    • simatec
      @MathiasJ
      Ich habe deine Config mal nachgestellt und denke dass es auf deinem NAS Probleme mit dem Schreibrechten gibt.
      So sollte dein Log aussehen ...
      backitup.0	2019-12-17 21:36:18.696	debug	(17482) [iobroker] exec: done
      backitup.0	2019-12-17 21:36:18.694	debug	(17482) [iobroker/umount] done
      backitup.0	2019-12-17 21:35:18.424	debug	(17482) [iobroker/umount] mount activ... umount in 60 Seconds!!
      backitup.0	2019-12-17 21:35:18.405	debug	(17482) [iobroker/history] backitup.0.history.html
      backitup.0	2019-12-17 21:35:18.388	debug	(17482) [iobroker/pushover] done
      backitup.0	2019-12-17 21:35:18.387	debug	(17482) sendTo "send" to system.adapter.pushover.0 from system.adapter.backitup.0
      backitup.0	2019-12-17 21:35:18.384	debug	(17482) [iobroker/pushover] [iobroker] used pushover-Instance: pushover.0
      backitup.0	2019-12-17 21:35:18.376	debug	(17482) [iobroker/clean] done
      backitup.0	2019-12-17 21:35:18.371	debug	(17482) [iobroker/googledrive] done
      backitup.0	2019-12-17 21:35:17.776	debug	(17482) [iobroker/googledrive] delete iobroker_2019_12_17-21_13_10_test_backupiobroker.tar.gz
      backitup.0	2019-12-17 21:34:22.730	debug	(17482) [iobroker/googledrive] Copy iobroker_2019_12_17-21_33_20_test_backupiobroker.tar.gz...
      backitup.0	2019-12-17 21:34:22.721	debug	(17482) [iobroker/dropbox] done
      backitup.0	2019-12-17 21:33:28.831	debug	(17482) [iobroker/dropbox] Copy iobroker_2019_12_17-21_33_20_test_backupiobroker.tar.gz...
      backitup.0	2019-12-17 21:33:28.826	debug	(17482) [iobroker/cifs] done
      backitup.0	2019-12-17 21:33:28.823	debug	(17482) [iobroker/iobroker] done
      backitup.0	2019-12-17 21:33:27.490	debug	(17482) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2019_12_17-21_33_20_test_backupiobroker.tar.gz
      backitup.0	2019-12-17 21:33:22.314	debug	(17482) [iobroker/iobroker] host.tinker-test 3058 objects saved
      backitup.0	2019-12-17 21:33:22.267	debug	(17482) [iobroker/iobroker] host.tinker-test 2741 states saved
      backitup.0	2019-12-17 21:33:20.440	debug	(17482) [iobroker/mount] done
      backitup.0	2019-12-17 21:32:53.520	debug	(17482) mount activ... umount in 2 Seconds!!
      backitup.0	2019-12-17 21:32:43.511	debug	(17482) [iobroker] 10 33 21 */1 * *
      backitup.0	2019-12-17 21:32:43.498	info	(17482) [iobroker] backup was activated at 21:33 every 1 day(s)
      backitup.0	2019-12-17 21:32:43.448	info	(17482) starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.17.0
      MathiasJ 1 Reply Last reply Reply Quote 0
      • Glasfaser
        Glasfaser @simatec last edited by
        @simatec
        Danke 👍
        So sieht es dann aus … und man könnte die Dateigröße wie schon erwähnt überwachen .
        • MathiasJ
          MathiasJ @simatec last edited by
          @simatec
          Und wie komme ich jetzt dahinter?
          Ich habe weder auf IObroker noch auf der NAS was geändert. 😞
          • simatec
            simatec Developer Most Active @MathiasJ last edited by
            @MathiasJ
            Wie nutzt du den NAS? Per NFS oder CIFS?
            • MathiasJ
              MathiasJ last edited by MathiasJ
              Per CIFS, due ganze Zeit schon.
              CIFS habe ich auf dem PI4 installiert und habe gefühlte 1000 mal den fixer drüber laufen lassen.
              Was ich jetzt aber nicht verstehe:
              Wenn ich das Häkchen bei der Hauotseite von der NAS entferne, müssten doch die Backups funktionieren, wenn es an der NAS liegt. Auch da habe ich 0kb
              simatec 2 Replies Last reply Reply Quote 0
              • simatec
                simatec Developer Most Active @MathiasJ last edited by simatec
                @MathiasJ
                Das war aber in deiner Aussage von vorhin anders.
                Da hast du geschrieben, dass es ohne NAS funktioniert
                Dann passen eventuell die Schreibrechte in dem Ordner /opt/iobroker/backups nicht
                • simatec
                  @MathiasJ
                  Probiere mal ein Backup über Konsole zu erstellen ...
                  Dann kannst du den Fehler eingrenzen.
                  iobroker backup
                  • MathiasJ
                    @simatec
                    Beim ersten Mal hat es ohne NAS funktioniert.
                    Mit NAS dann 0kb.
                    Die NAS wieder weg genommen, wieder 0kb.
                    Gruß, Mathias
                    • simatec
                      @MathiasJ sagte in Test Adapter Backitup v1.3.x:
                      0kb
                      Wo hast du 0 Kb in den Clouds oder auch lokal?
                      Probiere mal das manuelle Backup über Konsole siehe Post oben
                      Glasfaser MathiasJ 2 Replies Last reply Reply Quote 0
                      • Glasfaser
                        @simatec
                        Soll er nicht jetzt ein Backup anstoßen und den kompletten Debug-Log hier posten .Dann könnte man vielleicht mehr sehen !?
                        • simatec
                          simatec Developer Most Active @Glasfaser last edited by
                          @Glasfaser
                          Am besten wäre es ... aber ggfs. sogar ein manuelles Backup mit der aktivierten Debug Option in den Haupteinstellungen von Backitup.
                          Dann die komplette Konsolenausgabe posten
                          • MathiasJ
                            @simatec
                            Auch über der Konsole habe ich 0kb.
                            Nur einen Log kann ich nicht bieten. Habe es über dem Smartphone gemacht.
                            • simatec
                              @MathiasJ
                              Gut dann liegt dein Problem definitiv nicht an backitup sondern an deinem System
                              Prüfe die Rechte von /opt/iobroker/backups mal als erstes ...
                              • JB_Sullivan
                                JB_Sullivan last edited by
                                Ich haue mal wieder eine Frage raus, weil dazu in der Doku auf GitHub nichts zu finden ist.
                                ZiggBee Datenbank - bezieht sich das nur auf den Adapter ZiggBee oder wird auch was von deConz (ist ja auch ZiggBee) gesichert?
                                • simatec
                                  simatec Developer Most Active @JB_Sullivan last edited by
                                  @JB_Sullivan
                                  Es bezieht sich auf die Gerätedatenbank des zigbee Adapters
                                  Unter deconz ist das nicht nötig.
                                  • MathiasJ
                                    MathiasJ @simatec last edited by MathiasJ
                                    @simatec
                                    Mache ich dann morgen.
                                    Wie kann das sein, dass das System von jetzt auf gleich so verhunzt ist?
                                    Gehe ich richtig in der Annahme, dass es 777 sein muss bei /opt/iobroker/backups?
                                    Rootrechte= chmod 777
                                    Ich kann weder mit dem user, noch mit root ein Backup erstellen.
                                    ich habe den Fix nochmal drüber laufen lassen, jedoch ohne Erfolg.
                                    ich bekomme jedesmal 0 kb.
                                    • simatec
                                      @MathiasJ
                                      Am besten mit folgenden Befehlen ...
                                      sudo chmod 777 /opt/iobroker/backups/
                                      sudo chmod 777 /opt/iobroker/backups/*
                                      Damit bist du ganz sicher ...
                                      • MathiasJ
                                        @simatec
                                        root@ioBroker-RasPi4:~# chmod 777 /opt/iobroker/backups/*
                                        chmod: Zugriff auf '/opt/iobroker/backups/*' nicht möglich: Datei oder Verzeichnis nicht gefunden
                                        Ich werde nach der Arbeit Backitup komplett deinstallieren, den Ordner /opt/iobroker/backups löschen,
                                        Backitup wieder installieren. Dann müsste der Odner neu angelegt werden.
                                        Gruß,
                                        Mathias
                                        E simatec 2 Replies Last reply Reply Quote 0
                                          Jan1 last edited by Jan1
                                          wieder wurde das automatische Backup nicht entsprechend der Vorgabe erstellt. alles doppelt und IOBroker fehlt:
                                          im Log wieder die bekannten compact mode Errors:
                                          2019-12-18 02:00:38.043  - error: backitup.0 (COMPACT) TypeError: Cannot read property 'split' of undefined
                                              at options.adapter.getState (/opt/iobroker/node_modules/iobroker.backitup/lib/scripts/92-history.js:24:40)
                                              at Adapter.getState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5407:29)
                                              at Object.command (/opt/iobroker/node_modules/iobroker.backitup/lib/scripts/92-history.js:10:25)
                                              at Immediate.executeScripts (/opt/iobroker/node_modules/iobroker.backitup/lib/execute.js:216:22)
                                              at runCallback (timers.js:706:11)
                                              at tryOnImmediate (timers.js:676:5)
                                          und auch wieder beim manuellen Start des Backup alles OK.
                                          Warum geht das automatisch nicht?
                                            Einstein67 @MathiasJ last edited by
                                            @MathiasJ said in Test Adapter Backitup v1.3.x:
                                            Der Ordner wird nicht von BackitUp angelegt, sondern von ioBroker.
                                            170
                                            2780
                                            2367084
