    4. Apple Homekit Siri
    Apple Homekit Siri
    • V
      versteckt last edited by
      Ich mach nachher ein paar Screenshots bez. Einrichtung, muss jetzt zur Taekwondo Weihnachtsfeier.
      Gesendet von meinem iPhone mit Tapatalk
        pix last edited by
        Hallo versteckt,
        jetzt habe ich 0.0.7 fehlerfrei installalliert (alten Adapter vorher gelöscht). Beim Aktivieren der Instanz erscheint wieder der alte Fehler Error: Module version mismatch. Expected 46, got 47.
        2015-12-13 12:51:08.835 - info: host.MacMini-Ethernet.fritz.box object change system.adapter.homekit.0
        2015-12-13 12:51:15.981 - info: host.MacMini-Ethernet.fritz.box object change system.adapter.homekit.0
        2015-12-13 12:51:15.993 - info: host.MacMini-Ethernet.fritz.box instance system.adapter.homekit.0 started with pid 25812
        2015-12-13 12:51:16.595 - error: uncaught exception: Module version mismatch. Expected 46, got 47.
        2015-12-13 12:51:16.603 - error: Error: Module version mismatch. Expected 46, got 47.
        at Error (native)
        at Object.Module._extensions..node (module.js:460:18)
        at Module.load (module.js:356:32)
        at Function.Module._load (module.js:311:12)
        at Module.require (module.js:366:17)
        at require (module.js:385:17)
        at Object. <anonymous>(/Users/pix/Documents/iobroker/node_modules/mdns/lib/dns_sd.js:24:20)
        at Module._compile (module.js:435:26)
        at Object.Module._extensions..js (module.js:442:10)
        2015-12-13 12:51:16.664 - debug: homekit.0 objectDB connected
        2015-12-13 12:51:16.670 - debug: homekit.0 statesDB connected
        2015-12-13 12:51:16.827 - info: homekit.0 starting. Version 0.0.7 in /Users/pix/Documents/iobroker/node_modules/iobroker.homekit
        2015-12-13 12:51:16.830 - info: homekit.0 requesting all states
        2015-12-13 12:51:16.831 - info: homekit.0 requesting all objects
        2015-12-13 12:51:16.944 - error: host.MacMini-Ethernet.fritz.box instance system.adapter.homekit.0 terminated with code 6 (uncaught exception)
        2015-12-13 12:51:16.944 - info: host.MacMini-Ethernet.fritz.box Restart adapter system.adapter.homekit.0 because enabled</anonymous>
        Aber ich weiss nicht, welches Modul das falsche ist :roll:
        Gruß am Sonntag,
        Pix
        • V
          Wie besprochen hier mal die Fotostrecke mit meinem iPad:
          • V
            @Pix:
            Du müsstest vier verschiedene .node Dateien besitzen, welche bei der Installation kompiliert werden.
            Christians-Mac-mini:ioBroker.homekit christian$ pwd
            /Users/christian/DEVELOPMENT/node_modules/ioBroker.homekit
            Christians-Mac-mini:ioBroker.homekit christian$ find . -name *.node -ls
            8120828       48 -rwxr-xr-x    1 christian        staff               20924 Dec 12 18:18 ./node_modules/hap-nodejs/node_modules/curve25519/build/Release/curve.node
            8120718      184 -rwxr-xr-x    1 christian        staff               93460 Dec 12 18:17 ./node_modules/hap-nodejs/node_modules/ed25519/build/Release/ed25519.node
            8120810      208 -rwxr-xr-x    1 christian        staff              104624 Dec 12 18:18 ./node_modules/hap-nodejs/node_modules/mdns/build/Release/dns_sd_bindings.node
            8120574      144 -rwxr-xr-x    1 christian        staff               69832 Dec 12 18:17 ./node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/build/Release/bignum.node
              pix last edited by
              Hallo Christian, danke für die Mühe.@versteckt:
              @Pix:
              Du müsstest vier verschiedene .node Dateien besitzen, welche bei der Installation kompiliert werden. `
              Interessant, ich habe nur zwei
              pix$ find . -name *.node -ls
              37736714       48 -rwxr-xr-x    1 pix              staff               20932 13 Dez 12:46 ./node_modules/hap-nodejs/node_modules/curve25519/build/Release/curve.node
              37736857      184 -rwxr-xr-x    1 pix              staff               93508 13 Dez 12:46 ./node_modules/hap-nodejs/node_modules/ed25519/build/Release/ed25519.node
              MacMini-Ethernet:iobroker.homekit pix$
              wo kriege ich die denn her? Ich habe zwischenzeitlich nochmal installiert, aber keine Veränderung.
              Gruß,
              Pix
              • V
                Das finde ich spannend, ansich sollte das node Module hap-nodejs diese für dich kompilieren.
                Was passiert eigentlich wenn du folgendes ausführst?
                cd /tmp
                npm cache clean
                npm install hap-nodejs
                Dadurch wird dein NPM Cache ausgeleert und das zugrunde liegende Modul hap-nodejs in /tmp/node_modules/hap-nodejs
                installiert / kompiliert.
                Poste bitte mal diese Ausgabe.
                • fischi87
                  fischi87 last edited by
                  bei mir läuft das Programm nun ihnen fehlen, werde es die tage testen und weiter berichten!!!
                  top sache!!!!
                  Mit freundlichen Grüßen
                    pix last edited by
                    @versteckt:
                    cd /tmp
                    npm cache clean
                    Poste bitte mal diese Ausgabe. `
                    npm cache clean ging nur mit sudo, dann kein Problem
                    anschließend diese Ausgabe:
                    MacMini-Ethernet:tmp pix$ npm install hap-node.js
                    npm ERR! Darwin 15.0.0
                    npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "hap-node.js"
                    npm ERR! node v4.2.3
                    npm ERR! npm  v2.14.7
                    npm ERR! code E404
                    npm ERR! 404 Registry returned 404 for GET on https://registry.npmjs.org/hap-node.js
                    npm ERR! 404
                    npm ERR! 404 'hap-node.js' is not in the npm registry.
                    npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
                    npm ERR! 404
                    npm ERR! 404 Note that you can also install from a
                    npm ERR! 404 tarball, folder, http url, or git url.
                    npm ERR! Please include the following file with any support request:
                    npm ERR!     /private/tmp/npm-debug.log
                    Pix
                    • V
                      Du hast 'nen Punkt zuviel, das Modul heisst hap-nodejs
                        Headroom68 last edited by
                        ich habe noch immer Probleme die Kopplung mit Eve hinzubekommen.
                        Die Verbindung selbst funktioniert, denn ich erhalte beim eingeben eines falschen Schlüssels eine Fehlermeldung im iobroker-log.
                        Könnte es Probleme mit den Temperatursensoren / Wandthermostaten geben ? In der Konfig stehen diese nicht, sollten dann eigentlich auch nicht im Log auftauchen oder ?
                        homekit-0 2015-12-13 21:14:54 info < hap HM-WDS30-OT2-SM MEQ0204382:4.TEMPERATURE get CurrentTemperature for hm-rpc.0.MEQ0204382.undefined
                        homekit-0 2015-12-13 21:14:54 info > iobroker subscribe Thermostat hm-rpc.0.MEQ0204382.4.TEMPERATURE
                        homekit-0 2015-12-13 21:14:54 info < hap HM-WDS30-OT2-SM MEQ0204382:3.TEMPERATURE get CurrentTemperature for hm-rpc.0.MEQ0204382.undefined
                        homekit-0 2015-12-13 21:14:54 info > iobroker subscribe Thermostat hm-rpc.0.MEQ0204382.3.TEMPERATURE
                        homekit-0 2015-12-13 21:14:54 info < hap MK Rücklauf.TEMPERATURE get CurrentTemperature for hm-rpc.0.MEQ0204382.undefined
                        homekit-0 2015-12-13 21:14:54 info > iobroker subscribe Thermostat hm-rpc.0.MEQ0204382.2.TEMPERATURE
                        Und sollte bei den Switches nicht dann auch der Übertrag nach HAP (< hap) kommen ?
                        homekit-0 2015-12-13 21:14:54 info > iobroker subscribe Switch JEQ0347403:1
                        homekit-0 2015-12-13 21:14:54 info > iobroker subscribe Switch JEQ0347403:2
                        homekit-0 2015-12-13 21:14:54 info > iobroker subscribe Switch JEQ0347403:3
                        homekit-0 2015-12-13 21:14:54 info > iobroker subscribe Switch JEQ0347403:4
                        Und bezüglich der Module:
                        /opt/iobroker/node_modules/iobroker.homekit# find . -name *.node -ls
                        645850 32 -rwxr-xr-x 1 root root 29355 Dec 13 21:09 ./node_modules/hap-nodejs/node_modules/curve25519/build/Release/curve.node
                        645853 32 -rwxr-xr-x 1 root root 29355 Dec 13 21:09 ./node_modules/hap-nodejs/node_modules/curve25519/build/Release/obj.target/curve.node
                        646026 92 -rwxr-xr-x 1 root root 93880 Dec 13 21:11 ./node_modules/hap-nodejs/node_modules/mdns/build/Release/dns_sd_bindings.node
                        646029 92 -rwxr-xr-x 1 root root 93880 Dec 13 21:11 ./node_modules/hap-nodejs/node_modules/mdns/build/Release/obj.target/dns_sd_bindings.node
                        645970 128 -rwxr-xr-x 1 root root 128406 Dec 13 21:10 ./node_modules/hap-nodejs/node_modules/ed25519/build/Release/ed25519.node
                        645973 128 -rwxr-xr-x 1 root root 128406 Dec 13 21:10 ./node_modules/hap-nodejs/node_modules/ed25519/build/Release/obj.target/ed25519.node
                        645868 56 -rwxr-xr-x 1 root root 53798 Dec 13 21:09 ./node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/build/Release/bignum.node
                        645871 56 -rwxr-xr-x 1 root root 53798 Dec 13 21:09 ./node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/build/Release/obj.target/bignum.node
                        node -v
                        v0.12.6
                        npm -v
                        2.11.2
                          pix last edited by
                          @versteckt:
                          Du hast 'nen Punkt zuviel, das Modul heisst hap-nodejs `
                          Danke, blöder Fehler. Copy & Paste wär besser gewesen. :lol:
                          Installation davon hat geklappt
                          MacMini-Ethernet:~ pix$ cd /tmp
                          MacMini-Ethernet:tmp pix$ npm cache clean
                          MacMini-Ethernet:tmp pix$ npm install hap-nodejs
                          curve25519@1.1.0 install /private/tmp/node_modules/hap-nodejs/node_modules/curve25519
                          node-gyp rebuild
                          ! CXX(target) Release/obj.target/curve/node_curve.o
                          SOLINK_MODULE(target) Release/curve.node
                          ! > ed25519@0.0.3 install /private/tmp/node_modules/hap-nodejs/node_modules/ed25519
                          node-gyp rebuild
                          ! CC(target) Release/obj.target/ed25519/src/ed25519/keypair.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/sign.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/open.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/crypto_verify_32.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_double_scalarmult.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_frombytes.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_scalarmult_base.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_precomp_0.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_p2_0.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_p2_dbl.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_0.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_dbl.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_to_p2.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_to_cached.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_tobytes.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_madd.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_add.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_msub.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_sub.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_p1p1_to_p3.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_p1p1_to_p2.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/ge_tobytes.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/fe_0.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/fe_1.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/fe_cmov.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/fe_copy.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/fe_neg.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/fe_add.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/fe_sub.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/fe_mul.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/fe_sq.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/fe_sq2.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/fe_invert.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/fe_tobytes.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/fe_isnegative.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/fe_isnonzero.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/fe_frombytes.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/fe_pow22523.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/sc_reduce.o
                          CC(target) Release/obj.target/ed25519/src/ed25519/sc_muladd.o
                          CXX(target) Release/obj.target/ed25519/src/ed25519.o
                          SOLINK_MODULE(target) Release/ed25519.node
                          ! > mdns@2.2.11 install /private/tmp/node_modules/hap-nodejs/node_modules/mdns
                          node-gyp rebuild
                          ! CXX(target) Release/obj.target/dns_sd_bindings/src/dns_sd.o
                          CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_browse.o
                          CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_enumerate_domains.o
                          CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_get_addr_info.o
                          CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_process_result.o
                          CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_ref.o
                          CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_ref_deallocate.o
                          CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_ref_sock_fd.o
                          CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_register.o
                          CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_resolve.o
                          CXX(target) Release/obj.target/dns_sd_bindings/src/mdns_utils.o
                          CXX(target) Release/obj.target/dns_sd_bindings/src/network_interface.o
                          CXX(target) Release/obj.target/dns_sd_bindings/src/socket_watcher.o
                          CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_ref.o
                          CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_create.o
                          CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_deallocate.o
                          CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_set_value.o
                          CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_get_length.o
                          CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_buffer_to_object.o
                          SOLINK_MODULE(target) Release/dns_sd_bindings.node
                          ! > bignum@0.11.0 install /private/tmp/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum
                          node-gyp configure build
                          ! CXX(target) Release/obj.target/bignum/bignum.o
                          SOLINK_MODULE(target) Release/bignum.node
                          hap-nodejs@0.0.7 node_modules/hap-nodejs
                          ├── debug@2.2.0 (ms@0.7.1)
                          ├── node-persist@0.0.6 (q@1.1.2, mkdirp@0.3.5)
                          ├── curve25519@1.1.0 (bindings@1.2.1, nan@2.1.0)
                          ├── ed25519@0.0.3 (bindings@1.2.1, nan@2.1.0)
                          ├── mdns@2.2.11 (bindings@1.2.1, nan@2.1.0)
                          └── srp@0.2.0 (bignum@0.11.0)
                          Danach den Adapter wieder gelöscht und neu installiert. Danach die Instanz wieder gestartet und wieder Fehler:
                          2015-12-14 00:18:55.400  - info: host.MacMini-Ethernet.fritz.box object change system.adapter.homekit.0
                          2015-12-14 00:18:55.413  - info: host.MacMini-Ethernet.fritz.box instance system.adapter.homekit.0 started with pid 32913
                          2015-12-14 00:18:56.043  - error: uncaught exception: Module version mismatch. Expected 46, got 47.
                          2015-12-14 00:18:56.058  - error: Error: Module version mismatch. Expected 46, got 47.
                              at Error (native)
                          2015-12-14 00:18:56.128  - debug: homekit.0 objectDB connected
                          2015-12-14 00:18:56.137  - debug: homekit.0 statesDB connected
                          2015-12-14 00:18:56.345  - info: homekit.0 starting. Version 0.0.7 in /Users/pix/Documents/iobroker/node_modules/iobroker.homekit
                          2015-12-14 00:18:56.350  - info: homekit.0 requesting all states
                          2015-12-14 00:18:56.351  - info: homekit.0 requesting all objects
                          2015-12-14 00:18:56.385  - error: host.MacMini-Ethernet.fritz.box instance system.adapter.homekit.0 terminated with code 6 (uncaught exception)</anonymous>
                          Laut Installationslog beim Adapterinstallieren müssten jetzt alle module installiert sein
                          iobroker.homekit@0.0.7 node_modules/iobroker.homekit
                          └── hap-nodejs@0.0.7 (srp@0.2.0, node-persist@0.0.6, curve25519@1.1.0, ed25519@0.0.3)
                          Also nochmal im Verzeichnis nachgesehen:
                          Mini-Ethernet:iobroker.homekit pix$ pwd
                          MacMini-Ethernet:iobroker.homekit pix$ find . -name *.node -ls
                          37754159       48 -rwxr-xr-x    1 pix              staff               20932 14 Dez 00:17 ./node_modules/hap-nodejs/node_modules/curve25519/build/Release/curve.node
                          37754303      184 -rwxr-xr-x    1 pix              staff               93508 14 Dez 00:17 ./node_modules/hap-nodejs/node_modules/ed25519/build/Release/ed25519.node
                          Es sind wieder nur zwei. Sind die vielleicht woanders?
                          dns_sd_bindings.node habe ich gar nicht auf der Platte gefunden,
                          bignum.node liegt in iobroker/node_modules/bignum/build/Release/bignum.node
                          Zum Schluss nochmal hap-nodejs installiert und Instanz aktiviert, aber ohne Erfolg.
                          Pix
                            @pix:
                            Pix</anonymous> `
                            Hallo Pix,
                            das Paket mdns scheinst Du schon im iobroker/node_modules Verzeichnis zu haben.
                            Evtl. Dort löschen und nochmal probieren?
                            • V
                              Ja probier mal
                              5373_alarmanlage.txt
                                pix last edited by
                                ich habe nun mdns aus dem node_modules Verzeichnis genommen und hap-nodejs und anschließend den Adapter neu installiert. Tatscächlich war schonmal eine Datei mehr im besagten Verzeichnis :lol:
                                37774377       48 -rwxr-xr-x    1 pix              staff               20932 14 Dez 11:53 ./node_modules/hap-nodejs/node_modules/curve25519/build/Release/curve.node
                                37774523      184 -rwxr-xr-x    1 pix              staff               93508 14 Dez 11:53 ./node_modules/hap-nodejs/node_modules/ed25519/build/Release/ed25519.node
                                37774610      208 -rwxr-xr-x    1 pix              staff              104656 14 Dez 11:53 ./node_modules/hap-nodejs/node_modules/mdns/build/Release/dns_sd_bindings.node
                                Fehlt aber immer noch eine (./node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/build/Release/bignum.node)
                                Also bin ich mit srp genauso vorgegangen. Erstmal aus dem node_modules-Verzeichnis rausgnemommen und nochmal hap-nodejs und anschließend den (vor gelöschten) Adapter neu installiert. Aber es blieb dabei. Nur drei Dateien und srp fehlt vielleicht jetzt in node_modules ???
                                Wir sind auf dem richtigen Weg … 😉
                                Pix
                                  @pix:
                                  Pix `
                                  unter /opt/iobroker/node_modules sollten nur io-Adapter liegen (zumindest bei mir). Evtl. liegt bei Dir da noch mehr quer ?
                                  Was kommt denn für eine Fehlermeldung ?
                                  • V
                                    Hallo, für mich sieht das auch so aus, als wie wenn da was falsch rumliegt.
                                    Der node_modules Ordner unter /Users/xxx/ioBroker sollte normalerweise folgenden Inhalt haben:
                                    (Je nachdem wieviele Adapter du halt installiert hast)
                                    Christians-Mac-mini:node_modules christian$ pwd
                                    Christians-Mac-mini:node_modules christian$ ls -al
                                    total 32
                                    drwxrwxrwx@ 42 christian  staff   1428 Dec 14 18:41 .
                                    drwxrwxrwx@ 13 christian  staff    442 Dec  7 15:42 ..
                                    -rwxrwxrwx@  1 christian  staff  14340 Oct 26 15:33 .DS_Store
                                    drwxrwxrwx@  4 christian  staff    136 Dec  7 15:42 .bin
                                    drwxrwxrwx   2 christian  staff     68 Sep  5 11:12 etc
                                    drwxr-xr-x  15 christian  staff    510 Dec 13 08:33 ioBroker.homekit
                                    drwxrwxrwx@ 10 christian  staff    340 May 21  2015 iobroker
                                    drwxrwxrwx   3 christian  staff    102 Sep  5 11:13 iobroker-data
                                    drwxr-xr-x  14 christian  staff    476 Dec  7 15:47 iobroker.admin
                                    drwxrwxrwx@ 12 christian  staff    408 May 28  2015 iobroker.email
                                    drwxrwxrwx  11 christian  staff    374 Jul 19 16:06 iobroker.flot
                                    drwxrwxrwx@ 14 christian  staff    476 Jul 19 16:05 iobroker.history
                                    drwxrwxrwx@ 11 christian  staff    374 Jun 17 08:56 iobroker.hm-rega
                                    drwxrwxrwx  13 christian  staff    442 Jul 19 15:48 iobroker.hm-rpc
                                    drwxrwxrwx  12 christian  staff    408 Sep 27 17:47 iobroker.hmm
                                    drwxrwxrwx  15 christian  staff    510 Sep  5 11:27 iobroker.ical
                                    drwxrwxrwx  12 christian  staff    408 Dec 12 15:46 iobroker.icons-addictive-flavour-png
                                    drwxrwxrwx  11 christian  staff    374 Jul 19 16:55 iobroker.icons-material-png
                                    drwxrwxrwx  11 christian  staff    374 Dec 11 15:34 iobroker.icons-mfd-png
                                    drwxrwxrwx  11 christian  staff    374 Sep 15 12:31 iobroker.icons-ultimate-png
                                    drwxrwxrwx  12 christian  staff    408 Dec 11 15:32 iobroker.javascript
                                    drwxr-xr-x  21 christian  staff    714 Dec  7 15:43 iobroker.js-controller
                                    drwxrwxrwx  15 christian  staff    510 Sep  5 11:28 iobroker.node-red
                                    drwxrwxrwx  14 christian  staff    476 Dec 14 14:21 iobroker.occ
                                    drwxrwxrwx  11 christian  staff    374 Jul 19 15:01 iobroker.onkyo
                                    drwxrwxrwx  12 christian  staff    408 Dec 12 15:37 iobroker.pushover
                                    drwxrwxrwx@ 11 christian  staff    374 Jul 19 16:05 iobroker.rickshaw
                                    drwxrwxrwx  12 christian  staff    408 Dec 11 15:24 iobroker.scenes
                                    drwxrwxrwx  13 christian  staff    442 Sep 15 11:44 iobroker.terminal
                                    drwxrwxrwx  13 christian  staff    442 Dec 11 15:33 iobroker.vis
                                    drwxrwxrwx  10 christian  staff    340 Dec 12 15:46 iobroker.vis-bars
                                    drwxrwxrwx  11 christian  staff    374 Dec 11 15:33 iobroker.vis-hqwidgets
                                    drwxrwxrwx  11 christian  staff    374 Dec 11 15:33 iobroker.vis-metro
                                    drwxr-xr-x@ 13 christian  staff    442 Oct 16 11:49 iobroker.vis-template
                                    drwxr-xr-x@ 15 christian  staff    510 Oct 29 19:49 iobroker.vis-web-admin
                                    drwxrwxrwx  14 christian  staff    476 Jul  4 07:37 iobroker.volksbox
                                    drwxrwxrwx  13 christian  staff    442 Nov 20 19:06 iobroker.web
                                    drwxrwxrwx  17 christian  staff    578 Dec  5 18:48 iobroker.zwave
                                    drwxrwxrwx   2 christian  staff     68 Sep  5 11:13 log
                                    drwxrwxrwx   6 christian  staff    204 Sep  5 11:20 node_modules
                                    drwxrwxrwx  25 christian  staff    850 Aug  4 18:06 openzwave-control-panel
                                    drwxrwxrwx@ 15 christian  staff    510 May 21  2015 sinopia
                                      pix last edited by
                                      Au verdammt. Ich habe über 400 Objekte in dem Ordner. Da muss ich wohl aufräumen.
                                      Vielleicht habe ich Node und npm damals im falschen Ordner installiert [emoji30]
                                      Pix
                                      Edit: Hier die Dateien im Ordner
                                      MacMini-Ethernet:node_modules pix$ ls -al
                                      total 32
                                      drwxr-xr-x 399 pix staff 13566 14 Dez 12:04 .
                                      drwxrwxrwx 10 pix staff 340 15 Dez 11:51 ..
                                      -rw-r--r--@ 1 pix staff 14340 14 Dez 12:00 .DS_Store
                                      drwxr-xr-x 28 pix staff 952 8 Dez 14:23 .bin
                                      drwxr-xr-x 10 pix staff 340 25 Nov 16:50 HAP-NodeJS
                                      drwxrwxrwx 10 pix staff 340 20 Nov 02:08 abbrev
                                      drwxrwxrwx 7 pix staff 238 8 Dez 14:19 accepts
                                      drwxr-xr-x 10 pix staff 340 8 Dez 14:19 adm-zip
                                      drwxrwxrwx 9 pix staff 306 8 Dez 14:19 after
                                      drwxr-xr-x 6 pix staff 204 8 Dez 14:23 align-text
                                      drwxrwxrwx 7 pix staff 238 20 Nov 02:08 amdefine
                                      drwxrwxrwx 6 pix staff 204 18 Nov 17:40 ansi-regex
                                      drwxrwxrwx 6 pix staff 204 18 Nov 17:40 ansi-styles
                                      drwxr-xr-x 7 pix staff 238 8 Dez 14:23 ap
                                      drwxr-xr-x 8 pix staff 272 8 Dez 14:23 argf
                                      drwxrwxrwx 9 pix staff 306 20 Nov 02:08 argparse
                                      drwxrwxrwx 6 pix staff 204 8 Dez 14:19 array-flatten
                                      drwxrwxrwx 8 pix staff 272 8 Dez 14:19 arraybuffer.slice
                                      drwxr-xr-x 10 pix staff 340 8 Dez 14:23 asap
                                      drwxrwxrwx 9 pix staff 306 20 Nov 02:08 asn1
                                      drwxrwxrwx 5 pix staff 170 20 Nov 02:08 assert-plus
                                      drwxrwxrwx 8 pix staff 272 20 Nov 02:08 async
                                      drwxrwxrwx 10 pix staff 340 20 Nov 02:08 authenticate-pam
                                      drwxrwxrwx 6 pix staff 204 20 Nov 02:08 aws-sign2
                                      drwxrwxrwx 10 pix staff 340 25 Nov 16:51 aws4
                                      drwxr-xr-x 9 pix staff 306 8 Dez 14:23 babel-runtime
                                      drwxr-xr-x 10 pix staff 340 8 Dez 14:19 backo2
                                      drwxrwxrwx 14 pix staff 476 20 Nov 02:08 backoff
                                      drwxrwxrwx 11 pix staff 374 20 Nov 02:08 balanced-match
                                      drwxrwxrwx 12 pix staff 408 8 Dez 14:19 base64-arraybuffer
                                      drwxrwxrwx 6 pix staff 204 8 Dez 14:19 base64-url
                                      drwxrwxrwx 6 pix staff 204 8 Dez 14:19 base64id
                                      drwxrwxrwx 8 pix staff 272 8 Dez 14:19 benchmark
                                      drwxr-xr-x 9 pix staff 306 8 Dez 14:19 better-assert
                                      drwxr-xr-x 10 pix staff 340 8 Dez 14:23 big-number
                                      drwxrwxrwx 14 pix staff 476 25 Nov 16:50 bignum
                                      drwxr-xr-x 12 pix staff 408 8 Dez 14:23 bignumber.js
                                      drwxrwxrwx 5 pix staff 170 18 Nov 17:40 bindings
                                      drwxrwxrwx 10 pix staff 340 20 Nov 02:08 bl
                                      drwxrwxrwx 9 pix staff 306 8 Dez 14:19 blob
                                      drwxr-xr-x 9 pix staff 306 8 Dez 14:20 block-stream
                                      drwxrwxrwx 8 pix staff 272 8 Dez 14:21 body-parser
                                      drwxrwxrwx 11 pix staff 374 20 Nov 02:08 boom
                                      drwxrwxrwx 7 pix staff 238 20 Nov 02:08 brace-expansion
                                      drwxrwxrwx 9 pix staff 306 20 Nov 02:08 browser-request
                                      drwxr-xr-x 9 pix staff 306 8 Dez 14:23 buffer-writer
                                      drwxrwxrwx 11 pix staff 374 8 Dez 14:21 bufferutil
                                      drwxrwxrwx 6 pix staff 204 8 Dez 14:19 bytes
                                      drwxr-xr-x 8 pix staff 272 8 Dez 14:19 callsite
                                      drwxrwxrwx 6 pix staff 204 18 Nov 17:40 camelcase
                                      drwxrwxrwx 7 pix staff 238 20 Nov 02:08 caseless
                                      drwxr-xr-x 7 pix staff 238 8 Dez 14:23 center-align
                                      drwxr-xr-x 8 pix staff 272 8 Dez 14:23 chainsaw
                                      drwxrwxrwx 7 pix staff 238 20 Nov 02:08 chalk
                                      drwxrwxrwx 11 pix staff 374 18 Nov 17:40 cliui
                                      drwxrwxrwx 6 pix staff 204 18 Nov 17:40 code-point-at
                                      drwxrwxrwx 9 pix staff 306 25 Nov 16:49 coffee-compiler
                                      drwxrwxrwx 13 pix staff 442 25 Nov 16:49 coffee-script
                                      drwxr-xr-x 10 pix staff 340 8 Dez 14:19 colors
                                      drwxrwxrwx 6 pix staff 204 20 Nov 02:08 combined-stream
                                      drwxrwxrwx 7 pix staff 238 20 Nov 02:08 commander
                                      drwxr-xr-x 9 pix staff 306 8 Dez 14:19 component-bind
                                      drwxr-xr-x 11 pix staff 374 8 Dez 14:19 component-emitter
                                      drwxr-xr-x 10 pix staff 340 8 Dez 14:19 component-inherit
                                      drwxrwxrwx 9 pix staff 306 20 Nov 02:08 concat-map
                                      drwxrwxrwx 7 pix staff 238 8 Dez 14:19 connect-flash
                                      drwxrwxrwx 7 pix staff 238 8 Dez 14:19 content-disposition
                                      drwxrwxrwx 7 pix staff 238 8 Dez 14:19 content-type
                                      drwxrwxrwx 7 pix staff 238 8 Dez 14:19 cookie
                                      drwxrwxrwx 7 pix staff 238 8 Dez 14:19 cookie-parser
                                      drwxrwxrwx 7 pix staff 238 8 Dez 14:19 cookie-signature
                                      drwxr-xr-x 21 pix staff 714 8 Dez 14:23 core-js
                                      drwxrwxrwx 8 pix staff 272 20 Nov 02:08 core-util-is
                                      drwxrwxrwx 7 pix staff 238 8 Dez 14:19 crc
                                      drwxr-xr-x 11 pix staff 374 25 Nov 17:01 cron-parser
                                      drwxrwxrwx 9 pix staff 306 20 Nov 02:08 cryptiles
                                      drwxrwxrwx 13 pix staff 442 20 Nov 02:08 ctype
                                      drwxr-xr-x 13 pix staff 442 25 Nov 16:51 curve25519
                                      drwxr-xr-x 5 pix staff 170 8 Dez 14:19 cycle
                                      drwxr-xr-x 8 pix staff 272 8 Dez 14:19 daemonize2
                                      drwxrwxrwx 5 pix staff 170 20 Nov 02:08 dashdash
                                      drwxrwxrwx 13 pix staff 442 18 Nov 17:40 debug
                                      drwxrwxrwx 6 pix staff 204 18 Nov 17:40 decamelize
                                      drwxr-xr-x 10 pix staff 340 8 Dez 14:19 deep-equal
                                      drwxrwxrwx 10 pix staff 340 20 Nov 02:08 deep-is
                                      drwxrwxrwx 8 pix staff 272 20 Nov 02:08 delayed-stream
                                      drwxrwxrwx 8 pix staff 272 8 Dez 14:19 depd
                                      drwxrwxrwx 5 pix staff 170 8 Dez 14:19 destroy
                                      drwxrwxrwx 9 pix staff 306 25 Nov 16:51 duplexer
                                      drwxrwxrwx 10 pix staff 340 25 Nov 16:50 duplexify
                                      drwxr-xr-x 9 pix staff 306 8 Dez 14:20 ecc-jsbn
                                      drwxrwxrwx 13 pix staff 442 25 Nov 16:50 ed25519
                                      drwxrwxrwx 6 pix staff 204 8 Dez 14:19 ee-first
                                      drwxrwxrwx 7 pix staff 238 25 Nov 16:50 end-of-stream
                                      drwxrwxrwx 11 pix staff 374 8 Dez 14:19 engine.io
                                      drwxr-xr-x 13 pix staff 442 8 Dez 14:19 engine.io-client
                                      drwxrwxrwx 12 pix staff 408 8 Dez 14:19 engine.io-parser
                                      drwxrwxrwx 6 pix staff 204 8 Dez 14:19 escape-html
                                      drwxrwxrwx 6 pix staff 204 20 Nov 02:08 escape-string-regexp
                                      drwxrwxrwx 9 pix staff 306 20 Nov 02:08 escodegen
                                      drwxrwxrwx 8 pix staff 272 20 Nov 02:08 esprima
                                      drwxrwxrwx 9 pix staff 306 20 Nov 02:08 estraverse
                                      drwxrwxrwx 6 pix staff 204 20 Nov 02:08 esutils
                                      drwxrwxrwx 7 pix staff 238 8 Dez 14:19 etag
                                      drwxrwxrwx 10 pix staff 340 25 Nov 16:51 event-stream
                                      drwxrwxrwx 9 pix staff 306 8 Dez 14:21 express
                                      drwxrwxrwx 9 pix staff 306 8 Dez 14:20 express-session
                                      drwxrwxrwx 12 pix staff 408 20 Nov 02:08 extend
                                      drwxrwxrwx 12 pix staff 408 20 Nov 02:08 extsprintf
                                      drwxr-xr-x 8 pix staff 272 8 Dez 14:19 eyes
                                      drwxrwxrwx 6 pix staff 204 20 Nov 02:08 fast-levenshtein
                                      drwxrwxrwx 7 pix staff 238 20 Nov 02:08 faye-websocket
                                      drwxrwxrwx 10 pix staff 340 20 Nov 02:08 fileset
                                      drwxrwxrwx 7 pix staff 238 8 Dez 14:20 finalhandler
                                      drwxrwxrwx 6 pix staff 204 20 Nov 02:08 forever-agent
                                      drwxrwxrwx 6 pix staff 204 20 Nov 02:08 form-data
                                      drwxr-xr-x 7 pix staff 238 8 Dez 14:20 forwarded
                                      drwxrwxrwx 7 pix staff 238 8 Dez 14:19 fresh
                                      drwxrwxrwx 9 pix staff 306 25 Nov 16:51 from
                                      drwxr-xr-x 3 pix staff 102 25 Nov 16:48 ftp-response-parser
                                      drwxrwxrwx 9 pix staff 306 20 Nov 02:08 generate-function
                                      drwxrwxrwx 9 pix staff 306 20 Nov 02:08 generate-object-property
                                      drwxr-xr-x 11 pix staff 374 8 Dez 14:23 generic-pool
                                      drwxrwxrwx 8 pix staff 272 20 Nov 02:08 glob
                                      drwxr-xr-x 10 pix staff 340 8 Dez 14:19 global
                                      drwxr-xr-x 10 pix staff 340 8 Dez 14:20 graceful-fs
                                      drwxrwxrwx 8 pix staff 272 20 Nov 02:08 graceful-readlink
                                      drwxrwxrwx 18 pix staff 612 20 Nov 02:08 handlebars
                                      drwxr-xr-x 7 pix staff 238 8 Dez 14:20 har-validator
                                      drwxrwxrwx 12 pix staff 408 20 Nov 02:08 harmonyhubjs-client
                                      drwxrwxrwx 9 pix staff 306 20 Nov 02:08 harmonyhubjs-discover
                                      drwxrwxrwx 6 pix staff 204 20 Nov 02:08 has-ansi
                                      drwxr-xr-x 11 pix staff 374 8 Dez 14:19 has-binary
                                      drwxrwxrwx 11 pix staff 374 8 Dez 14:19 has-binary-data
                                      drwxr-xr-x 9 pix staff 306 8 Dez 14:19 has-cors
                                      drwxrwxrwx 6 pix staff 204 20 Nov 02:08 has-flag
                                      drwxr-xr-x 7 pix staff 238 8 Dez 14:23 hashish
                                      drwxrwxrwx 14 pix staff 476 20 Nov 02:08 hawk
                                      drwxrwxrwx 11 pix staff 374 20 Nov 02:08 hoek
                                      drwxrwxrwx 7 pix staff 238 8 Dez 14:19 http-errors
                                      drwxrwxrwx 10 pix staff 340 20 Nov 02:08 http-signature
                                      drwxr-xr-x 9 pix staff 306 8 Dez 14:19 i
                                      drwxrwxrwx 10 pix staff 340 8 Dez 14:19 iconv-lite
                                      drwxr-xr-x 8 pix staff 272 8 Dez 14:19 indexof
                                      drwxrwxrwx 8 pix staff 272 20 Nov 02:08 inflight
                                      drwxrwxrwx 8 pix staff 272 20 Nov 02:08 inherits
                                      drwxr-xr-x 6 pix staff 204 8 Dez 14:23 ini
                                      drwxr-xr-x 7 pix staff 238 8 Dez 14:23 inote-util
                                      drwxrwxrwx 5 pix staff 170 18 Nov 17:40 invert-kv
                                      drwxr-xr-x@ 15 pix staff 510 29 Nov 18:33 ioBroker.vis-communicate
                                      drwxr-xr-x 11 pix staff 374 19 Aug 15:23 iobroker
                                      drwxr-xr-x 14 pix staff 476 8 Dez 14:20 iobroker.admin
                                      drwxrwxrwx 14 pix staff 476 26 Nov 12:41 iobroker.dwd
                                      drwxr-xr-x 12 pix staff 408 8 Dez 14:22 iobroker.flot
                                      drwxr-xr-x 11 pix staff 374 19 Aug 15:23 iobroker.fritzbox
                                      drwxrwxrwx 12 pix staff 408 30 Nov 16:28 iobroker.harmony
                                      drwxrwxrwx 13 pix staff 442 19 Aug 15:23 iobroker.history
                                      drwxrwxrwx 11 pix staff 374 19 Aug 15:23 iobroker.hm-rega
                                      drwxr-xr-x 13 pix staff 442 19 Aug 15:23 iobroker.hm-rpc
                                      drwxrwxrwx 10 pix staff 340 19 Okt 14:00 iobroker.hmm
                                      drwxr-xr-x 12 pix staff 408 14 Dez 12:04 iobroker.homekit
                                      drwxr-xr-x 14 pix staff 476 23 Aug 14:37 iobroker.ical
                                      drwxr-xr-x 11 pix staff 374 19 Aug 15:23 iobroker.icons-addictive-flavour-png
                                      drwxr-xr-x 10 pix staff 340 19 Aug 15:23 iobroker.icons-material-png
                                      drwxr-xr-x 10 pix staff 340 19 Aug 15:23 iobroker.icons-material-svg
                                      drwxrwxrwx 10 pix staff 340 25 Sep 12:39 iobroker.icons-mfd-png
                                      drwxrwxrwx 10 pix staff 340 27 Sep 19:36 iobroker.icons-mfd-svg
                                      drwxr-xr-x 10 pix staff 340 19 Aug 15:23 iobroker.icons-ultimate-png
                                      drwxrwxrwx 12 pix staff 408 11 Dez 00:52 iobroker.javascript
                                      drwxr-xr-x 20 pix staff 680 3 Nov 18:19 iobroker.js-controller
                                      drwxrwxrwx 16 pix staff 544 19 Aug 15:23 iobroker.legacy
                                      drwxr-xr-x 10 pix staff 340 9 Nov 10:15 iobroker.mobile
                                      drwxr-xr-x 12 pix staff 408 19 Aug 15:23 iobroker.motion
                                      drwxrwxrwx 12 pix staff 408 25 Nov 16:50 iobroker.mqtt
                                      drwxr-xr-x 14 pix staff 476 23 Aug 14:33 iobroker.node-red
                                      drwxr-xr-x 14 pix staff 476 19 Aug 15:23 iobroker.occ
                                      drwxr-xr-x 12 pix staff 408 29 Aug 18:40 iobroker.ping
                                      drwxrwxrwx 11 pix staff 374 12 Okt 23:01 iobroker.pushbullet
                                      drwxrwxrwx 12 pix staff 408 19 Aug 15:23 iobroker.pushover
                                      drwxr-xr-x 12 pix staff 408 8 Dez 14:22 iobroker.rickshaw
                                      drwxr-xr-x 17 pix staff 578 26 Nov 12:59 iobroker.sayit
                                      drwxrwxrwx 12 pix staff 408 13 Dez 12:48 iobroker.scenes
                                      drwxr-xr-x 10 pix staff 340 29 Sep 02:41 iobroker.sequence
                                      drwxrwxrwx 11 pix staff 374 1 Okt 18:08 iobroker.simple-api
                                      drwxr-xr-x 3 pix staff 102 13 Dez 12:48 iobroker.socketio
                                      drwxr-xr-x 12 pix staff 408 17 Sep 19:20 iobroker.sonos
                                      drwxr-xr-x 10 pix staff 340 12 Dez 17:02 iobroker.sql
                                      drwxr-xr-x 15 pix staff 510 26 Aug 00:14 iobroker.terminal
                                      drwxr-xr-x 10 pix staff 340 2 Okt 18:11 iobroker.vcard
                                      drwxrwxrwx 14 pix staff 476 9 Dez 13:43 iobroker.vis
                                      drwxrwxrwx 9 pix staff 306 25 Sep 12:51 iobroker.vis-bars
                                      drwxrwxrwx 10 pix staff 340 27 Sep 19:41 iobroker.vis-colorpicker
                                      drwxrwxrwx 10 pix staff 340 14 Okt 13:35 iobroker.vis-fancyswitch
                                      drwxrwxrwx 14 pix staff 476 18 Nov 17:42 iobroker.vis-google-fonts
                                      drwxrwxrwx 12 pix staff 408 2 Dez 13:07 iobroker.vis-hqwidgets
                                      drwxrwxrwx 10 pix staff 340 3 Nov 12:20 iobroker.vis-jqui-mfd
                                      drwxr-xr-x 11 pix staff 374 23 Aug 14:40 iobroker.vis-lcars
                                      drwxrwxrwx 12 pix staff 408 7 Dez 15:11 iobroker.vis-metro
                                      drwxrwxrwx 10 pix staff 340 4 Okt 22:03 iobroker.vis-rgraph
                                      drwxrwxrwx 10 pix staff 340 5 Okt 23:23 iobroker.vis-timeandweather
                                      drwxr-xr-x 14 pix staff 476 8 Dez 14:21 iobroker.web
                                      drwxrwxrwx 11 pix staff 374 29 Okt 15:00 iobroker.yr
                                      drwxr-xr-x 13 pix staff 442 8 Dez 14:19 ipaddr.js
                                      drwxr-xr-x 10 pix staff 340 8 Dez 14:19 is
                                      drwxrwxrwx 6 pix staff 204 20 Nov 02:08 is-absolute
                                      drwxr-xr-x 9 pix staff 306 8 Dez 14:23 is-buffer
                                      drwxrwxrwx 6 pix staff 204 18 Nov 17:40 is-fullwidth-code-point
                                      drwxrwxrwx 12 pix staff 408 20 Nov 02:08 is-my-json-valid
                                      drwxrwxrwx 7 pix staff 238 20 Nov 02:08 is-property
                                      drwxrwxrwx 6 pix staff 204 20 Nov 02:08 is-relative
                                      drwxrwxrwx 7 pix staff 238 20 Nov 02:08 is-typedarray
                                      drwxrwxrwx 7 pix staff 238 20 Nov 02:08 isarray
                                      drwxrwxrwx 10 pix staff 340 20 Nov 02:08 isstream
                                      drwxrwxrwx 8 pix staff 272 20 Nov 02:08 istanbul
                                      drwxrwxrwx 7 pix staff 238 25 Nov 16:51 ivona-node
                                      drwxrwxrwx 13 pix staff 442 20 Nov 02:08 jodid25519
                                      drwxrwxrwx 11 pix staff 374 20 Nov 02:08 js-yaml
                                      drwxrwxrwx 9 pix staff 306 20 Nov 02:08 jsbn
                                      drwxr-xr-x 3 pix staff 102 25 Nov 16:48 jsftp
                                      drwxrwxrwx 13 pix staff 442 20 Nov 02:08 json-schema
                                      drwxrwxrwx 10 pix staff 340 20 Nov 02:08 json-stringify-safe
                                      drwxrwxrwx 11 pix staff 374 8 Dez 14:19 json3
                                      drwxrwxrwx 7 pix staff 238 20 Nov 02:08 jsonpointer
                                      drwxrwxrwx 7 pix staff 238 20 Nov 02:08 jsprim
                                      drwxr-xr-x 6 pix staff 204 8 Dez 14:19 keypress
                                      drwxr-xr-x 6 pix staff 204 8 Dez 14:23 kind-of
                                      drwxr-xr-x 6 pix staff 204 8 Dez 14:23 lazy-cache
                                      drwxrwxrwx 7 pix staff 238 18 Nov 17:40 lcid
                                      drwxrwxrwx 6 pix staff 204 20 Nov 02:08 levn
                                      drwxrwxrwx 30 pix staff 1020 20 Nov 02:08 lodash
                                      drwxrwxrwx 6 pix staff 204 20 Nov 02:08 lodash._baseassign
                                      drwxrwxrwx 6 pix staff 204 20 Nov 02:08 lodash._basecopy
                                      drwxrwxrwx 6 pix staff 204 20 Nov 02:08 lodash._bindcallback
                                      drwxrwxrwx 6 pix staff 204 20 Nov 02:08 lodash._createassigner
                                      drwxrwxrwx 6 pix staff 204 20 Nov 02:08 lodash._getnative
                                      drwxrwxrwx 6 pix staff 204 20 Nov 02:08 lodash._isiterateecall
                                      drwxrwxrwx 6 pix staff 204 20 Nov 02:08 lodash.assign
                                      drwxrwxrwx 6 pix staff 204 20 Nov 02:08 lodash.isarguments
                                      drwxrwxrwx 6 pix staff 204 20 Nov 02:08 lodash.isarray
                                      drwxrwxrwx 6 pix staff 204 20 Nov 02:08 lodash.keys
                                      drwxrwxrwx 6 pix staff 204 20 Nov 02:08 lodash.restparam
                                      drwxr-xr-x 6 pix staff 204 25 Nov 17:01 long-timeout
                                      drwxr-xr-x 6 pix staff 204 8 Dez 14:23 longest
                                      drwxrwxrwx 10 pix staff 340 25 Nov 16:51 lru-cache
                                      drwxrwxrwx 7 pix staff 238 20 Nov 02:08 ltx
                                      drwxrwxrwx 10 pix staff 340 25 Nov 16:51 map-stream
                                      drwxr-xr-x 7 pix staff 238 8 Dez 14:20 media-typer
                                      drwxrwxrwx 6 pix staff 204 8 Dez 14:19 merge-descriptors
                                      drwxrwxrwx 7 pix staff 238 8 Dez 14:19 methods
                                      drwxrwxrwx 8 pix staff 272 20 Nov 02:08 mime
                                      drwxr-xr-x 8 pix staff 272 8 Dez 14:20 mime-db
                                      drwxr-xr-x 7 pix staff 238 8 Dez 14:20 mime-types
                                      drwxrwxrwx 7 pix staff 238 20 Nov 02:08 minimatch
                                      drwxrwxrwx 9 pix staff 306 20 Nov 02:08 minimist
                                      drwxrwxrwx 11 pix staff 374 20 Nov 02:08 mkdirp
                                      drwxr-xr-x 3 pix staff 102 25 Nov 16:50 mqtt-packet
                                      drwxrwxrwx 8 pix staff 272 18 Nov 17:40 ms
                                      drwxr-xr-x 14 pix staff 476 8 Dez 14:23 mssql
                                      drwxr-xr-x 7 pix staff 238 8 Dez 14:20 mute-stream
                                      drwxr-xr-x 9 pix staff 306 8 Dez 14:23 mysql
                                      drwxr-xr-x 29 pix staff 986 8 Dez 14:21 nan
                                      drwxr-xr-x 13 pix staff 442 8 Dez 14:23 nconf
                                      drwxr-xr-x 10 pix staff 340 8 Dez 14:19 ncp
                                      drwxrwxrwx 8 pix staff 272 8 Dez 14:19 negotiator
                                      drwxrwxrwx 8 pix staff 272 20 Nov 02:08 node-persist
                                      drwxrwxrwx 10 pix staff 340 25 Nov 17:01 node-schedule
                                      drwxrwxrwx 12 pix staff 408 20 Nov 02:08 node-uuid
                                      drwxrwxrwx 9 pix staff 306 20 Nov 02:08 node-xmpp-client
                                      drwxrwxrwx 7 pix staff 238 20 Nov 02:08 node-xmpp-core
                                      drwxrwxrwx 8 pix staff 272 20 Nov 02:08 node-xmpp-jid
                                      drwxr-xr-x 10 pix staff 340 8 Dez 14:19 node.extend
                                      drwxr-xr-x 12 pix staff 408 21 Aug 19:15 node_modules
                                      drwxrwxrwx 11 pix staff 374 20 Nov 02:08 nopt
                                      drwxr-xr-x 24 pix staff 816 8 Dez 14:19 npm
                                      drwxrwxrwx 6 pix staff 204 18 Nov 17:40 number-is-nan
                                      drwxrwxrwx 7 pix staff 238 20 Nov 02:08 oauth-sign
                                      drwxr-xr-x 10 pix staff 340 8 Dez 14:19 object-component
                                      drwxrwxrwx 11 pix staff 374 8 Dez 14:19 object-keys
                                      drwxrwxrwx 7 pix staff 238 8 Dez 14:19 on-finished
                                      drwxrwxrwx 7 pix staff 238 8 Dez 14:19 on-headers
                                      drwxrwxrwx 7 pix staff 238 20 Nov 02:08 once
                                      drwxrwxrwx 10 pix staff 340 20 Nov 02:08 optimist
                                      drwxrwxrwx 7 pix staff 238 20 Nov 02:08 optionator
                                      drwxrwxrwx 7 pix staff 238 25 Nov 16:50 options
                                      drwxrwxrwx 6 pix staff 204 18 Nov 17:40 os-locale
                                      drwxr-xr-x 6 pix staff 204 8 Dez 14:23 packet-reader
                                      drwxr-xr-x 17 pix staff 578 25 Nov 16:48 parse-listing
                                      drwxr-xr-x 6 pix staff 204 8 Dez 14:19 parsejson
                                      drwxr-xr-x 6 pix staff 204 8 Dez 14:19 parseqs
                                      drwxr-xr-x 7 pix staff 238 8 Dez 14:19 parseuri
                                      drwxrwxrwx 8 pix staff 272 8 Dez 14:19 parseurl
                                      drwxrwxrwx 6 pix staff 204 8 Dez 14:19 passport
                                      drwxrwxrwx 6 pix staff 204 8 Dez 14:19 passport-local
                                      drwxrwxrwx 8 pix staff 272 8 Dez 14:19 passport-strategy
                                      drwxrwxrwx 6 pix staff 204 20 Nov 02:08 path-is-absolute
                                      drwxrwxrwx 7 pix staff 238 8 Dez 14:19 path-to-regexp
                                      drwxrwxrwx 8 pix staff 272 8 Dez 14:19 pause
                                      drwxrwxrwx 8 pix staff 272 25 Nov 16:51 pause-stream
                                      drwxr-xr-x 13 pix staff 442 8 Dez 14:23 pg
                                      drwxr-xr-x 9 pix staff 306 8 Dez 14:23 pg-connection-string
                                      drwxr-xr-x 10 pix staff 340 8 Dez 14:23 pg-types
                                      drwxr-xr-x 10 pix staff 340 8 Dez 14:23 pgpass
                                      drwxr-xr-x 6 pix staff 204 8 Dez 14:20 pinkie
                                      drwxr-xr-x 6 pix staff 204 8 Dez 14:20 pinkie-promise
                                      drwxr-xr-x 10 pix staff 340 8 Dez 14:19 pkginfo
                                      drwxr-xr-x 6 pix staff 204 8 Dez 14:23 postgres-array
                                      drwxr-xr-x 6 pix staff 204 8 Dez 14:23 postgres-bytea
                                      drwxr-xr-x 6 pix staff 204 8 Dez 14:23 postgres-date
                                      drwxr-xr-x 6 pix staff 204 8 Dez 14:23 postgres-interval
                                      drwxrwxrwx 7 pix staff 238 20 Nov 02:08 prelude-ls
                                      drwxr-xr-x 8 pix staff 272 8 Dez 14:20 process-nextick-args
                                      drwxr-xr-x 16 pix staff 544 8 Dez 14:23 promise
                                      drwxr-xr-x 7 pix staff 238 8 Dez 14:20 proxy-addr
                                      drwxr-xr-x 10 pix staff 340 25 Nov 16:50 pump
                                      drwxrwxrwx 7 pix staff 238 18 Nov 17:40 q
                                      drwxr-xr-x 15 pix staff 510 8 Dez 14:20 qs
                                      drwxrwxrwx 7 pix staff 238 8 Dez 14:19 range-parser
                                      drwxr-xr-x 8 pix staff 272 8 Dez 14:21 raw-body
                                      drwxr-xr-x 6 pix staff 204 8 Dez 14:20 read
                                      drwxrwxrwx 15 pix staff 510 20 Nov 02:08 readable-stream
                                      drwxrwxrwx 8 pix staff 272 20 Nov 02:08 reconnect-core
                                      drwxrwxrwx 10 pix staff 340 25 Nov 16:50 reduplexer
                                      drwxr-xr-x 10 pix staff 340 8 Dez 14:23 remove
                                      drwxr-xr-x 6 pix staff 204 8 Dez 14:23 repeat-string
                                      drwxrwxrwx 16 pix staff 544 20 Nov 02:08 request
                                      drwxrwxrwx 10 pix staff 340 20 Nov 02:08 resolve
                                      drwxr-xr-x 11 pix staff 374 8 Dez 14:19 revalidator
                                      drwxr-xr-x 6 pix staff 204 8 Dez 14:23 right-align
                                      drwxr-xr-x 7 pix staff 238 8 Dez 14:19 rimraf
                                      drwxrwxrwx 7 pix staff 238 25 Nov 16:48 sax
                                      drwxr-xr-x 15 pix staff 510 8 Dez 14:23 seedrandom
                                      drwxrwxrwx 9 pix staff 306 20 Nov 02:08 semaphore
                                      drwxr-xr-x 17 pix staff 578 8 Dez 14:19 semver
                                      drwxrwxrwx 8 pix staff 272 8 Dez 14:19 send
                                      drwxr-xr-x 8 pix staff 272 8 Dez 14:23 seq
                                      drwxrwxrwx 7 pix staff 238 8 Dez 14:19 serve-static
                                      drwxrwxrwx 7 pix staff 238 25 Nov 16:50 server-destroy
                                      drwxrwxrwx 12 pix staff 408 20 Nov 02:08 sntp
                                      drwxrwxrwx 12 pix staff 408 8 Dez 14:21 socket.io
                                      drwxrwxrwx 8 pix staff 272 8 Dez 14:19 socket.io-adapter
                                      drwxrwxrwx 10 pix staff 340 8 Dez 14:21 socket.io-client
                                      drwxr-xr-x 3 root staff 102 8 Dez 14:19 socket.io-parser
                                      drwxrwxrwx 12 pix staff 408 20 Nov 02:08 source-map
                                      drwxrwxrwx 10 pix staff 340 25 Nov 16:51 split
                                      drwxr-xr-x 7 pix staff 238 8 Dez 14:23 sprintf
                                      drwxrwxrwx 12 pix staff 408 20 Nov 02:08 sprintf-js
                                      drwxr-xr-x 7 pix staff 238 8 Dez 14:23 sql-client
                                      drwxr-xr-x 14 pix staff 476 8 Dez 14:23 sqlite3
                                      drwxr-xr-x 10 pix staff 340 8 Dez 14:20 sshpk
                                      drwxr-xr-x 8 pix staff 272 8 Dez 14:19 stack-trace
                                      drwxrwxrwx 7 pix staff 238 8 Dez 14:19 statuses
                                      drwxrwxrwx 9 pix staff 306 25 Nov 16:51 stream-combiner
                                      drwxrwxrwx 6 pix staff 204 18 Nov 17:40 string-width
                                      drwxrwxrwx 7 pix staff 238 20 Nov 02:08 string_decoder
                                      drwxrwxrwx 9 pix staff 306 20 Nov 02:08 stringstream
                                      drwxrwxrwx 6 pix staff 204 18 Nov 17:40 strip-ansi
                                      drwxr-xr-x 8 pix staff 272 25 Nov 16:49 suncalc
                                      drwxrwxrwx 7 pix staff 238 20 Nov 02:08 supports-color
                                      drwxr-xr-x 8 pix staff 272 8 Dez 14:23 tedious
                                      drwxrwxrwx 9 pix staff 306 25 Nov 16:51 through
                                      drwxr-xr-x 3 pix staff 102 25 Nov 16:50 through2
                                      drwxrwxrwx 8 pix staff 272 20 Nov 02:08 tls-connect
                                      drwxr-xr-x 7 pix staff 238 8 Dez 14:19 to-array
                                      drwxrwxrwx 6 pix staff 204 20 Nov 02:08 tough-cookie
                                      drwxr-xr-x 9 pix staff 306 8 Dez 14:23 traverse
                                      drwxrwxrwx 7 pix staff 238 20 Nov 02:08 tunnel-agent
                                      drwxrwxrwx 10 pix staff 340 20 Nov 02:08 tweetnacl
                                      drwxrwxrwx 6 pix staff 204 20 Nov 02:08 type-check
                                      drwxr-xr-x 7 pix staff 238 8 Dez 14:21 type-is
                                      drwxrwxrwx 9 pix staff 306 20 Nov 02:08 uglify-js
                                      drwxrwxrwx 9 pix staff 306 20 Nov 02:08 uglify-to-browserify
                                      drwxrwxrwx 7 pix staff 238 8 Dez 14:19 uid-safe
                                      drwxrwxrwx 9 pix staff 306 25 Nov 16:50 ultron
                                      drwxrwxrwx 6 pix staff 204 25 Nov 16:51 unorm
                                      drwxr-xr-x 7 pix staff 238 8 Dez 14:20 unpipe
                                      drwxrwxrwx 11 pix staff 374 8 Dez 14:21 utf-8-validate
                                      drwxrwxrwx 13 pix staff 442 8 Dez 14:19 utf8
                                      drwxrwxrwx 8 pix staff 272 20 Nov 02:08 util-deprecate
                                      drwxr-xr-x 11 pix staff 374 8 Dez 14:20 utile
                                      drwxrwxrwx 7 pix staff 238 8 Dez 14:19 utils-merge
                                      drwxrwxrwx 7 pix staff 238 8 Dez 14:19 vary
                                      drwxrwxrwx 13 pix staff 442 20 Nov 02:08 verror
                                      drwxrwxrwx 7 pix staff 238 25 Nov 16:49 wake_on_lan
                                      drwxrwxrwx 7 pix staff 238 20 Nov 02:08 websocket-driver
                                      drwxrwxrwx 6 pix staff 204 20 Nov 02:08 websocket-extensions
                                      drwxrwxrwx 9 pix staff 306 20 Nov 02:08 which
                                      drwxrwxrwx 7 pix staff 238 18 Nov 17:40 window-size
                                      drwxr-xr-x 14 pix staff 476 8 Dez 14:20 winston
                                      drwxrwxrwx 8 pix staff 272 20 Nov 02:08 wordwrap
                                      drwxrwxrwx 6 pix staff 204 18 Nov 17:40 wrap-ansi
                                      drwxrwxrwx 7 pix staff 238 20 Nov 02:08 wrappy
                                      drwxrwxrwx 15 pix staff 510 25 Nov 16:51 ws
                                      drwxrwxrwx 6 pix staff 204 25 Nov 16:48 xml2js
                                      drwxr-xr-x 7 pix staff 238 25 Nov 16:48 xmlbuilder
                                      drwxr-xr-x 9 pix staff 306 8 Dez 14:19 xmlhttprequest
                                      drwxrwxrwx 11 pix staff 374 20 Nov 02:08 xtend
                                      drwxrwxrwx 8 pix staff 272 18 Nov 17:40 y18n
                                      drwxrwxrwx 9 pix staff 306 18 Nov 17:40 yalm
                                      drwxrwxrwx 10 pix staff 340 18 Nov 17:40 yargs
                                        pix last edited by
                                        nachdem ich mein System mal gründlich aufgeräumt habe, hat die Installation von Homekit endlich geklappt! Vielen Dank für Eure Hilfe.
                                        Etwas tricky war die Koppelung. Ich musste leider die Schlüsselbundsynchronisation über iCloud einschalten, sonst war es nicht möglich zu koppeln.
                                        Heute abend werde ich mal fleissig einrichten.
                                        Danke nochmal,
                                        Pix
                                        :lol:
                                        • V
                                          Hallo, freut mich das zu hören.
                                          Ja das Thema "Schlüsselbundsync" ist etwas, das Apple vorschreibt.
                                          LG Christian
                                          • fischi87
                                            Servus,
                                            also bei mir läuft der adapter ja recht gut aber ein freund wollte diesen auch haben und da hab ich Probleme mit der installation.
                                            habe dass schon versucht wie bei pix aber ohne erfolg.?!
                                            dns_sd_bindings.target.mk:130: recipe for target 'Release/obj.target/dns_sd_bindings/src/dns_sd.o' failed
                                            make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
                                            make: Leaving directory '/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/mdns/build'
                                            gyp ERR! build error
                                            gyp ERR! stack Error: `make` failed with exit code: 2
                                            gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:267:23)
                                            gyp ERR! stack     at ChildProcess.EventEmitter.emit (events.js:98:17)
                                            gyp ERR! stack     at Process.ChildProcess._handle.onexit (child_process.js:789:12)
                                            gyp ERR! System Linux 4.1.7-v7+
                                            gyp ERR! command "node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                                            gyp ERR! cwd /opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/mdns
                                            gyp ERR! node -v v0.10.22
                                            gyp ERR! node-gyp -v v0.11.0
                                            gyp ERR! not ok
                                            npm ERR! mdns@2.2.11 install: `node-gyp rebuild`
                                            npm ERR! Exit status 1
                                            npm ERR!
                                            npm ERR! Failed at the mdns@2.2.11 install script.
                                            npm ERR! This is most likely a problem with the mdns package,
                                            npm ERR! not with npm itself.
                                            npm ERR! Tell the author that this fails on your system:
                                            npm ERR!     node-gyp rebuild
                                            npm ERR! You can get their info via:
                                            npm ERR!     npm owner ls mdns
                                            npm ERR! There is likely additional logging output above.
                                            npm ERR! System Linux 4.1.7-v7+
                                            npm ERR! command "/usr/local/bin/node" "/usr/local/bin/npm" "install" "https://github.com/husky-koglhof/ioBroker.homekit/tarball/master" "--production"
                                            npm ERR! cwd /opt/iobroker
                                            npm ERR! node -v v0.10.22
                                            npm ERR! npm -v 1.3.14
                                            npm ERR! code ELIFECYCLE
                                            npm ERR!
                                            npm ERR! Additional logging details can be found in:
                                            npm ERR!     /opt/iobroker/npm-debug.log
                                            npm ERR! not ok code 0
                                            root@raspberrypi:/opt/iobroker#
                                            250
                                            52391
