    4. Apple Homekit Siri
    Apple Homekit Siri
      Trident last edited by
      hab den Fehler selbst entdeckt… Muss natürlich vorher die aktuelle Version von Github laden.
      Installiert ist nun eine Instanz. Beim Start bekomme ich im iobroker-log folgende Meldungen:
      host-cubietruck	2015-09-28 20:36:16	error	instance system.adapter.homekit.0 terminated with code 6 (uncaught exception)
      SyntaxError:	2015-09-28 20:36:16	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
      SyntaxError:	2015-09-28 20:36:16	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      SyntaxError:	2015-09-28 20:36:16	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:220:12)
      SyntaxError:	2015-09-28 20:36:16	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:295:6)
      SyntaxError:	2015-09-28 20:36:16	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:151:27)
      SyntaxError:	2015-09-28 20:36:16	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2375:60
      SyntaxError:	2015-09-28 20:36:16	error	at /opt/iobroker/node_modules/iobroker.homekit/main.js:43:61
      SyntaxError:	2015-09-28 20:36:16	error	at /opt/iobroker/node_modules/iobroker.homekit/main.js:20:13
      SyntaxError:	2015-09-28 20:36:16	error	at main (/opt/iobroker/node_modules/iobroker.homekit/main.js:201:33)
      SyntaxError:	2015-09-28 20:36:16	error	at Object.parse (native)
      SyntaxError:	2015-09-28 20:36:16	error	Unexpected token u
      uncaught	2015-09-28 20:36:16	error	exception: Unexpected token u
      homekit-0	2015-09-28 20:36:16	info	Parent Object Adress: hm-rpc.0.LEQ0277589
      homekit-0	2015-09-28 20:36:16	info	HAP-NodeJS starting...
      homekit-0	2015-09-28 20:36:16	info	received all states
      homekit-0	2015-09-28 20:36:15	info	received all objects
      homekit-0	2015-09-28 20:36:13	info	requesting all objects
      homekit-0	2015-09-28 20:36:13	info	requesting all states
      homekit-0	2015-09-28 20:36:13	info	starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.homekit
      homekit-0	2015-09-28 20:36:13	debug	statesDB connected
      homekit-0	2015-09-28 20:36:13	debug	objectDB connected
      host-cubietruck	2015-09-28 20:36:10	info	instance system.adapter.homekit.0 started with pid 7122
      Nur als Info für die Entwickler…. Vielleicht liegt es auch an mir?
      Viele Grüße
      Trident
      • ruhr70
        ruhr70 last edited by
        @steinwedel:
        Bei mir stürzt der Adapter immer wieder ab:
        > warn host.iobroker instance system.adapter.homekit.0 terminated due to SIGSEGV `
        Schliesse mich dem an.
        Möchte an der Stelle aber auch meine Begeisterung für den Adapter ausdrücken! Teste gerne mit 😉
          konnte die Fehler beheben und der Adapter läuft nun stabil. Ich hatte nicht unterstütze Geräte in mein enum aufgenommen. Es klappt bei mir derzeit NUR mit der Ist-Temperatur der neuen Heizungsthermostaten. Allerdings erkennt die App auf meinem iPhone den Adapter nicht.. Gibt es da einen Trick?
          Viele Grüße
          Fabian
            pix last edited by
            ich schaffe es gar nicht, den Adapter zu installieren.
            1. Neueste Version von Github geladen, zip-Datei in iobroker/node_modules/iobroker.homekit entpackt.
            2. Adapter erscheint in ioBroker.admin Oberfläche (Version 0.0.3). Beim Installieren einer Instanz dieser Fehler:
            $ ./iobroker add homekit
            host.MacMini-Ethernet.fritz.box install adapter homekitnpm install --production --prefix "/Users/pix/Documents/iobroker/node_modules/iobroker.homekit" (System call)
            ! sudo: no tty present and no askpass program specified
            ! npm
            ERR! ioBroker.homekit@0.0.3 preinstall: sudo apt-get install git-core libnss-mdns libavahi-compat-libdnssd-dev -ynpm ERR!
            Exit status 1
            npm ERR!
            npm ERR! Failed at the ioBroker.homekit@0.0.3 preinstall script.npm
            ERR! This is most likely a problem with the ioBroker.homekit package,npm ERR! not with npm itself.
            npm ERR! Tell the author that this fails on your system:
            npm ERR! sudo apt-get install git-core libnss-mdns libavahi-compat-libdnssd-dev -y
            npm ERR! You can get their info via:
            npm
            ERR! npm owner ls ioBroker.homekitnpm ERR!
            There is likely additional logging output above.npm ERR!
            System Darwin 14.5.0npm ERR! command "node" "/usr/local/bin/npm" "install" "--production" "--prefix" "/Users/pix/Documents/iobroker/node_modules/iobroker.homekit"
            npm ERR! cwd /Users/pix/Documents
            npm ERR!
            node -v v0.10.33npm
            ERR! npm -v 1.4.28
            npm ERR! code ELIFECYCLE
            npm ERR!
            npm ERR! Additional logging details can be found in:
            npm ERR! /Users/pix/Documents/npm-debug.log
            npm ERR! not ok code 0
            ! Cannot install iobroker.homekit: 1
            ERROR: process exited with code 25
            Ist OS X Terminal, deshalb kein apt. Homebrew ging auch nicht.
            Hat jemand eine Idee?
            Gruß,
            Pix
            __EDIT (10.12.2015): Bei einem weiteren Versuch, eine Instanz zu installieren, lief alles sauber durch. Kann es nicht erklären, aber freue mich__ :?: :D
              hab jetzt auf dem Cubie parallel die homebridge laufen. Klappt auf Anhieb mit allen Devices. Echt sehr cool. Blöd ist nur die fehlende Integration in IO-Broker. Die Räume und Gerätenamen sind nicht synchron :). Ich denke es lohnt sich auf jeden Fall hier mal reinzuschauen! Vielleicht wird es eher ein "homebridge" Adapter für ioBroker?
              > [https://github.com/thkl/homebridge](https://github.com/thkl/homebridge)
              Der homekit-adapter wird leider nicht von der App auf dem iPhone erkannt….
              Viele Grüße
              Trident
                cybertron last edited by
                könnte mal einer das mit der Einrichtung der enums etwas erläutern.
                Wenn es nicht zu viel Aufwand ist, eventuell mit ein paar Bilder und 1-2 Beispielen.
                Ich hab den Adapter soweit problemlos installieren können. Jetzt scheitere ich aber an der enum-Konfiguration.
                Danke & Gruss
                Silvio
                • V
                  versteckt last edited by
                  Hallo, war die letzten Wochen leider außer Gefecht gesetzt.
                  Hab gestern auf meinem Github eine neue Version hochgeladen.
                  Gesendet von meinem iPhone mit Tapatalk
                  • fischi87
                    fischi87 last edited by
                    hallo, ich würde mich gerne beteiligen.
                    habe den adapter auch per console installiert aber bekomme bei den Adaptern einen Fehler?
                    Mit freundlichen Grüßen
                      steinwedel last edited by
                      Das Installationsproblem hatte ich auch. In dem Verzeichnis der Adapter heißt das Verzeichnis "ioBroker.homekit". Habe mit "mv ioBroker.homekit/ iobroker.homekit" das Verzeichnis umbenannt. Jetzt kann man Instanzen von Adaptern installieren.
                      • fischi87
                        top sache, danke hat geklappt
                          pix last edited by
                          Instanz installiert und einen Homematic Switch in den Aufzählungen eingefügt.
                          Beim Start der Instanz erhalte ich diesen Fehler:
                          2015-12-09 23:30:20.894 - info: host.MacMini-Ethernet.fritz.box object change system.adapter.homekit.0
                          2015-12-09 23:30:20.902 - info: host.MacMini-Ethernet.fritz.box instance system.adapter.homekit.0 started with pid 14256
                          2015-12-09 23:30:21.876 - error: uncaught exception: Could not locate the bindings file. Tried:
                          → /Users/pix/Documents/iobroker/node_modules/curve25519/build/curve.node
                          → /Users/pix/Documents/iobroker/node_modules/curve25519/build/Debug/curve.node
                          → /Users/pix/Documents/iobroker/node_modules/curve25519/build/Release/curve.node
                          → /Users/pix/Documents/iobroker/node_modules/curve25519/out/Debug/curve.node
                          → /Users/pix/Documents/iobroker/node_modules/curve25519/Debug/curve.node
                          → /Users/pix/Documents/iobroker/node_modules/curve25519/out/Release/curve.node
                          → /Users/pix/Documents/iobroker/node_modules/curve25519/Release/curve.node
                          → /Users/pix/Documents/iobroker/node_modules/curve25519/build/default/curve.node
                          → /Users/pix/Documents/iobroker/node_modules/curve25519/compiled/5.0.0/darwin/x64/curve.node
                          2015-12-09 23:30:21.882 - error: Error: Could not locate the bindings file. Tried:
                          at bindings (/Users/pix/Documents/iobroker/node_modules/bindings/bindings.js:88:9)
                          at Object. <anonymous>(/Users/pix/Documents/iobroker/node_modules/curve25519/index.js:1:96)
                          at Module._compile (module.js:425:26)
                          at Object.Module._extensions..js (module.js:432:10)
                          at Module.load (module.js:356:32)
                          at Function.Module._load (module.js:311:12)
                          at Module.require (module.js:366:17)
                          at require (module.js:385:17)
                          at Object. <anonymous>(/Users/pix/Documents/iobroker/node_modules/HAP-NodeJS/lib/util/encryption.js:3:18)
                          2015-12-09 23:30:21.929 - debug: homekit.0 objectDB connected
                          2015-12-09 23:30:21.934 - debug: homekit.0 statesDB connected
                          2015-12-09 23:30:22.064 - info: homekit.0 starting. Version 0.0.3 in /Users/pix/Documents/iobroker/node_modules/iobroker.homekit
                          2015-12-09 23:30:22.067 - info: homekit.0 requesting all states
                          2015-12-09 23:30:22.068 - info: homekit.0 requesting all objects
                          2015-12-09 23:30:22.914 - error: host.MacMini-Ethernet.fritz.box instance system.adapter.homekit.0 terminated with code 6 (uncaught exception)</anonymous></anonymous>
                          Was kann das sein?
                          Gruß,
                          Pix
                          • V
                            Hallo, hab dich nicht vergessen, hatte nur unter der Woche noch keine Zeit, schau mir den Fehler gleich mal an, bin ja grad mit einem Freund am erweitern der Konfiguration.
                            LG Christian
                            • V
                              Weil ich's grad gesehen habe, kannst du bitte die letzte Version installieren?
                              Ist mittlerweile 0.0.5 auf GitHub.
                              • fischi87
                                servus, hab den adapter installiert und mir auch eve runtergelassen nur findet eve das homefit nicht, gibt es da ne Lösung?
                                  pix last edited by
                                  @versteckt:
                                  Ist mittlerweile 0.0.5 auf GitHub. `
                                  hab das Update versucht, ging leider nicht durch:
                                  MacMini-Ethernet:iobroker pix$ npm install https://github.com/husky-koglhof/ioBroker.homekit/tarball/master --production
                                  npm WARN addRemoteGit git://github.com/KhaosT/node-srp.git resetting remote /Users/pix/.npm/_git-remotes/git-github-com-KhaosT-node-srp-git-2835e45f024c21e40cb2d65bd72f2b3c because of error: git: error: couldn't open cache file '/var/folders/qh/p1_kkf_x1fzdqzjpj7t18xqr0000gq/T/xcrun_db' (errno=File exists)
                                  npm WARN addRemoteGit git://github.com/KhaosT/node-curve25519.git resetting remote /Users/pix/.npm/_git-remotes/git-github-com-KhaosT-node-curve25519-git-33ca66a69c843d2ebb70497fca566be0 because of error: git: error: couldn't open cache file '/var/folders/qh/p1_kkf_x1fzdqzjpj7t18xqr0000gq/T/xcrun_db' (errno=File exists)
                                  npm WARN addRemoteGit git://github.com/KhaosT/ed25519.git resetting remote /Users/pix/.npm/_git-remotes/git-github-com-KhaosT-ed25519-git-cef11b6e9b2bb55b3b8f0a59f5a2d6bf because of error: git: error: couldn't open cache file '/var/folders/qh/p1_kkf_x1fzdqzjpj7t18xqr0000gq/T/xcrun_db' (errno=File exists)
                                  ! > ioBroker.homekit@0.0.5 preinstall /Users/pix/Documents/iobroker/node_modules/.staging/ioBroker.homekit-2481c4b93d734e6c4c816539f7b84a58
                                  ! Password:
                                  Sorry, try again.
                                  Password:
                                  sudo: apt-get: command not found
                                  • nan@2.1.0 node_modules/bignum/node_modules/nan
                                  • nan@1.9.0 node_modules/curve25519/node_modules/nan
                                  • nan@2.1.0 node_modules/ed25519/node_modules/nan
                                  • ansi-regex@2.0.0 node_modules/iobroker.homekit/node_modules/ansi-regex
                                  • ansi-styles@2.1.0 node_modules/iobroker.homekit/node_modules/ansi-styles
                                  • camelcase@2.0.1 node_modules/iobroker.homekit/node_modules/camelcase
                                  • decamelize@1.1.1 node_modules/iobroker.homekit/node_modules/decamelize
                                  • invert-kv@1.0.0 node_modules/iobroker.homekit/node_modules/invert-kv
                                  • lcid@1.0.0 node_modules/iobroker.homekit/node_modules/lcid
                                  • number-is-nan@1.0.0 node_modules/iobroker.homekit/node_modules/number-is-nan
                                  • is-fullwidth-code-point@1.0.0 node_modules/iobroker.homekit/node_modules/is-fullwidth-code-point
                                  • code-point-at@1.0.0 node_modules/iobroker.homekit/node_modules/code-point-at
                                  • os-locale@1.4.0 node_modules/iobroker.homekit/node_modules/os-locale
                                  • strip-ansi@3.0.0 node_modules/iobroker.homekit/node_modules/strip-ansi
                                  • string-width@1.0.1 node_modules/iobroker.homekit/node_modules/string-width
                                  • window-size@0.1.4 node_modules/iobroker.homekit/node_modules/window-size
                                  • wrap-ansi@1.0.0 node_modules/iobroker.homekit/node_modules/wrap-ansi
                                  • cliui@3.1.0 node_modules/iobroker.homekit/node_modules/cliui
                                  • y18n@3.2.0 node_modules/iobroker.homekit/node_modules/y18n
                                  • yalm@2.0.0 node_modules/iobroker.homekit/node_modules/yalm
                                  • yargs@3.31.0 node_modules/iobroker.homekit/node_modules/yargs
                                  • nan@2.0.9 node_modules/mdns/node_modules/nan
                                  • HAP-NodeJS@0.0.1 node_modules/HAP-NodeJS
                                    ├── mdns@2.2.11
                                    └── srp@0.2.0 (git://github.com/KhaosT/node-srp.git#7feff53254897a0b1b9f0667ad17a8beb78acbb9)
                                  ! npm WARN ENOENT ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/package.json'
                                  npm WARN ENOENT ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/node_modules/ftp-response-parser/package.json'
                                  npm WARN ENOENT ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/node_modules/jsftp/package.json'
                                  npm WARN ENOENT ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/node_modules/mqtt-packet/package.json'
                                  npm WARN ENOENT ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/node_modules/node_modules/package.json'
                                  npm WARN ENOENT ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/node_modules/socket.io-parser/package.json'
                                  npm WARN ENOENT ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/node_modules/through2/package.json'
                                  npm WARN EPACKAGEJSON iobroker No description
                                  npm WARN EPACKAGEJSON iobroker No repository field.
                                  npm WARN EPACKAGEJSON iobroker No README data
                                  npm WARN EPACKAGEJSON iobroker No license field.
                                  npm ERR! Darwin 15.0.0
                                  npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "https://github.com/husky-koglhof/ioBroker.homekit/tarball/master" "--production"
                                  npm ERR! node v5.0.0
                                  npm ERR! npm v3.4.0
                                  ! npm ERR! ioBroker.homekit@0.0.5 preinstall: sudo apt-get install git-core libnss-mdns libavahi-compat-libdnssd-dev -y
                                  npm ERR! Exit status 1
                                  npm ERR!
                                  npm ERR! Failed at the ioBroker.homekit@0.0.5 preinstall script 'sudo apt-get install git-core libnss-mdns libavahi-compat-libdnssd-dev -y'.
                                  npm ERR! Make sure you have the latest version of node.js and npm installed.
                                  npm ERR! If you do, this is most likely a problem with the ioBroker.homekit package,
                                  npm ERR! npm owner ls ioBroker.homekit
                                  npm ERR! There is likely additional logging output above.
                                  ! npm ERR! Please include the following file with any support request:
                                  npm ERR! /Users/pix/Documents/iobroker/npm-debug.log
                                  npm install [https://github.com/husky-koglhof/ioBrok … all/master](https://github.com/husky-koglhof/ioBroker.homekit/tarball/master) --production
                                  Das updaten in Admin wird noch nicht angeboten.
                                  Gruß,
                                  Pix
                                  • V
                                    Guten Morgen!
                                    Hab eine neue Version in GitHub hochgeladen, auf Mac und Raspian liess es sich installieren.
                                    Das sind die Änderungen:
                                    • Added new Devices
                                    • Temperature can now be a negative Value (Needed for Outdoor Temperature)
                                    • Package Name changed to lowercase
                                    • Removed Dependency for installation of Packages
                                    Bitte mal testen ob die Installation nun korrekt funktioniert.
                                    Es sind im Moment nicht viele Geräte aktiviert, muss erst mal schauen, das diese korrekt funktionieren.
                                      pix last edited by
                                      die Installation lief jetzt fast glatt durch, danke:
                                      ! MacMini-Ethernet:iobroker pix$ npm install https://github.com/husky-koglhof/ioBroker.homekit/tarball/master --production /Users/pix/Documents/iobroker └── iobroker.homekit@0.0.6 ! npm WARN ENOENT ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/package.json' npm WARN ENOENT ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/node_modules/ftp-response-parser/package.json' npm WARN ENOENT ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/node_modules/jsftp/package.json' npm WARN ENOENT ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/node_modules/mqtt-packet/package.json' npm WARN ENOENT ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/node_modules/node_modules/package.json' npm WARN ENOENT ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/node_modules/socket.io-parser/package.json' npm WARN ENOENT ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/node_modules/through2/package.json' npm WARN EPACKAGEJSON iobroker No description npm WARN EPACKAGEJSON iobroker No repository field. npm WARN EPACKAGEJSON iobroker No README data npm WARN EPACKAGEJSON iobroker No license field. MacMini-Ethernet:iobroker pix$ !
                                      allerdings habe ich bei Aktivierung der Instanz wieder diesen Fehler:
                                      2015-12-12 15:01:07.886 - info: host.MacMini-Ethernet.fritz.box object change system.adapter.homekit.0
                                      2015-12-12 15:01:07.896 - info: host.MacMini-Ethernet.fritz.box instance system.adapter.homekit.0 started with pid 16645
                                      2015-12-12 15:01:08.712 - error: uncaught exception: Could not locate the bindings file. Tried:
                                      2015-12-12 15:01:08.717 - error: Error: Could not locate the bindings file. Tried:
                                      at Object. <anonymous>(/Users/pix/Documents/iobroker/node_modules/hap-nodejs/lib/util/encryption.js:3:18)
                                      2015-12-12 15:01:08.762 - debug: homekit.0 objectDB connected
                                      2015-12-12 15:01:08.766 - debug: homekit.0 statesDB connected
                                      2015-12-12 15:01:08.911 - info: homekit.0 starting. Version 0.0.6 in /Users/pix/Documents/iobroker/node_modules/iobroker.homekit
                                      2015-12-12 15:01:08.914 - info: homekit.0 requesting all states
                                      2015-12-12 15:01:08.914 - info: homekit.0 requesting all objects
                                      2015-12-12 15:01:09.768 - error: host.MacMini-Ethernet.fritz.box instance system.adapter.homekit.0 terminated with code 6 (uncaught exception)</anonymous></anonymous>
                                      Hast du noch einen Tipp?
                                      Pix
                                      • V
                                        Hallo, so sieht es bei mir aus:
                                        Christians-Mac-mini:tmp christian$ npm install https://github.com/husky-koglhof/ioBroker.homekit/tarball/master --production
                                        > ed25519@0.0.3 install /private/tmp/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/ed25519
                                        > node-gyp rebuild
                                          CC(target) Release/obj.target/ed25519/src/ed25519/keypair.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/sign.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/open.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/crypto_verify_32.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_double_scalarmult.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_frombytes.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_scalarmult_base.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_precomp_0.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_p2_0.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_p2_dbl.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_0.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_dbl.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_to_p2.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_to_cached.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_tobytes.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_madd.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_add.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_msub.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_sub.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_p1p1_to_p3.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_p1p1_to_p2.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_tobytes.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/fe_0.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/fe_1.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/fe_cmov.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/fe_copy.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/fe_neg.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/fe_add.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/fe_sub.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/fe_mul.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/fe_sq.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/fe_sq2.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/fe_invert.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/fe_tobytes.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/fe_isnegative.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/fe_isnonzero.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/fe_frombytes.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/fe_pow22523.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/sc_reduce.o
                                          CC(target) Release/obj.target/ed25519/src/ed25519/sc_muladd.o
                                          CXX(target) Release/obj.target/ed25519/src/ed25519.o
                                          SOLINK_MODULE(target) Release/ed25519.node
                                        > curve25519@1.1.0 install /private/tmp/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/curve25519
                                        > node-gyp rebuild
                                          CXX(target) Release/obj.target/curve/node_curve.o
                                          SOLINK_MODULE(target) Release/curve.node
                                        > bignum@0.11.0 install /private/tmp/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum
                                        > node-gyp configure build
                                          CXX(target) Release/obj.target/bignum/bignum.o
                                          SOLINK_MODULE(target) Release/bignum.node
                                        > mdns@2.2.11 install /private/tmp/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/mdns
                                        > node-gyp rebuild
                                          CXX(target) Release/obj.target/dns_sd_bindings/src/dns_sd.o
                                          CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_browse.o
                                          CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_enumerate_domains.o
                                          CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_get_addr_info.o
                                          CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_process_result.o
                                          CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_ref.o
                                          CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_ref_deallocate.o
                                          CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_ref_sock_fd.o
                                          CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_register.o
                                          CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_resolve.o
                                          CXX(target) Release/obj.target/dns_sd_bindings/src/mdns_utils.o
                                          CXX(target) Release/obj.target/dns_sd_bindings/src/network_interface.o
                                          CXX(target) Release/obj.target/dns_sd_bindings/src/socket_watcher.o
                                          CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_ref.o
                                          CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_create.o
                                          CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_deallocate.o
                                          CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_set_value.o
                                          CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_get_length.o
                                          CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_buffer_to_object.o
                                          SOLINK_MODULE(target) Release/dns_sd_bindings.node
                                        iobroker.homekit@0.0.6 node_modules/iobroker.homekit
                                        ├── yalm@2.0.0 (ansi-styles@2.1.0)
                                        ├── yargs@3.31.0 (decamelize@1.1.1, camelcase@2.0.1, window-size@0.1.4, y18n@3.2.0, cliui@3.1.0, os-locale@1.4.0, string-width@1.0.1)
                                        └── hap-nodejs@0.0.7 (debug@2.2.0, node-persist@0.0.6, ed25519@0.0.3, curve25519@1.1.0, srp@0.2.0, mdns@2.2.11)
                                        Welche Node Version hast du bei dir am laufen?
                                        Christians-Mac-mini:tmp christian$ node -v
                                        v0.12.7
                                        Christians-Mac-mini:tmp christian$ npm -v
                                        2.11.3
                                          pix last edited by
                                          Schätze, da liegt wohl das Problem :roll:
                                          MacMini-Ethernet:iobroker pix$ node -v
                                          v5.0.0
                                          MacMini-Ethernet:iobroker pix$ npm -v
                                          3.4.0
                                          Pix
                                          • V
                                            Ok, kannst du versuchen eine ältere Version zu installieren?
                                            Geht ja beim Mac an sich recht fix.
                                            Du musst halt davor iobroker komplett stoppen, bzw. danach alles wieder hochfahren.
                                            250
                                            52385
