    4. Test Adapter Smartmeter 3.0.x
    • bahnuhr
      bahnuhr Forum Testing Most Active @apollon77 last edited by
      @apollon77 sagte in Test Adapter Smartmeter 3.0.x:
      Close Handling optimiert
      Instanz aus:
      host.Pi-Strom	2019-12-08 08:20:53.501	info	instance system.adapter.smartmeter.0 terminated with code 0 (OK)
      host.Pi-Strom	2019-12-08 08:20:53.470	info	stopInstance system.adapter.smartmeter.0 killing pid 17463
      host.Pi-Strom	2019-12-08 08:20:53.469	info	stopInstance system.adapter.smartmeter.0
      host.Pi-Strom	2019-12-08 08:20:53.469	info	"system.adapter.smartmeter.0" disabled
      host.Pi-Strom	2019-12-08 08:20:53.468	info	object change system.adapter.smartmeter.0
      host.Asus-Buero	2019-12-08 08:20:35.918	info	object change system.adapter.smartmeter.0
      Instanz ein:
      smartmeter.0	2019-12-08 08:22:30.836	info	Received 7 values, 7 updated
      smartmeter.0	2019-12-08 08:22:29.403	info	starting. Version 3.0.6 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v8.15.1
      host.Pi-Strom	2019-12-08 08:22:27.017	info	instance system.adapter.smartmeter.0 started with pid 17477
      host.Pi-Strom	2019-12-08 08:22:27.016	info	"system.adapter.smartmeter.0" enabled
      host.Pi-Strom	2019-12-08 08:22:27.015	info	object change system.adapter.smartmeter.0
      host.Asus-Buero	2019-12-08 08:22:08.499	info	object change system.adapter.smartmeter.0
      Instanz (Kreis gedrückt - also aus und dann ein):
      smartmeter.0	2019-12-08 08:23:13.143	info	Received 7 values, 7 updated
      smartmeter.0	2019-12-08 08:23:12.299	info	starting. Version 3.0.6 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v8.15.1
      host.Pi-Strom	2019-12-08 08:23:09.962	info	instance system.adapter.smartmeter.0 started with pid 17492
      host.Pi-Strom	2019-12-08 08:23:07.475	info	instance system.adapter.smartmeter.0 terminated with code 0 (OK)
      host.Pi-Strom	2019-12-08 08:23:07.442	info	stopInstance system.adapter.smartmeter.0 killing pid 17477
      host.Pi-Strom	2019-12-08 08:23:07.440	info	object change system.adapter.smartmeter.0
      Fazit:
      sieht ok aus. Fehler ist weg.
        apollon77 @bahnuhr last edited by
        @bahnuhr cool. Danke. Der hatte vorher versucht den Serien port zu schließen obwohl der schon zu war 😉
          MartyBr last edited by
          Hallo, ich habe nun am Wochenende meinen Adapter Smartmeter 1.x auf die Version 3.03 upgedatet. Ich habe damit gerechnet, dass der Adapter neue Datenpunkte mit den 2 _ anlegt. Die SQL Statements zum anpassen der in der SQL-DB geloggten Einträge lagen bereit.
          Nach dem Update war ich dann (positiv) erstaunt, dass die alten DPs beibehalten wurden. Es war also nicht nötig, die Einträge in der SQL Datenbank anzupassen.
          Jetzt habe ich auch das Update auf die 3.06 gemacht. Bisher läuft alles sehr gut.
          Vielen Dank hier an diese Stelle an @apollon77 .
          Hier ein Screenshot von der SQL-DB NACH dem Update:
          • bahnuhr
            bahnuhr Forum Testing Most Active @MartyBr last edited by
            @MartyBr sagte in Test Adapter Smartmeter 3.0.x:
            mit den 2 _ anlegt
            Bei mir wurden beim Update die 2 _ angelegt.
            Ich hatte somit die alten DP und auch die neuen mit den 2_.
              MartyBr @bahnuhr last edited by
              @bahnuhr Das hatte ich auch befürchtet. Ich verstehe auch den Unterschied nicht. Ich habe ganz normal über den Admin das Update angestoßen. Da meine History Daten in der SQL liegen, habe ich vorher nach einer Möglichkeit gesucht, diese anpassen zu können.
              Hier hatte mir @a200 geholfen.
              • bahnuhr
                Dein Screenshot zeigt aber sql, oder ?
                Die Datenpunkte mit den 2 _ werden aber doch bei den Objekten angelegt.
                In sql habe ich noch die damaligen * als Alias drin.
                  @bahnuhr Ja, ich logge alle History Daten in den SQL-Adapter.
                    MartyBr @MartyBr last edited by
                    Habe gerade gesehen, dass in den Objekten einige mit den zwei Unterstrichen angelegt wurden. Das ist hoffentlich nicht problematisch, ich logge nur die Zahlenwerte:
                    a200 1 Reply Last reply Reply Quote 0
                    • bahnuhr
                      Na, siehst du.
                      Und nur diese (mit 2_) enthalten zukünftig Daten.
                      Instanz aus.
                      Lösche mal die Objekte
                      Instanz ein.
                      Dann hast du nur die DP die auch Werte enthalten.
                      Und bei diesen dann sql.
                      Wenn du die alten Werte in sql erhalten willst, dann alias verwenden.
                      • bahnuhr
                        sieht dann so aus:
                          @bahnuhr Der zweite Zähler enthält andere Werte; hier gibt es die doppelten Unterstriche nicht:
                          • a200
                            a200 @MartyBr last edited by
                            @MartyBr solange du nicht VORHER schon die DP, die JETZT zwei Unterstriche haben, geloggt hast, spielt das für dich keine Rolle. Das ganze war nur nötig um die bisher gespeicherten Daten zu behalten und mit den neuen Namen weiter zu loggen.
                              MartyBr @a200 last edited by
                              @a200
                              Ich logge ja seit 9 Monaten die Daten. Daher wäre es nötig gewesen. Aber die Zählerstände beider Zähler haben weiter den gleichen DP. Nur die DP "Kumuliertes Maximum xxx" haben die neuen DPs bekommen. Diese Werte logge ich nicht, nur den "Zählerstand XX". Di Auswertung mache ich Sourceanalyticx.
                              Macht ihr das anders?
                                @bahnuhr
                                ich habe das sprechend gemacht:
                                M bahnuhr 2 Replies Last reply Reply Quote 0
                                  Hier mal alle DPs der beiden Zähler:
                                    Ob und welche mit zwei Unterstrichen neu angelegt werden hängt davon ab wie die ID der Objekte nach obis aufgebaut sind. D.h. es passiert nicht bei allen, sondern nur bei einigen.
                                    • bahnuhr
                                      Heißt der Datenpunkt wirklich "Haushaltsstrom" ?
                                      Ich habe smartmeter schon lange installiert.
                                      Und auch immer mit sql gespeichert.
                                      früher hieß der DP: smartmeter.0.1-0:2_8_0*255.value
                                      Dann war der * nicht mehr zulässig.
                                      daraus wurde dann: smartmeter.0.1-0:2_8_0_255.value
                                      und nun eben: smartmeter.0.1-0:2_8_0__255.value
                                      In sql sind sie aber weiterhin bei * gespeichert.
                                      Deshalb ja auch der alias.
                                        @bahnuhr Das ist ein Alias im Adapter SmartMeter. Der loggt dann (bei mir) die Daten unter "Haushaltsstrom" in der SQL Datenbank.
                                        Ich versuche das vom Adapter zu entkoppeln.
                                        apollon77 bahnuhr 2 Replies Last reply Reply Quote 0
                                          Ich muss mich jetzt für 2 Stunden abmelden, das Mittagessen ruft! 🍗
                                            apollon77 @MartyBr last edited by
                                            @MartyBr der alias gilt im History Adapter ... oder verstehe ich da was falsch gerade.
                                            smartmeter
                                            16
                                            130
                                            15168
