    4. Test Adapter TrashSchedule
      Termina @darkiop last edited by
      @darkiop sagte in Test Adapter TrashSchedule v0.0.x:
      Falls es hier jemand braucht, habe auf die schnelle mal ein Blockly für eine json-Tabelle mit den DPs erstellt:
       <block xmlns="http://www.w3.org/1999/xhtml" type="schedule" id="zH:a+Y|{4CrduNF1VUTG" x="-387" y="13">
        <field name="SCHEDULE">{"time":{"exactTime":true,"start":"00:05"},"period":{"days":1}}</field>
          <block type="control_ex" id="$7jAIT_mnpzNLP]~NJy{">
            <value name="OID">
              <shadow type="field_oid" id="sbu^)eqpdG=koC2q;ZDd">
                <field name="oid">Object ID</field>
              <block type="text" id="2Jn.QUiZj?ycCTjRK_W(">
                <field name="TEXT">javascript.0.VIS.Kalender_Tabelle_Muell</field>
              <shadow type="logic_boolean" id="C3xZGWbRz.8%NyHztTAC">
              <block type="convert_object2json" id="pu+4RS*`r:#QRXX(d|1I">
                <field name="PRETTIFY">FALSE</field>
                  <block type="lists_create_with" id="ZdEEwT){@[oWz7}6T|:6">
                    <mutation items="4"></mutation>
                    <value name="ADD0">
                      <block type="lists_create_with" id="$UUL3})|H~26WlgPAR}}">
                        <value name="ADD0">
                          <block type="text" id="69`+m2b?ah727]cb4b5m">
                            <field name="TEXT">Bio</field>
                        <value name="ADD1">
                          <block type="text_join" id="ErQ7M!ikghZ`#n9pZRgZ">
                            <value name="ADD0">
                              <block type="get_value_var" id="Mu|`W9bXFB;_0SX!nvgu">
                                <value name="OID">
                                  <shadow type="text" id="P#+:y_a5je5/#)4SO^L~">
                                    <field name="TEXT">trashschedule.0.type.Bio.daysleft</field>
                        <value name="ADD2">
                          <block type="text_join" id=".5ka+V$wB[[i4LiF3Dch">
                            <value name="ADD0">
                              <block type="get_value_var" id="w)`88fd-tS~uSu$)4=N%">
                                <value name="OID">
                                  <shadow type="text" id="puB=e5tWv:s95)2|m63d">
                                    <field name="TEXT">trashschedule.0.type.Bio.nextdateformat</field>
                    <value name="ADD1">
                      <block type="lists_create_with" id="z-XsI{)vm#5U/X{jxJhJ">
                        <value name="ADD0">
                          <block type="text" id="w`QASfUph?E*g6}`1K?B">
                            <field name="TEXT">Papier</field>
                        <value name="ADD1">
                          <block type="text_join" id="QI#7R02;o6yhi)k*GUWH">
                            <value name="ADD0">
                              <block type="get_value_var" id="d%;U*%+S^(/j-C(|f3_6">
                                <value name="OID">
                                  <shadow type="text" id="g}Fhsd_#kL-;`ckEn|E$">
                                    <field name="TEXT">trashschedule.0.type.Papier.daysleft</field>
                        <value name="ADD2">
                          <block type="text_join" id="]qySTY/w/@JC$^$1T;{G">
                            <value name="ADD0">
                              <block type="get_value_var" id="0){KH+1P@u-*9.*ptmtw">
                                <value name="OID">
                                  <shadow type="text" id="I/GJo^!Mp+AJ3=])tG{u">
                                    <field name="TEXT">trashschedule.0.type.Papier.nextdateformat</field>
                    <value name="ADD2">
                      <block type="lists_create_with" id="`.xF_srwKF%7{ISkZ9SS">
                        <value name="ADD0">
                          <block type="text" id="x%CaEm(Er0k@RdJmwY6|">
                            <field name="TEXT">Glas</field>
                        <value name="ADD1">
                          <block type="text_join" id="p}a2rlQ,oC%-6POTT1.n">
                            <value name="ADD0">
                              <block type="get_value_var" id="WMBSm@,}P(h-*tsb2dmG">
                                <value name="OID">
                                  <shadow type="text" id="+2IANn@_+1Bu_a97kr/P">
                                    <field name="TEXT">trashschedule.0.type.Glas.daysleft</field>
                        <value name="ADD2">
                          <block type="text_join" id="27btsxWYG5;!kT^ypS(w">
                            <value name="ADD0">
                              <block type="get_value_var" id="TXLvr-L9O$^^#IgE7r8/">
                                <value name="OID">
                                  <shadow type="text" id="5RS-i8]2v|k98c(IL4jg">
                                    <field name="TEXT">trashschedule.0.type.Glas.nextdateformat</field>
                    <value name="ADD3">
                      <block type="lists_create_with" id="T;;$gR}hB|ZO{5bqJK6C">
                        <value name="ADD0">
                          <block type="text" id="JW[g,${io?zI03+bo_dO">
                            <field name="TEXT">GelberSack</field>
                        <value name="ADD1">
                          <block type="text_join" id="QrX3i+Vd?s2f](@F!Ie,">
                            <value name="ADD0">
                              <block type="get_value_var" id="^Oe/%|U|fQkkLsicq87|">
                                <value name="OID">
                                  <shadow type="text" id="+{@)/]CLs+Rj{SCJaBI{">
                                    <field name="TEXT">trashschedule.0.type.GelberSack.daysleft</field>
                        <value name="ADD2">
                          <block type="text_join" id="kN@MK8x6Td!$z~Z0lQ|g">
                            <value name="ADD0">
                              <block type="get_value_var" id="F}3W/b(.](8I.VC=5jzy">
                                <value name="OID">
                                  <shadow type="text" id="SKqQ1Wjl;z7^4z_o{Nyz">
                                    <field name="TEXT">trashschedule.0.type.GelberSack.nextdateformat</field>
            <value name="DELAY_MS">
              <shadow type="math_number" id="T#OSxS{}/L9EbZB6%*;i">
                <field name="NUM">0</field>
      Sry, ich meinte diese Tabelle
      D ? 2 Replies Last reply Reply Quote 0
      • SBorg
        SBorg Forum Testing Most Active @Homoran last edited by
        @Homoran sagte in Test Adapter TrashSchedule v0.0.x:
        "in 1 Tagen" hat mein Feng Shui gestört
        IMHO noch besseres Feng Shui: HTML-Widget + Binding = mach aus in 1 Tag am 05.12.3019 einfach Morgen
        Homoran 1 Reply Last reply Reply Quote 2
          Homoran Global Moderator Administrators @SBorg last edited by
          @SBorg sagte in Test Adapter TrashSchedule v0.0.x:
          und wie???
          Auch wenn alle denken ich sei Profi - bin nur ein (etwas aktiver) User
          • SBorg
            SBorg Forum Testing Most Active @Homoran last edited by SBorg
            {tage:trashschedule.0.type.Biotonne.daysleft;datum:trashschedule.0.type.Biotonne.nextdateformat; tage != 1 ? "in "+tage+" Tagen am "+datum :: "<div style='color: yellow'>Morgen</div>"}
            Musst natürlich noch den Datenpunkt anpassen. Auch mal zur Demo "Morgen" in gelb gefärbt.
            ...und vertippt bei meinem Post. Im Jahr 3019 brauch ich bestimmt keinerlei Feng Shui mehr 🙂
            Homoran liv-in-sky 2 Replies Last reply Reply Quote 0
              Hatte ich stillschweigend akzeptiert 😉
              und Danke für das Binding
                liv-in-sky @SBorg last edited by
                @SBorg danke für das binding
                hast du nicht mal lust, einen thread mit deinen binding beispielen zu machen - so in der art - oder gibt es das schon
                https://forum.iobroker.net/topic/24179/vorlage-hilfreiche-javascript-funktionen
                ps: iobroker läuft ewig - noch die ur-ur-ur-... enkel werden es nutzen 🙂 - also immer auf das feng shui achten !
                  Homoran Global Moderator Administrators @liv-in-sky last edited by
                  @liv-in-sky sagte in Test Adapter TrashSchedule v0.0.x:
                  @SBorg
                  oder ein Tutorial für die Website.
                  Büddä!
                  • SBorg
                    Die liebe Zeit...
                    Ich stecke gerade in so vielen (eigenen) Projekten fest, dazu noch kpl. Renovierung Badezimmer (natürlich smart).
                    Dann kam ich auf die Idee nur noch eine Tonne (als Übersicht zur nächsten Leerung) zu nehmen und die per Binding zu färben...
                    Klar, könnte man auch alle übereinander legen und per "Sichtbarkeit" regeln, wo bleibt aber dann der Spaß/die Herausforderung? 😀
                      Frust!!!
                      Natürlich habe ich sie übereinandergelegt.
                      Dafür bastel ich gerade an einem Icon als Button um es wieder verschwinden zu lassen wenn man draufklickt, nachdem die Tonne an die Straße gestellt wurde.
                        darkiop Most Active @Termina last edited by
                        @Termina
                        view (du brauchst aber uhlas material design)
                         "settings": {
                           "style": {
                             "background_class": ""
                           "theme": "redmond",
                           "sizex": "",
                           "sizey": "",
                           "gridSize": "10",
                           "useAsDefault": false,
                           "snapType": 2,
                           "class": "",
                           "useBackground": false
                         "widgets": {
                           "e00001": {
                             "tpl": "tplHtml",
                             "data": {
                               "g_fixed": true,
                               "g_visibility": false,
                               "g_css_font_text": true,
                               "g_css_background": false,
                               "g_css_shadow_padding": false,
                               "g_css_border": false,
                               "g_gestures": false,
                               "g_signals": false,
                               "visibility-cond": "==",
                               "visibility-val": 1,
                               "visibility-groups-action": "hide",
                               "refreshInterval": "0",
                               "signals-cond-0": "==",
                               "signals-val-0": true,
                               "signals-icon-0": "/vis.0/material-temp/lowbattery.png",
                               "signals-icon-size-0": 0,
                               "signals-blink-0": false,
                               "signals-horz-0": 0,
                               "signals-vert-0": 0,
                               "signals-hide-edit-0": false,
                               "signals-cond-1": "==",
                               "signals-val-1": true,
                               "signals-icon-1": "/vis.0/material-temp/lowbattery.png",
                               "signals-icon-size-1": 0,
                               "signals-blink-1": false,
                               "signals-horz-1": 0,
                               "signals-vert-1": 0,
                               "signals-hide-edit-1": false,
                               "signals-cond-2": "==",
                               "signals-val-2": true,
                               "signals-icon-2": "/vis.0/material-temp/lowbattery.png",
                               "signals-icon-size-2": 0,
                               "signals-blink-2": false,
                               "signals-horz-2": 0,
                               "signals-vert-2": 0,
                               "signals-hide-edit-2": false,
                               "html": "",
                               "class": "mdui-abar mdui-bluegrey-bg",
                               "lc-type": "last-change",
                               "lc-is-interval": true,
                               "lc-is-moment": false,
                               "lc-format": "",
                               "lc-position-vert": "top",
                               "lc-position-horz": "right",
                               "lc-offset-vert": 0,
                               "lc-offset-horz": 0,
                               "lc-font-size": "12px",
                               "lc-font-family": "",
                               "lc-font-style": "",
                               "lc-bkg-color": "",
                               "lc-color": "",
                               "lc-border-width": "0",
                               "lc-border-style": "",
                               "lc-border-color": "",
                               "lc-border-radius": 10,
                               "lc-zindex": 0,
                               "comment": "",
                               "name": "app-bar"
                             "style": {
                               "left": "0px",
                               "top": "0px",
                               "width": "100%",
                               "height": "50px",
                               "z-index": "0",
                               "color": "#ffffff",
                               "text-align": "center",
                               "font-family": "RobotoCondensed-Light"
                             "widgetSet": "basic"
                           "e00002": {
                             "tpl": "tplImage",
                             "data": {
                               "g_fixed": false,
                               "g_css_font_text": false,
                               "g_signals": false,
                               "g_last_change": false,
                               "signals-icon-0": "/vis/signals/lowbattery.png",
                               "signals-icon-1": "/vis/signals/lowbattery.png",
                               "signals-icon-2": "/vis/signals/lowbattery.png",
                               "lc-format": "",
                               "lc-bkg-color": "",
                               "lc-color": "",
                               "lc-zindex": 0,
                               "src": "/icons-mfd-png/message_garbage_3.png"
                             "style": {
                               "left": "0",
                               "top": "0",
                               "width": "50px",
                               "height": "50px",
                           "e00003": {
                             "tpl": "tplHtml",
                             "data": {
                               "g_fixed": true,
                               "g_signals": false,
                               "html": "Müllkalender",
                               "class": "mdui-title",
                               "lc-format": "",
                               "lc-bkg-color": "",
                               "lc-color": "",
                               "lc-zindex": 0
                             "style": {
                               "left": "calc(0% + 50px)",
                               "top": "14px",
                               "width": "160px",
                               "height": "23px",
                               "z-index": 1,
                           "e00004": {
                             "tpl": "tplJquiButtonLinkBlank",
                             "data": {
                               "g_fixed": true,
                               "g_visibility": true,
                               "g_signals": false,
                               "visibility-val": "true",
                               "buttontext": "EDIT",
                               "padding": "0",
                               "lc-format": "",
                               "lc-bkg-color": "",
                               "lc-color": "",
                               "lc-zindex": 0,
                               "href": "http://iobroker-master.birkenweg.walk-steinweiler.de:8082/vis/edit.html?material-temp#{view}",
                               "no_style": false,
                               "class": "mdui-flatbutton",
                               "visibility-oid": "javascript.0.VIS.Edit_Mode"
                             "style": {
                               "left": "calc(100% - 80px)",
                               "top": "10px",
                               "width": "auto",
                               "height": "30px"
                             "widgetSet": "jqui"
                           "e00005": {
                             "tpl": "tplVis-materialdesign-Table",
                             "data": {
                               "oid": "javascript.0.VIS.Kalender_Tabelle_Muell",
                               "g_fixed": false,
                               "g_signals": false,
                               "countCols": "2",
                               "tableLayout": "standard",
                               "showHeader": "true",
                               "headerTextSize": "16px",
                               "showColumn0": "true",
                               "colType0": "text",
                               "textAlign0": "right",
                               "showColumn1": "true",
                               "colType1": "text",
                               "textAlign1": "center",
                               "lc-format": "",
                               "lc-bkg-color": "",
                               "lc-color": "",
                               "lc-zindex": 0,
                               "showColumn2": "true",
                               "colType2": "text",
                               "textAlign2": "center",
                               "showColumn3": "true",
                               "colType3": "text",
                               "textAlign3": "center",
                               "showColumn4": "true",
                               "colType4": "text",
                               "textAlign4": "center",
                               "showColumn5": "true",
                               "colType5": "text",
                               "textAlign5": "center",
                               "label0": " ",
                               "label1": "Nächste Leerung<br><em style=\"font-size: 14px\">(in Tagen)</em>",
                               "label2": "Nächste Leerung",
                               "colorBackground": "transparent",
                               "fontFamily0": "RobotoCondensed-Light",
                               "fontFamily1": "RobotoCondensed-Light",
                               "fontFamily2": "RobotoCondensed-Light",
                               "colTextColor2": "#ffffff",
                               "colTextColor1": "#ffffff",
                               "colTextColor0": "#ffffff",
                               "colorHeaderRowText": "#ffffff",
                               "headerFontFamily": "RobotoCondensed-Bold",
                               "colTextSize0": "16px",
                               "colTextSize1": "16px",
                               "colTextSize2": "16px",
                               "colNoWrap0": false,
                               "dividers": "transparent",
                               "columnWidth0": "100"
                             "style": {
                               "left": "10px",
                               "top": "60px",
                               "width": "calc(100% - 20px)",
                               "height": "calc(100% - 90px)"
                             "widgetSet": "materialdesign"
                         "name": "3_card_Kalender_Muell_new",
                         "filterList": []
                          ktsalti last edited by
                          Guten Abend,
                          ich möchte mich auch für den Adapter bedanken!! Habe damit jetzt auch mein altes Script deaktiviert und gleichzeitig eure Widgets mit eingebaut!! 🙂
                          Vielen Dank!
                          ktsalti
                          • Bostil
                            Bostil @darkiop last edited by Bostil
                            hier stand Stuss -> kann gelöscht werden
                              Sempre last edited by Sempre
                              @haus-automatisierung
                              Vielen Dank für den Adapter, ich habe diesen nun auch in Betrieb genommen, aber leider scheint bei mir noch nicht allles zu passen. Ich habe keine aktuellen Werte für Gelbe Tonne, obwohl diese als nächstes Event erkannt wird. Die nächste Leerung wäre diesen Freitag, aber wie gesagt unter den Typen-Objekten wird nichts angezeigt.
                              Zusätzlich fehlen mir noch die Werte für den Restmüll, hier habe ich absolut nichts an Daten. Wie weit schaut der Adapter denn in die Zukunft? Ich könnte mir vorstellen, das hier einfach der nächste Wert zu weit in der Zukunft ist, denn die nächste Leerung wäre am 14.1.2020
                              Edit: Ok hat sich erledigt, nun sind alle Daten da, warum auch immer das so ewig gedauert hat. Ein Teil der Daten war sofort da, der andere hat 10-15 Minuten gedauert.
                              • Chaot
                                Chaot @Sempre last edited by
                                @Sempre Das kannst du im ical - Adapter einstellen.
                                Dort hast du die Vorschau normalerweise auf 7 Tage stehen. Wenn du dort 60 oder 90 einträgst werden auch sehr späte Termine noch richtig erfasst.
                                  @Chaot
                                  Hallo
                                  ich habe mir über google nun einen Kalendar angelegt und über
                                  npm i iobroker.trashschedule
                                  installiert. Aktuell taucht leider das Objekt bei mir noch nicht auf.
                                  Was könnte ich übersehen haben?
                                    Sempre @Chaot last edited by
                                    @Chaot
                                    dort habe ich 30 Tage drin, daher soltle es passen. Es hat nach einer Weile ja nun auch alle Datenpuntke angelegt, war nur verwundert warum es so ewig gedauert hat. Eine Vermutung war dann das der Adapter selber eventuell noch eine Zeitbegrenzung hat, aber passt ja 🙂
                                    • Chaot
                                      Chaot @Guest last edited by
                                      @HeinrichB Der ical Adapter kommuniziert bei mir mit dem Google Kalender. Dort sind die Termine recht schnell hinterlegt und mit mehreren Kalendern kann man auch im ioBroker mehrfach den iCal laufen lassen
                                      Geburtstag
                                      Müll
                                      Termine
                                      @Sempre Ja, das ist bei mir auch manchmal das der Adapter recht lange braucht um Daten zu holen. Und manchmal passiert das binnen Sekunden.
                                      Warum das so ist habe ich aber noch nicht herausgefunden.
                                        A Former User @Chaot last edited by A Former User
                                        @Chaot
                                        Danke Dir. Ich habe den Kalendar mit ein paar Terminen angelegt.
                                        Dann den Adapter mit
                                        installiert.
                                        Leider taucht er bei nicht als Instanz auf. Was könnte ich übersehen haben?
                                        • Chaot
                                          @HeinrichB Du musst noch eine Instanz hinzufügen.
                                          Es scheint das du den erst "nur" installiert hast.
                                          Warum installierst du den eigentlich so? Geht doch über den ioBroker viel komfortabler finde ich.
                                            @Chaot hätte ich gern gemacht und mache ich sonst immer so. Nur taucht er bei mir in der Liste der Adapter nicht auf. 🤔
                                            adapter calendar ical kalender müll trash
                                            185
                                            1434
                                            484579
