    4. Wasserzähler - Selfmade
    • Rababersaft
      Rababersaft last edited by
      Moin, ich möchte mich hier mal kurz (oder lang 😊 ) mit einklinken.
      ich versuche gerade die Kamera zu implementieren, jedoch habe ich beim kompilieren folgenden Fehler
      'Adafruit_NeoPixel' does not name a type
                       from C:\Users\tajes\Documents\Arduino\all_wasser_skatch_jam\all_wasser_skatch_jam.ino:11:
      JomjolGitESP32CamComm.h:36:7: error: 'Adafruit_NeoPixel' does not name a type
             Adafruit_NeoPixel *light;
      In file included from C:\Users\tajes\AppData\Local\Temp\arduino_build_422536\sketch\JomjolGitESP32CAM-Server-Class.h:2:0,
                       from C:\Users\tajes\AppData\Local\Temp\arduino_build_422536\sketch\JomjolGitESP32CAM-Server-Class.cpp:1:
      In file included from C:\Users\tajes\AppData\Local\Temp\arduino_build_422536\sketch\JomjolGitESP32CamComm.cpp:1:0:
      C:\Users\tajes\AppData\Local\Temp\arduino_build_422536\sketch\JomjolGitESP32CAMComm.h:36:7: error: 'Adafruit_NeoPixel' does not name a type
      C:\Users\tajes\AppData\Local\Temp\arduino_build_422536\sketch\JomjolGitESP32CamComm.cpp: In constructor 'GitESP32CAMCommLibrary::ESP32CAMCommClass::ESP32CAMCommClass(int, int, int, int, int, WebServer*)':
      JomjolGitESP32CamComm.cpp:7:3: error: 'light' was not declared in this scope
         light = new Adafruit_NeoPixel(_num_led, _pin, NEO_GRBW + NEO_KHZ800);
      JomjolGitESP32CamComm.cpp:7:15: error: expected type-specifier before 'Adafruit_NeoPixel'
      C:\Users\tajes\AppData\Local\Temp\arduino_build_422536\sketch\JomjolGitESP32CamComm.cpp: In member function 'virtual void GitESP32CAMCommLibrary::ESP32CAMCommClass::setup()':
      JomjolGitESP32CamComm.cpp:193:3: error: 'light' was not declared in this scope
         light->setBrightness(brightness);
      C:\Users\tajes\AppData\Local\Temp\arduino_build_422536\sketch\JomjolGitESP32CamComm.cpp: In member function 'void GitESP32CAMCommLibrary::ESP32CAMCommClass::LightOn()':
      JomjolGitESP32CamComm.cpp:213:3: error: 'light' was not declared in this scope
         light->show(); // Initialize all pixels to 'off'
      C:\Users\tajes\AppData\Local\Temp\arduino_build_422536\sketch\JomjolGitESP32CamComm.cpp: In member function 'void GitESP32CAMCommLibrary::ESP32CAMCommClass::LightOff()':
      JomjolGitESP32CamComm.cpp:220:13: error: 'light' was not declared in this scope
         colorWipe(light->Color(0, 0, 0, 0), 0); // Aus
      C:\Users\tajes\AppData\Local\Temp\arduino_build_422536\sketch\JomjolGitESP32CamComm.cpp: In member function 'void GitESP32CAMCommLibrary::ESP32CAMCommClass::colorWipe(uint32_t, uint8_t)':
      JomjolGitESP32CamComm.cpp:226:23: error: 'light' was not declared in this scope
         for(uint16_t i=0; i<light->numPixels(); i++) {
      JomjolGitESP32CamComm.cpp:231:1: error: expected '}' at end of input
      Mehrere Bibliotheken wurden für "WebServer.h" gefunden
       Benutzt: C:\Users\tajes\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\WebServer
      Mehrere Bibliotheken wurden für "ESPmDNS.h" gefunden
       Benutzt: C:\Users\tajes\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\ESPmDNS
      Mehrere Bibliotheken wurden für "ArduinoOTA.h" gefunden
       Benutzt: C:\Users\tajes\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\ArduinoOTA
      Mehrere Bibliotheken wurden für "Update.h" gefunden
       Benutzt: C:\Users\tajes\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\Update
      Mehrere Bibliotheken wurden für "FS.h" gefunden
       Benutzt: C:\Users\tajes\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\FS
      Mehrere Bibliotheken wurden für "WiFi.h" gefunden
       Benutzt: C:\Users\tajes\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\WiFi
       Nicht benutzt: C:\Program
      Bibliothek WiFi in Version 1.0 im Ordner: C:\Users\tajes\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\WiFi  wird verwendet
      Bibliothek WebServer in Version 1.0 im Ordner: C:\Users\tajes\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\WebServer  wird verwendet
      Bibliothek ESPmDNS in Version 1.0 im Ordner: C:\Users\tajes\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\ESPmDNS  wird verwendet
      Bibliothek ArduinoOTA in Version 1.0 im Ordner: C:\Users\tajes\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\ArduinoOTA  wird verwendet
      Bibliothek Update in Version 1.0 im Ordner: C:\Users\tajes\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\Update  wird verwendet
      Bibliothek FS in Version 1.0 im Ordner: C:\Users\tajes\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\FS  wird verwendet
      exit status 1
            int brightness;
            void colorWipe(uint32_t c, uint8_t wait);
            framesize_t fr_size;
            uint8_t fr_quality;
      Von diesem in der ersten Zeile, im Sketch Zeile 36
      Hat das schon mal jemand gehabt bzw. eine Lösung ad hock parat?
      Für Brainstorming oder :"Ey Du siehst den Wald vor lauter Bäume nicht..." wäre ich sehr dankbar...
      Und Daumen Hoch für die geleistete Arbeit hier 👍
        jomjol @Rababersaft last edited by
        @Rababersaft Adafruit_Neopixel ist eine Bibliothek, die ich für eine Version mit getrennter Beleuchtung benötige. Ich flashe meinen ESP32 mit der Arduino Umgebung und dann kannst du das über die Bibliothekverwaltung installieren:
        Theoretisch kann man den Code auch streichen, aber dann ist es mit meiner alten Hardware nicht kompatibel (ESP3286 mit ArduCAM) - aktuell fehlt mir auch die Zeit dazu
        Rababersaft 1 Reply Last reply Reply Quote 1
        • Rababersaft
          Rababersaft @jomjol last edited by
          @jomjol Nabend 😉
          Ja, so flashe ich auch. Er moniert ja den *light Befehl bei mir. Evtl sollte ich auf deine Version von neopixel downgreaden. Das wäre nen Versuch mal wert 🙂
          Ich informiere weiter ...
          • Knallochse
            Knallochse @mcchickents last edited by Knallochse
            @mcchickents sagte in Wasserzähler - Selfmade:
            @Mikewolf
            kommt heute Abend
            So hier mein Programm.
            Programm mcchickents 191017.txt
            Du brauchst zwei DB Steine meine beiden heißen.
            Und dann habe ich SV auf meiner CCU gefühlt hier kannst du aber auch DB im Iobroker füllen.
            Gruß Julian
            Wie ich schon angemerkt hatte, werden bei mir die "Digitalen" Zahlem (m³) nicht immer richtig erkannt. Das führte bei mir zu Verbrauchswerten, die nicht besonders aussagekräftig waren.
            Dagegen habe ich beobachtet, das die Erkennung der Zeiger (analog) sehr zuverlässig funktioniert.
            Ich habe mir erlaubt, dass Script von @mcchickents so umzubauen, dass nur noch diese Analogen Werte verwendet werden. die Digitalen (m³) werden nur noch im Script hochgezählt.
            Ausgangspunkt sind die Parser Werte mit den Einstellungen von @mcchickents
            mit Intervall von 300000 (5min)
            Ich habe des Script so umgebaut, das mit Anfangszählerständen gearbeitet wird (Tag; Woche; Monat; Jahr) Die dazugehörigen Objekte müssen (wo immer Ihr sie hin haben wollt) angelegt werden.
            WICHTIG: Die Plausibilitätsprüfung muss ausgeschaltet sein, so das immer der gerade erkannte Wert im Parser mitgegeben wird.
            Bei mir funktioniert das seit 1er Woche ohne Auffälligkeiten.
            Ich würde mich über Tester freuen. Auch Verbesserungsvorschläge sind sehr willkommen.
            Ich bin wahrlich kein Profi, was das Scripten betrifft.
            Hier das Blockly Script:
              <variables>
                <variable type="" id="+{wu7EACDqh[jz.w|UJ_">Digital</variable>
                <variable type="" id="CrQs0Fj4!jTiB_=7Z{H#">Analog alt</variable>
                <variable type="undefined" id="timeout2">timeout2</variable>
                <variable type="undefined" id="timeout">timeout</variable>
                <variable type="" id="Y%2waVBVJfgC:UsZNg9^">Analog</variable>
                <variable type="" id="jD*[#Zlic1jmyurL%.%b">Wasser</variable>
                <variable type="" id="S~g:}fW6Tm:Aw?GxUkaZ">Wasser gerechnet</variable>
                <variable type="undefined" id="timeout3">timeout3</variable>
              </variables>
              <block type="variables_set" id="GE[E%kt%s0mH*y[T,]`|" x="-1813" y="-637">
                <field name="VAR" id="+{wu7EACDqh[jz.w|UJ_" variabletype="">Digital</field>
                  <block type="get_value" id="f#L%AXrk=Ex$lR)!ag{6">
                    <field name="OID">javascript.0.Wasserverbrauch1.Digital</field>
              <block type="on_ext" id="hW,coeg6nL[_/oRIW8`_" x="-1288" y="-612">
                <value name="OID0">
                  <shadow type="field_oid" id="#1+|n}n82E%YcW~~(OAJ">
                    <field name="oid">javascript.0.Wasserverbrauch1.Anfangszaehlerstand</field>
                  <block type="variables_set" id="[3s08X/c2]b+g09k=MS2">
                      <block type="get_value" id="~ZWWb=S%vhPDv}PO8g-~">
                        <field name="OID">javascript.0.Wasserverbrauch1.Anfangszaehlerstand</field>
              <block type="comment" id="{)~[qYJwM%HmTqZC[Dme" x="-1787" y="-537">
                <field name="COMMENT">Werte von Url Ausgabe aufbereiten und als Zahl in neuen DB</field>
                  <block type="on_ext" id="O@t;)N+2$SFNG$?Gf{h2">
                    <value name="OID0">
                      <shadow type="field_oid" id="9K|x1o#+%6GQb*;p%3O#">
                        <field name="oid">parser.0.Wasserzähler</field>
                      <block type="timeouts_settimeout" id="W]bzQri^_8bvqpKQOrEV">
                        <field name="DELAY">200</field>
                        <field name="UNIT">ms</field>
                          <block type="variables_set" id="5w0B^2Jki=M**PAtqc+u">
                            <field name="VAR" id="jD*[#Zlic1jmyurL%.%b" variabletype="">Wasser</field>
                              <block type="get_value" id=";?U(`UWCL4fsnK8#0#*[">
                                <field name="OID">parser.0.Wasserzähler</field>
                              <block type="variables_set" id="ixFd@J8)L1oE}OCVbtYq">
                                <field name="VAR" id="Y%2waVBVJfgC:UsZNg9^" variabletype="">Analog</field>
                                  <block type="text_join" id="/fqyB}E;PHmjBsJJ`0Fh">
                                    <mutation items="6"></mutation>
                                    <value name="ADD0">
                                      <block type="math_number" id="SMJBX;~T(pjV^d0~+S)y">
                                        <field name="NUM">0</field>
                                    <value name="ADD1">
                                      <block type="text" id="u[@%#8#fi4C^yX.r%d!I">
                                        <field name="TEXT">.</field>
                                    <value name="ADD2">
                                      <block type="text_charAt" id="kJ_eC,oa_KKeEhwykd:J">
                                        <mutation at="true"></mutation>
                                          <block type="variables_get" id="-y({kI6sfR,nQAjVkA]A">
                                        <value name="AT">
                                          <block type="math_number" id="hr%jA*b+T]5*Ca|K9m+4">
                                            <field name="NUM">7</field>
                                    <value name="ADD3">
                                      <block type="text_charAt" id="5.{HXUkih?pbuhQ3mL)E">
                                          <block type="variables_get" id="H=fwgeU*yM2BO1So/@rJ">
                                        <value name="AT">
                                          <block type="math_number" id="Up65|^q^LW$4[4{Q2Kvh">
                                            <field name="NUM">8</field>
                                    <value name="ADD4">
                                      <block type="text_charAt" id="ds.0fi_$#ZlQ+?RhAo,4">
                                          <block type="variables_get" id="O|qHH_xUhqy?KE+,cKX2">
                                        <value name="AT">
                                          <block type="math_number" id="bLvs%(U/*rs$Ld9Al1[+">
                                            <field name="NUM">9</field>
                                    <value name="ADD5">
                                      <block type="text_charAt" id="6OR:#lbqI-PRhCHNec9^">
                                          <block type="variables_get" id=":H4e}P$k[XW1ul.ATEA5">
                                        <value name="AT">
                                          <block type="math_number" id="X4xw.sN^lzaqf}IPF.jh">
                                            <field name="NUM">10</field>
                                  <block type="timeouts_settimeout" id=".SMM.AW-`BYfdQ}ya?b1">
                                    <field name="NAME">timeout3</field>
                                      <block type="controls_if" id="ju/a2i7Frg:jTfpH!r}c">
                                          <block type="logic_compare" id="iF^jZ2ra(+[,1@C9!+=|">
                                            <field name="OP">GT</field>
                                              <block type="math_arithmetic" id="_GG[w[-[]ELfHI1|/,TP">
                                                  <shadow type="math_number" id="Olf6S3dwBydhTC59hi/:">
                                                    <field name="NUM">1</field>
                                                  <block type="convert_tonumber" id="BL,kMdDU#u3!rMwPJmR*">
                                                      <block type="variables_get" id="PhuKa|3GsTTN8QxR{%AZ">
                                                        <field name="VAR" id="CrQs0Fj4!jTiB_=7Z{H#" variabletype="">Analog alt</field>
                                                  <shadow type="math_number" id="u!#Qj:zrQsUXSN8{%.g1">
                                                  <block type="convert_tonumber" id="OEPXck6@PFIlEp.OYnhd">
                                                      <block type="variables_get" id="7,s5XP+o{Z?X[7ll.+0Q">
                                              <block type="math_number" id="%At]Iu`?WR5ZfT:VCL#z">
                                                <field name="NUM">0.5</field>
                                          <block type="math_change" id="DAIA1CzWMpcy853_!RS!">
                                            <value name="DELTA">
                                              <shadow type="math_number" id="~^qVXIp-f$qYSGT|k(p*">
                                          <block type="control" id="9n0als[H])_JXK;wZ;Rj">
                                              <block type="convert_tonumber" id="(V-dzVo;qF_Ad-#3qQ{U">
                                                  <block type="variables_get" id="YRQ;vYYHy!{m@:dXStQf">
                                              <block type="control" id="y/fZ]IDy`tMrbrJLSaCC">
                                                <field name="OID">javascript.0.Wasserverbrauch1.Analog</field>
                                                  <block type="convert_tonumber" id="duI29L)?T~xuD,TORa9@">
                                                      <block type="variables_get" id="+Y@Az*Mey}}NRlITw$Xi">
                                                  <block type="control" id="K2vn9_SQgwL|)u!!gl1|">
                                                    <field name="OID">javascript.0.Wasserverbrauch1.Wasserverbrauch_aktualisiert</field>
                                                      <block type="math_arithmetic" id="MM+jsw4UfO(.Hx.u/s:`">
                                                        <field name="OP">ADD</field>
                                                          <shadow type="math_number" id="7Oaw?3HKyclxaVy@qE~p">
                                                          <block type="convert_tonumber" id="XJ=s_p6$TZ)-avlBa((;">
                                                              <block type="variables_get" id="W0w=_,X/ejFNyHT1XV{R">
                                                          <shadow type="math_number" id="|=f,]Pr,T6HC8laX|R;o">
                                                          <block type="convert_tonumber" id="552=i|r`DG0,-Fa.z5km">
                                                              <block type="variables_get" id="9`[$K-.pLdS/93Sr7u]M">
              <block type="on_ext" id="@zG4;]iYO[gk6PE9A8Bd" x="-1788" y="137">
                <value name="OID0">
                  <shadow type="field_oid" id="bo2gx?dIMh?:HL#A@*J[">
                  <block type="variables_set" id="$^5i[4.V)UQ$0,R53n%|">
                      <block type="variables_get" id="auf4Vpl?.5xl,2EQDC}x">
                      <block type="control" id="6DzKEv?-~d]3U=;Btcop">
                        <field name="OID">javascript.0.Wasserverbrauch1.Wasserverbrauch_alt</field>
                          <block type="get_value" id="o5`@Rv8Ul:#hrNuvl,2|">
              <block type="on_ext" id="g0!@tN:hJ5,@IC03]C(R" x="-1787" y="337">
                <value name="OID0">
                  <shadow type="field_oid" id="i*|8`Z*]C1Z-aKXfx4qF">
                    <field name="oid">javascript.0.Wasserverbrauch1.Wasserverbrauch_aktualisiert</field>
                  <block type="timeouts_settimeout" id="9)silgejCBBBlJ^K5*h.">
                    <field name="DELAY">1000</field>
                      <block type="controls_if" id="$_^*U)oNg;J39mNWX7iv">
                          <block type="logic_compare" id="R+]z+~$9PRX.!`-n2j$_">
                              <block type="get_value" id="1Q.u,.7hmJgpxgTS!yJJ">
                              <block type="get_value" id="*^w0O6:fgj}}S|y_?89S">
                          <block type="variables_set" id="z)/Gd*s9,-W6[D752=D?">
                            <field name="VAR" id="S~g:}fW6Tm:Aw?GxUkaZ" variabletype="">Wasser gerechnet</field>
                              <block type="math_arithmetic" id="xt-H^j-:43Irbg7Fhml(">
                                  <shadow type="math_number" id="X_rWlPD~o/J^KhVZi%6o">
                                  <block type="get_value" id="A4Sx?OtCp2T?h#I(031U">
                                  <shadow type="math_number" id="+qND:7;^kTj.azwuZHHi">
                                  <block type="get_value" id="@R6Vro4Waf_mK|.+!]^0">
                              <block type="control" id="0(_/h8O2,M[gEb`Ic4=2">
                                <field name="OID">hm-rega.0.8533</field>
                                  <block type="math_arithmetic" id="s)PN7Vw`prv!A?hv2mLf">
                                      <shadow type="math_number" id="E#zB^cvPPx!3cYPr+Pu{">
                                      <block type="math_rndfixed" id="A_V2Dl3Tco*!@[~Lr1n~">
                                        <field name="n">4</field>
                                        <value name="x">
                                          <shadow type="math_number" id="a?I?-VQtRV1uduc!*;@I">
                                            <field name="NUM">3.1234</field>
                                          <block type="math_arithmetic" id="XY5vn6~5Da?Zt0namcfQ">
                                              <shadow type="math_number" id="TlPoMg6n6S:en?y89?T4">
                                              <block type="get_value" id="Il/T*4`06v:{m@*OFmkc">
                                              <shadow type="math_number" id="%8A!l4mo_0a=h,ezfnVP">
                                              <block type="get_value" id="=TjWO/63[rWCTbDj7JUs">
                                                <field name="OID">javascript.0.Wasserverbrauch1.Anfangszaehlerstand_heute</field>
                                      <shadow type="math_number" id="tn*R.05(D.%K3Cq(}nvg">
                                        <field name="NUM">1000</field>
                                  <block type="control" id="5fng!*j2(M,$$,YwlLHx">
                                    <field name="OID">hm-rega.0.8568</field>
                                      <block type="math_arithmetic" id="j!|XN6hin]+7`7e88l18">
                                          <shadow type="math_number" id="!%YGCtSmGv.!]KU$#6Nw">
                                          <block type="math_rndfixed" id="-3@,nGkZ]@$FU1Ry}%PA">
                                            <value name="x">
                                              <block type="math_arithmetic" id="(E?id-LI#NfEL|Jt:.vZ">
                                                  <block type="get_value" id="0E2;EjD-PBt:GCDwPU~H">
                                                  <block type="get_value" id="YDY5~1aA-=^]//;i6MJ+">
                                          <shadow type="math_number" id="NUZlH-[?T]-}p@iCL{Au">
                                      <block type="control" id="oBT%X]5xBNnY,5AICE3X">
                                        <field name="OID">hm-rega.0.8566</field>
                                          <block type="math_arithmetic" id="[nv%@@BX,N#hLq#S-k`+">
                                              <shadow type="math_number" id="CL~9xg^p8_Kzc5n_ImjG">
                                              <block type="math_rndfixed" id=",P%Ylnd^*u1LkcG9X]:W">
                                                <value name="x">
                                                  <block type="math_arithmetic" id="|(*+rA~Ej?$2*?ityV)U">
                                                      <block type="get_value" id="]ziDJBvg89Wq:.R;J:!,">
                                                      <block type="get_value" id="nd_9af.ZMA1/K1,S#U@Q">
                                                        <field name="OID">javascript.0.Wasserverbrauch1.Anfangszaehlerstand_Woche</field>
                                              <shadow type="math_number" id="s#NIPHF{^u=-UljnNO$r">
                                          <block type="control" id="#z,-nejW?jGgjF|6|.H}">
                                            <field name="OID">hm-rega.0.8648</field>
                                              <block type="math_arithmetic" id="y39]M!U/%X9b%6jp*4#}">
                                                  <block type="math_rndfixed" id="2#^Z6@xqJOMGnvvjT6%?">
                                                    <value name="x">
                                                      <block type="math_arithmetic" id="UN.1V5+(r@))%J,=@gqY">
                                                          <block type="get_value" id="$mrk)426X5fx_+e!J_gK">
                                                          <block type="get_value" id="/Z@4#mZokQ,L-w^bH.Tg">
                                                            <field name="OID">javascript.0.Wasserverbrauch1.Anfangszaehlerstand_Monat</field>
                                                  <shadow type="math_number" id="Ha=O,ekrr9a?z]eu4Xs+">
                                              <block type="control" id="=E[:Y4;({rV9PgxM??W#">
                                                <field name="OID">hm-rega.0.8567</field>
                                                  <block type="math_rndfixed" id="N~pEF;p}RibZHL@Jj%]8">
                                                    <value name="x">
                                                      <block type="math_arithmetic" id="(ypJq^YjyV_r2Tja[JzG">
                                                          <block type="get_value" id="-MMgXsvKFd?[}m13v}9o">
                                                          <block type="get_value" id="iD:Yn+mvm5eH]y:k88K+">
                                                            <field name="OID">javascript.0.Wasserverbrauch1.Anfangszaehlerstand_Jahr</field>
              <block type="comment" id="ox+@jzn`KXVwX.fOTB$," x="-937" y="888">
                <field name="COMMENT">Wasserverbrauch letzte 5 min zurücksetzen</field>
                  <block type="on_ext" id="j=c,w9.$Xq;DsB5^}pBB">
                    <value name="OID0">
                      <shadow type="field_oid" id="}z+=RenMSy8(B@XhK@0K">
                        <field name="oid">hm-rega.0.8568</field>
                      <block type="controls_if" id="%|yEAWaJ*FP|KJ!T/+Y$">
                          <block type="logic_compare" id="_EAAa*G$MT%4=Rg?[~bP">
                              <block type="get_value" id="tZQSY0`YcA7JL[M$Ws@g">
                              <block type="math_number" id="Pd*)$#q#9Ay-w#:cv1+7">
                          <block type="control" id="lU:dL+CfL4WMPIg8M38w">
                            <mutation delay_input="true"></mutation>
                            <field name="DELAY_MS">5</field>
                              <block type="math_number" id="sH;+ugos5JXLrj_4BfDg">
              <block type="comment" id="qSxx=;Q,jlnWfNVxu*TC" x="-1688" y="1062">
                <field name="COMMENT">reset heute</field>
                  <block type="schedule" id="v;%?AXWh:txx%4R+2:U,">
                    <field name="SCHEDULE">59 23 * * *</field>
                      <block type="control" id="o03K_LgrizESb@J0r`gL">
                          <block type="math_number" id="+|Dv5/%]/%.QIWBB+**C">
                          <block type="control" id="8DJ|hXs^UV[]]q|j@$/@">
                              <block type="get_value" id="q#8NRrtE|p##-plw;KZ9">
              <block type="comment" id="f}lW@jf:=d$f0yptTr$b" x="-1687" y="1262">
                <field name="COMMENT">reset Woche</field>
                  <block type="schedule" id="CS=RSPfa:iN5AMzgx~+$">
                    <field name="SCHEDULE">59 23 * * 0</field>
                      <block type="control" id=".l7{U_lCbkh?eh[J76.L">
                          <block type="math_number" id="NQ{Xt.0IXvoF}I^AtomT">
                          <block type="control" id="lf}%4*+o^Q{FU:7fxp|;">
                              <block type="get_value" id="nh{y8TyWjpjiIEhFd/tl">
              <block type="comment" id="K/RigU5g)ITrS$Z5%z%$" x="-1687" y="1462">
                <field name="COMMENT">reset Monat</field>
                  <block type="schedule" id="I+d[tdGa*#NplJWq)l:D">
                    <field name="SCHEDULE">2 0 1 * *</field>
                      <block type="control" id="Xs0Vn%@[Z3LhUgSZi.{E">
                          <block type="math_number" id="!8%xuHUE*S.4byz]?#eV">
                          <block type="control" id="$izuc,5%%3Gb_Y!X,+vb">
                              <block type="get_value" id="~}P$;7JTwiREk|;4H:.i">
              <block type="comment" id="oHR,JG*z8K2lOHmdJgUI" x="-1687" y="1662">
                <field name="COMMENT">reset Jahr</field>
                  <block type="schedule" id="#CJ#r$^ohJ=^7![RC?r[">
                    <field name="SCHEDULE">59 23 31 12 *</field>
                      <block type="control" id="RjxS0F1e!{}R=?k0u5hu">
                          <block type="math_number" id="Gv+;Fb{zqvo$M?Mv;DML">
                          <block type="control" id="!u17z/OwRnOxh=PKk1UV">
                              <block type="get_value" id="@hyKafoqvaHq~H5k.|vG">
            W J 2 Replies Last reply Reply Quote 1
              watcherkb @Knallochse last edited by
              @Knallochse wegen Zeitmangel ruht das Projekt aktuell bei mir. Auch wegen der Anschaffung eines 3D-Druckers. Gehäuse ist schon gedruckt aber keine Zeit gehabt das final einzubauen und zu verlöten. Außerdem kämpfe ich immer noch mit dem Problem dass der ESP nach paar Tagen offline ist. Beschlagen der Uhr ist auch noch ein Problem was ich lösen muss. Wie schaut es bei euch aus?
              • pfried
                pfried last edited by
                @jomjol Hallo Jomjol, hattest Du schon Zeit Dir den Speicheroverflow anzusehen. Wenn nicht, welche HW verwendest Du, dann kann ich mir ja auch diese bestellen..... Vielen Dank und liebe Grüße Paul
                • coyote
                  coyote Most Active @watcherkb last edited by
                  @watcherkb also ich hab ja, wie oben beschrieben, vom Parser Adapter auf Scriptabfrage umgestellt, seit dem läuft das Ding jetzt schon seit 20 treffen unterbrechungsfrei, keine disconnects mehr vom ESP
                    jomjol @Knallochse last edited by
                    @Knallochse schick mir mal ein paar Bilder von deinen digitalen Ziffern. Je Ziffer so 3-5 Stück, dann kann ich die Erkennung damit trainieren.
                      jomjol @pfried last edited by
                      @pfried Hallo Paul,
                      bin momentan bis Weihnachten beruflich ziemlich beschäftigt und komme erst nach den Feiertagen dazu, es mir genauer anzuschauen. Welche Version verwendest du den genau, denn in der letzten Version habe schon ein kleineres potentielles Leck entfernt.
                      Dennoch kann ich das nicht richtig gut debuggen, denn bei mir läuft das ganze auf einer Synology DS718+ als Docker Container und dort ist es echt stabil.
                      pfried 1 Reply Last reply Reply Quote 0
                      • pfried
                        pfried @jomjol last edited by
                        Ich verwende die letzte Raspi-Rolling Version: jomjol/wasserzaehler:raspi-rolling, die ich über Docker pull bekommen habe, wie Du oben beschrieben hast. Läuft diese Version auf einem RP3+ bei Dir stabil, wenn ja, besorge ich mir noch einen......
                        Liebe Grüße
                        Paul
                          @pfried Hallo Paul,
                          bei mir läuft der Docker auf einer Synology mit 12 GB Ram, daher habe ich mit einem Speicherleck keine Probleme. Meinen Raspi B3 verwende ich nur zum Testen. Dort läuft es nicht im Produktivmodus über meherere Stunden.
                          Inzwischen habe ich aber mit googlen auch die Ursache gefunden. Das Problem ist bekannt und liegt in der Tensorflowbibliothek selbst: https://github.com/keras-team/keras/issues/13118.
                          Ich habe das Workaround eingebaut und gerade läuft der Docker-Build auch für den Raspi-Rolling. Ganz weg ist das Problem nicht, aber deutlich kleiner:
                          Vorher:
                          Nachher:
                          Jeweils nach 20 Aufrufen.
                          Probier mal das aus und melde ich. Bei mir installiere ich es auch, sobald der Build fertig ist.
                          LG, jomjol
                          hotplot created this issue in keras-team/keras
                          closed Repeatedly calling model.predict(...) results in memory leak #13118
                            C1500 last edited by
                            Servus
                            Ich hatte gestern die Idee das roi Bild mit in die VIS aufzunehemen.
                            Schaut sehr gut aus.
                            Aber leider wird es anscheinend nur aktualisiert, wenn ich die ip:3000/roi.html aufrufe.
                            Ich hab aber das direkte Bild verlinkt.
                            Kann ich das auch automatisch irgendwie generieren lassen?
                            Ideal wäre natürlich wenn es nur erstellt wir wenn die VIS aktiv ist und auch wirklich eine Änderung vorliegt.
                            Ist vermutlich eher eine VIS frage aber da es nur mit dem Wasserzähler zu tun hat frag ich hier.
                            Ich verwende noch die letzte Version die direkt auf dem PI ohner Docker läuft.
                            Gruß Peer
                            pfried J 2 Replies Last reply Reply Quote 0
                            • pfried
                              pfried @C1500 last edited by
                              @C1500 Hast Du schon probiert, das mit dem Parser zu machen, würde mich interessieren ob das geht. Wie läuft das mit Deiner Erkennungsrate, ist diese stabil?
                                Servus @pfried
                                Ich hatte mit dem Parser immer das Problem, dass er pünklich um 0:03 Uhr aufgehört hat und sich auch die CAM weggehängt hat.
                                Ich probier jetzt gerade das Script von weiter oben.
                                Letzte Nacht lief es schon mal durch.
                                Die Erkennungsrate ist sehr gut, solange ich "usePreValue" verwende.
                                Sobald die Zahlen anfangen sich wegzudrehen wird es sonst schwierig.
                                Gruß Peer
                                  jomjol @C1500 last edited by
                                  @C1500 Korrekt, das roi-Bild wird nur bei roi.html aktualisiert. Der Aufwand, es jedesmal zu aktualisieren ist nicht sehr groß, kann ich bei nächster Gelegenheit mal machen.
                                    ecki945 last edited by
                                    Hat einer von Euch diess Projekt erfolgreich in einer VM unter Proxmox am laufen?
                                    • pfried
                                      pfried last edited by pfried
                                      @jomjol Habe die neue Docker Version getestet. Es dauert nun nicht mehr 4 Stunden bis der Memory überläuft sondern 15 Stunden:
                                        @pfried Hallo Paul,
                                        der Memory-Leak liegt intern in Tensorflow. Da kann ich an meiner Software nichts machen. Nicht mal das Löschen und Neuladen der Tensorflowobjekte hilft nicht, da offenbar ein interner Tensor im Speicher bleibt. Habe mehrere Threads dazu gefunden.
                                        Die Tensorflow-Community arbeitet daran und es gibt Hinweise, dass es in der Nightly besser wird, aber anscheinend nicht bei allen.
                                        Bleibt nur das Beobachten und Update, sobald es eine neue Version gibt, testen. Ich beobachte es weiter.
                                        Eventuell kannst du deinen Container regelmäßig nach ein paar Stunden per Script neu starten als Zwischenlösung?
                                        Gruß, jomjol
                                        • pfried
                                          Hallo, hat jemand eine Lösung für die Beschlagung des Wasserzählers gefunden?
                                          Wie man sieht sinkt dadurch die Erkennungsrate gegen null:
                                            watcherkb @pfried last edited by
                                            @pfried das Beschlagen hat nur einen Grund: Wasser ist kalt, Umgebung warm. Dadurch beschlägt es. Also entweder dämmt man den Wasserzähler gegen Wärme, oder alternativ probieren eine anti-Beschlagfolie oder Spray verwenden. Alles nur Theorie...hab ich auch noch vor mir.
                                            how-to wasser wasserzähler
                                            48
                                            1089
                                            350794
