    4. [How-to] Node.js für ioBroker richtig updaten
      apollon77 @sveni_lee last edited by
      @sveni_lee Schreib mal alle buchstaben klein 🙂
      iobroker.js-controller
        sveni_lee @apollon77 last edited by
        @apollon77
        jetzt ging es schon mal weiter.
        svenilee@Gotham-City:/opt/iobroker$ npm i iobroker.js-controller --production --force
        npm WARN using --force I sure hope you know what you are doing.
        npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
        > iobroker.js-controller@1.5.14 preinstall /opt/iobroker/node_modules/iobroker.js-controller
        > node lib/preinstallCheck.js
        NPM version: 6.11.3
        npm version >= 5: disabling package-lock
        > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
        > node rebuild.js
        > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage
        > node-gyp rebuild
        make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird betreten
          CXX(target) Release/obj.target/diskusage/src/main.o
          CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
          SOLINK_MODULE(target) Release/obj.target/diskusage.node
          COPY Release/diskusage.node
        make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird verlassen
        > iobroker.js-controller@1.5.14 install /opt/iobroker/node_modules/iobroker.js-controller
        > node iobroker.js setup first
        > acme-v2@1.8.6 postinstall /opt/iobroker/node_modules/acme-v2
        > node scripts/postinstall
        Greenlock and ACME.js v3 are on the way!
        Watch for updates at https://indiegogo.com/at/greenlock
        + iobroker.js-controller@1.5.14
        added 335 packages from 279 contributors and audited 841 packages in 26.74s
        found 27 vulnerabilities (19 low, 8 high)
          run `npm audit fix` to fix them, or `npm audit` for details
        soll ich run npm audit fix to fix them, or npm audit for details ausführen?
        AlCalzone apollon77 2 Replies Last reply Reply Quote 0
        • AlCalzone
          AlCalzone Developer @sveni_lee last edited by
          @sveni_lee sagte in [How-to] Node.js für ioBroker richtig updaten:
          NEIN!
            @sveni_lee Alles gut, so geht es. Wie @AlCalzone geschrieben hat: nix weiter ausführen
              @apollon77
              etwas spät aber immerhin... es läuft ja wieder.
              aber irgendwas stimt bei meiner installation nicht.
              Jetzt habe ich Probleme mit JS-scripten
              "cannot find modul 'request'" steht da zum Beispiel. Das habe ich bei
              request, fs und dateformat.
                klausiob last edited by
                @apollon77 Danke für die Anleitung. Wollte mein Node.js von 8.14.0 auf 18.16.2 updaten (raspi3+). Bin am Punkt iobroker stop gescheitert.
                iobroker controller daemon is not running
                Es läuft aber noch alles in VIS und Admin. Dann versuchte ich mit sudo kill -9 <ProzessID> einzeln zu löschen. Funktioniert einzeln auch, mußte dann aber feststellen, dass nach und nach wieder alle Prozesse mit neuer PID da waren????
                Was mache ich falsch?
                BBTown apollon77 2 Replies Last reply Reply Quote 0
                • BBTown
                  BBTown @klausiob last edited by
                  @klausiob
                  ich bin ziemlich sicher, dass Du dann weltweit der Erste auf einer v18.x.x sein wirst ... 😎
                    apollon77 @klausiob last edited by
                    @klausiob wenn du manuell killst dann den js-Controller Prozess zuerst. Der startet sonst alles wieder. Wenn iobroker stop nicht tut Versuch „systemctl stop iobroker“ und am besten den fixer laufen lassen.
                      @apollon77 Danke hat funktioniert. Hier nochmal die Zusammenfassung:
                      Für das Kommando werden root-Rechte gebraucht
                      sudo -s
                      ps -ef|grep io
                      curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash
                      node -v
                      nodejs -v
                      Wollte erst ... setup_8.16.2 eingeben. Findet er aber nicht, nimmt mit "x" aber die gewünschte aktuellste Version.
                        maik150 last edited by
                        ich wollte nun auch node.js aktualisieren, was soweit auch klappte. als ich dann aber "npm rebuild" in cd /opt/iobroker ausgeführt habe, kam dies zum schluss. bin bis hier nach der anleitung hier aus dem forum vorgegangen.
                        gyp ERR! clean error
                        gyp ERR! stack Error: EACCES: permission denied, rmdir 'build'
                        gyp ERR! System Linux 4.9.59-v7+
                        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gy p/bin/node-gyp.js" "rebuild"
                        gyp ERR! cwd /opt/iobroker/node_modules/ursa
                        gyp ERR! node -v v10.17.0
                        gyp ERR! node-gyp -v v5.0.3
                        gyp ERR! not ok
                        npm ERR! code ELIFECYCLE
                        npm ERR! errno 1
                        npm ERR! ursa@0.9.4 install: `node-gyp rebuild`
                        npm ERR! Exit status 1
                        npm ERR!
                        npm ERR! Failed at the ursa@0.9.4 install script.
                        npm ERR! This is probably not a problem with npm. There is likely additional log ging output above.
                        npm ERR!     /root/.npm/_logs/2019-11-30T17_15_22_906Z-debug.log
                        kann mir da einer von euch weiterhelfen? oder kann man dies ignorieren, wahrscheinlich nicht oder?
                        apollon77 AlCalzone 2 Replies Last reply Reply Quote 0
                          apollon77 @maik150 last edited by
                          @maik150 installation fixer nutzen um alles rechte korrekt zu setzen.
                            maik150 @apollon77 last edited by
                            @apollon77 den installationsfixer habe ich davor ausgeführt
                              sigi234 Forum Testing Most Active @maik150 last edited by sigi234
                              @maik150 sagte in [How-to] Node.js für ioBroker richtig updaten:
                              node-gyp -v v5.0.3 ?
                                maik150 @sigi234 last edited by
                                @sigi234 keine ahnung, was sagt dieser wert aus?
                                  Was kommt bei:
                                  cd /opt/iobroker
                                  iobroker list instances
                                  node -v
                                  nodejs -v
                                  npm -v
                                    @sigi234
                                    root@raspberrypi2:/opt/iobroker# iobroker list instances
                                    system.adapter.admin.0                 : admin       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    system.adapter.cloud.0                 : cloud       -  enabled
                                    system.adapter.discovery.0             : discovery   -  enabled
                                    system.adapter.hm-rega.0               : hm-rega     -  enabled
                                    system.adapter.hm-rpc.0                : hm-rpc      -  enabled, port: 0
                                    system.adapter.info.0                  : info        -  enabled
                                    system.adapter.samsung.0               : samsung     - disabled
                                    node -v
                                    v10.17.0
                                    nodejs -v
                                    v10.17.0
                                    npm -v
                                    v6.11.3
                                      ich führe alles als root user aus nicht als pi user, falls das vielleicht wichtig ist?
                                      und der installationsfixer muss der im iobroker ordner ausgeführt werden?
                                      sigi234 BBTown 2 Replies Last reply Reply Quote 0
                                        @maik150
                                        https://forum.iobroker.net/topic/20211/iobroker-installation-fixer-beta-verfügbar
                                          @sigi234 hab ich gelesen, was soll ich dem entnehmen?
                                          • BBTown
                                            BBTown @maik150 last edited by
                                            nein
                                            installation linux node node.js nodejs windows
                                            106
                                            1105
                                            735917
