    4. Neue Installationsroutine (für Linux)
      Jan1 @nieIP last edited by Jan1
      @nieIP
      Ok, beim Pi eben Raspian 😎
      Lite ist ausreichend.
        marco-mh last edited by
        Hallo Leute, ich versuche schon seit Donnerstag den Iobroker auf einer QNAP TS251+ in der Linux Station unter Ubuntu 18.04 zu installieren.
        ich habe mich eigentlich an die Anleitung gehalten. node und nodejs sind 10.7, rpm ist 6.11.3
        ich bekomme folgende Ausgabe.
        User iobroker created
        Created /etc/sudoers.d/iobroker
        chown: invalid group: ‘admin:admin’
        Directory /opt/iobroker created
        touch: cannot touch '/opt/iobroker/INSTALLER_INFO.txt': Permission denied
        chmod: cannot access '/opt/iobroker/INSTALLER_INFO.txt': No such file or directory
        bash: line 724: /opt/iobroker/INSTALLER_INFO.txt: Permission denied
        bash: line 725: /opt/iobroker/INSTALLER_INFO.txt: Permission denied
        bash: line 726: /opt/iobroker/INSTALLER_INFO.txt: Permission denied
            Installing ioBroker (3/4)
        bash: line 746: /opt/iobroker/INSTALLER_INFO.txt: Permission denied
        npm ERR! code EACCES
        npm ERR! syscall access
        npm ERR! path /opt/iobroker
        npm ERR! errno -13
        npm ERR! Error: EACCES: permission denied, access '/opt/iobroker'
        npm ERR!  { [Error: EACCES: permission denied, access '/opt/iobroker']
        npm ERR!   stack: 'Error: EACCES: permission denied, access \'/opt/iobroker\'',
        npm ERR!   errno: -13,
        npm ERR!   code: 'EACCES',
        npm ERR!   syscall: 'access',
        npm ERR!   path: '/opt/iobroker' }
        npm ERR!
        npm ERR! The operation was rejected by your operating system.
        npm ERR! It is likely you do not have the permissions to access this file as the current user
        npm ERR!
        npm ERR! If you believe this might be a permissions issue, please double-check the
        npm ERR! permissions of the file and its containing directories, or try running
        npm ERR! the command again as root/Administrator.
        npm ERR!     /home/admin/.npm/_logs/2019-11-29T11_42_35_030Z-debug.log
            Finalizing installation (4/4)
        bash: line 772: /opt/iobroker/INSTALLER_INFO.txt: Permission denied
        Enabling autostart...
        Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /lib/systemd/system/iobroker.service.
        Autostart enabled!
        bash: line 947: /opt/iobroker/INSTALLER_INFO.txt: Permission denied
        Fixing directory permissions...
        This system does not support setting default permissions.
        Do not use npm to manually install adapters unless you know what you are doing!
        main: line 551: /opt/iobroker/INSTALLER_INFO.txt: Permission denied
        main: line 272: return: 192.168.178.10: numeric argument required
            ioBroker was installed successfully
            Open http://:8081 in a browser and start configuring!
        You need to re-login before doing anything else on the console!
        unter 16.04 in der Linux Station funktioniert es wunderbar.
        danke für eure hilfe und Gruß Marco
        apollon77 AlCalzone 2 Replies Last reply Reply Quote 0
          apollon77 @marco-mh last edited by
          @marco-mh Naja qnap ist halt leider kein echtes Linux sondern "custom" ... 😞 @AlCalzone
            Hab ich also keine Chance?
            schade, unter 16.04 gehts
            aber danke
            • AlCalzone
              AlCalzone Developer @marco-mh last edited by
              @marco-mh Ich bräuchte etwas mehr Infos über den User mit dem du angemeldet bist. Wie heißt dessen Gruppe? Normalerweise heißt die Gruppe wie der User.
              Als "echter" root sollte es gehen, aber dann bekommt admin keinen Zugriff aufs ioBroker-Verzeichnis.
                Ich hab es hinbekommen. Allerdings habe ich nicht die Linux Station genommen sondern hab eine Linux VM auf der QNAP installiert.
                Danke für die Hilfe
                  mpa last edited by mpa
                  ich versuche gerade iobroker auf einer VM mit Ubuntu LTS 18.04.3 zu installieren.
                  Mittlerweile habe ich jetzt mehrmals die Anleitung https://www.iobroker.net/#de/documentation/install/linux.md durchgeackert aber bekomme es leider nicht hin.
                  Beim Schritt "Installing ioBroker" bekomme ich immer folgende Fehlermeldungen:
                  ../src/unix_dgram.cc: In function ‘void {anonymous}::OnRecv({anonymous}::SocketContext*)’:
                  ../src/unix_dgram.cc:121:25: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                                       argv);
                  In file included from ../src/unix_dgram.cc:5:0:
                  ../../nan/nan.h:1024:46: note: declared here
                     NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
                  ../src/unix_dgram.cc: In function ‘void {anonymous}::OnWritable({anonymous}::SocketContext*)’:
                  ../src/unix_dgram.cc:129:28: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                                       0, NULL);
                  ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Socket(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/unix_dgram.cc:189:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                     domain      = info[0]->Int32Value();
                  In file included from /root/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,
                                   from /root/.cache/node-gyp/10.17.0/include/node/node.h:63,
                                   from ../../nan/nan.h:54,
                  /root/.cache/node-gyp/10.17.0/include/node/v8.h:2478:46: note: declared here
                     V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
                  /root/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
                     declarator __attribute__((deprecated(message)))
                  ../src/unix_dgram.cc:190:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                     type        = info[1]->Int32Value();
                  ../src/unix_dgram.cc:191:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                     protocol    = info[2]->Int32Value();
                  ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Bind(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/unix_dgram.cc:230:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                     fd = info[0]->Int32Value();
                  ../src/unix_dgram.cc:231:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                     String::Utf8Value path(info[1]);
                  /root/.cache/node-gyp/10.17.0/include/node/v8.h:2892:28: note: declared here
                                     explicit Utf8Value(Local<v8::Value> obj));
                  ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::SendTo(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/unix_dgram.cc:258:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                  ../src/unix_dgram.cc:259:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                     buf = info[1]->ToObject();
                  In file included from /root/.cache/node-gyp/10.17.0/include/node/node.h:63:0,
                  /root/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here
                   Local<Object> Value::ToObject() const {
                  ../src/unix_dgram.cc:260:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                     offset = info[2]->Uint32Value();
                  /root/.cache/node-gyp/10.17.0/include/node/v8.h:2477:47: note: declared here
                     V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);
                  ../src/unix_dgram.cc:261:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                     length = info[3]->Uint32Value();
                  ../src/unix_dgram.cc:262:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                     String::Utf8Value path(info[4]);
                  ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Send(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/unix_dgram.cc:302:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                  ../src/unix_dgram.cc:303:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                  ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Connect(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/unix_dgram.cc:340:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                  ../src/unix_dgram.cc:341:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                  ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Close(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/unix_dgram.cc:361:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                  Könnte mir hier bitte jemand weiterhelfen?
                  Vielen Dank!
                    apollon77 last edited by
                    Alles nur Warnungen, ignorieren. Wichtig ist was die letzten Zeilen der gesamten Ausgabe sind ... wenn da steht das alles ok ist dann ist alles ok
                      mpa @apollon77 last edited by
                      @apollon77 da kommt dann leider nichts mehr, da sich die VM aufhängt und Putty dadurch die Verbindung verliert.
                        A Former User last edited by
                        Ich versuche gerade, den ioBroker unter Lubuntu zum Laufen zu bringen.
                        Hierzu habe ich mich an die folgende Anleitung gehalten:
                        Es sei wohl auch alles erfolgreich installiert worden.
                        Nur komme ich mit dem Browser nicht auf die Oberfläche.
                        http://<iplocalhost>:8081
                        Es kommt, Seite ist nicht erreichbar
                        ioborker habe ich mit iobroker stop/start als auch restart probiert neu zu starten
                        Ich habe dann mal probiert
                        iobroker start admin
                        Dann kommt:
                        module.js:549
                        throw err;
                        Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                        at Function.Module._resolveFilename (module.js:547:15)
                        AlCalzone Homoran 2 Replies Last reply Reply Quote 0
                        • AlCalzone
                          AlCalzone Developer @Guest last edited by
                          @Alina sagte in Neue Installationsroutine (für Linux):
                          Das sieht mir nicht nach einer erfolgreichen Installation aus. Probiere es bitte nochmal und zeig uns dann die Ausgabe der Installation.
                            Homoran Global Moderator Administrators @Guest last edited by
                            @Alina
                            Wieso zwei Threads dazu?
                            Habe dir in dem anderen / älteren geantwortet
                              debianatoe last edited by
                              Kann man die neue Linux-Installationsroutine auch in buildroot-Systemen ausführen? buildroot ist ja ein besonders platzsparendes Linux. Das hätte dann insbesondere auf kleinen raspi-Systemen den Vorteil, daß man mehr RAM für den iobroker zur Verfügung hätte.
                                apollon77 @debianatoe last edited by
                                @debianatoe @AlCalzone ?!
                                • AlCalzone
                                  AlCalzone Developer @apollon77 last edited by
                                  @apollon77 @debianatoe
                                  Probier es aus. Ich hab keine Ahnung und bisher nicht davon gehört.
                                    Homoran Global Moderator Administrators @apollon77 last edited by
                                    @apollon77 Ich denke eher nicht.
                                    die CCU baut auf buildroot auf - wenn ich mich richtig erinnere hat sich Jens Maus da schon dran versucht
                                      debianatoe @Homoran last edited by
                                      @Homoran Ja, die CCU baut auf buildroot auf. Aber buildroot läßt sich sehr variabel konfigurieren. Insofern wäre es denkbar, daß sich ein spezielles iobroker-buildroot, das mit dem CCU-buildroot nur wenig gemeinsam hat, bauen ließe. Wenn sich allerdings Jens Maus daran schon vergeblich (?) versucht hat, klingt das nach erheblichem Aufwand ...
                                      Da wäre aus meiner Sicht ein iobroker-Installationsprofi gefragt, der genau weiß, welche Betriebssystem- und library-Bedingungen Voraussetzung sind.
                                        @debianatoe Am Ende stht alles im install.sh drin was auf Github steht ... alles ws fehlt wird nachinstalliert aktuell per apt oder yum
                                        • AlCalzone
                                          @apollon77 sagte in Neue Installationsroutine (für Linux):
                                          Das bezieht sich aber auf das, was wir von "normalen" Linux-Systemen kennen und wissen. Ggf muss bei buildroot noch mehr installiert werden.
                                            debianatoe @AlCalzone last edited by
                                            @AlCalzone sagte in Neue Installationsroutine (für Linux):
                                            So ist es leider. Im buildroot-Linux gibt es meines Wissens nach weder apt noch yum. Deshalb kann install.sh in dieser Form leider nicht funktionieren bzw. alles, was fehlt, nachinstallieren. Stand jetzt wäre das eine Menge Handarbeit.
                                            installation
                                            64
                                            415
                                            114507
