    4. Adapter: iobroker.backitup (stable Release)
    • opossum
      opossum last edited by
      Hallo, @simatec ,
      sorry, hatte gerade ein wenig Stress (Homeoffice). Hier die Einstellungen:
      … und hier das Log:
      2019-11-27 13:55:11.529 - debug: backitup.0 (13617) [minimal/minimal] host.iobrokerprod 10144 states saved
      2019-11-27 13:55:11.551 - debug: backitup.0 (13617) [minimal/minimal] host.iobrokerprod 13101 objects saved
      2019-11-27 13:55:12.942 - info: daswetter.0 (16531) Terminated (NO_ERROR): Without reason
      2019-11-27 13:55:13.506 - info: host.iobrokerprod instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2019-11-27 13:55:15.153 - debug: backitup.0 (13617) [minimal/minimal] Backup created: /opt/iobroker/backups/minimal_2019_11_27-13_55_10_standard_backupiobroker.tar.gz
      2019-11-27 13:55:16.161 - debug: backitup.0 (13617) [minimal/minimal] done
      2019-11-27 13:55:25.390 - debug: backitup.0 (13617) [minimal/mysql] done
      2019-11-27 13:55:25.398 - debug: backitup.0 (13617) [minimal/cifs] Copy minimal_2019_11_27-13_55_10_standard_backupiobroker.tar.gz...
      2019-11-27 13:55:25.571 - debug: backitup.0 (13617) [minimal/cifs] Copy mysql_2019_11_27-13_55_16_backupiobroker.tar.gz...
      2019-11-27 13:55:25.587 - debug: backitup.0 (13617) [minimal/cifs] done
      2019-11-27 13:55:25.589 - debug: backitup.0 (13617) [minimal/clean] delete /opt/iobroker/backups/minimal_2019_11_25-23_41_17_standard_backupiobroker.tar.gz
      2019-11-27 13:55:25.591 - debug: backitup.0 (13617) [minimal/clean] done
      2019-11-27 13:55:25.641 - debug: backitup.0 (13617) [minimal/history] backitup.0.history.html
      2019-11-27 13:55:25.642 - debug: backitup.0 (13617) [minimal] exec: done
      2019-11-27 13:55:35.391 - debug: backitup.0 (13617) [minimal/mysql] Packed 51MB so far...
      2019-11-27 13:55:36.489 - debug: backitup.0 (13617) [minimal/mysql] done
      2019-11-27 13:55:36.491 - debug: backitup.0 (13617) [minimal] exec: done
      2019-11-27 13:55:36.524 - debug: backitup.0 (13617) [minimal/mysql] MySql File deleted!
      … und die Screens aus /iobroker/backups:
      … und aus media/backup:
      • Diginix
        Diginix last edited by Diginix
        @simatec
        Könnte man das History Backup seltener als das tägliche Minimal einplanen?
        Mein minimal ist nur 4 MB groß, der gepackte history Ordner hat 80 MB. Das würde ich aber ungern täglich in die Dropbox schaufeln wollen.
        • JB_Sullivan
          JB_Sullivan last edited by
          Für den Fall, das ich es in diesem ultra langen Thread überlesen habe - warum hat man die Unterstützung für das Vollständige Backup unter 1.3.0 eingestellt - nur so rein Interesse halber.
            Homoran Global Moderator Administrators @JB_Sullivan last edited by
            @JB_Sullivan
            Weil es durch falsche Benutzung zu oft zu unnötigen Problemen gekommen ist.
            Außerdem ist es für iobroker nicht notwendig. Im Standardbackup ist alles notwendige drin.
            • MathiasJ
              MathiasJ last edited by
              @JB_Sullivan
              ich habe IObroker nicht nur einmal neu aufgesetzt, sei es als produktives oder als Testsystem.
              Ich habe zwar das total Backup gemacht, gebraucht habe ich es aber nie.
                Fabian1 last edited by Fabian1
                Hallo liebe Freunde des Backups 😂
                ich habe heute versucht auf meinem frisch installierten Raspberry Pi 4 mein Backup aus der Dropbox wiederherzustellen, leider ohne Erfolg.
                Gestartet...
                [ERROR] [minimal] host.raspberrypi-4b Cannot extract from file "/opt/iobroker/backups/minimal_2019_11_28-18_50_10_Standard_backupiobroker.tar.gz"
                [ERROR] [minimal] host.raspberrypi-4b Cannot find extracted file from file "/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backup.json"
                [DEBUG] [minimal] iobroker controller daemon is not running
                [DEBUG] [minimal] host.raspberrypi-4b OK.
                [ERROR] [minimal] (node:1050) UnhandledPromiseRejectionWarning: Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backup.json'
                [ERROR] [minimal] at Object.openSync (fs.js:443:3)
                [ERROR] [minimal] at Object.readFileSync (fs.js:343:35)
                [ERROR] [minimal] at BackupRestore.restoreAfterStop (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:566:23)
                [ERROR] [minimal] at Daemon.daemon.on (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:843:22)
                [ERROR] [minimal] at Daemon.emit (events.js:203:15)
                [ERROR] [minimal] at Daemon._kill (/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:246:14)
                [ERROR] [minimal] at Daemon.stop (/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:185:17)
                [ERROR] [minimal] at tar.extract.err (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:845:20)
                [ERROR] [minimal] at process._tickCallback (internal/process/next_tick.js:68:7)
                [ERROR] [minimal] (node:1050) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
                [ERROR] [minimal] (node:1050) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                [EXIT] 9
                [EXIT] 0
                Hat jemand eine Idee woran das liegen könnte. Komplett frischer Raspi mit nur Backitup Adapter installiert.
                Glasfaser simatec 2 Replies Last reply Reply Quote 0
                • Glasfaser
                  Glasfaser @Fabian1 last edited by
                  @Fabian1
                  Die Sicherungsdatei ist sehr winzig von 1.3 MB , da ist wohl nichts drin …
                  Lade Sie mal runter und schau mal rein was vorhanden ist !?
                  • simatec
                    simatec Developer Most Active @Fabian1 last edited by
                    @Fabian1
                    Es sieht so aus, als ob die Datei beschädigt ist.
                    Probiere sie mal mit 7zip zu öffnen.
                    Falls nicht, ziehe ein neues Backup und lege es am besten lokal für den Restore ab.
                    Somit umgehst du eventuelle Übertragungsfehler aus der Dropbox
                      Fabian1 @simatec last edited by
                      @simatec
                      ok das hat funktioniert! Vielen Dank! Haben die bei Dropbox vielleicht irgendwas geändert? Mir ist nämlich folgendes aufgefallen: Mache ich im Dropbox Ordner (online browser) einen Rechtsklick und wähle ziel speichern unter, ist die Datei nur 55kb groß und kann nicht entpackt werden. Genau diese 55kb Dateien habe ich auch in meinem Raspi Backup Ordner gefunden. Also scheint der backitup adapter die auch so runterzuladen. Geht man aber in Dropbox eine Ebene tiefer und wählt dann herunterladen, ist die Datei 1,3MB groß und funktioniert ohne Probleme.
                      • cash
                        Ich habe da jetzt auch mal eine Frage (sorry habe auch nicht alle Seiten gelesen).
                        Unter den Objekten gibt es einen Datenpunkt für das minimal-Backup.
                        In den Adaptereinstellungen gibt es einen Punkt Stanrdard-Backup dort kann ich auch ein Schedule einstellen .
                        Was ist der Unterschied zwischen ein normal Backup und ein Minimal Backup? Und was wird genau gesichert? In der Doku zu Github steht dazu leider auch nichts.
                        Ich habe mich bisher nie mit dem Thema Backup beschäftigt, da ich ioBroker auf ein Synology laufen lasse und das NAS wird regelmäßig automatisch gesichert. Dort aber eben einfach alles...
                          m4estr0 @stoffel67 last edited by
                          @stoffel67
                          wie hast du denn ein rebuild von yahka gemacht?
                          • simatec
                            simatec Developer Most Active @cash last edited by
                            @cash
                            Minimal = Standard.
                            Das Standard Backup entspricht exakt dem Backup vom Konsolenbefehl iobroker backup.
                            Es sichert alles was du brauchst, um dein System wiederherstellen zu können.
                            cash 1 Reply Last reply Reply Quote 0
                              Jan1 last edited by
                              Mir ist gerade aufgefallen, dass beim Wiederherstellen manuell in Node-Red installierte Nodes anscheinend nicht mit gesichert werden und diese dann nach einem restore fehlen.
                              Hab ich hier was falsch gemacht, oder kann das der Adapter (noch) nicht?
                              • simatec
                                simatec Developer Most Active @Jan1 last edited by
                                @Jan1 sagte in Adapter: iobroker.backitup (stable Release):
                                installierte
                                Da müssten wir mal mit dem Entwickler reden, ob diese mit im iobroker Backup enthalten sind.
                                backitup führt das Backup identisch zur Methode iobroker backup aus.
                                  Jan1 @simatec last edited by Jan1
                                  @simatec
                                  Wäre klasse, wenn Ihr das hin bekommt.
                                  Es ist zwar kein großer Aufwand das nach zu installieren und so oft kommt ein Restore auch nicht vor, aber wenn, vergisst man das gerne mal und gestern war dann bei Frauchen Panik angesagt, wenn man von Alexa nicht mehr verstanden wird und mittlerweile nicht mehr weiß wo welcher Schalter für welche Lampe im Haus zu finden ist😊
                                  Im konkreten Fall war es die "node-red-contrib-amazon-echo", die fehlte.
                                  • cash
                                    cash Most Active @simatec last edited by
                                    @simatec Danke für die schnelle Antwort. Noch zwei Verständnisfragen. Ich lege eigene Datenpunkte nicht unter javascript ab sondern in der obersten Ebene unter Systemvariablen.0. Werden die ebenfalls mitgesichert. Wie verhält sich das Backup bezüglich eines Restores auf unterschiedlichen Versionen? Ich habe noch eine alte Version vom js-Adapter und node.js ist auf 8.x
                                    Ich habe nun überlegt per Docker eine neue Installation zu machen und dort erstmal das System auf einen aktuellen Stand zu bringen und eben danach ein Restore. Sollte etwas schief gehen muss ich dann einfach nur den alten Container wieder starten und alles läuft wieder. Würde es Sinn machen bei der frischen Installation einzelne Adapter manuell zu installieren (ohne die Einstellungen nur Installieren) somit sollte der Restore anschließend deutlich schneller gehen weil nur noch die Adaptereinstellungen installiert werden müssen und eben die Datenpunkte.
                                    Sollte der Restore per Adapter erfolgen oder per Terminal?
                                    J simatec 2 Replies Last reply Reply Quote 0
                                      Jan1 @cash last edited by
                                      @cash
                                      Eigene DPs sollten (nicht muss) eigentlich hier generiert werden:
                                      und die werden definitiv gesichert und bei einem Restore wieder hergestellt, gerade gestern getestet 😊
                                      • cash
                                        cash Most Active @Jan1 last edited by
                                        @Jan1 das wurde erst mit dem js Adapter 2.0 eingeführt. Vorher nicht...
                                          @cash
                                          Richtig und da kann man jetzt eben schön seine DPs anlegen, oder vorhandene umziehen. Das ist genau der Grund warum es das gibt, damit nicht jeder irgendwo DPs erstellt. Ist kein Muss, aber sinnvoll es zu tun😉
                                            Homoran Global Moderator Administrators @Jan1 last edited by
                                            Der Grund ist, dass viele User ihre Datenpunkte in Adapterstrukturen oder noch schlimmer in Sytemverzeichnissen angelegt haben, weil sie es nicht auf die Reihe bekamen einen eigenen Baum anzulegen
                                            adapter backitup backup iobroker backup iobroker.backitup
                                            185
                                            2335
                                            1172545
