    4. Test Adapter tr-064-community v1.0.x
    • conectas
      conectas @apollon77 last edited by
      @apollon77 sagte in Test Adapter tr-064-community v1.0.x:
      /opt/iobroker/node_modules/iobroker.tr-064-community/
      pollingTimer = setTimeout(updateAll, 2000);
        apollon77 @conectas last edited by apollon77
        @conectas na wenn’s wieder tut mit debug dann kommentiert nix aus 😉
        Müsste ein Adapter.log.debug
        conectas 1 Reply Last reply Reply Quote 0
        • conectas
          Adapter.log.debug
          949 //adapter.log.debug('Final Phonebook: ' + JSON.stringify(phonebook));
          Haste DU bereits raus gemacht 😉
            Also dann neue logs bitte und Fälle neu checken.
            conectas 3 Replies Last reply Reply Quote 0
            • conectas
              conectas @apollon77 last edited by conectas
              Fall 01: 2mal hintereinander gleicher OUT (0171) auf IN (628yxz6)
              jetzt wird nix (selbst) tr-064-community.0.callmonitor.inbound.json nicht neu geschrieben
              2019-12-12 19:58:38.454  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 19:58:38;RING;2;0171xyz;628xyz6;SIP0;\r\n"
              2019-12-12 19:58:38.456  - debug: tr-064-community.0 (15488) callmonitor handle inbound message: {"caller":"0171xyz","callee":"628xyz6"}
              2019-12-12 19:58:38.457  - debug: tr-064-community.0 (15488) Set State callmonitor.inbound.timestamp: "12.12.19 19:58:38" / ack=true
              2019-12-12 19:58:38.460  - debug: tr-064-community.0 (15488) Search number 0049171xyz in phonebook: {"name":"NNAme Stefan","normalizedName":"NNAmestefan","number":"0049171yxz","id":"634","phonebookId":"0"}
              2019-12-12 19:58:38.463  - debug: tr-064-community.0 (15488) Search number 004930628xyz6 in phonebook: {"name":"NNAme Kerstin","normalizedName":"NNAmekerstin","number":"004930628xyz6","id":"631","phonebookId":"0"}
              2019-12-12 19:58:38.465  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "ring" / ack=true
              2019-12-12 19:58:38.467  - debug: tr-064-community.0 (15488) callMonitor.set: type=inbound caller=0171xyz callee=628xyz6 callerName=NNAme Stefan calleeName=NNAme Kerstin
              2019-12-12 19:58:38.671  - debug: tr-064-community.0 (15488) Set State callmonitor.ringing: true / ack=true
              2019-12-12 19:58:38.841  - debug: tr-064-community.0 (15488) setting 0 enable=false
              2019-12-12 19:58:38.843  - debug: tr-064-community.0 (15488) setting 1 enable=false
              2019-12-12 19:58:38.843  - debug: tr-064-community.0 (15488) setting 2 enable=false
              2019-12-12 19:58:38.844  - debug: tr-064-community.0 (15488) setting 3 enable=false
              2019-12-12 19:58:38.844  - debug: tr-064-community.0 (15488) setting 4 enable=false
              2019-12-12 19:58:38.845  - debug: tr-064-community.0 (15488) setting 5 enable=true
              2019-12-12 19:58:38.845  - debug: tr-064-community.0 (15488) setting 6 enable=true
              2019-12-12 19:58:38.846  - debug: tr-064-community.0 (15488) setting 7 enable=true
              2019-12-12 19:58:38.846  - debug: tr-064-community.0 (15488) setting 8 enable=true
              2019-12-12 19:58:38.847  - debug: tr-064-community.0 (15488) setting 9 enable=true
              2019-12-12 19:58:45.625  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 19:58:45;CONNECT;2;4;0171xyz;\r\n"
              2019-12-12 19:58:45.627  - debug: tr-064-community.0 (15488) callmonitor handle connect message: {"caller":"0171xyz","callee":"628xyz6","_type":"inbound","callerName":"NNAme Stefan","calleeName":"NNAme Kerstin","extension":"4"}
              2019-12-12 19:58:45.628  - debug: tr-064-community.0 (15488) Set State callmonitor.connect.timestamp: "12.12.19 19:58:45" / ack=true
              2019-12-12 19:58:45.629  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "connect" / ack=true
              2019-12-12 19:58:45.630  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState-4: "connect" / ack=true
              2019-12-12 19:58:45.631  - debug: tr-064-community.0 (15488) callMonitor.set: type=connect caller=0171xyz callee=628xyz6 callerName=NNAme Stefan calleeName=NNAme Kerstin
              2019-12-12 19:58:45.833  - debug: tr-064-community.0 (15488) Set State callmonitor.ringing: false / ack=true
              2019-12-12 19:58:48.464  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 19:58:48;DISCONNECT;2;3;\r\n"
              2019-12-12 19:58:48.466  - debug: tr-064-community.0 (15488) callmonitor handle lastCall message: {"caller":"0171xyz","callee":"628xyz6","_type":"connect","callerName":"NNAme Stefan","calleeName":"NNAme Kerstin","extension":"4","type":"disconnect","duration":3}
              2019-12-12 19:58:48.468  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.type: "disconnect" / ack=true
              2019-12-12 19:58:48.470  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.duration: 3 / ack=true
              2019-12-12 19:58:48.472  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.timestamp: "12.12.19 19:58:48" / ack=true
              2019-12-12 19:58:48.474  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.json: "{\"caller\":\"0171xyz\",\"callee\":\"628xyz6\",\"_type\":\"lastCall\",\"callerName\":\"NNAme Stefan\",\"calleeName\":\"NNAme Kerstin\",\"extension\":\"4\",\"type\":\"disconnect\",\"duration\":3}" / ack=true
              2019-12-12 19:58:48.476  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "end" / ack=true
              2019-12-12 19:58:48.478  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState-4: "end" / ack=true
              2019-12-12 19:58:48.479  - debug: tr-064-community.0 (15488) callMonitor.set: type=lastCall caller=0171xyz callee=628xyz6 callerName=NNAme Stefan calleeName=NNAme Kerstin
              2019-12-12 19:58:48.851  - debug: tr-064-community.0 (15488) in updateAll
              2019-12-12 19:58:48.853  - debug: tr-064-community.0 (15488) updateDevices
              2019-12-12 19:58:48.854  - debug: tr-064-community.0 (15488) forEachConfiguredDevice
              2019-12-12 19:58:51.289  - debug: tr-064-community.0 (15488) setting 0 enable=false
              2019-12-12 19:58:51.290  - debug: tr-064-community.0 (15488) setting 1 enable=false
              2019-12-12 19:58:51.291  - debug: tr-064-community.0 (15488) setting 2 enable=false
              2019-12-12 19:58:51.291  - debug: tr-064-community.0 (15488) setting 3 enable=false
              2019-12-12 19:58:51.292  - debug: tr-064-community.0 (15488) setting 4 enable=false
              2019-12-12 19:58:51.292  - debug: tr-064-community.0 (15488) setting 5 enable=true
              2019-12-12 19:58:51.292  - debug: tr-064-community.0 (15488) setting 6 enable=true
              2019-12-12 19:58:51.293  - debug: tr-064-community.0 (15488) setting 7 enable=true
              2019-12-12 19:58:51.293  - debug: tr-064-community.0 (15488) setting 8 enable=true
              2019-12-12 19:58:51.295  - debug: tr-064-community.0 (15488) setting 9 enable=true
              • conectas
                Fall2:
                abwechselt:
                OUT 0171 zu 628xy6
                danach
                OUT 0171 zu 628xy7
                tr-064-community.0.callmonitor.inbound.caller
                tr-064-community.0.callmonitor.inbound.callerName
                werden nicht aktualisiert...
                2019-12-12 20:07:10.493  - debug: tr-064-community.0 (15488) in updateAll
                2019-12-12 20:07:10.495  - debug: tr-064-community.0 (15488) updateDevices
                2019-12-12 20:07:10.496  - debug: tr-064-community.0 (15488) forEachConfiguredDevice
                2019-12-12 20:07:12.959  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 20:07:12;RING;2;0171xyz;628yxz6;SIP0;\r\n"
                2019-12-12 20:07:12.960  - debug: tr-064-community.0 (15488) callmonitor handle inbound message: {"caller":"0171xyz","callee":"628yxz6"}
                2019-12-12 20:07:12.961  - debug: tr-064-community.0 (15488) Set State callmonitor.inbound.callee: "628yxz6" / ack=true
                2019-12-12 20:07:12.962  - debug: tr-064-community.0 (15488) Set State callmonitor.inbound.timestamp: "12.12.19 20:07:12" / ack=true
                2019-12-12 20:07:12.963  - debug: tr-064-community.0 (15488) Search number 0049171xyz in phonebook: {"name":"NName Stefan","normalizedName":"NNamestefan","number":"0049171xyz","id":"634","phonebookId":"0"}
                2019-12-12 20:07:12.964  - debug: tr-064-community.0 (15488) Search number 004930628yxz6 in phonebook: {"name":"NName Kerstin","normalizedName":"NNamekerstin","number":"004930628yxz6","id":"631","phonebookId":"0"}
                2019-12-12 20:07:12.964  - debug: tr-064-community.0 (15488) Set State callmonitor.inbound.calleeName: "NName Kerstin" / ack=true
                2019-12-12 20:07:12.965  - debug: tr-064-community.0 (15488) Set State callmonitor.inbound.json: "{\"caller\":\"0171xyz\",\"callee\":\"628yxz6\",\"_type\":\"inbound\",\"callerName\":\"NName Stefan\",\"calleeName\":\"NName Kerstin\"}" / ack=true
                2019-12-12 20:07:12.966  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "ring" / ack=true
                2019-12-12 20:07:12.967  - debug: tr-064-community.0 (15488) callMonitor.set: type=inbound caller=0171xyz callee=628yxz6 callerName=NName Stefan calleeName=NName Kerstin
                2019-12-12 20:07:13.168  - debug: tr-064-community.0 (15488) Set State callmonitor.ringing: true / ack=true
                2019-12-12 20:07:13.225  - debug: tr-064-community.0 (15488) setting 0 enable=false
                2019-12-12 20:07:13.226  - debug: tr-064-community.0 (15488) setting 1 enable=false
                2019-12-12 20:07:13.227  - debug: tr-064-community.0 (15488) setting 2 enable=false
                2019-12-12 20:07:13.228  - debug: tr-064-community.0 (15488) setting 3 enable=false
                2019-12-12 20:07:13.229  - debug: tr-064-community.0 (15488) setting 4 enable=false
                2019-12-12 20:07:13.229  - debug: tr-064-community.0 (15488) setting 5 enable=true
                2019-12-12 20:07:13.230  - debug: tr-064-community.0 (15488) setting 6 enable=true
                2019-12-12 20:07:13.230  - debug: tr-064-community.0 (15488) setting 7 enable=true
                2019-12-12 20:07:13.231  - debug: tr-064-community.0 (15488) setting 8 enable=true
                2019-12-12 20:07:13.231  - debug: tr-064-community.0 (15488) setting 9 enable=true
                2019-12-12 20:07:19.126  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 20:07:19;CONNECT;2;4;0171xyz;\r\n"
                2019-12-12 20:07:19.127  - debug: tr-064-community.0 (15488) callmonitor handle connect message: {"caller":"0171xyz","callee":"628yxz6","_type":"inbound","callerName":"NName Stefan","calleeName":"NName Kerstin","extension":"4"}
                2019-12-12 20:07:19.128  - debug: tr-064-community.0 (15488) Set State callmonitor.connect.callee: "628yxz6" / ack=true
                2019-12-12 20:07:19.129  - debug: tr-064-community.0 (15488) Set State callmonitor.connect.calleeName: "NName Kerstin" / ack=true
                2019-12-12 20:07:19.130  - debug: tr-064-community.0 (15488) Set State callmonitor.connect.timestamp: "12.12.19 20:07:19" / ack=true
                2019-12-12 20:07:19.131  - debug: tr-064-community.0 (15488) Set State callmonitor.connect.json: "{\"caller\":\"0171xyz\",\"callee\":\"628yxz6\",\"_type\":\"connect\",\"callerName\":\"NName Stefan\",\"calleeName\":\"NName Kerstin\",\"extension\":\"4\"}" / ack=true
                2019-12-12 20:07:19.135  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "connect" / ack=true
                2019-12-12 20:07:19.136  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState-4: "connect" / ack=true
                2019-12-12 20:07:19.137  - debug: tr-064-community.0 (15488) callMonitor.set: type=connect caller=0171xyz callee=628yxz6 callerName=NName Stefan calleeName=NName Kerstin
                2019-12-12 20:07:19.339  - debug: tr-064-community.0 (15488) Set State callmonitor.ringing: false / ack=true
                2019-12-12 20:07:20.343  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 20:07:20;DISCONNECT;2;2;\r\n"
                2019-12-12 20:07:20.344  - debug: tr-064-community.0 (15488) callmonitor handle lastCall message: {"caller":"0171xyz","callee":"628yxz6","_type":"connect","callerName":"NName Stefan","calleeName":"NName Kerstin","extension":"4","type":"disconnect","duration":2}
                2019-12-12 20:07:20.345  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.callee: "628yxz6" / ack=true
                2019-12-12 20:07:20.346  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.calleeName: "NName Kerstin" / ack=true
                2019-12-12 20:07:20.347  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.duration: 2 / ack=true
                2019-12-12 20:07:20.348  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.timestamp: "12.12.19 20:07:20" / ack=true
                2019-12-12 20:07:20.350  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.json: "{\"caller\":\"0171xyz\",\"callee\":\"628yxz6\",\"_type\":\"lastCall\",\"callerName\":\"NName Stefan\",\"calleeName\":\"NName Kerstin\",\"extension\":\"4\",\"type\":\"disconnect\",\"duration\":2}" / ack=true
                2019-12-12 20:07:20.351  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "end" / ack=true
                2019-12-12 20:07:20.352  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState-4: "end" / ack=true
                2019-12-12 20:07:20.353  - debug: tr-064-community.0 (15488) callMonitor.set: type=lastCall caller=0171xyz callee=628yxz6 callerName=NName Stefan calleeName=NName Kerstin
                2019-12-12 20:07:23.232  - debug: tr-064-community.0 (15488) in updateAll
                2019-12-12 20:07:23.234  - debug: tr-064-community.0 (15488) updateDevices
                2019-12-12 20:07:23.235  - debug: tr-064-community.0 (15488) forEachConfiguredDevice
                • conectas
                  Ich würde bei Tests dieses Script mitlaufen lassen.. oder bringt das in deinen Logs dann zu viel durcheinander?
                  let tr064 = "tr-064-community.0.callmonitor.";
                  var callerNumber    // Anrufernummer
                  var callerName      // Name des Anrufers
                  var calleeNumber    // angerufene Nummer
                  var calleeName      // angerufener Name
                  var callAllDataJson = { "caller": "caller Nr", "callee": "callee Nr", "_type": "_type inbound", "callerName": "Caller Name", "calleeName": "Callee Name" };
                  on({ id: "tr-064-community.0.callmonitor.toPauseState", change: "any" }, function (obj) {
                      console.log('---> Ringing?: ');
                      let sToPauseState = getState(tr064 + "toPauseState").val;
                      if ("ring" == sToPauseState) {
                          callerNumber = getState(tr064 + "inbound.caller").val;          // Anrufernummer
                          callerName = getState(tr064 + "inbound.callerName").val;        // Name des Anrufers
                          calleeNumber = getState(tr064 + "inbound.callee").val;          // angerufene Nummer
                          calleeName = getState(tr064 + "inbound.calleeName").val;        // angerufener Name
                          callAllDataJson = getState(tr064 + "inbound.json").val;          // json
                          console.log('---> Ringing? - callerNumber: ' + callerNumber);
                          console.log('---> Ringing? - callerName: ' + callerName);
                          console.log('---> Ringing? - calleeNumber: ' + calleeNumber);
                          console.log('---> Ringing? - calleeName: ' + calleeName);
                          console.log('---> Ringing? - callAllDataJson: ' + String(callAllDataJson));
                      } else if ("end" == sToPauseState) {
                          setState(tr064 + "inbound.caller", '');
                          setState(tr064 + "inbound.callerName", '');
                          setState(tr064 + "inbound.callee", '');
                          setState(tr064 + "inbound.calleeName", '');
                          setState(tr064 + "inbound.json", '');
                    Oooook ... ich hab mal erste DInge verändert. Bitte nochmal neu versuchen vom GitHub, bitte checkt aber auch ob der ganze Rest (also auch IP.Devices und so) noch so tut wie es soll.
                    Und bitte extra Skripte weglassen. Danke
                    • conectas
                      Knallt...
                      2019-12-12 21:24:14.636  - info: host.raspberrypi "system.adapter.tr-064-community.0" enabled
                      2019-12-12 21:24:14.666  - info: host.raspberrypi instance system.adapter.tr-064-community.0 started with pid 18626
                      2019-12-12 21:24:17.602  - debug: tr-064-community.0 (18626) Redis Objects: Use Redis connection: 127.0.0.1:9001
                      2019-12-12 21:24:17.671  - debug: tr-064-community.0 (18626) Objects client ready ... initialize now
                      2019-12-12 21:24:17.680  - debug: tr-064-community.0 (18626) Objects create PubSub Client
                      2019-12-12 21:24:17.683  - debug: tr-064-community.0 (18626) Objects client initialize lua scripts
                      2019-12-12 21:24:17.712  - debug: tr-064-community.0 (18626) objectDB connected
                      2019-12-12 21:24:17.718  - debug: tr-064-community.0 (18626) Redis States: Use Redis connection: 127.0.0.1:9000
                      2019-12-12 21:24:17.725  - debug: tr-064-community.0 (18626) Objects connected to redis: 127.0.0.1:9001
                      2019-12-12 21:24:17.735  - debug: tr-064-community.0 (18626) States create PubSub Client
                      2019-12-12 21:24:17.738  - debug: tr-064-community.0 (18626) statesDB connected
                      2019-12-12 21:24:17.805  - debug: tr-064-community.0 (18626) States connected to redis: 127.0.0.1:9000
                      2019-12-12 21:24:18.366  - info: tr-064-community.0 (18626) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.17.0
                      2019-12-12 21:24:21.236  - error: tr-064-community.0 (18626) uncaught exception: st is not defined
                      2019-12-12 21:24:21.241  - error: tr-064-community.0 (18626) ReferenceError: st is not defined
                          at createObjects (/opt/iobroker/node_modules/iobroker.tr-064-community/main.js:102:59)
                          at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:940:9
                          at /opt/iobroker/node_modules/iobroker.tr-064-community/lib/soef.js:1610:28
                          at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
                          at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:306:18)
                          at Parser.emit (events.js:198:13)
                          at SAXParser.onclosetag (/opt/iobroker/node_modules/xml2js/lib/parser.js:264:26)
                          at emit (/opt/iobroker/node_modules/sax/lib/sax.js:624:35)
                          at emitNode (/opt/iobroker/node_modules/sax/lib/sax.js:629:5)
                          at closeTag (/opt/iobroker/node_modules/sax/lib/sax.js:889:7)
                      2019-12-12 21:24:21.300  - info: tr-064-community.0 (18626) terminating
                      2019-12-12 21:24:21.303  - info: tr-064-community.0 (18626) Terminated (NO_ERROR): Without reason
                      2019-12-12 21:24:21.861  - error: host.raspberrypi Caught by controller[0]: ReferenceError: st is not defined
                      2019-12-12 21:24:21.864  - error: host.raspberrypi Caught by controller[0]:     at createObjects (/opt/iobroker/node_modules/iobroker.tr-064-community/main.js:102:59)
                      2019-12-12 21:24:21.865  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:940:9
                      2019-12-12 21:24:21.866  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.tr-064-community/lib/soef.js:1610:28
                      2019-12-12 21:24:21.866  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
                      2019-12-12 21:24:21.867  - error: host.raspberrypi Caught by controller[0]:     at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:306:18)
                      2019-12-12 21:24:21.867  - error: host.raspberrypi Caught by controller[0]:     at Parser.emit (events.js:198:13)
                      2019-12-12 21:24:21.868  - error: host.raspberrypi Caught by controller[0]:     at SAXParser.onclosetag (/opt/iobroker/node_modules/xml2js/lib/parser.js:264:26)
                      2019-12-12 21:24:21.868  - error: host.raspberrypi Caught by controller[0]:     at emit (/opt/iobroker/node_modules/sax/lib/sax.js:624:35)
                      2019-12-12 21:24:21.869  - error: host.raspberrypi Caught by controller[0]:     at emitNode (/opt/iobroker/node_modules/sax/lib/sax.js:629:5)
                      2019-12-12 21:24:21.869  - error: host.raspberrypi Caught by controller[0]:     at closeTag (/opt/iobroker/node_modules/sax/lib/sax.js:889:7)
                      2019-12-12 21:24:21.870  - info: host.raspberrypi instance system.adapter.tr-064-community.0 terminated with code 0 (NO_ERROR)
                      2019-12-12 21:24:21.870  - info: host.raspberrypi Restart adapter system.adapter.tr-064-community.0 because enabled
                        gggrrrr ... fixed on GitHub. Sorry
                        • conectas
                          @apollon77
                          außer toPauseState werden im callmonitor nix angelegt.. 2x getestet
                            @conectas Hast Du wieder ein Log?
                            • conectas
                              @apollon77
                              vom Start .. da steht dann man ganzes Telefonbuch drin 😉
                              (habe auch Telefon .. falls de nicht tippen magst)
                                @conectas In dem Fall interessiert mich ja eher der "call" teil ... Ansonsten per email an iobroker@fischer-ka.de schicken
                                • conectas
                                  @apollon77
                                  2019-12-12 21:46:45.420  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:46:45;CALL;1;4;254xy;628xy7;SIP3;\r\n"
                                  2019-12-12 21:46:45.422  - debug: tr-064-community.0 (23433) callmonitor handle outbound message: {"caller":"254xy","callee":"628xy7","extension":"4"}
                                  2019-12-12 21:46:45.428  - debug: tr-064-community.0 (23433) Search number 004930254xy in phonebook: {"name":"NNAme Stefan","normalizedName":"NNAmestefan","number":"004930254xy","id":"634","phonebookId":"0"}
                                  2019-12-12 21:46:45.430  - debug: tr-064-community.0 (23433) Search number 004930628xy7 in phonebook: {"name":"NNAme Stefan","normalizedName":"NNAmestefan","number":"004930628xy7","id":"634","phonebookId":"0"}
                                  2019-12-12 21:46:45.431  - debug: tr-064-community.0 (23433) callMonitor.set: type=outbound caller=254xy callee=628xy7 callerName=NNAme Stefan calleeName=NNAme Stefan
                                  2019-12-12 21:46:45.790  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:46:45;RING;2;030254xy;628xy7;SIP1;\r\n"
                                  2019-12-12 21:46:45.792  - debug: tr-064-community.0 (23433) callmonitor handle inbound message: {"caller":"030254xy","callee":"628xy7"}
                                  2019-12-12 21:46:45.794  - debug: tr-064-community.0 (23433) Search number 004930254xy in phonebook: {"name":"NNAme Stefan","normalizedName":"NNAmestefan","number":"004930254xy","id":"634","phonebookId":"0"}
                                  2019-12-12 21:46:45.796  - debug: tr-064-community.0 (23433) Search number 004930628xy7 in phonebook: {"name":"NNAme Stefan","normalizedName":"NNAmestefan","number":"004930628xy7","id":"634","phonebookId":"0"}
                                  2019-12-12 21:46:45.799  - debug: tr-064-community.0 (23433) callMonitor.set: type=inbound caller=030254xy callee=628xy7 callerName=NNAme Stefan calleeName=NNAme Stefan
                                  2019-12-12 21:46:47.697  - debug: tr-064-community.0 (23433) in updateAll
                                  2019-12-12 21:46:47.699  - debug: tr-064-community.0 (23433) updateDevices
                                  2019-12-12 21:46:47.701  - debug: tr-064-community.0 (23433) forEachConfiguredDevice
                                  2019-12-12 21:46:47.779  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:46:47;CONNECT;2;11;030254xy;\r\n"
                                  2019-12-12 21:46:47.781  - debug: tr-064-community.0 (23433) callmonitor handle connect message: {"caller":"030254xy","callee":"628xy7","_type":"inbound","callerName":"NNAme Stefan","calleeName":"NNAme Stefan","extension":"11"}
                                  2019-12-12 21:46:47.790  - debug: tr-064-community.0 (23433) callMonitor.set: type=connect caller=030254xy callee=628xy7 callerName=NNAme Stefan calleeName=NNAme Stefan
                                  2019-12-12 21:46:47.906  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:46:47;CONNECT;1;4;628xy7;\r\n"
                                  2019-12-12 21:46:47.907  - debug: tr-064-community.0 (23433) callmonitor handle connect message: {"caller":"254xy","callee":"628xy7","extension":"4","_type":"outbound","callerName":"NNAme Stefan","calleeName":"NNAme Stefan"}
                                  2019-12-12 21:46:47.911  - debug: tr-064-community.0 (23433) callMonitor.set: type=connect caller=254xy callee=628xy7 callerName=NNAme Stefan calleeName=NNAme Stefan
                                  2019-12-12 21:46:50.443  - debug: tr-064-community.0 (23433) setting 0 enable=false
                                  2019-12-12 21:46:50.444  - debug: tr-064-community.0 (23433) setting 1 enable=false
                                  2019-12-12 21:46:50.444  - debug: tr-064-community.0 (23433) setting 2 enable=false
                                  2019-12-12 21:46:50.445  - debug: tr-064-community.0 (23433) setting 3 enable=false
                                  2019-12-12 21:46:50.445  - debug: tr-064-community.0 (23433) setting 4 enable=false
                                  2019-12-12 21:46:50.446  - debug: tr-064-community.0 (23433) setting 5 enable=true
                                  2019-12-12 21:46:50.446  - debug: tr-064-community.0 (23433) setting 6 enable=true
                                  2019-12-12 21:46:50.446  - debug: tr-064-community.0 (23433) setting 7 enable=true
                                  2019-12-12 21:46:50.447  - debug: tr-064-community.0 (23433) setting 8 enable=true
                                  2019-12-12 21:46:50.448  - debug: tr-064-community.0 (23433) setting 9 enable=true
                                  2019-12-12 21:46:52.331  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:46:52;DISCONNECT;1;5;\r\n"
                                  2019-12-12 21:46:52.341  - debug: tr-064-community.0 (23433) callmonitor handle lastCall message: {"caller":"254xy","callee":"628xy7","extension":"4","_type":"connect","callerName":"NNAme Stefan","calleeName":"NNAme Stefan","type":"disconnect","duration":5}
                                  2019-12-12 21:46:52.347  - debug: tr-064-community.0 (23433) callMonitor.set: type=lastCall caller=254xy callee=628xy7 callerName=NNAme Stefan calleeName=NNAme Stefan
                                  2019-12-12 21:46:52.374  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:46:52;DISCONNECT;2;5;\r\n"
                                  2019-12-12 21:46:52.375  - debug: tr-064-community.0 (23433) callmonitor handle lastCall message: {"caller":"030254xy","callee":"628xy7","_type":"connect","callerName":"NNAme Stefan","calleeName":"NNAme Stefan","extension":"11","type":"disconnect","duration":5}
                                  2019-12-12 21:46:52.380  - debug: tr-064-community.0 (23433) callMonitor.set: type=lastCall caller=030254xy callee=628xy7 callerName=NNAme Stefan calleeName=NNAme Stefan
                                  • conectas
                                    conectas @conectas last edited by
                                    @conectas
                                    glaube das ist besser.. wegen den Namen? Ansonsten gleich
                                    2019-12-12 21:49:26.143  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:49:26;CALL;1;4;254xy;628xy6;SIP3;\r\n"
                                    2019-12-12 21:49:26.144  - debug: tr-064-community.0 (23433) callmonitor handle outbound message: {"caller":"254xy","callee":"628xy6","extension":"4"}
                                    2019-12-12 21:49:26.145  - debug: tr-064-community.0 (23433) Search number 004930254xy in phonebook: {"name":"NName Stefan","normalizedName":"NNamestefan","number":"004930254xy","id":"634","phonebookId":"0"}
                                    2019-12-12 21:49:26.150  - debug: tr-064-community.0 (23433) Search number 004930628xy6 in phonebook: {"name":"NName Kerstin","normalizedName":"NNamekerstin","number":"004930628xy6","id":"631","phonebookId":"0"}
                                    2019-12-12 21:49:26.151  - debug: tr-064-community.0 (23433) callMonitor.set: type=outbound caller=254xy callee=628xy6 callerName=NName Stefan calleeName=NName Kerstin
                                    2019-12-12 21:49:26.526  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:49:26;RING;2;030254xy;628xy6;SIP0;\r\n"
                                    2019-12-12 21:49:26.527  - debug: tr-064-community.0 (23433) callmonitor handle inbound message: {"caller":"030254xy","callee":"628xy6"}
                                    2019-12-12 21:49:26.529  - debug: tr-064-community.0 (23433) Search number 004930254xy in phonebook: {"name":"NName Stefan","normalizedName":"NNamestefan","number":"004930254xy","id":"634","phonebookId":"0"}
                                    2019-12-12 21:49:26.531  - debug: tr-064-community.0 (23433) Search number 004930628xy6 in phonebook: {"name":"NName Kerstin","normalizedName":"NNamekerstin","number":"004930628xy6","id":"631","phonebookId":"0"}
                                    2019-12-12 21:49:26.532  - debug: tr-064-community.0 (23433) callMonitor.set: type=inbound caller=030254xy callee=628xy6 callerName=NName Stefan calleeName=NName Kerstin
                                    2019-12-12 21:49:30.495  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:49:30;CONNECT;2;11;030254xy;\r\n"
                                    2019-12-12 21:49:30.497  - debug: tr-064-community.0 (23433) callmonitor handle connect message: {"caller":"030254xy","callee":"628xy6","_type":"inbound","callerName":"NName Stefan","calleeName":"NName Kerstin","extension":"11"}
                                    2019-12-12 21:49:30.517  - debug: tr-064-community.0 (23433) callMonitor.set: type=connect caller=030254xy callee=628xy6 callerName=NName Stefan calleeName=NName Kerstin
                                    2019-12-12 21:49:30.537  - debug: tr-064-community.0 (23433) in updateAll
                                    2019-12-12 21:49:30.542  - debug: tr-064-community.0 (23433) updateDevices
                                    2019-12-12 21:49:30.543  - debug: tr-064-community.0 (23433) forEachConfiguredDevice
                                    2019-12-12 21:49:30.633  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:49:30;CONNECT;1;4;628xy6;\r\n"
                                    2019-12-12 21:49:30.635  - debug: tr-064-community.0 (23433) callmonitor handle connect message: {"caller":"254xy","callee":"628xy6","extension":"4","_type":"outbound","callerName":"NName Stefan","calleeName":"NName Kerstin"}
                                    2019-12-12 21:49:30.640  - debug: tr-064-community.0 (23433) callMonitor.set: type=connect caller=254xy callee=628xy6 callerName=NName Stefan calleeName=NName Kerstin
                                    2019-12-12 21:49:33.283  - debug: tr-064-community.0 (23433) setting 0 enable=false
                                    2019-12-12 21:49:33.284  - debug: tr-064-community.0 (23433) setting 1 enable=false
                                    2019-12-12 21:49:33.285  - debug: tr-064-community.0 (23433) setting 2 enable=false
                                    2019-12-12 21:49:33.290  - debug: tr-064-community.0 (23433) setting 3 enable=false
                                    2019-12-12 21:49:33.291  - debug: tr-064-community.0 (23433) setting 4 enable=false
                                    2019-12-12 21:49:33.291  - debug: tr-064-community.0 (23433) setting 5 enable=true
                                    2019-12-12 21:49:33.292  - debug: tr-064-community.0 (23433) setting 6 enable=true
                                    2019-12-12 21:49:33.293  - debug: tr-064-community.0 (23433) setting 7 enable=true
                                    2019-12-12 21:49:33.293  - debug: tr-064-community.0 (23433) setting 8 enable=true
                                    2019-12-12 21:49:33.294  - debug: tr-064-community.0 (23433) setting 9 enable=true
                                    2019-12-12 21:49:33.520  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:49:33;DISCONNECT;1;3;\r\n"
                                    2019-12-12 21:49:33.522  - debug: tr-064-community.0 (23433) callmonitor handle lastCall message: {"caller":"254xy","callee":"628xy6","extension":"4","_type":"connect","callerName":"NName Stefan","calleeName":"NName Kerstin","type":"disconnect","duration":3}
                                    2019-12-12 21:49:33.528  - debug: tr-064-community.0 (23433) callMonitor.set: type=lastCall caller=254xy callee=628xy6 callerName=NName Stefan calleeName=NName Kerstin
                                    2019-12-12 21:49:33.564  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:49:33;DISCONNECT;2;4;\r\n"
                                    2019-12-12 21:49:33.573  - debug: tr-064-community.0 (23433) callmonitor handle lastCall message: {"caller":"030254xy","callee":"628xy6","_type":"connect","callerName":"NName Stefan","calleeName":"NName Kerstin","extension":"11","type":"disconnect","duration":4}
                                    2019-12-12 21:49:33.580  - debug: tr-064-community.0 (23433) callMonitor.set: type=lastCall caller=030254xy callee=628xy6 callerName=NName Stefan calleeName=NName Kerstin
                                    2019-12-12 21:49:43.296  - debug: tr-064-community.0 (23433) in updateAll
                                    2019-12-12 21:49:43.299  - debug: tr-064-community.0 (23433) updateDevices
                                    2019-12-12 21:49:43.300  - debug: tr-064-community.0 (23433) forEachConfiguredDevice
                                    2019-12-12 21:49:45.844  - debug: tr-064-community.0 (23433) setting 0 enable=false
                                    2019-12-12 21:49:45.845  - debug: tr-064-community.0 (23433) setting 1 enable=false
                                    2019-12-12 21:49:45.846  - debug: tr-064-community.0 (23433) setting 2 enable=false
                                    2019-12-12 21:49:45.847  - debug: tr-064-community.0 (23433) setting 3 enable=false
                                    2019-12-12 21:49:45.847  - debug: tr-064-community.0 (23433) setting 4 enable=false
                                    2019-12-12 21:49:45.847  - debug: tr-064-community.0 (23433) setting 5 enable=true
                                    2019-12-12 21:49:45.848  - debug: tr-064-community.0 (23433) setting 6 enable=true
                                    2019-12-12 21:49:45.848  - debug: tr-064-community.0 (23433) setting 7 enable=true
                                    2019-12-12 21:49:45.854  - debug: tr-064-community.0 (23433) setting 8 enable=true
                                    2019-12-12 21:49:45.854  - debug: tr-064-community.0 (23433) setting 9 enable=true
                                      Und dann nochmal bitte von GitHub. Logging nochmal erweitert und so
                                      • conectas
                                        @apollon77
                                        Bitte am Ende des Tages bitte nicht vergessen eine func Version rein zu legen (habe gerade festgestellt das im iobroker backup .. nix von tr-064 drin ist)
                                        1. Ich muss wahrscheinlich gleich Mittag essen... sonst wird die besagte Kerstin .. na ja 😉
                                        2019-12-12 22:08:04.642  - debug: tr-064-community.0 (31690) callmonitor raw data: "12.12.19 22:08:04;CALL;1;4;254xy;628xy6;SIP3;\r\n"
                                        2019-12-12 22:08:04.643  - debug: tr-064-community.0 (31690) callmonitor handle outbound message: {"caller":"254xy","callee":"628xy6","extension":"4"}
                                        2019-12-12 22:08:04.647  - debug: tr-064-community.0 (31690) Search number 004930254xy in phonebook: {"name":"NNAme Stefan","normalizedName":"NNAmestefan","number":"004930254xy","id":"634","phonebookId":"0"}
                                        2019-12-12 22:08:04.652  - debug: tr-064-community.0 (31690) Search number 004930628xy6 in phonebook: {"name":"NNAme Kerstin","normalizedName":"NNAmekerstin","number":"004930628xy6","id":"631","phonebookId":"0"}
                                        2019-12-12 22:08:04.656  - debug: tr-064-community.0 (31690) callMonitor.set: type=outbound caller=254xy callee=628xy6 callerName=NNAme Stefan calleeName=NNAme Kerstin
                                        2019-12-12 22:08:04.686  - debug: tr-064-community.0 (31690) State-Change {"val":false,"ack":true,"ts":1576184884671,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184855434}
                                        2019-12-12 22:08:04.693  - debug: tr-064-community.0 (31690) State-Change {"val":"254xy","ack":true,"ts":1576184884672,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182914392}
                                        2019-12-12 22:08:04.699  - debug: tr-064-community.0 (31690) State-Change {"val":"628xy6","ack":true,"ts":1576184884676,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184851355}
                                        2019-12-12 22:08:04.704  - debug: tr-064-community.0 (31690) State-Change {"val":"4","ack":true,"ts":1576184884677,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182914401}
                                        2019-12-12 22:08:04.708  - debug: tr-064-community.0 (31690) State-Change {"val":"12.12.19 22:08:04","ack":true,"ts":1576184884678,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184884678}
                                        2019-12-12 22:08:04.711  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184884680,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182914403}
                                        2019-12-12 22:08:04.717  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184884681,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184851367}
                                        2019-12-12 22:08:04.721  - debug: tr-064-community.0 (31690) State-Change {"val":"{\"caller\":\"254xy\",\"callee\":\"628xy6\",\"extension\":\"4\",\"_type\":\"outbound\",\"callerName\":\"NNAme Stefan\",\"calleeName\":\"NNAme Kerstin\"}","ack":true,"ts":1576184884682,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184851368}
                                        2019-12-12 22:08:04.999  - debug: tr-064-community.0 (31690) callmonitor raw data: "12.12.19 22:08:04;RING;2;030254xy;628xy6;SIP0;\r\n"
                                        2019-12-12 22:08:05.000  - debug: tr-064-community.0 (31690) callmonitor handle inbound message: {"caller":"030254xy","callee":"628xy6"}
                                        2019-12-12 22:08:05.003  - debug: tr-064-community.0 (31690) Search number 004930254xy in phonebook: {"name":"NNAme Stefan","normalizedName":"NNAmestefan","number":"004930254xy","id":"634","phonebookId":"0"}
                                        2019-12-12 22:08:05.004  - debug: tr-064-community.0 (31690) Search number 004930628xy6 in phonebook: {"name":"NNAme Kerstin","normalizedName":"NNAmekerstin","number":"004930628xy6","id":"631","phonebookId":"0"}
                                        2019-12-12 22:08:05.006  - debug: tr-064-community.0 (31690) callMonitor.set: type=inbound caller=030254xy callee=628xy6 callerName=NNAme Stefan calleeName=NNAme Kerstin
                                        2019-12-12 22:08:05.022  - debug: tr-064-community.0 (31690) State-Change {"val":true,"ack":true,"ts":1576184885010,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184885010}
                                        2019-12-12 22:08:05.026  - debug: tr-064-community.0 (31690) State-Change {"val":"030254xy","ack":true,"ts":1576184885011,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576183605807}
                                        2019-12-12 22:08:05.031  - debug: tr-064-community.0 (31690) State-Change {"val":"628xy6","ack":true,"ts":1576184885011,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184851814}
                                        2019-12-12 22:08:05.034  - debug: tr-064-community.0 (31690) State-Change {"val":"12.12.19 22:08:04","ack":true,"ts":1576184885011,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184885011}
                                        2019-12-12 22:08:05.039  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184885012,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182914757}
                                        2019-12-12 22:08:05.044  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184885013,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184851817}
                                        2019-12-12 22:08:05.048  - debug: tr-064-community.0 (31690) State-Change {"val":"{\"caller\":\"030254xy\",\"callee\":\"628xy6\",\"_type\":\"inbound\",\"callerName\":\"NNAme Stefan\",\"calleeName\":\"NNAme Kerstin\"}","ack":true,"ts":1576184885014,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184851819}
                                        2019-12-12 22:08:05.053  - debug: tr-064-community.0 (31690) State-Change {"val":"ring","ack":true,"ts":1576184885014,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184885014}
                                        2019-12-12 22:08:08.937  - debug: tr-064-community.0 (31690) in updateAll
                                        2019-12-12 22:08:08.939  - debug: tr-064-community.0 (31690) updateDevices
                                        2019-12-12 22:08:08.940  - debug: tr-064-community.0 (31690) forEachConfiguredDevice
                                        2019-12-12 22:08:09.991  - debug: tr-064-community.0 (31690) callmonitor raw data: "12.12.19 22:08:09;CONNECT;2;11;030254xy;\r\n"
                                        2019-12-12 22:08:09.993  - debug: tr-064-community.0 (31690) callmonitor handle connect message: {"caller":"030254xy","callee":"628xy6","_type":"inbound","callerName":"NNAme Stefan","calleeName":"NNAme Kerstin","extension":"11"}
                                        2019-12-12 22:08:09.997  - debug: tr-064-community.0 (31690) callMonitor.set: type=connect caller=030254xy callee=628xy6 callerName=NNAme Stefan calleeName=NNAme Kerstin
                                        2019-12-12 22:08:10.022  - debug: tr-064-community.0 (31690) State-Change {"val":false,"ack":true,"ts":1576184890002,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890002}
                                        2019-12-12 22:08:10.027  - debug: tr-064-community.0 (31690) State-Change {"val":"030254xy","ack":true,"ts":1576184890003,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890003}
                                        2019-12-12 22:08:10.032  - debug: tr-064-community.0 (31690) State-Change {"val":"628xy6","ack":true,"ts":1576184890003,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576183770528}
                                        2019-12-12 22:08:10.037  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184890004,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182926674}
                                        2019-12-12 22:08:10.042  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184890005,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576183770530}
                                        2019-12-12 22:08:10.047  - debug: tr-064-community.0 (31690) State-Change {"val":"11","ack":true,"ts":1576184890006,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890006}
                                        2019-12-12 22:08:10.055  - debug: tr-064-community.0 (31690) State-Change {"val":"12.12.19 22:08:09","ack":true,"ts":1576184890006,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890006}
                                        2019-12-12 22:08:10.060  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184890007,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182926676}
                                        2019-12-12 22:08:10.063  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184890016,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576183770535}
                                        2019-12-12 22:08:10.083  - debug: tr-064-community.0 (31690) State-Change {"val":"{\"caller\":\"030254xy\",\"callee\":\"628xy6\",\"_type\":\"connect\",\"callerName\":\"NNAme Stefan\",\"calleeName\":\"NNAme Kerstin\",\"extension\":\"11\"}","ack":true,"ts":1576184890017,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890017}
                                        2019-12-12 22:08:10.087  - debug: tr-064-community.0 (31690) State-Change {"val":"connect","ack":true,"ts":1576184890019,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890019}
                                        2019-12-12 22:08:10.089  - debug: tr-064-community.0 (31690) State-Change {"val":"connect","ack":true,"ts":1576184890019,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890019}
                                        2019-12-12 22:08:10.105  - debug: tr-064-community.0 (31690) callmonitor raw data: "12.12.19 22:08:10;CONNECT;1;4;628xy6;\r\n"
                                        2019-12-12 22:08:10.106  - debug: tr-064-community.0 (31690) callmonitor handle connect message: {"caller":"254xy","callee":"628xy6","extension":"4","_type":"outbound","callerName":"NNAme Stefan","calleeName":"NNAme Kerstin"}
                                        2019-12-12 22:08:10.113  - debug: tr-064-community.0 (31690) callMonitor.set: type=connect caller=254xy callee=628xy6 callerName=NNAme Stefan calleeName=NNAme Kerstin
                                        2019-12-12 22:08:10.126  - debug: tr-064-community.0 (31690) State-Change {"val":false,"ack":true,"ts":1576184890118,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890002}
                                        2019-12-12 22:08:10.130  - debug: tr-064-community.0 (31690) State-Change {"val":"254xy","ack":true,"ts":1576184890119,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890119}
                                        2019-12-12 22:08:10.135  - debug: tr-064-community.0 (31690) State-Change {"val":"628xy6","ack":true,"ts":1576184890120,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576183770528}
                                        2019-12-12 22:08:10.138  - debug: tr-064-community.0 (31690) State-Change {"val":"4","ack":true,"ts":1576184890120,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890120}
                                        2019-12-12 22:08:10.141  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184890121,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182926674}
                                        2019-12-12 22:08:10.145  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184890121,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576183770530}
                                        2019-12-12 22:08:10.150  - debug: tr-064-community.0 (31690) State-Change {"val":"12.12.19 22:08:10","ack":true,"ts":1576184890121,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890121}
                                        2019-12-12 22:08:10.154  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184890122,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182926676}
                                        2019-12-12 22:08:10.158  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184890122,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576183770535}
                                        2019-12-12 22:08:10.162  - debug: tr-064-community.0 (31690) State-Change {"val":"{\"caller\":\"254xy\",\"callee\":\"628xy6\",\"extension\":\"4\",\"_type\":\"connect\",\"callerName\":\"NNAme Stefan\",\"calleeName\":\"NNAme Kerstin\"}","ack":true,"ts":1576184890123,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890123}
                                        2019-12-12 22:08:10.166  - debug: tr-064-community.0 (31690) State-Change {"val":"connect","ack":true,"ts":1576184890123,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890019}
                                        2019-12-12 22:08:10.169  - debug: tr-064-community.0 (31690) State-Change {"val":"connect","ack":true,"ts":1576184890124,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890124}
                                        2019-12-12 22:08:12.263  - debug: tr-064-community.0 (31690) callmonitor raw data: "12.12.19 22:08:12;DISCONNECT;1;3;\r\n"
                                        2019-12-12 22:08:12.264  - debug: tr-064-community.0 (31690) callmonitor handle lastCall message: {"caller":"254xy","callee":"628xy6","extension":"4","_type":"connect","callerName":"NNAme Stefan","calleeName":"NNAme Kerstin","type":"disconnect","duration":3}
                                        2019-12-12 22:08:12.270  - debug: tr-064-community.0 (31690) callMonitor.set: type=lastCall caller=254xy callee=628xy6 callerName=NNAme Stefan calleeName=NNAme Kerstin
                                        2019-12-12 22:08:12.286  - debug: tr-064-community.0 (31690) State-Change {"val":false,"ack":true,"ts":1576184892275,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890002}
                                        2019-12-12 22:08:12.291  - debug: tr-064-community.0 (31690) State-Change {"val":"254xy","ack":true,"ts":1576184892275,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892275}
                                        2019-12-12 22:08:12.296  - debug: tr-064-community.0 (31690) State-Change {"val":"628xy6","ack":true,"ts":1576184892276,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184859270}
                                        2019-12-12 22:08:12.301  - debug: tr-064-community.0 (31690) State-Change {"val":"4","ack":true,"ts":1576184892277,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892277}
                                        2019-12-12 22:08:12.306  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184892277,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182933087}
                                        2019-12-12 22:08:12.310  - debug: tr-064-community.0 (31690) callmonitor raw data: "12.12.19 22:08:12;DISCONNECT;2;3;\r\n"
                                        2019-12-12 22:08:12.311  - debug: tr-064-community.0 (31690) callmonitor handle lastCall message: {"caller":"030254xy","callee":"628xy6","_type":"connect","callerName":"NNAme Stefan","calleeName":"NNAme Kerstin","extension":"11","type":"disconnect","duration":3}
                                        2019-12-12 22:08:12.325  - debug: tr-064-community.0 (31690) callMonitor.set: type=lastCall caller=030254xy callee=628xy6 callerName=NNAme Stefan calleeName=NNAme Kerstin
                                        2019-12-12 22:08:12.338  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184892278,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184859272}
                                        2019-12-12 22:08:12.340  - debug: tr-064-community.0 (31690) State-Change {"val":"disconnect","ack":true,"ts":1576184892279,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184859273}
                                        2019-12-12 22:08:12.343  - debug: tr-064-community.0 (31690) State-Change {"val":3,"ack":true,"ts":1576184892279,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892279}
                                        2019-12-12 22:08:12.345  - debug: tr-064-community.0 (31690) State-Change {"val":"12.12.19 22:08:12","ack":true,"ts":1576184892280,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892280}
                                        2019-12-12 22:08:12.348  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184892281,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182933103}
                                        2019-12-12 22:08:12.350  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184892281,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184859275}
                                        2019-12-12 22:08:12.359  - debug: tr-064-community.0 (31690) State-Change {"val":"{\"caller\":\"254xy\",\"callee\":\"628xy6\",\"extension\":\"4\",\"_type\":\"lastCall\",\"callerName\":\"NNAme Stefan\",\"calleeName\":\"NNAme Kerstin\",\"type\":\"disconnect\",\"duration\":3}","ack":true,"ts":1576184892282,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892282}
                                        2019-12-12 22:08:12.362  - debug: tr-064-community.0 (31690) State-Change {"val":"end","ack":true,"ts":1576184892282,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892282}
                                        2019-12-12 22:08:12.364  - debug: tr-064-community.0 (31690) State-Change {"val":"end","ack":true,"ts":1576184892283,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892283}
                                        2019-12-12 22:08:12.384  - debug: tr-064-community.0 (31690) State-Change {"val":false,"ack":true,"ts":1576184892370,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890002}
                                        2019-12-12 22:08:12.386  - debug: tr-064-community.0 (31690) State-Change {"val":"030254xy","ack":true,"ts":1576184892375,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892375}
                                        2019-12-12 22:08:12.389  - debug: tr-064-community.0 (31690) State-Change {"val":"628xy6","ack":true,"ts":1576184892376,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184859270}
                                        2019-12-12 22:08:12.393  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184892376,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182933087}
                                        2019-12-12 22:08:12.396  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184892377,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184859272}
                                        2019-12-12 22:08:12.398  - debug: tr-064-community.0 (31690) State-Change {"val":"11","ack":true,"ts":1576184892377,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892377}
                                        2019-12-12 22:08:12.404  - debug: tr-064-community.0 (31690) State-Change {"val":"disconnect","ack":true,"ts":1576184892378,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184859273}
                                        2019-12-12 22:08:12.409  - debug: tr-064-community.0 (31690) State-Change {"val":3,"ack":true,"ts":1576184892378,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892279}
                                        2019-12-12 22:08:12.411  - debug: tr-064-community.0 (31690) State-Change {"val":"12.12.19 22:08:12","ack":true,"ts":1576184892378,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892280}
                                        2019-12-12 22:08:12.416  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184892379,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182933103}
                                        2019-12-12 22:08:12.422  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184892379,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184859275}
                                        2019-12-12 22:08:12.425  - debug: tr-064-community.0 (31690) State-Change {"val":"{\"caller\":\"030254xy\",\"callee\":\"628xy6\",\"_type\":\"lastCall\",\"callerName\":\"NNAme Stefan\",\"calleeName\":\"NNAme Kerstin\",\"extension\":\"11\",\"type\":\"disconnect\",\"duration\":3}","ack":true,"ts":1576184892380,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892380}
                                        2019-12-12 22:08:12.430  - debug: tr-064-community.0 (31690) State-Change {"val":"end","ack":true,"ts":1576184892380,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892282}
                                        2019-12-12 22:08:12.432  - debug: tr-064-community.0 (31690) State-Change {"val":"end","ack":true,"ts":1576184892381,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892381}
                                        2019-12-12 22:08:20.527  - debug: tr-064-community.0 (31690) in updateAll
                                        2019-12-12 22:08:20.530  - debug: tr-064-community.0 (31690) updateDevices
                                        2019-12-12 22:08:20.530  - debug: tr-064-community.0 (31690) forEachConfiguredDevice
                                        apollon77 2 Replies Last reply Reply Quote 0
                                        • marcuskl
                                          marcuskl last edited by
                                          Findet man diesen Adaper schon in IoBroker/Adapter ?
                                            @conectas jetzt sollte aber alles geschrieben werden oder ?! Zumindestens sagt das log das
                                            community tr-064
                                            88
                                            727
                                            189088
