Test Adapter ZWave2 (v0.3.x)
@JungleFire Noch wird der originale dafür benötigt. Die Oberfläche gehe ich im nächsten Update an.
Hallo AlCalzone
bekomme mit der 0.3 folgenden Fehler und der Adapter startet laufend neuzwave2.0 2019-11-27 09:46:44.440 info (6048) terminating zwave2.0 2019-11-27 09:46:44.411 info (6048) Cleaned everything up! zwave2.0 2019-11-27 09:46:44.402 info (6048) Shutting down driver... zwave2.0 2019-11-27 09:46:44.401 error at Timeout.saveToCacheTimer.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/zwave-js/build/lib/driver/Driver.js:1099:68) zwave2.0 2019-11-27 09:46:44.401 error at Driver.saveNetworkToCache (/opt/iobroker/node_modules/zwave-js/build/lib/driver/Driver.js:1107:21) zwave2.0 2019-11-27 09:46:44.401 error at Driver.saveNetworkToCacheInternal (/opt/iobroker/node_modules/zwave-js/build/lib/driver/Driver.js:1084:47) zwave2.0 2019-11-27 09:46:44.401 error at ZWaveController.serialize (/opt/iobroker/node_modules/zwave-js/build/lib/controller/Controller.js:593:70) zwave2.0 2019-11-27 09:46:44.401 error at Array.map (<anonymous>) zwave2.0 2019-11-27 09:46:44.401 error at nodes.objects_1.composeObject.map (/opt/iobroker/node_modules/zwave-js/build/lib/controller/Controller.js:593:111) zwave2.0 2019-11-27 09:46:44.401 error at ZWaveNode.serialize (/opt/iobroker/node_modules/zwave-js/build/lib/node/Node.js:946:18) zwave2.0 2019-11-27 09:46:44.401 error at Array.map (<anonymous>) zwave2.0 2019-11-27 09:46:44.401 error at commandClasses.objects_1.composeObject.sort.map (/opt/iobroker/node_modules/zwave-js/build/lib/node/Node.js:951:41) zwave2.0 2019-11-27 09:46:44.401 error at ZWaveNode.createCCInstance (/opt/iobroker/node_modules/zwave-js/build/lib/node/Endpoint.js:154:19) zwave2.0 2019-11-27 09:46:44.401 error (6048) Error: Cannot create an instance of the unsupported CC Basic (0x20) zwave2.0 2019-11-27 09:46:44.401 error (6048) uncaught exception: Cannot create an instance of the unsupported CC Basic (0x20) zwave2.0 2019-11-27 09:46:43.640 info (6048) Node 1: interview completed zwave2.0 2019-11-27 09:46:43.570 info (6048) The driver is ready. Found 5 nodes. zwave2.0 2019-11-27 09:46:42.724 info (6048) starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.zwave2, node: v10.17.0
Gruss Stephan
bin erstmal auf 0. 2.1 zurück -
@stephan61 Kannst du mir bitte deine Cache-Datei schicken?
/opt/iobroker/node_modules/zwave-js/cache/<irgendwas>.json
Hallo AlCalzone anbei die cache datei f72e307b.json
Gruß Stephan
@stephan61 Bitte teste mal v0.3.1, sollte in Kürze verfügbar sein.
Hallo mit 0.3.1 kommt keine Fehlermeldung
Danke -
Hallo AlCalzone
bekomme leider immernoch Fehlermeldungen
alle 2 Stunden kommt folgender Fehler2019-11-28 08:04:22.979 - [32minfo[39m: zwave2.0 (23350) Node 2: is now awake 2019-11-28 08:04:23.536 - [31merror[39m: zwave2.0 (23350) uncaught exception: Cannot read property 'toUpperCase' of undefined 2019-11-28 08:04:23.536 - [31merror[39m: zwave2.0 (23350) TypeError: Cannot read property 'toUpperCase' of undefined at str.split.map (/opt/iobroker/node_modules/iobroker.zwave2/src/lib/objects.ts:45:17) at Array.map (<anonymous>) at camelCase (/opt/iobroker/node_modules/iobroker.zwave2/src/lib/objects.ts:42:4) at nameToStateId (/opt/iobroker/node_modules/iobroker.zwave2/src/lib/objects.ts:36:9) at Object.computeId (/opt/iobroker/node_modules/iobroker.zwave2/src/lib/objects.ts:60:33) at Zwave2.onNodeMetadataUpdated (/opt/iobroker/node_modules/iobroker.zwave2/src/main.ts:180:22) at ZWaveNode.emit (events.js:198:13) at ZWaveNode.translateValueEvent (/opt/iobroker/node_modules/zwave-js/build/lib/node/Node.js:128:18) at ValueDB.emit (events.js:198:13) at ValueDB.setMetadata (/opt/iobroker/node_modules/zwave-js/build/lib/node/ValueDB.js:108:18) 2019-11-28 08:04:23.538 - [32minfo[39m: zwave2.0 (23350) Shutting down driver... 2019-11-28 08:04:23.637 - [32minfo[39m: zwave2.0 (23350) Cleaned everything up! 2019-11-28 08:04:23.659 - [32minfo[39m: zwave2.0 (23350) terminating 2019-11-28 08:04:23.662 - [32minfo[39m: zwave2.0 (23350) Terminated (NO_ERROR): Without reason
Node 2 ist ein FGMS001 Motion Sensor
Gruß Stephan
@stephan61 Danke für den Report! v0.3.2 (in ein paar Minuten verfügbar) sollte das fixen.
Hallo Alcazone habe einen Fehler gefunden
wenn ich bei node 3 Fibaro flood fsgs 101
unter configuration zwave2.0.Node_003.Configuration.typeAlarmFrameSentTo1-stAssocGroup änder e habe ich nur 0 und 255 zur auswahl stimmt so weit bei dem wert 255 kommt folgender Fehlerhost.proiobroker 2019-11-30 17:46:30.285 info instance system.adapter.zwave2.0 terminated with code 0 (NO_ERROR) host.proiobroker 2019-11-30 17:46:30.284 error Caught by controller[0]: at processImmediate (timers.js:658:5) host.proiobroker 2019-11-30 17:46:30.284 error Caught by controller[0]: at tryOnImmediate (timers.js:676:5) host.proiobroker 2019-11-30 17:46:30.283 error Caught by controller[0]: at runCallback (timers.js:705:18) host.proiobroker 2019-11-30 17:46:30.282 error Caught by controller[0]: at Immediate.setImmediate (/opt/iobroker/node_modules/zwave-js/build/lib/driver/Driver.js:930:33) host.proiobroker 2019-11-30 17:46:30.282 error Caught by controller[0]: at Driver.workOffSendQueue (/opt/iobroker/node_modules/zwave-js/build/lib/driver/Driver.js:987:30) host.proiobroker 2019-11-30 17:46:30.282 error Caught by controller[0]: at SendDataRequest.serialize (/opt/iobroker/node_modules/zwave-js/build/lib/controller/SendDataMessages.js:61:43) host.proiobroker 2019-11-30 17:46:30.281 error Caught by controller[0]: at ConfigurationCCSet.serialize (/opt/iobroker/node_modules/zwave-js/build/lib/commandclass/ConfigurationCC.js:700:13) host.proiobroker 2019-11-30 17:46:30.281 error Caught by controller[0]: at serializeValue (/opt/iobroker/node_modules/zwave-js/build/lib/commandclass/ConfigurationCC.js:1139:21) host.proiobroker 2019-11-30 17:46:30.279 error Caught by controller[0]: at Buffer.writeIntBE (internal/buffer.js:701:12) host.proiobroker 2019-11-30 17:46:30.278 error Caught by controller[0]: at writeU_Int8 (internal/buffer.js:555:11) host.proiobroker 2019-11-30 17:46:30.274 error Caught by controller[0]: RangeError [ERR_OUT_OF_RANGE]: The value of "value" is out of range. It must be >= -128 and <= 127. Received 255 zwave2.0 2019-11-30 17:46:29.699 info (12313) Terminated (NO_ERROR): Without reason
@stephan61 Verdammt, du bist gut! Das ist ein grundlegendes Problem, das ich bisher nicht bedacht hatte. Muss mal überlegen, wie ich es am besten löse.
@stephan61 In Kürze ist v0.3.3 verfügbar, die sich daran nicht mehr verschlucken sollte.
Hier gehts weiter:
https://forum.iobroker.net/topic/27592/test-adapter-zwave2-v0-4-x
