    4. Test Adapter tr-064-community v1.0.x
    • conectas
      conectas @apollon77 last edited by
      @apollon77 sagte in Test Adapter tr-064-community v1.0.x:
      Adapter.log.debug
      949 //adapter.log.debug('Final Phonebook: ' + JSON.stringify(phonebook));
      Haste DU bereits raus gemacht 😉
        Also dann neue logs bitte und Fälle neu checken.
        conectas 3 Replies Last reply Reply Quote 0
        • conectas
          conectas @apollon77 last edited by conectas
          Fall 01: 2mal hintereinander gleicher OUT (0171) auf IN (628yxz6)
          jetzt wird nix (selbst) tr-064-community.0.callmonitor.inbound.json nicht neu geschrieben
          2019-12-12 19:58:38.454  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 19:58:38;RING;2;0171xyz;628xyz6;SIP0;\r\n"
          2019-12-12 19:58:38.456  - debug: tr-064-community.0 (15488) callmonitor handle inbound message: {"caller":"0171xyz","callee":"628xyz6"}
          2019-12-12 19:58:38.457  - debug: tr-064-community.0 (15488) Set State callmonitor.inbound.timestamp: "12.12.19 19:58:38" / ack=true
          2019-12-12 19:58:38.460  - debug: tr-064-community.0 (15488) Search number 0049171xyz in phonebook: {"name":"NNAme Stefan","normalizedName":"NNAmestefan","number":"0049171yxz","id":"634","phonebookId":"0"}
          2019-12-12 19:58:38.463  - debug: tr-064-community.0 (15488) Search number 004930628xyz6 in phonebook: {"name":"NNAme Kerstin","normalizedName":"NNAmekerstin","number":"004930628xyz6","id":"631","phonebookId":"0"}
          2019-12-12 19:58:38.465  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "ring" / ack=true
          2019-12-12 19:58:38.467  - debug: tr-064-community.0 (15488) callMonitor.set: type=inbound caller=0171xyz callee=628xyz6 callerName=NNAme Stefan calleeName=NNAme Kerstin
          2019-12-12 19:58:38.671  - debug: tr-064-community.0 (15488) Set State callmonitor.ringing: true / ack=true
          2019-12-12 19:58:38.841  - debug: tr-064-community.0 (15488) setting 0 enable=false
          2019-12-12 19:58:38.843  - debug: tr-064-community.0 (15488) setting 1 enable=false
          2019-12-12 19:58:38.843  - debug: tr-064-community.0 (15488) setting 2 enable=false
          2019-12-12 19:58:38.844  - debug: tr-064-community.0 (15488) setting 3 enable=false
          2019-12-12 19:58:38.844  - debug: tr-064-community.0 (15488) setting 4 enable=false
          2019-12-12 19:58:38.845  - debug: tr-064-community.0 (15488) setting 5 enable=true
          2019-12-12 19:58:38.845  - debug: tr-064-community.0 (15488) setting 6 enable=true
          2019-12-12 19:58:38.846  - debug: tr-064-community.0 (15488) setting 7 enable=true
          2019-12-12 19:58:38.846  - debug: tr-064-community.0 (15488) setting 8 enable=true
          2019-12-12 19:58:38.847  - debug: tr-064-community.0 (15488) setting 9 enable=true
          2019-12-12 19:58:45.625  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 19:58:45;CONNECT;2;4;0171xyz;\r\n"
          2019-12-12 19:58:45.627  - debug: tr-064-community.0 (15488) callmonitor handle connect message: {"caller":"0171xyz","callee":"628xyz6","_type":"inbound","callerName":"NNAme Stefan","calleeName":"NNAme Kerstin","extension":"4"}
          2019-12-12 19:58:45.628  - debug: tr-064-community.0 (15488) Set State callmonitor.connect.timestamp: "12.12.19 19:58:45" / ack=true
          2019-12-12 19:58:45.629  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "connect" / ack=true
          2019-12-12 19:58:45.630  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState-4: "connect" / ack=true
          2019-12-12 19:58:45.631  - debug: tr-064-community.0 (15488) callMonitor.set: type=connect caller=0171xyz callee=628xyz6 callerName=NNAme Stefan calleeName=NNAme Kerstin
          2019-12-12 19:58:45.833  - debug: tr-064-community.0 (15488) Set State callmonitor.ringing: false / ack=true
          2019-12-12 19:58:48.464  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 19:58:48;DISCONNECT;2;3;\r\n"
          2019-12-12 19:58:48.466  - debug: tr-064-community.0 (15488) callmonitor handle lastCall message: {"caller":"0171xyz","callee":"628xyz6","_type":"connect","callerName":"NNAme Stefan","calleeName":"NNAme Kerstin","extension":"4","type":"disconnect","duration":3}
          2019-12-12 19:58:48.468  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.type: "disconnect" / ack=true
          2019-12-12 19:58:48.470  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.duration: 3 / ack=true
          2019-12-12 19:58:48.472  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.timestamp: "12.12.19 19:58:48" / ack=true
          2019-12-12 19:58:48.474  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.json: "{\"caller\":\"0171xyz\",\"callee\":\"628xyz6\",\"_type\":\"lastCall\",\"callerName\":\"NNAme Stefan\",\"calleeName\":\"NNAme Kerstin\",\"extension\":\"4\",\"type\":\"disconnect\",\"duration\":3}" / ack=true
          2019-12-12 19:58:48.476  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "end" / ack=true
          2019-12-12 19:58:48.478  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState-4: "end" / ack=true
          2019-12-12 19:58:48.479  - debug: tr-064-community.0 (15488) callMonitor.set: type=lastCall caller=0171xyz callee=628xyz6 callerName=NNAme Stefan calleeName=NNAme Kerstin
          2019-12-12 19:58:48.851  - debug: tr-064-community.0 (15488) in updateAll
          2019-12-12 19:58:48.853  - debug: tr-064-community.0 (15488) updateDevices
          2019-12-12 19:58:48.854  - debug: tr-064-community.0 (15488) forEachConfiguredDevice
          2019-12-12 19:58:51.289  - debug: tr-064-community.0 (15488) setting 0 enable=false
          2019-12-12 19:58:51.290  - debug: tr-064-community.0 (15488) setting 1 enable=false
          2019-12-12 19:58:51.291  - debug: tr-064-community.0 (15488) setting 2 enable=false
          2019-12-12 19:58:51.291  - debug: tr-064-community.0 (15488) setting 3 enable=false
          2019-12-12 19:58:51.292  - debug: tr-064-community.0 (15488) setting 4 enable=false
          2019-12-12 19:58:51.292  - debug: tr-064-community.0 (15488) setting 5 enable=true
          2019-12-12 19:58:51.292  - debug: tr-064-community.0 (15488) setting 6 enable=true
          2019-12-12 19:58:51.293  - debug: tr-064-community.0 (15488) setting 7 enable=true
          2019-12-12 19:58:51.293  - debug: tr-064-community.0 (15488) setting 8 enable=true
          2019-12-12 19:58:51.295  - debug: tr-064-community.0 (15488) setting 9 enable=true
          • conectas
            Fall2:
            abwechselt:
            OUT 0171 zu 628xy6
            danach
            OUT 0171 zu 628xy7
            tr-064-community.0.callmonitor.inbound.caller
            tr-064-community.0.callmonitor.inbound.callerName
            werden nicht aktualisiert...
            2019-12-12 20:07:10.493  - debug: tr-064-community.0 (15488) in updateAll
            2019-12-12 20:07:10.495  - debug: tr-064-community.0 (15488) updateDevices
            2019-12-12 20:07:10.496  - debug: tr-064-community.0 (15488) forEachConfiguredDevice
            2019-12-12 20:07:12.959  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 20:07:12;RING;2;0171xyz;628yxz6;SIP0;\r\n"
            2019-12-12 20:07:12.960  - debug: tr-064-community.0 (15488) callmonitor handle inbound message: {"caller":"0171xyz","callee":"628yxz6"}
            2019-12-12 20:07:12.961  - debug: tr-064-community.0 (15488) Set State callmonitor.inbound.callee: "628yxz6" / ack=true
            2019-12-12 20:07:12.962  - debug: tr-064-community.0 (15488) Set State callmonitor.inbound.timestamp: "12.12.19 20:07:12" / ack=true
            2019-12-12 20:07:12.963  - debug: tr-064-community.0 (15488) Search number 0049171xyz in phonebook: {"name":"NName Stefan","normalizedName":"NNamestefan","number":"0049171xyz","id":"634","phonebookId":"0"}
            2019-12-12 20:07:12.964  - debug: tr-064-community.0 (15488) Search number 004930628yxz6 in phonebook: {"name":"NName Kerstin","normalizedName":"NNamekerstin","number":"004930628yxz6","id":"631","phonebookId":"0"}
            2019-12-12 20:07:12.964  - debug: tr-064-community.0 (15488) Set State callmonitor.inbound.calleeName: "NName Kerstin" / ack=true
            2019-12-12 20:07:12.965  - debug: tr-064-community.0 (15488) Set State callmonitor.inbound.json: "{\"caller\":\"0171xyz\",\"callee\":\"628yxz6\",\"_type\":\"inbound\",\"callerName\":\"NName Stefan\",\"calleeName\":\"NName Kerstin\"}" / ack=true
            2019-12-12 20:07:12.966  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "ring" / ack=true
            2019-12-12 20:07:12.967  - debug: tr-064-community.0 (15488) callMonitor.set: type=inbound caller=0171xyz callee=628yxz6 callerName=NName Stefan calleeName=NName Kerstin
            2019-12-12 20:07:13.168  - debug: tr-064-community.0 (15488) Set State callmonitor.ringing: true / ack=true
            2019-12-12 20:07:13.225  - debug: tr-064-community.0 (15488) setting 0 enable=false
            2019-12-12 20:07:13.226  - debug: tr-064-community.0 (15488) setting 1 enable=false
            2019-12-12 20:07:13.227  - debug: tr-064-community.0 (15488) setting 2 enable=false
            2019-12-12 20:07:13.228  - debug: tr-064-community.0 (15488) setting 3 enable=false
            2019-12-12 20:07:13.229  - debug: tr-064-community.0 (15488) setting 4 enable=false
            2019-12-12 20:07:13.229  - debug: tr-064-community.0 (15488) setting 5 enable=true
            2019-12-12 20:07:13.230  - debug: tr-064-community.0 (15488) setting 6 enable=true
            2019-12-12 20:07:13.230  - debug: tr-064-community.0 (15488) setting 7 enable=true
            2019-12-12 20:07:13.231  - debug: tr-064-community.0 (15488) setting 8 enable=true
            2019-12-12 20:07:13.231  - debug: tr-064-community.0 (15488) setting 9 enable=true
            2019-12-12 20:07:19.126  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 20:07:19;CONNECT;2;4;0171xyz;\r\n"
            2019-12-12 20:07:19.127  - debug: tr-064-community.0 (15488) callmonitor handle connect message: {"caller":"0171xyz","callee":"628yxz6","_type":"inbound","callerName":"NName Stefan","calleeName":"NName Kerstin","extension":"4"}
            2019-12-12 20:07:19.128  - debug: tr-064-community.0 (15488) Set State callmonitor.connect.callee: "628yxz6" / ack=true
            2019-12-12 20:07:19.129  - debug: tr-064-community.0 (15488) Set State callmonitor.connect.calleeName: "NName Kerstin" / ack=true
            2019-12-12 20:07:19.130  - debug: tr-064-community.0 (15488) Set State callmonitor.connect.timestamp: "12.12.19 20:07:19" / ack=true
            2019-12-12 20:07:19.131  - debug: tr-064-community.0 (15488) Set State callmonitor.connect.json: "{\"caller\":\"0171xyz\",\"callee\":\"628yxz6\",\"_type\":\"connect\",\"callerName\":\"NName Stefan\",\"calleeName\":\"NName Kerstin\",\"extension\":\"4\"}" / ack=true
            2019-12-12 20:07:19.135  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "connect" / ack=true
            2019-12-12 20:07:19.136  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState-4: "connect" / ack=true
            2019-12-12 20:07:19.137  - debug: tr-064-community.0 (15488) callMonitor.set: type=connect caller=0171xyz callee=628yxz6 callerName=NName Stefan calleeName=NName Kerstin
            2019-12-12 20:07:19.339  - debug: tr-064-community.0 (15488) Set State callmonitor.ringing: false / ack=true
            2019-12-12 20:07:20.343  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 20:07:20;DISCONNECT;2;2;\r\n"
            2019-12-12 20:07:20.344  - debug: tr-064-community.0 (15488) callmonitor handle lastCall message: {"caller":"0171xyz","callee":"628yxz6","_type":"connect","callerName":"NName Stefan","calleeName":"NName Kerstin","extension":"4","type":"disconnect","duration":2}
            2019-12-12 20:07:20.345  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.callee: "628yxz6" / ack=true
            2019-12-12 20:07:20.346  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.calleeName: "NName Kerstin" / ack=true
            2019-12-12 20:07:20.347  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.duration: 2 / ack=true
            2019-12-12 20:07:20.348  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.timestamp: "12.12.19 20:07:20" / ack=true
            2019-12-12 20:07:20.350  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.json: "{\"caller\":\"0171xyz\",\"callee\":\"628yxz6\",\"_type\":\"lastCall\",\"callerName\":\"NName Stefan\",\"calleeName\":\"NName Kerstin\",\"extension\":\"4\",\"type\":\"disconnect\",\"duration\":2}" / ack=true
            2019-12-12 20:07:20.351  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "end" / ack=true
            2019-12-12 20:07:20.352  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState-4: "end" / ack=true
            2019-12-12 20:07:20.353  - debug: tr-064-community.0 (15488) callMonitor.set: type=lastCall caller=0171xyz callee=628yxz6 callerName=NName Stefan calleeName=NName Kerstin
            2019-12-12 20:07:23.232  - debug: tr-064-community.0 (15488) in updateAll
            2019-12-12 20:07:23.234  - debug: tr-064-community.0 (15488) updateDevices
            2019-12-12 20:07:23.235  - debug: tr-064-community.0 (15488) forEachConfiguredDevice
            • conectas
              Ich würde bei Tests dieses Script mitlaufen lassen.. oder bringt das in deinen Logs dann zu viel durcheinander?
              let tr064 = "tr-064-community.0.callmonitor.";
              var callerNumber    // Anrufernummer
              var callerName      // Name des Anrufers
              var calleeNumber    // angerufene Nummer
              var calleeName      // angerufener Name
              var callAllDataJson = { "caller": "caller Nr", "callee": "callee Nr", "_type": "_type inbound", "callerName": "Caller Name", "calleeName": "Callee Name" };
              on({ id: "tr-064-community.0.callmonitor.toPauseState", change: "any" }, function (obj) {
                  console.log('---> Ringing?: ');
                  let sToPauseState = getState(tr064 + "toPauseState").val;
                  if ("ring" == sToPauseState) {
                      callerNumber = getState(tr064 + "inbound.caller").val;          // Anrufernummer
                      callerName = getState(tr064 + "inbound.callerName").val;        // Name des Anrufers
                      calleeNumber = getState(tr064 + "inbound.callee").val;          // angerufene Nummer
                      calleeName = getState(tr064 + "inbound.calleeName").val;        // angerufener Name
                      callAllDataJson = getState(tr064 + "inbound.json").val;          // json
                      console.log('---> Ringing? - callerNumber: ' + callerNumber);
                      console.log('---> Ringing? - callerName: ' + callerName);
                      console.log('---> Ringing? - calleeNumber: ' + calleeNumber);
                      console.log('---> Ringing? - calleeName: ' + calleeName);
                      console.log('---> Ringing? - callAllDataJson: ' + String(callAllDataJson));
                  } else if ("end" == sToPauseState) {
                      setState(tr064 + "inbound.caller", '');
                      setState(tr064 + "inbound.callerName", '');
                      setState(tr064 + "inbound.callee", '');
                      setState(tr064 + "inbound.calleeName", '');
                      setState(tr064 + "inbound.json", '');
                Oooook ... ich hab mal erste DInge verändert. Bitte nochmal neu versuchen vom GitHub, bitte checkt aber auch ob der ganze Rest (also auch IP.Devices und so) noch so tut wie es soll.
                Und bitte extra Skripte weglassen. Danke
                conectas 1 Reply Last reply Reply Quote 0
                • conectas
                  Knallt...
                  2019-12-12 21:24:14.636  - info: host.raspberrypi "system.adapter.tr-064-community.0" enabled
                  2019-12-12 21:24:14.666  - info: host.raspberrypi instance system.adapter.tr-064-community.0 started with pid 18626
                  2019-12-12 21:24:17.602  - debug: tr-064-community.0 (18626) Redis Objects: Use Redis connection: 127.0.0.1:9001
                  2019-12-12 21:24:17.671  - debug: tr-064-community.0 (18626) Objects client ready ... initialize now
                  2019-12-12 21:24:17.680  - debug: tr-064-community.0 (18626) Objects create PubSub Client
                  2019-12-12 21:24:17.683  - debug: tr-064-community.0 (18626) Objects client initialize lua scripts
                  2019-12-12 21:24:17.712  - debug: tr-064-community.0 (18626) objectDB connected
                  2019-12-12 21:24:17.718  - debug: tr-064-community.0 (18626) Redis States: Use Redis connection: 127.0.0.1:9000
                  2019-12-12 21:24:17.725  - debug: tr-064-community.0 (18626) Objects connected to redis: 127.0.0.1:9001
                  2019-12-12 21:24:17.735  - debug: tr-064-community.0 (18626) States create PubSub Client
                  2019-12-12 21:24:17.738  - debug: tr-064-community.0 (18626) statesDB connected
                  2019-12-12 21:24:17.805  - debug: tr-064-community.0 (18626) States connected to redis: 127.0.0.1:9000
                  2019-12-12 21:24:18.366  - info: tr-064-community.0 (18626) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.17.0
                  2019-12-12 21:24:21.236  - error: tr-064-community.0 (18626) uncaught exception: st is not defined
                  2019-12-12 21:24:21.241  - error: tr-064-community.0 (18626) ReferenceError: st is not defined
                      at createObjects (/opt/iobroker/node_modules/iobroker.tr-064-community/main.js:102:59)
                      at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:940:9
                      at /opt/iobroker/node_modules/iobroker.tr-064-community/lib/soef.js:1610:28
                      at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
                      at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:306:18)
                      at Parser.emit (events.js:198:13)
                      at SAXParser.onclosetag (/opt/iobroker/node_modules/xml2js/lib/parser.js:264:26)
                      at emit (/opt/iobroker/node_modules/sax/lib/sax.js:624:35)
                      at emitNode (/opt/iobroker/node_modules/sax/lib/sax.js:629:5)
                      at closeTag (/opt/iobroker/node_modules/sax/lib/sax.js:889:7)
                  2019-12-12 21:24:21.300  - info: tr-064-community.0 (18626) terminating
                  2019-12-12 21:24:21.303  - info: tr-064-community.0 (18626) Terminated (NO_ERROR): Without reason
                  2019-12-12 21:24:21.861  - error: host.raspberrypi Caught by controller[0]: ReferenceError: st is not defined
                  2019-12-12 21:24:21.864  - error: host.raspberrypi Caught by controller[0]:     at createObjects (/opt/iobroker/node_modules/iobroker.tr-064-community/main.js:102:59)
                  2019-12-12 21:24:21.865  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:940:9
                  2019-12-12 21:24:21.866  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.tr-064-community/lib/soef.js:1610:28
                  2019-12-12 21:24:21.866  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
                  2019-12-12 21:24:21.867  - error: host.raspberrypi Caught by controller[0]:     at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:306:18)
                  2019-12-12 21:24:21.867  - error: host.raspberrypi Caught by controller[0]:     at Parser.emit (events.js:198:13)
                  2019-12-12 21:24:21.868  - error: host.raspberrypi Caught by controller[0]:     at SAXParser.onclosetag (/opt/iobroker/node_modules/xml2js/lib/parser.js:264:26)
                  2019-12-12 21:24:21.868  - error: host.raspberrypi Caught by controller[0]:     at emit (/opt/iobroker/node_modules/sax/lib/sax.js:624:35)
                  2019-12-12 21:24:21.869  - error: host.raspberrypi Caught by controller[0]:     at emitNode (/opt/iobroker/node_modules/sax/lib/sax.js:629:5)
                  2019-12-12 21:24:21.869  - error: host.raspberrypi Caught by controller[0]:     at closeTag (/opt/iobroker/node_modules/sax/lib/sax.js:889:7)
                  2019-12-12 21:24:21.870  - info: host.raspberrypi instance system.adapter.tr-064-community.0 terminated with code 0 (NO_ERROR)
                  2019-12-12 21:24:21.870  - info: host.raspberrypi Restart adapter system.adapter.tr-064-community.0 because enabled
                    gggrrrr ... fixed on GitHub. Sorry
                    • conectas
                      @apollon77
                      außer toPauseState werden im callmonitor nix angelegt.. 2x getestet
                        apollon77 @conectas last edited by
                        @conectas Hast Du wieder ein Log?
                        • conectas
                          @apollon77
                          vom Start .. da steht dann man ganzes Telefonbuch drin 😉
                          (habe auch Telefon .. falls de nicht tippen magst)
                            @conectas In dem Fall interessiert mich ja eher der "call" teil ... Ansonsten per email an iobroker@fischer-ka.de schicken
                            • conectas
                              @apollon77
                              2019-12-12 21:46:45.420  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:46:45;CALL;1;4;254xy;628xy7;SIP3;\r\n"
                              2019-12-12 21:46:45.422  - debug: tr-064-community.0 (23433) callmonitor handle outbound message: {"caller":"254xy","callee":"628xy7","extension":"4"}
                              2019-12-12 21:46:45.428  - debug: tr-064-community.0 (23433) Search number 004930254xy in phonebook: {"name":"NNAme Stefan","normalizedName":"NNAmestefan","number":"004930254xy","id":"634","phonebookId":"0"}
                              2019-12-12 21:46:45.430  - debug: tr-064-community.0 (23433) Search number 004930628xy7 in phonebook: {"name":"NNAme Stefan","normalizedName":"NNAmestefan","number":"004930628xy7","id":"634","phonebookId":"0"}
                              2019-12-12 21:46:45.431  - debug: tr-064-community.0 (23433) callMonitor.set: type=outbound caller=254xy callee=628xy7 callerName=NNAme Stefan calleeName=NNAme Stefan
                              2019-12-12 21:46:45.790  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:46:45;RING;2;030254xy;628xy7;SIP1;\r\n"
                              2019-12-12 21:46:45.792  - debug: tr-064-community.0 (23433) callmonitor handle inbound message: {"caller":"030254xy","callee":"628xy7"}
                              2019-12-12 21:46:45.794  - debug: tr-064-community.0 (23433) Search number 004930254xy in phonebook: {"name":"NNAme Stefan","normalizedName":"NNAmestefan","number":"004930254xy","id":"634","phonebookId":"0"}
                              2019-12-12 21:46:45.796  - debug: tr-064-community.0 (23433) Search number 004930628xy7 in phonebook: {"name":"NNAme Stefan","normalizedName":"NNAmestefan","number":"004930628xy7","id":"634","phonebookId":"0"}
                              2019-12-12 21:46:45.799  - debug: tr-064-community.0 (23433) callMonitor.set: type=inbound caller=030254xy callee=628xy7 callerName=NNAme Stefan calleeName=NNAme Stefan
                              2019-12-12 21:46:47.697  - debug: tr-064-community.0 (23433) in updateAll
                              2019-12-12 21:46:47.699  - debug: tr-064-community.0 (23433) updateDevices
                              2019-12-12 21:46:47.701  - debug: tr-064-community.0 (23433) forEachConfiguredDevice
                              2019-12-12 21:46:47.779  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:46:47;CONNECT;2;11;030254xy;\r\n"
                              2019-12-12 21:46:47.781  - debug: tr-064-community.0 (23433) callmonitor handle connect message: {"caller":"030254xy","callee":"628xy7","_type":"inbound","callerName":"NNAme Stefan","calleeName":"NNAme Stefan","extension":"11"}
                              2019-12-12 21:46:47.790  - debug: tr-064-community.0 (23433) callMonitor.set: type=connect caller=030254xy callee=628xy7 callerName=NNAme Stefan calleeName=NNAme Stefan
                              2019-12-12 21:46:47.906  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:46:47;CONNECT;1;4;628xy7;\r\n"
                              2019-12-12 21:46:47.907  - debug: tr-064-community.0 (23433) callmonitor handle connect message: {"caller":"254xy","callee":"628xy7","extension":"4","_type":"outbound","callerName":"NNAme Stefan","calleeName":"NNAme Stefan"}
                              2019-12-12 21:46:47.911  - debug: tr-064-community.0 (23433) callMonitor.set: type=connect caller=254xy callee=628xy7 callerName=NNAme Stefan calleeName=NNAme Stefan
                              2019-12-12 21:46:50.443  - debug: tr-064-community.0 (23433) setting 0 enable=false
                              2019-12-12 21:46:50.444  - debug: tr-064-community.0 (23433) setting 1 enable=false
                              2019-12-12 21:46:50.444  - debug: tr-064-community.0 (23433) setting 2 enable=false
                              2019-12-12 21:46:50.445  - debug: tr-064-community.0 (23433) setting 3 enable=false
                              2019-12-12 21:46:50.445  - debug: tr-064-community.0 (23433) setting 4 enable=false
                              2019-12-12 21:46:50.446  - debug: tr-064-community.0 (23433) setting 5 enable=true
                              2019-12-12 21:46:50.446  - debug: tr-064-community.0 (23433) setting 6 enable=true
                              2019-12-12 21:46:50.446  - debug: tr-064-community.0 (23433) setting 7 enable=true
                              2019-12-12 21:46:50.447  - debug: tr-064-community.0 (23433) setting 8 enable=true
                              2019-12-12 21:46:50.448  - debug: tr-064-community.0 (23433) setting 9 enable=true
                              2019-12-12 21:46:52.331  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:46:52;DISCONNECT;1;5;\r\n"
                              2019-12-12 21:46:52.341  - debug: tr-064-community.0 (23433) callmonitor handle lastCall message: {"caller":"254xy","callee":"628xy7","extension":"4","_type":"connect","callerName":"NNAme Stefan","calleeName":"NNAme Stefan","type":"disconnect","duration":5}
                              2019-12-12 21:46:52.347  - debug: tr-064-community.0 (23433) callMonitor.set: type=lastCall caller=254xy callee=628xy7 callerName=NNAme Stefan calleeName=NNAme Stefan
                              2019-12-12 21:46:52.374  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:46:52;DISCONNECT;2;5;\r\n"
                              2019-12-12 21:46:52.375  - debug: tr-064-community.0 (23433) callmonitor handle lastCall message: {"caller":"030254xy","callee":"628xy7","_type":"connect","callerName":"NNAme Stefan","calleeName":"NNAme Stefan","extension":"11","type":"disconnect","duration":5}
                              2019-12-12 21:46:52.380  - debug: tr-064-community.0 (23433) callMonitor.set: type=lastCall caller=030254xy callee=628xy7 callerName=NNAme Stefan calleeName=NNAme Stefan
                              • conectas
                                conectas @conectas last edited by
                                @conectas
                                glaube das ist besser.. wegen den Namen? Ansonsten gleich
                                2019-12-12 21:49:26.143  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:49:26;CALL;1;4;254xy;628xy6;SIP3;\r\n"
                                2019-12-12 21:49:26.144  - debug: tr-064-community.0 (23433) callmonitor handle outbound message: {"caller":"254xy","callee":"628xy6","extension":"4"}
                                2019-12-12 21:49:26.145  - debug: tr-064-community.0 (23433) Search number 004930254xy in phonebook: {"name":"NName Stefan","normalizedName":"NNamestefan","number":"004930254xy","id":"634","phonebookId":"0"}
                                2019-12-12 21:49:26.150  - debug: tr-064-community.0 (23433) Search number 004930628xy6 in phonebook: {"name":"NName Kerstin","normalizedName":"NNamekerstin","number":"004930628xy6","id":"631","phonebookId":"0"}
                                2019-12-12 21:49:26.151  - debug: tr-064-community.0 (23433) callMonitor.set: type=outbound caller=254xy callee=628xy6 callerName=NName Stefan calleeName=NName Kerstin
                                2019-12-12 21:49:26.526  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:49:26;RING;2;030254xy;628xy6;SIP0;\r\n"
                                2019-12-12 21:49:26.527  - debug: tr-064-community.0 (23433) callmonitor handle inbound message: {"caller":"030254xy","callee":"628xy6"}
                                2019-12-12 21:49:26.529  - debug: tr-064-community.0 (23433) Search number 004930254xy in phonebook: {"name":"NName Stefan","normalizedName":"NNamestefan","number":"004930254xy","id":"634","phonebookId":"0"}
                                2019-12-12 21:49:26.531  - debug: tr-064-community.0 (23433) Search number 004930628xy6 in phonebook: {"name":"NName Kerstin","normalizedName":"NNamekerstin","number":"004930628xy6","id":"631","phonebookId":"0"}
                                2019-12-12 21:49:26.532  - debug: tr-064-community.0 (23433) callMonitor.set: type=inbound caller=030254xy callee=628xy6 callerName=NName Stefan calleeName=NName Kerstin
                                2019-12-12 21:49:30.495  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:49:30;CONNECT;2;11;030254xy;\r\n"
                                2019-12-12 21:49:30.497  - debug: tr-064-community.0 (23433) callmonitor handle connect message: {"caller":"030254xy","callee":"628xy6","_type":"inbound","callerName":"NName Stefan","calleeName":"NName Kerstin","extension":"11"}
                                2019-12-12 21:49:30.517  - debug: tr-064-community.0 (23433) callMonitor.set: type=connect caller=030254xy callee=628xy6 callerName=NName Stefan calleeName=NName Kerstin
                                2019-12-12 21:49:30.537  - debug: tr-064-community.0 (23433) in updateAll
                                2019-12-12 21:49:30.542  - debug: tr-064-community.0 (23433) updateDevices
                                2019-12-12 21:49:30.543  - debug: tr-064-community.0 (23433) forEachConfiguredDevice
                                2019-12-12 21:49:30.633  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:49:30;CONNECT;1;4;628xy6;\r\n"
                                2019-12-12 21:49:30.635  - debug: tr-064-community.0 (23433) callmonitor handle connect message: {"caller":"254xy","callee":"628xy6","extension":"4","_type":"outbound","callerName":"NName Stefan","calleeName":"NName Kerstin"}
                                2019-12-12 21:49:30.640  - debug: tr-064-community.0 (23433) callMonitor.set: type=connect caller=254xy callee=628xy6 callerName=NName Stefan calleeName=NName Kerstin
                                2019-12-12 21:49:33.283  - debug: tr-064-community.0 (23433) setting 0 enable=false
                                2019-12-12 21:49:33.284  - debug: tr-064-community.0 (23433) setting 1 enable=false
                                2019-12-12 21:49:33.285  - debug: tr-064-community.0 (23433) setting 2 enable=false
                                2019-12-12 21:49:33.290  - debug: tr-064-community.0 (23433) setting 3 enable=false
                                2019-12-12 21:49:33.291  - debug: tr-064-community.0 (23433) setting 4 enable=false
                                2019-12-12 21:49:33.291  - debug: tr-064-community.0 (23433) setting 5 enable=true
                                2019-12-12 21:49:33.292  - debug: tr-064-community.0 (23433) setting 6 enable=true
                                2019-12-12 21:49:33.293  - debug: tr-064-community.0 (23433) setting 7 enable=true
                                2019-12-12 21:49:33.293  - debug: tr-064-community.0 (23433) setting 8 enable=true
                                2019-12-12 21:49:33.294  - debug: tr-064-community.0 (23433) setting 9 enable=true
                                2019-12-12 21:49:33.520  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:49:33;DISCONNECT;1;3;\r\n"
                                2019-12-12 21:49:33.522  - debug: tr-064-community.0 (23433) callmonitor handle lastCall message: {"caller":"254xy","callee":"628xy6","extension":"4","_type":"connect","callerName":"NName Stefan","calleeName":"NName Kerstin","type":"disconnect","duration":3}
                                2019-12-12 21:49:33.528  - debug: tr-064-community.0 (23433) callMonitor.set: type=lastCall caller=254xy callee=628xy6 callerName=NName Stefan calleeName=NName Kerstin
                                2019-12-12 21:49:33.564  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:49:33;DISCONNECT;2;4;\r\n"
                                2019-12-12 21:49:33.573  - debug: tr-064-community.0 (23433) callmonitor handle lastCall message: {"caller":"030254xy","callee":"628xy6","_type":"connect","callerName":"NName Stefan","calleeName":"NName Kerstin","extension":"11","type":"disconnect","duration":4}
                                2019-12-12 21:49:33.580  - debug: tr-064-community.0 (23433) callMonitor.set: type=lastCall caller=030254xy callee=628xy6 callerName=NName Stefan calleeName=NName Kerstin
                                2019-12-12 21:49:43.296  - debug: tr-064-community.0 (23433) in updateAll
                                2019-12-12 21:49:43.299  - debug: tr-064-community.0 (23433) updateDevices
                                2019-12-12 21:49:43.300  - debug: tr-064-community.0 (23433) forEachConfiguredDevice
                                2019-12-12 21:49:45.844  - debug: tr-064-community.0 (23433) setting 0 enable=false
                                2019-12-12 21:49:45.845  - debug: tr-064-community.0 (23433) setting 1 enable=false
                                2019-12-12 21:49:45.846  - debug: tr-064-community.0 (23433) setting 2 enable=false
                                2019-12-12 21:49:45.847  - debug: tr-064-community.0 (23433) setting 3 enable=false
                                2019-12-12 21:49:45.847  - debug: tr-064-community.0 (23433) setting 4 enable=false
                                2019-12-12 21:49:45.847  - debug: tr-064-community.0 (23433) setting 5 enable=true
                                2019-12-12 21:49:45.848  - debug: tr-064-community.0 (23433) setting 6 enable=true
                                2019-12-12 21:49:45.848  - debug: tr-064-community.0 (23433) setting 7 enable=true
                                2019-12-12 21:49:45.854  - debug: tr-064-community.0 (23433) setting 8 enable=true
                                2019-12-12 21:49:45.854  - debug: tr-064-community.0 (23433) setting 9 enable=true
                                  Und dann nochmal bitte von GitHub. Logging nochmal erweitert und so
                                  • conectas
                                    @apollon77
                                    Bitte am Ende des Tages bitte nicht vergessen eine func Version rein zu legen (habe gerade festgestellt das im iobroker backup .. nix von tr-064 drin ist)
                                    1. Ich muss wahrscheinlich gleich Mittag essen... sonst wird die besagte Kerstin .. na ja 😉
                                    2019-12-12 22:08:04.642  - debug: tr-064-community.0 (31690) callmonitor raw data: "12.12.19 22:08:04;CALL;1;4;254xy;628xy6;SIP3;\r\n"
                                    2019-12-12 22:08:04.643  - debug: tr-064-community.0 (31690) callmonitor handle outbound message: {"caller":"254xy","callee":"628xy6","extension":"4"}
                                    2019-12-12 22:08:04.647  - debug: tr-064-community.0 (31690) Search number 004930254xy in phonebook: {"name":"NNAme Stefan","normalizedName":"NNAmestefan","number":"004930254xy","id":"634","phonebookId":"0"}
                                    2019-12-12 22:08:04.652  - debug: tr-064-community.0 (31690) Search number 004930628xy6 in phonebook: {"name":"NNAme Kerstin","normalizedName":"NNAmekerstin","number":"004930628xy6","id":"631","phonebookId":"0"}
                                    2019-12-12 22:08:04.656  - debug: tr-064-community.0 (31690) callMonitor.set: type=outbound caller=254xy callee=628xy6 callerName=NNAme Stefan calleeName=NNAme Kerstin
                                    2019-12-12 22:08:04.686  - debug: tr-064-community.0 (31690) State-Change {"val":false,"ack":true,"ts":1576184884671,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184855434}
                                    2019-12-12 22:08:04.693  - debug: tr-064-community.0 (31690) State-Change {"val":"254xy","ack":true,"ts":1576184884672,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182914392}
                                    2019-12-12 22:08:04.699  - debug: tr-064-community.0 (31690) State-Change {"val":"628xy6","ack":true,"ts":1576184884676,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184851355}
                                    2019-12-12 22:08:04.704  - debug: tr-064-community.0 (31690) State-Change {"val":"4","ack":true,"ts":1576184884677,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182914401}
                                    2019-12-12 22:08:04.708  - debug: tr-064-community.0 (31690) State-Change {"val":"12.12.19 22:08:04","ack":true,"ts":1576184884678,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184884678}
                                    2019-12-12 22:08:04.711  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184884680,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182914403}
                                    2019-12-12 22:08:04.717  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184884681,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184851367}
                                    2019-12-12 22:08:04.721  - debug: tr-064-community.0 (31690) State-Change {"val":"{\"caller\":\"254xy\",\"callee\":\"628xy6\",\"extension\":\"4\",\"_type\":\"outbound\",\"callerName\":\"NNAme Stefan\",\"calleeName\":\"NNAme Kerstin\"}","ack":true,"ts":1576184884682,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184851368}
                                    2019-12-12 22:08:04.999  - debug: tr-064-community.0 (31690) callmonitor raw data: "12.12.19 22:08:04;RING;2;030254xy;628xy6;SIP0;\r\n"
                                    2019-12-12 22:08:05.000  - debug: tr-064-community.0 (31690) callmonitor handle inbound message: {"caller":"030254xy","callee":"628xy6"}
                                    2019-12-12 22:08:05.003  - debug: tr-064-community.0 (31690) Search number 004930254xy in phonebook: {"name":"NNAme Stefan","normalizedName":"NNAmestefan","number":"004930254xy","id":"634","phonebookId":"0"}
                                    2019-12-12 22:08:05.004  - debug: tr-064-community.0 (31690) Search number 004930628xy6 in phonebook: {"name":"NNAme Kerstin","normalizedName":"NNAmekerstin","number":"004930628xy6","id":"631","phonebookId":"0"}
                                    2019-12-12 22:08:05.006  - debug: tr-064-community.0 (31690) callMonitor.set: type=inbound caller=030254xy callee=628xy6 callerName=NNAme Stefan calleeName=NNAme Kerstin
                                    2019-12-12 22:08:05.022  - debug: tr-064-community.0 (31690) State-Change {"val":true,"ack":true,"ts":1576184885010,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184885010}
                                    2019-12-12 22:08:05.026  - debug: tr-064-community.0 (31690) State-Change {"val":"030254xy","ack":true,"ts":1576184885011,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576183605807}
                                    2019-12-12 22:08:05.031  - debug: tr-064-community.0 (31690) State-Change {"val":"628xy6","ack":true,"ts":1576184885011,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184851814}
                                    2019-12-12 22:08:05.034  - debug: tr-064-community.0 (31690) State-Change {"val":"12.12.19 22:08:04","ack":true,"ts":1576184885011,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184885011}
                                    2019-12-12 22:08:05.039  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184885012,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182914757}
                                    2019-12-12 22:08:05.044  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184885013,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184851817}
                                    2019-12-12 22:08:05.048  - debug: tr-064-community.0 (31690) State-Change {"val":"{\"caller\":\"030254xy\",\"callee\":\"628xy6\",\"_type\":\"inbound\",\"callerName\":\"NNAme Stefan\",\"calleeName\":\"NNAme Kerstin\"}","ack":true,"ts":1576184885014,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184851819}
                                    2019-12-12 22:08:05.053  - debug: tr-064-community.0 (31690) State-Change {"val":"ring","ack":true,"ts":1576184885014,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184885014}
                                    2019-12-12 22:08:08.937  - debug: tr-064-community.0 (31690) in updateAll
                                    2019-12-12 22:08:08.939  - debug: tr-064-community.0 (31690) updateDevices
                                    2019-12-12 22:08:08.940  - debug: tr-064-community.0 (31690) forEachConfiguredDevice
                                    2019-12-12 22:08:09.991  - debug: tr-064-community.0 (31690) callmonitor raw data: "12.12.19 22:08:09;CONNECT;2;11;030254xy;\r\n"
                                    2019-12-12 22:08:09.993  - debug: tr-064-community.0 (31690) callmonitor handle connect message: {"caller":"030254xy","callee":"628xy6","_type":"inbound","callerName":"NNAme Stefan","calleeName":"NNAme Kerstin","extension":"11"}
                                    2019-12-12 22:08:09.997  - debug: tr-064-community.0 (31690) callMonitor.set: type=connect caller=030254xy callee=628xy6 callerName=NNAme Stefan calleeName=NNAme Kerstin
                                    2019-12-12 22:08:10.022  - debug: tr-064-community.0 (31690) State-Change {"val":false,"ack":true,"ts":1576184890002,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890002}
                                    2019-12-12 22:08:10.027  - debug: tr-064-community.0 (31690) State-Change {"val":"030254xy","ack":true,"ts":1576184890003,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890003}
                                    2019-12-12 22:08:10.032  - debug: tr-064-community.0 (31690) State-Change {"val":"628xy6","ack":true,"ts":1576184890003,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576183770528}
                                    2019-12-12 22:08:10.037  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184890004,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182926674}
                                    2019-12-12 22:08:10.042  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184890005,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576183770530}
                                    2019-12-12 22:08:10.047  - debug: tr-064-community.0 (31690) State-Change {"val":"11","ack":true,"ts":1576184890006,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890006}
                                    2019-12-12 22:08:10.055  - debug: tr-064-community.0 (31690) State-Change {"val":"12.12.19 22:08:09","ack":true,"ts":1576184890006,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890006}
                                    2019-12-12 22:08:10.060  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184890007,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182926676}
                                    2019-12-12 22:08:10.063  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184890016,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576183770535}
                                    2019-12-12 22:08:10.083  - debug: tr-064-community.0 (31690) State-Change {"val":"{\"caller\":\"030254xy\",\"callee\":\"628xy6\",\"_type\":\"connect\",\"callerName\":\"NNAme Stefan\",\"calleeName\":\"NNAme Kerstin\",\"extension\":\"11\"}","ack":true,"ts":1576184890017,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890017}
                                    2019-12-12 22:08:10.087  - debug: tr-064-community.0 (31690) State-Change {"val":"connect","ack":true,"ts":1576184890019,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890019}
                                    2019-12-12 22:08:10.089  - debug: tr-064-community.0 (31690) State-Change {"val":"connect","ack":true,"ts":1576184890019,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890019}
                                    2019-12-12 22:08:10.105  - debug: tr-064-community.0 (31690) callmonitor raw data: "12.12.19 22:08:10;CONNECT;1;4;628xy6;\r\n"
                                    2019-12-12 22:08:10.106  - debug: tr-064-community.0 (31690) callmonitor handle connect message: {"caller":"254xy","callee":"628xy6","extension":"4","_type":"outbound","callerName":"NNAme Stefan","calleeName":"NNAme Kerstin"}
                                    2019-12-12 22:08:10.113  - debug: tr-064-community.0 (31690) callMonitor.set: type=connect caller=254xy callee=628xy6 callerName=NNAme Stefan calleeName=NNAme Kerstin
                                    2019-12-12 22:08:10.126  - debug: tr-064-community.0 (31690) State-Change {"val":false,"ack":true,"ts":1576184890118,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890002}
                                    2019-12-12 22:08:10.130  - debug: tr-064-community.0 (31690) State-Change {"val":"254xy","ack":true,"ts":1576184890119,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890119}
                                    2019-12-12 22:08:10.135  - debug: tr-064-community.0 (31690) State-Change {"val":"628xy6","ack":true,"ts":1576184890120,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576183770528}
                                    2019-12-12 22:08:10.138  - debug: tr-064-community.0 (31690) State-Change {"val":"4","ack":true,"ts":1576184890120,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890120}
                                    2019-12-12 22:08:10.141  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184890121,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182926674}
                                    2019-12-12 22:08:10.145  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184890121,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576183770530}
                                    2019-12-12 22:08:10.150  - debug: tr-064-community.0 (31690) State-Change {"val":"12.12.19 22:08:10","ack":true,"ts":1576184890121,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890121}
                                    2019-12-12 22:08:10.154  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184890122,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182926676}
                                    2019-12-12 22:08:10.158  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184890122,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576183770535}
                                    2019-12-12 22:08:10.162  - debug: tr-064-community.0 (31690) State-Change {"val":"{\"caller\":\"254xy\",\"callee\":\"628xy6\",\"extension\":\"4\",\"_type\":\"connect\",\"callerName\":\"NNAme Stefan\",\"calleeName\":\"NNAme Kerstin\"}","ack":true,"ts":1576184890123,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890123}
                                    2019-12-12 22:08:10.166  - debug: tr-064-community.0 (31690) State-Change {"val":"connect","ack":true,"ts":1576184890123,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890019}
                                    2019-12-12 22:08:10.169  - debug: tr-064-community.0 (31690) State-Change {"val":"connect","ack":true,"ts":1576184890124,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890124}
                                    2019-12-12 22:08:12.263  - debug: tr-064-community.0 (31690) callmonitor raw data: "12.12.19 22:08:12;DISCONNECT;1;3;\r\n"
                                    2019-12-12 22:08:12.264  - debug: tr-064-community.0 (31690) callmonitor handle lastCall message: {"caller":"254xy","callee":"628xy6","extension":"4","_type":"connect","callerName":"NNAme Stefan","calleeName":"NNAme Kerstin","type":"disconnect","duration":3}
                                    2019-12-12 22:08:12.270  - debug: tr-064-community.0 (31690) callMonitor.set: type=lastCall caller=254xy callee=628xy6 callerName=NNAme Stefan calleeName=NNAme Kerstin
                                    2019-12-12 22:08:12.286  - debug: tr-064-community.0 (31690) State-Change {"val":false,"ack":true,"ts":1576184892275,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890002}
                                    2019-12-12 22:08:12.291  - debug: tr-064-community.0 (31690) State-Change {"val":"254xy","ack":true,"ts":1576184892275,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892275}
                                    2019-12-12 22:08:12.296  - debug: tr-064-community.0 (31690) State-Change {"val":"628xy6","ack":true,"ts":1576184892276,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184859270}
                                    2019-12-12 22:08:12.301  - debug: tr-064-community.0 (31690) State-Change {"val":"4","ack":true,"ts":1576184892277,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892277}
                                    2019-12-12 22:08:12.306  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184892277,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182933087}
                                    2019-12-12 22:08:12.310  - debug: tr-064-community.0 (31690) callmonitor raw data: "12.12.19 22:08:12;DISCONNECT;2;3;\r\n"
                                    2019-12-12 22:08:12.311  - debug: tr-064-community.0 (31690) callmonitor handle lastCall message: {"caller":"030254xy","callee":"628xy6","_type":"connect","callerName":"NNAme Stefan","calleeName":"NNAme Kerstin","extension":"11","type":"disconnect","duration":3}
                                    2019-12-12 22:08:12.325  - debug: tr-064-community.0 (31690) callMonitor.set: type=lastCall caller=030254xy callee=628xy6 callerName=NNAme Stefan calleeName=NNAme Kerstin
                                    2019-12-12 22:08:12.338  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184892278,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184859272}
                                    2019-12-12 22:08:12.340  - debug: tr-064-community.0 (31690) State-Change {"val":"disconnect","ack":true,"ts":1576184892279,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184859273}
                                    2019-12-12 22:08:12.343  - debug: tr-064-community.0 (31690) State-Change {"val":3,"ack":true,"ts":1576184892279,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892279}
                                    2019-12-12 22:08:12.345  - debug: tr-064-community.0 (31690) State-Change {"val":"12.12.19 22:08:12","ack":true,"ts":1576184892280,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892280}
                                    2019-12-12 22:08:12.348  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184892281,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182933103}
                                    2019-12-12 22:08:12.350  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184892281,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184859275}
                                    2019-12-12 22:08:12.359  - debug: tr-064-community.0 (31690) State-Change {"val":"{\"caller\":\"254xy\",\"callee\":\"628xy6\",\"extension\":\"4\",\"_type\":\"lastCall\",\"callerName\":\"NNAme Stefan\",\"calleeName\":\"NNAme Kerstin\",\"type\":\"disconnect\",\"duration\":3}","ack":true,"ts":1576184892282,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892282}
                                    2019-12-12 22:08:12.362  - debug: tr-064-community.0 (31690) State-Change {"val":"end","ack":true,"ts":1576184892282,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892282}
                                    2019-12-12 22:08:12.364  - debug: tr-064-community.0 (31690) State-Change {"val":"end","ack":true,"ts":1576184892283,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892283}
                                    2019-12-12 22:08:12.384  - debug: tr-064-community.0 (31690) State-Change {"val":false,"ack":true,"ts":1576184892370,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890002}
                                    2019-12-12 22:08:12.386  - debug: tr-064-community.0 (31690) State-Change {"val":"030254xy","ack":true,"ts":1576184892375,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892375}
                                    2019-12-12 22:08:12.389  - debug: tr-064-community.0 (31690) State-Change {"val":"628xy6","ack":true,"ts":1576184892376,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184859270}
                                    2019-12-12 22:08:12.393  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184892376,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182933087}
                                    2019-12-12 22:08:12.396  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184892377,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184859272}
                                    2019-12-12 22:08:12.398  - debug: tr-064-community.0 (31690) State-Change {"val":"11","ack":true,"ts":1576184892377,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892377}
                                    2019-12-12 22:08:12.404  - debug: tr-064-community.0 (31690) State-Change {"val":"disconnect","ack":true,"ts":1576184892378,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184859273}
                                    2019-12-12 22:08:12.409  - debug: tr-064-community.0 (31690) State-Change {"val":3,"ack":true,"ts":1576184892378,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892279}
                                    2019-12-12 22:08:12.411  - debug: tr-064-community.0 (31690) State-Change {"val":"12.12.19 22:08:12","ack":true,"ts":1576184892378,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892280}
                                    2019-12-12 22:08:12.416  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184892379,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182933103}
                                    2019-12-12 22:08:12.422  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184892379,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184859275}
                                    2019-12-12 22:08:12.425  - debug: tr-064-community.0 (31690) State-Change {"val":"{\"caller\":\"030254xy\",\"callee\":\"628xy6\",\"_type\":\"lastCall\",\"callerName\":\"NNAme Stefan\",\"calleeName\":\"NNAme Kerstin\",\"extension\":\"11\",\"type\":\"disconnect\",\"duration\":3}","ack":true,"ts":1576184892380,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892380}
                                    2019-12-12 22:08:12.430  - debug: tr-064-community.0 (31690) State-Change {"val":"end","ack":true,"ts":1576184892380,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892282}
                                    2019-12-12 22:08:12.432  - debug: tr-064-community.0 (31690) State-Change {"val":"end","ack":true,"ts":1576184892381,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892381}
                                    2019-12-12 22:08:20.527  - debug: tr-064-community.0 (31690) in updateAll
                                    2019-12-12 22:08:20.530  - debug: tr-064-community.0 (31690) updateDevices
                                    2019-12-12 22:08:20.530  - debug: tr-064-community.0 (31690) forEachConfiguredDevice
                                    apollon77 2 Replies Last reply Reply Quote 0
                                    • marcuskl
                                      marcuskl last edited by
                                      Findet man diesen Adaper schon in IoBroker/Adapter ?
                                        @conectas jetzt sollte aber alles geschrieben werden oder ?! Zumindestens sagt das log das
                                          @conectas sagte in Test Adapter tr-064-community v1.0.x:
                                          Das wird so eine Sache ... Den Stand von früher heute wiederherzustellen wir nahezu unmöglich ... und wir müssen jetzt mal endlich vorankommen
                                          • conectas
                                            @apollon77
                                            tr-064-community.0.callmonitor // Hat sich nicht geändert.
                                            tr-064-community.0.callForwarding sieht okay aus..
                                            tr-064-community.0.states ist bis auf den Eintrag: tr-064-community.0.states.calllists auch leer
                                            1.0k
                                            community tr-064
                                            88
                                            727
                                            188866
