    4. Test Adapter tr-064-community v1.0.x
    • bahnuhr
      Ich kann nicht teste.
      Bekomme den Adapter nicht mehr zum starten.
      host.Asus-Buero	2019-12-15 18:30:26.669	error	startInstance tr-064-community.0: cannot find start file!
      host.Asus-Buero	2019-12-15 18:30:26.666	info	object change system.adapter.tr-064-community.0
      iobroker	2019-12-15 18:29:58.113	info	host.Asus-Buero object system.adapter.tr-064-community.0 created
      host.Asus-Buero	2019-12-15 18:29:58.106	error	startInstance tr-064-community.0: cannot find start file!
      host.Asus-Buero	2019-12-15 18:29:58.079	info	object change system.adapter.tr-064-community.0
      iobroker	2019-12-15 18:29:58.038	info	host.Asus-Buero object system.adapter.tr-064-community.0.alive created
      iobroker	2019-12-15 18:29:58.009	info	host.Asus-Buero object system.adapter.tr-064-community.0.connected created
      iobroker	2019-12-15 18:29:57.980	info	host.Asus-Buero object system.adapter.tr-064-community.0.cpu created
      iobroker	2019-12-15 18:29:57.952	info	host.Asus-Buero object system.adapter.tr-064-community.0.cputime created
      iobroker	2019-12-15 18:29:57.923	info	host.Asus-Buero object system.adapter.tr-064-community.0.memHeapUsed created
      iobroker	2019-12-15 18:29:57.895	info	host.Asus-Buero object system.adapter.tr-064-community.0.memHeapTotal created
      iobroker	2019-12-15 18:29:57.866	info	host.Asus-Buero object system.adapter.tr-064-community.0.memRss created
      iobroker	2019-12-15 18:29:57.837	info	host.Asus-Buero object system.adapter.tr-064-community.0.uptime created
      iobroker	2019-12-15 18:29:57.807	info	host.Asus-Buero object system.adapter.tr-064-community.0.inputCount created
      iobroker	2019-12-15 18:29:57.780	info	host.Asus-Buero object system.adapter.tr-064-community.0.outputCount created
      iobroker	2019-12-15 18:29:57.774	info	host.Asus-Buero create instance tr-064-community
      Es kommt: cannot find start file!
      Habe ihn schon deinstalliert. von git neu geholt und Adapter wieder installiert.
      Dann kommt o.g. Punkte.
      mfg Dieter
      • bahnuhr
        Nachtrag:
        iob auf win7
          apollon77 @bahnuhr last edited by
          @bahnuhr Versuch mal ein upload. (Du hattest noch Controller 1.5 gell?!)
          • bahnuhr
            bahnuhr Forum Testing Most Active @apollon77 last edited by
            @apollon77 sagte in Test Adapter tr-064-community v1.0.x:
            Controller 1.5 gell
            ja, 1.5.11
            upload?
            Ich vermute mal nein.
            Frage:
            Was meinst du mit upload ?
              @bahnuhr schau mal den Namen korrekt an ... ist glaube ich ein großes O und keine 0 vor der 64 ... 😉
              Aber ja genau das meine ich an sich.
              • bahnuhr
                sieht aber für mich wie eine 0 aus.
                Ne, das klappt nicht mit der o.
                  @bahnuhr darf beim upload die Instanzen nummer dabei sein?
                  bahnuhr apollon77 2 Replies Last reply Reply Quote 0
                  • bahnuhr
                    bahnuhr Forum Testing Most Active @Homoran last edited by
                    @Homoran sagte in Test Adapter tr-064-community v1.0.x:
                    Der Rainer !!!
                    Ja, das wars.
                    So, nun teste ich mal.
                    • bahnuhr
                      bahnuhr Forum Testing Most Active last edited by bahnuhr
                      Gut, ich teste doch nicht.
                      Der Adpater will wohl mit 1.5 nicht.
                      Und update wollte ich noch zurückstellen (bis ich das Gefühl habe, dass alles andere läuft).
                        apollon77 @Homoran last edited by
                        @Homoran Nein darf nicht.
                          apollon77 @bahnuhr last edited by apollon77
                          @bahnuhr uuuuiii ja ... deswegen 2.0.0 und sorry hatte das komplett vom Radar verloren sonst hätte ich es dir vorher gesagt 😞
                          • bahnuhr
                            Auch gut, dann erst mal für mich erledigt.
                            Habe auf meinem Testsystem (win10 und iob als Master / raspi 3 als slave) noch ein paar Probleme mit der neuen Umgebung:
                            • wie kopiere ich in raspi mit der neuen Umgebung eine Datei in ein Verzeichnis?
                              Mit winscp klappt dies nicht.
                              Und in mbus kann man noch keinen gerätenamen eingeben.
                            • Wie kopiere per script in win10 auf einen Laufwerksbuchstaben.
                              Klappt derzeit nicht (oder ich bekomme es nicht hin.
                            Habe hier auch ein thread aufgemacht. Antworten kamen da nicht.
                            Also dann.
                            • bahnuhr
                              So, habs auf meinem Testsystem mit win10 iob und js> 2 mal installiert.
                              Auf debug gestellt.
                              Es werden zahlreiche Namen meines Tel.buchs angezeigt.
                              Test phonebook.
                              Eingabe meiner tel. unter phonebook Number
                              Es erfolgt keine Anzeige des Names unter phonebook.name
                              Und umgedreht.
                              Eingabe eines names der vorher unter debug eingelesen wurde.
                              Es erfolgt keine Anzeige der Tel.Nr. unter phonebook.number
                              Sollte jetzt funktionieren, oder ?
                              sigi234 apollon77 2 Replies Last reply Reply Quote 0
                                sigi234 Forum Testing Most Active @bahnuhr last edited by
                                @bahnuhr sagte in Test Adapter tr-064-community v1.0.x:
                                In Debug oder unter Objekte?
                                • bahnuhr
                                  bahnuhr Forum Testing Most Active @sigi234 last edited by
                                  @sigi234 sagte in Test Adapter tr-064-community v1.0.x:
                                  Debug
                                    sigi234 Forum Testing Most Active @bahnuhr last edited by sigi234
                                    Debug
                                    Ok, ist bei mir auch so.
                                    @apollon77 ist da gerade dran.
                                      @bahnuhr kannst du mir ein debug log vom
                                      Start und von so einem
                                      Versuch das mit Name und Nummer mal per email schicken ?!
                                      Iobroker@fischer-ka.de
                                      Dann sehe ich mir das morgen mal an
                                        GitHub ist nochmal aktualisiert und ich bin im GitHub mal alle übernommen und neuen Issues durchgegangen. Es sind jetzt nur noch enhancements und ein/zwei Themen offen.
                                        Bitte checkt es nochmal alles und meldet euch mit Details zu den offenen Themen.
                                        conectas 1 Reply Last reply Reply Quote 0
                                          steimi last edited by
                                          Ich habe den Adapter zwar installiert, aber noch nicht wirklich im Einsatz. Aber den Schreibfehler kannst du doch sicherlich leicht beseitigen. Danke!
                                          • conectas
                                            conectas @apollon77 last edited by
                                            @apollon77
                                            Moin!
                                            Ich sehe das Phonebook 0 und 1 ausgelesen werden.
                                            Frage wo wird das eigentlich hingeschrieben?
                                            /sg
                                            conectas apollon77 2 Replies Last reply Reply Quote 0
                                            community tr-064
                                            88
                                            727
                                            189083
