    3. Cloud Dienste
    4. Alexa 2.6.4 hat plötzlich Adapterteile verloren ?!
    • MesserMike
      MesserMike last edited by MesserMike
      Danke für deine Antwort, aber bei ALLEN Alexa-Geräten sind die SELBEN Einstellungen weg.... 😕
      Dot3, Dot2, Show2... ok, also wenn Amazon was ändert holt sich das der Adapter selbstständig? nicht gut... 😥
      werd ihn mal rausschmeissen... seh eh was dann passiert... 🙇‍♂️
      host.iobroker	2019-12-03 22:40:52.102	info	Restart adapter system.adapter.alexa2.0 because enabled
      host.iobroker	2019-12-03 22:40:52.102	info	instance system.adapter.alexa2.0 terminated with code 0 (NO_ERROR)
      host.iobroker	2019-12-03 22:40:52.102	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:63:19)
      host.iobroker	2019-12-03 22:40:52.102	error	Caught by controller[0]: at endReadableNT (_stream_readable.js:1103:12)
      host.iobroker	2019-12-03 22:40:52.101	error	Caught by controller[0]: at TLSSocket.emit (events.js:194:15)
      host.iobroker	2019-12-03 22:40:52.101	error	Caught by controller[0]: at TLSSocket.socketOnEnd (_http_client.js:426:9)
      host.iobroker	2019-12-03 22:40:52.101	error	Caught by controller[0]: at ClientRequest.emit (events.js:189:13)
      host.iobroker	2019-12-03 22:40:52.101	error	Caught by controller[0]: at ClientRequest.<anonymous> (/opt/iobroker/node_modules/alexa-cookie2/alexa-cookie.js:114:20)
      host.iobroker	2019-12-03 22:40:52.100	error	Caught by controller[0]: at request (/opt/iobroker/node_modules/alexa-cookie2/alexa-cookie.js:204:50)
      host.iobroker	2019-12-03 22:40:52.099	error	Caught by controller[0]: TypeError: Cannot read property 'headers' of null
      alexa2.0	2019-12-03 22:40:51.580	info	(3929) Terminated (NO_ERROR): Without reason
      alexa2.0	2019-12-03 22:40:51.577	info	(3929) terminating
      alexa2.0	2019-12-03 22:40:51.513	error	(3929) TypeError: Cannot read property 'headers' of null at request (/opt/iobroker/node_modules/alexa-cookie2/alexa-cookie.js:204:50) at ClientRequest.<anonymous> (/opt/iobroker/node_modules/a
      alexa2.0	2019-12-03 22:40:51.511	error	(3929) uncaught exception: Cannot read property 'headers' of null
      alexa2.0	2019-12-03 22:40:51.490	warn	(3929) Exception: TypeError: Cannot read property 'headers' of null
      alexa2.0	2019-12-03 22:39:25.109	error	(3929) Error: You can try to get the cookie manually by opening http://192.168.1.11:37223/ with your browser.
      alexa2.0	2019-12-03 22:39:25.108	error	(3929) Error:
      alexa2.0	2019-12-03 22:39:24.407	info	(3929) Proxy IP not set, use first network interface (192.168.1.11) instead
      alexa2.0	2019-12-03 22:39:24.261	info	(3929) starting. Version 2.6.4 in /opt/iobroker/node_modules/iobroker.alexa2, node: v10.15.2
      host.iobroker	2019-12-03 22:39:20.645	info	instance system.adapter.alexa2.0 started with pid 3929
      host.iobroker	2019-12-03 22:38:50.630	info	Restart adapter system.adapter.alexa2.0 because enabled
      JETZT wirds wieder mal interessant...
      Hab ALEXA Adpater gelöscht, dann neu installiert...
      Spinnt komplett... Cookie hat er nun schon 3x bekommen... und dann stirbt der Adapter...
      So... gesamter Neustart vom RaspiBroker... Adapter hält... SPEAK ist auch wieder da...
      Selbstzerstörung des Adapters ???
      • dslraser
        dslraser Forum Testing Most Active @MesserMike last edited by
        @MesserMike
        eventuell über GitHub installiert/aktualisiert ?
        Lese mal den letzten Absatz von hier.
        https://forum.iobroker.net/post/332962
        • MesserMike
          Nein hab ich nicht, ganz normal installiert. Hab ich noch nie über Github installiert, Button ist auch aus.
          Habe heute Nacht etwas neues bemerkt uns soll mich laut Adapter an den Developer wenden...
          alexa2.0	2019-12-04 03:17:40.502	info	(1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":
          Die Meldung kam 40x in 2 Sekunden, Adapter gibts nur 1x am Broker bezugnehmend auf DOPPLER_ACTIVITIES.
          Fängt damit jemand was an?
          Neu installiert ist er schon seit gestern. Zumindest sind die gestrigen Probleme mit dem automatischen
          löschen der Adapterteile ala speak usw nicht mehr aufgetreten und sie sind noch da und funktionieren auch noch.
          • dslraser
            @MesserMike sagte in Alexa 2.6.4 hat plötzlich Adapterteile verloren ?!:
            @apollon77 ?
            MesserMike 1 Reply Last reply Reply Quote 0
            • MesserMike
              MesserMike @dslraser last edited by
              @dslraser
              denn möcht ich nicht direkt kontaktieren.
              Wenn er hier drüberliest, aber ich möcht da nicht mit möglicherweise banalitäten stören.
              Vielleicht hat ja jemand schon mal das Problem gehabt und kann helfen.
              Wenn nicht, dann bleibt mir eh nichts anderes über als ihn zu kontaktieren.
                apollon77 last edited by
                Also der Adapter liesst bei jedem neustart die Gerätedetails neu ein und ggf werden dadurch Datenpunkte entfernt. Was jetzt genau bei Dir passiert ist kann man nur im Log rausfinden. Nimm doch mal das Log auf platte, überleg wann es zuletzt ging und such im logfile nach alexa2 ausgaben seitdem bis heute früh.
                • MesserMike
                  Dann hat da Mikey scheisse baut, weil ich nach dem Neustart das Log über die ROTE Löschentaste gelöscht habe da ich die seite für neue nachrichten übersichtlich frei haben wollte...
                  Steht der Log sonst noch wo gespeichert, oder hab i da tatsächlich den Log komplett gelöscht?
                  Muss ich halt warten bis wieder auftritt... hoffe es dauert mal...
                  War aufjeden fall im laufenden betrieb mitten in der nacht gegen 3 Uhr...
                    apollon77 @MesserMike last edited by
                    @MesserMike siehe meine Signatur : auf der Platte /opt/iobroker/log/...
                    • MesserMike
                      MesserMike @apollon77 last edited by
                      @apollon77
                      Hallo Apollon77
                      Erneut ab 3 Uhr heut AlexaAdaptermeldungen und seit dem Spinnen mir auch die Sonoffs wieder...
                      Ich vermute das der Fehler nicht an den Adaptern liegt sondern am seit 5 Tagen neuen Raspi4B 4GB...
                      Ich werd versuchen ein Backup in den alten Rechner hochzuladen und schaun was dort passiert...
                      Mach ich noch heute Abend...
                      Log wie folgt:
                      2019-12-05 00:00:30.574  - info: javascript.0 (967) Stop script script.js.common.Test2
                      2019-12-05 00:00:30.756  - info: javascript.0 (967) Start javascript script.js.common.Test2
                      2019-12-05 00:00:30.835  - info: javascript.0 (967) script.js.common.Test2: registered 3 subscriptions and 0 schedules
                      2019-12-05 03:26:32.085  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1480895999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.089  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1481500799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.110  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1484524799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.111  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1485129599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.116  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1485734399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.120  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1483919999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.122  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1486339199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.125  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1487548799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.146  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1482710399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.149  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1483315199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.202  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1489363199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.203  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1486943999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.213  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1488758399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.214  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1490572799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.227  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1482105599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.228  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1491782399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.230  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1492991999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.231  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1489967999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.236  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1496015999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.238  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1494806399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.242  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1499039999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.246  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1488153599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.263  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1497225599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.264  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1500249599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.268  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1492387199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.269  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1491177599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.318  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1500854399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.319  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1494201599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.328  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1498435199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.329  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1496620799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.343  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1493596799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.344  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1495411199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.346  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1499644799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.353  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1503878399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.354  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1504483199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.356  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1502063999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.357  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1502668799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.359  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1505087999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.361  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1506297599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.362  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1505692799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.363  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1497830399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.365  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1501459199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.368  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1507507199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.369  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1508111999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.378  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1509321599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.379  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1506902399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.383  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1510531199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.384  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1511135999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.386  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1509926399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.387  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1511740799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.389  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1512345599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.432  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1514159999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.433  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1513555199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.442  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1515369599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.443  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1503273599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.457  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1516579199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.458  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1517183999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.467  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1518393599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.468  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1518998399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.472  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1514764799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.473  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1520812799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.474  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1508716799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.474  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1522627199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.475  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1523231999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.478  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1519603199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.479  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1523836799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.489  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1512950399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.490  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1515974399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.498  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1525651199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.499  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1525046399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.499  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1517788799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.500  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1526255999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.501  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1526860799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.501  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1527465599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.502  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1520207999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.549  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1529279999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.550  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1524441599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.559  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1530489599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.560  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1531094399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.574  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1522022399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.575  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1528675199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.584  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1521417599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.585  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1533513599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.589  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1531699199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.590  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1529884799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.590  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1535932799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.591  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1534118399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.592  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1532303999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.604  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1538351999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.605  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1534723199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.606  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1539561599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.614  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1537142399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.615  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1536537599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.616  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1528070399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.616  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1535327999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.619  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1537747199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.667  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1532908799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.677  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1540166399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.678  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1540771199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.692  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1541375999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.693  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1538956799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.702  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1542585599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.703  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1543190399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.707  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1545004799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.725  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1546819199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.741  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1548633599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.747  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1543795199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.749  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1549843199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.755  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1551052799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.756  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1550447999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.773  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1545609599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.785  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1549238399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.786  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1551657599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.795  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1547423999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.796  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1544399999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.810  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1554681599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.811  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1552262399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.820  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1548028799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.821  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1541980799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.825  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1557100799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.826  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1557705599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.840  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1556495999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.841  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1552867199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.842  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1553471999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.842  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1555286399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.861  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1554076799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.862  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1560729599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.863  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1560124799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.871  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1561939199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.872  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1558915199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.873  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1562543999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      2019-12-05 03:26:32.873  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1563148799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                      • MesserMike
                        2019-12-05 03:26:32.891  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1555891199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:26:32.892  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1563753599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:26:32.893  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1564963199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:26:32.893  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1558310399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:26:32.902  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1565567999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:26:32.912  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1561334399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:26:32.930  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1559519999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:26:32.941  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1564358399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:26:32.955  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1566777599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:26:32.992  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1566172799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:26:33.029  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1567382399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:26:33.096  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1546214399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:26:33.544  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1567728000000,"dopplerId":{"deviceSerialNumber":"G090LF1173621QNU","deviceType":"A3S5BH2HU6VAYF"}}
                        2019-12-05 03:28:36.919  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1482105599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:36.922  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1482710399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:36.931  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1480895999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:36.934  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1481500799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:36.936  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1483919999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:36.946  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1484524799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:36.965  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1486339199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:36.971  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1486943999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:36.977  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1487548799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:36.980  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1485129599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.036  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1488153599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.038  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1483315199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.039  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1485734399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.041  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1489363199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.042  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1489967999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.049  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1490572799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.054  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1492387199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.059  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1492991999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.067  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1488758399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.075  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1491177599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.081  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1494806399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.086  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1493596799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.104  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1494201599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.106  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1491782399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.151  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1497830399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.153  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1500249599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.154  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1496620799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.156  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1499039999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.157  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1496015999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.159  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1500854399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.166  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1501459199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.168  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1502063999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.172  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1495411199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.178  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1503273599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.184  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1503878399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.185  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1502668799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.190  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1504483199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.196  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1505087999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.221  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1505692799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.222  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1499644799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.224  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1507507199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.261  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1497225599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.263  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1506297599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.266  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1506902399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.268  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1508716799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.269  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1509321599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.274  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1509926399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.284  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1510531199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.291  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1508111999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.303  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1512345599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.310  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1511135999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.344  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1511740799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.525  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1512950399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.529  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1513555199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.532  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1514159999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.545  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1514764799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.548  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1515369599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.553  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1515974399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.564  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1517183999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.568  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1517788799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.577  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1518393599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.584  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1518998399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.597  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1519603199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.634  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1521417599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.636  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1522627199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.638  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1516579199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.647  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1523231999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.649  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1520812799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.650  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1522022399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.651  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1523836799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.662  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1524441599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.663  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1525046399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.672  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1526255999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.681  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1526860799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.685  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1520207999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.708  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1525651199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.714  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1529884799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.715  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1527465599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.720  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1530489599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.752  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1531094399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.754  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1531699199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.755  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1532303999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.757  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1529279999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.758  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1533513599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.760  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1534118399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.780  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1532908799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.781  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1528675199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.841  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1535932799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.850  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1536537599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.869  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1537142399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.871  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1535327999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.873  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1537747199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.875  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1538351999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.885  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1534723199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.887  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1538956799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.894  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1540166399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.912  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1541375999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.914  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1541980799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.929  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1543795199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.938  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1540771199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.941  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1544399999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.948  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1542585599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.968  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1545004799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.969  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1539561599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.970  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1546214399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.980  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1547423999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:37.990  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1548633599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.007  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1548028799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.040  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1549238399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.041  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1543190399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.042  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1551657599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.042  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1551052799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.043  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1528070399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.044  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1549843199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.047  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1552262399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.054  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1546819199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.056  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1545609599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.084  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1555286399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.085  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1555891199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.088  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1556495999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.094  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1552867199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.098  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1557705599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.119  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1550447999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.120  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1554681599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.121  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1558915199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.154  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1560729599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.155  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1558310399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.156  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1560124799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.156  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1561334399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.157  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1553471999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.158  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1559519999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.160  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1563148799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.161  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1563753599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.162  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1554076799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.164  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1562543999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.169  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1564963199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.170  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1561939199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.173  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1557100799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.199  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1565567999000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.200  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1566172799000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.201  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1566777599000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.201  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1567382399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.237  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1564358399000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.270  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1567728000000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 03:28:38.456  - info: alexa2.0 (1108) Alexa-Push-Connection Unknown Command PUSH_DELETE_DOPPLER_ACTIVITIES - send to Developer: {"destinationUserId":"A1Z167LV2VAUIE","targetCustomerId":"A1Z167LV2VAUIE","deleteBeforeTimeInclusive":1498435199000,"dopplerId":{"deviceSerialNumber":null,"deviceType":null}}
                        2019-12-05 19:13:57.250  - info: sonoff.0 (998) Client [Sonoff Licht Wohnzimmer] reconnected. Old secret 1575409602489_6825. New secret 1575569637250_7200
                        2019-12-05 19:13:57.514  - info: web.0 (1048) ==>Connected system.user.admin from ::ffff:192.168.1.103
                        2019-12-05 19:13:57.716  - info: sonoff.0 (998) Client [Sonoff Licht Vorraum] reconnected. Old secret 1575409602183_8581. New secret 1575569637715_6976
                        2019-12-05 19:13:57.908  - info: sonoff.0 (998) Client [Sonoff Licht Couch] reconnected. Old secret 1575409602508_9221. New secret 1575569637907_7905
                        2019-12-05 19:13:58.036  - warn: sonoff.0 (998) Old client Sonoff Licht Wohnzimmer with secret 1575409602489_6825 sends pingreq. Ignore! Actual secret is 1575569637250_7200
                        2019-12-05 19:13:58.175  - info: sonoff.0 (998) Client [Waschmaschine] reconnected. Old secret 1575409601993_8657. New secret 1575569638174_7142
                        2019-12-05 19:13:58.794  - info: web.0 (1048) ==>Connected system.user.admin from ::ffff:192.168.1.103
                        2019-12-05 19:13:59.239  - info: sonoff.0 (998) Client [Sonoff_4ch] reconnected. Old secret 1575409602267_7623. New secret 1575569639238_225
                        2019-12-05 19:13:59.858  - info: sonoff.0 (998) Client [Sonoff_Weihnachten_2] reconnected. Old secret 1575409602338_9028. New secret 1575569639856_5188
                        2019-12-05 19:14:00.627  - info: sonoff.0 (998) Client [Sonoff_Weihnachten_3] reconnected. Old secret 1575409602194_7089. New secret 1575569640626_5481
                        2019-12-05 19:14:00.768  - info: sonoff.0 (998) Client [SHP_Scentsy_Vorraum] reconnected. Old secret 1575409602436_6439. New secret 1575569640765_6877
                        2019-12-05 19:14:01.474  - info: sonoff.0 (998) Client [Shelly1_Nebenraum_LedLicht] reconnected. Old secret 1575409602540_5253. New secret 1575569641472_3316
                        2019-12-05 19:14:01.671  - info: sonoff.0 (998) Client [Sonoff Steckdose SZ Scentsy] reconnected. Old secret 1575409601995_2992. New secret 1575569641668_729
                        2019-12-05 19:14:01.802  - warn: sonoff.0 (998) Old client SHP_Scentsy_Vorraum with secret 1575409602436_6439 sends pingreq. Ignore! Actual secret is 1575569640765_6877
                        2019-12-05 19:14:02.059  - info: sonoff.0 (998) Client [Sonoff Steckdose KÜ Scentsy] reconnected. Old secret 1575409602392_290. New secret 1575569642055_2389
                        2019-12-05 19:14:02.929  - warn: sonoff.0 (998) Old client Sonoff Steckdose KÜ Scentsy with secret 1575409602392_290 sends pingreq. Ignore! Actual secret is 1575569642055_2389
                        2019-12-05 19:14:03.235  - warn: sonoff.0 (998) Old client Sonoff Steckdose SZ Scentsy with secret 1575409601995_2992 sends pingreq. Ignore! Actual secret is 1575569641668_729
                        2019-12-05 19:14:03.569  - info: sonoff.0 (998) Client [Licht Terrasse] reconnected. Old secret 1575409602650_548. New secret 1575569643568_1628
                        2019-12-05 19:14:03.954  - info: sonoff.0 (998) Client [H801_Essplatz] reconnected. Old secret 1575409602231_6629. New secret 1575569643952_7125
                        2019-12-05 19:14:04.014  - info: sonoff.0 (998) Client [Sonoff Aussensensor] reconnected. Old secret 1575409602695_2905. New secret 1575569644012_156
                        2019-12-05 19:14:05.188  - info: sonoff.0 (998) Client [Sonoff Steckdose WZ Scenty] reconnected. Old secret 1575409602475_9570. New secret 1575569645187_1365
                        2019-12-05 19:14:05.266  - warn: sonoff.0 (998) Old client Sonoff Aussensensor with secret 1575409602695_2905 sends pingreq. Ignore! Actual secret is 1575569644012_156
                        2019-12-05 19:14:05.318  - warn: sonoff.0 (998) Old client Licht Terrasse with secret 1575409602650_548 sends pingreq. Ignore! Actual secret is 1575569643568_1628
                        2019-12-05 19:14:06.394  - warn: sonoff.0 (998) Old client Sonoff Steckdose WZ Scenty with secret 1575409602475_9570 sends pingreq. Ignore! Actual secret is 1575569645187_1365
                        2019-12-05 19:14:07.841  - info: sonoff.0 (998) Client [Sonoff Heizung Schlafzimmer] reconnected. Old secret 1575409602064_7049. New secret 1575569647840_5609
                        2019-12-05 19:14:10.181  - info: sonoff.0 (998) Client [Sonoff FBH Vorraum] reconnected. Old secret 1575409602550_5998. New secret 1575569650180_7538
                        2019-12-05 19:14:16.555  - warn: sonoff.0 (998) Old client Sonoff FBH Vorraum with secret 1575409602550_5998 sends publish. Ignore! Actual secret is 1575569650180_7538
                        2019-12-05 19:14:16.573  - warn: sonoff.0 (998) Old client Sonoff FBH Vorraum with secret 1575409602550_5998 sends publish. Ignore! Actual secret is 1575569650180_7538
                        2019-12-05 19:14:16.574  - warn: sonoff.0 (998) Old client Sonoff FBH Vorraum with secret 1575409602550_5998 sends publish. Ignore! Actual secret is 1575569650180_7538
                        2019-12-05 19:14:16.575  - warn: sonoff.0 (998) Old client Sonoff FBH Vorraum with secret 1575409602550_5998 sends publish. Ignore! Actual secret is 1575569650180_7538
                        2019-12-05 19:14:16.575  - warn: sonoff.0 (998) Old client Sonoff FBH Vorraum with secret 1575409602550_5998 sends pingreq. Ignore! Actual secret is 1575569650180_7538
                        2019-12-05 19:14:16.576  - warn: sonoff.0 (998) Old client Sonoff FBH Vorraum with secret 1575409602550_5998 sends publish. Ignore! Actual secret is 1575569650180_7538
                        2019-12-05 19:14:16.577  - warn: sonoff.0 (998) Old client Sonoff FBH Vorraum with secret 1575409602550_5998 sends publish. Ignore! Actual secret is 1575569650180_7538
                        2019-12-05 19:14:16.578  - warn: sonoff.0 (998) Old client Sonoff FBH Vorraum with secret 1575409602550_5998 sends publish. Ignore! Actual secret is 1575569650180_7538
                        2019-12-05 19:14:16.583  - warn: sonoff.0 (998) Old client Sonoff FBH Vorraum with secret 1575409602550_5998 sends publish. Ignore! Actual secret is 1575569650180_7538
                        2019-12-05 19:14:16.584  - warn: sonoff.0 (998) Old client Sonoff FBH Vorraum with secret 1575409602550_5998 sends publish. Ignore! Actual secret is 1575569650180_7538
                        2019-12-05 19:14:25.615  - info: mihome.0 (6136) Change connection status: true
                        2019-12-05 19:15:17.801  - warn: sonoff.0 (998) Old client Sonoff Licht Vorraum with secret 1575409602183_8581 sends pingreq. Ignore! Actual secret is 1575569637715_6976
                        2019-12-05 19:15:18.165  - warn: sonoff.0 (998) Old client Waschmaschine with secret 1575409601993_8657 sends pingreq. Ignore! Actual secret is 1575569638174_7142
                        2019-12-05 19:15:20.257  - warn: sonoff.0 (998) Old client Sonoff Licht Couch with secret 1575409602508_9221 sends pingreq. Ignore! Actual secret is 1575569637907_7905
                        2019-12-05 19:15:22.571  - warn: sonoff.0 (998) Old client Sonoff_4ch with secret 1575409602267_7623 sends pingreq. Ignore! Actual secret is 1575569639238_225
                        2019-12-05 19:15:22.728  - info: web.0 (1048) <==Disconnect system.user.admin from ::ffff:192.168.1.103 vis.0
                        2019-12-05 19:15:23.215  - warn: sonoff.0 (998) Old client Sonoff_Weihnachten_2 with secret 1575409602338_9028 sends pingreq. Ignore! Actual secret is 1575569639856_5188
                        2019-12-05 19:15:23.217  - warn: sonoff.0 (998) Old client Sonoff_Weihnachten_2 with secret 1575409602338_9028 sends publish. Ignore! Actual secret is 1575569639856_5188
                        2019-12-05 19:15:23.500  - warn: sonoff.0 (998) Old client Sonoff_Weihnachten_3 with secret 1575409602194_7089 sends pingreq. Ignore! Actual secret is 1575569640626_5481
                        2019-12-05 19:15:24.436  - warn: sonoff.0 (998) Old client Shelly1_Nebenraum_LedLicht with secret 1575409602540_5253 sends pingreq. Ignore! Actual secret is 1575569641472_3316
                        2019-12-05 19:15:24.437  - warn: sonoff.0 (998) Old client Shelly1_Nebenraum_LedLicht with secret 1575409602540_5253 sends publish. Ignore! Actual secret is 1575569641472_3316
                        2019-12-05 19:15:24.438  - warn: sonoff.0 (998) Old client Shelly1_Nebenraum_LedLicht with secret 1575409602540_5253 sends publish. Ignore! Actual secret is 1575569641472_3316
                        2019-12-05 19:15:26.701  - warn: sonoff.0 (998) Old client H801_Essplatz with secret 1575409602231_6629 sends pingreq. Ignore! Actual secret is 1575569643952_7125
                        2019-12-05 19:15:26.702  - warn: sonoff.0 (998) Old client H801_Essplatz with secret 1575409602231_6629 sends publish. Ignore! Actual secret is 1575569643952_7125
                        2019-12-05 19:15:31.452  - warn: sonoff.0 (998) Old client Sonoff Heizung Schlafzimmer with secret 1575409602064_7049 sends pingreq. Ignore! Actual secret is 1575569647840_5609
                          apollon77 @MesserMike last edited by
                          @MesserMike diese delete Meldungen einfach ignorieren. !! Die kommen wenn die Sprachaufnahmen bei Amazon gelöscht werden. Die nächste Version ignoriert die einfach. Das ist es nicht und es sollte dann auch nichts anderes spinnen - zumindestens hat das damit dann nichts zu tun!!
                          • MesserMike
                            @apollon77
                            Danke für die Info.
                            Dann such ich jetzt mal den Sonoff Fehler 😉
                            Backup schon in den alten Rechner hochgeladen und updated nun mal laaaangsam..
                            Schau ma...
                            DANKE FÜR INFOS !!!
                            alexa
                            799
