    4. Amazon Dash Button
    UNSOLVED Amazon Dash Button
      RandyAndy @arteck last edited by Negalein
      @arteck
      here we go (habe mal nur auf dash button geiltert)
      amazon-dash.0	2019-10-29 15:04:07.781	warn	(2880) Terminated (UNCAUGHT_EXCEPTION): Without reason
      amazon-dash.0	2019-10-29 15:04:07.593	info	(2880) starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.amazon-dash, node: v10.17.0
      amazon-dash.0	2019-10-29 15:03:35.497	warn	(2865) Terminated (UNCAUGHT_EXCEPTION): Without reason
      amazon-dash.0	2019-10-29 15:03:35.206	info	(2865) starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.amazon-dash, node: v10.17.0
      amazon-dash.0	2019-10-29 15:03:34.494	error	at Module.load (internal/modules/cjs/loader.js:653:32)
      amazon-dash.0	2019-10-29 15:03:34.494	error	at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
      amazon-dash.0	2019-10-29 15:03:34.494	error	at Module._compile (internal/modules/cjs/loader.js:778:30)
      amazon-dash.0	2019-10-29 15:03:34.494	error	at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:3:21)
      amazon-dash.0	2019-10-29 15:03:34.494	error	at require (internal/modules/cjs/helpers.js:25:18)
      amazon-dash.0	2019-10-29 15:03:34.494	error	at Module.require (internal/modules/cjs/loader.js:692:17)
      amazon-dash.0	2019-10-29 15:03:34.494	error	at Function.Module._load (internal/modules/cjs/loader.js:585:3)
      amazon-dash.0	2019-10-29 15:03:34.494	error	at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
      amazon-dash.0	2019-10-29 15:03:34.494	error	at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)
      amazon-dash.0	2019-10-29 15:03:34.494	error	the module (for instance, using `npm rebuild` or `npm install`).
      amazon-dash.0	2019-10-29 15:03:34.494	error	NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
      amazon-dash.0	2019-10-29 15:03:34.494	error	NODE_MODULE_VERSION 48. This version of Node.js requires
      amazon-dash.0	2019-10-29 15:03:34.494	error	was compiled against a different Node.js version using
      amazon-dash.0	2019-10-29 15:03:34.494	error	(2865) Error: The module '/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/build/Release/pcap_binding.node'
      amazon-dash.0	2019-10-29 15:03:34.490	error	the module (for instance, using `npm rebuild` or `npm install`).
      amazon-dash.0	2019-10-29 15:03:34.490	error	NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
      amazon-dash.0	2019-10-29 15:03:34.490	error	NODE_MODULE_VERSION 48. This version of Node.js requires
      amazon-dash.0	2019-10-29 15:03:34.490	error	was compiled against a different Node.js version using
      amazon-dash.0	2019-10-29 15:03:34.490	error	(2865) uncaught exception: The module '/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/build/Release/pcap_binding.node'
      amazon-dash.0	2019-10-29 15:03:13.176	warn	(2850) Terminated (UNCAUGHT_EXCEPTION): Without reason
      amazon-dash.0	2019-10-29 15:03:12.826	info	(2850) starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.amazon-dash, node: v10.17.0
      amazon-dash.0	2019-10-29 15:03:12.170	error	at Module.load (internal/modules/cjs/loader.js:653:32)
      amazon-dash.0	2019-10-29 15:03:12.170	error	at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
      amazon-dash.0	2019-10-29 15:03:12.170	error	at Module._compile (internal/modules/cjs/loader.js:778:30)
      amazon-dash.0	2019-10-29 15:03:12.170	error	at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:3:21)
      amazon-dash.0	2019-10-29 15:03:12.170	error	at require (internal/modules/cjs/helpers.js:25:18)
      amazon-dash.0	2019-10-29 15:03:12.170	error	at Module.require (internal/modules/cjs/loader.js:692:17)
      amazon-dash.0	2019-10-29 15:03:12.170	error	at Function.Module._load (internal/modules/cjs/loader.js:585:3)
      amazon-dash.0	2019-10-29 15:03:12.170	error	at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
      amazon-dash.0	2019-10-29 15:03:12.170	error	at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)
      amazon-dash.0	2019-10-29 15:03:12.170	error	the module (for instance, using `npm rebuild` or `npm install`).
      amazon-dash.0	2019-10-29 15:03:12.170	error	NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
      amazon-dash.0	2019-10-29 15:03:12.170	error	NODE_MODULE_VERSION 48. This version of Node.js requires
      amazon-dash.0	2019-10-29 15:03:12.170	error	was compiled against a different Node.js version using
      amazon-dash.0	2019-10-29 15:03:12.170	error	(2850) Error: The module '/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/build/Release/pcap_binding.node'
      amazon-dash.0	2019-10-29 15:03:12.167	error	the module (for instance, using `npm rebuild` or `npm install`).
      amazon-dash.0	2019-10-29 15:03:12.167	error	NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
      amazon-dash.0	2019-10-29 15:03:12.167	error	NODE_MODULE_VERSION 48. This version of Node.js requires
      amazon-dash.0	2019-10-29 15:03:12.167	error	was compiled against a different Node.js version using
      amazon-dash.0	2019-10-29 15:03:12.167	error	(2850) uncaught exception: The module '/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/build/Release/pcap_binding.node'
      amazon-dash.0	2019-10-29 15:02:40.856	warn	(2831) Terminated (UNCAUGHT_EXCEPTION): Without reason
      amazon-dash.0	2019-10-29 15:02:40.594	info	(2831) starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.amazon-dash, node: v10.17.0
      amazon-dash.0	2019-10-29 15:02:39.852	error	at Module.load (internal/modules/cjs/loader.js:653:32)
      amazon-dash.0	2019-10-29 15:02:39.852	error	at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
      amazon-dash.0	2019-10-29 15:02:39.852	error	at Module._compile (internal/modules/cjs/loader.js:778:30)
      amazon-dash.0	2019-10-29 15:02:39.852	error	at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:3:21)
      amazon-dash.0	2019-10-29 15:02:39.852	error	at require (internal/modules/cjs/helpers.js:25:18)
      amazon-dash.0	2019-10-29 15:02:39.852	error	at Module.require (internal/modules/cjs/loader.js:692:17)
      amazon-dash.0	2019-10-29 15:02:39.852	error	at Function.Module._load (internal/modules/cjs/loader.js:585:3)
      amazon-dash.0	2019-10-29 15:02:39.852	error	at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
      amazon-dash.0	2019-10-29 15:02:39.852	error	at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)
      amazon-dash.0	2019-10-29 15:02:39.852	error	the module (for instance, using `npm rebuild` or `npm install`).
      amazon-dash.0	2019-10-29 15:02:39.852	error	NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
      amazon-dash.0	2019-10-29 15:02:39.852	error	NODE_MODULE_VERSION 48. This version of Node.js requires
      amazon-dash.0	2019-10-29 15:02:39.852	error	was compiled against a different Node.js version using
      amazon-dash.0	2019-10-29 15:02:39.852	error	(2831) Error: The module '/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/build/Release/pcap_binding.node'
      amazon-dash.0	2019-10-29 15:02:39.847	error	the module (for instance, using `npm rebuild` or `npm install`).
      amazon-dash.0	2019-10-29 15:02:39.847	error	NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
      amazon-dash.0	2019-10-29 15:02:39.847	error	NODE_MODULE_VERSION 48. This version of Node.js requires
      amazon-dash.0	2019-10-29 15:02:39.847	error	was compiled against a different Node.js version using
      amazon-dash.0	2019-10-29 15:02:39.847	error	(2831) uncaught exception: The module '/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/build/Release/pcap_binding.node'
      amazon-dash.0	2019-10-29 15:02:08.531	warn	(2815) Terminated (UNCAUGHT_EXCEPTION): Without reason
      amazon-dash.0	2019-10-29 15:02:08.206	info	(2815) starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.amazon-dash, node: v10.17.0
      amazon-dash.0	2019-10-29 15:02:07.525	error	at Module.load (internal/modules/cjs/loader.js:653:32)
      amazon-dash.0	2019-10-29 15:02:07.525	error	at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
      amazon-dash.0	2019-10-29 15:02:07.525	error	at Module._compile (internal/modules/cjs/loader.js:778:30)
      amazon-dash.0	2019-10-29 15:02:07.525	error	at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:3:21)
      amazon-dash.0	2019-10-29 15:02:07.525	error	at require (internal/modules/cjs/helpers.js:25:18)
      amazon-dash.0	2019-10-29 15:02:07.525	error	at Module.require (internal/modules/cjs/loader.js:692:17)
      amazon-dash.0	2019-10-29 15:02:07.525	error	at Function.Module._load (internal/modules/cjs/loader.js:585:3)
      amazon-dash.0	2019-10-29 15:02:07.525	error	at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
      amazon-dash.0	2019-10-29 15:02:07.525	error	at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)
      amazon-dash.0	2019-10-29 15:02:07.525	error	the module (for instance, using `npm rebuild` or `npm install`).
      amazon-dash.0	2019-10-29 15:02:07.525	error	NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
      amazon-dash.0	2019-10-29 15:02:07.525	error	NODE_MODULE_VERSION 48. This version of Node.js requires
      amazon-dash.0	2019-10-29 15:02:07.525	error	was compiled against a different Node.js version using
      amazon-dash.0	2019-10-29 15:02:07.525	error	(2815) Error: The module '/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/build/Release/pcap_binding.node'
      amazon-dash.0	2019-10-29 15:02:07.522	error	the module (for instance, using `npm rebuild` or `npm install`).
      amazon-dash.0	2019-10-29 15:02:07.522	error	NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
      amazon-dash.0	2019-10-29 15:02:07.522	error	NODE_MODULE_VERSION 48. This version of Node.js requires
      amazon-dash.0	2019-10-29 15:02:07.522	error	was compiled against a different Node.js version using
      amazon-dash.0	2019-10-29 15:02:07.522	error	(2815) uncaught exception: The module '/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/build/Release/pcap_binding.node'
      amazon-dash.0	2019-10-29 15:01:36.163	warn	(2798) Terminated (UNCAUGHT_EXCEPTION): Without reason
      amazon-dash.0	2019-10-29 15:01:35.856	info	(2798) starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.amazon-dash, node: v10.17.0
      amazon-dash.0	2019-10-29 15:01:35.159	error	at Module.load (internal/modules/cjs/loader.js:653:32)
      amazon-dash.0	2019-10-29 15:01:35.159	error	at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
      amazon-dash.0	2019-10-29 15:01:35.159	error	at Module._compile (internal/modules/cjs/loader.js:778:30)
      amazon-dash.0	2019-10-29 15:01:35.159	error	at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:3:21)
      amazon-dash.0	2019-10-29 15:01:35.159	error	at require (internal/modules/cjs/helpers.js:25:18)
      amazon-dash.0	2019-10-29 15:01:35.159	error	at Module.require (internal/modules/cjs/loader.js:692:17)
      amazon-dash.0	2019-10-29 15:01:35.159	error	at Function.Module._load (internal/modules/cjs/loader.js:585:3)
      amazon-dash.0	2019-10-29 15:01:35.159	error	at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
      amazon-dash.0	2019-10-29 15:01:35.159	error	at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)
      amazon-dash.0	2019-10-29 15:01:35.159	error	the module (for instance, using `npm rebuild` or `npm install`).
      amazon-dash.0	2019-10-29 15:01:35.159	error	NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
      amazon-dash.0	2019-10-29 15:01:35.159	error	NODE_MODULE_VERSION 48. This version of Node.js requires
      amazon-dash.0	2019-10-29 15:01:35.159	error	was compiled against a different Node.js version using
      amazon-dash.0	2019-10-29 15:01:35.159	error	(2798) Error: The module '/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/build/Release/pcap_binding.node'
      amazon-dash.0	2019-10-29 15:01:35.156	error	the module (for instance, using `npm rebuild` or `npm install`).
      amazon-dash.0	2019-10-29 15:01:35.156	error	NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
      amazon-dash.0	2019-10-29 15:01:35.156	error	NODE_MODULE_VERSION 48. This version of Node.js requires
      amazon-dash.0	2019-10-29 15:01:35.156	error	was compiled against a different Node.js version using
      amazon-dash.0	2019-10-29 15:01:35.156	error	(2798) uncaught exception: The module '/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/build/Release/pcap_binding.node'
      amazon-dash.0	2019-10-29 15:01:03.775	warn	(2704) Terminated (UNCAUGHT_EXCEPTION): Without reason
      amazon-dash.0	2019-10-29 15:01:03.500	info	(2704) starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.amazon-dash, node: v10.17.0
      Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
      Hier gehts zur Hilfe.
        A Former User @RandyAndy last edited by
        @RandyAndy @BBTown die funktionieren noch, hab ca. 40 im Einsatz, und noch n paar als Reserve. Allerdings hatte ich auch schon 2, bei denen die Batterie leer ging, und öffnen .. naja, ich sag mal, kann man machen, aber mir ist bei beiden der Knopf kaputt gegangen und damit waren die unbrauchbar. ( Ein neues Gehäuse hätte ich mir ja drucken können..)
          arteck Developer Most Active @RandyAndy last edited by arteck
          @RandyAndy sagte in Amazon Dash Button:
          was möchtest du mir mitteilen.. du hast dein node auf ne höhere version gebracht und kein rebuild des adapter durchgeführt..
            RandyAndy @arteck last edited by RandyAndy
            @arteck
            eine Neuinstallation habe ich schon durchgeführt. Hat aber nichts gebracht.
            Und re-compiling kein Ahnung was das bedeuten soll.
            Andreas
              @RandyAndy
              cd /opt/iobroker/node-modules
              npm rebuild
                @arteck
                hat nicht wirklich etwas gebracht
                Andreas
                • Rummelmug
                  Rummelmug last edited by
                  Hallo, ich muss mich hier auch mal einklinken. Ich hab meine Fritzbox gegen eine neue getauscht. Mit der Backupfunktion hat auch alles easy funktioniert. Lediglich einer meiner zwei Dashbuttons funktioniert nicht mehr. Ich finde ihn noch in meiner Fritzbox unter ungenutzter Verbindung, aber er reagiert nicht mehr. Bei einem Tastendruck leuchtet er blau, statt rot, wie der noch funktionierende. Scheinbar kann man in der Amazon-App diesen nicht mehr neu anlernen, was ein zurücksetzen schwierig macht.
                  Weiß hier jemand ob da noch was zu retten ist, oder war es das jetzt auch mit den vorhandenen Dashbuttons, wo Amazon den Verkauf eingestellt hat.
                    A Former User @Rummelmug last edited by
                    @Rummelmug Hi, wenn er nur noch blau leuchtet, dann ist wahrscheinlich die Batterie am Ende..
                    Anlernen geht nicht mehr, die haben die Funktion in der App rausgenommen.
                    Rummelmug 1 Reply Last reply Reply Quote 0
                    • Rummelmug
                      Rummelmug @Guest last edited by
                      @ilovegym ich hab ihn mal geöffnet und die Batterie gewechselt. Hat nichts geändert. Er hat wohl seine Halbwertzeit überschritten. Wenn es keine Möglichkeit gibt ohne die Amazon App ein WLAN Zugang auf die Dinger zu speichern, dann muss ich mich wohl mal nach ner Alternative umschauen. Die waren schön praktisch, da günstig, recht neutral ohne Aufkleber und vor allem ohne eine zusätzliche Bridge funktionsfähig.
                        liv-in-sky @Rummelmug last edited by
                        @Rummelmug find ich auch schade - bin auf xiaomi wifi schalter umgestiegen - sind auch günstig - man muss halt das gateway (hardware) einmalig anschaffen - aber da auch die fensterkontakte von xiaomi brauchbar sind, hat sich das rentiert
                        die xiaomi's können auch noch doppel-klick und lang-click
                        • Dr. Bakterius
                          Dr. Bakterius Most Active last edited by
                          Die Dash-Buttons gibt es schon noch bei Amazon, allerdings nennen sie sich AWS IoT Button und sind nicht ganz so günstig. Hier Infos dazu: https://aws.amazon.com/de/iotbutton/
                          a200 1 Reply Last reply Reply Quote 0
                          • a200
                            a200 @Dr. Bakterius last edited by
                            @Dr-Bakterius sagte in Amazon Dash Button:
                            Hast du das ausprobiert? Ich habe versucht mein Dash-Button über die DSN bei AWS als Device zu aktivieren. Leider ist die Nummer zu lang. Erwartet wird ein Buchstabe das Minus-Zeichen und eine 10 Stellige Nummer. die DSN meines Buttons ist in etwa so aufgebaut: G030M90322932579
                            • Dr. Bakterius
                              Dr. Bakterius Most Active @a200 last edited by
                              @a200 sagte in Amazon Dash Button:
                              Nein, hab ich nicht. Noch sind bei mir drei Produkt-Dash-Buttons in Betrieb. Wenn die Batterie leer wird, werde ich sie tauschen versuchen. Sonst werden sie durch etwas anderes ersetzt.
                              Aber die AWS IoT Buttons gibt es schon länger und werden sicher eine andere Software haben als die für die Produkte.
                              • Rummelmug
                                Ich wollte den Xiaomi Tastern mal eine Chance geben und hab mir dafür einen ConBee2 Stick bestellt. Mir war bislang völlig unbekannt, dass man über den ConBee auf die Tradfri Sachen als Datenpunkt in den ioBroker bekommt. Bisher hatte ich 2 von den Bewegungsmelder und Fernbedienungen immer nur an die HUE-Bridge angelernt.
                                Ich bin so begeistert von der Tradfri und ConBee Combo, dass ich nun meine Alternative zum Dashbutton gefunden habe.
                                  Cobalt-60 last edited by Cobalt-60
                                  Eine Alternative wäre der MyStrom-Button.
                                  Funktioniert auch über Wifi, dauert ungefähr 5-8 sec bis Schaltung, also ähnlich Dash-Button.
                                  Ansonsten habe ich auch den Xiaomi-Button in Verwendung, ist aber Zigbee, es wird also Gateway oder ähnliches (CC2531) benötigt.
                                  Anbindung MyStrom-Button : siehe hier
                                  dash-button
                                  1341
