    4. Adapter: DasWetter
    Adapter: DasWetter
    • Rene_HM
      Rene_HM Developer @SMS last edited by Rene_HM
      @SMS Der Adapter aktualisiert Daten. Das sieht man ja auch oben im screen shot unter daswetter.0.
      Der Adapter schreibt aber nicht auf Datenpunkte unter javascript.vis. Das müsste im script erfolgen...
      • FredF
        FredF Most Active Forum Testing @SMS last edited by
        @SMS
        Wenn Daten ankommen, ist die Frage was das Skript macht und wo die Daten hinwandern. Zeig doch bitte mal dein Skript
        • SMS
          SMS last edited by SMS
          createState('WeatherSymbol0', '');
          createState('WindSymbol0', '');
          createState('WeatherSymbol1', '');
          createState('WindSymbol1', '');
          createState('WeatherSymbol2', '');
          createState('WindSymbol2', '');
          createState('WeatherSymbol3', '');
          createState('WindSymbol3', '');
          createState('WeatherSymbol4', '');
          createState('WindSymbol4', '');
          on("daswetter.0.NextDaysDetailed.0d.SymbolID", function(obj) {
          var symbol = parseInt(obj.newState.val, 10);
          var temp = 'http://192.168.178.75:8082/daswetter/i … /galeria3/' + symbol + '.png';
          log (temp);
          setState('WeatherSymbol0', temp );
          on("daswetter.0.NextDaysDetailed.0d.WindSymbolB", function(obj) {
          var windsymbol = parseInt(obj.newState.val, 10);
          var temp = 'http://192.168.178.75:8082/daswetter/i ... nd/galeria 2 - Beaufort/' + windsymbol + '.png';
          log (temp);
          setState('WindSymbol0', temp);
          on("daswetter.0.NextDaysDetailed.1d.SymbolID", function(obj) {
          var temp = 'http://192.168.178.75:8082/daswetter/i ... /galeria3/' + symbol + '.png';
          log (temp);
          setState('WeatherSymbol1', temp );
          on("daswetter.0.NextDaysDetailed.1d.WindSymbolB", function(obj) {
          log (temp);
          setState('WindSymbol1', temp);
          on("daswetter.0.NextDaysDetailed.2d.SymbolID", function(obj) {
          log (temp);
          setState('WeatherSymbol2', temp );
          on("daswetter.0.NextDaysDetailed.2d.WindSymbolB", function(obj) {
          log (temp);
          setState('WindSymbol2', temp);
          on("daswetter.0.NextDaysDetailed.3d.SymbolID", function(obj) {
          log (temp);
          setState('WeatherSymbol3', temp );
          on("daswetter.0.NextDaysDetailed.3d.WindSymbolB", function(obj) {
          log (temp);
          setState('WindSymbol3', temp);
          on("daswetter.0.NextDaysDetailed.4d.SymbolID", function(obj) {
          log (temp);
          setState('WeatherSymbol4', temp );
          on("daswetter.0.NextDaysDetailed.4d.WindSymbolB", function(obj) {
          log (temp);
          setState('WindSymbol4', temp);
          Ist der von hier, habe lediglich die IP Adresse angepasst
          Das obere weather Widget hatte ich mir auch anders vorgestellt ... Zumindest wenn ich mal so vergleiche was man so sieht ...
          Rene_HM 2 Replies Last reply Reply Quote 0
          • Rene_HM
            @SMS und warum nimmst du die Pfade zu den Symbolen nicht direkt aus dem Adapter?
            Da könntest du dir das script sparen...
            • Rene_HM
              @SMS sagte in Adapter: DasWetter:
              Da kannst du doch fast alles selbst einstellen. Was fehlt dir?
              • SMS
                SMS last edited by
                Asso das muss alles einzeln eingestellt werden ... Dachte das wäre fertig ...
                • SMS
                  SMS @sigi234 last edited by
                  Das hier sind also alles einzelne Widgets?
                  • Negalein
                    Negalein Global Moderator @SMS last edited by
                    Ja
                    • CKMartens
                      CKMartens last edited by
                      seit dem js-controller 2.x habe ich diese Fehlermeldungen von daswetter:
                      host.iob01	2019-12-21 08:46:08.089	error	instance system.adapter.daswetter.0 terminated with code 15 (15)
                      daswetter.0	2019-12-21 08:46:07.450	warn	(4250) Terminated (15): Without reason
                      daswetter.0	2019-12-21 08:46:07.447	error	(4250) force terminate, objects still in list: 2374
                      Gibt es da einen Workaround?
                      • Rene_HM
                        Rene_HM Developer @CKMartens last edited by
                        @CKMartens versuch mal den parse timeout zu erhöhen. Wenn das nicht hilft, bitte debug-log. Im ersten Moment laut o.g. log sieht es aber einfach danach aus, als ob der Adapter mit dem parsen der Daten nicht fertig wird...
                        CKMartens 2 Replies Last reply Reply Quote 0
                        • CKMartens
                          CKMartens @Rene_HM last edited by
                          @Rene_HM sagte in Adapter: DasWetter:
                          OK danke, ich versuche es heute Abend mal einzustellen.
                          • CKMartens
                            Danke hat geholfen. Habe auf 120 Sekunden erhöht und bisher keine weiteren Fehlermeldung im Log
                            • magiczoom
                              magiczoom last edited by
                              ich möchte gerne den Adapter nutzen um mir in Lovelace das Wetter aus meiner Region anzeigen zu lassen.
                              Leider erscheinen bei mir nicht die entsprechenden Icons, sondern nur der jeweilige Pfad.
                              Ich habe schon versucht eine eigene Galerie anzulegen um diese dann anzeigen zu lassen, aber auch das hat nicht geholfen.
                              Kann mir dazu jemand weiterhelfen?
                              Anbei der Screenshot
                              Besten Dank
                              • Rene_HM
                                Rene_HM Developer @magiczoom last edited by
                                @magiczoom Der Plan mit dem Pfad war, dass du den als Input für z.Bsp. ein "string img src" verwendest:
                                  PatrickFro last edited by Negalein
                                  Moin,
                                  ich habe mich heute etwas mehr mit daswetter beschäftigt und habe 2 Fragen:
                                  Ich habe bisher keinen Unterschied gefunden. Warum gibt es 2 Datenpunkte für Next Hours?
                                  Aber für mich viel wichtiger: a838f289-f7c7-4c2b-bbde-59c5bee8e249-image.png
                                  Wie schaffe ich es, dass bei Current wirklich die aktuelle Stunde angezeigt wird? Im Beispiel 17 statt 18 Uhr..
                                  Im Javascript-Adapter und allgemein habe ich die korrekte Zeitzone drinnen (seit heute). Ich möchte gerne eine Lampe am Eingang blau leuchten lassen, wenn es regnet (oder zumindest die Chance groß ist). Hierfür ist die korrekte Zeit für mich sehr wichtig.
                                  • Rene_HM
                                    Rene_HM Developer last edited by
                                    @PatrickFro sagte in Adapter: DasWetter:
                                    Das liegt daran, dass du alle URL's, die dir DasWetter anbietet, eingegeben hast. Du brauchst aber nur die URL eingeben, für die Daten enthält, die dich interessieren. NextHours und NextHours2 unterscheiden sich darin, dass das Datenformat unterschiedlich ist. Inhaltlich sind sie identisch.
                                    Bei jedem update wird die Uhrzeit geprüft. Wenn du also einmal pro Stunde aktualisierst, bekommst du die Daten für die aktuelle Stunde in current.
                                    • JB_Sullivan
                                      JB_Sullivan last edited by
                                      Ich sage schonmal SORRY - aber 961 Beiträge habe ich mir jetzt nicht durchgelesen - nur für den Fall das meine Frage schonmal da gewesen ist.
                                      Ich bekomme von "daswetter" immer folgende Meldung ins LOG geschrieben - nicht das es stört, aber vielleicht ist es ja nur eine Kleinigkeit und man kann es relativ leicht abstellen.
                                      daswetter.0	2020-02-19 21:30:10.719	info	(6212) Terminated (NO_ERROR): Without reason
                                      daswetter.0	2020-02-19 21:30:02.856	info	(6212) got wrong data structure! trying to repair...
                                      daswetter.0	2020-02-19 21:30:01.571	info	(6212) starting. Version 2.8.1 in C:/iobroker/GLT/node_modules/iobroker.daswetter, node: v10.17.0
                                      Hat jemand eine Idee dazu, welches diese "wrong data structure" sein könnte?
                                      Meine VIS Seite die auf daswetter bassiert, sieht so aus. Also wenn ich das richtig sehe, gibt es da keine falschen oder fehlenden Werte.
                                      P Rene_HM 2 Replies Last reply Reply Quote 0
                                        PatrickFro @JB_Sullivan last edited by
                                        @JB_Sullivan sorry wenn ich beim eigentlichen Problem nicht helfen kann, aber deine VIS sieht sehr genial aus. Würdest Du einen Export zur Verfügung stellen?
                                        • JB_Sullivan
                                          JB_Sullivan @PatrickFro last edited by
                                          @PatrickFro
                                          Da kann ich leider nicht weiter helfen. Ich hatte schon öfters Anfragen bzgl. meiner VIS Bilder. Da da auch persönliche Daten drin stecken, muss ich einen anonymen Export machen - leider kackt dabei jedesmal der VIS Editor ab. Ich bekomme die VIS Bilder einfach nicht als komplettes Bild exportiert - ich müsste also alles Widget für Widget einzeln exportieren - dazu fehlt mir aber im Moment die Zeit.
                                            @JB_Sullivan Schade. Kannst Du vielleicht das unter Details befindliche Temperatur-Widget zur Verfügung stellen? Mir geht es nicht um das Bild sondern darum, wie Du das hinbekommen hast. Da dürften ja keine persönlichen Daten drinnen sein. Ich versuche es dann für mich nachzubauen.
                                            1198
                                            372627
