    4. Test Adapter tr-064-community v1.0.x
    • conectas
      conectas @conectas last edited by
      Fall 02 auch der gleiche Fehler..
      2019-12-12 23:24:03.851  - debug: tr-064-community.0 (21048) callMonitor.set: type=outbound caller=254xy callee=628xy7 callerName=NName Stefan calleeName=NName Stefan
      2019-12-12 23:24:04.235  - debug: tr-064-community.0 (21048) callMonitor.set: type=inbound caller=030254xy callee=628xy7 callerName=NName Stefan calleeName=NName Stefan
      2019-12-12 23:24:06.296  - debug: tr-064-community.0 (21048) callMonitor.set: type=connect caller=030254xy callee=628xy7 callerName=NName Stefan calleeName=NName Stefan
      2019-12-12 23:24:06.437  - debug: tr-064-community.0 (21048) callMonitor.set: type=connect caller=254xy callee=628xy7 callerName=NName Stefan calleeName=NName Stefan
      2019-12-12 23:24:06.878  - debug: tr-064-community.0 (21048) in updateAll
      2019-12-12 23:24:06.881  - debug: tr-064-community.0 (21048) updateDevices
      2019-12-12 23:24:06.883  - debug: tr-064-community.0 (21048) forEachConfiguredDevice
      2019-12-12 23:24:09.784  - debug: tr-064-community.0 (21048) setting 0 enable=false
      2019-12-12 23:24:09.786  - debug: tr-064-community.0 (21048) setting 1 enable=false
      2019-12-12 23:24:09.787  - debug: tr-064-community.0 (21048) setting 2 enable=false
      2019-12-12 23:24:09.787  - debug: tr-064-community.0 (21048) setting 3 enable=false
      2019-12-12 23:24:09.800  - debug: tr-064-community.0 (21048) setting 4 enable=false
      2019-12-12 23:24:09.801  - debug: tr-064-community.0 (21048) setting 5 enable=true
      2019-12-12 23:24:09.802  - debug: tr-064-community.0 (21048) setting 6 enable=true
      2019-12-12 23:24:09.803  - debug: tr-064-community.0 (21048) setting 7 enable=true
      2019-12-12 23:24:09.804  - debug: tr-064-community.0 (21048) setting 8 enable=true
      2019-12-12 23:24:09.805  - debug: tr-064-community.0 (21048) setting 9 enable=true
      2019-12-12 23:24:10.891  - debug: tr-064-community.0 (21048) callMonitor.set: type=lastCall caller=254xy callee=628xy7 callerName=NName Stefan calleeName=NName Stefan
      2019-12-12 23:24:10.933  - debug: tr-064-community.0 (21048) callMonitor.set: type=lastCall caller=030254xy callee=628xy7 callerName=NName Stefan calleeName=NName Stefan
      2019-12-12 23:24:19.806  - debug: tr-064-community.0 (21048) in updateAll
      2019-12-12 23:24:19.809  - debug: tr-064-community.0 (21048) updateDevices
      2019-12-12 23:24:19.810  - debug: tr-064-community.0 (21048) forEachConfiguredDevice
      2019-12-12 23:24:22.140  - debug: tr-064-community.0 (21048) setting 0 enable=false
      2019-12-12 23:24:22.141  - debug: tr-064-community.0 (21048) setting 1 enable=false
      2019-12-12 23:24:22.142  - debug: tr-064-community.0 (21048) setting 2 enable=false
      2019-12-12 23:24:22.142  - debug: tr-064-community.0 (21048) setting 3 enable=false
      2019-12-12 23:24:22.143  - debug: tr-064-community.0 (21048) setting 4 enable=false
      2019-12-12 23:24:22.143  - debug: tr-064-community.0 (21048) setting 5 enable=true
      2019-12-12 23:24:22.143  - debug: tr-064-community.0 (21048) setting 6 enable=true
      2019-12-12 23:24:22.144  - debug: tr-064-community.0 (21048) setting 7 enable=true
      2019-12-12 23:24:22.144  - debug: tr-064-community.0 (21048) setting 8 enable=true
      2019-12-12 23:24:22.145  - debug: tr-064-community.0 (21048) setting 9 enable=true
        apollon77 last edited by
        Ok, dann mal eine Frage ... der Code macht ein was: Wenn sich der Wert vom State nicht ändert im Vergleich zu dem der aktuell gesetzt ist ... dann wird auch nichts aktualisiert. Kann es sein das das dein Missverständnis ist? UND im Standard hier ist der Delay nachdem Änderungen übernommen werden 500ms.
        Ich habe jetzt als letztes für heute noch ein Update auf GitHub mit:
        • State Change logging ... so sehen wir besser was wirklich geschrieben wird
        • Calllist logging für Refreshs
        Also damit bitte nochmal solche call logs @conectas
        Danke!
        conectas 1 Reply Last reply Reply Quote 0
        • conectas
          conectas @apollon77 last edited by
          Siehe E-Mail .. 2. kommt gleich
            apollon77 @conectas last edited by
            @conectas schaue ich morgen an. Für heute bin ich zu Tod und deprimiert 😉
            Marco Tönjes 1 Reply Last reply Reply Quote 0
            • Marco Tönjes
              Marco Tönjes @apollon77 last edited by
              OFFTOPIC
              @apollon77 Nachdem das andere zu ist und ich dir nur ein Feedback geben wollte. Ich habe die Vertrauenseinstellung fürs CERT vergessen :(( nun hat alles auf den 1 Versuch geklappt. Danke Dir PS: Youtube hatte dieses mal geholfen 🙂
              Gruß Marco
              << kann gelöscht oder verschoben werden >>
                apollon77 @Marco Tönjes last edited by
                @Marco-Tönjes ich verstehe Nicht was du meinst? Wenn es um einen anderen Adapter geht ist es wiiiirklich off topic
                  So, auf GitHub gibts jetzt die 2.0.0 ... Calllists gehen auch wieder
                  jetzt sagt mal .. was ist jetzt noch offen?
                  Generell eine Info zu "Sate-Aktualisierungen" bei dem Adapter: States werden nur dann aktualisiert wenn sich der Wert auch ändert! Das hat soef so gebaut und ist immer noch so drin.
                  Wenn sich alse caller/callee oder so nicht ändern dann vllt weil es der gleiche Wert wäre wie vorher?
                  Im Debug Log sieht man jetzt schön was geschrieben wird.
                  Es wäre super wenn jemand mal noch testen könnte das doe phonebook.number/name States funktionieren und da sind wo Sie sein sollen.
                  • Knallochse
                    Knallochse last edited by
                    @apollon77 wäre es möglich den Adapter so zu erweitern, dass er anzeigt mit welchem Zugangspunkt im Mesh Netzwerk die WLAN Geräte verbunden sind? (Fritzbox, Repeater1, Repeater2 usw.)
                      apollon77 @Knallochse last edited by
                      @Knallochse Jetzt lass uns das ding erstmal irgendwie überhaupt wieder zum laufen bringen ... Feature Requests -> GitHub issue bitte
                      Knallochse 1 Reply Last reply Reply Quote 0
                      • Knallochse
                        Knallochse @apollon77 last edited by
                        @apollon77 Sorry, war von mir nicht als Aufforderung gemeint. Du leistest hervorragende Arbeit und ich bin Dankbar für deinen Einsatz.
                          @Knallochse Alles gut 🙂 Ich bin nur gerade in dem einen Fokus und der dauert schon deutlich länger als gedacht 😞 bevor wir da neue Features einbauen muss man umfangreicher ran
                            klmf2 last edited by
                            so wie ich das verstanden habe, kann man über den Adapter das Bild mit dem QR-Code des Gäste Wlan herunterladen.
                            Ich finde aber nichts, wie man das hin bekommt. Sämtlich Suchbegriffe führten mich nicht weiter. Kann mir jemand sagen, wo ich weitere Infos nachlesen kann? Muss ich dazu bei Command etwas eingeben?
                              sigi234 Forum Testing Most Active @klmf2 last edited by sigi234
                              @klmf2 sagte in Test Adapter tr-064-community v1.0.x:
                              JS Skript:
                              // https://www.npmjs.com/package/qr-image
                              var MySSID          = "xxx";           //  SSID Name
                              var MyCrypt         = "xxx";                //  [WEP|WPA|WPA2]
                              var MyVisibility    = "n";                  //  Hidden SSID?
                              var cronStr         = "1 3 * * *"           // Script wird jeden Tag um 03:01 Ausgeführt
                              var idQRZiel = "javascript.0.QR-Code.Gast"; // Zieldatenpunkt für QR-Code
                              var IdGPasswd = "tr-064-community.0.states.wlanGuestPassword"; /*wlanGuestPassword*/
                              if(MyVisibility == "y") {
                                  var MyHidden="H:true";
                              else {
                                  MyHidden="";
                              createState(idQRZiel, "", {
                                   name: 'QR-Code für Gastpasswort',
                                   desc: 'QR-Code für Gastpasswort',
                                   type: 'string',
                                   role: 'value'
                              function randomString(length) {         // Methode zur Erstellung eines Random-Passworts kann angepasst werden
                                  return Math.round((Math.pow(36, length + 1) - Math.random() * Math.pow(36, length))).toString(36).slice(1);
                              function createQRcode() {
                                  var qr = require('qr-image');
                                  var NewPasswd = randomString(16);       // 16 Stelliges Passwort
                                       var svg_string = qr.imageSync('WIFI:S:'+MySSID+';T:'+MyCrypt+';P:'+NewPasswd+';'+MyHidden+';', { type: 'svg' });
                                  setState(idQRZiel, svg_string);
                                  setState(IdGPasswd, NewPasswd);
                              // regelmässige Wiederholungen
                              schedule(cronStr, createQRcode);
                              Widget:
                              [{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"{javascript.0.QR-Code.Gast}"},"style":{"left":"1178px","top":"606px","width":"116px","height":"104px","z-index":"2"},"widgetSet":"basic"}]
                                Hups - das ging schnell. Vielen Dank
                                  Bitte benutzt das Voting rechts unten im Beitrag wenn er euch geholfen hat.😀
                                    Hey alle ausser Sigi234 (der hat heute Tagsüber schon mit mir massiv getestet) ... Wie ist der Stand? Jemand die 2.0.0 probiert? Alles ok? Was fehlt?
                                    sigi234 K crunchip ? bahnuhr 5 Replies Last reply Reply Quote 0
                                      klmf2 @sigi234 last edited by
                                      @sigi234 sagte in Test Adapter tr-064-community v1.0.x:
                                      Mache ich gerne. Habe aber noch Fehlermeldungen. Schaue mir das gerade genauer an.
                                      javascript.0	2019-12-14 00:05:00.043	error	(7480) at Timer.processTimers (timers.js:223:10)
                                      javascript.0	2019-12-14 00:05:00.043	error	(7480) at listOnTimeout (timers.js:263:5)
                                      javascript.0	2019-12-14 00:05:00.041	error	(7480) at tryOnTimeout (timers.js:300:5)
                                      javascript.0	2019-12-14 00:05:00.041	error	(7480) at ontimeout (timers.js:436:11)
                                      javascript.0	2019-12-14 00:05:00.040	error	(7480) at Timeout._onTimeout (C:\Program Files\iobroker\iobroker\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:501:7)
                                      javascript.0	2019-12-14 00:05:00.040	error	(7480) at C:\Program Files\iobroker\iobroker\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:543:11
                                      javascript.0	2019-12-14 00:05:00.040	error	(7480) at Job.invoke (C:\Program Files\iobroker\iobroker\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:173:10)
                                      javascript.0	2019-12-14 00:05:00.039	error	(7480) at Job.nodeSchedule.scheduleJob [as job] (C:\Program Files\iobroker\iobroker\node_modules\iobroker.javascript\lib\sandbox.js:1181:34)
                                      javascript.0	2019-12-14 00:05:00.038	error	(7480) at Object.createQRcode (script.js.common.Telefon_FritzBox.GästePasswort_lesen:34:30)
                                      javascript.0	2019-12-14 00:05:00.029	error	(7480) Error in callback: TypeError: Cannot read property 'imageSync' of undefined
                                      javascript.0	2019-12-14 00:05:00.027	error	(7480) at Timer.processTimers (timers.js:223:10)
                                      javascript.0	2019-12-14 00:05:00.027	error	(7480) at listOnTimeout (timers.js:263:5)
                                      javascript.0	2019-12-14 00:05:00.027	error	(7480) at tryOnTimeout (timers.js:300:5)
                                      javascript.0	2019-12-14 00:05:00.026	error	(7480) at ontimeout (timers.js:436:11)
                                      javascript.0	2019-12-14 00:05:00.026	error	(7480) at Timeout._onTimeout (C:\Program Files\iobroker\iobroker\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:501:7)
                                      javascript.0	2019-12-14 00:05:00.025	error	(7480) at C:\Program Files\iobroker\iobroker\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:543:11
                                      javascript.0	2019-12-14 00:05:00.025	error	(7480) at Job.invoke (C:\Program Files\iobroker\iobroker\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:173:10)
                                      javascript.0	2019-12-14 00:05:00.024	error	(7480) at Job.nodeSchedule.scheduleJob [as job] (C:\Program Files\iobroker\iobroker\node_modules\iobroker.javascript\lib\sandbox.js:1181:34)
                                      javascript.0	2019-12-14 00:05:00.024	error	(7480) at Object.createQRcode (script.js.common.Telefon_FritzBox.GästePasswort_lesen:32:14)
                                      javascript.0	2019-12-14 00:05:00.023	error	(7480) script.js.common.Telefon_FritzBox.GästePasswort_lesen: Error: Cannot find module 'C:\Program Files\iobroker\iobroker\node_modules\iobroker.javascript\lib/../../qr-image'
                                        Du musst das Modul qr-image in den JS Adapter eintragen! Neu starten.
                                          jau Klasse. Läuft. 🙂
                                            sigi234 Forum Testing Most Active @apollon77 last edited by
                                            @apollon77 sagte in Test Adapter tr-064-community v1.0.x:
                                            gibt es wo eine Api was alles ausgelesen werden kann, die FB hat ja einen Menge an Daten.
                                            Da hätte ich für später mal noch so einige Wünsche. 😀
                                            1.2k
                                            community tr-064
                                            88
                                            727
                                            188993
