    4. SMA Wechselrichter
    SMA Wechselrichter
      Buchi @bunni last edited by Buchi
      @bunni Hallo, hier das Blockly. Datenpunkte musst Du natürlich noch erstellen:
        <variables>
          <variable type="undefined" id="timeout">timeout</variable>
        </variables>
        <block type="comment" id="v/Aa_,CKf;/@1){R?S8a" x="-287" y="-362">
          <field name="COMMENT">Kosten / Nutzen Rechnung</field>
            <block type="on_ext" id=".0B,rlj@c2R;C(R!EBkr" collapsed="true">
              <value name="OID0">
                <shadow type="field_oid" id="f_Gy,Kh~lsYAyu}DOUJB">
                  <field name="oid">modbus.0.inputRegisters.30581_Netzbezug_Gesamt</field>
              <value name="OID1">
                <shadow type="field_oid" id="L|$_6Q.+bGC7?d*ZaY!K">
                  <field name="oid">modbus.0.inputRegisters.30583_Einspeisung-Gesamt</field>
              <value name="OID2">
                <shadow type="field_oid" id="E9M)b%Xk1+4;G2N[bh(|">
                  <field name="oid">javascript.0.Photovoltaik.Neu_berechnen</field>
                <block type="update" id="(/X@P/D.zZQ~_{o2$YZW">
                  <field name="OID">javascript.0.Photovoltaik.Neu_berechnen</field>
                    <block type="logic_boolean" id="m7=8#6[Z-^l=)f9$DQ0O">
                    <block type="update" id="lXdA,/L4`6qf(CmKb+X]">
                      <field name="OID">javascript.0.Photovoltaik.Kosten_ohne_PV</field>
                        <block type="math_arithmetic" id="B0W~[?@ir6)F0S|^N0y{">
                            <shadow type="math_number" id="OO(D8GadUMpytQ1EzT+u">
                              <field name="NUM">1</field>
                            <block type="get_value" id="e=4WLxYu^]#n1bR[q0+}">
                              <field name="OID">modbus.0.inputRegisters.30571_Gesamtverbrauch</field>
                            <shadow type="math_number" id="aMXd]EP6A:Vbf$j^X)zU">
                              <field name="NUM">0.00026</field>
                            <block type="get_value" id=")%F7nbDj@s#XNLNM.qDU">
                              <field name="OID">javascript.0.Photovoltaik.Strompreis_Durchschnitt</field>
                        <block type="update" id="Rv.LB.YV,^%l_b+[?M(4">
                          <field name="OID">javascript.0.Photovoltaik.Kosten_mit_PV</field>
                            <block type="math_arithmetic" id="s8IR[5ahp2fF9jx~q#iN">
                                <block type="get_value" id="]|KLgT2aQ%V4BfvExEPv">
                                  <field name="OID">modbus.0.inputRegisters.30581_Netzbezug_Gesamt</field>
                                <shadow type="math_number" id="+nWg5odh8|;zjjYB}D#J">
                                <block type="get_value" id="]b*oLvR;;7Nz9@yB=,D6">
                            <block type="update" id="c$~(#yH$TyYyJUAWjd4F">
                              <field name="OID">javascript.0.Photovoltaik.Ersparnis</field>
                                <block type="math_arithmetic" id="y}aSfx[:]H|PqzWOvn3G">
                                    <block type="get_value" id="B.tr31jj{{rdMPSKSqld">
                                      <field name="OID">modbus.0.inputRegisters.30593_Eigenverbrauch-Gesamt</field>
                                    <shadow type="math_number" id="tTtkLWdx8hBq+5yXW/*]">
                                    <block type="get_value" id="nOgV[4nJS,t}_]R7rd/A">
                                <block type="update" id="Q_@%J?3~mbGxZmbU6!/A">
                                  <field name="OID">javascript.0.Photovoltaik.Vergütung</field>
                                    <block type="math_arithmetic" id="~}X]h8P];T]y%^x*foCF">
                                        <block type="get_value" id="Ue*4bs7+@C6~4JzZQM#7">
                                          <field name="OID">modbus.0.inputRegisters.30583_Einspeisung-Gesamt</field>
                                        <shadow type="math_number" id="9+J8e.3[7uH.J1nrGcRs">
                                          <field name="NUM">0.00012</field>
                                    <block type="update" id="Ze7N4fI|q58u-D*^vF(o">
                                      <field name="OID">javascript.0.Photovoltaik.Ergebnis</field>
                                        <block type="math_arithmetic" id="IgIkWiCtM.v4KcatnO-m" inline="false">
                                            <shadow type="math_number" id="}wX!46p0`B{G!i6/i~H%">
                                            <block type="math_arithmetic" id=";ujF3g*CB1TnxHAuaZLy" inline="false">
                                              <field name="OP">ADD</field>
                                                <block type="math_arithmetic" id="ideUl|,b*cnb6CrGGPgL" inline="false">
                                                    <shadow type="math_number" id="adcj]yt@s$lYwJnB@x5-">
                                                    <block type="get_value" id="rkr91tw5scF)|r=(Dv4%">
                                                    <shadow type="math_number" id="|DZ[ahbxyf/oIe~_]IN^">
                                                    <block type="get_value" id="NG`PWpSVnvV#kRI{#gOO">
                                                <shadow type="math_number" id="4_ARbd7pY=$dl3Fd$Jhy">
                                                <block type="get_value" id="4OM(Kry{@CC?xZPkh?+u">
                                            <shadow type="math_number" id="a1|+!s|[B!}JMDEZ6[%c">
                                              <field name="NUM">0</field>
                                        <block type="comment" id="[yu=,6[2y3?0htH`:jz/">
                                          <field name="COMMENT">Berechnung Laufzeit in Monaten</field>
                                            <block type="update" id="6X,csAM:7_Yuz}0-H9Wk">
                                              <field name="OID">javascript.0.Photovoltaik.Laufzeit_Monate</field>
                                                <block type="math_round" id="l2Gymdw6)+nKk#hdK=+;">
                                                  <field name="OP">ROUNDDOWN</field>
                                                  <value name="NUM">
                                                    <shadow type="math_number" id="Q?M{Tz;}=El[lO}yDY,U">
                                                      <field name="NUM">3.1</field>
                                                    <block type="math_arithmetic" id="|qI@I_+L^,][_]Q~GL42" inline="false">
                                                      <field name="OP">DIVIDE</field>
                                                        <shadow type="math_number" id="(yy7Q^yC}5BrM.p9=Y];">
                                                        <block type="math_arithmetic" id="_bSOuDH{6*_{SZ|cz86O" inline="false">
                                                            <shadow type="math_number" id="8Y)r.n5*eww^481b4{pE">
                                                            <block type="time_get" id="Bd:fm=3J*{}Va.,x},n|">
                                                              <mutation format="false" language="false"></mutation>
                                                              <field name="OPTION">object</field>
                                                            <shadow type="math_number" id="IJ8bGn{/0O8A||(ukI.{">
                                                            <block type="convert_from_date" id="P6B{Yo[YHvH0e)3+Ldp$">
        <block type="text" id="iA~_q)lD^e{{~?@8F=.g">
        <field name="TEXT">2017-07-01</field>
                                                        <shadow type="math_number" id="/Q.AUxfhOReuMY;eymeS">
                                                          <field name="NUM">2628000000</field>
                                                <block type="update" id="RuL?X7P$c|eL+Wn:p%Y%">
                                                  <field name="OID">javascript.0.Photovoltaik.Laufzeit_Tage</field>
                                                    <block type="math_round" id="/X0HQC`(-?5*^e{5Mv3t">
                                                      <value name="NUM">
                                                        <block type="math_arithmetic" id="ibRkC=RRS_@[V=gq^Dk6" inline="false">
                                                            <block type="math_arithmetic" id="@H8s2H6WyyzNV!S]JJ9l" inline="false">
        <block type="time_get" id="NF2-_DJk@69JqBf$5)o*">
        <block type="convert_from_date" id="yd.YKxV+cL;Y)0;oL)ML">
        <block type="text" id=",o1)J$!%aP2ornVxaS};">
                                                            <shadow type="math_number" id="Y?/0bxR8(tLoYx;rCbHx">
                                                              <field name="NUM">86400000</field>
                                                    <block type="comment" id="7N[uN=gFh*KB;_?Tju-U">
                                                      <field name="COMMENT">Berechnung Durchschnittswerte</field>
                                                        <block type="timeouts_settimeout" id="`dVqouizUO_5b0y/,yX(">
                                                          <field name="DELAY">2</field>
                                                            <block type="update" id="c1!g;5thK.4}ND(:,W1F">
                                                              <field name="OID">javascript.0.Photovoltaik.Kosten_ohne_PV_Durchschnitt</field>
        <block type="math_arithmetic" id="#/*gX(ZwNbpP-NAjHNQ%" inline="false">
        <shadow type="math_number" id="y-_SXwpYm8|HJbWl-VW/">
        <block type="math_arithmetic" id="eE,IseHv==+O_Q/]S6-8" inline="false">
        <shadow type="math_number" id="hiwg{J3!C1FFeqh#55{%">
        <block type="get_value" id="Vr(=oAWh:]Gfd+%Gs.c5">
        <shadow type="math_number" id="k3oPyJvEM|0.2E:oh,fk">
        <block type="get_value" id="!u%P#H.Ki8LcngVW/~Ed">
        <shadow type="math_number" id=")r4iYKqr0|L:4YT:?g+z">
        <field name="NUM">365</field>
        <block type="update" id="QJ^Ep5syujpr7~@hsSas">
        <field name="OID">javascript.0.Photovoltaik.Kosten_mit_PV_Durchschnitt</field>
        <block type="math_arithmetic" id="RTrBE*-mJ6l=CPV+R0zz" inline="false">
        <block type="math_arithmetic" id="a9Q1nHj)YciVF^{.#,a`" inline="false">
        <block type="get_value" id="$Z{H*k(BRE}#|qa6y-Ws">
        <block type="get_value" id=",@xE,BY68(|y7]2AkgeC">
        <shadow type="math_number" id="i)D-rjvAT4,JYDs)~T%;">
        <block type="update" id="H7d7W5n/NrJ+pTUbt{Fa">
        <field name="OID">javascript.0.Photovoltaik.Ersparnis_Durchschnitt</field>
        <block type="math_arithmetic" id="}{nZPpsIxn+f9+pV)%?^" inline="false">
        <block type="math_arithmetic" id="1hdj$+KokI4W:.10NS5a" inline="false">
        <block type="get_value" id="x/qE8N*rKP421y~c!yb*">
        <block type="get_value" id="*yY!6a;bS|u!%uhKk`r=">
        <shadow type="math_number" id="fg+Q:UfAxZ6Qd?wykNG$">
        <block type="update" id="9.vuC8Jmbi{edxCJ-s)T">
        <field name="OID">javascript.0.Photovoltaik.Vergütung_Durchschnitt</field>
        <block type="math_arithmetic" id=":)#rq5;`d_#{L,N}H]N%" inline="false">
        <block type="math_arithmetic" id="$,G2z(gh,yHH:OwgSn.2" inline="false">
        <block type="get_value" id=")hsn)css1zo+lE[K*7T{">
        <block type="get_value" id="!)7D_el2oU/AQqa#3ja5">
        <shadow type="math_number" id="$gG5vr?6!]ojmv1d+{#Q">
        <block type="update" id="PCq4@*^3,R(%:R00g:4g">
        <field name="OID">javascript.0.Photovoltaik.Ergebnis_Durchschnitt</field>
        <block type="math_arithmetic" id="=UQV7P^Mf9$uQ!-ppPMj" inline="false">
        <block type="math_arithmetic" id="`|8]$mlQIknpl~~C{i+Z" inline="false">
        <block type="get_value" id="#i+W|!WAw|uheHUcwVg`">
        <block type="get_value" id="Mmj!?~RR]+)y)7Q0~2W_">
        <shadow type="math_number" id="*;D1cS?Ibas#E!NJQ2P3">
        <block type="comment" id="-=1!bo9bZM2d^wVzzvfM" x="-278" y="-257">
          <field name="COMMENT">Berechnung Batterieladung</field>
            <block type="on_ext" id="0gabH}^1*|ShtqYl70wN" collapsed="true">
              <value name="OID0">
                <shadow type="field_oid" id="cb(|SM|ZxJK`+vf!8j[/">
                  <field name="oid">modbus.0.inputRegisters.30775_Batterieentadung-Aktuell</field>
              <value name="OID1">
                <shadow type="field_oid" id=",ZOnw%CObrjS2V_`bk5R">
                  <field name="oid">modbus.0.inputRegisters.30873_Batterieladung-Aktuell</field>
              <value name="OID2">
                <shadow type="field_oid" id="kWM5$f2bvH1#7Qb$e!C4">
                  <field name="oid">modbus.0.inputRegisters.30861_Aktueller-Verbrauch</field>
                <block type="controls_if" id="WuKN5t|UKGDrDT5Gy!{v">
                    <block type="logic_compare" id="jE.Nigu#6W[V=6qb.Znb">
                      <field name="OP">GT</field>
                        <block type="get_value" id="_{TAdtc]8n5FI_G9r.C8">
                          <field name="OID">modbus.0.inputRegisters.30873_Batterieladung-Aktuell</field>
                        <block type="math_number" id="4HnpC=f/IN-Ci;5k(`{$">
                    <block type="control" id="z9TUHX4n3QZPJiK6pK-{">
                      <field name="OID">javascript.0.Photovoltaik.Batterie_Ladung</field>
                        <block type="get_value" id="@(%HN|A?ghB#cf[Mb(kK">
                  <statement name="ELSE">
                    <block type="control" id="lkj`pab_cLPSzCywdTvc">
                        <block type="math_arithmetic" id="@jgv,g$G`6YTgO%=HLc8">
                            <shadow type="math_number" id="Y`{yKwzAdc^FX0C3oou{">
                            <shadow type="math_number" id="{6!B!`rTmgyz0+4Dss`H">
                            <block type="get_value" id="a]YTsPN7{.k6F}MP8M]d">
                              <field name="OID">modbus.0.inputRegisters.30775_Batterieentladung-Aktuell</field>
        <block type="comment" id="+^AI}m{0D]}I04*wzNz." x="-287" y="113">
          <field name="COMMENT">Berechnung Anzeige Prozent</field>
            <block type="on_ext" id="78_MuSqngD/-AUF1E_rQ" collapsed="true">
              <value name="OID0">
                <shadow type="field_oid" id="v52k=fZKSwk5KcZl:6gi">
                  <field name="oid">modbus.0.inputRegisters.30845_Batterieladezustand</field>
                <block type="controls_if" id="7bn]4,pc}L@f~VF4Os:N">
                  <mutation elseif="2" else="1"></mutation>
                    <block type="logic_compare" id="vx6syAzf#v$^9_;)rHWN">
                        <block type="get_value" id="l`wh,Qd:.^fH@Dw_bV6!">
                          <field name="OID">modbus.0.inputRegisters.30845_Batterieladezustand</field>
                        <block type="math_number" id="_$3FqT6G#fBHa{sF=99`">
                          <field name="NUM">75</field>
                    <block type="control" id="$Mu+m4c_@C+5v8EJN~-y">
                      <field name="OID">javascript.0.Photovoltaik.Batterie_Status</field>
                        <block type="math_number" id=")2,k?j;qf/rnJP2,I4L8">
                          <field name="NUM">3</field>
                  <value name="IF1">
                    <block type="logic_compare" id="KSyq*@9+9=UywZ-St)i5">
                        <block type="get_value" id="UBO2x~p=Ku!=P-jw9*Bj">
                        <block type="math_number" id="cO!H^NQ3xgX)]T+~~r^r">
                          <field name="NUM">50</field>
                  <statement name="DO1">
                    <block type="control" id="NwV.BBi0l=N$K~kL4!Hz">
                        <block type="math_number" id="I:RO0=Fw^YC}sVpU9B(8">
                          <field name="NUM">2</field>
                  <value name="IF2">
                    <block type="logic_compare" id="N_IhcZLV]r1n?Q%.Nx^n">
                        <block type="get_value" id="$hHP=TpN=NkO/qO(pi5{">
                        <block type="math_number" id="5m4!P{%l*yn?Etco7H(G">
                          <field name="NUM">25</field>
                  <statement name="DO2">
                    <block type="control" id="qip@z804+5w[TPwB1~~p">
                        <block type="math_number" id="Oic2hY6OKQZ@27~{N^7;">
                    <block type="control" id="+N:`2;|(_G.oZHvpXvTA">
                        <block type="math_number" id="Mcihe(Dw7cDa4p3ch74#">
        <block type="comment" id="Bb]rWs+$F$ezOkrj?ds:" x="-287" y="213">
          <field name="COMMENT">Berechnung Netzbezug</field>
            <block type="on_ext" id="^xGRJs.]%0ux$Gy*WTAK" collapsed="true">
              <value name="OID0">
                <shadow type="field_oid" id="REcX5BQk7^pm-9`x,U;Q">
                  <field name="oid">modbus.0.inputRegisters.30865_Aktueller-Netzbezug</field>
              <value name="OID1">
                <shadow type="field_oid" id="8D27{krV,BT?9+G5x9L|">
                  <field name="oid">modbus.0.inputRegisters.30867_Aktuelle-Einspeisung</field>
                <block type="controls_if" id="Ef_3x4,:0*Cy0Svf-UaJ">
                    <block type="logic_compare" id="DG}wm5bvt7,K-JlliiP#">
                        <block type="get_value" id="xJIt4,5iolsN*7Ar|F)/">
                          <field name="OID">modbus.0.inputRegisters.30867_Aktuelle-Einspeisung</field>
                        <block type="math_number" id="0GG;GK_]Ok@Ku:bV#].k">
                    <block type="control" id="FSQ5n4!6llu0*;W6Hic3">
                      <field name="OID">javascript.0.Photovoltaik.Netz</field>
                        <block type="get_value" id="M:8i9Ohk@mJX9@y1(3Y6">
                    <block type="control" id="q7aA7OV4RIR0;(v+op8^">
                        <block type="math_arithmetic" id="zw)p49_{,Puzvq7+Rx|T">
                            <shadow type="math_number" id="up8.Ov%SWcH/16JRSS59">
                            <block type="get_value" id="A4fm?)//:Xb9i2a2cKsc">
                              <field name="OID">modbus.0.inputRegisters.30865_Aktueller-Netzbezug</field>
      Hier die EIngangsregister:
      Die View lässt sich gerade leider nicht exportieren. Ich schau mal ob das noch hinbekomme.
        bunni @Buchi last edited by
        @Buchi Vielen Dank für Deine Mühe!
        • ub.privat
          ub.privat @lobomau last edited by
          @lobomau
          Guten Abend,
          ich möchte mich gern an deine gemachten Erfahrungen zum Thema "anhängen".
          Bin ebenfalls gerade an der Umsetzung Solar, SHM2.0 der VIS.
          Meine Vorstellung schaut in etwa so aus:
          Schlussendlich sollen die Pfeile entsprechend farbig animiert werden, entsprechend des Leistungsfluss.
          Bei der Sichtung der Datenpunkte im SHM2.0 ist mir noch nicht wirklich klar, was genau was ist.
          Hier wäre meine Frage, ob du pregard, psurplus ... deuten kannst?
          Im weiteren Forenverlauf hast du die Lösung scheinbar "gedanklich" fertig!?
          Darf man davon eventuell profitieren? Modbus-Adapter wird gerade installiert und konfiguriert.
          • lobomau
            lobomau last edited by lobomau
            Ja, das habe ich auch so gemacht. Netzbezug und Netzeinspeisuung ginge mit dem SHM-Adapter, geht aber auch alles mit dem Modbus-Adapter. Ich habe auch die Empfehlung befolgt und mache alles mit dem Modbus-Adapter. Wozu zwei Adapter laufen lassen?
            So sieht es jetzt abends bei mir unter VIS aus:
            Bei Netzeinspeisung dreht sich der Pfeil und bei Stromerzeugung wird die Sonne angezeigt. Ist nur auf die Schnelle erstellt. Hauptsache die Werte stimmen:
            Bei einigen threads zuvor steht wie man es in Modbus einstellt, um Bezug, Einspeisung und Erzeugung darzustellen. Diese Einstellarbeiten (richtige Werte für Register eintippen) fallen beim SHM-Adapter weg für Bezug und Einspeisung, aber man muss den Modbus-Adapter einstellen für die Erzeugung. Deswegen am besten gleich einmal die Mühe machen und alles mit dem Modbus-Adapter.
            Edit: Eingangsregister-Einstellungen findest du hier. Müssen nicht alle bei dir funktionieren. Probier es aus: 17. thread-Seite von Buchi 30. Nov. 2019, 06:04
            • Peoples
              Peoples @lobomau last edited by
              @lobomau sagte in SMA Wechselrichter:
              @Peoples sagte in SMA Wechselrichter:
              @Peoples ok, dann weiß ich schon mal, dass der Adapter bei mir alles richtig macht und man den Rest selbst aufbereiten muss.
              Denke ich auch, bei mir sieht es nicht anders aus. Ich nutze zusätzlich noch den Modbus für den Wechselrichter so kann man eigentlich auf alle Werte zugreifen.
              Beispiel:
              Genau. Diese Darstellung möchte man ja auch gerne in vis haben 😉
              Hast du das hinbekommen oder soll ich dir mal den export einstellen?
              lobomau 1 Reply Last reply Reply Quote 1
              • lobomau
                lobomau @Peoples last edited by
                @Peoples só gut habe ich es nicht hinbekommen. Ich dachte das wäre ein Screenshot von Handy App. Sieht ja genau so aus. Gerne hätte ich gerne davon einen Export.
                Peoples 1 Reply Last reply Reply Quote 0
                • Peoples
                  Peoples @lobomau last edited by Peoples
                  @lobomau
                  Nein das ist tatsächlich aus dem IoB.
                  Im Zip ist alles was du dafür brauchst. Ausgehend von meiner Hardware Zusammenstellung. Ich habe den SunnyHomemanager und einen SMA - Wechselrichter, verwende den sma-em und Modbus-Adapter.
                  Im Zip findest du:
                  • Die Bilder
                  • Das Javascript zum berechnen der Werte
                  • einen View-Export
                  • die Css-klassen
                  Wichtig du darfst die Objekte in der View nicht verschieben, sondern musst die ganze View dort wo du sie anzeigen willst als Teilbereich via Iframe einbinden. Die Bilderpfade musst du noch anpassen und ggf. das Script.
                  Schau mal ob du klar kommst wenn nicht einfach Bescheid geben.
                  pv_iob.zip
                  lobomau ub.privat S maeuseking 5 Replies Last reply Reply Quote 3
                  • lobomau
                    @Peoples vielen Dank. Probiere ich mal aus. Sollte zumindest von meiner Hardware aus gehen. Die beiden Adapter laufen auch bei mir.
                    • lobomau
                      @Peoples es sieht schon mal sehr gut aus. Es zeigt die richtigen Werte wie im sunnyportal an. Nur CSS habe ich noch nicht eingebaut. Wozu ist das? Macht das die Rot-grün Aufteilung beim Gesamtverbrauch? Und wo muss ich das einsetzen? Hier ist es wohl falsch:
                      • Peoples
                        @lobomau
                        Da ist es richtig, das macht die Ecken rund.
                        Ich mach aber immer Projekt nicht global
                        • ub.privat
                          ub.privat @Peoples last edited by ub.privat
                          @Peoples
                          hallo peoples, habe mich auch deiner Solar-Visu bedient. Scheint erst einmal zu funktionieren.
                          Was ich nicht wirklich verstanden habe, wie du es bzgl. Iframe gemeint hast.
                          Sollen alle Widgets in ein iFrame gepackt werden?
                          in der Mittelsäule liegen ja der grüne und rote Hintergrund übereinander.
                          Rot wird in der Höhe gemäß Verbrauch berechnet - genial clever.
                          Ich gehe davon aus, das grün den kleineren Z-Index hat?
                          Wäre es dir bitte nochmals möglich, die animierten Pfeile zu übersenden?
                          Der linke ist bei Vergößerung "arg rund", der rechte sieht perfekt aus.
                          Musste für meine Visu das ganze ein wenig vergößern...
                          Nochmal vielen DANK!👍 👍 👍
                          • Peoples
                            Peoples @ub.privat last edited by Peoples
                            @ub-privat
                            Schaut gut aus!
                            Die sind leider so, ggf. mit CSS rotieren wäre eine Lösung.
                            Das mit dem Iframe meinte ich wie folgt:
                            Die Animation von grün und rot wird ja in Abhängigkeit der Postition deines Widgets "errechnet" wenn du das nun z.B. an mehreren Stellen deines Vis Projekts nutzen möchtest, müsstest du jedesmal diese Werte anpassen.
                            Wenn du nun dein Bild oben auf eine separate View machst, kannst du diese überall wo du es möchtest den Teil der View via iFrame-Widget anzeigen lassen und verschieben ohne dass es einen Einfluss auf dein Erscheinungsbild hat.
                            ub.privat 1 Reply Last reply Reply Quote 0
                            • ub.privat
                              @Peoples said in SMA Wechselrichter:
                              Schaut gut aus! 😊 DANKE
                              Die sind leider so, ggf. mit CSS rotieren wäre eine Lösung. - dazu fehlt mir nun die "Vorstellungskraft".
                              Wollte eigentlich die Aussenkontur analog des rechten Pfeils nacharbeiten.
                              Die View sieht im ganzen so aus (ist aber noch in Arbeit!):
                              Wenn man aber nach vermeintlicher "Perfektion" strebt, sind solche Details der Beginn der Verzweifelung... 😧
                              • Peoples
                                @ub-privat
                                Ich habe den Pfeil leider nur rund bei mir fällt das nur nicht so auf weil es bei mir viel kleiner angezeigt wird wie bei dir, versuch doch mal den rechten Pfeil zweimal zu verwenden und ihm eine Css-Klasse mit
                                transform: rotate(90deg);
                                zu geben.
                                • ub.privat
                                  Für mich als "Beginner" sind das noch böhmische Dörfer.
                                  Muss ich GLOBAL oder PROJEKT wählen?
                                  Rot Schrift bedeutet immer Fehler...
                                  • Peoples
                                    @ub-privat
                                    Wenn du es global machst, gilt der Name der Klasse überall in allen Projekten (so verstehe ich das). Wenn du nun mal für ein weiteres Gerät eine Ansicht baust, und zufällig einen Css-Klassen Namen verwendest den du in dem alten Projekt nutzt gibt das Fehler. Da ich viele Css-Klassen habe mache ich immer Projekt.
                                    .bild_rotieren{
                                        transform: rotate(180deg);
                                    Müssen natürlich 180 Grad sein 🙂
                                    Dann dein Bild anklicken und dem Bild die Klasse zuweisen:
                                    • ub.privat
                                      PERFEKT 👍 👍 👍
                                      Hat prima funktioniert. Das Beste daran ist, dass ich wieder etwas gelernt habe!!!
                                      Vielen Dank!
                                      Vielleicht hast hierzu noch eine Idee:
                                      48535c4d-3645-4d5f-b4b2-9ca120c7e50b-grafik.png f39a3e0b-c9c8-41ea-b4d7-68fabe21eb9b-grafik.png
                                      Im Livebiild springt die Anzeige immer zwischen den Werten hin und her. Aus dem Datenpunkt kommt diese riesen Nachkommastelle.
                                      Kann ich diese irgendwie "runden" auf eine feste Nachkommastelle?
                                      Auch hierzu vielen Dank im voraus...
                                      • Peoples
                                        @ub-privat
                                        Klar gibts da ne Lösung, nimm das Number-Widget (zu finden wenn du nach Value suchst) und in diesem Widget gibt es die Möglichkeit die Anzahl der Nachkommastellen anzugeben:
                                        Edit - jetzt Bild mit Pfeil
                                        ub.privat 1 Reply Last reply Reply Quote 1
                                        • ub.privat
                                          @Peoples
                                          Danke - funktioniert! bis demnächst...
                                          • Martin Steiner
                                            Martin Steiner last edited by Martin Steiner
                                            Hallo zusammen... Danke, die Hinweise helfen wirklich gut!
                                            586
                                            161988
