      toki1973 @Homoran last edited by toki1973
      admin.0
      2019-12-12 15:28:55.232
      debug
      Disable logging, because no one socket connected
      backitup.0
      2019-12-12 15:27:34.558
      debug
      sendTo "getTelegramUser" to system.adapter.admin.0 from system.adapter.backitup.0: {"571415110":"to"}
      admin.0
      2019-12-12 15:27:34.478
      debug
      Subscribes: backitup.0.*, system.adapter.backitup.0.alive
      admin.0
      2019-12-12 15:27:34.477
      debug
      admin.0
      2019-12-12 15:27:34.471
      debug
      sendTo "getTelegramUser" to system.adapter.backitup.0 from system.adapter.admin.0
      backitup.0
      2019-12-12 15:26:52.375
      debug
      [minimal] 10 00 02 */1 * *
      backitup.0
      2019-12-12 15:26:52.306
      info
      [minimal] backup was activated at 02:00 every 1 day(s)
      backitup.0
      2019-12-12 15:26:52.135
      info
      starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.16.0
      backitup.0
      2019-12-12 15:26:51.954
      debug
      statesDB connected
      backitup.0
      2019-12-12 15:26:51.768
      debug
      objectDB connected
      host.raspberrypi
      2019-12-12 15:26:44.129
      info
      instance system.adapter.backitup.0 started with pid 23932
      host.raspberrypi
      2019-12-12 15:26:42.176
      info
      instance system.adapter.backitup.0 terminated with code 156 ()
      host.raspberrypi
      2019-12-12 15:26:41.593
      info
      stopInstance system.adapter.backitup.0 killing pid 23606
      host.raspberrypi
      info
      host.raspberrypi
      2019-12-12 15:26:41.592
      info
      object change system.adapter.backitup.0
      admin.0
      2019-12-12 15:25:22.334
      debug
      Subscribes: system.adapter.*, system.host.*, *.info.connection
      admin.0
      2019-12-12 15:25:22.329
      debug
      admin.0
      2019-12-12 15:25:21.418
      debug
      admin.0
      2019-12-12 15:25:21.286
      debug
      admin.0
      2019-12-12 15:25:21.283
      debug
      Subscribe STATES: system.adapter.backitup.0.alive
      admin.0
      2019-12-12 15:25:21.261
      debug
      admin.0
      2019-12-12 15:25:21.258
      debug
      Subscribe STATES: backitup.0.*
      admin.0
      2019-12-12 15:25:19.330
      debug
      Subscribe OBJECTS: system.host.*
      admin.0
      2019-12-12 15:25:19.329
      debug
      Subscribe OBJECTS: system.adapter.*
      admin.0
      2019-12-12 15:25:19.328
      debug
      admin.0
      2019-12-12 15:25:19.327
      debug
      Subscribe STATES: *.info.connection
      admin.0
      2019-12-12 15:25:19.326
      debug
      admin.0
      2019-12-12 15:25:19.324
      debug
      Subscribe STATES: system.host.*
      admin.0
      2019-12-12 15:25:19.307
      debug
      admin.0
      2019-12-12 15:25:19.298
      debug
      Subscribe STATES: system.adapter.*
      admin.0
      2019-12-12 15:25:18.953
      debug
      Next repo update on 12/12/2019, 7:11:46 PM
      admin.0
      2019-12-12 15:25:18.304
      debug
      system.adapter.admin.0: logging true
      admin.0
      2019-12-12 15:25:18.269
      debug
      Subscribes: dummy
      admin.0
      2019-12-12 15:25:18.260
      debug
      Change log subscriber state: true
      admin.0
      2019-12-12 15:25:18.258
      debug
      Subscribe LOGS
      admin.0
      2019-12-12 15:25:17.910
      debug
      Subscribe OBJECTS: *
        Homoran Global Moderator Administrators @toki1973 last edited by
        @toki1973 Bitte in Code-Tags </> setzen
          @Homoran hatte ich gleich korrigiert. wie kann ich prüfen ob gemounted wird?
            @toki1973 sagte in Test Adapter Backitup v1.3.x:
            Ich kenne dein NAS nicht, weiß nicht mal was du benutzst.
            Auf der Synology sieht man das in dessen WebUI:
            Gut dass wir gesprochen haben 😉
            da hatte sich auch einer nicht ausgeloggt!
            Backitup Instanz des entsprechenden Servers neu gestartet und der mount war weg
              Habe auch eine Synoligy.Der Backup User ist nicht über cifs verbunden
                @toki1973
                Hast du jetzt nochmal versucht den Timer auf eine nahe Zeit zu stellen bei der das Backup starten soll?
                In deinem log steht das:
                backitup.0
                info
                bis 02:00 wollte ich jetzt nicht warten.
                Was passiert denn bei einem manuellen start des Backups
                  @Homoran Ich t
                  Test ja die ganze Zeit mi dem manuellen Backup;) Nur der Fenster Dialog geht auf und bleibt bei der Meldung oben einfach stehen.
                  Homoran simatec 3 Replies Last reply Reply Quote 0
                    Homoran Global Moderator Administrators @toki1973 last edited by Homoran
                    Ich t
                    Da sehe ich nichts von im log!
                    sieht bei mir unter debug so aus:
                    2019-12-12 19:19:33.738 - debug: backitup.0 [minimal/mount] done
                    2019-12-12 19:19:37.685 - debug: backitup.0 [minimal/minimal] Backup created: /opt/iobroker/backups/minimal_2019_12_12-19_19_33_VM01_backupiobroker.tar.gz
                    2019-12-12 19:19:37.728 - debug: backitup.0 [minimal/minimal] done
                    2019-12-12 19:19:37.730 - debug: backitup.0 [minimal/cifs] done
                    2019-12-12 19:19:37.731 - debug: backitup.0 [minimal/clean] done
                    2019-12-12 19:19:37.743 - debug: backitup.0 [minimal/history] backitup.0.history.html
                    2019-12-12 19:19:37.754 - debug: backitup.0 [minimal/umount] mount activ... umount in 60 Seconds!!
                    • simatec
                      simatec Developer Most Active @toki1973 last edited by
                      @toki1973
                      Stelle die Instanz von Backitup auf debug und poste den Log, wenn du das Backup ausführst.
                      Welche Version hast du installiert?
                      Wie ist dein System sonst aufgebaut?
                      node, npm, js-contoller Versionen?
                        toki1973 @simatec last edited by
                        @simatec @Homoran
                        RASP 3
                        Platform       : linux
                        Architecture   : arm
                        CPUs           : 4
                        Speed          : 1200 MHz
                        Model          : ARMv7 Processor rev 4 (v7l)
                        RAM            : 926 MB
                        System uptime  : 21d. 04:45:56
                        Node.js        : v10.16.0
                        Disk size      : 14.4 GiB
                        Disk free      : 11.1 GiB
                        adapters count : 262
                        NPM            : v6.9.0
                        Und im Log tut sich nicht viel:
                        backitup.0
                        2019-12-12 19:33:03.647
                        debug
                        backitup.0
                        2019-12-12 19:33:03.589
                        info
                        backitup.0
                        2019-12-12 19:33:03.427
                        info
                        backitup.0
                        2019-12-12 19:33:03.264
                        debug
                        statesDB connected
                        backitup.0
                        2019-12-12 19:33:03.166
                        debug
                        objectDB connected
                        Homoran simatec 2 Replies Last reply Reply Quote 0
                          @toki1973
                          mich irritiert dein log in mehrfacher hinsicht.
                          1.) Wieso hast du da Zeilenumbrüche drin?
                          2.) Die Zeile: backitup.0 2019-12-12 19:33:03.647 debug [minimal] 10 00 02 */1 * *
                          taucht bei mir überhaupt nicht auf.
                          Außerdem ist der Cron 6-stellig mit 10 Sekunden zur Vollen 2. Stunde.
                          Wieso das?
                          T simatec 2 Replies Last reply Reply Quote 0
                            @Homoran
                            Ich habe einfach aus dem Log Tab heraus kopiert. Der Cron wird ja hier eingestellt.
                            ![alt text](c328d4d5-a75a-4cad-86a2-f6f0b3a04af9-image.png image url)
                            • simatec
                              @Homoran sagte in Test Adapter Backitup v1.3.x:
                              Wieso das?
                              Das ist so korrekt
                              Es wird immer 10 Sekunden später ausgeführt
                              • simatec
                                Kann ja auch nicht, wenn du 2 Uhr eingestellt hast.
                                  @simatec
                                  Ich t
                                  • simatec
                                    Ab sofort ist die Version 1.3.3 im Github und ab spätestens heute Nacht auch in der latest Repo.
                                    Changelog
                                    1.3.3 (14.12.2019)
                                    • (simatec) Fix Webinterface for Restore
                                    • (simatec) Fix MySql Backup
                                    • (simatec) Added some debug logs for Restore
                                    • (simatec) some Bug Fix
                                    • (simatec) Messagebox for restore list
                                    • (simatec) hide password on log
                                    • (simatec) Added password hiding
                                    • (simatec) Clean Code
                                    • (simatec) detected history path
                                    • (simatec) Fix deteced
                                    • MathiasJ
                                      MathiasJ last edited by MathiasJ
                                      bin wieder auf die 1.3.2 zurück.
                                      IObroker rödelt sich zu tode und nichts passiert.
                                      Das Popup bleibt leer, bzw ich sehe nur Backup gestartet, das war's
                                      Wenn ich dann in der ordner /opt/iobroker/backup gehe, habe ich hier gefühlte 1000 backups liegen. Diese werden aber nicht auf die NAS - Dropbox - FTP und Googledrive weitergereicht.
                                        Homoran Global Moderator Administrators @MathiasJ last edited by Homoran
                                        @MathiasJ
                                        Bitte Instanz auf debug stellen und log posten.
                                        J MathiasJ 2 Replies Last reply Reply Quote 0
                                        • simatec
                                          simatec Developer Most Active @MathiasJ last edited by
                                          @MathiasJ
                                          Diese Aussagen helfen leider nicht.
                                          Bitte poste den Debug Log.
                                          Gibt es errors?
                                          Was für Backups wolltest du erstellen?
                                            Jan1 @Homoran last edited by
                                            @Homoran
                                            Mir ist da eben was aufgefallen.
                                            Der Ordner backups im IOBroker Verzeichnis wird beim Backup erstellen an gemeckert. Ich habe mir dann das mal angesehen und der ist nicht mehr vorhanden. Also von Hand angelegt und jetzt wirds seltsam, in der Konsole kann ich ihn sehen:
                                            root@Beelink:/opt/iobroker# ls
                                            backups                       iob            node_modules
                                            CHANGELOG_FIXER_LINUX.md      iobroker       package.json
                                            CHANGELOG_INSTALLER_LINUX.md  iobroker-data  package-lock.json
                                            fix_installation.sh           lib            README.md
                                            install                       LICENSE        reinstall.js
                                            in FileZilla nicht:
                                            und wenn ich den Fixer laufen lasse, dann kommt auch ne Fehlermeldung genau zu dem Ordner:
                                            Created /etc/sudoers.d/iobroker
                                            Fixing directory permissions...
                                            chown: Zugriff auf '/opt/iobroker/backups' nicht möglich: Der Rechner ist nicht aktiv
                                            This system does not support setting default permissions.
                                            Do not use npm to manually install adapters unless you know what you are doing!
                                            Was ist denn da los?
                                            Die Backups werden aber korrekt angelegt:
                                            Log vom Backup:
                                            Gestartet...
                                            [DEBUG] [mount] - mount activ... umount is started before mount!!
                                            [DEBUG] [mount] - done
                                            [DEBUG] [iobroker] - host.Beelink 6477 states saved
                                            [DEBUG] [iobroker] - host.Beelink 4684 objects saved
                                            [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2019_12_15-10_46_41_BeeLink_backupiobroker.tar.gz
                                            [DEBUG] [iobroker] - done
                                            [ERROR] [historyDB] - [IGNORED] No source for compress!
                                            [DEBUG] [zigbee] - done
                                            [DEBUG] [cifs] - done
                                            [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
                                            [DEBUG] [clean] - done
                                            [DEBUG] [history] - backitup.0.history.html
                                            [DEBUG] [umount] - mount activ... umount in 60 Seconds!!
                                            [DEBUG] [umount] - done
                                            [EXIT] 0
                                            170
                                            2780
                                            2363914
