    4. Test Adapter Hue v2.4.x
    • foxriver76
      foxriver76 Developer @Negalein last edited by foxriver76
      @Negalein k probiere es heute Abend mal nachzustellen bei mir.
      Kannst du mir noch ein Screen der Widget Config zeigen.
      • Negalein
        Negalein Global Moderator @foxriver76 last edited by
        @foxriver76 sagte in Test Adapter Hue v2.4.x:
        • foxriver76
          @Negalein Finde kein colorpicker Widget in vis, ist das aus einem Adapter oder wie heißt es genau?
          Habe probiert genau den Befehl zu senden wie es dein Widget tut:
          {"transitiontime":1,"xy":"0.5255681818181818,0.86015625","level":100}
          So schaut das dann aus:
          2019-12-19 18:30:21.865 - debug: hue.0 (30635) stateChange hue.0.Nachttisch_Eins.command {"val":"{\"transitiontime\":1,\"xy\":\"0.5255681818181818,0.86015625\",\"level\":100}","ack":false,"ts":1576776621847,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1576776342881}
          2019-12-19 18:30:21.927 - debug: hue.0 (30635) final lightState for Nachttisch Eins:{"bri":254,"on":true,"xy":"0.33270596590909096,0.667294034090909","r":161,"g":254,"b":0,"transitiontime":1,"colormode":"xy","level":100}
          2019-12-19 18:30:22.038 - debug: hue.0 (30635) lights.setLightState:24:01b16972126b418291bcb104deda7a1b result: true
          2019-12-19 18:30:22.191 - debug: hue.0 (30635) polling light Nachttisch Eins (24) with prio 3
          2019-12-19 18:30:22.245 - debug: hue.0 (30635) lights.getLightById:24:94d8ee07882199f19e536e846e91773d result: {"_rawData":{"state":{"on":true,"bri":254,"hue":19723,"sat":254,"effect":"none","xy":[0.3327,0.6673],"ct":153,"alert":"select","colormode":"xy","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2019-12-19T09:41:55"},"type":"Extended color light","name":"Nachttisch Eins","modelid":"LCT026","manufacturername":"Philips","productname":"Hue go","capabilities":{"certified":true,"control":{"mindimlevel":70,"maxlumen":400,"colorgamuttype":"C","colorgamut":[[0.6915,0.3083],[0.17,0.7],[0.1532,0.0475]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true,"proxy":true}},"config":{"archetype":"huego","function":"decorative","direction":"omnidirectional","startup":{"mode":"safety","configured":true}},"uniqueid":"00:17:88:01:06:f9:66:50-0b","swversion":"1.56.8_r30456","swconfigid":"AF1CA01E","productid":"Philips-LCT026-1-HueGo_v2"},"_id":24,"mappedColorGamut":"C"}
          2019-12-19 18:30:22.327 - debug: hue.0 (30635) updated lighstate(24) after change
          Bei dir werden aber zusätzliche State changes für je rgb direkt ausgelöst, zu dem State existiert kein Objekt (soll auch nicht). Entweder hast du ein Skript laufen, oder das Widget macht da was komisches. Siehe deine getriggerten State Changes:
          hue.0	2019-12-18 17:42:05.047	debug	(18324) stateChange hue.0.Philips_hue.Wintergarten.b {"val":0,"ack":false,"ts":1576687325041,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1576687325041}
          hue.0	2019-12-18 17:42:05.046	debug	(18324) stateChange hue.0.Philips_hue.Wintergarten.g {"val":255,"ack":false,"ts":1576687325040,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1576687325040}
          hue.0	2019-12-18 17:42:05.044	debug	(18324) stateChange hue.0.Philips_hue.Wintergarten.r {"val":162,"ack":false,"ts":1576687325040,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1576687325040}
          hue.0	2019-12-18 17:42:05.037	debug	(18324) stateChange hue.0.Wintergarten.command {"val":"{\"transitiontime\":1,\"xy\":\"0.5255681818181818,0.86015625\",\"level\":100}","ack":false,"ts":1576687325032,"q":0,"from":"system.adapter.web.0"
          Leider ist dein Log abgeschnitten, wenn du Log herunterladen klickst oder direkt aus dem File kopierst, werden die Zeilen nicht abgeschnitten.
          • Negalein
            Es ist das vis-colorpicker.0
            Kein Script dafür in Verwendung.
            hier das Debug-Log von gestern um 17:42 ca.
            new 3.txt
            • foxriver76
              @Negalein
              2019-12-18 17:42:05.044  - debug: hue.0 (18324) stateChange hue.0.Philips_hue.Wintergarten.r {"val":162,"ack":false,"ts":1576687325040,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1576687325040}
              2019-12-18 17:42:05.046  - debug: hue.0 (18324) stateChange hue.0.Philips_hue.Wintergarten.g {"val":255,"ack":false,"ts":1576687325040,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1576687325040}
              2019-12-18 17:42:05.047  - debug: hue.0 (18324) stateChange hue.0.Philips_hue.Wintergarten.b {"val":0,"ack":false,"ts":1576687325041,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1576687325041}
              Wird auf jeden Fall durch web gesetzt.
              • foxriver76
                @Negalein In deinem Widget, unter der Konfiguration von 'Allgemein' gibt es RGB als Reiter, da sind deine DP falsch gesetzt.
                • Negalein
                  komisch!
                  Wintergarten hab ich definitiv mit dem Widget geschaltet.
                  Ist sonst nirgends eingebaut.
                  also R G B dann komplett raus?
                  • foxriver76
                    @Negalein Ne, aber da steht ja überall hue.0.Phillips_hue.Wintergarten... die neue Struktur ist ja nur noch hue.0.Wintergarten.... Einfach entsprechend anpassen, hast du da wohl übersehen gehabt.
                    • Negalein
                      Ahhhh, hab ich tatsächlich übersehen.
                      Danke, werde wieder berichten.
                      • foxriver76
                        foxriver76 Developer last edited by foxriver76
                        Hier gehts weiter.
                        Hier darf bitte zugemacht werden. Danke.
                        31.7k
                        79.8k
                        hue tester testing
                        1172
