    4. Apple Homekit Siri
    Apple Homekit Siri
      pix last edited by
      Schätze, da liegt wohl das Problem :roll:
      MacMini-Ethernet:iobroker pix$ node -v
      v5.0.0
      MacMini-Ethernet:iobroker pix$ npm -v
      3.4.0
      Pix
      • V
        versteckt last edited by
        Ok, kannst du versuchen eine ältere Version zu installieren?
        Geht ja beim Mac an sich recht fix.
        Du musst halt davor iobroker komplett stoppen, bzw. danach alles wieder hochfahren.
          pix last edited by
          Ok, habe jetzt die "zuverlässige" https://nodejs.org/en/download/ installiert (vorher iobroker gestoppt, backups). Neustart ioBroker ohne Probleme.
          Bei der AKtivierung der homekit-Instanz erscheint nun dieser Fehler
          2015-12-12 16:45:04.900 - info: host.MacMini-Ethernet.fritz.box instance system.adapter.vis-google-fonts.0 terminated while should be started once
          2015-12-12 16:45:06.934 - info: host.MacMini-Ethernet.fritz.box object change system.adapter.homekit.0
          2015-12-12 16:45:06.940 - info: host.MacMini-Ethernet.fritz.box instance system.adapter.homekit.0 started with pid 16823
          2015-12-12 16:45:07.389 - error: uncaught exception: Module version mismatch. Expected 46, got 47.
          2015-12-12 16:45:07.394 - error: Error: Module version mismatch. Expected 46, got 47.
          at Error (native)
          at Object.Module._extensions..node (module.js:460:18)
          at Module.load (module.js:356:32)
          at Function.Module._load (module.js:311:12)
          at Module.require (module.js:366:17)
          at require (module.js:385:17)
          at Object. <anonymous>(/Users/pix/Documents/iobroker/node_modules/mdns/lib/dns_sd.js:24:20)
          at Module._compile (module.js:435:26)
          at Object.Module._extensions..js (module.js:442:10)
          2015-12-12 16:45:07.455 - debug: homekit.0 objectDB connected
          2015-12-12 16:45:07.461 - debug: homekit.0 statesDB connected
          2015-12-12 16:45:07.625 - info: homekit.0 starting. Version 0.0.6 in /Users/pix/Documents/iobroker/node_modules/iobroker.homekit
          2015-12-12 16:45:07.627 - info: homekit.0 requesting all states
          2015-12-12 16:45:07.628 - info: homekit.0 requesting all objects
          2015-12-12 16:45:07.756 - error: host.MacMini-Ethernet.fritz.box instance system.adapter.homekit.0 terminated with code 6 (uncaught exception)
          2015-12-12 16:45:07.756 - info: host.MacMini-Ethernet.fritz.box Restart adapter system.adapter.homekit.0 because enabled</anonymous>
          Deshalb lösche ich den Adapter komplett und installiere ganz neu:
          Tataa! :lol:
          MacMini-Ethernet:iobroker pix$ npm install https://github.com/husky-koglhof/ioBroker.homekit/tarball/master --production
          > curve25519@1.1.0 install /Users/pix/Documents/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/curve25519
          > node-gyp rebuild
          >!   CXX(target) Release/obj.target/curve/node_curve.o
            SOLINK_MODULE(target) Release/curve.node
          >! > ed25519@0.0.3 install /Users/pix/Documents/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/ed25519
          > node-gyp rebuild
          >!   CC(target) Release/obj.target/ed25519/src/ed25519/keypair.o
            CC(target) Release/obj.target/ed25519/src/ed25519/sign.o
            CC(target) Release/obj.target/ed25519/src/ed25519/open.o
            CC(target) Release/obj.target/ed25519/src/ed25519/crypto_verify_32.o
            CC(target) Release/obj.target/ed25519/src/ed25519/ge_double_scalarmult.o
            CC(target) Release/obj.target/ed25519/src/ed25519/ge_frombytes.o
            CC(target) Release/obj.target/ed25519/src/ed25519/ge_scalarmult_base.o
            CC(target) Release/obj.target/ed25519/src/ed25519/ge_precomp_0.o
            CC(target) Release/obj.target/ed25519/src/ed25519/ge_p2_0.o
            CC(target) Release/obj.target/ed25519/src/ed25519/ge_p2_dbl.o
            CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_0.o
            CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_dbl.o
            CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_to_p2.o
            CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_to_cached.o
            CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_tobytes.o
            CC(target) Release/obj.target/ed25519/src/ed25519/ge_madd.o
            CC(target) Release/obj.target/ed25519/src/ed25519/ge_add.o
            CC(target) Release/obj.target/ed25519/src/ed25519/ge_msub.o
            CC(target) Release/obj.target/ed25519/src/ed25519/ge_sub.o
            CC(target) Release/obj.target/ed25519/src/ed25519/ge_p1p1_to_p3.o
            CC(target) Release/obj.target/ed25519/src/ed25519/ge_p1p1_to_p2.o
            CC(target) Release/obj.target/ed25519/src/ed25519/ge_tobytes.o
            CC(target) Release/obj.target/ed25519/src/ed25519/fe_0.o
            CC(target) Release/obj.target/ed25519/src/ed25519/fe_1.o
            CC(target) Release/obj.target/ed25519/src/ed25519/fe_cmov.o
            CC(target) Release/obj.target/ed25519/src/ed25519/fe_copy.o
            CC(target) Release/obj.target/ed25519/src/ed25519/fe_neg.o
            CC(target) Release/obj.target/ed25519/src/ed25519/fe_add.o
            CC(target) Release/obj.target/ed25519/src/ed25519/fe_sub.o
            CC(target) Release/obj.target/ed25519/src/ed25519/fe_mul.o
            CC(target) Release/obj.target/ed25519/src/ed25519/fe_sq.o
            CC(target) Release/obj.target/ed25519/src/ed25519/fe_sq2.o
            CC(target) Release/obj.target/ed25519/src/ed25519/fe_invert.o
            CC(target) Release/obj.target/ed25519/src/ed25519/fe_tobytes.o
            CC(target) Release/obj.target/ed25519/src/ed25519/fe_isnegative.o
            CC(target) Release/obj.target/ed25519/src/ed25519/fe_isnonzero.o
            CC(target) Release/obj.target/ed25519/src/ed25519/fe_frombytes.o
            CC(target) Release/obj.target/ed25519/src/ed25519/fe_pow22523.o
            CC(target) Release/obj.target/ed25519/src/ed25519/sc_reduce.o
            CC(target) Release/obj.target/ed25519/src/ed25519/sc_muladd.o
            CXX(target) Release/obj.target/ed25519/src/ed25519.o
            SOLINK_MODULE(target) Release/ed25519.node
          iobroker.homekit@0.0.6 node_modules/iobroker.homekit
          └── hap-nodejs@0.0.7 (srp@0.2.0, node-persist@0.0.6, curve25519@1.1.0, ed25519@0.0.3)
          Bei Installation der Instanz erscheint ein kleiner Fehler
          ! 2015-12-12 16:50:06.409 - info: iobroker add homekit 2015-12-12 16:50:07.233 - info: iobroker host.MacMini-Ethernet.fritz.box install adapter homekit 2015-12-12 16:50:07.259 - info: iobroker got /Users/pix/Documents/iobroker/node_modules/iobroker.homekit/admin 2015-12-12 16:50:07.288 - info: iobroker upload [1] homekit.admin /Users/pix/Documents/iobroker/node_modules/iobroker.homekit/admin/index.html index.html text/html 2015-12-12 16:50:07.355 - info: iobroker upload [0] homekit.admin /Users/pix/Documents/iobroker/node_modules/iobroker.homekit/admin/homekit.png homekit.png image/png 2015-12-12 16:50:07.437 - info: iobroker host.MacMini-Ethernet.fritz.box command: node "adapter/homekit/main.js" --install 2015-12-12 16:50:07.577 - info: iobroker module.js:339 throw err; ^ ! Error: Cannot find module '/Users/pix/Documents/adapter/homekit/main.js' at Function.Module._resolveFilename (module.js:337:15) at Function.Module._load (module.js:287:25) at Function.Module.runMain (module.js:467:10) at startup (node.js:136:18) at node.js:963:3 ! 2015-12-12 16:50:07.592 - info: iobroker host.MacMini-Ethernet.fritz.box object system.adapter.homekit created 2015-12-12 16:50:07.691 - info: iobroker host.MacMini-Ethernet.fritz.box create instance homekit 2015-12-12 16:50:07.703 - info: iobroker host.MacMini-Ethernet.fritz.box object system.adapter.homekit.0.uptime created 2015-12-12 16:50:07.737 - info: iobroker host.MacMini-Ethernet.fritz.box object system.adapter.homekit.0.memRss created 2015-12-12 16:50:07.771 - info: iobroker host.MacMini-Ethernet.fritz.box object system.adapter.homekit.0.memHeapTotal created 2015-12-12 16:50:07.805 - info: iobroker host.MacMini-Ethernet.fritz.box object system.adapter.homekit.0.memHeapUsed created 2015-12-12 16:50:07.841 - info: iobroker host.MacMini-Ethernet.fritz.box object system.adapter.homekit.0.connected created 2015-12-12 16:50:07.875 - info: iobroker host.MacMini-Ethernet.fritz.box object system.adapter.homekit.0.alive created 2015-12-12 16:50:07.907 - info: host.MacMini-Ethernet.fritz.box object change system.adapter.homekit.0 2015-12-12 16:50:07.909 - info: iobroker host.MacMini-Ethernet.fritz.box object system.adapter.homekit.0 created 2015-12-12 16:50:07.916 - info: iobroker exit 0 !
          .. läuft aber durch.
          und schließlich die Instanz aktiviert und … :evil: (siehe oben)
          2015-12-12 16:51:30.493 - info: host.MacMini-Ethernet.fritz.box object change system.adapter.homekit.0
          2015-12-12 16:51:30.503 - info: host.MacMini-Ethernet.fritz.box instance system.adapter.homekit.0 started with pid 18771
          2015-12-12 16:51:30.992 - error: uncaught exception: Module version mismatch. Expected 46, got 47.
          2015-12-12 16:51:30.999 - error: Error: Module version mismatch. Expected 46, got 47.
          at Error (native)
          2015-12-12 16:51:31.062 - debug: homekit.0 objectDB connected
          2015-12-12 16:51:31.067 - debug: homekit.0 statesDB connected
          2015-12-12 16:51:31.280 - info: homekit.0 starting. Version 0.0.6 in /Users/pix/Documents/iobroker/node_modules/iobroker.homekit
          2015-12-12 16:51:31.283 - info: homekit.0 requesting all states
          2015-12-12 16:51:31.284 - info: homekit.0 requesting all objects
          2015-12-12 16:51:31.405 - error: host.MacMini-Ethernet.fritz.box instance system.adapter.homekit.0 terminated with code 6 (uncaught exception)</anonymous>
          Welche Node-Version sollte ich nehmen? Deine 0.12.7 erscheint ja geradezu alpha, wenn ich nur die VErsionsnummern vergleiche :?:
          Pix
          • V
            Ich probiere nachher mal die Version 4.2.3 aus, ev. kann ich es kurzfristig fixen.
            • V
              Hallo, zumindest in WebStorm startet die homekit Instanz mit 4.2.3 ohne Probleme.
              Für mich sieht das nach einem Fehler beim kompilieren aus.
              Bei dir wird weder mdns noch bignum kompiliert.
              Ich muss mir das in Ruhe nochmals ansehen, jetzt steht kochen am Programm.
              Christians-Mac-mini:tmp christian$ npm install https://github.com/husky-koglhof/ioBroker.homekit/tarball/master --production
              > curve25519@1.1.0 install /private/tmp/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/curve25519
              > node-gyp rebuild
              > mdns@2.2.11 install /private/tmp/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/mdns
              > node-gyp rebuild
                CXX(target) Release/obj.target/dns_sd_bindings/src/dns_sd.o
                CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_browse.o
                CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_enumerate_domains.o
                CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_get_addr_info.o
                CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_process_result.o
                CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_ref.o
                CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_ref_deallocate.o
                CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_ref_sock_fd.o
                CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_register.o
                CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_resolve.o
                CXX(target) Release/obj.target/dns_sd_bindings/src/mdns_utils.o
                CXX(target) Release/obj.target/dns_sd_bindings/src/network_interface.o
                CXX(target) Release/obj.target/dns_sd_bindings/src/socket_watcher.o
                CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_ref.o
                CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_create.o
                CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_deallocate.o
                CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_set_value.o
                CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_get_length.o
                CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_buffer_to_object.o
                SOLINK_MODULE(target) Release/dns_sd_bindings.node
              > bignum@0.11.0 install /private/tmp/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum
              > node-gyp configure build
                CXX(target) Release/obj.target/bignum/bignum.o
                SOLINK_MODULE(target) Release/bignum.node
              > ed25519@0.0.3 install /private/tmp/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/ed25519
              > node-gyp rebuild
              ├── yalm@2.0.0 (ansi-styles@2.1.0)
              ├── yargs@3.31.0 (camelcase@2.0.1, decamelize@1.1.1, window-size@0.1.4, y18n@3.2.0, os-locale@1.4.0, cliui@3.1.0, string-width@1.0.1)
              └── hap-nodejs@0.0.7 (node-persist@0.0.6, debug@2.2.0, curve25519@1.1.0, mdns@2.2.11, srp@0.2.0, ed25519@0.0.3)
              • fischi87
                fischi87 last edited by
                also ich habe den adapter drauf leider verbindet sich eve immer noch nicht mit diesem. muss man in der config des adapters noch etwas umstellen????
                Mit freundlichen Grüßen
                • V
                  Normal nicht, Probier mal beim User die letzten beiden Stellen auf FF zu ändern.
                  Gesendet von meinem iPhone mit Tapatalk
                  • fischi87
                    Er startet zwar neu aber er übernimmt das FF nicht?
                    Sagt dir das mehr?
                      Headroom68 last edited by
                      gleicher Fehler bei mir, wie bei fischi87.
                      Kein Fehler bei der Installation.
                      Konfiguration lässt sich nicht ändern und unter Eve wird keine Bridge gefunden.
                      netstat -a | grep 51826
                      tcp6 0 0 [::]:51826 [::]:* LISTEN
                      tcp6 0 66688 Server-Banana-Pi.:51826 iPad-Air.f:49242 ESTABLISHED
                      • V
                        Guten Morgen!
                        Das Config Thema kenn ich schon von occ, da habe ich das gleiche Problem.
                        Bitte ändert den Username direkt im Objekt:
                        Diesen Fehler muss ich mir genauer ansehen, bis dorthin sollte diese Lösung funktionieren.
                        • V
                          Hallo, Version 0.0.7 ist hochgeladen.
                          Die Parameter werden nun korrekt gespeichert.
                          Zusätzlich wird im Debug die Konfiguration ins Logfile geschrieben.
                          Ausserdem kann der Name angepasst werden. Dies sollte aber nur initial durchgeführt werden.
                          Sollte die Homekit Bridge in iOS nicht sichtbar sein, sollte der Username (MAC Adress Style) geändert werden.
                          • fischi87
                            Guten morgen, hab die 7er version drauf und bekomme jetzt diesen Fehler im log:
                              bei mir hat es geholfen den Adapter zu deinstallieren un neu zu installieren.
                              Die Konfiguration kann dann auch geändert werden und der Adapter / Instanz startet ohne Fehler.
                              In Eve wird die Bridge angezeigt. Allerdings schlägt dann das hinzufügen fehl (Verbindung mit Zubehör nicht möglich).
                              • V
                                Ich mach nachher ein paar Screenshots bez. Einrichtung, muss jetzt zur Taekwondo Weihnachtsfeier.
                                  pix last edited by
                                  Hallo versteckt,
                                  jetzt habe ich 0.0.7 fehlerfrei installalliert (alten Adapter vorher gelöscht). Beim Aktivieren der Instanz erscheint wieder der alte Fehler Error: Module version mismatch. Expected 46, got 47.
                                  2015-12-13 12:51:08.835 - info: host.MacMini-Ethernet.fritz.box object change system.adapter.homekit.0
                                  2015-12-13 12:51:15.981 - info: host.MacMini-Ethernet.fritz.box object change system.adapter.homekit.0
                                  2015-12-13 12:51:15.993 - info: host.MacMini-Ethernet.fritz.box instance system.adapter.homekit.0 started with pid 25812
                                  2015-12-13 12:51:16.595 - error: uncaught exception: Module version mismatch. Expected 46, got 47.
                                  2015-12-13 12:51:16.603 - error: Error: Module version mismatch. Expected 46, got 47.
                                  at Error (native)
                                  2015-12-13 12:51:16.664 - debug: homekit.0 objectDB connected
                                  2015-12-13 12:51:16.670 - debug: homekit.0 statesDB connected
                                  2015-12-13 12:51:16.827 - info: homekit.0 starting. Version 0.0.7 in /Users/pix/Documents/iobroker/node_modules/iobroker.homekit
                                  2015-12-13 12:51:16.830 - info: homekit.0 requesting all states
                                  2015-12-13 12:51:16.831 - info: homekit.0 requesting all objects
                                  2015-12-13 12:51:16.944 - error: host.MacMini-Ethernet.fritz.box instance system.adapter.homekit.0 terminated with code 6 (uncaught exception)
                                  2015-12-13 12:51:16.944 - info: host.MacMini-Ethernet.fritz.box Restart adapter system.adapter.homekit.0 because enabled</anonymous>
                                  Aber ich weiss nicht, welches Modul das falsche ist :roll:
                                  Gruß am Sonntag,
                                  Pix
                                  • V
                                    Wie besprochen hier mal die Fotostrecke mit meinem iPad:
                                    • V
                                      @Pix:
                                      Du müsstest vier verschiedene .node Dateien besitzen, welche bei der Installation kompiliert werden.
                                      Christians-Mac-mini:ioBroker.homekit christian$ pwd
                                      /Users/christian/DEVELOPMENT/node_modules/ioBroker.homekit
                                      Christians-Mac-mini:ioBroker.homekit christian$ find . -name *.node -ls
                                      8120828       48 -rwxr-xr-x    1 christian        staff               20924 Dec 12 18:18 ./node_modules/hap-nodejs/node_modules/curve25519/build/Release/curve.node
                                      8120718      184 -rwxr-xr-x    1 christian        staff               93460 Dec 12 18:17 ./node_modules/hap-nodejs/node_modules/ed25519/build/Release/ed25519.node
                                      8120810      208 -rwxr-xr-x    1 christian        staff              104624 Dec 12 18:18 ./node_modules/hap-nodejs/node_modules/mdns/build/Release/dns_sd_bindings.node
                                      8120574      144 -rwxr-xr-x    1 christian        staff               69832 Dec 12 18:17 ./node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/build/Release/bignum.node
                                        pix last edited by
                                        Hallo Christian, danke für die Mühe.@versteckt:
                                        @Pix:
                                        Du müsstest vier verschiedene .node Dateien besitzen, welche bei der Installation kompiliert werden. `
                                        Interessant, ich habe nur zwei
                                        pix$ find . -name *.node -ls
                                        37736714       48 -rwxr-xr-x    1 pix              staff               20932 13 Dez 12:46 ./node_modules/hap-nodejs/node_modules/curve25519/build/Release/curve.node
                                        37736857      184 -rwxr-xr-x    1 pix              staff               93508 13 Dez 12:46 ./node_modules/hap-nodejs/node_modules/ed25519/build/Release/ed25519.node
                                        MacMini-Ethernet:iobroker.homekit pix$
                                        wo kriege ich die denn her? Ich habe zwischenzeitlich nochmal installiert, aber keine Veränderung.
                                        Gruß,
                                        Pix
                                        • V
                                          Das finde ich spannend, ansich sollte das node Module hap-nodejs diese für dich kompilieren.
                                          Was passiert eigentlich wenn du folgendes ausführst?
                                          cd /tmp
                                          npm cache clean
                                          npm install hap-nodejs
                                          Dadurch wird dein NPM Cache ausgeleert und das zugrunde liegende Modul hap-nodejs in /tmp/node_modules/hap-nodejs
                                          installiert / kompiliert.
                                          Poste bitte mal diese Ausgabe.
                                          • fischi87
                                            bei mir läuft das Programm nun ihnen fehlen, werde es die tage testen und weiter berichten!!!
                                            top sache!!!!
                                            250
                                            52390
