    4. Kommunikationsschwierigkeiten
    UNSOLVED Kommunikationsschwierigkeiten
    • Daniel S
      Daniel S last edited by
      Moin,
      nach dem NPM Update funktionieren BLE, Modbus und auch web.0 SSL bei mir nicht mehr. Anbei der Log. Jemand eine Idee woran das liegen könnte?
      Was könnte ich versuchen bevor ich das ganze wieder neu aufsetze?
      Grüße aus Hamburg
      host.raspberrypi	2019-12-18 12:12:31.605	error	instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      web.0	2019-12-18 12:12:31.062	info	(3035) https server listening on port 1024
      web.0	2019-12-18 12:12:31.059	warn	(3035) Terminated (JS_CONTROLLER_STOPPED): Without reason
      web.0	2019-12-18 12:12:31.056	error	(3035) port 443 already in use
      web.0	2019-12-18 12:11:32.170	info	(3035) Secure socket.io server listening on port 443
      web.0	2019-12-18 12:11:31.596	info	(3035) starting. Version 2.4.10 in /opt/iobroker/node_modules/iobroker.web, node: v10.17.0
      host.raspberrypi	2019-12-18 12:11:29.411	info	instance system.adapter.web.0 started with pid 3035
      modbus.0	2019-12-18 12:10:59.777	warn	(2750) On error: {"errno":"ETIMEDOUT","code":"ETIMEDOUT","syscall":"connect","address":"192.168.2.210","port":502}
      modbus.0	2019-12-18 12:10:59.776	error	(2750) Client in error state.
      modbus.0	2019-12-18 12:10:59.775	error	(2750) Socket Error
      host.raspberrypi	2019-12-18 12:10:59.383	info	Restart adapter system.adapter.web.0 because enabled
      host.raspberrypi	2019-12-18 12:10:59.380	error	instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      web.0	2019-12-18 12:10:58.834	info	(2991) https server listening on port 1024
      web.0	2019-12-18 12:10:58.831	warn	(2991) Terminated (JS_CONTROLLER_STOPPED): Without reason
      web.0	2019-12-18 12:10:58.828	error	(2991) port 443 already in use
      web.0	2019-12-18 12:09:59.954	info	(2991) Secure socket.io server listening on port 443
      web.0	2019-12-18 12:09:59.415	info	(2991) starting. Version 2.4.10 in /opt/iobroker/node_modules/iobroker.web, node: v10.17.0
      host.raspberrypi	2019-12-18 12:09:57.141	info	instance system.adapter.web.0 started with pid 2991
      host.raspberrypi	2019-12-18 12:09:27.110	info	Restart adapter system.adapter.web.0 because enabled
      host.raspberrypi	2019-12-18 12:09:27.107	error	instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      web.0	2019-12-18 12:09:26.568	info	(2939) https server listening on port 1024
      web.0	2019-12-18 12:09:26.566	warn	(2939) Terminated (JS_CONTROLLER_STOPPED): Without reason
      web.0	2019-12-18 12:09:26.562	error	(2939) port 443 already in use
      web.0	2019-12-18 12:08:27.702	info	(2939) Secure socket.io server listening on port 443
      web.0	2019-12-18 12:08:27.115	info	(2939) starting. Version 2.4.10 in /opt/iobroker/node_modules/iobroker.web, node: v10.17.0
      host.raspberrypi	2019-12-18 12:08:24.912	info	instance system.adapter.web.0 started with pid 2939
      host.raspberrypi	2019-12-18 12:07:54.883	info	Restart adapter system.adapter.web.0 because enabled
      host.raspberrypi	2019-12-18 12:07:54.880	error	instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      web.0	2019-12-18 12:07:54.317	info	(2900) https server listening on port 1024
      web.0	2019-12-18 12:07:54.316	warn	(2900) Terminated (JS_CONTROLLER_STOPPED): Without reason
      web.0	2019-12-18 12:07:54.314	error	(2900) port 443 already in use
      modbus.0	2019-12-18 12:07:45.219	warn	(2750) On error: {"errno":"ETIMEDOUT","code":"ETIMEDOUT","syscall":"connect","address":"192.168.2.210","port":502}
      modbus.0	2019-12-18 12:07:45.217	error	(2750) Client in error state.
      modbus.0	2019-12-18 12:07:45.216	error	(2750) Socket Error
      web.0	2019-12-18 12:06:55.422	info	(2900) Secure socket.io server listening on port 443
      web.0	2019-12-18 12:06:54.874	info	(2900) starting. Version 2.4.10 in /opt/iobroker/node_modules/iobroker.web, node: v10.17.0
      host.raspberrypi	2019-12-18 12:06:52.557	info	instance system.adapter.web.0 started with pid 2900
      host.raspberrypi	2019-12-18 12:06:22.527	info	Restart adapter system.adapter.web.0 because enabled
      host.raspberrypi	2019-12-18 12:06:22.524	error	instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      web.0	2019-12-18 12:06:21.982	info	(2872) https server listening on port 1024
      web.0	2019-12-18 12:06:21.980	warn	(2872) Terminated (JS_CONTROLLER_STOPPED): Without reason
      web.0	2019-12-18 12:06:21.976	error	(2872) port 443 already in use
      web.0	2019-12-18 12:05:23.111	info	(2872) Secure socket.io server listening on port 443
      web.0	2019-12-18 12:05:22.538	info	(2872) starting. Version 2.4.10 in /opt/iobroker/node_modules/iobroker.web, node: v10.17.0
      host.raspberrypi	2019-12-18 12:05:20.564	info	instance system.adapter.web.0 started with pid 2872
      host.raspberrypi	2019-12-18 12:04:50.536	info	Restart adapter system.adapter.web.0 because enabled
      host.raspberrypi	2019-12-18 12:04:50.533	error	instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      web.0	2019-12-18 12:04:49.990	info	(2809) https server listening on port 1024
      web.0	2019-12-18 12:04:49.987	warn	(2809) Terminated (JS_CONTROLLER_STOPPED): Without reason
      web.0	2019-12-18 12:04:49.983	error	(2809) port 443 already in use
      modbus.0	2019-12-18 12:04:30.663	warn	(2750) On error: {"errno":"ETIMEDOUT","code":"ETIMEDOUT","syscall":"connect","address":"192.168.2.210","port":502}
      modbus.0	2019-12-18 12:04:30.661	error	(2750) Client in error state.
      modbus.0	2019-12-18 12:04:30.658	error	(2750) Socket Error
      web.0	2019-12-18 12:03:51.045	info	(2809) Secure socket.io server listening on port 443
      web.0	2019-12-18 12:03:50.449	info	(2809) starting. Version 2.4.10 in /opt/iobroker/node_modules/iobroker.web, node: v10.17.0
      host.raspberrypi	2019-12-18 12:03:47.634	info	instance system.adapter.web.0 started with pid 2809
      host.raspberrypi	2019-12-18 12:03:17.609	info	Restart adapter system.adapter.web.0 because enabled
      host.raspberrypi	2019-12-18 12:03:17.608	error	instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      web.0	2019-12-18 12:03:17.084	info	(2757) https server listening on port 1024
      web.0	2019-12-18 12:03:17.082	warn	(2757) Terminated (JS_CONTROLLER_STOPPED): Without reason
      web.0	2019-12-18 12:03:17.080	error	(2757) port 443 already in use
      host.raspberrypi	2019-12-18 12:02:51.439	info	iobroker exit 0
      • list item
      |Systemdata| Bitte Ausfüllen|
      Hardwaresystem: NUC/Pi3/etc.
      Arbeitsspeicher: 1GB
      Festplattenart: SD-Karte/SSD/HDD
      Betriebssystem: Ubuntu/Windows/Mac
      Node-Version: 10.x.x
      Nodejs-Version: 10.x.x
      NPM-Version: 6.x.x
      Installationsart: Skript/Manuell
      Image genutzt: Ja/Nein
      Ort/Name der Imagedatei: Link
      Daniel S 1 Reply Last reply Reply Quote 0
      • Daniel S
        Daniel S @Daniel S last edited by
        @Daniel-S
        mhhh. Der Befehl:
        curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/stable-installer/fix_installation.sh | bash
        hat schonmal bis auf den Modbus alles repariert....
        • AlCalzone
          AlCalzone Developer @Daniel S last edited by
          @Daniel-S Wo hast du diesen Link gefunden? Wir haben inzwischen eine deutliche kürzere Variante. Ggf. müssen wir noch eine Doku anpassen.
          • Daniel S
            Hier:
            https://www.iobroker.net/docu/index-15.htm?page_id=8323&lang=de
            • Daniel S
              Daniel S last edited by Daniel S
              Jemand eine Idee?
              modbus.0	2019-12-18 13:36:05.927	warn	(2323) On error: {"errno":"ETIMEDOUT","code":"ETIMEDOUT","syscall":"connect","address":"192.168.2.210","port":502}
              modbus.0	2019-12-18 13:36:05.926	error	(2323) Client in error state.
              modbus.0	2019-12-18 13:36:05.923	error	(2323) Socket Error
              modbus.0	2019-12-18 13:32:51.366	warn	(2323) On error: {"errno":"ETIMEDOUT","code":"ETIMEDOUT","syscall":"connect","address":"192.168.2.210","port":502}
              modbus.0	2019-12-18 13:32:51.365	error	(2323) Client in error state.
              modbus.0	2019-12-18 13:32:51.363	error	(2323) Socket Error
              modbus.0	2019-12-18 13:32:49.176	info	(2323) List of port: [{"comName":"/dev/ttyAMA0"}]```
                apollon77 @Daniel S last edited by
                @Daniel-S sicher das da nicht irgendwie noch Prozesse laufen? Port 443 noch belegt. Serial Timeouts. Mal reboot?
                errorproblem modbus ssl
