    4. Scene Adapter False wird nicht ausgeführt
      AndyUM61 last edited by
      2. Zeile deaktiviert, bei "true":
      inMem	2015-12-11 16:58:08	debug	message scene.* scene.Weihnachtslicht val=uncertain, ack=true, ts=1449849489, q=0, from=system.adapter.scenes.0, lc=1449849489
      inMem	2015-12-11 16:58:08	debug	message hm-rpc.1.JEQ0713213.17.STATE hm-rpc.1.JEQ0713213.17.STATE val=false, ack=true, ts=1449849489, q=0, from=system.adapter.hm-rpc.1, lc=1449849468
      inMem	2015-12-11 16:58:08	debug	message hm-rpc.2.CUX4000008.4.SEND_CMD hm-rpc.2.CUX4000008.4.SEND_CMD val=, ack=true, ts=1449849489, q=0, from=system.adapter.hm-rpc.2, lc=1449849489
      inMem	2015-12-11 16:58:08	debug	message scene.* scene.Weihnachtslicht val=true, ack=true, ts=1449849489, q=0, from=system.adapter.scenes.0, lc=1449849489
      hm-rpc-2	2015-12-11 16:58:08	info	setValue ["CUX4000008:4","SEND_CMD","is0000FF000FFF"] STRING
      hm-rpc-1	2015-12-11 16:58:08	info	setValue ["JEQ0713213:17","STATE",false] BOOL
      inMem	2015-12-11 16:58:08	debug	message hm-rpc.2.CUX4000008.4.SEND_CMD hm-rpc.2.CUX4000008.4.SEND_CMD val=is0000FF000FFF, ack=false, ts=1449849489, q=0, from=system.adapter.scenes.0, lc=1449849489
      inMem	2015-12-11 16:58:08	debug	message hm-rpc.1.JEQ0713213.17.STATE hm-rpc.1.JEQ0713213.17.STATE val=false, ack=false, ts=1449849489, q=0, from=system.adapter.scenes.0, lc=1449849468
      scenes-0	2015-12-11 16:58:08	debug	activateScene: new state for "scene.Weihnachtslicht" is "true"
      scenes-0	2015-12-11 16:58:08	debug	activateScene: execute for "scene.Weihnachtslicht" (true)
      …bei "false":
      inMem	2015-12-11 16:58:41	debug	message scene.* scene.Weihnachtslicht val=uncertain, ack=true, ts=1449849521, q=0, from=system.adapter.scenes.0, lc=1449849521
      inMem	2015-12-11 16:58:41	debug	message hm-rpc.1.JEQ0713213.17.STATE hm-rpc.1.JEQ0713213.17.STATE val=true, ack=true, ts=1449849521, q=0, from=system.adapter.hm-rpc.1, lc=1449849521
      inMem	2015-12-11 16:58:41	debug	message hm-rpc.2.CUX4000008.4.SEND_CMD hm-rpc.2.CUX4000008.4.SEND_CMD val=, ack=true, ts=1449849521, q=0, from=system.adapter.hm-rpc.2, lc=1449849521
      inMem	2015-12-11 16:58:41	debug	message scene.* scene.Weihnachtslicht val=false, ack=true, ts=1449849521, q=0, from=system.adapter.scenes.0, lc=1449849521
      inMem	2015-12-11 16:58:41	debug	message hm-rpc.2.CUX4000008.4.SEND_CMD hm-rpc.2.CUX4000008.4.SEND_CMD val=is0000FF000FF0, ack=false, ts=1449849521, q=0, from=system.adapter.scenes.0, lc=1449849521
      javascript-0	2015-12-11 16:58:41	info	script.js.LichterAn: Anzahl Lichter: 24 # davon an: 2
      javascript-0	2015-12-11 16:58:41	info	script.js.LichterAn: New state of hm-rpc.1.JEQ0713213.17.STATE: true
      inMem	2015-12-11 16:58:41	debug	message hm-rpc.1.JEQ0713213.17.STATE hm-rpc.1.JEQ0713213.17.STATE val=true, ack=false, ts=1449849521, q=0, from=system.adapter.scenes.0, lc=1449849521
      hm-rpc-2	2015-12-11 16:58:41	info	setValue ["CUX4000008:4","SEND_CMD","is0000FF000FF0"] STRING
      hm-rpc-1	2015-12-11 16:58:41	info	setValue ["JEQ0713213:17","STATE",true] BOOL
      scenes-0	2015-12-11 16:58:41	debug	activateScene: new state for "scene.Weihnachtslicht" is "false"
      scenes-0	2015-12-11 16:58:41	debug	activateScene: execute for "scene.Weihnachtslicht" (false)
      • Bluefox
        Bluefox last edited by
        @AndyUM61:
        …bei "false":
        geht es um JEQ0713213 ?
        Weil in beiden Fällen ich kann sehen dass es korrekt abgearbeitet wird:
        scene.Weihnachtslicht(true) => hm-rpc.1.JEQ0713213.17.STATE val=false, ack=true
        scene.Weihnachtslicht(false) => hm-rpc.1.JEQ0713213.17.STATE val=true, ack=true
          Ja, es geht um JEQ0713213.
          Der schaltet nur bei "false" aus, wenn er extra in der 2. Zeile steht.
          Ist die 2. Zeile deaktiviert, schaltet er nicht aus.
          • Bluefox
            @AndyUM61:
            Ist die 2. Zeile deaktiviert, schaltet er nicht aus. `
            Aber da kommt sogar die Bestätigung von hm-rpc, dass alles geklappt hat:
            Wenn du über admin schaltest, was passiert dann? oder:
            iobroker state set hm-rpc.1.JEQ0713213.17.STATE false
            iobroker state set hm-rpc.1.JEQ0713213.17.STATE true
              Wie mache ich das?
              ok. hab verstanden…
              Funktioniert Beides korrekt.
              7419_iobroker.2018-10-21.log
                Es ist wirklich so, dass, wenn ich in der 1. Zeile "true" und "false" anklicke, und dann die Szene teste erst eingeschaltet, und sofort wieder ausgeschaltet wird.
                Warum auch immer das so ist…
                  Arminhh last edited by
                  moin, sorry das ich mich jetzt erst melde!! Ein log hast du jetzt ja. Ein Problem mit dem Ausschalten hat sich bei mir erledigt. Ich hatte das setzen von True und false falsch interpretiert.
                  Ein Problem habe ich aber. Wenn ich einen Wert z.B die Helligkeit setzen will, wird der Wert nicht gesetzt. Anbei mal ein Pic.
                  Eventuell könnte man viele Missverstände vermeiden wenn jemand bei dem alles Funktioniert mal Screenshots zur Verfügung stellt von einer Scene, Gruppe und Vgruppe. Bin auch nicht sicher alles richtig verstanden zu haben, weil es nur zur Hälfte funktioniert! Sonst hätte ich die Screenshots gemacht.
                  Dane für die Hilfe!
                  mfg
                  Armin
                    Pman last edited by
                    Das liegt daran, dass du bei den Hue Lampen bri und on verwendest. On ist aber nichts anderes als bri = 254. Nimm das on raus, dann sollte es funktionieren.
                    @bluefox kannst du hue 0.5.2 publishen? Ich habe alle jscs Fehler beseitigt und einige Funktionen gefixt.
                      Danke Pman schon wieder ein Fehler weniger!! 😄
                        was ich vermisse das ich bei einer Virtuellen Gruppe bei einer Variable Werteliste z.B. 1-7 keine Rechenoperationen auswählen kann. z.B. >5
                        mfg
                        Arminhh
                        • Bluefox
                          @Pman:
                          @bluefox kannst du hue 0.5.2 publishen? Ich habe alle jscs Fehler beseitigt und einige Funktionen gefixt. `
                          Sorry. Ich dachte, ich habe das schon gemacht.
                          Jetzt 0.5.2 ist draußen.
                          2141
