    4. MQTT-Adapter nach Update - Fehler
      AndyUM61 last edited by
      Irgend etwas läuft aber gewaltig schief:
      mqtt.0	2015-11-21 21:02:31	info	mqtt.0 Send to client [TempSensor01] "system/adapter/hm-rpc/0/connected": true
      mqtt.0	2015-11-21 21:02:28	info	mqtt.0 Send to client [TempSensor01] "system/adapter/hm-rpc/1/connected": true
      mqtt.0	2015-11-21 21:02:22	info	mqtt.0 Send to client [TempSensor01] "system/adapter/hm-rpc/0/connected": true
      mqtt.0	2015-11-21 21:02:18	info	mqtt.0 Send to client [TempSensor01] "system/adapter/hm-rpc/2/connected": true
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "system/adapter/hm-rpc/0/connected": true
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "TempSensor01/IP": 192.168.0.30
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "TempSensor01/Licht": 1024
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "TempSensor01/Temperatur": 6.40
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "TempSensor01/Luftfeuchte": 99.90
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "RGB01/MODE": 5
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "RGB01/COLOR": #FF0000
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "RGB01/BRIGH": 100
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "RGB01/IP": 192.168.0.36
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "TuerSensor01/Light": 251
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "TuerSensor01/IP": 192.168.0.32
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "TuerSensor01/Sensor1": false
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "hm-rpc/0/LEQ0772770/1/WORKING": false
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "hm-rpc/0/LEQ0772770/1/SUBMIT": undefined
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "hm-rpc/0/LEQ0772770/1/STATE": false
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "hm-rpc/0/LEQ0772770/1/ON_TIME": undefined
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "hm-rpc/0/LEQ0772770/1/INSTALL_TEST": undefined
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "hm-rpc/0/LEQ0772770/1/INHIBIT": undefined
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "hm-rpc/0/LEQ0772770/0/UPDATE_PENDING": undefined
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "hm-rpc/0/LEQ0772770/0/UNREACH": undefined
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "hm-rpc/0/LEQ0772770/0/STICKY_UNREACH": undefined
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "hm-rpc/0/LEQ0772770/0/RSSI_PEER": undefined
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "hm-rpc/0/LEQ0772770/0/RSSI_DEVICE": undefined
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "hm-rpc/0/LEQ0772770/0/LOWBAT": undefined
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "hm-rpc/0/LEQ0772770/0/DUTYCYCLE": undefined
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "hm-rpc/0/LEQ0772770/0/DEVICE_IN_BOOTLOADER": undefined
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "hm-rpc/0/LEQ0772770/0/CONFIG_PENDING": undefined
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "hm-rpc/0/LEQ0772770/0/AES_KEY": undefined
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "system/adapter/vis-google-fonts/upload": 0
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "javascript/0/ColorPicker02/ledB": 61.000
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "javascript/0/ColorPicker02/ledG": 250.000
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "javascript/0/ColorPicker02/ledR": 228.000
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "javascript/0/ColorPicker02/ledRGB": #E4FA3D
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "mqtt/0/RGB01/MODE": 5
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "mqtt/0/RGB01/COLOR": #FF0000
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "mqtt/0/RGB01/BRIGH": 100
      mqtt.0	2015-11-21 21:02:17	info	mqtt.0 Send to client [TempSensor01] "mqtt/0/RGB01/IP": 192.168.0.36
      536_wiffi_config.json.txt
        Pman last edited by
        Schreibst du die Daten in vorhandene States oder werden die sonst in mqtt.0…. geschrieben?
        Ich schreibe z. B. in den vorhandenen State "ioApp.0.P6000_Pro.sensors.battery" und habe keine Probleme mit, Adapterkonfiguration wie bei dir, nur das "Bekanntgeben eigene States beim Verbinden" habe ich aus, sonst ballert der Broker immer hunderte States zum Client sobald ich verbinde.
        Bei Windows bin ich grad leider überfragt, wie werden denn dort sonst Adapter installiert, der Befehl steht doch normalerweise da, wenn man einen Adapter installiert. Da brauchst du dann nur "iobroker.xyz" mit der url tauschen.
          Pman last edited by
          @AndyUM61:
          siehe mein letzter Post, du lässt den Broker auf "*" laufen, also ALLE states, und hast die Option an, dass beim Verbinden alle states an den Client geschickt werden.
            Ich habe jetzt bei
            "Maske für Bekanntgeben eigene States: mqtt.0.*"
            eingegeben ist das korrekt?
            Also die Vorversion des Adapters lief ohne Probleme.
            6909_log.txt
              Pman last edited by
              Bin mir nicht sicher, was du da eingestellt hattest, in welche States willst du denn schreiben, bzw. welche willst du lesen?
                Sobald sich bei mir ein Client erstmals anmeldet, erstellt er seine eigenen benötigten States unter z.B mqtt.0.RGB01.COLOR (ein Topic von einem WS8212B Effektlicht)
                Diese States bedient er dann selbst durch publish, oder ich setze sie und der Client verarbeitet sie durch subscribe.
                Dadurch kann ich einen Client, z.B. ein ESP8266 mit den entsprechend gewünschten Namen und MQTT-Topics programmieren und
                beim ersten Hochfahren des Client wird in der Initialisierung jeder gewünschte Topic einmal publisht und somit im ioBroker erstellt.
                Das alles lief bis vor dem Update auch einwandfrei.
                Jetzt werden von ioBroker zwar die Daten korrekt empfangen, aber nicht in die Topics geschrieben:(.
                  Pman last edited by
                  Also die "Publish beim verbinden" Option betrifft den Server, sobald sich ein Client verbindet werden ungefragt alle abonnierten Topics an den Client gesendet, auch wenn dieser kein subscribe gesendet hat.
                  Der Mqtt Adapter schreibt alle empfangenen States nach mqtt.0.* wenn er die States nicht kennt. In deinem Fall kannst du die Masken-Option leer lassen, da du ja nicht in vorhandene States schreiben willst. Bleibt zu klären warum die States jetzt nicht mehr in mqtt.0.* geschrieben werden.
                  • Bluefox
                    Bluefox last edited by
                    Probier mal die Version 0.2.14
                      Pman last edited by
                      ok es gab wohl noch einen fix
                        Pman last edited by
                        @bluefox kannst du mal hier gucken:
                        https://github.com/ioBroker/ioBroker.mq … t-14544620
                        Bin mir nicht sicher wieso du da topic gelöscht hast, vielleicht ist es okay.
                          @Bluefox:
                          Probier mal die Version 0.2.14 `
                          Funktioniert scheinbar einwandfrei:).
                          DANKE!!!
                          • Bluefox
                            @Pman:
                            Bin mir nicht sicher wieso du da topic gelöscht hast, vielleicht ist es okay. `
                            Ich habe den nach oben geschoben. Damit jshint nicht schimpft.
                              Pman last edited by
                              Ah okay, dann ist gut :lol:
                              Da du ja meine letzte Änderung zurück genommen hast denke ich dass der Fehler dadurch kam?! Lustigerweise hat bei mir mit der Änderung alles geklappt. Jetzt ist die Frage ob das mit der neuen Änderung auch so bleibt, ich hatte vorher diesen Fehler:
                              EDIT: alles gut, in der neuen Version klappt es super!
                              • Bluefox
                                Kann jemand außer Pman die aktuelle Version von mqtt testen?
                                Einfach über admin und "eigene URL" installieren: 48_img_002.png
                                https://github.com/ioBroker/ioBroker.mqtt
                                  @Bluefox:
                                  Kann jemand außer Pman die aktuelle Version von mqtt testen? `
                                  Guten Morgen,
                                  ich habe den Adapter mal installiert und getestet, scheint alles korrekt zu funktionieren.
                                  Also auf jeden Fall Anmeldung, publish und subscribe.
                                  LWT habe ich bei meinen Clients bisher nicht verwendet.
                                  • Bluefox
                                    Gut dann mache ich eine Version heute.
                                    Andere Frage. Verwendet jemand MQTT mit Arduino? Kann man hier Arduino Projekt (falls Stabil) posten?
                                    Danke.
                                      @Bluefox:
                                      Danke. `
                                      Ich verwende MQTT in Verbindung mit der ArduinoIDE und auch LUA, allerdings auf ESP8266-WLAN.
                                      Bisher realisiert: Temperatursensor, PIR-Sensor, optischer Signalgeber mit WS8212B.
                                      Läuft bisher stabil.
                                      Ist das auch interessant?
                                      • Bluefox
                                        Ja. Natürlich.
                                          Pman last edited by
                                          ESP8266 ist total interessant, wollte mich demnächst mal damit beschäftigen.
                                            @Bluefox:
                                            Ja. Natürlich. `
                                            Unter welcher Rubrik sollte ich denn dann mal diese MQTT-Geschichten vorstellen?
                                            Ist ja letztendlich eine Kombination aus Hard- und Software.
                                            2326
