    4. Test Adapter zoneminder v0.3.x
    • Meistertr
      Meistertr Developer @ErazorVIP last edited by
      @ErazorVIP zoneminder meldet user not found zurück also ist endwegder der user nicht da oder die api ist in den einstellungen von zoneminder nicht richtig eingestellt
      • Meistertr
        so die 0.3.3 ist online damit sollten Loginfehler von Adapterseite der Vergangenheit angehören.
        • coyote
          coyote Most Active @Meistertr last edited by coyote
          @Meistertr bekomme nach einer Weile leider immer noch den Websocket Error, hier das Log nach start:
          zoneminder.0	2019-11-12 06:37:53.345	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","NotRunning"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],[
          zoneminder.0	2019-11-12 06:37:53.344	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","NotRunning"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],[
          zoneminder.0	2019-11-12 06:37:53.342	debug	(1449) found states:_[["zoneminder.0.cam_4.monitor","Name","text","Monitor-4"],["zoneminder.0.cam_4.monitor","Function",null,"1"],["zoneminder.0.cam_4.monitor","Enabled",null,true],["zoneminder.0.cam_
          zoneminder.0	2019-11-12 06:37:53.341	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
          zoneminder.0	2019-11-12 06:37:53.332	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
          zoneminder.0	2019-11-12 06:37:53.330	debug	(1449) found states:_[["zoneminder.0.cam_3.monitor","Name","text","Haustuer"],["zoneminder.0.cam_3.monitor","Function",null,"2"],["zoneminder.0.cam_3.monitor","Enabled",null,true],["zoneminder.0.cam_3
          zoneminder.0	2019-11-12 06:37:53.329	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","16.67"],[
          zoneminder.0	2019-11-12 06:37:53.320	debug	(1449) found states:_[["zoneminder.0.cam_2.monitor","Name","text","Garten"],["zoneminder.0.cam_2.monitor","Function",null,"1"],["zoneminder.0.cam_2.monitor","Enabled",null,true],["zoneminder.0.cam_2.m
          zoneminder.0	2019-11-12 06:37:53.301	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","16.67"],[
          zoneminder.0	2019-11-12 06:37:53.284	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","16.67"],[
          zoneminder.0	2019-11-12 06:37:53.272	debug	(1449) found states:_[["zoneminder.0.cam_1.monitor","Name","text","Garage"],["zoneminder.0.cam_1.monitor","Function",null,"2"],["zoneminder.0.cam_1.monitor","Enabled",null,true],["zoneminder.0.cam_1.m
          zoneminder.0	2019-11-12 06:37:53.271	debug	(1449) REQUEST: Get data"{\n \"monitors\": [\n {\n \"Monitor\": {\n \"Id\": \"1\",\n \"Name\": \"Garage\",\n \"ServerId\": null,\n
          zoneminder.0	2019-11-12 06:37:53.220	debug	(1449) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json?&auth=11cda9fcd2470143abefbebc7d6ce7d2","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":t
          zoneminder.0	2019-11-12 06:37:53.220	debug	(1449) GET_
          zoneminder.0	2019-11-12 06:37:53.219	debug	(1449) SetStates
          zoneminder.0	2019-11-12 06:37:48.218	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","NotRunning"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],[
          zoneminder.0	2019-11-12 06:37:48.192	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","NotRunning"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],[
          zoneminder.0	2019-11-12 06:37:48.191	debug	(1449) found states:_[["zoneminder.0.cam_4.monitor","Name","text","Monitor-4"],["zoneminder.0.cam_4.monitor","Function",null,"1"],["zoneminder.0.cam_4.monitor","Enabled",null,true],["zoneminder.0.cam_
          zoneminder.0	2019-11-12 06:37:48.190	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
          zoneminder.0	2019-11-12 06:37:48.177	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
          zoneminder.0	2019-11-12 06:37:48.171	debug	(1449) found states:_[["zoneminder.0.cam_3.monitor","Name","text","Haustuer"],["zoneminder.0.cam_3.monitor","Function",null,"2"],["zoneminder.0.cam_3.monitor","Enabled",null,true],["zoneminder.0.cam_3
          zoneminder.0	2019-11-12 06:37:48.170	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","16.67"],[
          zoneminder.0	2019-11-12 06:37:48.169	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","16.67"],[
          zoneminder.0	2019-11-12 06:37:48.167	debug	(1449) found states:_[["zoneminder.0.cam_2.monitor","Name","text","Garten"],["zoneminder.0.cam_2.monitor","Function",null,"1"],["zoneminder.0.cam_2.monitor","Enabled",null,true],["zoneminder.0.cam_2.m
          zoneminder.0	2019-11-12 06:37:48.166	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","16.67"],[
          zoneminder.0	2019-11-12 06:37:48.165	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","16.67"],[
          zoneminder.0	2019-11-12 06:37:48.157	debug	(1449) found states:_[["zoneminder.0.cam_1.monitor","Name","text","Garage"],["zoneminder.0.cam_1.monitor","Function",null,"2"],["zoneminder.0.cam_1.monitor","Enabled",null,true],["zoneminder.0.cam_1.m
          zoneminder.0	2019-11-12 06:37:48.156	debug	(1449) REQUEST: Get data"{\n \"monitors\": [\n {\n \"Monitor\": {\n \"Id\": \"1\",\n \"Name\": \"Garage\",\n \"ServerId\": null,\n
          zoneminder.0	2019-11-12 06:37:48.142	debug	(1449) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json?&auth=11cda9fcd2470143abefbebc7d6ce7d2","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":t
          zoneminder.0	2019-11-12 06:37:48.142	debug	(1449) GET_
          zoneminder.0	2019-11-12 06:37:48.141	debug	(1449) SetStates
          zoneminder.0	2019-11-12 06:37:43.140	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","NotRunning"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],[
          zoneminder.0	2019-11-12 06:37:43.139	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","NotRunning"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],[
          zoneminder.0	2019-11-12 06:37:43.137	debug	(1449) found states:_[["zoneminder.0.cam_4.monitor","Name","text","Monitor-4"],["zoneminder.0.cam_4.monitor","Function",null,"1"],["zoneminder.0.cam_4.monitor","Enabled",null,true],["zoneminder.0.cam_
          zoneminder.0	2019-11-12 06:37:43.078	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
          zoneminder.0	2019-11-12 06:37:43.076	debug	(1449) found states:_[["zoneminder.0.cam_3.monitor","Name","text","Haustuer"],["zoneminder.0.cam_3.monitor","Function",null,"2"],["zoneminder.0.cam_3.monitor","Enabled",null,true],["zoneminder.0.cam_3
          zoneminder.0	2019-11-12 06:37:43.073	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","14.29"],[
          zoneminder.0	2019-11-12 06:37:43.051	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","14.29"],[
          zoneminder.0	2019-11-12 06:37:43.025	debug	(1449) found states:_[["zoneminder.0.cam_2.monitor","Name","text","Garten"],["zoneminder.0.cam_2.monitor","Function",null,"1"],["zoneminder.0.cam_2.monitor","Enabled",null,true],["zoneminder.0.cam_2.m
          zoneminder.0	2019-11-12 06:37:43.024	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","14.29"],[
          zoneminder.0	2019-11-12 06:37:43.022	debug	(1449) found states:_[["zoneminder.0.cam_1.monitor","Name","text","Garage"],["zoneminder.0.cam_1.monitor","Function",null,"2"],["zoneminder.0.cam_1.monitor","Enabled",null,true],["zoneminder.0.cam_1.m
          zoneminder.0	2019-11-12 06:37:43.017	debug	(1449) REQUEST: Get data"{\n \"monitors\": [\n {\n \"Monitor\": {\n \"Id\": \"1\",\n \"Name\": \"Garage\",\n \"ServerId\": null,\n
          zoneminder.0	2019-11-12 06:37:42.981	debug	(1449) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json?&auth=11cda9fcd2470143abefbebc7d6ce7d2","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":t
          zoneminder.0	2019-11-12 06:37:42.981	debug	(1449) GET_
          zoneminder.0	2019-11-12 06:37:42.980	debug	(1449) SetStates
          zoneminder.0	2019-11-12 06:37:37.973	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","Running"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],["zo
          zoneminder.0	2019-11-12 06:37:37.972	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","Running"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],["zo
          zoneminder.0	2019-11-12 06:37:37.955	debug	(1449) found states:_[["zoneminder.0.cam_4.monitor","Name","text","Monitor-4"],["zoneminder.0.cam_4.monitor","Function",null,"1"],["zoneminder.0.cam_4.monitor","Enabled",null,true],["zoneminder.0.cam_
          zoneminder.0	2019-11-12 06:37:37.951	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
          zoneminder.0	2019-11-12 06:37:37.950	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
          zoneminder.0	2019-11-12 06:37:37.944	debug	(1449) found states:_[["zoneminder.0.cam_3.monitor","Name","text","Haustuer"],["zoneminder.0.cam_3.monitor","Function",null,"2"],["zoneminder.0.cam_3.monitor","Enabled",null,true],["zoneminder.0.cam_3
          zoneminder.0	2019-11-12 06:37:37.943	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","14.29"],[
          zoneminder.0	2019-11-12 06:37:37.942	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","14.29"],[
          zoneminder.0	2019-11-12 06:37:37.913	debug	(1449) found states:_[["zoneminder.0.cam_2.monitor","Name","text","Garten"],["zoneminder.0.cam_2.monitor","Function",null,"1"],["zoneminder.0.cam_2.monitor","Enabled",null,true],["zoneminder.0.cam_2.m
          zoneminder.0	2019-11-12 06:37:37.913	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","14.29"],[
          zoneminder.0	2019-11-12 06:37:37.912	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","14.29"],[
          zoneminder.0	2019-11-12 06:37:37.904	debug	(1449) found states:_[["zoneminder.0.cam_1.monitor","Name","text","Garage"],["zoneminder.0.cam_1.monitor","Function",null,"2"],["zoneminder.0.cam_1.monitor","Enabled",null,true],["zoneminder.0.cam_1.m
          zoneminder.0	2019-11-12 06:37:37.903	debug	(1449) REQUEST: Get data"{\n \"monitors\": [\n {\n \"Monitor\": {\n \"Id\": \"1\",\n \"Name\": \"Garage\",\n \"ServerId\": null,\n
          zoneminder.0	2019-11-12 06:37:37.877	debug	(1449) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json?&auth=11cda9fcd2470143abefbebc7d6ce7d2","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":t
          zoneminder.0	2019-11-12 06:37:37.877	debug	(1449) GET_
          zoneminder.0	2019-11-12 06:37:37.876	debug	(1449) SetStates
          zoneminder.0	2019-11-12 06:37:32.861	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","Running"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],["zo
          zoneminder.0	2019-11-12 06:37:32.860	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","Running"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],["zo
          zoneminder.0	2019-11-12 06:37:32.854	debug	(1449) found states:_[["zoneminder.0.cam_4.monitor","Name","text","Monitor-4"],["zoneminder.0.cam_4.monitor","Function",null,"1"],["zoneminder.0.cam_4.monitor","Enabled",null,true],["zoneminder.0.cam_
          zoneminder.0	2019-11-12 06:37:32.853	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
          zoneminder.0	2019-11-12 06:37:32.849	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
          zoneminder.0	2019-11-12 06:37:32.836	debug	(1449) found states:_[["zoneminder.0.cam_3.monitor","Name","text","Haustuer"],["zoneminder.0.cam_3.monitor","Function",null,"2"],["zoneminder.0.cam_3.monitor","Enabled",null,true],["zoneminder.0.cam_3
          zoneminder.0	2019-11-12 06:37:32.835	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","16.67"],[
          zoneminder.0	2019-11-12 06:37:32.834	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","16.67"],[
          zoneminder.0	2019-11-12 06:37:32.832	debug	(1449) found states:_[["zoneminder.0.cam_2.monitor","Name","text","Garten"],["zoneminder.0.cam_2.monitor","Function",null,"1"],["zoneminder.0.cam_2.monitor","Enabled",null,true],["zoneminder.0.cam_2.m
          zoneminder.0	2019-11-12 06:37:32.831	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","16.67"],[
          zoneminder.0	2019-11-12 06:37:32.830	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","16.67"],[
          zoneminder.0	2019-11-12 06:37:32.822	debug	(1449) found states:_[["zoneminder.0.cam_1.monitor","Name","text","Garage"],["zoneminder.0.cam_1.monitor","Function",null,"2"],["zoneminder.0.cam_1.monitor","Enabled",null,true],["zoneminder.0.cam_1.m
          zoneminder.0	2019-11-12 06:37:32.821	debug	(1449) REQUEST: Get data"{\n \"monitors\": [\n {\n \"Monitor\": {\n \"Id\": \"1\",\n \"Name\": \"Garage\",\n \"ServerId\": null,\n
          zoneminder.0	2019-11-12 06:37:32.802	debug	(1449) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json?&auth=11cda9fcd2470143abefbebc7d6ce7d2","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":t
          zoneminder.0	2019-11-12 06:37:32.802	debug	(1449) GET_
          zoneminder.0	2019-11-12 06:37:32.801	debug	(1449) SetStates
          zoneminder.0	2019-11-12 06:37:27.799	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","NotRunning"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],[
          zoneminder.0	2019-11-12 06:37:27.797	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","NotRunning"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],[
          zoneminder.0	2019-11-12 06:37:27.775	debug	(1449) found states:_[["zoneminder.0.cam_4.monitor","Name","text","Monitor-4"],["zoneminder.0.cam_4.monitor","Function",null,"1"],["zoneminder.0.cam_4.monitor","Enabled",null,true],["zoneminder.0.cam_
          zoneminder.0	2019-11-12 06:37:27.773	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
          zoneminder.0	2019-11-12 06:37:27.772	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
          zoneminder.0	2019-11-12 06:37:27.769	debug	(1449) found states:_[["zoneminder.0.cam_3.monitor","Name","text","Haustuer"],["zoneminder.0.cam_3.monitor","Function",null,"2"],["zoneminder.0.cam_3.monitor","Enabled",null,true],["zoneminder.0.cam_3
          zoneminder.0	2019-11-12 06:37:27.763	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","16.67"],[
          zoneminder.0	2019-11-12 06:37:27.762	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","16.67"],[
          zoneminder.0	2019-11-12 06:37:27.760	debug	(1449) found states:_[["zoneminder.0.cam_2.monitor","Name","text","Garten"],["zoneminder.0.cam_2.monitor","Function",null,"1"],["zoneminder.0.cam_2.monitor","Enabled",null,true],["zoneminder.0.cam_2.m
          zoneminder.0	2019-11-12 06:37:27.759	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","16.67"],[
          zoneminder.0	2019-11-12 06:37:27.758	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","16.67"],[
          zoneminder.0	2019-11-12 06:37:27.754	debug	(1449) found states:_[["zoneminder.0.cam_1.monitor","Name","text","Garage"],["zoneminder.0.cam_1.monitor","Function",null,"2"],["zoneminder.0.cam_1.monitor","Enabled",null,true],["zoneminder.0.cam_1.m
          zoneminder.0	2019-11-12 06:37:27.753	debug	(1449) REQUEST: Get data"{\n \"monitors\": [\n {\n \"Monitor\": {\n \"Id\": \"1\",\n \"Name\": \"Garage\",\n \"ServerId\": null,\n
          zoneminder.0	2019-11-12 06:37:27.716	debug	(1449) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json?&auth=11cda9fcd2470143abefbebc7d6ce7d2","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":t
          zoneminder.0	2019-11-12 06:37:27.716	debug	(1449) GET_
          zoneminder.0	2019-11-12 06:37:27.715	debug	(1449) SetStates
          zoneminder.0	2019-11-12 06:37:22.714	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","NotRunning"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],[
          zoneminder.0	2019-11-12 06:37:22.711	debug	(1449) found states:_[["zoneminder.0.cam_4.monitor","Name","text","Monitor-4"],["zoneminder.0.cam_4.monitor","Function",null,"1"],["zoneminder.0.cam_4.monitor","Enabled",null,true],["zoneminder.0.cam_
          zoneminder.0	2019-11-12 06:37:22.710	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
          zoneminder.0	2019-11-12 06:37:22.703	debug	(1449) found states:_[["zoneminder.0.cam_3.monitor","Name","text","Haustuer"],["zoneminder.0.cam_3.monitor","Function",null,"2"],["zoneminder.0.cam_3.monitor","Enabled",null,true],["zoneminder.0.cam_3
          zoneminder.0	2019-11-12 06:37:22.702	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","14.29"],[
          zoneminder.0	2019-11-12 06:37:22.700	debug	(1449) found states:_[["zoneminder.0.cam_2.monitor","Name","text","Garten"],["zoneminder.0.cam_2.monitor","Function",null,"1"],["zoneminder.0.cam_2.monitor","Enabled",null,true],["zoneminder.0.cam_2.m
          zoneminder.0	2019-11-12 06:37:22.699	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","14.29"],[
          zoneminder.0	2019-11-12 06:37:22.692	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","14.29"],[
          zoneminder.0	2019-11-12 06:37:22.689	debug	(1449) found states:_[["zoneminder.0.cam_1.monitor","Name","text","Garage"],["zoneminder.0.cam_1.monitor","Function",null,"2"],["zoneminder.0.cam_1.monitor","Enabled",null,true],["zoneminder.0.cam_1.m
          zoneminder.0	2019-11-12 06:37:22.684	debug	(1449) REQUEST: Get data"{\n \"monitors\": [\n {\n \"Monitor\": {\n \"Id\": \"1\",\n \"Name\": \"Garage\",\n \"ServerId\": null,\n
          zoneminder.0	2019-11-12 06:37:22.660	debug	(1449) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json?&auth=11cda9fcd2470143abefbebc7d6ce7d2","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":t
          zoneminder.0	2019-11-12 06:37:22.659	debug	(1449) GET_
          zoneminder.0	2019-11-12 06:37:22.659	debug	(1449) SetStates
          zoneminder.0	2019-11-12 06:37:17.656	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","Running"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],["zo
          zoneminder.0	2019-11-12 06:37:17.655	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","Running"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],["zo
          zoneminder.0	2019-11-12 06:37:17.652	debug	(1449) found states:_[["zoneminder.0.cam_4.monitor","Name","text","Monitor-4"],["zoneminder.0.cam_4.monitor","Function",null,"1"],["zoneminder.0.cam_4.monitor","Enabled",null,true],["zoneminder.0.cam_
          zoneminder.0	2019-11-12 06:37:17.650	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
          zoneminder.0	2019-11-12 06:37:17.617	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
          zoneminder.0	2019-11-12 06:37:17.614	debug	(1449) found states:_[["zoneminder.0.cam_3.monitor","Name","text","Haustuer"],["zoneminder.0.cam_3.monitor","Function",null,"2"],["zoneminder.0.cam_3.monitor","Enabled",null,true],["zoneminder.0.cam_3
          zoneminder.0	2019-11-12 06:37:17.608	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","14.29"],[
          zoneminder.0	2019-11-12 06:37:17.607	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","14.29"],[
          zoneminder.0	2019-11-12 06:37:17.599	debug	(1449) found states:_[["zoneminder.0.cam_2.monitor","Name","text","Garten"],["zoneminder.0.cam_2.monitor","Function",null,"1"],["zoneminder.0.cam_2.monitor","Enabled",null,true],["zoneminder.0.cam_2.m
          zoneminder.0	2019-11-12 06:37:17.586	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","14.29"],[
          zoneminder.0	2019-11-12 06:37:17.585	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","14.29"],[
          zoneminder.0	2019-11-12 06:37:17.568	debug	(1449) found states:_[["zoneminder.0.cam_1.monitor","Name","text","Garage"],["zoneminder.0.cam_1.monitor","Function",null,"2"],["zoneminder.0.cam_1.monitor","Enabled",null,true],["zoneminder.0.cam_1.m
          zoneminder.0	2019-11-12 06:37:17.559	debug	(1449) REQUEST: Get data"{\n \"monitors\": [\n {\n \"Monitor\": {\n \"Id\": \"1\",\n \"Name\": \"Garage\",\n \"ServerId\": null,\n
          zoneminder.0	2019-11-12 06:37:17.530	debug	(1449) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json?&auth=11cda9fcd2470143abefbebc7d6ce7d2","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":t
          zoneminder.0	2019-11-12 06:37:17.530	debug	(1449) GET_
          zoneminder.0	2019-11-12 06:37:17.530	debug	(1449) SetStates
          zoneminder.0	2019-11-12 06:37:13.555	debug	(1449) FOUND in listzoneminder.0.cam_4
          zoneminder.0	2019-11-12 06:37:13.555	debug	(1449) FOUND in listzoneminder.0.cam_2
          zoneminder.0	2019-11-12 06:37:13.555	debug	(1449) FOUND in listzoneminder.0.cam_3
          zoneminder.0	2019-11-12 06:37:13.555	debug	(1449) FOUND in listzoneminder.0.cam_1
          zoneminder.0	2019-11-12 06:37:13.554	debug	(1449) CAM_ids: ["zoneminder.0.cam_1","zoneminder.0.cam_2","zoneminder.0.cam_3","zoneminder.0.cam_4"]
          zoneminder.0	2019-11-12 06:37:13.543	debug	(1449) found states:_[["zoneminder.0.cam_4.zmEvent","MonitorId","default_num","0"],["zoneminder.0.cam_4.zmEvent","EventId","default_num","000"],["zoneminder.0.cam_4.zmEvent","Name","text","INIT"],["zo
          zoneminder.0	2019-11-12 06:37:13.468	debug	(1449) found states:_[["zoneminder.0.cam_4.monitor","Name","text","Monitor-4"],["zoneminder.0.cam_4.monitor","Function",null,"1"],["zoneminder.0.cam_4.monitor","Enabled",null,true],["zoneminder.0.cam_
          zoneminder.0	2019-11-12 06:37:13.465	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","Running"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],["zo
          zoneminder.0	2019-11-12 06:37:13.465	debug	(1449) Monitor_3 o.Monitor_Status = [object Object]
          zoneminder.0	2019-11-12 06:37:13.465	debug	(1449) Monitor_3 o.Monitor = [object Object]
          zoneminder.0	2019-11-12 06:37:13.464	debug	(1449) monitor found in Objects
          zoneminder.0	2019-11-12 06:37:13.440	debug	(1449) found states:_[["zoneminder.0.cam_3.zmEvent","MonitorId","default_num","0"],["zoneminder.0.cam_3.zmEvent","EventId","default_num","000"],["zoneminder.0.cam_3.zmEvent","Name","text","INIT"],["zo
          zoneminder.0	2019-11-12 06:37:13.431	debug	(1449) found states:_[["zoneminder.0.cam_3.monitor","Name","text","Haustuer"],["zoneminder.0.cam_3.monitor","Function",null,"2"],["zoneminder.0.cam_3.monitor","Enabled",null,true],["zoneminder.0.cam_3
          zoneminder.0	2019-11-12 06:37:13.429	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
          zoneminder.0	2019-11-12 06:37:13.428	debug	(1449) Monitor_2 o.Monitor_Status = [object Object]
          zoneminder.0	2019-11-12 06:37:13.428	debug	(1449) Monitor_2 o.Monitor = [object Object]
          zoneminder.0	2019-11-12 06:37:13.427	debug	(1449) monitor found in Objects
          zoneminder.0	2019-11-12 06:37:13.426	debug	(1449) found states:_[["zoneminder.0.cam_2.zmEvent","MonitorId","default_num","0"],["zoneminder.0.cam_2.zmEvent","EventId","default_num","000"],["zoneminder.0.cam_2.zmEvent","Name","text","INIT"],["zo
          zoneminder.0	2019-11-12 06:37:13.413	debug	(1449) found states:_[["zoneminder.0.cam_2.monitor","Name","text","Garten"],["zoneminder.0.cam_2.monitor","Function",null,"1"],["zoneminder.0.cam_2.monitor","Enabled",null,true],["zoneminder.0.cam_2.m
          zoneminder.0	2019-11-12 06:37:13.412	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","16.67"],[
          zoneminder.0	2019-11-12 06:37:13.411	debug	(1449) Monitor_1 o.Monitor_Status = [object Object]
          zoneminder.0	2019-11-12 06:37:13.410	debug	(1449) Monitor_1 o.Monitor = [object Object]
          zoneminder.0	2019-11-12 06:37:13.409	debug	(1449) monitor found in Objects
          zoneminder.0	2019-11-12 06:37:13.399	debug	(1449) found states:_[["zoneminder.0.cam_1.zmEvent","MonitorId","default_num","0"],["zoneminder.0.cam_1.zmEvent","EventId","default_num","000"],["zoneminder.0.cam_1.zmEvent","Name","text","INIT"],["zo
          zoneminder.0	2019-11-12 06:37:13.383	debug	(1449) found states:_[["zoneminder.0.cam_1.monitor","Name","text","Garage"],["zoneminder.0.cam_1.monitor","Function",null,"2"],["zoneminder.0.cam_1.monitor","Enabled",null,true],["zoneminder.0.cam_1.m
          zoneminder.0	2019-11-12 06:37:13.362	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","16.67"],[
          zoneminder.0	2019-11-12 06:37:13.361	debug	(1449) Monitor_0 o.Monitor_Status = [object Object]
          zoneminder.0	2019-11-12 06:37:13.361	debug	(1449) Monitor_0 o.Monitor = [object Object]
          zoneminder.0	2019-11-12 06:37:13.348	debug	(1449) monitor found in Objects
          zoneminder.0	2019-11-12 06:37:12.921	debug	(1449) REQUEST: Get data"{\n \"monitors\": [\n {\n \"Monitor\": {\n \"Id\": \"1\",\n \"Name\": \"Garage\",\n \"ServerId\": null,\n
          zoneminder.0	2019-11-12 06:37:12.891	debug	(1449) found states:_[["zoneminder.0.history.LastzmEvent","MonitorId","default_num","0"],["zoneminder.0.history.LastzmEvent","EventId","default_num","000"],["zoneminder.0.history.LastzmEvent","Name","
          zoneminder.0	2019-11-12 06:37:12.889	debug	(1449) [{"Monitor":{"Id":"1","Name":"Garage","ServerId":null,"StorageId":"1","Type":"Ffmpeg","Function":"Modect","Enabled":"1","LinkedMonitors":null,"Triggers":"","Device":"/dev/video0","Channel":"0",
          zoneminder.0	2019-11-12 06:37:12.882	debug	(1449) REQUEST: Get data"{\n \"monitors\": [\n {\n \"Monitor\": {\n \"Id\": \"1\",\n \"Name\": \"Garage\",\n \"ServerId\": null,\n
          zoneminder.0	2019-11-12 06:37:12.642	debug	(1449) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json?&auth=11cda9fcd2470143abefbebc7d6ce7d2","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":t
          zoneminder.0	2019-11-12 06:37:12.641	debug	(1449) GET_
          zoneminder.0	2019-11-12 06:37:12.631	debug	(1449) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json?&auth=11cda9fcd2470143abefbebc7d6ce7d2","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":t
          zoneminder.0	2019-11-12 06:37:12.630	debug	(1449) GET_
          zoneminder.0	2019-11-12 06:37:12.629	debug	(1449) Connected to Api
          zoneminder.0	2019-11-12 06:37:12.612	debug	(1449) AUTH: get authkey auth=11cda9fcd2470143abefbebc7d6ce7d2
          zoneminder.0	2019-11-12 06:37:12.612	debug	(1449) AUTH: json Message {"credentials":"auth=11cda9fcd2470143abefbebc7d6ce7d2","append_password":0,"version":"1.32.3","apiversion":"1.0"}
          zoneminder.0	2019-11-12 06:37:12.611	debug	(1449) REQUEST: Get data"{\n \"credentials\": \"auth=11cda9fcd2470143abefbebc7d6ce7d2\",\n \"append_password\": 0,\n \"version\": \"1.32.3\",\n \"apiversion\": \"1.0\"\n}"
          zoneminder.0	2019-11-12 06:37:12.454	debug	(1449) REQUEST: Options {"method":"POST","uri":"http://192.168.66.184/zm/api/host/login.json","body":"user=admin&pass=admin","headers":{"content-type":"application/x-www-form-urlencoded","content-leng
          zoneminder.0	2019-11-12 06:37:12.437	debug	(1449) GET_
          zoneminder.0	2019-11-12 06:37:12.436	debug	(1449) data: {"user":"admin","password":"admin","host":"http://192.168.66.184/zm","zmEvent":true}
          zoneminder.0	2019-11-12 06:37:12.360	info	(1449) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.zoneminder, node: v10.17.0
          zoneminder.0	2019-11-12 06:37:06.528	info	(1223) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          zoneminder.0	2019-11-12 06:37:06.526	info	(1223) terminating
          und hier dann nach einer Weile wieder den Error mit drin, das hat sich die Nacht so weit hochgeschaukelt, dass das komplette Log fast nur noch aus dem Error bestand:
          zoneminder.0	2019-11-12 06:39:39.941	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","Running"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],["zo
          zoneminder.0	2019-11-12 06:39:39.940	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","Running"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],["zo
          zoneminder.0	2019-11-12 06:39:39.939	debug	(1449) found states:_[["zoneminder.0.cam_4.monitor","Name","text","Monitor-4"],["zoneminder.0.cam_4.monitor","Function",null,"1"],["zoneminder.0.cam_4.monitor","Enabled",null,true],["zoneminder.0.cam_
          zoneminder.0	2019-11-12 06:39:39.938	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","9.09"],["
          zoneminder.0	2019-11-12 06:39:39.936	debug	(1449) found states:_[["zoneminder.0.cam_3.monitor","Name","text","Haustuer"],["zoneminder.0.cam_3.monitor","Function",null,"2"],["zoneminder.0.cam_3.monitor","Enabled",null,true],["zoneminder.0.cam_3
          zoneminder.0	2019-11-12 06:39:39.932	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","16.67"],[
          zoneminder.0	2019-11-12 06:39:39.931	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","16.67"],[
          zoneminder.0	2019-11-12 06:39:39.930	debug	(1449) found states:_[["zoneminder.0.cam_2.monitor","Name","text","Garten"],["zoneminder.0.cam_2.monitor","Function",null,"1"],["zoneminder.0.cam_2.monitor","Enabled",null,true],["zoneminder.0.cam_2.m
          zoneminder.0	2019-11-12 06:39:39.930	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","14.29"],[
          zoneminder.0	2019-11-12 06:39:39.929	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","14.29"],[
          zoneminder.0	2019-11-12 06:39:39.923	debug	(1449) found states:_[["zoneminder.0.cam_1.monitor","Name","text","Garage"],["zoneminder.0.cam_1.monitor","Function",null,"2"],["zoneminder.0.cam_1.monitor","Enabled",null,true],["zoneminder.0.cam_1.m
          zoneminder.0	2019-11-12 06:39:39.922	debug	(1449) REQUEST: Get data"{\n \"monitors\": [\n {\n \"Monitor\": {\n \"Id\": \"1\",\n \"Name\": \"Garage\",\n \"ServerId\": null,\n
          zoneminder.0	2019-11-12 06:39:39.869	debug	(1449) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json?&auth=11cda9fcd2470143abefbebc7d6ce7d2","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":t
          zoneminder.0	2019-11-12 06:39:39.868	debug	(1449) GET_
          zoneminder.0	2019-11-12 06:39:39.868	debug	(1449) SetStates
          zoneminder.0	2019-11-12 06:39:34.867	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","NotRunning"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],[
          zoneminder.0	2019-11-12 06:39:34.866	debug	(1449) found states:_[["zoneminder.0.cam_4.monitor","Name","text","Monitor-4"],["zoneminder.0.cam_4.monitor","Function",null,"1"],["zoneminder.0.cam_4.monitor","Enabled",null,true],["zoneminder.0.cam_
          zoneminder.0	2019-11-12 06:39:34.865	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","9.09"],["
          zoneminder.0	2019-11-12 06:39:34.864	debug	(1449) found states:_[["zoneminder.0.cam_3.monitor","Name","text","Haustuer"],["zoneminder.0.cam_3.monitor","Function",null,"2"],["zoneminder.0.cam_3.monitor","Enabled",null,true],["zoneminder.0.cam_3
          zoneminder.0	2019-11-12 06:39:34.863	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","16.67"],[
          zoneminder.0	2019-11-12 06:39:34.861	debug	(1449) found states:_[["zoneminder.0.cam_2.monitor","Name","text","Garten"],["zoneminder.0.cam_2.monitor","Function",null,"1"],["zoneminder.0.cam_2.monitor","Enabled",null,true],["zoneminder.0.cam_2.m
          zoneminder.0	2019-11-12 06:39:34.860	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","14.29"],[
          zoneminder.0	2019-11-12 06:39:34.859	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","14.29"],[
          zoneminder.0	2019-11-12 06:39:34.858	debug	(1449) found states:_[["zoneminder.0.cam_1.monitor","Name","text","Garage"],["zoneminder.0.cam_1.monitor","Function",null,"2"],["zoneminder.0.cam_1.monitor","Enabled",null,true],["zoneminder.0.cam_1.m
          zoneminder.0	2019-11-12 06:39:34.857	debug	(1449) REQUEST: Get data"{\n \"monitors\": [\n {\n \"Monitor\": {\n \"Id\": \"1\",\n \"Name\": \"Garage\",\n \"ServerId\": null,\n
          zoneminder.0	2019-11-12 06:39:34.808	debug	(1449) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json?&auth=11cda9fcd2470143abefbebc7d6ce7d2","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":t
          zoneminder.0	2019-11-12 06:39:34.808	debug	(1449) GET_
          zoneminder.0	2019-11-12 06:39:34.805	debug	(1449) SetStates
          zoneminder.0	2019-11-12 06:39:29.796	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","Running"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],["zo
          zoneminder.0	2019-11-12 06:39:29.751	debug	(1449) found states:_[["zoneminder.0.cam_4.monitor","Name","text","Monitor-4"],["zoneminder.0.cam_4.monitor","Function",null,"1"],["zoneminder.0.cam_4.monitor","Enabled",null,true],["zoneminder.0.cam_
          zoneminder.0	2019-11-12 06:39:29.750	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
          zoneminder.0	2019-11-12 06:39:29.748	debug	(1449) found states:_[["zoneminder.0.cam_3.monitor","Name","text","Haustuer"],["zoneminder.0.cam_3.monitor","Function",null,"2"],["zoneminder.0.cam_3.monitor","Enabled",null,true],["zoneminder.0.cam_3
          zoneminder.0	2019-11-12 06:39:29.747	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","14.29"],[
          zoneminder.0	2019-11-12 06:39:29.739	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","14.29"],[
          zoneminder.0	2019-11-12 06:39:29.736	debug	(1449) found states:_[["zoneminder.0.cam_2.monitor","Name","text","Garten"],["zoneminder.0.cam_2.monitor","Function",null,"1"],["zoneminder.0.cam_2.monitor","Enabled",null,true],["zoneminder.0.cam_2.m
          zoneminder.0	2019-11-12 06:39:29.736	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","16.67"],[
          zoneminder.0	2019-11-12 06:39:29.735	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","16.67"],[
          zoneminder.0	2019-11-12 06:39:29.733	debug	(1449) found states:_[["zoneminder.0.cam_1.monitor","Name","text","Garage"],["zoneminder.0.cam_1.monitor","Function",null,"2"],["zoneminder.0.cam_1.monitor","Enabled",null,true],["zoneminder.0.cam_1.m
          zoneminder.0	2019-11-12 06:39:29.731	debug	(1449) REQUEST: Get data"{\n \"monitors\": [\n {\n \"Monitor\": {\n \"Id\": \"1\",\n \"Name\": \"Garage\",\n \"ServerId\": null,\n
          zoneminder.0	2019-11-12 06:39:29.711	debug	(1449) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json?&auth=11cda9fcd2470143abefbebc7d6ce7d2","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":t
          zoneminder.0	2019-11-12 06:39:29.711	debug	(1449) GET_
          zoneminder.0	2019-11-12 06:39:29.710	debug	(1449) SetStates
          zoneminder.0	2019-11-12 06:39:24.707	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","NotRunning"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],[
          zoneminder.0	2019-11-12 06:39:24.706	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","NotRunning"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],[
          zoneminder.0	2019-11-12 06:39:24.703	debug	(1449) found states:_[["zoneminder.0.cam_4.monitor","Name","text","Monitor-4"],["zoneminder.0.cam_4.monitor","Function",null,"1"],["zoneminder.0.cam_4.monitor","Enabled",null,true],["zoneminder.0.cam_
          zoneminder.0	2019-11-12 06:39:24.699	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
          zoneminder.0	2019-11-12 06:39:24.698	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
          zoneminder.0	2019-11-12 06:39:24.697	debug	(1449) found states:_[["zoneminder.0.cam_3.monitor","Name","text","Haustuer"],["zoneminder.0.cam_3.monitor","Function",null,"2"],["zoneminder.0.cam_3.monitor","Enabled",null,true],["zoneminder.0.cam_3
          zoneminder.0	2019-11-12 06:39:24.696	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","14.29"],[
          zoneminder.0	2019-11-12 06:39:24.695	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","14.29"],[
          zoneminder.0	2019-11-12 06:39:24.693	debug	(1449) found states:_[["zoneminder.0.cam_2.monitor","Name","text","Garten"],["zoneminder.0.cam_2.monitor","Function",null,"1"],["zoneminder.0.cam_2.monitor","Enabled",null,true],["zoneminder.0.cam_2.m
          zoneminder.0	2019-11-12 06:39:24.692	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","14.29"],[
          zoneminder.0	2019-11-12 06:39:24.691	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","14.29"],[
          zoneminder.0	2019-11-12 06:39:24.690	debug	(1449) found states:_[["zoneminder.0.cam_1.monitor","Name","text","Garage"],["zoneminder.0.cam_1.monitor","Function",null,"2"],["zoneminder.0.cam_1.monitor","Enabled",null,true],["zoneminder.0.cam_1.m
          zoneminder.0	2019-11-12 06:39:24.688	debug	(1449) REQUEST: Get data"{\n \"monitors\": [\n {\n \"Monitor\": {\n \"Id\": \"1\",\n \"Name\": \"Garage\",\n \"ServerId\": null,\n
          zoneminder.0	2019-11-12 06:39:24.658	debug	(1449) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json?&auth=11cda9fcd2470143abefbebc7d6ce7d2","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":t
          zoneminder.0	2019-11-12 06:39:24.658	debug	(1449) GET_
          zoneminder.0	2019-11-12 06:39:24.657	debug	(1449) SetStates
          zoneminder.0	2019-11-12 06:39:22.229	error	(1449) WEBSOCKET: Error: client: 192.168.66.184 Message: Error: connect ETIMEDOUT 192.168.66.184:9000
          zoneminder.0	2019-11-12 06:39:19.657	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","Running"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],["zo
          zoneminder.0	2019-11-12 06:39:19.651	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","Running"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],["zo
          zoneminder.0	2019-11-12 06:39:19.650	debug	(1449) found states:_[["zoneminder.0.cam_4.monitor","Name","text","Monitor-4"],["zoneminder.0.cam_4.monitor","Function",null,"1"],["zoneminder.0.cam_4.monitor","Enabled",null,true],["zoneminder.0.cam_
          zoneminder.0	2019-11-12 06:39:19.648	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
          zoneminder.0	2019-11-12 06:39:19.647	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
          zoneminder.0	2019-11-12 06:39:19.646	debug	(1449) found states:_[["zoneminder.0.cam_3.monitor","Name","text","Haustuer"],["zoneminder.0.cam_3.monitor","Function",null,"2"],["zoneminder.0.cam_3.monitor","Enabled",null,true],["zoneminder.0.cam_3
          zoneminder.0	2019-11-12 06:39:19.603	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","16.67"],[
          zoneminder.0	2019-11-12 06:39:19.602	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","16.67"],[
          zoneminder.0	2019-11-12 06:39:19.599	debug	(1449) found states:_[["zoneminder.0.cam_2.monitor","Name","text","Garten"],["zoneminder.0.cam_2.monitor","Function",null,"1"],["zoneminder.0.cam_2.monitor","Enabled",null,true],["zoneminder.0.cam_2.m
          zoneminder.0	2019-11-12 06:39:19.597	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","14.29"],[
          zoneminder.0	2019-11-12 06:39:19.596	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","14.29"],[
          zoneminder.0	2019-11-12 06:39:19.595	debug	(1449) found states:_[["zoneminder.0.cam_1.monitor","Name","text","Garage"],["zoneminder.0.cam_1.monitor","Function",null,"2"],["zoneminder.0.cam_1.monitor","Enabled",null,true],["zoneminder.0.cam_1.m
          zoneminder.0	2019-11-12 06:39:19.594	debug	(1449) REQUEST: Get data"{\n \"monitors\": [\n {\n \"Monitor\": {\n \"Id\": \"1\",\n \"Name\": \"Garage\",\n \"ServerId\": null,\n
          zoneminder.0	2019-11-12 06:39:19.579	debug	(1449) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json?&auth=11cda9fcd2470143abefbebc7d6ce7d2","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":t
          zoneminder.0	2019-11-12 06:39:19.578	debug	(1449) GET_
          zoneminder.0	2019-11-12 06:39:19.577	debug	(1449) SetStates
          So sah es heute Nacht aus und das ist nur ein Bruchteil davon:
          2019-11-12 00:00:51.826  - error: zoneminder.0 (16978) WEBSOCKET: Error: client: 192.168.66.184 Message: Error: connect ETIMEDOUT 192.168.66.184:9000
          2019-11-12 00:00:51.828  - error: zoneminder.0 (16978) WEBSOCKET: Error: client: 192.168.66.184 Message: Error: connect ETIMEDOUT 192.168.66.184:9000
          2019-11-12 00:00:51.829  - error: zoneminder.0 (16978) WEBSOCKET: Error: client: 192.168.66.184 Message: Error: connect ETIMEDOUT 192.168.66.184:9000
          2019-11-12 00:00:51.830  - error: zoneminder.0 (16978) WEBSOCKET: Error: client: 192.168.66.184 Message: Error: connect ETIMEDOUT 192.168.66.184:9000
          2019-11-12 00:00:51.831  - error: zoneminder.0 (16978) WEBSOCKET: Error: client: 192.168.66.184 Message: Error: connect ETIMEDOUT 192.168.66.184:9000
          2019-11-12 00:00:51.833  - error: zoneminder.0 (16978) WEBSOCKET: Error: client: 192.168.66.184 Message: Error: connect ETIMEDOUT 192.168.66.184:9000
          2019-11-12 00:00:51.834  - error: zoneminder.0 (16978) WEBSOCKET: Error: client: 192.168.66.184 Message: Error: connect ETIMEDOUT 192.168.66.184:9000
          2019-11-12 00:00:51.843  - error: zoneminder.0 (16978) WEBSOCKET: Error: client: 192.168.66.184 Message: Error: connect ETIMEDOUT 192.168.66.184:9000
          2019-11-12 00:00:51.844  - error: zoneminder.0 (16978) WEBSOCKET: Error: client: 192.168.66.184 Message: Error: connect ETIMEDOUT 192.168.66.184:9000
            mikiline last edited by mikiline
            Kann ich momentan nicht bestätigen. Hab den Adapter heute morgen nach der Meldung von Meistert installiert und seitdem keine Fehlermeldung bekommen.
            Einzig das der lastZMevent wieder auf INIT steht, obwohl alarm vorhanden war. ich habe jedoch den adapter nicht neu gestartet
            Meistertr 1 Reply Last reply Reply Quote 0
            • Meistertr
              Meistertr Developer @mikiline last edited by
              @mikiline ja das mit dem init is mir gerade aufgefallen und wird gefixed
                Websocketmeldungen erscheinen wieder. Und es bringt mir meinen Zoneminder Server durcheinander. Webcam bleibt dann "rot". Scheint etwas mit den Alarmen zu tun zu haben.
                Nach Restart Adapter und ZM geht es wieder
                  wäre es dir möglich bitte noch dies einzubinden
                  curl -XGET  http://server/zm/api/states.json # returns list of run states
                  curl -XPOST  http://server/zm/api/states/change/restart.json #restarts ZM
                  curl -XPOST  http://server/zm/api/states/change/stop.json #Stops ZM
                  curl -XPOST  http://server/zm/api/states/change/start.json #Starts ZM
                  • Meistertr
                    @mikiline wenn mal ein Websocket error auftritt ist das nicht so tragisch. da der adapter sich dann ein paar Sekunden später neu verbindet. schwierig wird es wenn in einer Sekunde 10 oder mehr websocket errors aufreten. Das init problem sollte nun behoben sein.
                    • coyote
                      @Meistertr genau so ist es ja bei mir mit den websocket Errors. Das schaukelt sich immer weiter auf. Aber woran liegt das eigentlich? Bei 2-3 Versionen vorher war das ja noch nicht
                      • Xsev
                        Xsev @Meistertr last edited by Xsev
                        @Meistertr
                        Vielleicht kannst du mir helfen. Ich verwende die Adapter Verison 0.3.3. und ZM 1.32.3.
                        Ich hab seit längerem immer wieder Performance Probleme wenn der Adapter läuft.
                        Anbei ein Screenshot wie das ganze aussieht. Ab dem Moment wenn ich den Adapter Starte steigt stündlich (auf die Minute genau) die CPU Last. Dies geht soweit das mein Broker dann jede Stunde für ca 2 Minuten völlig aus dem Ruder läuft, Vis etc. dann kurzzeitig hängt.
                        Kannst du damit vielleicht was anfangen?
                          @Meistertr
                          Hi, Machst Du noch etwas am Adapter? Falls ja, könntest Du bitte die Tokenaktualisierung auch in dem EventURL aktualisieren?
                          Problem ist, das wenn der Adapter neu startet, der Token bei der MonitorURL aktualisiert wird, jedoch bei der EventURL nicht.
                          Danke und Grüsse
                            djsirius last edited by
                            @Meistertr
                            Ich würde mich auch freuen, wenn es mit dem Adapter weiter gehen würde! 👍
                            • Meistertr
                              Zur Zeit stockt es etwas da ich von zoneminder momentan nicht so begeistert bin und die api sich in den letzten. Versionen stark geeandert hat und eine große Änderung noch bevorsteht.. Aber weiter machen will ich auf jeden Fall noch
                                mikiline @Meistertr last edited by
                                @Meistertr sagte in Test Adapter zoneminder v0.3.x:
                                Darf ich fragen mit was du nicht mehr so begeistert bist? Hast Du Probleme mit Zoneminder?
                                • coyote
                                  coyote Most Active last edited by
                                  Das würde mich auch interessieren. Ich habe letzte Woche zoneminder nochmal komplett neu aufgesetzt und endlich auch die Objekterkennung am laufen, jedoch muss ich momentan sagen, dass die Erkennung irgendwie recht langsam ist.
                                  Ich habe nebenbei noch tinycam Monitor auf einen Android Tablet laufen und schicke über simple API einen request sobald eine Erkennung da ist. Das ist locker mindestens 5 Sekunden schneller als zoneminder.
                                  Zoneminder bekomme ich einfach momentan nicht gescheit eingestellt.
                                  Mit der einen Cam geht die Personenerkennung, mit der anderen erkennt er keine Person, aber Auto funktioniert leider weiß ich nicht wirklich wieso
                                  • Meistertr
                                    ich habe zoneminder in einem Container auf proxmox am laufen, glaube da ist auch das Problem , da meine Grafikkarte aus meinem sehr potenten nuc nicht durchgereicht wird. Die Folge ist teilweise sehr hohe CPU last. ich habe ums haus relolink Kameras mit 5mpx die bekomme ich nicht über den rstp steam eingebunden sondern nur über ffmpeg und das auch nur mit einer sehr geringen VGA Auflösung da sonst das Problem mit der hohen CPU last auftritt (nuc i5 mit 3 kernen für zoneminder bekomme ich bis zu 100% Auslastung).
                                    Desweiteren nervt der Event Manager der teilweise zu langsam reagiert. Teilweise habe ich bis zu 5 Sekunden Verzögerung gemessen. das ist mir viel zu langsam. Außerdem lößt er teilweise gar nicht aus.
                                    Dazu kommt bei hoher Auflösung eine Latenzzeit von 15 Sekunden was nahezu untragbar für mich ist (wahrscheinlich auch der fehlenden Grafikkarte geschuldet)
                                    Dann noch das api Problem, in den letzten 3 Versionen sind 3 Verschiedene Apis mit der Ankündigung ein er neuen verbesserten api... da ich im adapter nicht 4 verschiedene Fälle abfangen will warte hier noch etwas ab
                                    Johannes Bauerstatter coyote M 3 Replies Last reply Reply Quote 0
                                    • Johannes Bauerstatter
                                      Johannes Bauerstatter @Meistertr last edited by
                                      @Meistertr Hallo ich hab auf meinem NUC Motioneye für die Snapshot URL´s und Kerberos für die Bewegungserkennung und Bildaufzeichnung. Meiner Meinung nach viel einfacher zu bedienen als Zoneminder. Leider braucht man in Kerberos für jede Kamera einen eigenen Container.
                                      • coyote
                                        @Meistertr OK, dann deckt sich das ja ziemlich mit meiner Erfahrung. Auch im Container auf einem i3 Nuc.
                                        Objekterkennung ist bei mir auch viel zu langsam, wie ich schon geschrieben habe, locker 5 Sekunden zu spät.
                                        @Johannes-Bauerstatter kann kerberos.io Objekterkennung?
                                        Johannes Bauerstatter 1 Reply Last reply Reply Quote 0
                                          Johannes Bauerstatter @coyote last edited by Johannes Bauerstatter
                                          @coyote Bewegungserkennung funktioniert bestens; Objekte geht glaub ich nicht...
                                            mikiline @coyote last edited by
                                            @coyote
                                            Also die 5 Sekunden stehen auch in der config für den Eventmanager (als Abfragezeit)
                                            Bei mir läuft Zoneminder eigentlich sehr stabil. Auch die Motionerkennung usw...
                                            31.7k
                                            79.8k
                                            camera motion zoneminder
                                            23
                                            206
                                            24383
