    4. JavaScript
    5. [Vorlage] JS: Log-Datei aufbereiten für VIS
      base last edited by
      Hallo, bekomme nach Start des Scripts folgende Fehlermeldung:
      javascript.0	2019-11-13 15:56:54.939	error	(29884) at process._tickCallback (internal/process/next_tick.js:68:7)
      javascript.0	2019-11-13 15:56:54.939	error	(29884) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      javascript.0	2019-11-13 15:56:54.939	error	(29884) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      javascript.0	2019-11-13 15:56:54.939	error	(29884) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:491:17)
      javascript.0	2019-11-13 15:56:54.939	error	(29884) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:845:17)
      javascript.0	2019-11-13 15:56:54.938	error	(29884) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1254:17)
      javascript.0	2019-11-13 15:56:54.938	error	(29884) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1201:37)
      javascript.0	2019-11-13 15:56:54.938	error	(29884) at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:978:28)
      javascript.0	2019-11-13 15:56:54.938	error	(29884) at Object.createScript (vm.js:277:10)
      javascript.0	2019-11-13 15:56:54.938	error	(29884) at new Script (vm.js:83:7)
      javascript.0	2019-11-13 15:56:54.938	error	(29884) SyntaxError: Unexpected end of input
      javascript.0	2019-11-13 15:56:54.937	error	(29884)
      javascript.0	2019-11-13 15:56:54.937	error	(29884) log('registered ' + __engine.__subscriptions + ' subscription' + (__engine.__subscriptions === 1 ? '' : 's' ) + ' and ' + __engine.__schedules + ' schedule' + (__engine.__schedules === 1 ? ''
      javascript.0	2019-11-13 15:56:54.937	error	at script.js.common.Home.LogfileSrcipt2:1392
      javascript.0	2019-11-13 15:56:54.937	error	(29884) script.js.common.Home.LogfileSrcipt2 compile failed:
      was bedeutet das?
      • Glasfaser
        Glasfaser @base last edited by
        @base
        Zeige mal bitte dein ganzes Skript.
        Lade es als . txt Datei hier hoch.
          base @Glasfaser last edited by
          @Glasfaser logfilescript.txt
          • Glasfaser
            Glasfaser @base last edited by Glasfaser
            @base
            Hast du beim kopieren unterschlagen .
            Habe es hier verbessert :
            NEU .txt
              @Glasfaser
              oh peinlich. Vielen Dank für den Hinweis👍
                Sascha12 last edited by
                erstmal Kompliment, geiles Script, toll Dokumentiert, so viel Mühe. Meinen grössten Respekt.
                Nun kommt meine Frage: Ich benutze Habpanel und möchte ungerne die VIS einblenden extra dafür, zumal Habpanel so einfach ist.
                Dafür müsste mir das LOG die Daten nicht als Fließtext ausgeben, sondern es müsste immer einen harten Zeilenumbruch nach jeder Zeile einfügen.
                Ein Beispiel wie ich eine Statusseite hardcoded eingegeben hatte in das Template-Widget. So müsste also der Syntax aussehen. Am Log-Code selbst hatte ich bisher extra nichts geändert.
                Geht das irgendwie umzusetzen oder hat jemand irgendeine andere Idee wie ich es sauber in Habpanel einpflege?
                {{itemValue('deconz.0.Sensors.5.lastupdated')}}<br>
                {{itemValue('deconz.0.Sensors.6.lastupdated')}}<br>
                {{itemValue('deconz.0.Sensors.7.lastupdated')}}<br>
                {{itemValue('deconz.0.Sensors.8.lastupdated')}}<br>
                VG Sascha
                Mic 1 Reply Last reply Reply Quote 0
                • Mic
                  Mic Developer @Sascha12 last edited by
                  @Sascha12
                  Vielen Dank für dein Feedback 🙂 !
                  Was du machen kannst:
                  Den entsprechenden Datenpunkt von logJSON, also etwa javascript.0.Log-Script.xxxxx.logJSON, einfach auf Änderung überwachen. Bei Änderung dann auslesen, die Logzeilen neu aufbauen, und dann in einen neuen Datenpunkt ausgeben.
                  Beispiel (kopiert aus einem Script von mir):
                  // State von Logfile-Script, den wir verarbeiten wollen
                  const STATE_LOG = 'javascript.0.Log-Script.logError.logJSON';
                  // Neuer State, der die geparste Ausgabe enthält
                  const STATE_RESULT = 'javascript.0.Test.Testlog'
                  //////////////////////////// AB HIER NICHTS MEHR ÄNDERN ///////////////////////////////////////
                  createState(STATE_RESULT, {'name':'Test Log', 'type':'string', 'read':true, 'write':true, 'def':'' });
                  on({id: STATE_LOG, change: 'any'}, function (obj) {
                      doStuff();
                  function doStuff() {
                      let obj;
                      // https://forum.iobroker.net/topic/6805/mqtt-json-einzelner-datenpunkt-sonoffpow-script/4
                  	try {obj = JSON.parse(getState(STATE_LOG).val);
                  	} catch (e) {
                          	log('Cannot parse: ' + getState(STATE_LOG).val, 'warn');
                          	return;
                      let logStr = '';
                      for (let lpEntry of obj) {
                          // hier kannst du beliebig alles anpassen für die Ausgabe
                          logStr += lpEntry.date + ' - Level: ' + lpEntry.level + ', Quelle: ' + lpEntry.source + ', Message: ' + lpEntry.msg;
                      setState(STATE_RESULT, logStr);
                  Bei // hier kannst du beliebig alles anpassen für die Ausgabe kannst du deine Ausgabe individuell konfigurieren.
                    Sascha12 @Mic last edited by
                    @Mic said in [Vorlage] JS: Log-Datei aufbereiten für VIS:
                    @Sascha12
                    Danke Dir. Das muss ich erstmal ansehen. Habe es implementiert und funktioniert wie von Dir angegeben !
                    Ich glaube aber, dass ich das nicht weiter verfolge, weil das weitere Anpassen über meinen Horizont geht.
                    Ich müsste ja auch in JS eine Tabelle definieren und in den Code einfügen, weil Habpanel "nur" den reinen Code nimmt im Template-Widget.
                    VG Sascha
                    • AlexAtHome
                      AlexAtHome last edited by
                      Hi @Mic ,
                      vielen, vielen Dank für Dein Script!
                      Ich habe es gerade bei mir auf die aktuellste Version upgedated, und es läuft soweit. Jedoch sagt er mir im Script-Editor folgendes:
                      In der Function init in Zeile
                      // Subscribe to log handler
                              G_LogHandler = onLog('*', data => {
                                  processNewLogLine(data);
                      Das * wird angemeckert, bei Mouse-Over kommt diese Meldung:
                      Argument of type '"*"' is not assignable to parameter of type 'LogLevel'.
                      Ist das ein Problem?
                      Vielen Dank + Greets, Alex
                      • Mic
                        Mic Developer @AlexAtHome last edited by Mic
                        Hi @AlexAtHome aka Alex,
                        vielen Dank für dein Feedback 🙂
                        Die Syntax-Funktion vom JavaScript-Editor mag leider den ziemlich neuen Befehl onLog('*'), also mit Sternchen, noch nicht und kennzeichnet dies als Fehler, während das aber vollständig von ioBroker unterstützt wird.
                        Siehe https://github.com/ioBroker/ioBroker.javascript/blob/master/docs/en/javascript.md#onlog
                        Daher: diese Meldung im JavaScript-Editor kannst du absolut ignorieren, hat keinerlei Auswirkung.
                        Viel Spaß beim Anwenden des Scripts.
                          apollon77 @Mic last edited by
                          @Mic dann bitte GitHub issue beim JavaScript Adapter anlegen. Danke
                          • Mic
                            Mic Developer @apollon77 last edited by
                            @apollon77
                            gerne, erledigt: https://github.com/ioBroker/ioBroker.javascript/issues/457
                            Mic-M created this issue in ioBroker/ioBroker.javascript
                            closed onLog() with wildcard *: not identified by editor #457
                              blackeagle998 last edited by
                              @Mic
                              Ich habe solange nach einer Überwachungsmöglichkeit für die Logs gesucht und bin nun endlich auf dein wunderbares Skript gestoßen. Herzlichen Dank, dass ihr Entwickler euch solche Mühen macht, gerade auch was Support und Weiterentwicklung betrifft!
                              Da ich kein VIS oder ähnliches nutze, lasse ich mir Error Meldungen und bestimmte andere Meldungen (eigene Filter und States habe ich bereits angelegt) per Pushover senden.
                              Im Grunde funktioniert das auch super, allerdings ist die Liste an Error Meldungen sehr lang, da ja die Meldungen der Vortage noch enthalten sind.
                              Theoretisch könnte ich jeden Tag um 00:01Uhr alles leer machen, aber da gibt es doch bestimmt noch eine elegantere Lösung.
                              Ich möchte gerne, dass in den Error-State nur die neuen Fehlermeldungen geschrieben werden, alle davor existierenden sind irrelevant. Kannst du mir sagen, an welcher Stelle ich was einbauen / abklemmen müsste, damit das so funktioniert?
                              Ich habe schon irgendwo was mit "merge" gesehen, da werden die Nachrichten bestimmt zusammengefügt, aber mir fehlt das Detailwissen um da alleine einzugreifen 🙂
                              In diesem Sinne freue ich mich auf deine Rückmeldung.
                              Glasfaser Mic 2 Replies Last reply Reply Quote 0
                              • Glasfaser
                                Glasfaser @blackeagle998 last edited by
                                @blackeagle998
                                Meist du so :
                                damit bekommt man die letzte nachricht des json's -
                                  blackeagle998 @Glasfaser last edited by
                                  @Glasfaser
                                  Danke, das probiere ich mal aus.
                                  Wenn seit dem letzten Lauf fünf Error Meldungen vorhanden sind, gibt er dann genau diese Differenz aus oder tatsächlich nur die allerletzte Message?
                                  • Mic
                                    Mic Developer @blackeagle998 last edited by
                                    @blackeagle998 sagte in [Vorlage] JS: Log-Datei aufbereiten für VIS:
                                    @Mic
                                    Danke für dein Feedback 🙂
                                    Wie definierst du denn "neu" und "davor"? Über Anzahl Stunden, also z.B. alle Meldungen älter als x Stunden ignorieren/rauswerfen?
                                      blackeagle998 @Mic last edited by blackeagle998
                                      @Mic
                                      Ich habe das Skript auf 60 Sekunden gestellt. Das heißt, alles was an neuen Meldungen (in diesem Fall Error) im Vergleich zum vorherigen Lauf hinzugekommen ist, brauche ich in einem Datenpunkt, sodass ich nur diese neuen Meldungen per Pushover versenden kann.
                                      @Glasfaser
                                      Das Blockly habe ich getestet, leider nicht erfolgreich.
                                      Es wurde nur eine bestimmte Message ausgegeben, allerdings ist die von vor fünf Tagen und scheint für mich willkürlich aus dem kompletten JSON gewählt worden zu sein 😁
                                        Alexxx2005 last edited by Alexxx2005
                                        bin gerade auf dieses Skript gestossen und erhoffe mir mein Problem zu lösen,
                                        der Parser0 gibt mir div. Wartezeiten aus, es soll eine Tabelle generiert werden mit Aufsteigenden Wartezeiten, der parser.0 gibt folgendes aus :
                                        hierzu dacht ich an das Beispiel mit dem Hubschrauber, aber leider funktioniert das nicht, was mache ich falsch ?
                                            filter_all:  ['parser.0'],
                                            filter_any:  [],
                                            blacklist:   [],
                                        Grüße Alex
                                        • Glasfaser
                                          Glasfaser @Alexxx2005 last edited by
                                          @Alexxx2005
                                          Was hältst du hiervon , dort kannst du die Datenpunkte in VIS anzeigen lassen.
                                          ID oder Name eines State in Vis anzeigen
                                          • Basti97
                                            Basti97 Most Active last edited by
                                            Sehr gutes Script habe ich schon immer gesucht. Nach dem ich das Script Kopiert habe und gestartet habe kam bei mir folgende Fehlermeldung. Villeicht kann einer von euch mir helfen. Gruß Basti
                                            Script Fehler.JPG Log Datei.JPG image url)
                                            1.0k
                                            617
                                            143375
