    4. Fire TV Adapter
    SOLVED Fire TV Adapter
    • O
      ooooli last edited by
      Yeah! Danke - hab ich nicht gesehen. Nun funktioniert der Adapter.
        Lordcyber last edited by
        Hallo, an dem Adapter bin ich jetzt auch dran.
        Habe es nach den anleitungen heir installiert.
        es kommt allerdings:
        host.IoBroker	2019-09-09 22:54:17.799	info	Restart adapter system.adapter.firetv.0 because enabled
        host.IoBroker	2019-09-09 22:54:17.799	error	instance system.adapter.firetv.0 terminated with code 1 ()
        Caught	2019-09-09 22:54:17.799	error	by controller[0]: at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3)
        Caught	2019-09-09 22:54:17.799	error	by controller[0]: at startup (internal/bootstrap/node.js:283:19)
        Caught	2019-09-09 22:54:17.799	error	by controller[0]: at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
        Caught	2019-09-09 22:54:17.799	error	by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
        Caught	2019-09-09 22:54:17.799	error	by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
        Caught	2019-09-09 22:54:17.799	error	by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
        Caught	2019-09-09 22:54:17.799	error	by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
        Caught	2019-09-09 22:54:17.799	error	by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
        Caught	2019-09-09 22:54:17.799	error	by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.firetv/firetv.js:79:20)
        Caught	2019-09-09 22:54:17.799	error	by controller[0]: at Object.exports.Adapter (/opt/iobroker/node_modules/soef/soef.js:1148:23)
        Caught	2019-09-09 22:54:17.799	error	by controller[0]: TypeError: fns.adapter is not a function
        Caught	2019-09-09 22:54:17.799	error	by controller[0]: ^
        Caught	2019-09-09 22:54:17.799	error	by controller[0]: fns.adapter = fns.adapter(options);
        Caught	2019-09-09 22:54:17.798	error	by controller[0]: /opt/iobroker/node_modules/soef/soef.js:1148
        host.IoBroker	2019-09-09 22:54:17.500	info	instance system.adapter.firetv.0 started with pid 25136
        Was stimmt da nicht?
          sigi234 Forum Testing Most Active @Lordcyber last edited by
          @Lordcyber
          Suche mal nach soef
            @sigi234 said in Fire TV Adapter:
            @Lordcyber
            Suche mal nach soef
            Habe jetzt das soef installiert. der Fehler ist aber immer noch da.
              @Lordcyber sagte in Fire TV Adapter:
              @Lordcyber
              Suche mal nach soef
              hast du an deinem stick die Meldung .. adb erhalten und freigeschaltet ?
                Lordcyber @sigi234 last edited by Lordcyber
                @Lordcyber
                Suche mal nach soef
                Nein, es kam auch keine Meldung. Im Menü hab ich debugging auf an gestellt.
                Neugestartet wurde der Stick auch.
                Node.js
                v10.16.3
                NPM
                6.11.3
                kann da was falsch sein?
                  Pascal51882 last edited by
                  habe nach den Anleitungen hier auf dieser Seite den Adapter, ADB und Fastboot installiert.
                  ADB liegt bei mir unter: /usr/lib/android-sdk/platform-tools/adb
                  So habe ich ihn auch im Adapter eingegeben.
                  ADB ist auf meinem Fire TV aktiv. Habe bereits Apps darüber installiert.
                  Der Adapter bleibt rot. Habe ich etwas übersehen?
                  Laut Log wird ein Modul nicht gefunden. Was muss ich noch machen bzw. mache ich falsch?
                  host.DebianVM	2019-11-10 17:07:51.368	info	Restart adapter system.adapter.firetv.0 because enabled
                  host.DebianVM	2019-11-10 17:07:51.368	error	instance system.adapter.firetv.0 terminated with code 1 ()
                  Caught	2019-11-10 17:07:51.368	error	by controller[0]: at bootstrap_node.js:625:3
                  Caught	2019-11-10 17:07:51.368	error	by controller[0]: at startup (bootstrap_node.js:204:16)
                  Caught	2019-11-10 17:07:51.368	error	by controller[0]: at Function.Module.runMain (module.js:694:10)
                  Caught	2019-11-10 17:07:51.368	error	by controller[0]: at Function.Module._load (module.js:498:3)
                  Caught	2019-11-10 17:07:51.368	error	by controller[0]: at tryModuleLoad (module.js:506:12)
                  Caught	2019-11-10 17:07:51.368	error	by controller[0]: at Module.load (module.js:566:32)
                  Caught	2019-11-10 17:07:51.368	error	by controller[0]: at Object.Module._extensions..js (module.js:664:10)
                  Caught	2019-11-10 17:07:51.368	error	by controller[0]: at Module._compile (module.js:653:30)
                  Caught	2019-11-10 17:07:51.368	error	by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.firetv/firetv.js:6:14)
                  Caught	2019-11-10 17:07:51.368	error	by controller[0]: at require (internal/module.js:11:18)
                  Caught	2019-11-10 17:07:51.368	error	by controller[0]: at Module.require (module.js:597:17)
                  Caught	2019-11-10 17:07:51.368	error	by controller[0]: at Function.Module._load (module.js:475:25)
                  Caught	2019-11-10 17:07:51.368	error	by controller[0]: at Function.Module._resolveFilename (module.js:548:15)
                  Caught	2019-11-10 17:07:51.368	error	by controller[0]: Error: Cannot find module './node_modules/adbkit/lib/adb/client'
                  Caught	2019-11-10 17:07:51.367	error	by controller[0]: ^
                  Caught	2019-11-10 17:07:51.367	error	by controller[0]: throw err;
                  Caught	2019-11-10 17:07:51.367	error	by controller[0]: module.js:550
                  host.DebianVM	2019-11-10 17:07:51.203	info	instance system.adapter.firetv.0 started with pid 11631
                  host.DebianVM	2019-11-10 17:07:51.199	info	object change system.adapter.firetv.0
                  host.DebianVM	2019-11-10 17:07:50.305	info	Restart adapter system.adapter.firetv.0 because enabled
                  • I
                    ichwersonst @Pascal51882 last edited by
                    Hallo Leute,
                    ich bin neu hier und ich hab genau das gleiche Problem und Meldungen wie Pascal51882 vor mir geschrieben hat.
                    Ich habe schon den Thread komplett gelesen und auch in anderen Foren nach Hinweisen gesucht. Leider komme ich nicht weiter.
                    Ich würde mich freuen, wenn da jemand der mehr mit den Meldungen anfangen kann, ein paar Tipps geben könnte was da falsch läuft.
                    Grüße 🙂
                      ChrisXY last edited by
                      Ich auch .. scheint wohl an JS 2.0 zu liegen 😞
                        michi150870 last edited by
                        Hallo, ich habe nach dieser Anleitung gemacht und geht schon seit Monaten. Auch mit JS 2.0 .
                        https://www.schimmer-media.de/forum/index.php?thread/513-firetv-adaptor/&postID=30719&highlight=Firetv#post30719
                          Ja die lösung ist "npm install soef" danach lief es dann auch.
                          • metaxa
                            metaxa @xbow42 last edited by metaxa
                            @xbow42 sagte in Fire TV Adapter:
                            Jetzt werde ich erst mal sehen was man mit dem Adapter überhaupt anfangen kann.
                            cu xbow
                            Hi, ich habe den Adapter nun endlich auf grün 🙂
                            Hast du oder irgendwer Steuer- oder mehr Infomöglichkeiten entdeckt?
                            Mehr gibts bei mir nicht:
                            Andersrum gefragt: Läuft! freu und nun?
                            LG, mxa
                            • Stephan Schleich
                              Stephan Schleich @kmxak last edited by Stephan Schleich
                              Gibt's mittlerweile eine Lösung?
                              Hab n aktuelles System bekomm aber folgende Fehlermeldung.
                              ADB etc geht bereits, nur der Adapter meckert.
                                crunchip Forum Testing Most Active @Stephan Schleich last edited by
                                @Stephan-Schleich sagte in Fire TV Adapter:
                                scheinbar gehts noch nicht, auch am Stick aktiviert?
                                Stephan Schleich 1 Reply Last reply Reply Quote 0
                                • Stephan Schleich
                                  Stephan Schleich @crunchip last edited by Stephan Schleich
                                  Die Anleitungen hier stimmen schon, ihr müsste nur am Schluss noch unter "/opt/iobroker/node_modules/iobroker.firetv" "npm install soef" ausführen und schon läufts
                                    Flopsi last edited by Negalein
                                    Bei mir hat es so geklappt nach dieser Anleitung:
                                    am Ende muss ich aber noch den Tip von befolgen danach wurde es grün 🙂
                                    @Stephan Schleich
                                    Stephan Schleich Starter 14. Feb. 2020, 07:35
                                    Die Anleitungen hier stimmen schon, ihr müsste nur am Schluss noch unter >"/opt/iobroker/node_modules/iobroker.firetv" "npm install soef" ausführen und schon läufts
                                    cd /opt/iobroker/node_modules/iobroker.firetv
                                    dann
                                    npm install soef
                                    das war es bei mir.
                                    Es wurde GRÜN.
                                    • I
                                      ichwersonst @manne_r last edited by
                                      @manne_r ich bin gerade am verzweifeln beim starten einer app über den firetv adapter.
                                      ich finde einfach nicht heraus, welcher befehl in welchem syntax in die start app zeile im objekte verzeichnis muss.
                                      Ich hab die package names herausgefunden und ich vermute das ich die class duch ein "/" getrennt angeben muss. leider funktioniert es nicht.
                                      als result bekomme ich das hier wieder : Error: Activity class {com.spotify.tv.android/MainActicity} does not exist.
                                      Vielleicht kannst du mir ja helfen ... würde mich freuen 🙂
                                      harrym 1 Reply Last reply Reply Quote 0
                                      • harrym
                                        harrym @ichwersonst last edited by
                                        @ichwersonst einfach den Namen verwenden? Starten kannst du mMn eh nur eine App nach der anderen.
                                        • I
                                          ichwersonst @harrym last edited by
                                          @harrym das funktioniert leider nur mit netflix.
                                          Alle anderen Apps bringen dieses Result wenn ich nur den Namen (z.B. YoutTube) verwende: Error: Activity class {YouTube/MainActicity} does not exist.
                                            Sali84 last edited by
                                            Weiss einer wie ich die ADB.exe bei einer Docker installation, "installiert" bekomme? oder muss ich einfach die Exe Datei im Pfad im Container angeben?
                                            Kann man nur die einzelne Exe irgendwo downloaden?
                                            Grüsse
                                            181
                                            52124
