    4. Test Adapter lovelace v0.2.x
    • marcuskl
      marcuskl @WW1983 last edited by
      @WW1983 Ja auf jedenfall !
      Ok danke dir, werde ich versuchen.
      Ja klar hier:
      transparent:
          #Background image
          background: center / cover no-repeat url("/cards/background.jpg") fixed
          # Main colors
          primary-color: '##363941'                                                        # Header
          accent-color: '#E45E65'                                                         # Accent color
          dark-primary-color: 'var(--accent-color)'                                       # Hyperlinks
          light-primary-color: 'var(--accent-color)'                                      # Horizontal line in about
          ha-card-border-radius: '20px'
          ha-card-background: 'rgba(150, 150, 150, 0.1)'
          # Text colors
          primary-text-color: '#FFFFFF'                                                   # Primary text colour, here is referencing dark-primary-color
          text-primary-color: 'var(--primary-text-color)'                                 # Primary text colour
          secondary-text-color: '#5294E2'                                                 # For secondary titles in more info boxes etc.
          disabled-text-color: '#7F848E'                                                  # Disabled text colour
          label-badge-border-color: 'green'                                               # Label badge border, just a reference value
          # Background colors
          primary-background-color: '#383C45'                                             # Settings background
          secondary-background-color: '#383C45'                                           # Main card UI background
          divider-color: 'rgba(0, 0, 0, .12)'                                             # Divider
          # Table rows
          table-row-background-color: '#353840'                                           # Table row
          table-row-alternative-background-color: '#3E424B'                               # Table row alternative
          # Nav Menu
          paper-listbox-color: 'var(--primary-color)'                                     # Navigation menu selection hoover
          paper-listbox-background-color: '#2E333A'                                       # Navigation menu background
          paper-grey-50: 'var(--primary-text-color)'
          paper-grey-200: '#414A59'                                                       # Navigation menu selection
          # Paper card
          paper-card-header-color: 'var(--accent-color)'                                  # Card header text colour
          paper-card-background-color: 'rgba(150, 150, 150, 0.1)'                         # Card background colour
          paper-dialog-background-color: '#434954'                                        # Card dialog background colour
          paper-item-icon-color: 'var(--primary-text-color)'                              # Icon color
          paper-item-icon-active-color: '#F9C536'                                         # Icon color active
          paper-item-icon_-_color: 'green'
          paper-item-selected_-_background-color: '#434954'                               # Popup item select
          paper-tabs-selection-bar-color: 'green'
          # Labels
          label-badge-red: 'var(--accent-color)'                                          # References the brand colour label badge border
          label-badge-text-color: 'var(--primary-text-color)'                             # Now same as label badge border but that's a matter of taste
          label-badge-background-color: '#2E333A'                                         # Same, but can also be set to transparent here
          label-badge-background: 'rgba(255, 255, 255, 0.1)'
          # Switches
          paper-toggle-button-checked-button-color: 'var(--accent-color)'
          paper-toggle-button-checked-bar-color: 'var(--accent-color)'
          paper-toggle-button-checked-ink-color: 'var(--accent-color)'
          paper-toggle-button-unchecked-button-color: 'var(--disabled-text-color)'
          paper-toggle-button-unchecked-bar-color: 'var(--disabled-text-color)'
          paper-toggle-button-unchecked-ink-color: 'var(--disabled-text-color)'
          # Sliders
          paper-slider-knob-color: 'var(--accent-color)'
          paper-slider-knob-start-color: 'var(--accent-color)'
          paper-slider-pin-color: 'var(--accent-color)'
          paper-slider-active-color: 'var(--accent-color)'
          paper-slider-container-color: 'linear-gradient(var(--primary-background-color), var(--secondary-background-color)) no-repeat'
          paper-slider-secondary-color: 'var(--secondary-background-color)'
          paper-slider-disabled-active-color: 'var(--disabled-text-color)'
          paper-slider-disabled-secondary-color: 'var(--disabled-text-color)'
          # Google colors
          google-red-500: '#E45E65'
          google-green-500: '#39E949'
        WW1983 @Thorsten Zai last edited by
        @Thorsten-Zai
        Funktioniert das manuelle Zuweisen (nicht über Raum u. Funktion) auch nicht?
        Thorsten Zai 1 Reply Last reply Reply Quote 0
          WW1983 @marcuskl last edited by
          @marcuskl
          Vielen Dank!
          • schmallaria
            schmallaria last edited by schmallaria
            bin recht neu in der Welt von ioBroker unterwegs und versuche gerade den AccuWeather Adapter zusammen mit Lovelace-UI zum laufen zu bringen. Ich scheitere allerdings darin, dass ich in der Lovelace-UI Konfiguration die entsprechende Wetter-Entität nicht angezeigt bekomme.
            Versionen:
            AccuWeather-Adapter: 1.1.1
            Lovelace-UI: 0.2.3
            Mit den Adaptern yr.no oder DasWetter funktioniert es.
            Wie beschrieben habe ich in den Aufzählungen einen Raum "Any" und die Funktion "Weather" angelegt und das dann entsprechend an den Objekten konfiguriert.
            Die gewünschte Entität wird aber nicht erzeugt. Als nächste habe ich dann mal den Lovelace-UI Adapter auf Debug gestellt und bekomme im Log dann die Meldung:
            [Type-Detector] device accuweather.0.Summary.CurrentDateTime - info - accuweather.0.Summary is not yet supported
            Von der Meldung ausgehend habe ich mir dann mal den Lovelace-UI Adapater genauer angesehen. Dort gibt es in der server.js eine Methode namens _processIobState. Hier wird der o.g. Fehler erzeugt und zwar weil mein Wetter-Objekt mit dem "control type == info" erkannt wird. Damit in dem Adapter aber die richtige Konvertierungsmethode aufgerufen wird, müsste es eigentlich "control type == accuWeatherForecast" sein.
            Hat das schon mal jemand zum Laufen gebracht?
            Wie genau funktioniert der Type-Detector und wie kann ich die Ermittlung der entsprechenden Typen beeinflussen?
            Vorab schonmal Danke
            W A 2 Replies Last reply Reply Quote 0
              WW1983 @schmallaria last edited by
              @schmallaria
              Für AccuWeather gibt es eine extra custom Card. Die musst gesondert installiert werden. Mit dem normalen Wetter Card funktioniert das nicht.
              Hier ist die Card:
              https://github.com/algar42/IoB.lovelace.accuweather-card
              schmallaria 1 Reply Last reply Reply Quote 0
              • schmallaria
                schmallaria @WW1983 last edited by
                @WW1983
                Die habe ich gesehen und auch installiert. Das ist aber nicht das Problem.
                Mir fehlt die entsprechende Entität in der Konfiguration des Lovelace-UI Adapater
                Das warum habe ich versucht in meinem vorhergehenden Post zu erklären.
                • Thorsten Zai
                  Thorsten Zai @WW1983 last edited by Thorsten Zai
                  @WW1983 said in Test Adapter lovelace v0.2.x:
                  @Thorsten-Zai
                  Hallo , vielen Dank für die Antwort.
                  Da muss ich mich mal kurz doof stellen, manuell zuweisen heisst über die Webseite den Entity konfigurieren ?
                  Da bin ich leider vom Kenntnisstand raus.
                  Vielleicht noch ein Hinweis, bei der alten, sowie auch komplett neuen iobroker Installation habe ich im Log immer folgendes stehen :
                  lovelace.0 2019-12-05 22:32:28.737 error (5244) Cannot find view "custom" for search "state" : null
                  Edit sagt : steht mehrmals im Log aber kein erkennbarer Rythmus
                  Danke vorab
                  Thorsten
                  W G 2 Replies Last reply Reply Quote 0
                    @Thorsten-Zai
                    Hallo Thorsten. Nein, wenn du in die Objekte gehst und dort den Datenpunkt den du einstellen willst suchst, dort gibt eine Schraubenschlüssel. Wenn du diesen aufmachst, kannst du Einstellungen für Lovelace vornehmen. Und dort die Entity manuell definieren.
                    • Thorsten Zai
                      @Thorsten-Zai
                      Hi nochmals,
                      habe ich auch getestet .. leider mit dem gleichen Ergebnis.
                      Echt schade, mir erklärt sich auch nicht, trotz Neuinstallation, warum das nicht klappt.
                      Bei iqcontrol klappt es auch oder bei MaterialUI
                      Was könnte es denn mit der Fehlermeldung die ich habe auf sich haben ?
                      Thorsten
                      • JB1985
                        JB1985 last edited by JB1985
                        weiß jemand wie ich den State "true" "false" umändern kann?
                        type: glance
                        entities:
                          - entity: sensor.Name_anwesend
                            icon: 'mdi:home'
                        show_state: true
                        show_icon: true
                        columns: 3
                        true soll anwesend sein und false abwesend.
                        Jemand eine Idee?
                          cavediver last edited by
                          welchen 'entity type' verwendet ihr für Bewegungsmelder und Tür- und Fensterkontakte? In der Liste der Typen fehlt leider 'binary_sensor', der lt. Dokumentation am besten passen würde. Type 'sensor' funktioniert leider nicht bei Zustandsaufzeichnug mit 'mini-graph-card' und 'history'. Alternative: 'input_boolean' hat wieder den Nachteil, dass man den Wert mittels Schalter setzen kann – auch nicht optimal…
                          Wo findet man eine gute Beschreibung, welche Typen für welche Komponenten verwendet werden sollten?
                          Vielen Dank!
                          • Henning Hi
                            Henning Hi last edited by Henning Hi
                            ich beschäftige mich seit dem Wochenende mit dem Lovelace-Adapter und finde diesen echt Klasse. Bei einem Punkt komme ich aber einfach nicht weiter:
                            Ich möchte Variablen, die nicht aus physischen Geräten stammen, also etwa meine Variable für den Stromverbrauch der letzten Woche in Lovelace einbinden. Ich habe sämtliche Entities-Types durchprobiert, aber keiner liefert mir den Wert in einer Karten. Die einfach "Entities-Card" würde mir schon reichen.
                            Da diese Variable keinen Raum oder Funktion hat, habe ich mir unter "Aufzählungen" in ioBroker jeweils eine Function und Raum ausgedacht, die ich der Variable zugewiesen habe. Aber auch das bringt nichts. Was mache ich hier falsch? Welcher Typ ist richtig um auch einfache Variablen anzeigen zu können?
                              BastelKlaus @Henning Hi last edited by
                              @Henning-Hi schau mal hier, wenn ich das richtig sehe hast du einen "-" drin damit funktioniert es nicht.
                              @BastelKlaus sagte in Test Adapter lovelace v0.2.x:
                              Issue erstellt (Node-RED Daten werden nicht mit glance darstellt) --- Issue gelöst danke nochmal an @algar42
                              Lösung des Problems steckt im Unique Name des Objekts, hier darf kein- verwendet werden nur _ sind erlaubt.
                              • marcuskl
                                ich habe ein Problem und finde nicht die Lösung.
                                Ich möchte in einer custom button entity card ein button schalten (also ein Objekt type button) ohne das dieser immer ein true/false macht sondern einfach nur tastend?
                                Bluefox 1 Reply Last reply Reply Quote 0
                                • marcuskl
                                  Ich habe mir jetzt mit der Button Card eine RGB Farbsteuerung gebastelt und teile diese mit euch, falls jemand auch mal endlich seine RGB Beleuchtung steuern will.
                                  Ich habe Datenpunkte für ein paar Farben angelegt und lasse mit Blockly die Farbe verändern.
                                  type: vertical-stack
                                  cards:
                                   - type: horizontal-stack
                                     cards:
                                       - type: entities
                                         title: Wohnzimmer
                                         entities:
                                           - entity: light.Wohnzimmerlicht
                                           - entity: light.Stehlampe
                                           - entity: input_number.stehlampe_helligkeit
                                             name: Stehlampe Helligkeit
                                             icon: 'mdi:brightness-6'
                                           - entity: light.RGB_Fernseher
                                           - entity: input_number.led_stripes_helligkeit
                                             name: LED Stripes Helligkeit
                                           - entity: light.Weihnachtsbaum
                                     title: Wohnzimmer Farbwahl
                                     cards:
                                       - type: 'custom:button-card'
                                         color_type: blank-card
                                         styles:
                                           card:
                                             - height: 40px
                                             - width: 40px
                                         icon: 'mdi:palette'
                                         styles:
                                           card:
                                             - height: 40px
                                             - width: 40px
                                         entity: switch.red
                                         color_type: card
                                         show_icon: false
                                         show_name: false
                                         state:
                                           - value: 'on'
                                             color: 'rgb(245, 98, 93)'
                                             styles:
                                               card:
                                                 - height: 40px
                                                 - width: 40px
                                           - value: 'off'
                                             styles:
                                               card:
                                                 - height: 40px
                                                 - width: 40px
                                         entity: switch.blue
                                         color_type: card
                                         show_icon: false
                                         show_name: false
                                         state:
                                           - value: 'on'
                                             color: 'rgb(93, 126, 245)'
                                             styles:
                                               card:
                                                 - height: 40px
                                                 - width: 40px
                                           - value: 'off'
                                             styles:
                                               card:
                                                 - height: 40px
                                                 - width: 40px
                                         entity: switch.green
                                         color_type: card
                                         show_icon: false
                                         show_name: false
                                         state:
                                           - value: 'on'
                                             color: 'rgb(93, 245, 96)'
                                             styles:
                                               card:
                                                 - height: 40px
                                                 - width: 40px
                                           - value: 'off'
                                             styles:
                                               card:
                                                 - height: 40px
                                                 - width: 40px
                                         entity: switch.violett
                                         color_type: card
                                         show_icon: false
                                         show_name: false
                                         state:
                                           - value: 'on'
                                             color: 'rgb(232, 93, 245)'
                                             styles:
                                               card:
                                                 - height: 40px
                                                 - width: 40px
                                           - value: 'off'
                                             styles:
                                               card:
                                                 - height: 40px
                                                 - width: 40px
                                         entity: switch.turkis
                                         color_type: card
                                         show_icon: false
                                         show_name: false
                                         state:
                                           - value: 'on'
                                             color: 'rgb(93, 245, 210)'
                                             styles:
                                               card:
                                                 - height: 40px
                                                 - width: 40px
                                           - value: 'off'
                                             styles:
                                               card:
                                                 - height: 40px
                                                 - width: 40px
                                     cards:
                                         styles:
                                           card:
                                             - height: 40px
                                             - width: 40px
                                         icon: 'mdi:thermometer'
                                         styles:
                                           card:
                                             - height: 40px
                                             - width: 40px
                                         entity: switch.warmweiß
                                         color_type: card
                                         show_icon: false
                                         show_name: false
                                         state:
                                           - value: 'on'
                                             color: 'rgb(255, 202, 87)'
                                             styles:
                                               card:
                                                 - height: 40px
                                                 - width: 40px
                                           - value: 'off'
                                             styles:
                                               card:
                                                 - height: 40px
                                                 - width: 40px
                                         entity: switch.kaltweiß
                                         color_type: card
                                         show_icon: false
                                         show_name: false
                                         state:
                                           - value: 'on'
                                             color: 'rgb(255, 254, 252)'
                                             styles:
                                               card:
                                                 - height: 40px
                                                 - width: 40px
                                           - value: 'off'
                                             styles:
                                               card:
                                                 - height: 40px
                                                 - width: 40px
                                  JB1985 1 Reply Last reply Reply Quote 0
                                  • Bluefox
                                    Bluefox @marcuskl last edited by
                                    @marcuskl man kann mit einem skript den Button wieder auf False setzen.
                                    marcuskl 1 Reply Last reply Reply Quote 0
                                    • marcuskl
                                      marcuskl @Bluefox last edited by
                                      @Bluefox sagte in Test Adapter lovelace v0.2.x:
                                      Ah ja stimmt, die Idee ist mir nicht gekommen.
                                      Danke !
                                      • JB1985
                                        Lovelace scheint ja den Bug zu haben, dass das Passwort für den Alarm nicht speichern lässt.
                                        Ich hab schon ein Bug in Github gemeldet, allerdings hat darauf noch keiner geantwortet.
                                        Weiss jemand wie man den Standardcode 1234 irgendwo im Sourcecode ändern kann?
                                        Das ist leider so überhaupt nicht brauchbar, wenn der Alarmcode jedesmal auf 1234 überschrieben wird.
                                          g.polat @JB1985 last edited by
                                          @JB1985 sagte in Test Adapter lovelace v0.2.x:
                                          leg dir einen eigenen Alarm Datenpunkt an und kopiere aus der RAW von Lovelace, so hat es bei mir geklappt.
                                          • JB1985
                                            JB1985 @g.polat last edited by
                                            @g-polat Danke! Werde ich gleich mal probieren.
                                            call for action lovelace test visualisierung
                                            131
                                            1051
                                            376430
