    4. [gelöst] Vis startet nicht mehr 1.2.2
    SOLVED [gelöst] Vis startet nicht mehr 1.2.2
      Lacoste9 last edited by Lacoste9
      pi@raspberrypi:~ $ iobroker list instances
      + system.adapter.admin.0                 : admin                 -  enabled, por              t: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.daswetter.0             : daswetter             - disabled
      + system.adapter.denon.0                 : HEOS Sub              -  enabled
      + system.adapter.discovery.0             : discovery             -  enabled
        system.adapter.dwd.0                   : dwd                   -  enabled
      + system.adapter.email.0                 : email                 -  enabled
        system.adapter.flot.0                  : flot                  -  enabled
      + system.adapter.history.0               : history               -  enabled
      + system.adapter.homeconnect.0           : homeconnect           -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png -  e              nabled
        system.adapter.icons-icons8.0          : icons-icons8          -  enabled
        system.adapter.icons-material-png.0    : icons-material-png    -  enabled
        system.adapter.icons-material-svg.0    : icons-material-svg    -  enabled
        system.adapter.icons-mfd-png.0         : icons-mfd-png         -  enabled
        system.adapter.icons-mfd-svg.0         : icons-mfd-svg         -  enabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png -  e              nabled
      + system.adapter.info.0                  : info                  -  enabled
      + system.adapter.iqontrol.0              : iqontrol              -  enabled
      + system.adapter.javascript.0            : javascript            -  enabled
        system.adapter.material.0              : material              -  enabled
        system.adapter.mobile.0                : mobile                - disabled
      + system.adapter.ping.0                  : ping                  -  enabled
        system.adapter.pushsafer.0             : pushsafer             - disabled
      + system.adapter.radar2.0                : radar2                -  enabled
        system.adapter.rickshaw.0              : rickshaw              -  enabled
      + system.adapter.samsung.0               : samsung               -  enabled
      + system.adapter.shelly.0                : shelly                -  enabled, por              t: 1882, bind: 0.0.0.0
        system.adapter.synology.0              : synology              - disabled, por              t: 5000
      + system.adapter.tankerkoenig.0          : tankerkoenig          -  enabled
        system.adapter.tr-064.0                : tr-064                - disabled
        system.adapter.tr-064.1                : tr-064                - disabled
        system.adapter.tr-064.2                : tr-064                - disabled
      + system.adapter.upnp.0                  : upnp                  -  enabled
        system.adapter.vis-bars.0              : vis-bars              -  enabled
        system.adapter.vis-canvas-gauges.0     : vis-canvas-gauges     -  enabled
        system.adapter.vis-colorpicker.0       : vis-colorpicker       -  enabled
        system.adapter.vis-fancyswitch.0       : vis-fancyswitch       -  enabled
        system.adapter.vis-google-fonts.0      : vis-google-fonts      -  enabled
        system.adapter.vis-history.0           : vis-history           -  enabled
        system.adapter.vis-hqwidgets.0         : vis-hqwidgets         -  enabled
        system.adapter.vis-jqui-mfd.0          : vis-jqui-mfd          -  enabled
        system.adapter.vis-justgage.0          : vis-justgage          -  enabled
        system.adapter.vis-keyboard.0          : vis-keyboard          -  enabled
        system.adapter.vis-lcars.0             : vis-lcars             -  enabled
        system.adapter.vis-map.0               : vis-map               -  enabled
        system.adapter.vis-metro.0             : vis-metro             -  enabled
        system.adapter.vis-players.0           : vis-players           -  enabled
        system.adapter.vis-plumb.0             : vis-plumb             -  enabled
        system.adapter.vis-rgraph.0            : vis-rgraph            -  enabled
        system.adapter.vis-timeandweather.0    : vis-timeandweather    -  enabled
        system.adapter.vis-weather.0           : vis-weather           -  enabled
        system.adapter.vis.0                   : vis                   -  enabled
      + system.adapter.web.0                   : web                   -  enabled, por              t: 8082, bind: 0.0.0.0, run as: admin
      node: v10.17.0
      nodejs: v10.17.0
      npm: 6.11.3
        sigi234 Forum Testing Most Active @Lacoste9 last edited by sigi234
        @Lacoste9
        Was kommt bei F12
        Anderen Browser schon mal getestet?
        Hast du ein Addon im Browser laufen? Popup Blocker?
        Browser Cache mal komplett geleert?
          ich habe nix geändert.
          browser ist firefox aktuell
          chrome probiert das gleiche problem
            Homoran Global Moderator Administrators @Lacoste9 last edited by Homoran
            @Lacoste9 sagte in Vis startet nicht mehr 1.2.2:
            F5 bringt nix.
            du solltest ja auch STRG-F5 machen
            läuftnicht
            stimmt denn die ausgelöschte IP?
            Hat ioBroker vielleicht eine andere IP bekommen?
            • Glasfaser
              Glasfaser @Lacoste9 last edited by
              @Lacoste9
              Zeige mal die Ausgabe bei F12 wie schon sigi234 gefragt hat , wenn du die leere Seite hast .
                Die Ip stimmt alles.
                STRG F5 bringt auch nix. Wo ist denn der unterschied zwischen F5 und STRG F5.
                F12 sehe ich .......so viel. was braucht ihr da?
                  Den Reiter Console als screenshot
                    F5 lädt neu; STRG-F5 löscht vorher den Seitencache
                      Ah ok. gut zu wissen mit STRG F5
                      Homoran Glasfaser 2 Replies Last reply Reply Quote 0
                        @Lacoste9
                        gibt es den angemeckerten View noch?
                        da ist ein / drin, nicht dass der stört
                        • Glasfaser
                          @Lacoste9
                          Hier mal als Bild :
                            Den habe ich neu angelegt und bin dann weg vom PC.
                            Auf dem view ist noch nix drauf. Der kann gelöscht werden.
                            Aber keine Ahnung wie....
                            Röstkartoffel Glasfaser 2 Replies Last reply Reply Quote 0
                            • Röstkartoffel
                              Röstkartoffel @Lacoste9 last edited by Röstkartoffel
                              @Lacoste9
                              ich habe bei deinen Instanzen das gesehen:
                              Sollte unter "bind:" nicht die IP deines ioBrokers stehen?
                              meine WEB-Adapter Einstellung:
                              damit sieht es so aus:
                              + system.adapter.web.0                   : web         -  enabled, port: 8082, bind: 192.168.178.248, run as: admin
                              • Glasfaser
                                Glasfaser @Lacoste9 last edited by Glasfaser
                                @Lacoste9
                                Hier die Lösung wegen dem / im Viewname
                                @Röstkartoffel
                                funktioniert auch mit 0.0.0.0
                                Röstkartoffel L 2 Replies Last reply Reply Quote 0
                                • Röstkartoffel
                                  Röstkartoffel @Glasfaser last edited by
                                  @Glasfaser
                                  ok, danke, wieder was gelernt. 😎
                                    Lacoste9 @Glasfaser last edited by Negalein
                                    @Glasfaser
                                    aus dem anderen thread....
                                    /opt/iobroker/iobroker-data/files/vis.0/main/vis-views.json
                                    wie komme ich denn in dem ordner um die zu bearbeiten?
                                    die ist doch auf dem pi drauf oder?
                                    • Glasfaser
                                      @Glasfaser
                                      per FileZilla oder WinSCP
                                      Richtig
                                        Hallo
                                        Habe endlich Zeit gehabt es zu testen.
                                        Filezilla hat geklappt.
                                        Und das bearbeiten der .jason auch.
                                        Ich kam zwar wieder rauf aber die view war immer noch da. Konnte ihn aber nicht mehr anklicken.
                                        Habe dann alles gespeichert meine ganzen widgets also exportiert und dann habe ich das ganzen Projekt gelöscht und neu angefangen.
                                        Hat erstmal gemeckert da keine .jason vorhanden war.
                                        "erstellen?"
                                        Ja und alles war wieder gut.
                                        Denke mal die unterstriche haben Probleme gemacht?
                                        War ja noch nicht ganz so viel.
                                        Widget importiert und bissle klein Krams.
                                        Danke für die Hilfe👌👍
                                        vis editor visualisierung visualization
                                        2275
