Test Adapter ioBroker.backitup v3.1.x
Nein .. kein Error Meldung oder sonstige Fehler !
@vauvau07
Kannst du bitte mal die Version 1.3.4 vom Github installieren und testen, ob der Fehler behoben ist?
Ich kann den Fehler leider nicht nachstellen, habe aber eine Vermutung.Habe das in Version 1.3.4 auf Github gefixt.
@simatec
leider für mich das gleiche Ergebnis mit 1.3.4backitup.0 2019-12-15 16:39:20.461 debug (10481) mount activ... umount in 2 Seconds!! backitup.0 2019-12-15 16:39:10.473 debug (10481) [iobroker] 10 00 01 */1 * * backitup.0 2019-12-15 16:39:10.461 info (10481) [iobroker] backup was activated at 01:00 every 1 day(s) backitup.0 2019-12-15 16:39:10.426 info (10481) starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.17.0 host.iobroker2 2019-12-15 16:39:07.972 info instance system.adapter.backitup.0 started with pid 10481 javascript.0 2019-12-15 16:39:00.175 info (20087) script.js.Klima___Energie.UWZ: [{"object":"{\"center\":\"UWZ\",\"areaID\":\"UWZDE26129\",\"dtgEnd\":1576436400,\"areaType\":\"UWZCODE\",\"dtgStart\":1576393200,\"payload\":{\"translationsLong host.iobroker2 2019-12-15 16:38:37.953 info Restart adapter system.adapter.backitup.0 because enabled host.iobroker2 2019-12-15 16:38:37.953 info instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR) host.iobroker2 2019-12-15 16:38:37.953 error Caught by controller[0]: at processImmediate (timers.js:658:5) host.iobroker2 2019-12-15 16:38:37.953 error Caught by controller[0]: at tryOnImmediate (timers.js:676:5) host.iobroker2 2019-12-15 16:38:37.953 error Caught by controller[0]: at runCallback (timers.js:705:18) host.iobroker2 2019-12-15 16:38:37.953 error Caught by controller[0]: at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4749:38) host.iobroker2 2019-12-15 16:38:37.953 error Caught by controller[0]: at Adapter.emit (events.js:198:13) host.iobroker2 2019-12-15 16:38:37.953 error Caught by controller[0]: at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.backitup/main.js:67:17) host.iobroker2 2019-12-15 16:38:37.953 error Caught by controller[0]: at startBackup (/opt/iobroker/node_modules/iobroker.backitup/main.js:44:9) host.iobroker2 2019-12-15 16:38:37.953 error Caught by controller[0]: at executeScripts (/opt/iobroker/node_modules/iobroker.backitup/lib/execute.js:176:37) host.iobroker2 2019-12-15 16:38:37.952 error Caught by controller[0]: TypeError: Cannot read property 'dropbox' of null backitup.0 2019-12-15 16:38:37.433 info (8223) Terminated (NO_ERROR): Without reason backitup.0 2019-12-15 16:38:37.432 info (8223) terminating backitup.0 2019-12-15 16:38:36.927 error at processImmediate (timers.js:658:5) backitup.0 2019-12-15 16:38:36.927 error at tryOnImmediate (timers.js:676:5) backitup.0 2019-12-15 16:38:36.927 error at runCallback (timers.js:705:18) backitup.0 2019-12-15 16:38:36.927 error at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4749:38) backitup.0 2019-12-15 16:38:36.927 error at Adapter.emit (events.js:198:13) backitup.0 2019-12-15 16:38:36.927 error at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.backitup/main.js:67:17) backitup.0 2019-12-15 16:38:36.927 error at startBackup (/opt/iobroker/node_modules/iobroker.backitup/main.js:44:9) backitup.0 2019-12-15 16:38:36.927 error at executeScripts (/opt/iobroker/node_modules/iobroker.backitup/lib/execute.js:176:37) backitup.0 2019-12-15 16:38:36.927 error (8223) TypeError: Cannot read property 'dropbox' of null backitup.0 2019-12-15 16:38:36.927 error (8223) uncaught exception: Cannot read property 'dropbox' of null javascript.0 2019-12-15 16:38:00.202 info (20087) script.js.Klima___Energie.UWZ: [{"object":"{\"center\":\"UWZ\",\"areaID\":\"UWZDE26129\",\"dtgEnd\":1576436400,\"areaType\":\"UWZCODE\",\"dtgStart\":1576393200,\"payload\":{\"translationsLong host.iobroker2 2019-12-15 16:37:59.032 info iobroker exit 0 host.iobroker2 2019-12-15 16:37:57.896 info iobroker upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png host.iobroker2 2019-12-15 16:37:57.841 info iobroker upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/de/translations.json i18n/de/translations.json application/json host.iobroker2 2019-12-15 16:37:57.787 info iobroker upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/en/translations.json i18n/en/translations.json application/json host.iobroker2 2019-12-15 16:37:57.733 info iobroker upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/es/translations.json i18n/es/translations.json application/json host.iobroker2 2019-12-15 16:37:57.678 info iobroker upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/fr/translations.json i18n/fr/translations.json application/json host.iobroker2 2019-12-15 16:37:57.624 info iobroker upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/it/translations.json i18n/it/translations.json application/json host.iobroker2 2019-12-15 16:37:57.571 info iobroker upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/nl/translations.json i18n/nl/translations.json application/json host.iobroker2 2019-12-15 16:37:57.513 info iobroker upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pl/translations.json i18n/pl/translations.json application/json host.iobroker2 2019-12-15 16:37:57.458 info iobroker upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pt/translations.json i18n/pt/translations.json application/json host.iobroker2 2019-12-15 16:37:57.403 info iobroker upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/ru/translations.json i18n/ru/translations.json application/json host.iobroker2 2019-12-15 16:37:57.347 info iobroker upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html host.iobroker2 2019-12-15 16:37:57.292 info iobroker upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html host.iobroker2 2019-12-15 16:37:57.206 info iobroker upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript host.iobroker2 2019-12-15 16:37:56.257 info iobroker upload backitup backitup.0 2019-12-15 16:37:37.163 debug (8223) mount activ... umount in 2 Seconds!! backitup.0 2019-12-15 16:37:27.175 debug (8223) [iobroker] 10 00 01 */1 * * backitup.0 2019-12-15 16:37:27.163 info (8223) [iobroker] backup was activated at 01:00 every 1 day(s) backitup.0 2019-12-15 16:37:27.131 info (8223) starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.17.0 backitup.0 2019-12-15 16:37:25.955 debug (8223) States connected to redis: 127.0.0.1:9000 backitup.0 2019-12-15 16:37:25.901 debug (8223) statesDB connected backitup.0 2019-12-15 16:37:25.900 debug (8223) States create PubSub Client backitup.0 2019-12-15 16:37:25.886 debug (8223) Redis States: Use Redis connection: 127.0.0.1:9000 backitup.0 2019-12-15 16:37:25.883 debug (8223) objectDB connected backitup.0 2019-12-15 16:37:25.876 debug (8223) Objects connected to redis: 127.0.0.1:9001 backitup.0 2019-12-15 16:37:25.847 debug (8223) Objects client initialize lua scripts backitup.0 2019-12-15 16:37:25.846 debug (8223) Objects create PubSub Client backitup.0 2019-12-15 16:37:25.834 debug (8223) Objects client ready ... initialize now backitup.0 2019-12-15 16:37:25.703 debug (8223) Redis Objects: Use Redis connection: 127.0.0.1:9001 -
@vauvau07
Mach mal bitte nochmal einen Upload und Neustart des Adapters -
@simatec
ich habe mir angewöhnt bei jedem Adapter mit neuer Version dies zu machen,
also leider keine Änderung gleiche Fehlermeldung -
@vauvau07
Ich habe dir mal eine PN geschickt ... -
version 1.3.2 alles i.o.
@vauvau07
Diese Funktion gab es in Version 1.3.2 noch nicht ... habe dir nochmal ne PN geschickt.
Jetzt sollte der Fehler gefixt sein -
Ab sofort ist die Version 1.3.4 im Github und ab spätestens heute Nacht auch in der latest Repo.
Changelog
1.3.4 (15.12.2019)
- (simatec) Fix hide passwords
@Homoran sagte in Test Adapter Backitup v1.3.x:
@MathiasJ
Bitte Instanz auf debug stellen und log posten.Version 1.3.4 installiert und läuft wieder!
Es scheint ein Bug im 1.3.3 gewesen zu sein, weil ich nicht der einzige war, der das Problem hatte.
Die IObroker-Backups bleiben im Ordner/opt/iobroker/backupssie sind in meinem Fall auch ca 3 MB kleiner ais vorher.
Ich kann jetzt leider nicht gucken, ob die Backup-Dateien defekt sind.
Was mich freuen würde ist die Möglichkeit, bei einer zweiten CCU Backups zu erstellen,
so lange es kein HMIP-LAN-Gateway gibt.
Im Moment läuft eine zweite Instanz, um auch Backups der zweiten CCU zu erstellen.
ich weiß, dass sich HMIP-Geräte ein Mesh-Netzwerk aufbauen können.
Mir fehlt aber irgendwie das Kleingeld, ein Notstrom-Aggregat in Form eines Schiffsdiesels zu installieren.
@MathiasJ sagte in Test Adapter Backitup v1.3.x:
Genau dafür sind Instanzen da.
Du hast ja auch für die zweite ccu weitere Instanzen angelegt.
Es wäre trotzdem gut hier mal den Error Log zu posten, damit wir den Fehler auch eingrenzen können.
Geht nicht hilft leider niemanden -
Dann müsste ich wieder auf die 1.3.3 zurück gehen....
Ich werde mir erst einmal eine Testinstallation aufbauen und gucken, ob das Backup funktioniertIch bekomme mit der 1.3.4 Backups in der Größe von 0 bytes.
Habe gerade festgestellt, auch mit der Version 1.3.2
Im Log wird nichts angezeigt.
Ich habe backitup erst mal deaktiviert, nicht dass alle funktionierenden backups gelöscht und mit den 0-Bytes ersetzt werden.
Hier stimmt was nicht. Wenn ich meine automatischen Backups kontrolliere, dann macht er History und Zigbee doppelt und "vergisst" dafür den IOBroker komplett:
Wenn ich manuell starte, ist alles wie es soll:
Was soll ich mit dieser Aussage anfangen? Was ist 0 bytes und wo liegt das was auch immer für ein backup mit 0 byte.
Wie ich es dir bereits mehrfach geschrieben habe, brauche ich Informationen, mit denen man auch etwas anfangen kann.
Ich kann auf keinen meiner Testsysteme einen Fehler dieser Art reproduzieren. -
@Jan1
Wo tritt das Problem genau auf? Zeige mal deine Config.
Speicherst du auf einem NAS oder in einer Cloud oder ist das Problem lokal? -
ich habe alle Updates des Adapters eingespielt. Mache täglich um 02:00:00 mein Backup. das ist aber aus meiner Sicht i.O.
Auch die Speicherung in einem anderen Verzeichnis läuft:
@Jan1
Habe probiert auf meinen Testsystemen mit diversen Linux OS und Windows probiert den Fehler nachzustellen, aber bei allen Systemen wird das backup korrekt erstellt und kopiert -
@simatec
Wie geschrieben, wenn ich es manuell über den Adapter anstoße, dann funktioniert das auch, nur das automatische Backup vergisst den IOBroker zu sichern.
Hier mal die Konfiguration:
@Jan1
Poste mal bitte den Debuglog von heute Nacht.
Da sich am Code für den Backupprozess nichts geändert hat, kann man ausschließen, dass es an der aktuellen Version liegt.
hier gab es lediglich Modifikationen für Log-Ausgaben etc.
Starte mal den Adapter neu und schupse nochmal ein automatisches Backup an.
