    • JB_Sullivan
      JB_Sullivan @sigi234 last edited by Negalein
      @sigi234
      Ich vermute mal, das der Restore so, wie unter Linux unter Windows nicht funktioniert. ioB ist wieder eingefroren. Es werden scheinbar nur die vier Adapter die nach einer Neuinstallation vorhanden sind aus dem Backup restored, was dann scheinbar unter Windows zum Kollaps des Systems führt.
      [DEBUG] [minimal] iobroker controller daemon is not running
      [DEBUG] [minimal] host.GLT(GLT) OK.
      [DEBUG] [minimal] host.GLT(GLT) Clear all objects and states...
      [DEBUG] [minimal] clean 349 objects...
      [ERROR] [minimal] [Not critical] Cannot delete object 0_userdata.0: "Object is marked as non deletable"
      [ERROR] [minimal] [Not critical] Cannot delete object alias.0: "Object is marked as non deletable"
      [ERROR] [minimal] [Not critical] Cannot delete object system.repositories: "Object is marked as non deletable"
      [ERROR] [minimal] [Not critical] Cannot delete object system.config: "Object is marked as non deletable"
      [ERROR] [minimal] [Not critical] Cannot delete object enum.functions: "Object is marked as non deletable"
      [ERROR] [minimal] [Not critical] Cannot delete object enum.rooms: "Object is marked as non deletable"
      [DEBUG] [minimal] clean 269 states...
      [DEBUG] [minimal] host.GLT(GLT) done.
      [DEBUG] [minimal] host.GLT(GLT) Processed 0/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 200/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 400/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 600/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 800/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 1000/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 1200/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 1400/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 1600/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 1800/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 2000/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 2200/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 2400/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 2600/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 2800/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 3000/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 3200/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 3400/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 3600/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 3800/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 4000/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 4200/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 4400/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 4600/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 4800/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 5000/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 5200/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 5400/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 5600/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 5800/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 6000/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 6200/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 6400/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 6600/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 6800/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 7000/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 7200/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 7400/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 7600/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 7800/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 8000/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 8200/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 8400/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 8600/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 8800/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 9000/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 9200/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 9400/9641 states
      [DEBUG] [minimal] host.GLT(GLT) Processed 9600/9641 states
      [DEBUG] [minimal] 9641 states restored.
      [DEBUG] [minimal] host.GLT(GLT) Processed 0/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 200/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 400/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 600/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 800/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 1000/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 1200/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 1400/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 1600/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 1800/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 2000/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 2200/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 2400/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 2600/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 2800/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 3000/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 3200/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 3400/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 3600/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 3800/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 4000/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 4200/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 4400/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 4600/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 4800/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 5000/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 5200/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 5400/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 5600/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 5800/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 6000/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 6200/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 6400/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 6600/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 6800/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 7000/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 7200/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 7400/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 7600/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 7800/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 8000/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 8200/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 8400/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 8600/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 8800/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 9000/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 9200/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 9400/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 9600/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 9800/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 10000/10346 objects
      [DEBUG] [minimal] host.GLT(GLT) Processed 10200/10346 objects
      [DEBUG] [minimal] 10346 objects restored.
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis/css/vis-common-user.css
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/Abfall/blaue_tonne.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/Abfall/gelbe_tonne.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/Abfall/schwarze_tonne.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/Abfall/tonne_grün.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/Mondimages/0.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/Mondimages/1.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/Mondimages/2.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/Mondimages/3.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/Mondimages/4.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/Mondimages/5.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/Mondimages/6.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/Mondimages/7.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/1.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/10.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/11.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/12.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/13.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/14.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/15.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/16.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/17.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/18.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/19.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/2.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/3.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/4.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/5.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/6.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/7.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/8.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/9.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/windrose/g_rose000.gif
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/windrose/images 2.gif
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/Heizung/drei-wge-ventil.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/Heizung/Fussbodenheizung trans.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/Heizung/Pumpe bottom.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/Heizung/Pumpe left.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/Heizung/Pumpe right.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/Heizung/Pumpe top.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/Heizung/Radiator trans.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/Heizung/Solarplatten trans.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/Heizung/Warmwasser trans.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/Heizung/Wärmetauscher Solar.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/Heizung/Wärmetauscher Wasser.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/1.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/11a.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/2.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/3.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/3dprinter.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/4.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/5.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/6.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/617a.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/820a.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/871a.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/achtung.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/alexa.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/audio_ff.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/audio_pause.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/audio_play.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/audio_repeat.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/audio_rew.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/audio_shuffle.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/audio_volume_high.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/audio_volume_low.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/audio_volume_mute.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/Battery_-01.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/Battery_-02.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/Battery_-03.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/Battery_-04.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/Battery_-05.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/Battery_-06.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/Battery_-07.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/behaelter.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/cam.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/control_arrow_down.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/control_arrow_downward.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/control_building_control.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/control_building_empty.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/control_building_modern_s_2og_all.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/control_building_s_okg_eg.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/control_building_s_okg_int_all.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/control_building_s_okg_og.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/control_cancel.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/eisregen.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/ElliOil.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/frau.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/fts_door.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/fts_door_open.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/fts_door_tilt.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/fts_window_1w.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/fts_window_1w_open.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/gabionenzaun1.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/garden.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/garderobe.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/icons8-garage-geschlossen-80.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/icons8-garage-offen-80.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/icons8-stehende-frau-128.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/icons8-stehender-mann-128.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/ic_add_circle_outline_white_48dp.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/ic_local_gas_station_white_48dp.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/ic_remove_circle_outline_white_48dp.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/images 2.gif
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/it_fax.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/it_nas.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/it_net.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/it_radio.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/it_remote.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/it_telephone.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/it_television.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/kugaicon.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/light_ball.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/light_dinner_table.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/light_floor_lamp.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/light_kitchen_hood.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/light_led_stripe.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/light_light_dim_00.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/light_stairs.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/lowbattery.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/mann.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/markise.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/measure_battery_0.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/measure_battery_100.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/measure_battery_100.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/measure_battery_25.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/measure_battery_25.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/measure_battery_50.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/measure_battery_75.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/measure_photovoltaic_inst.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/measure_photovoltaic_inst.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/noun_socket_1135198.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/power.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/Power_socket_icon.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/raspberry.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/roomba.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/roomba312.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/roombagfx.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/Rund_graph_user8.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/Rund_Haus_user8.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/Rund_holiday_user8.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/Rund_Variable_user8.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/sani_cogeneration.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/sani_heating.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/sani_heating.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/scene_aquarium.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/scene_bath.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/scene_childs_room.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/scene_cinema.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/scene_garden.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/scene_kitchen_sink.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/scene_living.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/scene_livingroom.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/scene_pool.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/scene_sleeping_alternat.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/scene_summerhouse.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/schreibtischlampe.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/socket.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/sos.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/spotify.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/status_woman.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/steckdose.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/Steckdose.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/strom.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/suncloud.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/temp_temperature.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/temp_temperature_max.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/temp_temperature_min.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/temp_windchill.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/text_max.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/text_min.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/time_automatic.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/time_manual_mode.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/Tradfri Fernbedienung.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/trash.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/tuerklingel.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/wall-e.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/waterfall.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/weather_barometric_pressure.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/weather_cloudy.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/weather_cloudy_light.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/weather_frost.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/weather_humidity.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/weather_rain.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/weather_sunrise.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/weather_wind_directions_e.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/weather_wind_speed.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/icons/weather_wind_speed_bft.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/Pool/Filter.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/Pool/Heizung.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/Pool/Pool.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/Pool/Pumpe.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/Pool/Rohr_horizontal.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/Pool/Rohr_vertikal.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/Pool/Schieber_horizontal.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/Pool/Schieber_vertikal.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/Pool/T-Stueck_links.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/Pool/T-Stueck_oben.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/Pool/T-Stueck_rechts.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/Pool/T-Stueck_unten.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/Pool/Winkel_oben_links.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/Pool/Winkel_oben_rechts.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/Pool/Winkel_unten_links.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/Pool/Winkel_unten_rechts.svg
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/vis-views.json
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/wetter/1.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/wetter/10.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/wetter/11.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/wetter/12.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/wetter/13.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/wetter/14.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/wetter/15.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/wetter/16.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/wetter/17.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/wetter/18.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/wetter/19.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/wetter/2.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/wetter/20.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/wetter/21.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/wetter/22.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/wetter/3.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/wetter/4.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/wetter/5.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/wetter/6.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/wetter/7.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/wetter/8.png
      [DEBUG] [minimal] host.GLT(GLT) Upload user file "vis.0/main/wetter/9.png
      [DEBUG] [minimal] upload [3] admin.admin C:/iobroker/GLT/node_modules/iobroker.admin/admin/words.js words.js application/javascript
      [DEBUG] [minimal] upload [2] admin.admin C:/iobroker/GLT/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
      [DEBUG] [minimal] upload [1] admin.admin C:/iobroker/GLT/node_modules/iobroker.admin/admin/index.html index.html text/html
      [DEBUG] [minimal] upload [0] admin.admin C:/iobroker/GLT/node_modules/iobroker.admin/admin/admin.png admin.png image/png
      [DEBUG] [minimal] upload [3] backitup.admin C:/iobroker/GLT/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
      [DEBUG] [minimal] upload [2] backitup.admin C:/iobroker/GLT/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
      [DEBUG] [minimal] upload [1] backitup.admin C:/iobroker/GLT/node_modules/iobroker.backitup/admin/index.html index.html text/html
      [DEBUG] [minimal] upload [0] backitup.admin C:/iobroker/GLT/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
      [DEBUG] [minimal] upload [5] discovery.admin C:/iobroker/GLT/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
      [DEBUG] [minimal] upload [4] discovery.admin C:/iobroker/GLT/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
      [DEBUG] [minimal] upload [3] discovery.admin C:/iobroker/GLT/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
      [DEBUG] [minimal] upload [2] discovery.admin C:/iobroker/GLT/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
      [DEBUG] [minimal] upload [1] discovery.admin C:/iobroker/GLT/node_modules/iobroker.discovery/admin/index.html index.html text/html
      [DEBUG] [minimal] upload [0] discovery.admin C:/iobroker/GLT/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
      [DEBUG] [minimal] upload [80] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/words.js words.js application/javascript
      [DEBUG] [minimal] upload [70] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/js/hostInfo.js lib/js/hostInfo.js application/javascript
      [DEBUG] [minimal] upload [60] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/js/bootstrap.min.js lib/js/bootstrap.min.js application/javascript
      [DEBUG] [minimal] upload [50] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/img/logos/slackware.png lib/img/logos/slackware.png image/png
      [DEBUG] [minimal] upload [40] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/img/logos/manjaro.png lib/img/logos/manjaro.png image/png
      [DEBUG] [minimal] upload [30] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/img/logos/coreos.png lib/img/logos/coreos.png image/png
      [DEBUG] [minimal] upload [20] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/img/icons/disk.png lib/img/icons/disk.png image/png
      [DEBUG] [minimal] upload [19] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/img/icons/cpu.png lib/img/icons/cpu.png image/png
      [DEBUG] [minimal] upload [18] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/img/icons/battery.png lib/img/icons/battery.png image/png
      [DEBUG] [minimal] upload [17] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/img/clock/sechand.png lib/img/clock/sechand.png image/png
      [DEBUG] [minimal] upload [16] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/img/clock/minhand.png lib/img/clock/minhand.png image/png
      [DEBUG] [minimal] upload [15] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/img/clock/hourhand.png lib/img/clock/hourhand.png image/png
      [DEBUG] [minimal] upload [14] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/img/clock/clockface.png lib/img/clock/clockface.png image/png
      [DEBUG] [minimal] upload [13] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/fonts/FontAwesome.otf lib/fonts/FontAwesome.otf font/otf
      [DEBUG] [minimal] upload [12] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff2 lib/fonts/fontawesome-webfont.woff2 font/woff2
      [DEBUG] [minimal] upload [11] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff lib/fonts/fontawesome-webfont.woff font/woff
      [DEBUG] [minimal] upload [10] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.ttf lib/fonts/fontawesome-webfont.ttf font/ttf
      [DEBUG] [minimal] upload [9] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.svg lib/fonts/fontawesome-webfont.svg image/svg+xml
      [DEBUG] [minimal] upload [8] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.eot lib/fonts/fontawesome-webfont.eot application/vnd.ms-fontobject
      [DEBUG] [minimal] upload [7] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/data/infoData.json lib/data/infoData.json application/json
      [DEBUG] [minimal] upload [6] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/css/simplemde.min.css lib/css/simplemde.min.css text/css
      [DEBUG] [minimal] upload [5] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/css/info.css lib/css/info.css text/css
      [DEBUG] [minimal] upload [4] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/css/font-awesome.min.css lib/css/font-awesome.min.css text/css
      [DEBUG] [minimal] upload [3] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/css/chartist.min.css lib/css/chartist.min.css text/css
      [DEBUG] [minimal] upload [2] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
      [DEBUG] [minimal] upload [1] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/info.png info.png image/png
      [DEBUG] [minimal] upload [0] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/index_m.html index_m.html text/html
      [DEBUG] [minimal] System successfully restored!
      [EXIT] 0
      Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
      Hier gehts zur Hilfe.
      simatec 2 Replies Last reply Reply Quote 0
        sigi234 Forum Testing Most Active @simatec last edited by
        @simatec sagte in Test Adapter Backitup v1.3.x:
        @sigi234
        Installiere mal bitte die Version 1.3.2 von backitup und führe den Restore damit durch
        Da kannst du den Log verfolgen und wir sehen, was passiert
        Danke, will ich ja nicht, bei mir geht ja alles. Ist für @JB_Sullivan
        • simatec
          simatec Developer Most Active @JB_Sullivan last edited by
          @JB_Sullivan
          Der restore ist sauber durchgelaufen.
          Falls iob nicht automatisch starte, öffne die Konsole von iob und starte manuell
          • simatec
            @JB_Sullivan
            Das ist aber nicht backitup 1.3.1
            Da gibt es kein Minimal mehr
            • JB_Sullivan
              JB_Sullivan @simatec last edited by JB_Sullivan
              @simatec
              Das ist ja interessant - also bei mir auf dem Produktiven System ist BackItUp mit 1.3.1 vorhanden und legt Backup Dateien an, welche iobroker am Anfang heißen.
              Auf der neuen Installation - ebenfalls mit BackItUp 1.3.1 - werden diese Backups nicht gefunden. Benenne ich sie in minimal um, werden sie gefunden, darum habe ich die Datei von iobroker _xxxxxx in minimal_xxxxxxx umbenannt.
              simatec Dr. Bakterius 2 Replies Last reply Reply Quote 0
              • simatec
                @JB_Sullivan
                Dann ist dein neues System nicht mit backitup 1.3.1 ausgestattet.
                Installiere mal 1.3.2 vom Github bzw. ab heute nach dann im latest.
                Wenn du eine ältere Version hast, kann der start nach dem Restore unter Windows Probleme machen.
                Wie gesagt, starte iobroker manuell und du siehst in Log den Fortschritt der einzelnen Installationen der Adapter.
                Das kann aber einige Zeit dauern
                • JB_Sullivan
                  @simatec
                  OK, mache ich mal - aber was soll ich sagen - das neue System ist 1.3.1 - wenn auch mit gemecker bei der Installation.
                  backitup.0	2019-12-05 22:45:18.988	error	at processImmediate (timers.js:658:5)
                  backitup.0	2019-12-05 22:45:18.988	error	at tryOnImmediate (timers.js:676:5)
                  backitup.0	2019-12-05 22:45:18.988	error	at runCallback (timers.js:705:18)
                  backitup.0	2019-12-05 22:45:18.988	error	at Immediate.setImmediate (C:\iobroker\GLT\node_modules\iobroker.js-controller\lib\adapter.js:4748:38)
                  backitup.0	2019-12-05 22:45:18.988	error	at Adapter.emit (events.js:198:13)
                  backitup.0	2019-12-05 22:45:18.988	error	at Adapter.adapter.on (C:\iobroker\GLT\node_modules\iobroker.backitup\main.js:58:20)
                  backitup.0	2019-12-05 22:45:18.988	error	(9120) TypeError: Cannot read property 'val' of null
                  backitup.0	2019-12-05 22:45:18.987	error	(9120) uncaught exception: Cannot read property 'val' of null
                  backitup.0	2019-12-05 22:45:18.877	info	(9120) starting. Version 1.3.1 in C:/iobroker/GLT/node_modules/iobroker.backitup, node: v10.17.0
                  • JB_Sullivan
                    Aber bei der Gelegenheit - ganz sauber scheint auch das Upgrade des js-controller nicht zu verlaufen.
                    Obwohl Visual Studio genau an dem angegeben Ort liegt gibt es bei upgrade self - Error Meldungen - aber das nur mal so am Rande.
                    C:\iobroker\GLT>iobroker upgrade self
                    Update js-controller from @2.1.0 to @2.1.1
                    NPM version: 6.11.3
                    npm install iobroker.js-controller@2.1.1 --unsafe-perm --loglevel error --prefix "C:/iobroker/GLT" (System call)
                    gyp ERR! build error
                    gyp ERR! stack Error: `C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe` failed with exit code: 1
                    gyp ERR! stack     at ChildProcess.onExit (C:\iobroker\GLT\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:193:23)
                    gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
                    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                    gyp ERR! System Windows_NT 10.0.18363
                    gyp ERR! command "C:\\iobroker\\GLT\\nodejs\\node.exe" "C:\\iobroker\\GLT\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
                    gyp ERR! cwd C:\iobroker\GLT\node_modules\iobroker.js-controller\node_modules\unix-dgram
                    gyp ERR! node -v v10.17.0
                    gyp ERR! node-gyp -v v5.0.3
                    gyp ERR! not ok
                    Starting node restart.js
                    C:\iobroker\GLT>iobroker start
                    2019-12-05 22:52:32,655 INFO  - Starting the service with id 'iobroker(GLT)'
                    • JB_Sullivan
                      JB_Sullivan last edited by Negalein
                      Also irgendwo ist in der Windows Installation der Wurm drin. Ich habe jetzt BackItUp 1.3.2 drauf. Nun findet er auch die Backupdatei die mit "iobroker_xxxxx" beginnt.
                      Soweit so gut
                      [DEBUG] [iobroker] iobroker controller daemon is not running
                      [DEBUG] [iobroker] host.GLT(GLT) OK.
                      [DEBUG] [iobroker] host.GLT(GLT) Clear all objects and states...
                      [DEBUG] [iobroker] clean 351 objects...
                      [ERROR] [iobroker] [Not critical] Cannot delete object 0_userdata.0: "Object is marked as non deletable"
                      [ERROR] [iobroker] [Not critical] Cannot delete object alias.0: "Object is marked as non deletable"
                      [ERROR] [iobroker] [Not critical] Cannot delete object system.repositories: "Object is marked as non deletable"
                      [ERROR] [iobroker] [Not critical] Cannot delete object system.config: "Object is marked as non deletable"
                      [ERROR] [iobroker] [Not critical] Cannot delete object enum.functions: "Object is marked as non deletable"
                      [ERROR] [iobroker] [Not critical] Cannot delete object enum.rooms: "Object is marked as non deletable"
                      [DEBUG] [iobroker] clean 270 states...
                      [DEBUG] [iobroker] host.GLT(GLT) done.
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 0/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 200/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 400/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 600/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 800/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 1000/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 1200/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 1400/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 1600/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 1800/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 2000/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 2200/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 2400/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 2600/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 2800/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 3000/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 3200/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 3400/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 3600/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 3800/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 4000/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 4200/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 4400/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 4600/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 4800/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 5000/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 5200/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 5400/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 5600/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 5800/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 6000/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 6200/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 6400/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 6600/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 6800/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 7000/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 7200/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 7400/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 7600/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 7800/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 8000/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 8200/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 8400/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 8600/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 8800/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 9000/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 9200/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 9400/9641 states
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 9600/9641 states
                      [DEBUG] [iobroker] 9641 states restored.
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 0/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 200/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 400/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 600/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 800/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 1000/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 1200/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 1400/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 1600/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 1800/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 2000/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 2200/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 2400/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 2600/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 2800/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 3000/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 3200/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 3400/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 3600/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 3800/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 4000/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 4200/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 4400/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 4600/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 4800/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 5000/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 5200/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 5400/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 5600/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 5800/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 6000/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 6200/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 6400/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 6600/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 6800/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 7000/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 7200/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 7400/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 7600/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 7800/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 8000/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 8200/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 8400/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 8600/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 8800/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 9000/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 9200/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 9400/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 9600/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 9800/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 10000/10346 objects
                      [DEBUG] [iobroker] host.GLT(GLT) Processed 10200/10346 objects
                      [DEBUG] [iobroker] 10346 objects restored.
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis/css/vis-common-user.css
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/Abfall/blaue_tonne.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/Abfall/gelbe_tonne.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/Abfall/schwarze_tonne.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/Abfall/tonne_grün.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/Mondimages/0.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/Mondimages/1.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/Mondimages/2.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/Mondimages/3.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/Mondimages/4.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/Mondimages/5.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/Mondimages/6.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/Mondimages/7.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/1.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/10.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/11.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/12.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/13.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/14.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/15.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/16.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/17.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/18.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/19.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/2.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/3.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/4.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/5.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/6.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/7.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/8.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/wetter/9.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/windrose/g_rose000.gif
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/daswetter/icons/windrose/images 2.gif
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/Heizung/drei-wge-ventil.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/Heizung/Fussbodenheizung trans.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/Heizung/Pumpe bottom.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/Heizung/Pumpe left.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/Heizung/Pumpe right.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/Heizung/Pumpe top.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/Heizung/Radiator trans.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/Heizung/Solarplatten trans.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/Heizung/Warmwasser trans.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/Heizung/Wärmetauscher Solar.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/Heizung/Wärmetauscher Wasser.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/1.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/11a.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/2.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/3.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/3dprinter.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/4.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/5.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/6.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/617a.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/820a.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/871a.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/achtung.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/alexa.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/audio_ff.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/audio_pause.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/audio_play.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/audio_repeat.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/audio_rew.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/audio_shuffle.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/audio_volume_high.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/audio_volume_low.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/audio_volume_mute.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/Battery_-01.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/Battery_-02.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/Battery_-03.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/Battery_-04.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/Battery_-05.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/Battery_-06.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/Battery_-07.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/behaelter.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/cam.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/control_arrow_down.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/control_arrow_downward.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/control_building_control.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/control_building_empty.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/control_building_modern_s_2og_all.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/control_building_s_okg_eg.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/control_building_s_okg_int_all.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/control_building_s_okg_og.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/control_cancel.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/eisregen.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/ElliOil.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/frau.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/fts_door.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/fts_door_open.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/fts_door_tilt.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/fts_window_1w.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/fts_window_1w_open.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/gabionenzaun1.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/garden.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/garderobe.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/icons8-garage-geschlossen-80.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/icons8-garage-offen-80.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/icons8-stehende-frau-128.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/icons8-stehender-mann-128.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/ic_add_circle_outline_white_48dp.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/ic_local_gas_station_white_48dp.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/ic_remove_circle_outline_white_48dp.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/images 2.gif
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/it_fax.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/it_nas.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/it_net.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/it_radio.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/it_remote.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/it_telephone.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/it_television.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/kugaicon.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/light_ball.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/light_dinner_table.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/light_floor_lamp.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/light_kitchen_hood.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/light_led_stripe.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/light_light_dim_00.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/light_stairs.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/lowbattery.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/mann.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/markise.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/measure_battery_0.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/measure_battery_100.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/measure_battery_100.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/measure_battery_25.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/measure_battery_25.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/measure_battery_50.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/measure_battery_75.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/measure_photovoltaic_inst.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/measure_photovoltaic_inst.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/noun_socket_1135198.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/power.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/Power_socket_icon.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/raspberry.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/roomba.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/roomba312.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/roombagfx.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/Rund_graph_user8.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/Rund_Haus_user8.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/Rund_holiday_user8.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/Rund_Variable_user8.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/sani_cogeneration.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/sani_heating.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/sani_heating.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/scene_aquarium.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/scene_bath.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/scene_childs_room.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/scene_cinema.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/scene_garden.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/scene_kitchen_sink.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/scene_living.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/scene_livingroom.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/scene_pool.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/scene_sleeping_alternat.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/scene_summerhouse.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/schreibtischlampe.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/socket.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/sos.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/spotify.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/status_woman.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/steckdose.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/Steckdose.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/strom.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/suncloud.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/temp_temperature.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/temp_temperature_max.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/temp_temperature_min.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/temp_windchill.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/text_max.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/text_min.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/time_automatic.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/time_manual_mode.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/Tradfri Fernbedienung.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/trash.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/tuerklingel.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/wall-e.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/waterfall.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/weather_barometric_pressure.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/weather_cloudy.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/weather_cloudy_light.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/weather_frost.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/weather_humidity.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/weather_rain.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/weather_sunrise.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/weather_wind_directions_e.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/weather_wind_speed.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/icons/weather_wind_speed_bft.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/Pool/Filter.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/Pool/Heizung.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/Pool/Pool.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/Pool/Pumpe.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/Pool/Rohr_horizontal.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/Pool/Rohr_vertikal.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/Pool/Schieber_horizontal.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/Pool/Schieber_vertikal.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/Pool/T-Stueck_links.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/Pool/T-Stueck_oben.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/Pool/T-Stueck_rechts.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/Pool/T-Stueck_unten.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/Pool/Winkel_oben_links.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/Pool/Winkel_oben_rechts.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/Pool/Winkel_unten_links.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/Pool/Winkel_unten_rechts.svg
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/vis-views.json
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/wetter/1.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/wetter/10.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/wetter/11.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/wetter/12.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/wetter/13.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/wetter/14.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/wetter/15.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/wetter/16.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/wetter/17.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/wetter/18.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/wetter/19.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/wetter/2.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/wetter/20.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/wetter/21.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/wetter/22.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/wetter/3.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/wetter/4.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/wetter/5.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/wetter/6.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/wetter/7.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/wetter/8.png
                      [DEBUG] [iobroker] host.GLT(GLT) Upload user file "vis.0/main/wetter/9.png
                      [DEBUG] [iobroker] upload [3] admin.admin C:/iobroker/GLT/node_modules/iobroker.admin/admin/words.js words.js application/javascript
                      [DEBUG] [iobroker] upload [2] admin.admin C:/iobroker/GLT/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
                      [DEBUG] [iobroker] upload [1] admin.admin C:/iobroker/GLT/node_modules/iobroker.admin/admin/index.html index.html text/html
                      [DEBUG] [iobroker] upload [0] admin.admin C:/iobroker/GLT/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                      [DEBUG] [iobroker] upload [12] backitup.admin C:/iobroker/GLT/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                      [DEBUG] [iobroker] upload [11] backitup.admin C:/iobroker/GLT/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                      [DEBUG] [iobroker] upload [10] backitup.admin C:/iobroker/GLT/node_modules/iobroker.backitup/admin/index.html index.html text/html
                      [DEBUG] [iobroker] upload [9] backitup.admin C:/iobroker/GLT/node_modules/iobroker.backitup/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                      [DEBUG] [iobroker] upload [8] backitup.admin C:/iobroker/GLT/node_modules/iobroker.backitup/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                      [DEBUG] [iobroker] upload [7] backitup.admin C:/iobroker/GLT/node_modules/iobroker.backitup/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                      [DEBUG] [iobroker] upload [6] backitup.admin C:/iobroker/GLT/node_modules/iobroker.backitup/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                      [DEBUG] [iobroker] upload [5] backitup.admin C:/iobroker/GLT/node_modules/iobroker.backitup/admin/i18n/it/translations.json i18n/it/translations.json application/json
                      [DEBUG] [iobroker] upload [4] backitup.admin C:/iobroker/GLT/node_modules/iobroker.backitup/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                      [DEBUG] [iobroker] upload [3] backitup.admin C:/iobroker/GLT/node_modules/iobroker.backitup/admin/i18n/es/translations.json i18n/es/translations.json application/json
                      [DEBUG] [iobroker] upload [2] backitup.admin C:/iobroker/GLT/node_modules/iobroker.backitup/admin/i18n/en/translations.json i18n/en/translations.json application/json
                      [DEBUG] [iobroker] upload [1] backitup.admin C:/iobroker/GLT/node_modules/iobroker.backitup/admin/i18n/de/translations.json i18n/de/translations.json application/json
                      [DEBUG] [iobroker] upload [0] backitup.admin C:/iobroker/GLT/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                      [DEBUG] [iobroker] upload [5] discovery.admin C:/iobroker/GLT/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                      [DEBUG] [iobroker] upload [4] discovery.admin C:/iobroker/GLT/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                      [DEBUG] [iobroker] upload [3] discovery.admin C:/iobroker/GLT/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                      [DEBUG] [iobroker] upload [2] discovery.admin C:/iobroker/GLT/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                      [DEBUG] [iobroker] upload [1] discovery.admin C:/iobroker/GLT/node_modules/iobroker.discovery/admin/index.html index.html text/html
                      [DEBUG] [iobroker] upload [0] discovery.admin C:/iobroker/GLT/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                      [DEBUG] [iobroker] upload [80] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/words.js words.js application/javascript
                      [DEBUG] [iobroker] upload [70] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/js/hostInfo.js lib/js/hostInfo.js application/javascript
                      [DEBUG] [iobroker] upload [60] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/js/bootstrap.min.js lib/js/bootstrap.min.js application/javascript
                      [DEBUG] [iobroker] upload [50] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/img/logos/slackware.png lib/img/logos/slackware.png image/png
                      [DEBUG] [iobroker] upload [40] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/img/logos/manjaro.png lib/img/logos/manjaro.png image/png
                      [DEBUG] [iobroker] upload [30] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/img/logos/coreos.png lib/img/logos/coreos.png image/png
                      [DEBUG] [iobroker] upload [20] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/img/icons/disk.png lib/img/icons/disk.png image/png
                      [DEBUG] [iobroker] upload [19] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/img/icons/cpu.png lib/img/icons/cpu.png image/png
                      [DEBUG] [iobroker] upload [18] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/img/icons/battery.png lib/img/icons/battery.png image/png
                      [DEBUG] [iobroker] upload [17] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/img/clock/sechand.png lib/img/clock/sechand.png image/png
                      [DEBUG] [iobroker] upload [16] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/img/clock/minhand.png lib/img/clock/minhand.png image/png
                      [DEBUG] [iobroker] upload [15] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/img/clock/hourhand.png lib/img/clock/hourhand.png image/png
                      [DEBUG] [iobroker] upload [14] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/img/clock/clockface.png lib/img/clock/clockface.png image/png
                      [DEBUG] [iobroker] upload [13] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/fonts/FontAwesome.otf lib/fonts/FontAwesome.otf font/otf
                      [DEBUG] [iobroker] upload [12] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff2 lib/fonts/fontawesome-webfont.woff2 font/woff2
                      [DEBUG] [iobroker] upload [11] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff lib/fonts/fontawesome-webfont.woff font/woff
                      [DEBUG] [iobroker] upload [10] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.ttf lib/fonts/fontawesome-webfont.ttf font/ttf
                      [DEBUG] [iobroker] upload [9] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.svg lib/fonts/fontawesome-webfont.svg image/svg+xml
                      [DEBUG] [iobroker] upload [8] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.eot lib/fonts/fontawesome-webfont.eot application/vnd.ms-fontobject
                      [DEBUG] [iobroker] upload [7] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/data/infoData.json lib/data/infoData.json application/json
                      [DEBUG] [iobroker] upload [6] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/css/simplemde.min.css lib/css/simplemde.min.css text/css
                      [DEBUG] [iobroker] upload [5] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/css/info.css lib/css/info.css text/css
                      [DEBUG] [iobroker] upload [4] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/css/font-awesome.min.css lib/css/font-awesome.min.css text/css
                      [DEBUG] [iobroker] upload [3] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/css/chartist.min.css lib/css/chartist.min.css text/css
                      [DEBUG] [iobroker] upload [2] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
                      [DEBUG] [iobroker] upload [1] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/info.png info.png image/png
                      [DEBUG] [iobroker] upload [0] info.admin C:/iobroker/GLT/node_modules/iobroker.info/admin/index_m.html index_m.html text/html
                      [DEBUG] [iobroker] System successfully restored!
                      [EXIT] 0
                      Dann dreht der Kreis lustig vor sich hin. Ein Manueller Neustart, wird mit dieser Fehlermeldung quittiert. Ein drücken der Taste F5 killed alles. Danach geht gar nichts mehr - Man kann ioB nur noch deinstallieren.
                      2019-12-05 23:01:09,486 INFO  - Starting the service with id 'iobroker(GLT)'
                      2019-12-05 23:01:09,538 FATAL - WMI Operation failure: ServiceAlreadyRunning
                      WMI.WmiException: ServiceAlreadyRunning
                         bei WMI.WmiRoot.BaseHandler.CheckError(ManagementBaseObject result)
                         bei WMI.WmiRoot.InstanceHandler.Invoke(Object proxy, MethodInfo method, Object[] args)
                         bei winsw.WrapperService.Run(String[] _args, ServiceDescriptor descriptor)
                         bei winsw.WrapperService.Main(String[] args)
                      C:\iobroker\GLT>
                      • JB_Sullivan
                        So, ich mache für heute Schluss - muss morgen wieder raus. Morgen Nachmittag geht es dann weiter .......
                        • simatec
                          @JB_Sullivan
                          So wie es aussieht, lief iobroker schon.
                          F5 aktualisiert nur das Browserfenster und killt nix.
                          Was hat der Log von backitup am Ende gesagt?
                          Der Log öffnet sich mit Beginn des Restores im neuen Tab, wenn dein Browser keine Popups blockiert
                            Einstein67 last edited by Einstein67
                            Vielen Dank für die neue Version!
                            Hab gerade einen Wiederherstellungs-Test (History + Standard) auf einer ioBroker Neuinstallation gemacht. Hat auch beides funktioniert. Beim History Restore kam allerdings in dem neuen Statusfenster die Meldung:
                            Log Backitup Restore:
                            Restore is started ...
                            [EXIT] historyDB restore done **** Restore was canceled!! ****
                            The log can be closed ...
                            In dem Fenster das es schon vorher gab wird die Wiederherstellung ganz normal mit "Exit 0" beendet, und alle History Daten sind auch da ...
                            Edit: Im Debug Log kommen danach folgende Warnungen:
                            backitup.0	2019-12-06 08:10:22.085	warn	- /opt/iobroker/node_modules/iobroker.backitup/main.js
                            backitup.0	2019-12-06 08:10:22.085	warn	Require stack:
                            backitup.0	2019-12-06 08:10:22.085	warn	(524) Cannot read log file: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.backitup/lib/total.json'
                            backitup.0	2019-12-06 08:10:22.080	debug	(524) [EXIT] historyDB restore done
                            Spielt da irgendwie das ehemalige Total-Backup (cannot find ... total.json) noch mit rein?
                            Aber wie schon geschrieben: Alles funktioniert wie erwartet!!
                            • simatec
                              simatec Developer Most Active @Einstein67 last edited by Negalein
                              @Einstein67 sagte in Test Adapter Backitup v1.3.x:
                              Da ist eine Ausgabe irgendwie noch nicht in korrekt.
                              Ist aber nur die reine Darststellungssache im Webinterface. Da muss ich noch einmal ran.
                              Das sagt aus, das alles korrekt gelaufen ist.
                              Mod-Edit: Vollzitat gekürzt
                                Einstein67 @simatec last edited by Einstein67
                                @simatec said in Test Adapter Backitup v1.3.x:
                                Danke für die schnelle Antwort! Bei mir hat die Meldung "Restore was canceled!! und die rote Schrift;
                                sofort mein "ioBroker Alarmsystem" ausgelöst 😉
                                Aber nach nach dem schließen des Fensters wurde ich durch das bekannte:
                                dann schnell wieder beruhigt!
                                • JB_Sullivan
                                  @simatec
                                  so, da bin ich wieder - mit den gleichen Problemen wie gestern.
                                  In der Zwischenzeit habe ich wieder und wieder versucht eine nagelneue Windows ioB Installation via BackItUp 1.3.2 einzurichten.
                                  Ich glaube der Fehler liegt nicht in BackItUp, sondern beim Windows Installer (siehe meinen Beitrag hier -> https://forum.iobroker.net/topic/27425/wininstaller-2-1-auf-nagelneuem-nuc-fehlerhaft ). F5 ist dann nur die "Krönung" und führt dazu das man das WebInterface von ioBroker nicht mehr angezeigt bekommt.
                                  In Wirklichkeit ist ioB schon nach einspielen der Updatedatei nicht mehr Funktionsfähig. Man bekommt die Webseite mit dem drehenden BackItUp Kreis nur als - ich nenne es mal "Cache Echo" angezeigt.
                                  Benötigt BackItUp irgend etwas von Microsoft Visual Studio? Der Win Installer sagt nämlich während des Installationsprozess, das dass Studio vorhanden ist. In Wirklichkeit ist es das aber nicht, was man beim Update des js-controller auf 2.1.1 auch angezeigt bekommt.
                                  Fakt ist im Moment, das ich nicht in der Lage bin eine neue Windows Installation via Backup Datei auf den alten Stand zu bringen. Ich werde jetzt alle von mir verwendeten Adapter mal einzeln und von Hand installieren und dann nochmal einen Versuch unternehmen das Backup zurück zu spielen.
                                  Irgendwie muss das doch funktionieren.
                                  Hier das Log File von BackItUp
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 0/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 200/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 400/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 600/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 800/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 1000/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 1200/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 1400/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 1600/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 1800/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 2000/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 2200/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 2400/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 2600/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 2800/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 3000/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 3200/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 3400/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 3600/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 3800/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 4000/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 4200/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 4400/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 4600/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 4800/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 5000/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 5200/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 5400/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 5600/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 5800/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 6000/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 6200/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 6400/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 6600/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 6800/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 7000/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 7200/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 7400/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 7600/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 7800/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 8000/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 8200/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 8400/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 8600/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 8800/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 9000/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 9200/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 9400/9627 states
                                  [DEBUG] [iobroker] host.GLT(GLT) Processed 9600/9627 states
                                  [DEBUG] [iobroker] 9627 states restored.
                                  [DEBUG] [iobroker] upload [3] backitup.admin C:/iobroker/GLT/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                                  [DEBUG] [iobroker] upload [2] backitup.admin C:/iobroker/GLT/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                                  [DEBUG] [iobroker] upload [1] backitup.admin C:/iobroker/GLT/node_modules/iobroker.backitup/admin/index.html index.html text/html
                                  [EXIT] 0 **** Restore completed successfully!! ****
                                  • simatec
                                    simatec Developer Most Active @JB_Sullivan last edited by simatec
                                    @JB_Sullivan
                                    So jetzt nochmal langsam, bevor du dir unnötig Arbeit machst.
                                    Das Backup wurde sauber eingespielt.
                                    Lediglich dein Iobroker startet nicht automatisch im Anschluss.
                                    Dafür gehst du in dein Startmenü und wählst die Konsole dort von iobroker an.
                                    Nicht einfach nur cmd öffnen. Sondern wirklich die iobroker Konsole.
                                    Dort startest du iobroker einfach manuell mit „iobroker start“
                                    Dann im Log abwarten, bis alle Adapter installiert sind.
                                    • JB_Sullivan
                                      @simatec
                                      Nichts anderes tue ich - der Broker ist nicht mehr erreichbar, auch wenn rein Visiuell alles zu laufen scheint.
                                      • simatec
                                        @JB_Sullivan
                                        Starte mal den Rechner neu
                                        • JB_Sullivan
                                          @simatec
                                          Habe ich auch schon - bringt nichts.
                                          .Ist das ggf. Ein Rechte oder Firewall Regel Problem. Sowas ähnliches hatte ich mal.mit einer neuen Version von Octoprint. War nach dem Update nicht mehr als localhost erreichbar
                                          • simatec
                                            @JB_Sullivan
                                            Ist auf deinem alten System die Erreichbarkeit von admin auf 0.0.0.0 eingestellt?
                                            Das ist auf jeden Fall wichtig, wenn du das System wechselst
                                            Sonst ist das neue System nicht erreichbar.
                                            Sonst kannst du aber auch noch die 127.0.0.1 testen
                                            170
                                            2780
                                            2363926
