    4. Projekt WetterView von sigi234
      heli-wolf last edited by Negalein
      nachdem mein raspberry immer wieder abstürzt habe ich mir jetzt einmal das Log angesehen und dabei einen Fehler im UWZ Skript entdeckt.
      Nachdem ich keine Erfahrung mit Skripten habe, stelle ich die Fehlermeldung mal hier rein. Vielleicht kann mir da bitte jemand weiterhelfen.
      29.11.2019, 18:18:53.488	[info ]: javascript.0 Stop script script.js.common.uwz
      29.11.2019, 18:18:54.389	[info ]: javascript.0 script.js.common.uwz: compiling TypeScript source...
      29.11.2019, 18:18:54.389	[warn ]: javascript.0 script.js.common.uwz: TypeScript compilation had errors:
              AreaChannelId=ChannelId+"."+warncellid[j];
      ERROR: Cannot find name 'AreaChannelId'. Did you mean 'AreaChannelID'?
                  createState(AreaChannelId+".warning."+i+".ShortText","",forceInitStates,{type: 'string'});
                  createState(AreaChannelId+".warning."+i+".LongText","",forceInitStates,{type: 'string'});
                  createState(AreaChannelId+".warning."+i+".object","",forceInitStates,{type: 'string'});
                  createState(AreaChannelId+".warning."+i+".begin","",forceInitStates,{type: 'string'});
                  createState(AreaChannelId+".warning."+i+".end","",forceInitStates,{type: 'string'});
                  createState(AreaChannelId+".warning."+i+".severity",0,forceInitStates,{type: 'number'});
                  createState(AreaChannelId+".warning."+i+".type",0,forceInitStates,{min:0, max:11, type: 'number',states:UWZTypesArray});
      ERROR: No overload matches this call.
        The last overload gave the following error.
          Type 'boolean' has no properties in common with type 'Partial<StateCommon>'.
                  createState(AreaChannelId+".warning."+i+".uwzLevel",0,forceInitStates,{min:0, max:5, type: 'number'});
                  createState(AreaChannelId+".warning."+i+".uwzColor",0,forceInitStates,{type:'number'});
                  createState(AreaChannelId+".warning."+i+".HTMLShort","",forceInitStates,{type: 'string'});
                  createState(AreaChannelId+".warning."+i+".HTMLLong","",forceInitStates,{type: 'string'});
              for (i=0; i<thedata.results.length; i++) {
      ERROR: Cannot find name 'i'.
                  warnings.push(new processResultEntry(thedata.results[i]));
          dwmlog(JSON.stringify(warnings));
      ERROR: Expected 3 arguments, but got 1.
          for (i=0; i<numOfWarnings; i++) {
              if (i<warnings.length) {
                  setState(AreaChannelId+".warning."+i+".LongText",warnings[i].LongText);
                  setState(AreaChannelId+".warning."+i+".ShortText",warnings[i].ShortText);
                  setState(AreaChannelId+".warning."+i+".object",warnings[i].object);
                  setState(AreaChannelId+".warning."+i+".begin",warnings[i].begin);
                  setState(AreaChannelId+".warning."+i+".end",warnings[i].end);
                  setState(AreaChannelId+".warning."+i+".severity",warnings[i].severity);
                  setState(AreaChannelId+".warning."+i+".type",warnings[i].type);
                  setState(AreaChannelId+".warning."+i+".uwzLevel",warnings[i].uwzLevel);
                  setState(AreaChannelId+".warning."+i+".uwzColor",warnings[i].uwzColor);
                  setState(AreaChannelId+".warning."+i+".HTMLShort",warnings[i].HTMLShort);
                  setState(AreaChannelId+".warning."+i+".HTMLLong",warnings[i].HTMLLong);
                  setState(AreaChannelId+".warning."+i+".LongText","");
                  setState(AreaChannelId+".warning."+i+".ShortText","");
                  setState(AreaChannelId+".warning."+i+".object","{}");
                  setState(AreaChannelId+".warning."+i+".begin","");
                  setState(AreaChannelId+".warning."+i+".end","");
                  setState(AreaChannelId+".warning."+i+".severity",0);
                  setState(AreaChannelId+".warning."+i+".type",0);
                  setState(AreaChannelId+".warning."+i+".uwzLevel",0);
                  setState(AreaChannelId+".warning."+i+".uwzColor",0);
                  setState(AreaChannelId+".warning."+i+".HTMLShort","");
                  setState(AreaChannelId+".warning."+i+".HTMLLong","");
      var request = require('request');
      ERROR: Cannot redeclare block-scoped variable 'request'.
      ERROR: Cannot find name 'require'. Do you need to install type definitions for node? Try `npm i @types/node`.
                      dwmlog("AREA: "+getAreaFromURI(response.request.uri.href),4);
      ERROR: Expected 3 arguments, but got 2.
                      dwmlog("UWZ Body: " + body,4);
      29.11.2019, 18:18:54.390	[info ]: javascript.0 script.js.common.uwz: registered 0 subscriptions and 1 schedule
      Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
      Hier gehts zur Hilfe.
        sigi234 Forum Testing Most Active @heli-wolf last edited by sigi234
        @heli-wolf sagte in Projekt WetterView von sigi234:
        AreaChannelId
        Hast du die auch Richtig eingetragen?
        Und das:
          Bei mir schaut das folgendermaßen aus:
          Die zusätzlichen NPM Module habe ich nicht ??
          Wie komme ich zu diesen?
            reinschreiben, aber nur das Rot unterstrichene.
            request
              habe ich gemacht, muss ich jetzt den PI neu durchstarten oder reicht es den javascript Adapter neu zu starten.
              Wie merke ich ob das der Fehler war?
                Beides und im Log
                  das hat nichts geändert. Im Skript wird folgendes ausgegeben.
                  29.11.2019, 19:44:45.973	[info ]: javascript.0 Stop script script.js.common.uwz
                  29.11.2019, 19:44:50.276	[info ]: javascript.0 script.js.common.uwz: compiling TypeScript source...
                  29.11.2019, 19:44:50.277	[warn ]: javascript.0 script.js.common.uwz: TypeScript compilation had errors:
                  29.11.2019, 19:44:50.278	[info ]: javascript.0 script.js.common.uwz: registered 0 subscriptions and 1 schedule
                    Modul jetzt erfasst.
                      Ok, zeig mal dein Skript vom UWZ
                        Ok, sorry aber man lernt NIE aus !!
                        var debuglevel = 1;
                        var debugchannel = 'info';
                        function dwmlog( message, level, channel) {
                            if (typeof channel === 'undefined') {
                                channel = debugchannel;
                            if ( typeof level === 'undefined')
                                level = debuglevel;
                            if ( debuglevel >= level ) {
                                log (message, channel );
                        var AdapterId = "javascript."+instance;
                        var ChannelId = "UWZ";
                        var forceInitStates = false;
                        var numOfWarnings = 3;
                        var url='http://feed.alertspro.meteogroup.com/AlertsPro/AlertsProPollService.php?method=getWarning&language=de&areaID=XXXAREAXXX';
                        /********************* Hier die Warnzellen-Id's eintragen *****************************/
                        var warncellid = ['UWZAT01026'];
                        var UWZTypesArray=["n/a","unbekannt","Sturm/Orkan","Schneefall","Starkregen","Extremfrost","Waldbrandgefahr","Gewitter","Glätte","Hitze","Glatteisregen","Bodenfrost"];
                        function createStates(n){
                            var AreaChannelID = null;
                            for (var j=0; j<warncellid.length; j++) {
                                for (var i=0; i<n; i++) {
                        function getUWZLevel (warnName){
                            var result = -1; // -1 is an error!
                            var alert = warnName.split("_");
                            var colors = ["green","darkgreen","yellow","orange","red","violet"];
                            if (alert[0]=="notice") { result = 1; }
                            else if (alert[1] == "forewarn") { result = 2; }
                            else {
                                result = colors.indexOf(alert[2]);
                            return result;
                        function getUWZUrgency (warnName){
                            var result = 0;
                                result = 1;
                            else {
                                result = 2; // immediate;
                            return result;
                        function getLevelColor(uwzLevel) {
                            var uwzColor = [
                                0x00ff00, // 0 - Grün
                                0x009b00, // 1 - Dunkelgrün
                                0xffff00, // 2 - Gelb Wetterwarnungen (Stufe 1)
                                0xffb400, // 3 - Orange Warnungen vor markantem Wetter (Stufe 2)
                                0xff0000, // 4 - Rot Unwetterwarnungen (Stufe 3)
                                0xff00ff, // 5 - Violett Warnungen vor extremem Unwetter (Stufe 4)
                            if (uwzLevel>=0 && uwzLevel<=5)
                                return uwzColor[uwzLevel];
                            else
                                return 0;
                        function createHTMLShort(w){
                            var html = '<div style="background: #'+w.uwzColor.toString(16)+'" border:"10px">';
                            var theData = JSON.parse(w.object);
                            html += '<h3>';
                            if (w.uwzUrgency==1) html+="Vorwarnung vor "; else html+="Warnung vor ";
                            html += UWZTypesArray[w.type];
                            html +="</h3>";
                            html += "<p>Zeitraum von "+formatDate(new Date(theData.dtgStart*1000),"WW, DD. OO YYYY hh:mm")+" Uhr bis "+formatDate(new Date(theData.dtgEnd*1000),"WW, DD. OO YYYY hh:mm")+" Uhr </p>";
                            html += '<p>'+w.ShortText+'</p>';
                            html += "</div>";
                            return html;
                        function createHTMLLong(w){
                            html += '<h3>';
                            html +="</h3>";
                            html += '<p>'+w.LongText+'</p>';
                            html += "</div>";
                            return html;
                        function processResultEntry(w) {
                            this.object = JSON.stringify(w);
                            this.begin=formatDate(new Date(w.dtgStart*1000),"DD.MM.YYYY hh:mm");
                            this.end=formatDate(new Date(w.dtgEnd*1000),"DD.MM.YYYY hh:mm");
                            // dwmlog (formatDate(this.begin,"DD.MM.YYYY hh:mm"),4);
                            // dwmlog (formatDate(this.end,"DD.MM.YYYY hh:mm"),4);
                            this.LongText = w.payload.translationsLongText.DE;
                            this.ShortText = w.payload.translationsShortText.DE;
                            this.severity = w.severity;
                            this.type = w.type;
                            this.uwzLevel = getUWZLevel(w.payload.levelName);
                            this.uwzUrgency = getUWZUrgency(w.payload.levelName);
                            this.uwzColor = getLevelColor(this.uwzLevel);
                            var x = this;
                            this.HTMLShort = createHTMLShort(x);
                            this.HTMLLong  = createHTMLLong(x);
                        function processData(Area,data) {
                            if (!data) {
                               return;
                            var AreaChannelId=ChannelId+"."+Area;
                            var thedata = JSON.parse(data);
                            var warnings= [];
                            if (thedata.results.length>0) {
                            warnings.sort(function(a,b){
                                var asort = a.severity;
                                var bsort = b.severity;
                                return bsort-asort;
                                } else {
                        function getAreaFromURI(uri) {
                            var searchstr = "&areaID=";
                            var n = uri.search(searchstr);
                            var result = uri.slice(n+searchstr.length,uri.length);
                            return result;
                        createStates(numOfWarnings);
                        // processData(jsond2);
                        schedule ("3 * * * *", function(){
                            for (var i=0; i<warncellid.length; i++) {
                                    request({
                                        uri: url.replace("XXXAREAXXX",warncellid[i]),
                                        method: "GET",
                                        timeout: 10000,
                                        followRedirect: true,
                                        maxRedirects: 10
                                    }, function(error, response, body) {
                                        // dwmlog("UWZ Error" + error,2);
                                        // dwmlog("UWZ Response: " + JSON.stringify(response),4);
                                        if (response.statusCode == 200) {
                                            processData(getAreaFromURI(response.request.uri.href),body);
                          @heli-wolf
                          Getestet, bei mir geht es.
                          AHA!
                          Du hast es in common! Da gehört es nicht hin.
                          • Negalein
                            Negalein Global Moderator @sigi234 last edited by
                            @sigi234 sagte in Projekt WetterView von sigi234:
                            meins läuft auch Common. Das passt normal schon so.
                              sigi234 Forum Testing Most Active @Negalein last edited by
                              @Negalein sagte in Projekt WetterView von sigi234:
                              Ja, verwechselt mit Global
                                crunchip Forum Testing Most Active @heli-wolf last edited by
                                @heli-wolf du hast ein typeScript erstellt, anstatt ein JS-Script
                                  sigi234 Forum Testing Most Active @crunchip last edited by sigi234
                                  @crunchip sagte in Projekt WetterView von sigi234:
                                  Ja, gerade gesehen
                                    AHA, ich habe doch irgendwo gelesen, dass alle deine Skripte für dieses Projekt als TypeSkript erstellt wurden ???
                                    Deshalb habe ich dieses ausgewählt.
                                    Müssen alle anderen Skripte (Zeitplanung und Biowetter) auch in JS erstellt werden.
                                    Alle Skipte in JS und GLOBAL - Oder??
                                    Negalein sigi234 2 Replies Last reply Reply Quote 0
                                    • Negalein
                                      Negalein Global Moderator @heli-wolf last edited by
                                      GLOBAL
                                      Nein, in COMMON
                                        In JS und nicht in Global!
                                        Nur das POLLENSKRIPT ist ein TS Skript!
                                          OK, vielen Dank!
                                          das habe ich jetzt einmal alles umgestellt, Adapter und PI neu gestartet und jetzt werde ich das ganze ein bisschen beobachten und hoffe, dass es jetzt richtig läuft.
                                          Andernfalls ersuche ich euch nochmals um eure Hilfe.
                                          Danke vorerst einmal !!
                                            Das Pollenskript habe ich noch gar nicht implementiert, aber wo du es sagst.
                                            Ich habe ja 2 Skripte
                                            • pollen_css.txt
                                            • pollen_css_Ampeln.txt
                                            ich dachte dass ich die beiden in der Vis unter CSS einfügen muss?
                                            wetter wetterview sigi234
                                            60
                                            497
                                            134839
