
                            Negalein Global Moderator @BuZZy last edited by Negalein
                            irrtümlich gepostet
                            143
                            32783
