    4. Backup mit 1.3.3 Stoppt
    UNSOLVED Backup mit 1.3.3 Stoppt
    • Z
      zgadgeter last edited by zgadgeter
      Hallo, bie mir funktioniert der Backup Adapter nicht mehr seid dem update auf 1.3.3. Habe Gestern noch ein update gemacht mit 1.3.2 (glaube ich), aber jetzt bleibt das backup stehen, siehe Unten. Im Log steht folgendes, aber alles außer NAS backup ist deaktiviert, auch dropbox.
      backitup.0	2019-12-15 12:23:56.758	info	(734) [iobroker] backup was activated at 03:00 every 1 day(s)
      backitup.0	2019-12-15 12:23:56.687	info	(734) starting. Version 1.3.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.16.0
      host.ubuntu_iobroker	2019-12-15 12:23:52.139	info	instance system.adapter.backitup.0 started with pid 734
      host.ubuntu_iobroker	2019-12-15 12:23:22.104	info	Restart adapter system.adapter.backitup.0 because enabled
      host.ubuntu_iobroker	2019-12-15 12:23:22.104	info	instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
      host.ubuntu_iobroker	2019-12-15 12:23:22.074	error	Caught by controller[0]: at processImmediate (timers.js:658:5)
      host.ubuntu_iobroker	2019-12-15 12:23:22.074	error	Caught by controller[0]: at tryOnImmediate (timers.js:676:5)
      host.ubuntu_iobroker	2019-12-15 12:23:22.074	error	Caught by controller[0]: at runCallback (timers.js:705:18)
      host.ubuntu_iobroker	2019-12-15 12:23:22.074	error	Caught by controller[0]: at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4749:38)
      host.ubuntu_iobroker	2019-12-15 12:23:22.073	error	Caught by controller[0]: at Adapter.emit (events.js:198:13)
      host.ubuntu_iobroker	2019-12-15 12:23:22.073	error	Caught by controller[0]: at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.backitup/main.js:67:17)
      host.ubuntu_iobroker	2019-12-15 12:23:22.073	error	Caught by controller[0]: at startBackup (/opt/iobroker/node_modules/iobroker.backitup/main.js:44:9)
      host.ubuntu_iobroker	2019-12-15 12:23:22.073	error	Caught by controller[0]: at executeScripts (/opt/iobroker/node_modules/iobroker.backitup/lib/execute.js:176:37)
      host.ubuntu_iobroker	2019-12-15 12:23:22.069	error	Caught by controller[0]: TypeError: Cannot read property 'dropbox' of null
      backitup.0	2019-12-15 12:23:21.399	info	(32278) Terminated (NO_ERROR): Without reason
      backitup.0	2019-12-15 12:23:21.398	info	(32278) terminating
      backitup.0	2019-12-15 12:23:20.883	error	at processImmediate (timers.js:658:5)
      backitup.0	2019-12-15 12:23:20.883	error	at tryOnImmediate (timers.js:676:5)
      backitup.0	2019-12-15 12:23:20.883	error	at runCallback (timers.js:705:18)
      backitup.0	2019-12-15 12:23:20.883	error	at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4749:38)
      backitup.0	2019-12-15 12:23:20.883	error	at Adapter.emit (events.js:198:13)
      backitup.0	2019-12-15 12:23:20.883	error	at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.backitup/main.js:67:17)
      backitup.0	2019-12-15 12:23:20.883	error	at startBackup (/opt/iobroker/node_modules/iobroker.backitup/main.js:44:9)
      backitup.0	2019-12-15 12:23:20.883	error	at executeScripts (/opt/iobroker/node_modules/iobroker.backitup/lib/execute.js:176:37)
      backitup.0	2019-12-15 12:23:20.883	error	(32278) TypeError: Cannot read property 'dropbox' of null
      backitup.0	2019-12-15 12:23:20.882	error	(32278) uncaught exception: Cannot read property 'dropbox' of null
      backitup.0	2019-12-15 12:23:18.732	info	(32278) [iobroker] backup was activated at 03:00 every 1 day(s)
      backitup.0	2019-12-15 12:23:18.651	info	(32278) starting. Version 1.3.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.16.0
      Haben auch andere dieses Problem?
      Systemdata Bitte Ausfüllen
      Hardwaresystem: NUC5CPHY
      Arbeitsspeicher: 4GB
      Festplattenart: SSD128GB
      Betriebssystem: Debian
      Node-Version: 10.16.0
      Nodejs-Version: 10.16.0
      NPM-Version: v6.10.1-next.1
      Installationsart: Skript/Manuell
      Image genutzt: Ja/Nein
      Ort/Name der Imagedatei: Link
      Glasfaser simatec 2 Replies Last reply Reply Quote 0
      • Glasfaser
        Glasfaser @zgadgeter last edited by Glasfaser
        @zgadgeter
        Mache mal ein Reboot von deinem System
        und danach nochmal ein Backup!
        PS: Kennst du diesen Thread, da wäre deine Frage / Problem besser aufgehoben .
        • simatec
          simatec Developer Most Active @zgadgeter last edited by
          @zgadgeter
          Fehler wird schnellstmöglich gefixt.
          Um erstmal den Fehler grob zu beheben, aktiviere mL die Dropbox Option, speichere diese und deaktiviere sie im Anschluss wieder.
          Fix kommt heute noch
          • Z
            Hallo, und danke für die Hilfe.
            System hatte ich schon mal neu gestartet, brachte nichts.
            Jetzt habe ich backup deinstalliert, und wieder installiert, und es ist jetzt durchgelaufen. Die Integrität des Backups kann ich nicht prüfen, aber von der Groesse ist es fast identisch mit dem letzten, also gehe ich davon aus das es ok ist.
            Danke für die Hinweise/Hilfe.
            • Z
              zgadgeter @simatec last edited by
              @simatec said in Backup mit 1.3.3 Stoppt:
              Das hatte ich auch schon mal probiert...hat nichts gebracht. Nur deinstallieren, jetzt funktioniert es wieder. Danke!
              • simatec
                @zgadgeter sagte in Backup mit 1.3.3 Stoppt:
                Die Version 1.3.3?
                • Z
                  Die Version 1.3.3?
                  Ja, diese Version.
                  backup 1.3.3
