    • JB_Sullivan
      JB_Sullivan @simatec last edited by
      @simatec
      was meinst du mit "iobroker list instances"? Die hier?
      simatec 2 Replies Last reply Reply Quote 0
      • simatec
        simatec Developer Most Active @JB_Sullivan last edited by
        @JB_Sullivan
        Nein per Konsole nach dem Restore
        • simatec
          @JB_Sullivan
          Mache mal bitte folgendes:
          Restore ausführen und dann iobroker stoppen (falls iobroker läuft) und dann über die Konsole „iobroker host this“ danach wieder starten und du solltest über localhost drauf kommen
          • JB_Sullivan
            @simatec
            C:\iobroker\GLT>iobroker list instances
              system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              system.adapter.alexa2.0                : alexa2                - disabled
              system.adapter.backitup.0              : backitup              -  enabled
              system.adapter.bring.0                 : bring                 - disabled
              system.adapter.cloud.0                 : cloud                 - disabled
              system.adapter.daswetter.0             : daswetter             - disabled
              system.adapter.deconz.0                : deconz                - disabled
              system.adapter.discovergy.0            : discovergy            - disabled
              system.adapter.discovery.0             : discovery             - disabled
              system.adapter.dwd.0                   : dwd                   - disabled
              system.adapter.email.0                 : email                 - disabled
              system.adapter.flot.0                  : flot                  - disabled
              system.adapter.fritzbox.0              : fritzbox              - disabled
              system.adapter.fritzdect.0             : fritzdect             - disabled
              system.adapter.fullybrowser.0          : fullybrowser          - disabled
              system.adapter.history.0               : history               - disabled
              system.adapter.ical.0                  : ical                  - disabled
              system.adapter.ical.1                  : ical                  - disabled
              system.adapter.icons-material-png.0    : icons-material-png    - disabled
              system.adapter.icons-material-svg.0    : icons-material-svg    - disabled
              system.adapter.info.0                  : info                  - disabled
              system.adapter.innogy-smarthome.0      : innogy-smarthome      - disabled
              system.adapter.iot.0                   : iot                   - disabled
              system.adapter.javascript.0            : javascript            - disabled
              system.adapter.mihome-vacuum.0         : mihome-vacuum         - disabled, port: 54321
              system.adapter.octoprint.0             : octoprint             - disabled
              system.adapter.ping.0                  : ping                  - disabled
              system.adapter.proxy.0                 : proxy                 - disabled
              system.adapter.rflink.0                : rflink                - disabled
              system.adapter.roomba.0                : roomba                - disabled
              system.adapter.socketio.0              : socketio              - disabled, port: 8084, bind: 0.0.0.0, run as: admin
              system.adapter.sonoff.0                : sonoff                - disabled, port: 1883, bind: 0.0.0.0
              system.adapter.sourceanalytix.0        : sourceanalytix        - disabled
              system.adapter.spotify-premium.0       : spotify-premium       - disabled
              system.adapter.tankerkoenig.0          : tankerkoenig          - disabled
              system.adapter.telegram.0              : telegram              - disabled, port: 8443, bind: 0.0.0.0
              system.adapter.tr-064.0                : tr-064                - disabled
              system.adapter.trashschedule.0         : trashschedule         - disabled
              system.adapter.vis-canvas-gauges.0     : vis-canvas-gauges     - disabled
              system.adapter.vis-colorpicker.0       : vis-colorpicker       - disabled
              system.adapter.vis-history.0           : vis-history           - disabled
              system.adapter.vis-hqwidgets.0         : vis-hqwidgets         - disabled
              system.adapter.vis-jqui-mfd.0          : vis-jqui-mfd          - disabled
              system.adapter.vis-justgage.0          : vis-justgage          - disabled
              system.adapter.vis-materialdesign.0    : vis-materialdesign    - disabled
              system.adapter.vis-plumb.0             : vis-plumb             - disabled
              system.adapter.vis-timeandweather.0    : vis-timeandweather    - disabled
              system.adapter.vis-weather.0           : vis-weather           - disabled
              system.adapter.vis.0                   : vis                   - disabled
              system.adapter.web.0                   : web                   - disabled, port: 8082, bind: 0.0.0.0, run as: admin
            + instance is alive
            • JB_Sullivan
              @simatec sagte in Test Adapter Backitup v1.3.x:
              iobroker host this
              BINGO !!!!!! Ich komme wieder drauf !!!!!
              C:\iobroker\GLT>iobroker stop
              2019-12-06 22:37:02,462 INFO  - Stopping the service with id 'iobroker(GLT)'
              C:\iobroker\GLT>iobroker host this
              Host "iobroker(ioBroker)" successfully renamed to "GLT".
              The host for instance "system.adapter.admin.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.alexa2.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.backitup.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.bring.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.cloud.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.daswetter.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.deconz.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.discovergy.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.discovery.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.dwd.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.email.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.flot.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.fritzbox.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.fritzdect.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.fullybrowser.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.history.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.ical.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.ical.1" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.icons-material-png.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.icons-material-svg.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.info.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.innogy-smarthome.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.iot.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.javascript.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.mihome-vacuum.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.octoprint.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.ping.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.proxy.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.rflink.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.roomba.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.socketio.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.sonoff.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.sourceanalytix.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.spotify-premium.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.tankerkoenig.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.telegram.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.tr-064.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.trashschedule.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.vis-canvas-gauges.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.vis-colorpicker.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.vis-history.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.vis-hqwidgets.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.vis-jqui-mfd.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.vis-justgage.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.vis-materialdesign.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.vis-plumb.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.vis-timeandweather.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.vis-weather.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.vis.0" was changed from "GLT(GLT)" to "GLT".
              The host for instance "system.adapter.web.0" was changed from "GLT(GLT)" to "GLT".
              C:\iobroker\GLT>iobroker start
              2019-12-06 22:37:22,326 INFO  - Starting the service with id 'iobroker(GLT)'
              • simatec
                @JB_Sullivan 👍
                • JB_Sullivan
                  @simatec
                  Jetzt sieht man im LOG, das er mächtig am nachladen ist - was war des Rätsels Lösung, bzw. warum dieses "Fehlverhalten"?
                  • simatec
                    @JB_Sullivan
                    Lag nicht am restore oder backitup.
                    Es wurde der Hostname von deinem alten System gesetzt
                    Stabilostick 1 Reply Last reply Reply Quote 0
                    • Stabilostick
                      Stabilostick @simatec last edited by Stabilostick
                      @simatec @JB_Sullivan
                      Wenn man die Wiederherstellung des gesicherten iobroker-data-Ordners mit dem Windows Installer macht, wird dabei u.a. auch der Hostname automatisch auf den aktuellen Stand gebracht.
                      • simatec
                        simatec Developer Most Active @Stabilostick last edited by
                        @Stabilostick
                        Das sollte dann bei backitup auch mit rein.
                        Aber für sollten uns beide noch einmal kurzschließen ...
                        • JB_Sullivan
                          @simatec
                          Also vielen Dank für deine Geduld und deine Unterstützung. Alleine hätte ich das NIE lösen können - Also nochmals vielen vielen Dank !!! 👍 👍 👍 👍
                          • Dr. Bakterius
                            Dr. Bakterius Most Active @JB_Sullivan last edited by Dr. Bakterius
                            Wo wird die Konsole mit dem Fortschritt angezeigt? Bei mir läuft nur der Balken endlos durch. Habe auch mal versucht http://IP:PORT/backitup-restore selbst aufzurufen. Da war keine Seite erreichbar.
                            • opossum
                              opossum last edited by
                              Hallo, @Dr-Bakterius ,
                              hast Du im Browser einen Popupblocker? Bei mir wurde das erst angezeigt, als ich den Popupblocker ausgeschaltet hatte.
                              • Dr. Bakterius
                                Dr. Bakterius Most Active @opossum last edited by Dr. Bakterius
                                @opossum Kann schon sein (Chrome). Müsste ich beim nächsten Mal testen und alles was blocken könnte abschalten.
                                Edit: Habe es jetzt auch mal mit Edge und v1.3.2 probiert, da ging das Statusfenster auf. 👍
                                Habe meinen Post von oben angepasst da ich wohl doch nicht v1.3.2 sondern die stable installiert hatte. Habe zuvor vergessen auf 'latest' umzustellen. 🙄
                                Passt also alles! Mein Test in einem Proxmox-Container hat reibungslos funktioniert. Super Tool! 👏
                                • simatec
                                  simatec Developer Most Active @Dr. Bakterius last edited by
                                  @Dr-Bakterius
                                  Welche Version hast du installiert?
                                  Das Feature gibt es erst ab Version 1.3.2
                                  • SRo769
                                    SRo769 last edited by
                                    Hi, hab mal den Adapter 1.3.2 getestet. Klappt soweit alles (mysql, redis, ccu - alles enthalten - keine Fehlermeldungen). Allerdings habe ich folgendes Problem:
                                    Nach dem eigentlichen Backup-Ende kommen die folgenden Log-Einträge dauerhaft:
                                    Alle paar Sekunden ein neuer Eintrag- die Redis-Sicherung ist auch nur 1kb groß und lässt sich nicht entpacken. Habe ich so auch noch nicht gehabt. Ist das schon mal woanders aufgetreten?
                                    VG Sven
                                    • Dr. Bakterius
                                      Dr. Bakterius Most Active @simatec last edited by
                                      @Dr-Bakterius
                                      Sieh mal mein Post direkt ober deinem. 😉 Hab' meinen Fehler schon gefunden gehabt.
                                      • JB_Sullivan
                                        So, da bin ich wieder : )
                                        Ich habe heute erst festgestellt, das meine ganzen Einstellungen für sourceanalytix und history nach dem Backup beim Sonoff Adapter komplett nicht mehr vorhanden sind.
                                        Da das ein Haufen Zeug war was ich neu einstellen müsste, kann man das irgendwie einzeln restoren? Wo werden diese Einstellungen üblicherweise gespeichert? Vielleicht ist es ja auch möglich aus der alten ioB Installation die Datei mit diesen Infos einzeln rüber zu kopieren?
                                        • simatec
                                          simatec Developer Most Active @JB_Sullivan last edited by simatec
                                          @JB_Sullivan
                                          History Daten kannst du in backitup separat sichern.
                                          Zu den Daten von sourceanalytix müsste @Dutchman eventuell mal was zu sagen
                                          • JB_Sullivan
                                            Das mit dem history Pfad habe ich noch nicht so ganz verstanden.
                                            Da steht bei mir "media/usb/history" drin. Was ist das für ein Pfad? Da wohin gesichert werden soll, oder der Pfad wo das History Verzeichnis liegt (liegen sollte)?
                                            History liegt zumindest bei meiner Windows Installation hier: - \iobroker-data\history
                                            Wie gesagt, das mit der history Sicherung erschließt sich mir noch nicht so wirklich.
                                            1.4k
                                            170
                                            2780
                                            2362044
