    4. [Vorstellung] Meine zweite Visualisierung
      Kuddel @djsirius last edited by
      @djsirius @DennisMenger
      hier der Export von meinem Blocky Skript für CCU Ram und CPU
      <block xmlns="http://www.w3.org/1999/xhtml" type="controls_if" id="xnk=*_QH@*1`CFD(1a7h" x="-516" y="-235">
         <block type="logic_compare" id="u#T!/oat^_3MwuyL3k6q">
           <field name="OP">EQ</field>
             <block type="get_value" id=";qE}4SO_Nz_hT/A2lo+C">
               <field name="OID">ping.0.ioBroker-MASTER.192_168_4_5</field>
             <block type="logic_boolean" id="W`ys[u(6LC_e{TNxyu]r">
         <block type="comment" id="uHRGC9R1TW)a)*MXZ$fG">
           <field name="COMMENT">CPU Usage</field>
             <block type="exec" id="foLexYPHdsTw}f.9N]M/">
               <mutation with_statement="true"></mutation>
               <field name="WITH_STATEMENT">TRUE</field>
               <field name="LOG"></field>
               <value name="COMMAND">
                 <shadow type="text" id="$@nX$^+;CZkV,PPKl2U:">
                   <field name="TEXT">ssh root@192.168.4.5 grep 'cpu ' /proc/stat | awk '{usage=($2+$4)*100/($2+$4+$5)} END {print usage "%"}'</field>
                 <block type="control" id="hIu)12Q5nbUJD{Ck^+Sr">
                   <field name="OID">javascript.0.ressourcen.ccu.ccu_cpu_usage</field>
                     <block type="convert_tonumber" id="yvyX3Mv[_ghUBP-h:0Wq">
                         <block type="variables_get" id="M,#dq?-#RIaQITy7(L~4">
                           <field name="VAR" id="7(zFM`@Yx-M/c5uU@N^j" variabletype="">result</field>
                 <block type="comment" id="}|3/zzNigDhU{#rg1xVo">
                   <field name="COMMENT">RAM Usage</field>
                     <block type="exec" id=",n:$=vRd,wA]ga5wZH;Y">
                         <shadow type="text" id="9s_Gwnh3eHv4fE7pxwA-">
                           <field name="TEXT">ssh root@192.168.4.5 free | grep Mem | awk '{print $3}'</field>
                         <block type="variables_set" id="?v@;MB*mzJbJDVB0Jc{Z">
                             <block type="math_arithmetic" id="p[SYLr.N:yD1hcuwi4;A" inline="false">
                                 <shadow type="math_number" id="|$gF@aegqyNxeI!|91WM">
                                   <field name="NUM">1</field>
                                 <block type="variables_get" id="vnqjezfN2OE%(4(+2zlE">
                                 <shadow type="math_number" id="BK8JB8qd~v`QG{ZC^6*c">
                                   <field name="NUM">100</field>
                             <block type="variables_set" id="Cc@_[BQVv82~Z#a~|P]E">
                                 <block type="math_arithmetic" id="GFC;:i5$Ds}K3GCiVEn}" inline="false">
                                   <field name="OP">DIVIDE</field>
                                     <block type="variables_get" id="$=5g/=_MlIxoU;Dm!7GC">
                                     <shadow type="math_number" id="IEuShKVUaC.!Xho2EFay">
                                       <field name="NUM">724840</field>
                                 <block type="control" id="F([O{[%0?{uF|%B}1IeP">
                                   <field name="OID">javascript.0.ressourcen.ccu.ccu_ram_usage</field>
                                     <block type="variables_get" id="1mBSVA_|K7u(0H}Fm14h">
        djsirius @Kuddel last edited by
        @Kuddel Vielen Dank! 👍
          DennisMenger @Kuddel last edited by
          @Kuddel ok das hat tatsächlich geholfen. Alles auseinander geflückt. Jetzt scheint es zu funktionieren. Danke für den Tipp.
          Jetzt habe ich die View so angepasst, dass ich alle 3 Lampen einzeln schalten kann und habe einen Button (ganz unten), der alle 3 Lampen gleichzeitig einschaltet bzw. ausschaltet. Die Rahmen um die Schalter sollen ja wahrscheinlich anzeigen, ob Lampe an oder aus ist.
          Wie kann ich es hinbekommen, dass der gelbe Rahmen für alle Lampen an ist, wenn ich alle 3 Lampen einzeln anschalte. Mit den normalen Bedingungen bei den Sichtbarkeiten der Widgets werde ich das ja wahrscheinlich nicht hinbekommen oder?
          Ich hoffe das war einigermaßen verständlich.
          Dennis
            Kuddel @DennisMenger last edited by
            @DennisMenger dafür brauchst du einen extra Datenpunkt der von einem Skript gefüllt.
            Wenn alle Lampen = an dann neuerDP = true sonst false und den nimmst du dann für den Rahmen
            D P 2 Replies Last reply Reply Quote 0
              @Kuddel ok danke. Skripte schreiben bin ich noch nicht firm drin. Sollte aber auch mit einem Blockly gehen oder? Dann würde ich das erst mal darüber probieren.
                PatrickFro @Kuddel last edited by PatrickFro
                Die folgende Frage hat sich erledigt, Blockly übersehen!
                @Kuddel Auch wenn die Veröffentlichung schon länger her ist habe ich doch etwas gefunden, was ich gerne nutzen wollte: Die Anzeige der jeweiligen JS-Controller/Node/NPM -Versionen. Datei habe ich im Verzeichnis gespeichert und ausführbar gemacht. Rückmeldung in der Console ließt sich für mich ok:
                Jedoch wird die Versionsnummer in keinem State hinterlegt:
                Kannst Du mir sagen, was ich hier falsch gemacht habe?
                Danke!!!
                • opossum
                  opossum last edited by
                  ich würde sagen, Deine Datenpunktnamen stimmen nicht mit den Namen im Script überein?
                    HoTi @Kuddel last edited by
                    Workaround für das Hochladen der kompletten VIS
                    1. Meine_Icons.zip entpacken
                    2. 2019-11-06-VIS.zip entpacken
                    3. Die beiden VIS-Datein und die den Icons Ordner zu einem neuen Zip Archiv zusammefügen
                    4. Das neue Zip archiv importieren
                    ich habe versucht die Komplette VIS mit dem Workaround hoch zu laden. Er nimmt alles an, aber dann passiert nichts mehr nur das Importfenster schließt sich.
                    Ich bin mir sicher das ich die Schritte richtig gemacht habe. Im Dateimanager finde ich den import auch nicht. Muss ich da noch irgendwelche Rechte vergeben?
                    Viele Grüße
                    Tim
                      DennisMenger @Glasfaser last edited by DennisMenger
                      @Horie wie sieht dein Verzeichnis nach dem Packen aus? Ich hatte damals auch Probleme mit dem Verzeichnis
                      @Glasfaser sagte in [Vorstellung] Meine zweite Visualisierung:
                      @DennisMenger
                      Zeige mal den zip ( Archiv ) Inhalt , wie du es zusammen gefügt hast !
                      So muss dann der Inhalt aussehen !
                      Test Projekt installiert ……. , so sieht es dann aus :
                      @Negalein Danke für den Edit 👍
                        HoTi @DennisMenger last edited by HoTi
                        @DennisMenger
                        ja das habe ich schon gelesen. Das habe ich richtig.
                        • Glasfaser
                          Glasfaser @HoTi last edited by
                          @Horie
                          Nimm mal bitte die Original zip Datei ( 2019-11-06-VIS.zip ) ohne die Bilder und importiere diese.
                          Viewname dann als " Test "nehmen .
                            HoTi @Glasfaser last edited by
                            @Glasfaser Ja, das ging. Wie bekomme ich jetzt die Bilder rein 👍
                            • Glasfaser
                              @Horie
                              War nur ein Test , ob es überhaupt bei Dir funktioniert !
                              Da muß was mit deiner erstellten Zip Datei sein , versuche es nochmal neu zu zippen.
                                HoTi last edited by
                                Boa, ihr seit echt schneller als die Polizei erlaubt. Das ist ja toll hier...
                                Passt die Einstellung der ZIP:
                                • Glasfaser
                                  Glasfaser @HoTi last edited by Glasfaser
                                  @Horie
                                  Ich habe noch niemals was an den Original-Einstellungen verändert , dazu kann ich dir jetzt nichts sagen !
                                  Erstelle es einfach neu !
                                    @Glasfaser schnif ich bin zu blöd... geht nicht
                                    • Glasfaser
                                      @Horie
                                      Nicht aufgeben ..... hast du es mal mit einem anderen Zip Programm mal versucht !
                                        @Glasfaser said in [Vorstellung] Meine zweite Visualisierung:
                                        @Horie
                                        Na sowieso nicht! Probiere jetzt noch ein anderes ZIP Programm und einen anderen Browser. Aber dann muss ich die Daten ohne Import an die richtige stelle legen ...
                                        • Glasfaser
                                          @Horie sagte in [Vorstellung] Meine zweite Visualisierung:
                                          Nein das geht nicht ....
                                          Nur über den Vis Import als Projekt oder über den Dateimanager ( Bilder ) im Vis einfügen !
                                            HoTi last edited by
                                            Es lag an der VPN Verbindung. Als ich dann zuhause war, direkt im WLAN hat alles einwandfrei geklappt. Danke euch!
                                            Nun werde ich mich als erstes mal mit dem Abfall Widget beschäftigen und dann nach und nach alle anderen 😀
                                            template vis
                                            148
                                            1324
                                            493148
