    4. Neuling?
    Neuling?
    • fischi87
      fischi87 last edited by
      Sowas steht bei mir nicht?!
      [{"id":"46eaf489.b9150c","type":"inject","name":"Start","topic":"","payload":"","payloadType":"string","repeat":"900","crontab":"","once":false,"x":77.21598815917969,"y":62.86397933959961,"z":"3249cd7d.cdb632","wires":[["e832faba.17cd08"]]},{"id":"e832faba.17cd08","type":"http request","name":"Wetterinfo für Strehla über API-Key","method":"GET","ret":"obj","url":"http://api.openweathermap.org/data/2.5/ … 32":[["d69796bc.296868","62ede8a7.9d1218"]]},{"id":"d69796bc.296868","type":"function","name":"Daten extrahieren","func":"msg1 = {};\nmsg1.payload = msg.payload.main.temp;\nmsg2 = {};\nmsg2.payload = msg.payload.main.pressure;\nmsg3 = {};\nmsg3.payload = msg.payload.main.humidity;\nmsg4 = {};\nmsg4.payload = msg.payload.wind.speed;\nmsg5 = {};\nmsg5.payload = msg.payload.wind.deg;\n\nreturn [msg1,msg2,msg3,msg4,msg5];","outputs":"5","noerr":0,"x":631.2159881591797,"y":145.8639793395996,"z":"3249cd7d.cdb632","wires":[["49311bdd.b6cee4"],["1782aa54.e87d56"],["bd7c22f9.4283e"],["f39debec.0c6218"],["b02f0df9.4fd0f"]]},{"id":"49311bdd.b6cee4","type":"ioBroker out","name":"Außentemperatur","topic":"hm-rega.0.4764","ack":"false","autoCreate":"true","x":921.6127166748047,"y":62.86397933959961,"z":"3249cd7d.cdb632","wires":[]},{"id":"1782aa54.e87d56","type":"ioBroker out","name":"Luftdruck","topic":"hm-rega.0.4765","ack":"false","autoCreate":"false","x":899.0413055419922,"y":113.32455062866211,"z":"3249cd7d.cdb632","wires":[]},{"id":"bd7c22f9.4283e","type":"ioBroker out","name":"Luftfeuchtigkeit","topic":"hm-rega.0.4766","ack":"false","autoCreate":"false","x":917.6127166748047,"y":159.4673728942871,"z":"3249cd7d.cdb632","wires":[]},{"id":"f39debec.0c6218","type":"ioBroker out","name":"Windgeschwindigkeit","topic":"hm-rega.0.4767","ack":"false","autoCreate":"false","x":938.4698944091797,"y":209.75320053100586,"z":"3249cd7d.cdb632","wires":[]},{"id":"b02f0df9.4fd0f","type":"ioBroker out","name":"Windrichtung","topic":"hm-rega.0.4768","ack":"false","autoCreate":"false","x":918.6127166748047,"y":257.7530174255371,"z":"3249cd7d.cdb632","wires":[]},{"id":"62ede8a7.9d1218","type":"debug","name":"Ausgabe","active":true,"console":"false","complete":"payload","x":625.2159881591797,"y":62.86397933959961,"z":"3249cd7d.cdb632","wires":[]}]
        HKF8770 last edited by
        Hallo Paul,
        kannst du mir sagen wir mann da rundet?? Bei java ist das ja .toFixed(2). Somit kann ich dann nen Wert runden auf 2 Stellen nach dem Komma. Aber bei Node geht der Befehl nicht. Was du ne Lösung?
          paul53 last edited by
          @fischi87:
          Sowas steht bei mir nicht?! Die einzige Stelle, an der man drehen kann, sehe ich bei > msg1.payload = msg.payload.main.temp Vielleicht hilft ein Ersetzen durch ?: > msg1.payload = msg.payload.main.temp.toFixed(2) `
          • Bluefox
            Bluefox last edited by
            @paul53:
            @fischi87:
            toFixed erwartet schon number als Typ. Deswegen:
            msg.payload = parseFloat(egalWas || 0).toFixed(2);
              @Bluefox:
              toFixed erwartet schon number als Typ. `
              Laut http://openweathermap.org/current sollte Typ "number" geliefert werden.
              Mit parseFloat(wert) ist es natürlich sicherer und sieht dann im konkreten Fall so aus:
              msg1.payload = parseFloat(msg.payload.main.temp).toFixed(2)
              • fischi87
                hey paul53,
                viele dank dein code hat funktioniert, nur wenn ich das übertrage auch auf "speed" steht bei mir in der ccm nur "nan" da????
                Mit freundlichen Grüßen
                  msg4.payload = parseFloat(msg.payload.wind.speed).toFixed(2)
                  funktioniert nicht ?
                  "nan" erzeugt Javascript, wenn Typ "number" erwartet wird, aber nicht vorliegt.
                  • fischi87
                    nein funktioniert leider nicht, selbst wenn ich das jetzt wieder ändere in original zustand komm ich nicht wieder auf die zahl??????
                    was mir auch gerade auffällt, ich bekomme jetzt immer eine 0 nach dem Komma auch wenn eine zahl übermittelt wird???
                    • fischi87
                      so jetzt hat es doch funktioniert, sorry hab mal neu gestartet, jetzt funktioniert alles, danke euch
                      ps. hab noch viel zu lernen was node-red betrifft, wo findet man die befehle und ihre Bedeutung?
                      • fischi87
                        hey paul53 ich nochmal, vielleicht kannst du oder jemand anderes nochmal helfen?!
                        wie gesagt versuche mir node-red irgendwie beizubringen.
                        ich habe vor per sind adapter eine sv zu schalten d.h. wenn alles Geräte in mehr im plan sind soll die sv sich ändern aber was schreibt man da für eine Funktion rein oder wie realisiert man dies?
                        das ist der Anfang:
                        [{"id":"f7a2cf94.085d3","type":"ioBroker in","name":"PS 4","topic":"ping.0.RaspberryPi.192_168_178_31","payloadType":"value","x":136,"y":434,"z":"751d0e6f.8ae2f","wires":[[]]}]
                        • fischi87
                          @fischi87:
                          das ist der Anfang:
                          danke Mit freundlichen Grüßen
                            Von node-red habe ich nicht die geringste Ahnung. Lediglich mit der darin eingebetten Javascript-Funktion (hinter "func":) kann ich etwas anfangen.
                            • fischi87
                              und kannst du mir da mit meinem Projekt helfen? ich werde ja eine Funktion brauchen und den true and false status der jeweiligen Geräte zu erkennen und dann eine "wenn oder" Auswertung zu bekommen?!
                                Bei der Funktion kann ich Dir sicherlich helfen, wenn Du genau beschreibst, was diese Funktion machen soll und was die Eingangs- und Ausgangsgrößen sind.
                                  So sieht die Javascript-Lösung für die Aufgabenstellng aus:
                                  var request = require('request');
                                  var url = 'http://api.openweathermap.org/data/2.5/weather?q=Strehla,DE&units=metric&APPID=e5de2c3e2339a69b6d181c0cb9d2e5d8';
                                  var wetter = {};
                                  // alle 15 Minuten
                                  schedule("*/15 * * * *", function () {
                                      request(url, function(error, response, body) {
                                      if (!error && response.statusCode == 200) {
                                          wetter = JSON.parse(body);
                                          setState("hm-rega.0.4764",wetter.main.temp.toFixed(2) + " °C");
                                          setState("hm-rega.0.4765",wetter.main.pressure.toFixed(1) + " hPa");
                                          setState("hm-rega.0.4766",wetter.main.humidity;.toFixed(0) + " %");
                                          setState("hm-rega.0.4767",wetter.wind.speed.toFixed(1) + " m/s");
                                          setState("hm-rega.0.4768",wetter.wind.deg.toFixed(0) + " °");
                                  3828
