    3. Entwicklung
    4. Widget circle-menu
    Widget circle-menu
      pix last edited by
      leider habe ich das Update auf 0.7.15 gemacht, bevor ich mehr gelesen habe. Jetzt ist mein Produktivsystem wieder mal abgeschmiert.
      Log (ganzer Vorgang im Textfile-Anhang)
      ! ├── npm@2.14.13
      ! ├── rimraf@2.4.4
      ! └─┬ socket.io-adapter@0.3.1
      ! └─┬ debug@1.0.2
      ! └── ms@0.6.2
      ! npm WARN ENOENT ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/package.json'
      ! npm WARN ENOENT ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/node_modules/ftp-response-parser/package.json'
      ! npm WARN ENOENT ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/node_modules/jsftp/package.json'
      ! npm WARN ENOENT ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/node_modules/mqtt-packet/package.json'
      ! npm WARN ENOENT ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/node_modules/node_modules/package.json'
      ! npm WARN ENOENT ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/node_modules/through2/package.json'
      ! npm WARN EPACKAGEJSON iobroker No description
      ! npm WARN EPACKAGEJSON iobroker No repository field.
      ! npm WARN EPACKAGEJSON iobroker No README data
      ! npm WARN EPACKAGEJSON iobroker No license field.
      ! MacMini-Ethernet:iobroker pix$ ./iobroker start
      ! Starting ioBroker controller daemon…
      ! /Users/pix/Documents/iobroker/node_modules/daemonize2/lib/daemonize.js:136
      ! throw new Error(msg.error);
      ! Error: Error: Cannot find module 'socket.io'
      ! at Function.Module._resolveFilename (module.js:337:15)
      ! at Function.Module._load (module.js:287:25)
      ! at Module.require (module.js:366:17)
      ! at require (module.js:385:17)
      ! at Object. <anonymous>(/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:8:16)
      ! at Module._compile (module.js:425:26)
      ! at Object.Module._extensions..js (module.js:432:10)
      ! at Module.load (module.js:356:32)
      ! at Function.Module._load (module.js:311:12)
      ! at ChildProcess. <anonymous>(/Users/pix/Documents/iobroker/node_modules/daemonize2/lib/daemonize.js:136:19)
      ! at emitTwo (events.js:87:13)
      ! at ChildProcess.emit (events.js:172:7)
      ! at handleMessage (internal/child_process.js:686:10)
      ! at Pipe.channel.onread (internal/child_process.js:440:11)
      ! MacMini-Ethernet:iobroker pix$</anonymous></anonymous>
      Zum Glück habe ich TimeMachine und heute etwas Zeit. 261_fehler.txt
      Pix
        Communicate last edited by
        Oh 😞 das tut mir leid. Vielleicht kann bluefox hier unterstützen
        von unterwegs gesendet
          mc-hollin last edited by
          So, ich hab dein Widget auch mal installiert.
          Ging soweit alles ohne Fehler.
          Im VIS wird das Widget-Packet "communicate" auch angezeigt.
          Leider sehe ich kein Widget.
          Meine js.controller Version ist 0.7.15
          Mir ist Aufgefallen, dass bei der Instanz kein Default-Log eingestellt ist.
          Holger
            Hmm. Den visdebug communicate hast du aber gemacht, oder?
              Sonst muss bluefox hier mal mit unterstützen.
                Hier die Ausgabe von visdebug:
                ! D:\Hausserver-Entwicklung\ioBroker>node node_modules/iobroker.js-controller/iobroker.js visdebug communicate
                ! Upload "D:\Hausserver-Entwicklung\ioBroker\node_modules\ioBroker.vis\www\index.html.original"
                ! Upload "D:\Hausserver-Entwicklung\ioBroker\node_modules\ioBroker.vis\www\edit.html.original"
                ! Modify "D:\Hausserver-Entwicklung\ioBroker\node_modules\ioBroker.vis\www\cache.manifest"
                ! Upload "D:/Hausserver-Entwicklung/ioBroker/node_modules/iobroker.vis-communicate/widgets"
                ! Upload "D:/Hausserver-Entwicklung/ioBroker/node_modules/iobroker.vis-communicate/widgets/communicate/css/Cicle Fina.ttf"
                ! Upload "D:/Hausserver-Entwicklung/ioBroker/node_modules/iobroker.vis-communicate/widgets/communicate/css/style.css"
                ! Upload "D:/Hausserver-Entwicklung/ioBroker/node_modules/iobroker.vis-communicate/widgets/communicate/img/sani_heating_temp.svg"
                ! Upload "D:/Hausserver-Entwicklung/ioBroker/node_modules/iobroker.vis-communicate/widgets/communicate.html"
                  Das sieht eigentlich gut aus.
                  Hast du mal einen reboot probiert? Aber das ist jetzt nur stochern im Nebel.
                  @Bluefox: haben wir etwas vergessen?
                    Ich hab mal mit "jqui-mfd" verglichen.
                    Hier liegt noch eine "doc.html" im Verzeichnis "ioBroker\node_modules\iobroker.vis-jqui-mfd\widgets\jqui-mfd".
                    Ist die eventuell für die Ansicht zuständig?
                      Nein, eigentlich nicht. Das eigentliche widget steht in communicate.html und in styles.css
                        Hab jetzt den ioBroker Dienst neu gestartet und den ganzen Rechner neu gebootet.
                        Beides ohne Erfolg.
                          Hmm.
                          Du hast ein Testsystem, oder?
                          Ich hoffe auch mit Backup.
                          Wenn ja, probier mal folgendes:
                          cd /opt/iobroker/node_modules/iobroker.vis-communicate
                          npm install
                            Ja, läuft auf einem Testsystem unter Windows 10.
                            Leider hat "npm install" auch nichts gebracht.
                            Ich hab auf dem Testsystem node 4.2.2 laufen.
                            Ob das was zu sagen hat?
                            Hier das Ergebnis:
                            ! D:\Hausserver-Entwicklung\ioBroker\node_modules\iobroker.vis-communicate>npm install
                            ! npm WARN deprecated lodash@0.9.2: lodash@<3.0.0 is no longer maintained. Upgrade to lodash@^3.0.0.
                            ! npm WARN deprecated lodash@2.4.2: lodash@<3.0.0 is no longer maintained. Upgrade to lodash@^3.0.0.
                            ! grunt-exec@0.4.6 node_modules\grunt-exec
                            ! grunt-contrib-copy@0.8.2 node_modules\grunt-contrib-copy
                            ! ├── file-sync-cmp@0.1.1
                            ! └── chalk@1.1.1 (escape-string-regexp@1.0.3, ansi-styles@2.1.0, supports-color@2.0.0, has-ansi@2.0.0, strip-ansi@3.0.0)
                            ! grunt-contrib-clean@0.6.0 node_modules\grunt-contrib-clean
                            ! └── rimraf@2.2.8
                            ! grunt-http@1.6.0 node_modules\grunt-http
                            ! ├── aws-sign2@0.5.0
                            ! ├── oauth-sign@0.4.0
                            ! ├── tunnel-agent@0.4.1
                            ! ├── async@0.9.2
                            ! ├── tough-cookie@2.2.1
                            ! ├── http-signature@0.10.1 (assert-plus@0.1.5, ctype@0.5.3, asn1@0.1.11)
                            ! ├── hawk@2.3.1 (cryptiles@2.0.5, boom@2.10.1, sntp@1.0.9, hoek@2.16.3)
                            ! ├── form-data@0.1.4 (mime@1.2.11, combined-stream@0.0.7)
                            ! └── request@2.47.0 (caseless@0.6.0, forever-agent@0.5.2, stringstream@0.0.5, json-stringify-safe@5.0.1, mime-types@1.0.2, qs@2.3.3, node-uuid@1.4.7, combined-stream@0.0.7, bl@0.9.4, hawk@1.1.1)
                            ! grunt@0.4.5 node_modules\grunt
                            ! ├── eventemitter2@0.4.14
                            ! ├── dateformat@1.0.2-1.2.3
                            ! ├── getobject@0.1.0
                            ! ├── which@1.0.9
                            ! ├── colors@0.6.2
                            ! ├── async@0.1.22
                            ! ├── lodash@0.9.2
                            ! ├── rimraf@2.2.8
                            ! ├── hooker@0.2.3
                            ! ├── grunt-legacy-util@0.2.0
                            ! ├── exit@0.1.2
                            ! ├── coffee-script@1.3.3
                            ! ├── iconv-lite@0.2.11
                            ! ├── underscore.string@2.2.1
                            ! ├── nopt@1.0.10 (abbrev@1.0.7)
                            ! ├── minimatch@0.2.14 (sigmund@1.0.1, lru-cache@2.7.3)
                            ! ├── glob@3.1.21 (inherits@1.0.2, graceful-fs@1.2.3)
                            ! ├── grunt-legacy-log@0.1.2 (grunt-legacy-log-utils@0.1.1, lodash@2.4.2, underscore.string@2.3.3)
                            ! ├── findup-sync@0.1.3 (lodash@2.4.2, glob@3.2.11)
                            ! └── js-yaml@2.0.5 (esprima@1.0.4, argparse@0.1.16)
                            ! grunt-replace@0.9.3 node_modules\grunt-replace
                            ! ├── chalk@1.1.1 (escape-string-regexp@1.0.3, ansi-styles@2.1.0, supports-color@2.0.0, strip-ansi@3.0.0, has-ansi@2.0.0)
                            ! ├── lodash@3.10.1
                            ! └── applause@0.4.3 (cson-parser@1.3.0, js-yaml@3.4.6)
                            ! grunt-contrib-compress@0.13.0 node_modules\grunt-contrib-compress
                            ! ├── prettysize@0.0.3
                            ! ├── chalk@0.5.1 (escape-string-regexp@1.0.3, ansi-styles@1.1.0, supports-color@0.2.0, strip-ansi@0.3.0, has-ansi@0.1.0)
                            ! └── archiver@0.13.1 (buffer-crc32@0.2.5, async@0.9.2, lazystream@0.1.0, lodash@2.4.2, readable-stream@1.0.33, tar-stream@1.1.5, glob@4.3.5, zip-stream@0.5.2)
                            ! grunt-contrib-jshint@0.11.3 node_modules\grunt-contrib-jshint
                            ! ├── hooker@0.2.3
                            ! └── jshint@2.8.0 (strip-json-comments@1.0.4, exit@0.1.2, minimatch@2.0.10, shelljs@0.3.0, console-browserify@1.1.0, cli@0.6.6, htmlparser2@3.8.3, lodash@3.7.0)
                            ! grunt-jscs@2.3.0 node_modules\grunt-jscs
                            ! ├── vow@0.4.11
                            ! ├── hooker@0.2.3
                            ! ├── lodash@3.10.1
                            ! └── jscs@2.5.1 (to-double-quotes@2.0.0, to-single-quotes@2.0.0, reserved-words@0.1.1, strip-json-comments@1.0.4, natural-compare@1.2.2, estraverse@4.1.1, pathval@0.1.1, jscs-preset-wikimedia@1.0.0, esprima@2.7.0, exit@0.1.2, xmlbuilder@3.1.0, commander@2.9.0, strip-bom@2.0.0, chalk@1.1.1, cli-table@0.3.1, glob@5.0.15, minimatch@3.0.0, resolve@1.1.6, jscs-jsdoc@1.2.0, vow-fs@0.3.4, js-yaml@3.4.6, babel-jscs@2.0.5, htmlparser2@3.8.3, prompt@0.2.14, jsonlint@1.6.2, escope@3.3.0, babel-core@5.8.34)
                            Was mir leider überhaupt nichts sagt :shock:
                              Jetzt nochmal den visdebug teil
                                so, ich habe jetzt eine idee woran es liegen könnte.
                                ersetze mal bitte folgende dateien mit diesen:
                                515_archiv.zip.txt
                                (datei in zip unbenennen, dann entpacken)
                                /opt/iobroker/node_modules/iobroker.vis-communicate/widgets/communicate.html
                                /opt/iobroker/node_modules/iobroker.vis-communicate/widgets/communicate/css/style.css
                                danach dann nochmal
                                iobroker visdebug communicate
                                @PIX: da osx ja auch case sensitive ist: das Verzeichnis muss "iobroker.vis-communicate" heissen nicht ioBroker.vis-communicate
                                Bei mc-hollin hat es jetzt funktioniert - jetzt gehts an gemeinsame Entscheiden, welche Eigenschaften administriebar sein sollen und ans
                                weiterentwickeln.
                                Es sind jetzt überigens zwei Widgets geworden, einmal Circle und einmal Corner-Menu.
                                Für das Circle Widget, musst bei der CSS-Lasche noch noch folgendes erfasst werden:
                                @import "http://netdna.bootstrapcdn.com/font-awe … wesome.css";
                                Beim Menu Widget kann man bis jetzt die Eigenschaften Link1, Link2, Link3 und Link4 nutzen (sonst sieht man auch keinen Text im Widget)
                                Wenn jemand Ahnung von CSS hat - das können wir bestimmt auch gut gebrauchen.
                                Dominic
                                • V
                                  vore last edited by
                                  Hallo!
                                  Seit ihr weiter gekommen? Hätte auch Interesse dran.
                                  Vore
                                    Hansi1234 last edited by Hansi1234
                                    @Communicate said in Widget circle-menu:
                                    Wurden hier schon Fortschritte gemacht? Finde die Idee toll. Bei FHEM wurde das sehr toll umgesetzt.
                                    EDIT: Sehe gerade, dass es ein neueres Thema darüber gibt:
                                    link text
                                    5255
